[U-Boot] [PATCH v2 0/2]: imx: mx6: use OTP for freq grade
This is a second take on my last series to obtain and use CPU frequency grade in print_cpuinfo().
Signed-off-by: Tim Harvey tharvey@gateworks.com -- v2: - split into two series: 1 for CPU frequency, other for Temperature grade
Tim Harvey (2): imx: mx6: add get_cpu_speed_grade_hz func to return MHz speed grade from OTP mx: mx6: display max cpu frequency in print_cpuinfo()
arch/arm/cpu/armv7/mx6/soc.c | 41 +++++++++++++++++++++++++++++++ arch/arm/imx-common/cpu.c | 16 +++++++++++- arch/arm/include/asm/arch-mx6/sys_proto.h | 1 + 3 files changed, 57 insertions(+), 1 deletion(-)
The IMX6 has four different speed grades determined by eFUSE SPEED_GRADING indicated by OCOTP_CFG3[17:16] which is at 0x440 in the Fusemap Description Table. Return this frequency so that it can be used elsewhere.
Note that the IMX6SDLRM and the IMX6SXRM do not indicate this in the their Fusemap Description Table however Freescale has confirmed that these eFUSE bits match the description within the IMX6DQRM and that they will be added to the next revision of the respective reference manuals.
These have been tested with IMX6 Quad/Solo/Dual-light 800Mhz and 1GHz grades.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/cpu/armv7/mx6/soc.c | 41 +++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx6/sys_proto.h | 1 + 2 files changed, 42 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index dd34138..71fa1fb 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -83,6 +83,47 @@ u32 get_cpu_rev(void) return (type << 12) | (reg + 0x10); }
+/* + * OCOTP_CFG3[17:16] (see Fusemap Description Table offset 0x440) + * defines a 2-bit SPEED_GRADING + */ +#define OCOTP_CFG3_SPEED_SHIFT 16 +#define OCOTP_CFG3_SPEED_800MHZ 0 +#define OCOTP_CFG3_SPEED_850MHZ 1 +#define OCOTP_CFG3_SPEED_1GHZ 2 +#define OCOTP_CFG3_SPEED_1P2GHZ 3 + +u32 get_cpu_speed_grade_hz(void) +{ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[0]; + struct fuse_bank0_regs *fuse = + (struct fuse_bank0_regs *)bank->fuse_regs; + uint32_t val; + + val = readl(&fuse->cfg3); + val >>= OCOTP_CFG3_SPEED_SHIFT; + val &= 0x3; + + switch (val) { + /* Valid for IMX6DQ */ + case OCOTP_CFG3_SPEED_1P2GHZ: + if (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) + return 1200000000; + /* Valid for IMX6SX/IMX6SDL/IMX6DQ */ + case OCOTP_CFG3_SPEED_1GHZ: + return 996000000; + /* Valid for IMX6DQ */ + case OCOTP_CFG3_SPEED_850MHZ: + if (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) + return 852000000; + /* Valid for IMX6SX/IMX6SDL/IMX6DQ */ + case OCOTP_CFG3_SPEED_800MHZ: + return 792000000; + } + return 0; +} + #ifdef CONFIG_REVISION_TAG u32 __weak get_board_rev(void) { diff --git a/arch/arm/include/asm/arch-mx6/sys_proto.h b/arch/arm/include/asm/arch-mx6/sys_proto.h index 28ba844..a2cd0a9 100644 --- a/arch/arm/include/asm/arch-mx6/sys_proto.h +++ b/arch/arm/include/asm/arch-mx6/sys_proto.h @@ -16,6 +16,7 @@
u32 get_nr_cpus(void); u32 get_cpu_rev(void); +u32 get_cpu_speed_grade_hz(void);
/* returns MXC_CPU_ value */ #define cpu_type(rev) (((rev) >> 12)&0xff)
Hi
2015-05-14 7:08 GMT+02:00 Tim Harvey tharvey@gateworks.com:
- OCOTP_CFG3[17:16] (see Fusemap Description Table offset 0x440)
- defines a 2-bit SPEED_GRADING
Note: 0x3 is defined as reserved (IMX6DQRM Rev 2, 06/2014).
