[U-Boot-Users] [PATCH 2/2] Freescale eLBC FCM NAND driver
This is a driver for the Flash Control Machine of the enhanched Local Bus Controller found on some Freescale chips (such as the mpc8313 and the mpc8379).
Signed-off-by: Scott Wood scottwood@freescale.com --- This patch applies to the mtd-2.6.22.1 branch of the nand tree.
drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/fsl_elbc_nand.c | 764 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 765 insertions(+), 0 deletions(-) create mode 100644 drivers/mtd/nand/fsl_elbc_nand.c
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 244fa09..470f63f 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -32,6 +32,7 @@ COBJS-y += nand_ecc.o COBJS-y += nand_bbt.o COBJS-y += nand_util.o
+COBJS-y += fsl_elbc_nand.o COBJS-y += fsl_upm.o
COBJS := $(COBJS-y) diff --git a/drivers/mtd/nand/fsl_elbc_nand.c b/drivers/mtd/nand/fsl_elbc_nand.c new file mode 100644 index 0000000..ceb3529 --- /dev/null +++ b/drivers/mtd/nand/fsl_elbc_nand.c @@ -0,0 +1,764 @@ +/* Freescale Enhanced Local Bus Controller FCM NAND driver + * + * Copyright (c) 2006-2008 Freescale Semiconductor + * + * Authors: Nick Spence nick.spence@freescale.com, + * Scott Wood scottwood@freescale.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> + +#if defined(CONFIG_CMD_NAND) && defined(CONFIG_NAND_FSL_ELBC) + +#include <malloc.h> + +#include <linux/mtd/mtd.h> +#include <linux/mtd/nand.h> +#include <linux/mtd/nand_ecc.h> + +#include <asm/io.h> +#include <asm/errno.h> + +#ifdef VERBOSE_DEBUG +#define DEBUG_ELBC +#define vdbg(format, arg...) printf("DEBUG: " format, ##arg) +#else +#define vdbg(format, arg...) do {} while (0) +#endif + +/* Can't use plain old DEBUG because the linux mtd + * headers define it as a macro. + */ +#ifdef DEBUG_ELBC +#define dbg(format, arg...) printf("DEBUG: " format, ##arg) +#else +#define dbg(format, arg...) do {} while (0) +#endif + +#define MAX_BANKS 8 +#define ERR_BYTE 0xFF /* Value returned for read bytes when read failed */ +#define FCM_TIMEOUT_MSECS 10 /* Maximum number of mSecs to wait for FCM */ + +#define LTESR_NAND_MASK (LTESR_FCT | LTESR_PAR | LTESR_CC) + +struct fsl_elbc_ctrl; + +/* mtd information per set */ + +struct fsl_elbc_mtd { + struct mtd_info mtd; + struct nand_chip chip; + struct fsl_elbc_ctrl *ctrl; + + struct device *dev; + int bank; /* Chip select bank number */ + u8 __iomem *vbase; /* Chip select base virtual address */ + int page_size; /* NAND page size (0=512, 1=2048) */ + unsigned int fmr; /* FCM Flash Mode Register value */ +}; + +/* overview of the fsl elbc controller */ + +struct fsl_elbc_ctrl { + struct nand_hw_control controller; + struct fsl_elbc_mtd *chips[MAX_BANKS]; + + /* device info */ + lbus83xx_t *regs; + u8 __iomem *addr; /* Address of assigned FCM buffer */ + unsigned int page; /* Last page written to / read from */ + unsigned int read_bytes; /* Number of bytes read during command */ + unsigned int column; /* Saved column from SEQIN */ + unsigned int index; /* Pointer to next byte to 'read' */ + unsigned int