[U-Boot] [PATCH v3 8/8] ehci: Optimize qTD allocations
Relax the qTD transfer alignment constraints in order to need less qTDs for buffers that are aligned to 512 bytes but not to pages.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Marek Vasut marex@denx.de Cc: Ilya Yanok ilya.yanok@cogentembedded.com Cc: Stefan Herbrechtsmeier stefan@herbrechtsmeier.net --- Changes for v2: N/A. Changes for v3: - New patch.
.../drivers/usb/host/ehci-hcd.c | 68 +++++++++++--------- 1 file changed, 38 insertions(+), 30 deletions(-)
diff --git u-boot-usb-8d5fb14.orig/drivers/usb/host/ehci-hcd.c u-boot-usb-8d5fb14/drivers/usb/host/ehci-hcd.c index 84c7d08..37517cb 100644 --- u-boot-usb-8d5fb14.orig/drivers/usb/host/ehci-hcd.c +++ u-boot-usb-8d5fb14/drivers/usb/host/ehci-hcd.c @@ -215,7 +215,7 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, volatile struct qTD *vtd; unsigned long ts; uint32_t *tdp; - uint32_t endpt, token, usbsts; + uint32_t endpt, maxpacket, token, usbsts; uint32_t c, toggle; uint32_t cmd; int timeout; @@ -230,6 +230,7 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, le16_to_cpu(req->value), le16_to_cpu(req->value), le16_to_cpu(req->index));
+#define PKT_ALIGN 512 /* * The USB transfer is split into qTD transfers. Eeach qTD transfer is * described by a transfer descriptor (the qTD). The qTDs form a linked @@ -251,43 +252,41 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, if (length > 0 || req == NULL) { /* * Determine the qTD transfer size that will be used for the - * data payload (not considering the final qTD transfer, which - * may be shorter). + * data payload (not considering the first qTD transfer, which + * may be longer or shorter, and the final one, which may be + * shorter). * * In order to keep each packet within a qTD transfer, the qTD - * transfer size is aligned to EHCI_PAGE_SIZE, which is a - * multiple of wMaxPacketSize (except in some cases for - * interrupt transfers, see comment in submit_int_msg()). + * transfer size is aligned to PKT_ALIGN, which is a multiple of + * wMaxPacketSize (except in some cases for interrupt transfers, + * see comment in submit_int_msg()). * - * By default, i.e. if the input buffer is page-aligned, + * By default, i.e. if the input buffer is aligned to PKT_ALIGN, * QT_BUFFER_CNT full pages will be used. */ int xfr_sz = QT_BUFFER_CNT; /* - * However, if the input buffer is not page-aligned, the qTD - * transfer size will be one page shorter, and the first qTD + * However, if the input buffer is not aligned to PKT_ALIGN, the + * qTD transfer size will be one page shorter, and the first qTD * data buffer of each transfer will be page-unaligned. */ - if ((uint32_t)buffer & (EHCI_PAGE_SIZE - 1)) + if ((uint32_t)buffer & (PKT_ALIGN - 1)) xfr_sz--; /* Convert the qTD transfer size to bytes. */ xfr_sz *= EHCI_PAGE_SIZE; /* - * Determine the number of qTDs that will be required for the - * data payload. This value has to be rounded up since the final - * qTD transfer may be shorter than the regular qTD transfer - * size that has just been computed. + * Approximate by excess the number of qTDs that will be + * required for the data payload. The exact formula is way more + * complicated and saves at most 2 qTDs, i.e. a total of 128 + * bytes. */ - qtd_count += DIV_ROUND_UP(length, xfr_sz); - /* ZLPs also need a qTD. */ - if (!qtd_count) - qtd_count++; + qtd_count += 2 + length / xfr_sz; } /* - * Threshold value based on the worst-case total size of the qTDs to allocate - * for a mass-storage transfer of 65535 blocks of 512 bytes. + * Threshold value based on the worst-case total size of the allocated qTDs for + * a mass-storage transfer of 65535 blocks of 512 bytes. */ -#if CONFIG_SYS_MALLOC_LEN <= 128 * 1024 +#if CONFIG_SYS_MALLOC_LEN <= 64 + 128 * 1024 #warning CONFIG_SYS_MALLOC_LEN may be too small for EHCI #endif qtd = memalign(USB_DMA_MINALIGN, qtd_count * sizeof(struct qTD)); @@ -314,9 +313,10 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, qh->qh_link = cpu_to_hc32((uint32_t)qh_list | QH_LINK_TYPE_QH); c = (usb_pipespeed(pipe) != USB_SPEED_HIGH && usb_pipeendpoint(pipe) == 0); + maxpacket = usb_maxpacket(dev, pipe); endpt = (8 << QH_ENDPT1_RL) | (c << QH_ENDPT1_C) | - (usb_maxpacket(dev, pipe) << QH_ENDPT1_MAXPKTLEN) | + (maxpacket << QH_ENDPT1_MAXPKTLEN) | (0 << QH_ENDPT1_H) | (QH_ENDPT1_DTC_DT_FROM_QTD << QH_ENDPT1_DTC) | (usb_pipespeed(pipe) << QH_ENDPT1_EPS) | @@ -362,6 +362,7 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, }