uint32_t val;
val &= 0x3;
switch (val) {
return 1200000000;
return 996000000;
return 852000000;
return 792000000;
Do we really need the ifs inside the cases? The speed grading fuse value is read only and we must simply life with the value we read back. So I would drop the is_cpu_type(..) thing.
greets -- Christian Gmeiner, MSc
Hi Christian,
On 15/05/2015 09:53, Christian Gmeiner wrote:
Hi
That means that the manual is buggy, if the SOC returns exactly this value ;-)
uint32_t val;
val &= 0x3;
switch (val) {
return 1200000000;
return 996000000;
return 852000000;
return 792000000;
Function does not returns the value of the fuse, else it should returns val. The value is parsed for consistency, and if it is not, 0 means a failure. IMHO this interpretation is correct - I would agree with you only if the return value would be the read value, but it is not.
Best regards, Stefano Babic
greets
2015-05-15 15:20 GMT+02:00 Stefano Babic sbabic@denx.de:
Hi Christian,
Hi
yep :)
uint32_t val;
val &= 0x3;
switch (val) {
return 1200000000;
return 996000000;
return 852000000;
return 792000000;
If all mx6 variants use the same otp register/values, then the ifs are _NOT_ needed. I hope that later testings/doc updates/etc proofs it and we can get rid of the superfluous ifs.
If they are different then I can life with it.
Hi Christian,
Ok - let's see if this can be proofed. It looks like we have to test and ask the hardware for that instead of relying on the documentation.
On 5/15/2015 7:32 AM, Stefano Babic wrote:
Hi Christian,
On our imx6sx board the patch outputs
U-Boot 2015.04-00074-g1bd6819 (May 15 2015 - 12:44:22)
CPU: Freescale i.MX6SX rev1.0 996 MHz (running at 792 MHz) Reset cause: WDOG Board: Nitrogen6sx ______________
Did you want me to test some variation of this?
Thanks Troy
On Fri, May 15, 2015 at 12:54 PM, Troy Kisky troy.kisky@boundarydevices.com wrote:
Hi Christian,
Thanks Troy
Troy,
As far as the frequency grade goes if you know the actual part number is a 1GHz part then that looks good - thanks for the test!
Could you provide similar results for the thermal grade patch series as well? (you will need to enable imx6 thermal sensor and remove the if (!imx6sx) around the print).
Thanks!
Tim
Hi Christian,
Thanks Troy
Troy,
Right, it is a 1GHz part.
Will do.
Thanks!
Tim
Hi Christian,
Thanks Troy
Troy,
Will do.
Thanks!
Tim
Ok. I think I gave bad info
The part number is PCIMX6X4AVM08AA, which should be -40 to 125 C, 800 MHz
and u-boot prints
U-Boot 2015.07-rc1-01048-gc4f95cb-dirty (May 15 2015 - 14:46:05)
CPU: Freescale i.MX6SX rev1.0 996 MHz (running at 792 MHz) CPU: Extended Commercial temperature grade (-20C to 105C) _______________
U-boot then freezes in "uclass_get_device(UCLASS_THERMAL, 0, &thermal_dev);"
Troy
On Fri, May 15, 2015 at 7:34 PM, Troy Kisky troy.kisky@boundarydevices.com wrote: ...
TO1.0 is the first one and had some issues. We need testing with current production TO not alpha customers one.
Thanks for pointing that out, Otavio.
Troy
On Fri, May 15, 2015 at 12:53 AM, Christian Gmeiner christian.gmeiner@gmail.com wrote:
Hi
Right - this goes back to the fact that the RM's are full of omissions in this area. I've gotten confirmation of sorts from Freescale that the above is what is used. Still, I would love to see some testing and I only have 800MHz/1GHz ranges, so if anyone out there with a IMX6DUAL or IMX6QUAD at 1.2GHz could verify this works please do.
uint32_t val;
val &= 0x3;
switch (val) {
return 1200000000;
return 996000000;
return 852000000;
return 792000000;
I've had a bit of a difficult time getting verification from Freescale that all IMX6 CPU's use the exact same OTP register and setting for this which is why I'm asking for testing. I haven't gotten a simple 'yes' to that question but instead of been giving small snippets of information. Not a single one of the RM's agree's with the other in this area (most marked as reserved or omit the register or omit the values altogether)
My personal feeling is that the speed grades (and temp grades for that matter) are the same for all IMX6 and even though the datasheets for the IMX6SDL/IMX6SX state they don't 'sell' a 850MHz or 1.2GHz speed grade we should honor the setting (meaning I agree with you that we should remove the if's).
