[U-Boot] [PATCH 0/4] Remove old unused x86 boards and code
As suggested by Graeme Russ this series attempts to remove old unused boards and code from x86 U-Boot. This includes:
- Dumping the eNET boards - Dumping the SC520 CPU - Dumping 16-bit 'Real Mode' support (other than what is needed for the reset vector and protected mode switch)
No restructuring is attempted by this series.
Simon Glass (4): x86: Remove eNET boards x86: Remove sc520 cpu x86: Remove all real mode code x86: Remove 16-bit reset code
Makefile | 4 - README | 9 - arch/x86/config.mk | 1 - arch/x86/cpu/Makefile | 1 - arch/x86/cpu/resetvec.S | 38 -- arch/x86/cpu/sc520/Makefile | 58 --- arch/x86/cpu/sc520/asm-offsets.c | 45 --- arch/x86/cpu/sc520/sc520.c | 66 ---- arch/x86/cpu/sc520/sc520_car.S | 94 ----- arch/x86/cpu/sc520/sc520_pci.c | 142 -------- arch/x86/cpu/sc520/sc520_reset.c | 40 --- arch/x86/cpu/sc520/sc520_sdram.c | 479 ------------------------ arch/x86/cpu/sc520/sc520_ssi.c | 93 ----- arch/x86/cpu/sc520/sc520_timer.c | 89 ----- arch/x86/cpu/start16.S | 146 -------- arch/x86/cpu/u-boot.lds | 25 -- arch/x86/include/asm/arch-sc520/pci.h | 79 ---- arch/x86/include/asm/arch-sc520/sc520.h | 372 ------------------- arch/x86/include/asm/arch-sc520/ssi.h | 34 -- arch/x86/include/asm/realmode.h | 36 -- arch/x86/lib/Makefile | 10 - arch/x86/lib/bios.S | 569 ----------------------------- arch/x86/lib/bios.h | 3 - arch/x86/lib/bios_pci.S | 447 ----------------------- arch/x86/lib/bios_setup.c | 179 --------- arch/x86/lib/realmode.c | 93 ----- arch/x86/lib/realmode_switch.S | 232 ------------ arch/x86/lib/video.c | 6 - arch/x86/lib/video_bios.c | 196 ---------- arch/x86/lib/zimage.c | 23 -- board/eNET/Makefile | 52 --- board/eNET/eNET.c | 284 --------------- board/eNET/eNET_pci.c | 128 ------- board/eNET/eNET_start.S | 30 -- board/eNET/eNET_start16.S | 87 ----- board/eNET/hardware.h | 36 -- boards.cfg | 2 - include/configs/coreboot.h | 1 - include/configs/eNET.h | 619 -------------------------------- 39 files changed, 4848 deletions(-) delete mode 100644 arch/x86/cpu/resetvec.S delete mode 100644 arch/x86/cpu/sc520/Makefile delete mode 100644 arch/x86/cpu/sc520/asm-offsets.c delete mode 100644 arch/x86/cpu/sc520/sc520.c delete mode 100644 arch/x86/cpu/sc520/sc520_car.S delete mode 100644 arch/x86/cpu/sc520/sc520_pci.c delete mode 100644 arch/x86/cpu/sc520/sc520_reset.c delete mode 100644 arch/x86/cpu/sc520/sc520_sdram.c delete mode 100644 arch/x86/cpu/sc520/sc520_ssi.c delete mode 100644 arch/x86/cpu/sc520/sc520_timer.c delete mode 100644 arch/x86/cpu/start16.S delete mode 100644 arch/x86/include/asm/arch-sc520/pci.h delete mode 100644 arch/x86/include/asm/arch-sc520/sc520.h delete mode 100644 arch/x86/include/asm/arch-sc520/ssi.h delete mode 100644 arch/x86/include/asm/realmode.h delete mode 100644 arch/x86/lib/bios.S delete mode 100644 arch/x86/lib/bios_pci.S delete mode 100644 arch/x86/lib/bios_setup.c delete mode 100644 arch/x86/lib/realmode.c delete mode 100644 arch/x86/lib/realmode_switch.S delete mode 100644 arch/x86/lib/video_bios.c delete mode 100644 board/eNET/Makefile delete mode 100644 board/eNET/eNET.c delete mode 100644 board/eNET/eNET_pci.c delete mode 100644 board/eNET/eNET_start.S delete mode 100644 board/eNET/eNET_start16.S delete mode 100644 board/eNET/hardware.h delete mode 100644 include/configs/eNET.h
These are no longer used and should be removed.