if (length > 0 || req == NULL) { + uint32_t qtd_toggle = toggle; uint8_t *buf_ptr = buffer; int left_length = length;
@@ -379,9 +380,9 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, xfr_bytes -= (uint32_t)buf_ptr & (EHCI_PAGE_SIZE - 1); /* * In order to keep each packet within a qTD transfer, - * align the qTD transfer size to EHCI_PAGE_SIZE. + * align the qTD transfer size to PKT_ALIGN. */ - xfr_bytes &= ~(EHCI_PAGE_SIZE - 1); + xfr_bytes &= ~(PKT_ALIGN - 1); /* * This transfer may be shorter than the available qTD * transfer size that has just been computed. @@ -401,7 +402,7 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, cpu_to_hc32(QT_NEXT_TERMINATE); qtd[qtd_counter].qt_altnext = cpu_to_hc32(QT_NEXT_TERMINATE); - token = (toggle << QT_TOKEN_DT) | + token = (qtd_toggle << QT_TOKEN_DT) | (xfr_bytes << QT_TOKEN_TOTALBYTES) | ((req == NULL) << QT_TOKEN_IOC) | (0 << QT_TOKEN_CPAGE) | @@ -418,6 +419,13 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, /* Update previous qTD! */ *tdp = cpu_to_hc32((uint32_t)&qtd[qtd_counter]); tdp = &qtd[qtd_counter++].qt_next; + /* + * Data toggle has to be adjusted since the qTD transfer + * size is not always an even multiple of + * wMaxPacketSize. + */ + if ((xfr_bytes / maxpacket) & 1) + qtd_toggle ^= 1; buf_ptr += xfr_bytes; left_length -= xfr_bytes; } while (left_length > 0); @@ -944,11 +952,11 @@ submit_int_msg(struct usb_device *dev, unsigned long pipe, void *buffer, * because bInterval is ignored. * * Also, ehci_submit_async() relies on wMaxPacketSize being a power of 2 - * if several qTDs are required, while the USB specification does not - * constrain this for interrupt transfers. That means that - * ehci_submit_async() would support interrupt transfers requiring - * several transactions only as long as the transfer size does not - * require more than a single qTD. + * <= PKT_ALIGN if several qTDs are required, while the USB + * specification does not constrain this for interrupt transfers. That + * means that ehci_submit_async() would support interrupt transfers + * requiring several transactions only as long as the transfer size does + * not require more than a single qTD. */ if (length > usb_maxpacket(dev, pipe)) { printf("%s: Interrupt transfers requiring several transactions "
Dear Benoît Thébaudeau,
- New patch.
I'll need to go through this patch one more time ... can you please just check my comments on 1/8? The rest are all right (but this, which I'll review tomorrow I hope).
Thanks a lot for your {code, time, contribution, patience with lousy usb maintainership}!
Best regards, Marek Vasut
- New patch.
- uint32_t endpt, maxpacket, token, usbsts; uint32_t c, toggle; uint32_t cmd; int timeout;
Make this const int maybe ?
* may be shorter).
* shorter).
- In order to keep each packet within a qTD transfer, the qTD
- QT_BUFFER_CNT full pages will be used.
- data buffer of each transfer will be page-unaligned.
/* Convert the qTD transfer size to bytes. */ xfr_sz *= EHCI_PAGE_SIZE; /*if ((uint32_t)buffer & (PKT_ALIGN - 1)) xfr_sz--;
*/* bytes.
if (!qtd_count)
qtd_count++;
}qtd_count += 2 + length / xfr_sz;
- Threshold value based on the worst-case total size of the qTDs to
- Threshold value based on the worst-case total size of the allocated
- maxpacket = usb_maxpacket(dev, pipe); endpt = (8 << QH_ENDPT1_RL) | (c << QH_ENDPT1_C) |
Is this change really needed? (not that I care much).
Took me a bit to make it through, but I think I get it ... just real nits above.
Dear Marek Vasut,
- New patch.
Why? I don't see any need for this.
* may be shorter).
* shorter).
*/* bytes.
if (!qtd_count)
qtd_count++;
It's here only to avoid calling the usb_maxpacket() function several times for nothing since it is also called later in the patch.
OK. Tell me if you have any question.
I don't think any change is needed, all the more you have already applied this patch.
Best regards, Benoît
Dear Marek Vasut,
Changes for v3:
- New patch.
Typecheck maybe, but it's not so important.
* may be shorter).
* shorter).
* bytes.
if (!qtd_count)
qtd_count++;
Ah ok.
I did? Heh ... must have been a mistake, but all right, I don't see much trouble with this one anyway :)
Well then we're done here ... thanks for your patches!
Benoît Thébaudeau