Tim
Hi Tim,
- struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR;
- struct fuse_bank *bank = &ocotp->bank[0];
- struct fuse_bank0_regs *fuse =
- uint32_t val;
- val = readl(&fuse->cfg3);
- val >>= OCOTP_CFG3_SPEED_SHIFT;
- val &= 0x3;
- switch (val) {
- /* Valid for IMX6DQ */
- case OCOTP_CFG3_SPEED_1P2GHZ:
return 1200000000;
- /* Valid for IMX6SX/IMX6SDL/IMX6DQ */
- case OCOTP_CFG3_SPEED_1GHZ:
return 996000000;
- case OCOTP_CFG3_SPEED_850MHZ:
return 852000000;
- case OCOTP_CFG3_SPEED_800MHZ:
return 792000000;
- #ifdef CONFIG_REVISION_TAG u32 __weak get_board_rev(void) {
U-Boot 2015.07-rc1-21804-gaf1db4a-dirty (May 18 2015 - 00:31:26)
CPU: Freescale i.MX6SOLO rev1.1 996 MHz (running at 792 MHz) Reset cause: WDOG Board: RIoTboard
Tested-by: Nikolay Dimitrov picmaster@mail.bg
Regards, Nikolay
Display the max CPU frequency as well as the current running CPU frequency if the max CPU frequency is available and differs from the current CPU frequency.
Before: CPU: Freescale i.MX6Q rev1.2 at 792 MHz
After - using an 800MHz IMX6DL (running at its max) CPU: Freescale i.MX6DL rev1.1 at 792 MHz
After - using a 1GHz IMX6Q (not running at its max): CPU: Freescale i.MX6Q rev1.2 996 MHz (running at 792 MHz)
Signed-off-by: Tim Harvey tharvey@gateworks.com --- v2: - split out from patch that obtains the max cpu freq - add before/after example and more description of change
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/imx-common/cpu.c | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 067d08f..6b20482 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -142,7 +142,7 @@ const char *get_imx_type(u32 imxtype)
int print_cpuinfo(void) { - u32 cpurev; + u32 cpurev, max_freq;
#if defined(CONFIG_MX6) && defined(CONFIG_IMX6_THERMAL) struct udevice *thermal_dev; @@ -151,11 +151,25 @@ int print_cpuinfo(void)
cpurev = get_cpu_rev();
+#if defined(CONFIG_MX6) + printf("CPU: Freescale i.MX%s rev%d.%d", + get_imx_type((cpurev & 0xFF000) >> 12), + (cpurev & 0x000F0) >> 4, + (cpurev & 0x0000F) >> 0); + max_freq = get_cpu_speed_grade_hz(); + if (!max_freq || max_freq == mxc_get_clock(MXC_ARM_CLK)) { + printf(" at %dMHz\n", mxc_get_clock(MXC_ARM_CLK) / 1000000); + } else { + printf(" %d MHz (running at %d MHz)\n", max_freq / 1000000, + mxc_get_clock(MXC_ARM_CLK) / 1000000); + } +#else printf("CPU: Freescale i.MX%s rev%d.%d at %d MHz\n", get_imx_type((cpurev & 0xFF000) >> 12), (cpurev & 0x000F0) >> 4, (cpurev & 0x0000F) >> 0, mxc_get_clock(MXC_ARM_CLK) / 1000000); +#endif
#if defined(CONFIG_MX6) && defined(CONFIG_IMX6_THERMAL) ret = uclass_get_device(UCLASS_THERMAL, 0, &thermal_dev);
v2:
- u32 cpurev;
- printf("CPU: Freescale i.MX%s rev%d.%d",
- max_freq = get_cpu_speed_grade_hz();
- if (!max_freq || max_freq == mxc_get_clock(MXC_ARM_CLK)) {
- } else {
Regards, Nikolay
participants (6)
Christian Gmeiner
Nikolay Dimitrov
Otavio Salvador
Stefano Babic
Tim Harvey
Troy Kisky
