[U-Boot] [PATCH 0/2] GPIO: CREG: improve flexibility of hsdk-creg-gpio driver
CREG GPIO is a driver for weird soc-specific output ports, which are controlled by some fields in memory mapped register.
Example:
31 9 7 5 0 < bit number | | | | | [ not used | gpio-1 | gpio-0 | <-shift-> ] < 32 bit register ^ ^ | | write 0x2 == set output to "1" (activate) write 0x3 == set output to "0" (deactivate)
As of tooday we only support fixed (hardcoded) bit per gpio line, activate / deactivatei and shift values. Fix that by read them from device tree to be able to use this driver for other boards.
Eugeniy Paltsev (2): GPIO: CREG: improve flexibility of hsdk-creg-gpio driver CREG GPIO: add device tree bindings
MAINTAINERS | 1 + arch/arc/dts/hsdk.dts | 7 +- doc/device-tree-bindings/gpio/snps,creg-gpio.txt | 43 ++++++++++ drivers/gpio/hsdk-creg-gpio.c | 103 ++++++++++++++++++----- 4 files changed, 131 insertions(+), 23 deletions(-) create mode 100644 doc/device-tree-bindings/gpio/snps,creg-gpio.txt
Example:
Remove "hsdk" prefix from compatible string as this driver can be used with different boards like HSDK, AXS101, AXS103, etc.
Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com --- arch/arc/dts/hsdk.dts | 7 ++- drivers/gpio/hsdk-creg-gpio.c | 103 +++++++++++++++++++++++++++++++++--------- 2 files changed, 87 insertions(+), 23 deletions(-)
diff --git a/arch/arc/dts/hsdk.dts b/arch/arc/dts/hsdk.dts index 264512877e..e41e4ce84b 100644 --- a/arch/arc/dts/hsdk.dts +++ b/arch/arc/dts/hsdk.dts @@ -101,11 +101,16 @@ };
cs_gpio: gpio@f00014b0 { - compatible = "snps,hsdk-creg-gpio"; + compatible = "snps,creg-gpio"; reg = <0xf00014b0 0x4>; gpio-controller; #gpio-cells = <1>; gpio-bank-name = "hsdk-spi-cs"; gpio-count = <1>; + gpio-first-shift = <0>; + gpio-bit-per-line = <2>; + gpio-activate-val = <2>; + gpio-deactivate-val = <3>; + gpio-default-val = <1>; }; }; diff --git a/drivers/gpio/hsdk-creg-gpio.c b/drivers/gpio/hsdk-creg-gpio.c index 084a2da652..800027f18e 100644 --- a/drivers/gpio/hsdk-creg-gpio.c +++ b/drivers/gpio/hsdk-creg-gpio.c @@ -16,25 +16,24 @@ #include <errno.h> #include <linux/printk.h>
-#define HSDK_CREG_MAX_GPIO 8 - -#define GPIO_ACTIVATE 0x2 -#define GPIO_DEACTIVATE 0x3 -#define GPIO_PIN_MASK 0x3 -#define BIT_PER_GPIO 2 +#define DRV_NAME "gpio_creg"
struct hsdk_creg_gpio { - uint32_t *regs; + u32 *regs; + u8 shift; + u8 activate; + u8 deactivate; + u8 bit_per_gpio; };
static int hsdk_creg_gpio_set_value(struct udevice *dev, unsigned oft, int val) { struct hsdk_creg_gpio *hcg = dev_get_priv(dev); - uint32_t reg = readl(hcg->regs); - uint32_t cmd = val ? GPIO_DEACTIVATE : GPIO_ACTIVATE; + u8 reg_shift = oft * hcg->bit_per_gpio + hcg->shift; + u32 reg = readl(hcg->regs);
- reg &= ~(GPIO_PIN_MASK << (oft * BIT_PER_GPIO)); - reg |= (cmd << (oft * BIT_PER_GPIO)); + reg &= ~(GENMASK(hcg->bit_per_gpio - 1, 0) << reg_shift); + reg |= ((val ? hcg->deactivate : hcg->activate) << reg_shift);
writel(reg, hcg->regs);
@@ -51,7 +50,9 @@ static int hsdk_creg_gpio_direction_output(struct udevice *dev, unsigned oft,
