[PATCH] rockchip: rk3328: Add missing bootph-some-ram props
Add bootph-some-ram props to pinctrl nodes related to eMMC, SD-card and SPI flash to match e.g. RK3308 and RK3399.
Also adjust bootph props for sdio_vcc_pin, pinctrl and uart2m1_xfer.
Fixes: 1e21f5693045 ("rockchip: rk3328: Fix loading FIT from SD-card when booting from eMMC") Signed-off-by: Jonas Karlman jonas@kwiboo.se --- This has been runtime tested on a Rock64 and NanoPi R2S Plus.
The uart2m1_xfer change help speed up boot by around 100 ms. --- arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi | 2 +- .../rk3328-orangepi-r1-plus-lts-u-boot.dtsi | 7 ++++--- .../dts/rk3328-orangepi-r1-plus-u-boot.dtsi | 7 ++++--- arch/arm/dts/rk3328-rock64-u-boot.dtsi | 7 ++++--- arch/arm/dts/rk3328-u-boot.dtsi | 20 +++++++++++++++---- 5 files changed, 29 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi b/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi index 4fa170eeaf8d..d8c79600b659 100644 --- a/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi +++ b/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi @@ -12,7 +12,7 @@ };
&sdio_vcc_pin { - bootph-all; + bootph-pre-ram; };
&usb20_otg { diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi b/arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi index 0a9423cd9c7e..b50c1332b836 100644 --- a/arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi +++ b/arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi @@ -8,9 +8,6 @@ #include "rk3328-sdram-lpddr3-666.dtsi"
&spi0 { - bootph-pre-ram; - bootph-some-ram; - flash@0 { bootph-pre-ram; bootph-some-ram; @@ -19,18 +16,22 @@
&spi0m2_clk { bootph-pre-ram; + bootph-some-ram; };
&spi0m2_cs0 { bootph-pre-ram; + bootph-some-ram; };
&spi0m2_rx { bootph-pre-ram; + bootph-some-ram; };
&spi0m2_tx { bootph-pre-ram; + bootph-some-ram; };
&usb20_otg { diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi b/arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi index 1096821fc5d3..8ae003bbefd1 100644 --- a/arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi +++ b/arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi @@ -8,9 +8,6 @@ #include "rk3328-sdram-ddr4-666.dtsi"
&usb20_otg { diff --git a/arch/arm/dts/rk3328-rock64-u-boot.dtsi b/arch/arm/dts/rk3328-rock64-u-boot.dtsi index 551cff6f24f6..22f128090f84 100644 --- a/arch/arm/dts/rk3328-rock64-u-boot.dtsi +++ b/arch/arm/dts/rk3328-rock64-u-boot.dtsi @@ -30,9 +30,6 @@ };
&spi0 { - bootph-pre-ram; - bootph-some-ram; - flash@0 { bootph-pre-ram; bootph-some-ram; @@ -41,18 +38,22 @@
&usb20_otg { diff --git a/arch/arm/dts/rk3328-u-boot.dtsi b/arch/arm/dts/rk3328-u-boot.dtsi index d3608bd0e2b2..0135bc08d491 100644 --- a/arch/arm/dts/rk3328-u-boot.dtsi +++ b/arch/arm/dts/rk3328-u-boot.dtsi @@ -17,7 +17,6 @@ };
dmc: dmc { - bootph-all; compatible = "rockchip,rk3328-dmc"; reg = <0x0 0xff400000 0x0 0x1000 0x0 0xff780000 0x0 0x3000 @@ -25,6 +24,7 @@ 0x0 0xff440000 0x0 0x1000 0x0 0xff720000 0x0 0x1000 0x0 0xff798000 0x0 0x1000>; + bootph-all; }; };
@@ -42,14 +42,17 @@
&emmc_bus8 { bootph-pre-ram; + bootph-some-ram; };
&emmc_clk { bootph-pre-ram; + bootph-some-ram; };
&emmc_cmd { bootph-pre-ram; + bootph-some-ram; };
&gpio0 { @@ -66,10 +69,12 @@
&pcfg_pull_none_8ma { bootph-pre-ram; + bootph-some-ram; };
&pcfg_pull_none_12ma { bootph-pre-ram; + bootph-some-ram; };
&pcfg_pull_up { @@ -78,19 +83,21 @@
&pcfg_pull_up_4ma { bootph-pre-ram; + bootph-some-ram; };
&pcfg_pull_up_8ma { bootph-pre-ram; + bootph-some-ram; };
&pcfg_pull_up_12ma { bootph-pre-ram; + bootph-some-ram; };
&pinctrl { - bootph-pre-ram; - bootph-some-ram; + bootph-all; };
&sdmmc { @@ -103,18 +110,22 @@
&sdmmc0_bus4 { bootph-pre-ram; + bootph-some-ram; };
&sdmmc0_clk { bootph-pre-ram; + bootph-some-ram; };
&sdmmc0_cmd { bootph-pre-ram; + bootph-some-ram; };
&sdmmc0_dectn { bootph-pre-ram; + bootph-some-ram; };
&sdmmc0m1_pin { @@ -127,7 +138,8 @@ };
&uart2m1_xfer { - bootph-all; + bootph-pre-sram; + bootph-pre-ram; };
&vop {
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
&sdio_vcc_pin {
- bootph-all;
bootph-pre-ram; };
&usb20_otg {
&spi0 {
- bootph-pre-ram;
- bootph-some-ram;
@@ -19,18 +16,22 @@
bootph-some-ram; };
bootph-some-ram; };
bootph-some-ram; };
bootph-some-ram; };
&usb20_otg {
&spi0 {
- bootph-pre-ram;
- bootph-some-ram;
@@ -19,18 +16,22 @@
bootph-some-ram; };
bootph-some-ram; };
bootph-some-ram; };
bootph-some-ram; };
&usb20_otg {
&spi0 {
- bootph-pre-ram;
- bootph-some-ram;
@@ -41,18 +38,22 @@
bootph-some-ram; };
bootph-some-ram; };
bootph-some-ram; };
bootph-some-ram; };
&usb20_otg {
dmc: dmc {
compatible = "rockchip,rk3328-dmc"; reg = <0x0 0xff400000 0x0 0x1000 0x0 0xff780000 0x0 0x3000bootph-all;
}; };bootph-all;
@@ -42,14 +42,17 @@
bootph-some-ram; };
bootph-some-ram; };
bootph-some-ram; };
&gpio0 {
@@ -66,10 +69,12 @@
bootph-some-ram; };
bootph-some-ram; };
&pcfg_pull_up {
@@ -78,19 +83,21 @@
bootph-some-ram; };
bootph-some-ram; };
bootph-some-ram; };
&pinctrl {
- bootph-pre-ram;
- bootph-some-ram;
bootph-all; };
&sdmmc {
bootph-some-ram; };
bootph-some-ram; };
bootph-some-ram; };
bootph-some-ram; };
&sdmmc0m1_pin {
&uart2m1_xfer {
- bootph-all;
bootph-pre-sram;
bootph-pre-ram; };
&vop {
Jonas Karlman
Kever Yang