status; /* status read from LTESR after last op */ + unsigned int mdr; /* UPM/FCM Data Register value */ + unsigned int use_mdr; /* Non zero if the MDR is to be set */ + unsigned int oob; /* Non zero if operating on OOB data */ + uint8_t *oob_poi; /* Place to write ECC after read back */ +}; + +/* These map to the positions used by the FCM hardware ECC generator */ + +/* Small Page FLASH with FMR[ECCM] = 0 */ +static struct nand_ecclayout fsl_elbc_oob_sp_eccm0 = { + .eccbytes = 3, + .eccpos = {6, 7, 8}, + .oobfree = { {0, 5}, {9, 7} }, + .oobavail = 12, +}; + +/* Small Page FLASH with FMR[ECCM] = 1 */ +static struct nand_ecclayout fsl_elbc_oob_sp_eccm1 = { + .eccbytes = 3, + .eccpos = {8, 9, 10}, + .oobfree = { {0, 5}, {6, 2}, {11, 5} }, + .oobavail = 12, +}; + +/* Large Page FLASH with FMR[ECCM] = 0 */ +static struct nand_ecclayout fsl_elbc_oob_lp_eccm0 = { + .eccbytes = 12, + .eccpos = {6, 7, 8, 22, 23, 24, 38, 39, 40, 54, 55, 56}, + .oobfree = { {1, 5}, {9, 13}, {25, 13}, {41, 13}, {57, 7} }, + .oobavail = 48, +}; + +/* Large Page FLASH with FMR[ECCM] = 1 */ +static struct nand_ecclayout fsl_elbc_oob_lp_eccm1 = { + .eccbytes = 12, + .eccpos = {8, 9, 10, 24, 25, 26, 40, 41, 42, 56, 57, 58}, + .oobfree = { {1, 7}, {11, 13}, {27, 13}, {43, 13}, {59, 5} }, + .oobavail = 48, +}; + +/*=================================*/ + +/* + * Set up the FCM hardware block and page address fields, and the fcm + * structure addr field to point to the correct FCM buffer in memory + */ +static void set_addr(struct mtd_info *mtd, int column, int page_addr, int oob) +{ + struct nand_chip *chip = mtd->priv; + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + lbus83xx_t *lbc = ctrl->regs; + int buf_num; + + ctrl->page = page_addr; + + out_be32(&lbc->fbar, + page_addr >> (chip->phys_erase_shift - chip->page_shift)); + + if (priv->page_size) { + out_be32(&lbc->fpar, + ((page_addr << FPAR_LP_PI_SHIFT) & FPAR_LP_PI) | + (oob ? FPAR_LP_MS : 0) | column); + buf_num = (page_addr & 1) << 2; + } else { + out_be32(&lbc->fpar, + ((page_addr << FPAR_SP_PI_SHIFT) & FPAR_SP_PI) | + (oob ? FPAR_SP_MS : 0) | column); + buf_num = page_addr & 7; + } + + ctrl->addr = priv->vbase + buf_num * 1024; + ctrl->index = column; + + /* for OOB data point to the second half of the buffer */ + if (oob) + ctrl->index += priv->page_size ? 2048 : 512; + + vdbg("set_addr: bank=%d, ctrl->addr=0x%p (0x%p), " + "index %x, pes %d ps %d\n", + buf_num, ctrl->addr, priv->vbase, ctrl->index, + chip->phys_erase_shift, chip->page_shift); +} + +/* + * execute FCM command and wait for it to complete + */ +static int fsl_elbc_run_command(struct mtd_info *mtd) +{ + struct nand_chip *chip = mtd->priv; + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + lbus83xx_t *lbc = ctrl->regs; + long long end_tick; + u32 ltesr; + + /* Setup the FMR[OP] to execute without write protection */ + out_be32(&lbc->fmr, priv->fmr | 3); + if (ctrl->use_mdr) + out_be32(&lbc->mdr, ctrl->mdr); + + vdbg("fsl_elbc_run_command: fmr=%08x fir=%08x