static int hsdk_creg_gpio_direction_input(struct udevice *dev, unsigned oft) { - pr_err("hsdk-creg-gpio can't be used as input!\n"); + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + + pr_err("%s can't be used as input!\n", uc_priv->bank_name);
return -ENOTSUPP; } @@ -59,10 +60,11 @@ static int hsdk_creg_gpio_direction_input(struct udevice *dev, unsigned oft) static int hsdk_creg_gpio_get_value(struct udevice *dev, unsigned int oft) { struct hsdk_creg_gpio *hcg = dev_get_priv(dev); - uint32_t val = readl(hcg->regs); + u32 val = readl(hcg->regs);
- val = (val >> (oft * BIT_PER_GPIO)) & GPIO_PIN_MASK; - return (val == GPIO_DEACTIVATE) ? 1 : 0; + val >>= oft * hcg->bit_per_gpio + hcg->shift; + val &= GENMASK(hcg->bit_per_gpio - 1, 0); + return (val == hcg->deactivate) ? 1 : 0; }
static const struct dm_gpio_ops hsdk_creg_gpio_ops = { @@ -76,17 +78,74 @@ static int hsdk_creg_gpio_probe(struct udevice *dev) { struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); struct hsdk_creg_gpio *hcg = dev_get_priv(dev); + u32 shift, bit_per_gpio, activate, deactivate, gpio_count; + const u8 *defaults;
- hcg->regs = (uint32_t *)devfdt_get_addr_ptr(dev); - - uc_priv->gpio_count = dev_read_u32_default(dev, "gpio-count", 1); - if (uc_priv->gpio_count > HSDK_CREG_MAX_GPIO) - uc_priv->gpio_count = HSDK_CREG_MAX_GPIO; + hcg->regs = (u32 *)devfdt_get_addr_ptr(dev); + gpio_count = dev_read_u32_default(dev, "gpio-count", 1); + shift = dev_read_u32_default(dev, "gpio-first-shift", 0); + bit_per_gpio = dev_read_u32_default(dev, "gpio-bit-per-line", 1); + activate = dev_read_u32_default(dev, "gpio-activate-val", 1); + deactivate = dev_read_u32_default(dev, "gpio-deactivate-val", 0); + defaults = dev_read_u8_array_ptr(dev, "gpio-default-val", gpio_count);
uc_priv->bank_name = dev_read_string(dev, "gpio-bank-name"); if (!uc_priv->bank_name) uc_priv->bank_name = dev_read_name(dev);
+ if (!bit_per_gpio) { + pr_err("%s: 'gpio-bit-per-line' can't be 0\n", + uc_priv->bank_name); + + return -EINVAL; + } + + if (!gpio_count) { + pr_err("%s: 'gpio-count' can't be 0\n", + uc_priv->bank_name); + + return -EINVAL; + } + + if ((gpio_count * bit_per_gpio + shift) > 32) { + pr_err("%s: u32 io register overflow: try to use %u bits\n", + uc_priv->bank_name, gpio_count * bit_per_gpio + shift); + + return -EINVAL; + } + + if (GENMASK(31, bit_per_gpio) & activate) { + pr_err("%s: 'gpio-activate-val' can't be more than %lu\n", + uc_priv->bank_name, GENMASK(bit_per_gpio - 1, 0)); + + return -EINVAL; + } + + if (GENMASK(31, bit_per_gpio) & deactivate) { + pr_err("%s: 'gpio-deactivate-val' can't be more than %lu\n", + uc_priv->bank_name, GENMASK(bit_per_gpio - 1, 0)); + + return -EINVAL; + } + + if (activate == deactivate) { + pr_err("%s: 'gpio-deactivate-val' and 'gpio-activate-val' can't be equal\n", + uc_priv->bank_name); + + return -EINVAL; + } + + hcg->shift = (u8)shift; + hcg->bit_per_gpio = (u8)bit_per_gpio; + hcg->activate = (u8)activate; + hcg->deactivate = (u8)deactivate; + uc_priv->gpio_count = gpio_count; + + /* Setup default GPIO value if we have "gpio-default-val" array */ + if (defaults) + for (u8 i = 0; i < gpio_count; i++) + hsdk_creg_gpio_set_value(dev, i, defaults[i]); + pr_debug("%s GPIO [0x%p] controller with %d gpios probed\n", uc_priv->bank_name, hcg->regs, uc_priv->gpio_count);