Signed-off-by: Simon Glass sjg@chromium.org --- board/eNET/Makefile | 52 ---- board/eNET/eNET.c | 284 --------------------- board/eNET/eNET_pci.c | 128 ---------- board/eNET/eNET_start.S | 30 --- board/eNET/eNET_start16.S | 87 ------- board/eNET/hardware.h | 36 --- boards.cfg | 2 - include/configs/eNET.h | 619 ---------------------------------------------- 8 files changed, 1238 deletions(-) delete mode 100644 board/eNET/Makefile delete mode 100644 board/eNET/eNET.c delete mode 100644 board/eNET/eNET_pci.c delete mode 100644 board/eNET/eNET_start.S delete mode 100644 board/eNET/eNET_start16.S delete mode 100644 board/eNET/hardware.h delete mode 100644 include/configs/eNET.h
diff --git a/board/eNET/Makefile b/board/eNET/Makefile deleted file mode 100644 index ad1c5b1..0000000 --- a/board/eNET/Makefile +++ /dev/null @@ -1,52 +0,0 @@ -# -# (C) Copyright 2008 -# Graeme Russ, graeme.russ@gmail.com. -# -# (C) Copyright 2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# (C) Copyright 2002 -# Daniel Engström, Omicron Ceti AB, daniel@omicron.se. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += eNET.o -COBJS-$(CONFIG_PCI) += eNET_pci.o -SOBJS-y += eNET_start16.o -SOBJS-y += eNET_start.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/eNET/eNET.c b/board/eNET/eNET.c deleted file mode 100644 index 2f26470..0000000 --- a/board/eNET/eNET.c +++ /dev/null @@ -1,284 +0,0 @@ -/* - * (C) Copyright 2008 - * Graeme Russ, graeme.russ@gmail.com. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/arch/sc520.h> -#include <net.h> -#include <netdev.h> - -#ifdef CONFIG_HW_WATCHDOG -#include <watchdog.h> -#endif - -#include "hardware.h" - -DECLARE_GLOBAL_DATA_PTR; - -unsigned long monitor_flash_len = CONFIG_SYS_MONITOR_LEN; - -static void enet_timer_isr(void); -static void enet_toggle_run_led(void); -static void enet_setup_pars(void); - -/* - * Miscellaneous platform dependent initializations - */ -int board_early_init_f(void) -{ - u16 pio_out_cfg = 0x0000; - - /* Configure General Purpose Bus timing */ - writeb(CONFIG_SYS_SC520_GPCSRT, &sc520_mmcr->gpcsrt); - writeb(CONFIG_SYS_SC520_GPCSPW, &sc520_mmcr->gpcspw); - writeb(CONFIG_SYS_SC520_GPCSOFF, &sc520_mmcr->gpcsoff); - writeb(CONFIG_SYS_SC520_GPRDW, &sc520_mmcr->gprdw); - writeb(CONFIG_SYS_SC520_GPRDOFF, &sc520_mmcr->gprdoff); - writeb(CONFIG_SYS_SC520_GPWRW, &sc520_mmcr->gpwrw); - writeb(CONFIG_SYS_SC520_GPWROFF, &sc520_mmcr->gpwroff); - - /* Configure Programmable Input/Output Pins */ - writew(CONFIG_SYS_SC520_PIODIR15_0, &sc520_mmcr->piodir15_0); - writew(CONFIG_SYS_SC520_PIODIR31_16, &sc520_mmcr->piodir31_16); - writew(CONFIG_SYS_SC520_PIOPFS31_16, &sc520_mmcr->piopfs31_16); - writew(CONFIG_SYS_SC520_PIOPFS15_0, &sc520_mmcr->piopfs15_0); - writeb(CONFIG_SYS_SC520_CSPFS, &sc520_mmcr->cspfs); - writeb(CONFIG_SYS_SC520_CLKSEL, &sc520_mmcr->clksel); - - /* - * Turn