fcr=%08x\n", + in_be32(&lbc->fmr), in_be32(&lbc->fir), in_be32(&lbc->fcr)); + vdbg("fsl_elbc_run_command: fbar=%08x fpar=%08x " + "fbcr=%08x bank=%d\n", + in_be32(&lbc->fbar), in_be32(&lbc->fpar), + in_be32(&lbc->fbcr), priv->bank); + + /* execute special operation */ + out_be32(&lbc->lsor, priv->bank); + + /* wait for FCM complete flag or timeout */ + end_tick = usec2ticks(FCM_TIMEOUT_MSECS * 1000) + get_ticks(); + + ltesr = 0; + while (end_tick > get_ticks()) { + ltesr = in_be32(&lbc->ltesr); + if (ltesr & LTESR_CC) + break; + } + + ctrl->status = ltesr & LTESR_NAND_MASK; + out_be32(&lbc->ltesr, ctrl->status); + out_be32(&lbc->lteatr, 0); + + /* store mdr value in case it was needed */ + if (ctrl->use_mdr) + ctrl->mdr = in_be32(&lbc->mdr); + + ctrl->use_mdr = 0; + + vdbg("fsl_elbc_run_command: stat=%08x mdr=%08x fmr=%08x\n", + ctrl->status, ctrl->mdr, in_be32(&lbc->fmr)); + + /* returns 0 on success otherwise non-zero) */ + return ctrl->status == LTESR_CC ? 0 : -EIO; +} + +static void fsl_elbc_do_read(struct nand_chip *chip, int oob) +{ + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + lbus83xx_t *lbc = ctrl->regs; + + if (priv->page_size) { + out_be32(&lbc->fir, + (FIR_OP_CW0 << FIR_OP0_SHIFT) | + (FIR_OP_CA << FIR_OP1_SHIFT) | + (FIR_OP_PA << FIR_OP2_SHIFT) | + (FIR_OP_CW1 << FIR_OP3_SHIFT) | + (FIR_OP_RBW << FIR_OP4_SHIFT)); + + out_be32(&lbc->fcr, (NAND_CMD_READ0 << FCR_CMD0_SHIFT) | + (NAND_CMD_READSTART << FCR_CMD1_SHIFT)); + } else { + out_be32(&lbc->fir, + (FIR_OP_CW0 << FIR_OP0_SHIFT) | + (FIR_OP_CA << FIR_OP1_SHIFT) | + (FIR_OP_PA << FIR_OP2_SHIFT) | + (FIR_OP_RBW << FIR_OP3_SHIFT)); + + if (oob) + out_be32(&lbc->fcr, + NAND_CMD_READOOB << FCR_CMD0_SHIFT); + else + out_be32(&lbc->fcr, NAND_CMD_READ0 << FCR_CMD0_SHIFT); + } +} + +/* cmdfunc send commands to the FCM */ +static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command, + int column, int page_addr) +{ + struct nand_chip *chip = mtd->priv; + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + lbus83xx_t *lbc = ctrl->regs; + + ctrl->use_mdr = 0; + + /* clear the read buffer */ + ctrl->read_bytes = 0; + if (command != NAND_CMD_PAGEPROG) + ctrl->index = 0; + + switch (command) { + /* READ0 and READ1 read the entire buffer to use hardware ECC. */ + case NAND_CMD_READ1: + column += 256; + + /* fall-through */ + case NAND_CMD_READ0: + vdbg("fsl_elbc_cmdfunc: NAND_CMD_READ0, page_addr:" + " 0x%x, column: 0x%x.\n", page_addr, column); + + out_be32(&lbc->fbcr, 0); /* read entire page to enable ECC */ + set_addr(mtd, 0, page_addr, 0); + + ctrl->read_bytes = mtd->writesize + mtd->oobsize; + ctrl->index += column; + + fsl_elbc_do_read(chip, 0); + fsl_elbc_run_command(mtd); + return; + + /* READOOB reads only the OOB because no ECC is performed. */ + case NAND_CMD_READOOB: + vdbg("fsl_elbc_cmdfunc: NAND_CMD_READOOB, page_addr:" + " 0x%x, column: 0x%x.\n", page_addr, column); + + out_be32(&lbc->fbcr, mtd->oobsize - column); + set_addr(mtd, column, page_addr, 1); + + ctrl->read_bytes = mtd->writesize + mtd->oobsize; + + fsl_elbc_do_read(chip, 1); + fsl_elbc_run_command(mtd); + + return; + + /* READID must read all 5 possible bytes while CEB is active */ + case NAND_CMD_READID: + vdbg("fsl_elbc_cmdfunc: NAND_CMD_READID.