[U-Boot] [PATCH] Make FIT support really optional
Due to some mistakes in the source code, it was not possible to really turn FIT support off. This commit fixes the problem by means of the following changes:
- Enclose "bootm_host_load_image" and "bootm_host_load_images" between checks for CONFIG_FIT_SIGNATURE, in common/bootm.c.
- Enclose the declaration of "bootm_host_load_images" between checks for CONFIG_FIT_SIGNATURE, in common/bootm.h.
- Condition the compilation and linking of fit_common.o fit_image.o image-host.o common/image-fit.o to CONFIG_FIT=y, in tools/Makefile.
Signed-off-by: Carlos Santos casantos@datacom.ind.br [fabio: adapt for 2016.07] Signed-off-by: Fabio Estevam festevam@gmail.com [Ricardo: fix conditional compilation and linking of the files mentioned above for 2016.07] Signed-off-by: Ricardo Martincoski ricardo.martincoski@gmail.com [Jörg: adapt for 2019.01] Signed-off-by: Jörg Krause joerg.krause@embedded.rocks [Retrieved from: https://git.buildroot.net/buildroot/tree/package/uboot-tools/0003-Make-FIT-s...] Signed-off-by: Fabrice Fontaine fontaine.fabrice@gmail.com --- common/bootm.c | 2 ++ include/bootm.h | 2 ++ tools/Makefile | 6 ++---- 3 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/common/bootm.c b/common/bootm.c index b5d37d38db..d193751647 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -924,6 +924,7 @@ void memmove_wd(void *to, void *from, size_t len, ulong chunksz) memmove(to, from, len); }
+#if defined(CONFIG_FIT_SIGNATURE) static int bootm_host_load_image(const void *fit, int req_image_type) { const char *fit_uname_config = NULL; @@ -988,5 +989,6 @@ int bootm_host_load_images(const void *fit, int cfg_noffset) /* Return the first error we found */ return err; } +#endif
#endif /* ndef USE_HOSTCC */ diff --git a/include/bootm.h b/include/bootm.h index e2cc6d4b99..f771b733f5 100644 --- a/include/bootm.h +++ b/include/bootm.h @@ -42,7 +42,9 @@ void lynxkdi_boot(image_header_t *hdr);
boot_os_fn *bootm_os_get_boot_func(int os);
+#if defined(CONFIG_FIT_SIGNATURE) int bootm_host_load_images(const void *fit, int cfg_noffset); +#endif
int boot_selected_os(int argc, char * const argv[], int state, bootm_headers_t *images, boot_os_fn *boot_fn); diff --git a/tools/Makefile b/tools/Makefile index eadeba417d..e2f572cae1 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -58,6 +58,7 @@ hostprogs-$(CONFIG_FIT_SIGNATURE) += fit_info fit_check_sign
hostprogs-$(CONFIG_CMD_BOOTEFI_SELFTEST) += file2include
+FIT_OBJS-$(CONFIG_FIT) := fit_common.o fit_image.o image-host.o common/image-fit.o FIT_SIG_OBJS-$(CONFIG_FIT_SIGNATURE) := common/image-sig.o
# The following files are synced with upstream DTC. @@ -80,16 +81,13 @@ ROCKCHIP_OBS = lib/rc4.o rkcommon.o rkimage.o rksd.o rkspi.o # common objs for dumpimage and mkimage dumpimage-mkimage-objs := aisimage.o \ atmelimage.o \ + $(FIT_OBJS-y) \ $(FIT_SIG_OBJS-y) \ common/bootm.o \ lib/crc32.o \ default_image.o \ lib/fdtdec_common.o \ lib/fdtdec.o \ - fit_common.o \ - fit_image.o \ - common/image-fit.o \ - image-host.o \ common/image.o \ imagetool.o \ imximage.o \
Fabrice Fontaine