off top board - * Set StrataFlash chips to 16-bit width - * Set StrataFlash chips to normal (non reset/power down) mode - */ - pio_out_cfg |= CONFIG_SYS_ENET_TOP_BRD_PWR; - pio_out_cfg |= CONFIG_SYS_ENET_SF_WIDTH; - pio_out_cfg |= CONFIG_SYS_ENET_SF1_MODE; - pio_out_cfg |= CONFIG_SYS_ENET_SF2_MODE; - writew(pio_out_cfg, &sc520_mmcr->pioset15_0); - - /* Turn off auxiliary power output */ - writew(CONFIG_SYS_ENET_AUX_PWR, &sc520_mmcr->pioclr15_0); - - /* Clear FPGA program mode */ - writew(CONFIG_SYS_ENET_FPGA_PROG, &sc520_mmcr->pioset31_16); - - enet_setup_pars(); - - /* Disable Watchdog */ - writew(0x3333, &sc520_mmcr->wdtmrctl); - writew(0xcccc, &sc520_mmcr->wdtmrctl); - writew(0x0000, &sc520_mmcr->wdtmrctl); - - /* Chip Select Configuration */ - writew(CONFIG_SYS_SC520_BOOTCS_CTRL, &sc520_mmcr->bootcsctl); - writew(CONFIG_SYS_SC520_ROMCS1_CTRL, &sc520_mmcr->romcs1ctl); - writew(CONFIG_SYS_SC520_ROMCS2_CTRL, &sc520_mmcr->romcs2ctl); - - writeb(CONFIG_SYS_SC520_ADDDECCTL, &sc520_mmcr->adddecctl); - writeb(CONFIG_SYS_SC520_UART1CTL, &sc520_mmcr->uart1ctl); - writeb(CONFIG_SYS_SC520_UART2CTL, &sc520_mmcr->uart2ctl); - - writeb(CONFIG_SYS_SC520_SYSARBCTL, &sc520_mmcr->sysarbctl); - writew(CONFIG_SYS_SC520_SYSARBMENB, &sc520_mmcr->sysarbmenb); - - /* enable posted-writes */ - writeb(CONFIG_SYS_SC520_HBCTL, &sc520_mmcr->hbctl); - - return 0; -} - -static void enet_setup_pars(void) -{ - /* - * PARs 11 and 12 are 2MB SRAM @ 0x19000000 - * - * These are setup now because older version of U-Boot have them - * mapped to a different PAR which gets clobbered which prevents - * using SRAM for warm-booting a new image - */ - writel(CONFIG_SYS_SC520_SRAM1_PAR, &sc520_mmcr->par[11]); - writel(CONFIG_SYS_SC520_SRAM2_PAR, &sc520_mmcr->par[12]); - - /* PARs 0 and 1 are Compact Flash slots (4kB each) */ - writel(CONFIG_SYS_SC520_CF1_PAR, &sc520_mmcr->par[0]); - writel(CONFIG_SYS_SC520_CF2_PAR, &sc520_mmcr->par[1]); - - /* PAR 2 is used for Cache-As-RAM */ - - /* - * PARs 5 through 8 are additional NS16550 UARTS - * 8 bytes each @ 0x013f8, 0x012f8, 0x011f8 and 0x010f8 - */ - writel(CONFIG_SYS_SC520_UARTA_PAR, &sc520_mmcr->par[5]); - writel(CONFIG_SYS_SC520_UARTB_PAR, &sc520_mmcr->par[6]); - writel(CONFIG_SYS_SC520_UARTC_PAR, &sc520_mmcr->par[7]); - writel(CONFIG_SYS_SC520_UARTD_PAR, &sc520_mmcr->par[8]); - - /* PARs 9 and 10 are 32MB StrataFlash @ 0x10000000 */ - writel(CONFIG_SYS_SC520_SF1_PAR, &sc520_mmcr->par[9]); - writel(CONFIG_SYS_SC520_SF2_PAR, &sc520_mmcr->par[10]); - - /* PAR 13 is 4kB DPRAM @ 0x18100000 (implemented in FPGA) */ - writel(CONFIG_SYS_SC520_DPRAM_PAR, &sc520_mmcr->par[13]); - - /* - * PAR 14 is Low Level I/O (LEDs, Hex Switches etc) - * Already configured