\n"); + + out_be32(&lbc->fir, (FIR_OP_CW0 << FIR_OP0_SHIFT) | + (FIR_OP_UA << FIR_OP1_SHIFT) | + (FIR_OP_RBW << FIR_OP2_SHIFT)); + out_be32(&lbc->fcr, NAND_CMD_READID << FCR_CMD0_SHIFT); + /* 5 bytes for manuf, device and exts */ + out_be32(&lbc->fbcr, 5); + ctrl->read_bytes = 5; + ctrl->use_mdr = 1; + ctrl->mdr = 0; + + set_addr(mtd, 0, 0, 0); + fsl_elbc_run_command(mtd); + return; + + /* ERASE1 stores the block and page address */ + case NAND_CMD_ERASE1: + vdbg("fsl_elbc_cmdfunc: NAND_CMD_ERASE1, " + "page_addr: 0x%x.\n", page_addr); + set_addr(mtd, 0, page_addr, 0); + return; + + /* ERASE2 uses the block and page address from ERASE1 */ + case NAND_CMD_ERASE2: + vdbg("fsl_elbc_cmdfunc: NAND_CMD_ERASE2.\n"); + + out_be32(&lbc->fir, + (FIR_OP_CW0 << FIR_OP0_SHIFT) | + (FIR_OP_PA << FIR_OP1_SHIFT) | + (FIR_OP_CM1 << FIR_OP2_SHIFT)); + + out_be32(&lbc->fcr, + (NAND_CMD_ERASE1 << FCR_CMD0_SHIFT) | + (NAND_CMD_ERASE2 << FCR_CMD1_SHIFT)); + + out_be32(&lbc->fbcr, 0); + ctrl->read_bytes = 0; + + fsl_elbc_run_command(mtd); + return; + + /* SEQIN sets up the addr buffer and all registers except the length */ + case NAND_CMD_SEQIN: { + u32 fcr; + vdbg("fsl_elbc_cmdfunc: NAND_CMD_SEQIN/PAGE_PROG, " + "page_addr: 0x%x, column: 0x%x.\n", + page_addr, column); + + ctrl->column = column; + ctrl->oob = 0; + + if (priv->page_size) { + fcr = (NAND_CMD_SEQIN << FCR_CMD0_SHIFT) | + (NAND_CMD_PAGEPROG << FCR_CMD1_SHIFT); + + out_be32(&lbc->fir, + (FIR_OP_CW0 << FIR_OP0_SHIFT) | + (FIR_OP_CA << FIR_OP1_SHIFT) | + (FIR_OP_PA << FIR_OP2_SHIFT) | + (FIR_OP_WB << FIR_OP3_SHIFT) | + (FIR_OP_CW1 << FIR_OP4_SHIFT)); + } else { + fcr = (NAND_CMD_PAGEPROG << FCR_CMD1_SHIFT) | + (NAND_CMD_SEQIN << FCR_CMD2_SHIFT); + + out_be32(&lbc->fir, + (FIR_OP_CW0 << FIR_OP0_SHIFT) | + (FIR_OP_CM2 << FIR_OP1_SHIFT) | + (FIR_OP_CA << FIR_OP2_SHIFT) | + (FIR_OP_PA << FIR_OP3_SHIFT) | + (FIR_OP_WB << FIR_OP4_SHIFT) | + (FIR_OP_CW1 << FIR_OP5_SHIFT)); + + if (column >= mtd->writesize) { + /* OOB area --> READOOB */ + column -= mtd->writesize; + fcr |= NAND_CMD_READOOB << FCR_CMD0_SHIFT; + ctrl->oob = 1; + } else if (column < 256) { + /* First 256 bytes --> READ0 */ + fcr |= NAND_CMD_READ0 << FCR_CMD0_SHIFT; + } else { + /* Second 256 bytes --> READ1 */ + fcr |= NAND_CMD_READ1 << FCR_CMD0_SHIFT; + } + } + + out_be32(&lbc->fcr, fcr); + set_addr(mtd, column, page_addr, ctrl->oob); + return; + } + + /* PAGEPROG reuses all of the setup from SEQIN and adds the length */ + case NAND_CMD_PAGEPROG: { + int full_page; + vdbg("fsl_elbc_cmdfunc: NAND_CMD_PAGEPROG " + "writing %d bytes.