@@ -94,12 +153,12 @@ static int hsdk_creg_gpio_probe(struct udevice *dev) }
static const struct udevice_id hsdk_creg_gpio_ids[] = { - { .compatible = "snps,hsdk-creg-gpio" }, + { .compatible = "snps,creg-gpio" }, { } };
U_BOOT_DRIVER(gpio_hsdk_creg) = { - .name = "gpio_hsdk_creg", + .name = DRV_NAME, .id = UCLASS_GPIO, .ops = &hsdk_creg_gpio_ops, .probe = hsdk_creg_gpio_probe,
Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com --- MAINTAINERS | 1 + doc/device-tree-bindings/gpio/snps,creg-gpio.txt | 43 ++++++++++++++++++++++++ 2 files changed, 44 insertions(+) create mode 100644 doc/device-tree-bindings/gpio/snps,creg-gpio.txt
diff --git a/MAINTAINERS b/MAINTAINERS index 642c448093..0ea730e33c 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -74,6 +74,7 @@ ARC HSDK CREG GPIO M: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com S: Maintained L: uboot-snps-arc@synopsys.com +F: doc/device-tree-bindings/gpio/snps,creg-gpio.txt F: drivers/gpio/hsdk-creg-gpio.c
ARM diff --git a/doc/device-tree-bindings/gpio/snps,creg-gpio.txt b/doc/device-tree-bindings/gpio/snps,creg-gpio.txt new file mode 100644 index 0000000000..46ceb65c53 --- /dev/null +++ b/doc/device-tree-bindings/gpio/snps,creg-gpio.txt @@ -0,0 +1,43 @@ +GPIO via CREG (control registers) driver + +31 9 7 5 0 < bit number +| | | | | +[ not used | gpio-1 | gpio-0 | <-shift-> ] < 32 bit register + ^ ^ + | | + write 0x2 == set output to "1" (activate) + write 0x3 == set output to "0" (deactivate) + +Required properties: +- compatible : "snps,creg-gpio" +- reg : Exactly one register range with length 0x4. +- #gpio-cells : Should be one - the pin number. +- gpio-controller : Marks the device node as a GPIO controller. +- gpio-count: Number of GPIO pins. +- gpio-bit-per-line: Number of bits per gpio line (see picture). +- gpio-first-shift: Shift (in bits) of the first GPIO field in register + (see picture). +- gpio-activate-val: Value should be set in corresponding field to set + output to "1" (see picture). Applied to all GPIO ports. +- gpio-deactivate-val: Value should be set in corresponding field to set + output to "0" (see picture). Applied to all GPIO ports. + +Optional properties: +- gpio-bank-name: name of bank (as default driver name is used is used) +- gpio-default-val: array of default output values (must me 0 or 1) + +Example (see picture): + +gpio: gpio@f00014b0 { + compatible = "snps,creg-gpio"; + reg = <0xf00014b0 0x4>; + gpio-controller; + #gpio-cells = <1>; + gpio-bank-name = "hsdk-spi-cs"; + gpio-count = <2>; + gpio-first-shift = <5>; + gpio-bit-per-line = <2>; + gpio-activate-val = <2>; + gpio-deactivate-val = <3>; + gpio-default-val = <1 1>; +};
Eugeniy Paltsev