\n", ctrl->index); + + /* if the write did not start at 0 or is not a full page + * then set the exact length, otherwise use a full page + * write so the HW generates the ECC. + */ + if (ctrl->oob || ctrl->column != 0 || + ctrl->index != mtd->writesize + mtd->oobsize) { + out_be32(&lbc->fbcr, ctrl->index); + full_page = 0; + } else { + out_be32(&lbc->fbcr, 0); + full_page = 1; + } + + fsl_elbc_run_command(mtd); + + /* Read back the page in order to fill in the ECC for the + * caller. Is this really needed? + */ + if (full_page && ctrl->oob_poi) { + out_be32(&lbc->fbcr, 3); + set_addr(mtd, 6, page_addr, 1); + + ctrl->read_bytes = mtd->writesize + 9; + + fsl_elbc_do_read(chip, 1); + fsl_elbc_run_command(mtd); + + memcpy_fromio(ctrl->oob_poi + 6, + &ctrl->addr[ctrl->index], 3); + ctrl->index += 3; + } + + ctrl->oob_poi = NULL; + return; + } + + /* CMD_STATUS must read the status byte while CEB is active */ + /* Note - it does not wait for the ready line */ + case NAND_CMD_STATUS: + out_be32(&lbc->fir, + (FIR_OP_CM0 << FIR_OP0_SHIFT) | + (FIR_OP_RBW << FIR_OP1_SHIFT)); + out_be32(&lbc->fcr, NAND_CMD_STATUS << FCR_CMD0_SHIFT); + out_be32(&lbc->fbcr, 1); + set_addr(mtd, 0, 0, 0); + ctrl->read_bytes = 1; + + fsl_elbc_run_command(mtd); + + /* The chip always seems to report that it is + * write-protected, even when it is not. + */ + out_8(ctrl->addr, in_8(ctrl->addr) | NAND_STATUS_WP); + return; + + /* RESET without waiting for the ready line */ + case NAND_CMD_RESET: + dbg("fsl_elbc_cmdfunc: NAND_CMD_RESET.\n"); + out_be32(&lbc->fir, FIR_OP_CM0 << FIR_OP0_SHIFT); + out_be32(&lbc->fcr, NAND_CMD_RESET << FCR_CMD0_SHIFT); + fsl_elbc_run_command(mtd); + return; + + default: + printf("fsl_elbc_cmdfunc: error, unsupported command 0x%x.\n", + command); + } +} + +static void fsl_elbc_select_chip(struct mtd_info *mtd, int chip) +{ + /* The hardware does not seem to support multiple + * chips per bank. + */ +} + +/* + * Write buf to the FCM Controller Data Buffer + */ +static void fsl_elbc_write_buf(struct mtd_info *mtd, const u8 *buf, int len) +{ + struct nand_chip *chip = mtd->priv; + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + unsigned int bufsize = mtd->writesize + mtd->oobsize; + + if (len < 0) { + printf("write_buf of %d bytes", len); + ctrl->status = 0; + return; + } + + if ((unsigned int)len > bufsize - ctrl->index) { + printf("write_buf beyond end of buffer " + "(%d requested, %u available)\n", + len, bufsize - ctrl->index); + len = bufsize - ctrl->index; + } + + memcpy_toio(&ctrl->addr[ctrl->index], buf, len); + ctrl->index += len; +} + +/* + * read a byte from either the FCM hardware buffer if it has any data left + * otherwise issue a command to read a single byte. + */ +static u8 fsl_elbc_read_byte(struct mtd_info *mtd) +{ + struct nand_chip *chip = mtd->priv; + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + + /* If there are still bytes in the FCM, then use the next byte. */ + if (ctrl->index < ctrl->read_bytes) + return in_8(&ctrl->addr[ctrl->index++]); + + printf("read_byte beyond end of buffer\n"); + return ERR_BYTE; +} + +/* + * Read from the FCM Controller Data Buffer + */ +static void fsl_elbc_read_buf(struct mtd_info *mtd, u8 *buf, int len) +{ + struct nand_chip *chip = mtd->priv; + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + int avail; + + if (len < 0) + return; + + avail = min((unsigned int)len, ctrl->read_bytes - ctrl->index); + memcpy_fromio(buf, &ctrl->addr[ctrl->index], avail); + ctrl->index += avail; + + if (len > avail) + printf("read_buf beyond end of buffer " + "(%d requested, %d available)\n", + len, avail); +} + +/* + * Verify buffer against the FCM Controller Data Buffer + */ +static int fsl_elbc_verify_buf(struct mtd_info *mtd, + const u_char *buf, int len) +{ + struct nand_chip *chip = mtd->priv; + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + int i; + + if (len < 0) { + printf("write_buf of %d bytes", len); + return -EINVAL; + } + + if ((unsigned int)len > ctrl->read_bytes - ctrl->index) { + printf("verify_buf beyond end of buffer " + "(%d requested, %u available)\n", + len, ctrl->read_bytes - ctrl->index); + + ctrl->index = ctrl->read_bytes; + return -EINVAL; + } + + for (i = 0; i < len; i++) + if (in_8(&ctrl->addr[ctrl->index + i]) != buf[i]) + break; + + ctrl->index += len; + return i == len && ctrl->status == LTESR_CC ? 0 : -EIO; +} + +/* This function is called after Program and Erase Operations to + * check for success or failure. + */ +static int fsl_elbc_wait(struct mtd_info *mtd, struct nand_chip *chip) +{ + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + lbus83xx_t *lbc = ctrl->regs; + + if (ctrl->status != LTESR_CC) + return NAND_STATUS_FAIL; + + /* Use READ_STATUS command, but wait for the device to be ready */ + ctrl->use_mdr = 0; + out_be32(&lbc->fir, + (FIR_OP_CW0 << FIR_OP0_SHIFT) | + (FIR_OP_RBW << FIR_OP1_SHIFT)); + out_be32(&lbc->fcr, NAND_CMD_STATUS << FCR_CMD0_SHIFT); + out_be32(&lbc->fbcr, 1); + set_addr(mtd, 0, 0, 0); + ctrl->read_bytes = 1; + + fsl_elbc_run_command(mtd); + + if (ctrl->status != LTESR_CC) + return NAND_STATUS_FAIL; + + /* The chip always seems to report that it is + * write-protected, even when it is not. + */ + out_8(ctrl->addr, in_8(ctrl->addr) | NAND_STATUS_WP); + return fsl_elbc_read_byte(mtd); +} + +static int fsl_elbc_read_page(struct mtd_info *mtd, + struct nand_chip *chip, + uint8_t *buf) +{ + fsl_elbc_read_buf(mtd, buf, mtd->writesize); + fsl_elbc_read_buf(mtd, chip->oob_poi, mtd->oobsize); + + if (fsl_elbc_wait(mtd, chip) & NAND_STATUS_FAIL) + mtd->ecc_stats.failed++; + + return 0; +} + +/* ECC will be calculated automatically, and errors will be detected in + * waitfunc. + */ +static void fsl_elbc_write_page(struct mtd_info *mtd, + struct nand_chip *chip, + const uint8_t *buf) +{ + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + + fsl_elbc_write_buf(mtd, buf, mtd->writesize); + fsl_elbc_write_buf(mtd, chip->oob_poi, mtd->oobsize); + + ctrl->oob_poi = chip->oob_poi; +} + +static struct fsl_elbc_ctrl *elbc_ctrl; + +static void fsl_elbc_ctrl_init(void) +{ + immap_t *im = (immap_t *)CFG_IMMR; + + elbc_ctrl = kzalloc(sizeof(*elbc_ctrl), GFP_KERNEL); + if (!elbc_ctrl) + return; + + elbc_ctrl->regs = &im->lbus; + + /* clear event registers */ + out_be32(&elbc_ctrl->regs->ltesr, LTESR_NAND_MASK); + out_be32(&elbc_ctrl->regs->lteatr, 0); + + /* Enable interrupts for any detected events */ + out_be32(&elbc_ctrl->regs->lteir, LTESR_NAND_MASK); + + elbc_ctrl->read_bytes = 0; + elbc_ctrl->index = 0; + elbc_ctrl->addr = NULL; +} + +int board_nand_init(struct nand_chip *nand) +{ + struct fsl_elbc_mtd *priv; + uint32_t br, or; + + if (!elbc_ctrl) { + fsl_elbc_ctrl_init(); + if (!elbc_ctrl) + return -1; + } + + priv = kzalloc(sizeof(*priv), GFP_KERNEL); + if (!priv) + return -ENOMEM; + + priv->ctrl = elbc_ctrl; + priv->vbase = nand->IO_ADDR_R; + + /* Find which chip select it is connected to. It'd be nice + * if we could pass more than one datum to the NAND driver... + */ + for (priv->bank = 0; priv->bank < MAX_BANKS; priv->bank++) { + br = in_be32(&elbc_ctrl->regs->bank[priv->bank].br); + or = in_be32(&elbc_ctrl->regs->bank[priv->bank].or); + + if ((br & BR_V) && (br & BR_MSEL) == BR_MS_FCM && + (br & or & BR_BA) == (phys_addr_t)nand->IO_ADDR_R) + break; + } + + if (priv->bank >= MAX_BANKS) { + printf("fsl_elbc_nand: address did not match any " + "chip selects\n"); + return -ENODEV; + } + + elbc_ctrl->chips[priv->bank] = priv; + + /* fill in nand_chip structure */ + /* set up function call table */ + nand->read_byte = fsl_elbc_read_byte; + nand->write_buf = fsl_elbc_write_buf; + nand->read_buf = fsl_elbc_read_buf; + nand->verify_buf = fsl_elbc_verify_buf; + nand->select_chip = fsl_elbc_select_chip; + nand->cmdfunc = fsl_elbc_cmdfunc; + nand->waitfunc = fsl_elbc_wait; + + /* set up nand options */ + nand->options = NAND_NO_READRDY | NAND_NO_AUTOINCR; + + nand->controller = &elbc_ctrl->controller; + nand->priv = priv; + + nand->ecc.read_page = fsl_elbc_read_page; + nand->ecc.write_page = fsl_elbc_write_page; + + /* If CS Base Register selects full hardware ECC then use it */ + if ((br & BR_DECC) == BR_DECC_CHK_GEN) { + nand->ecc.mode = NAND_ECC_HW; + + nand->ecc.layout = (priv->fmr & FMR_ECCM) ? + &fsl_elbc_oob_sp_eccm1 : + &fsl_elbc_oob_sp_eccm0; + + nand->ecc.size = 512; + nand->ecc.bytes = 3; + nand->ecc.steps = 1; + } else { + /* otherwise fall back to default software ECC */ + nand->ecc.mode = NAND_ECC_SOFT; + } + + priv->fmr = (12 << FMR_CWTO_SHIFT) | (2 << FMR_AL_SHIFT); + + /* adjust Option Register and ECC to match Flash page size */ + if (or & OR_FCM_PGS) { + priv->page_size = 1; + + /* adjust ecc setup if needed */ + if ((br & BR_DECC) == BR_DECC_CHK_GEN) { + nand->ecc.steps = 4; + nand->ecc.layout = (priv->fmr & FMR_ECCM) ? + &fsl_elbc_oob_lp_eccm1 : + &fsl_elbc_oob_lp_eccm0; + } + } + + return 0; +} + +#endif
- Copyright (c) 2006-2008 Freescale Semiconductor
- Authors: Nick Spence nick.spence@freescale.com,
Scott Wood <scottwood@freescale.com>
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
Please move to the Makefile
return;
- /* READOOB reads only the OOB because no ECC is performed. */
- case NAND_CMD_READOOB:
^^^^^^^^^^^^^ WhiteSpace please remove
return;
- /* READID must read all 5 possible bytes while CEB is active */
- case NAND_CMD_READID:
ctrl->use_mdr = 1;
ctrl->mdr = 0;
return;
command);
- /* The hardware does not seem to support multiple
* chips per bank.
please use this comment style /* * ... * .... */
- Write buf to the FCM Controller Data Buffer
- struct nand_chip *chip = mtd->priv;
- struct fsl_elbc_mtd *priv = chip->priv;
- struct fsl_elbc_ctrl *ctrl = priv->ctrl;
- unsigned int bufsize = mtd->writesize + mtd->oobsize;
- for (i = 0; i < len; i++)
break;
- ctrl->index += len;
- return i == len && ctrl->status == LTESR_CC ? 0 : -EIO;
please use something like that to help the reading return ((i==len) && (ctrl->status==LTESR_CC))? 0 : -EIO;
- check for success or failure.
Comment same as before
- lbus83xx_t *lbc = ctrl->regs;
- if (ctrl->status != LTESR_CC)
- /* Use READ_STATUS command, but wait for the device to be ready */
- ctrl->use_mdr = 0;
- out_be32(&lbc->fir,
- out_be32(&lbc->fcr, NAND_CMD_STATUS << FCR_CMD0_SHIFT);
- out_be32(&lbc->fbcr, 1);
- set_addr(mtd, 0, 0, 0);
- ctrl->read_bytes = 1;
- fsl_elbc_run_command(mtd);
- /* The chip always seems to report that it is
- out_8(ctrl->addr, in_8(ctrl->addr) | NAND_STATUS_WP);
- return fsl_elbc_read_byte(mtd);
uint8_t *buf)
- fsl_elbc_read_buf(mtd, buf, mtd->writesize);
- fsl_elbc_read_buf(mtd, chip->oob_poi, mtd->oobsize);
- if (fsl_elbc_wait(mtd, chip) & NAND_STATUS_FAIL)
- waitfunc.
const uint8_t *buf)
- fsl_elbc_write_buf(mtd, buf, mtd->writesize);
- fsl_elbc_write_buf(mtd, chip->oob_poi, mtd->oobsize);
- ctrl->oob_poi = chip->oob_poi;
- if (!priv)
return -ENOMEM;
- priv->ctrl = elbc_ctrl;
- priv->vbase = nand->IO_ADDR_R;
- /* Find which chip select it is connected to. It'd be nice
- for (priv->bank = 0; priv->bank < MAX_BANKS; priv->bank++) {
break;
- if (priv->bank >= MAX_BANKS) {
"chip selects\n");
return -ENODEV;
- elbc_ctrl->chips[priv->bank] = priv;
Please check all comments.
Best Regards, J.
OK.
Grr... I keep forgetting to enable the post-commit hook in new git repositories. I wish it could be configured globally in a ~/.gitrc or similar.
Of course, I also wish people wouldn't get so bent out of shape about blank lines being indented to the level of the code around them.
* chips per bank.
Do we really need such trivial style differences with the Linux driver, which will only serve as an annoyance when keeping the two in sync, not to mention wasting vertical space with no readability benefit because there's pretty much always a (mostly) blank line above the comment?
That's not the style I've generally seen used.
-Scott
* chips per bank.
This preferred comment style *should* be used. But I would not object to your (and others) multi-line comment style either. It's being used in Linux frequently and as you already mentioned saves one line. Especially when moving Linux drivers to U-Boot, we should allow this coding style for better maintenance.
Just my 2 cents.
Best regards, Stefan
Scott Wood
Stefan Roese