in board_init16 (eNET_start16.S) - * - * PAR 15 is Boot ROM - * Already configured in board_init16 (eNET_start16.S) - */ -} - - -int board_early_init_r(void) -{ - /* CPU Speed to 100MHz */ - gd->cpu_clk = 100000000; - - /* Crystal is 33.000MHz */ - gd->bus_clk = 33000000; - - return 0; -} - -void show_boot_progress(int val) -{ - uchar led_mask; - - led_mask = 0x00; - - if (val < 0) - led_mask |= LED_ERR_BITMASK; - - led_mask |= (uchar)(val & 0x001f); - outb(led_mask, LED_LATCH_ADDRESS); -} - - -int last_stage_init(void) -{ - outb(0x00, LED_LATCH_ADDRESS); - - register_timer_isr(enet_timer_isr); - - printf("Serck Controls eNET\n"); - - return 0; -} - -ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) -{ - if (banknum == 0) { /* non-CFI boot flash */ - info->portwidth = FLASH_CFI_8BIT; - info->chipwidth = FLASH_CFI_BY8; - info->interface = FLASH_CFI_X8; - return 1; - } else { - return 0; - } -} - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} - -void setup_pcat_compatibility() -{ - /* disable global interrupt mode */ - writeb(0x40, &sc520_mmcr->picicr); - - /* set all irqs to edge */ - writeb(0x00, &sc520_mmcr->pic_mode[0]); - writeb(0x00, &sc520_mmcr->pic_mode[1]); - writeb(0x00, &sc520_mmcr->pic_mode[2]); - - /* - * active low polarity on PIC interrupt pins, - * active high polarity on all other irq pins - */ - writew(0x0000, &sc520_mmcr->intpinpol); - - /* - * PIT 0 -> IRQ0 - * RTC -> IRQ8 - * FP error -> IRQ13 - * UART1 -> IRQ4 - * UART2 -> IRQ3 - */ - writeb(SC520_IRQ0, &sc520_mmcr->pit_int_map[0]); - writeb(SC520_IRQ8, &sc520_mmcr->rtcmap); - writeb(SC520_IRQ13, &sc520_mmcr->ferrmap); - writeb(SC520_IRQ4, &sc520_mmcr->uart_int_map[0]); - writeb(SC520_IRQ3, &sc520_mmcr->uart_int_map[1]); - - /* Disable all other interrupt sources */ - writeb(SC520_IRQ_DISABLED, &sc520_mmcr->gp_tmr_int_map[0]); - writeb(SC520_IRQ_DISABLED, &sc520_mmcr->gp_tmr_int_map[1]); - writeb(SC520_IRQ_DISABLED, &sc520_mmcr->gp_tmr_int_map[2]); - writeb(SC520_IRQ_DISABLED, &sc520_mmcr->pit_int_map[1]); - writeb(SC520_IRQ_DISABLED, &sc520_mmcr->pit_int_map[2]); - writeb(SC520_IRQ_DISABLED, &sc520_mmcr->ssimap); - writeb(SC520_IRQ_DISABLED, &sc520_mmcr->wdtmap); - writeb(SC520_IRQ_DISABLED, &sc520_mmcr->wpvmap); - writeb(SC520_IRQ_DISABLED, &sc520_mmcr->icemap); -} - -void enet_timer_isr(void) -{ - static long enet_ticks; - - enet_ticks++; - - /* Toggle Watchdog every 100ms */ - if ((enet_ticks % 100) == 0) - hw_watchdog_reset(); - - /* Toggle Run LED every 500ms */ - if ((enet_ticks % 500) == 0) - enet_toggle_run_led(); -} - -void hw_watchdog_reset(void) -{ - /* Watchdog Reset must be atomic */ - long flag = disable_interrupts(); - - if (sc520_mmcr->piodata15_0 & WATCHDOG_PIO_BIT) - sc520_mmcr->pioclr15_0 = WATCHDOG_PIO_BIT; - else - sc520_mmcr->pioset15_0 = WATCHDOG_PIO_BIT; - - if (flag) - enable_interrupts(); -} - -void enet_toggle_run_led(void) -{ - unsigned char leds_state = inb(LED_LATCH_ADDRESS); - if (leds_state & LED_RUN_BITMASK) - outb(leds_state & ~LED_RUN_BITMASK, LED_LATCH_ADDRESS); - else - outb(leds_state | LED_RUN_BITMASK, LED_LATCH_ADDRESS); -} diff --git a/board/eNET/eNET_pci.c b/board/eNET/eNET_pci.c deleted file mode 100644 index 5af4ef7..0000000 --- a/board/eNET/eNET_pci.c +++ /dev/null @@ -1,128 +0,0 @@ -/* - * (C) Copyright 2008,2009 - * Graeme Russ, graeme.russ@gmail.com - * - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <pci.h> -#include <asm/pci.h> -#include <asm/arch/pci.h> - -static void pci_enet_fixup_irq(struct pci_controller *hose, pci_dev_t dev) -{ - /* a configurable lists of IRQs to steal when we need one */ - static int irq_list[] = { - CONFIG_SYS_FIRST_PCI_IRQ, - CONFIG_SYS_SECOND_PCI_IRQ, - CONFIG_SYS_THIRD_PCI_IRQ, - CONFIG_SYS_FORTH_PCI_IRQ - }; - static int next_irq_index; - - uchar tmp_pin; - int pin; - - pci_hose_read_config_byte(hose, dev, PCI_INTERRUPT_PIN, &tmp_pin); - pin = tmp_pin; - - pin -= 1; /* PCI config space use 1-based numbering */ - if (pin == -1) - return; /* device use no irq */ - - /* map device number + pin to a pin on the sc520 */ - switch (PCI_DEV(dev)) { - case 12: /* First Ethernet Chip */ - pin += SC520_PCI_INTA; - break; - - case 13: /* Second Ethernet Chip */ - pin += SC520_PCI_INTB; - break; - - default: - return; - } - - pin &= 3; /* wrap around */ - - if (sc520_pci_ints[pin] == -1) { - /* re-route one interrupt for us */ - if (next_irq_index > 3) - return; - - if (pci_sc520_set_irq(pin, irq_list[next_irq_index])) - return; - - next_irq_index++; - } - - if (-1 != sc520_pci_ints[pin]) - pci_hose_write_config_byte(hose, dev, PCI_INTERRUPT_LINE, - sc520_pci_ints[pin]); - - printf("fixup_irq: device %d pin %c irq %d\n", - PCI_DEV(dev), 'A' + pin, sc520_pci_ints[pin]); -} - -static struct pci_controller enet_hose = { - fixup_irq: pci_enet_fixup_irq, -}; - -void pci_init_board(void) -{ - pci_sc520_init(&enet_hose); -} - -int pci_set_regions(struct pci_controller *hose) -{ - /* System memory space */ - pci_set_region(hose->regions + 0, - SC520_PCI_MEMORY_BUS, - SC520_PCI_MEMORY_PHYS, - SC520_PCI_MEMORY_SIZE, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - /* ISA/PCI memory space */ - pci_set_region(hose->regions + 1, - SC520_ISA_MEM_BUS, - SC520_ISA_MEM_PHYS, - SC520_ISA_MEM_SIZE, - PCI_REGION_MEM); - - /* PCI I/O space */ - pci_set_region(hose->regions + 2, - SC520_PCI_IO_BUS, - SC520_PCI_IO_PHYS, - SC520_PCI_IO_SIZE, - PCI_REGION_IO); - - /* ISA/PCI I/O space */ - pci_set_region(hose->regions + 3, - SC520_ISA_IO_BUS, - SC520_ISA_IO_PHYS, - SC520_ISA_IO_SIZE, - PCI_REGION_IO); - - return 4; -} diff --git a/board/eNET/eNET_start.S b/board/eNET/eNET_start.S deleted file mode 100644 index 0dec7ea..0000000 --- a/board/eNET/eNET_start.S +++ /dev/null @@ -1,30 +0,0 @@ -/* - * (C) Copyright 2008 - * Graeme Russ, graeme.russ@gmail.com. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include "hardware.h" - -/* board early intialization */ -.globl early_board_init -early_board_init: - /* No 32-bit board specific initialisation */ - jmp early_board_init_ret diff --git a/board/eNET/eNET_start16.S b/board/eNET/eNET_start16.S deleted file mode 100644 index 5e3f44c..0000000 --- a/board/eNET/eNET_start16.S +++ /dev/null @@ -1,87 +0,0 @@ -/* - * (C) Copyright 2008 - * Graeme Russ, graeme.russ@gmail.com. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * 16bit initialization code. - * This code have to map the area of the boot flash - * that is used by U-boot to its final destination. - */ - -#include "config.h" -#include "hardware.h" -#include <asm/arch/sc520.h> -#include <generated/asm-offsets.h> - -.text -.section .start16, "ax" -.code16 -.globl board_init16 -board_init16: - /* Alias MMCR to 0xdf000 */ - movw $0xfffc, %dx - movl $0x800df0cb, %eax - outl %eax, %dx - - /* Set ds to point to MMCR alias */ - movw $0xdf00, %ax - movw %ax, %ds - - /* Map PAR for Boot Flash (BOOTCS, 512kB @ 0x380000000) */ - movl $GENERATED_SC520_PAR14, %edi - movl $CONFIG_SYS_SC520_BOOTCS_PAR, %eax - movl %eax, (%di) - - /* Map PAR for LED, Hex Switches (GPCS6, 20 Bytes @ 0x1000) */ - movl $GENERATED_SC520_PAR15, %edi - movl $CONFIG_SYS_SC520_LLIO_PAR, %eax - movl %eax, (%di) - - /* Disabe MMCR alias */ - movw $0xfffc, %dx - movl $0x000000cb, %eax - outl %eax, %dx - - jmp board_init16_ret - -.section .bios, "ax" -.code16 -.globl realmode_reset -.hidden realmode_reset -.type realmode_reset, @function -realmode_reset: - /* Alias MMCR to 0xdf000 */ - movw $0xfffc, %dx - movl $0x800df0cb, %eax - outl %eax, %dx - - /* Set ds to point to MMCR alias */ - movw $0xdf00, %ax - movw %ax, %ds - - /* issue software reset thorugh MMCR */ - movl $0xd72, %edi - movb $0x01, %al - movb %al, (%di) - -1: hlt - jmp 1 diff --git a/board/eNET/hardware.h b/board/eNET/hardware.h deleted file mode 100644 index dec2cd8..0000000 --- a/board/eNET/hardware.h +++ /dev/null @@ -1,36 +0,0 @@ -/* - * (C) Copyright 2008 - * Graeme Russ, graeme.russ@gmail.com. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef HARDWARE_H_ -#define HARDWARE_H_ - -#define LED_LATCH_ADDRESS 0x1002 -#define LED_RUN_BITMASK 0x01 -#define LED_1_BITMASK 0x02 -#define LED_2_BITMASK 0x04 -#define LED_RX_BITMASK 0x08 -#define LED_TX_BITMASK 0x10 -#define LED_ERR_BITMASK 0x20 -#define WATCHDOG_PIO_BIT 0x8000 - -#endif /* HARDWARE_H_ */ diff --git a/boards.cfg b/boards.cfg index 98f7a14..d378e4d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -1118,7 +1118,5 @@ gr_ep2s60 sparc leon3 - gaisler grsim sparc leon3 - gaisler gr_xc3s_1500 sparc leon3 - gaisler coreboot-x86 x86 x86 coreboot chromebook-x86 coreboot coreboot:SYS_TEXT_BASE=0x01110000 -eNET x86 x86 eNET - sc520 eNET:SYS_TEXT_BASE=0x38040000 -eNET_SRAM x86 x86 eNET - sc520 eNET:SYS_TEXT_BASE=0x19000000 # Target ARCH CPU Board name Vendor SoC Options ######################################################################################################################## diff --git a/include/configs/eNET.h b/include/configs/eNET.h deleted file mode 100644 index 28cf95b..0000000 --- a/include/configs/eNET.h +++ /dev/null @@ -1,619 +0,0 @@ -/* - * (C) Copyright 2008 - * Graeme Russ, graeme.russ@gmail.com. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <asm/ibmpc.h> -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SYS_SC520 -#define CONFIG_SYS_SC520_SSI -#define CONFIG_SHOW_BOOT_PROGRESS -#define CONFIG_LAST_STAGE_INIT - -/*----------------------------------------------------------------------- - * Watchdog Configuration - * NOTE: If CONFIG_HW_WATCHDOG is NOT defined, the watchdog jumper on the - * bottom (processor) board MUST be removed! - */ -#undef CONFIG_WATCHDOG -#define CONFIG_HW_WATCHDOG - -/*----------------------------------------------------------------------- - * Real Time Clock Configuration - */ -#define CONFIG_RTC_MC146818 -#define CONFIG_SYS_ISA_IO_BASE_ADDRESS 0 - -/*----------------------------------------------------------------------- - * Serial Configuration - */ -#define CONFIG_CONS_INDEX 1 -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK 1843200 -#define CONFIG_BAUDRATE 9600 -#define CONFIG_SYS_BAUDRATE_TABLE {300, 600, 1200, 2400, 4800, \ - 9600, 19200, 38400, 115200} -#define CONFIG_SYS_NS16550_COM1 UART0_BASE -#define CONFIG_SYS_NS16550_COM2 UART1_BASE -#define CONFIG_SYS_NS16550_COM3 (0x1000 + UART0_BASE) -#define CONFIG_SYS_NS16550_COM4 (0x1000 + UART1_BASE) -#define CONFIG_SYS_NS16550_PORT_MAPPED - -/*----------------------------------------------------------------------- - * Video Configuration - */ -#undef CONFIG_VIDEO -#undef CONFIG_CFB_CONSOLE - -/*----------------------------------------------------------------------- - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_BDI -#define CONFIG_CMD_BOOTD -#define CONFIG_CMD_CONSOLE -#define CONFIG_CMD_DATE -#define CONFIG_CMD_ECHO -#define CONFIG_CMD_FLASH -#define CONFIG_CMD_FPGA -#define CONFIG_CMD_IMI -#define CONFIG_CMD_IMLS -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_ITEST -#define CONFIG_CMD_LOADB -#define CONFIG_CMD_LOADS -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_MISC -#define CONFIG_CMD_NET -#undef CONFIG_CMD_NFS -#define CONFIG_CMD_PCI -#define CONFIG_CMD_PING -#define CONFIG_CMD_RUN -#define CONFIG_CMD_SAVEENV -#define CONFIG_CMD_SETGETDCR -#define CONFIG_CMD_SOURCE -#define CONFIG_CMD_XIMG -#define CONFIG_CMD_ZBOOT - -#define CONFIG_BOOTDELAY 15 -#define CONFIG_BOOTARGS "root=/dev/mtdblock0 console=ttyS0,9600" - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_KGDB_BAUDRATE 115200 -#define CONFIG_KGDB_SER_INDEX 2 -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_PROMPT "boot > " -#define CONFIG_SYS_CBSIZE 256 -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT) + \ - 16) -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -#define CONFIG_SYS_MEMTEST_START 0x00100000 -#define CONFIG_SYS_MEMTEST_END 0x01000000 -#define CONFIG_SYS_LOAD_ADDR 0x100000 -#define CONFIG_SYS_HZ 1000 - -/*----------------------------------------------------------------------- - * SDRAM Configuration - */ -#define CONFIG_SYS_SDRAM_DRCTMCTL 0x18 -#define CONFIG_SYS_SDRAM_REFRESH_RATE 156 -#define CONFIG_NR_DRAM_BANKS 4 - -/* CONFIG_SYS_SDRAM_DRCTMCTL Overrides the following*/ -#undef CONFIG_SYS_SDRAM_PRECHARGE_DELAY -#undef CONFIG_SYS_SDRAM_RAS_CAS_DELAY -#undef CONFIG_SYS_SDRAM_CAS_LATENCY_2T -#undef CONFIG_SYS_SDRAM_CAS_LATENCY_3T - -/*----------------------------------------------------------------------- - * CPU Features - */ -#define CONFIG_SYS_SC520_HIGH_SPEED 0 -#define CONFIG_SYS_SC520_RESET -#define CONFIG_SYS_SC520_TIMER -#undef CONFIG_SYS_GENERIC_TIMER -#define CONFIG_SYS_PCAT_INTERRUPTS -#define CONFIG_SYS_NUM_IRQS 16 -#define CONFIG_SYS_PC_BIOS -#define CONFIG_SYS_PCI_BIOS -#define CONFIG_SYS_X86_REALMODE -#define CONFIG_SYS_X86_ISR_TIMER - -/*----------------------------------------------------------------------- - * Memory organization: - * 32kB Stack - * 16kB Cache-As-RAM @ 0x19200000 - * 256kB Monitor - * (128kB + Environment Sector Size) malloc pool - */ -#define CONFIG_SYS_STACK_SIZE (32 * 1024) -#define CONFIG_SYS_CAR_ADDR 0x19200000 -#define CONFIG_SYS_CAR_SIZE (16 * 1024) -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SECT_SIZE + \ - 128*1024) -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/*----------------------------------------------------------------------- - * FLASH configuration - * 512kB Boot Flash @ 0x38000000 (Monitor @ 38040000) - * 16MB StrataFlash #1 @ 0x10000000 - * 16MB StrataFlash #2 @ 0x11000000 - */ -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_FLASH_CFI_LEGACY -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_SYS_MAX_FLASH_BANKS 3 -#define CONFIG_SYS_FLASH_BASE 0x38000000 -#define CONFIG_SYS_FLASH_BASE_1 0x10000000 -#define CONFIG_SYS_FLASH_BASE_2 0x11000000 -#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE, \ - CONFIG_SYS_FLASH_BASE_1, \ - CONFIG_SYS_FLASH_BASE_2} -#define CONFIG_SYS_FLASH_EMPTY_INFO -#undef CONFIG_SYS_FLASH_USE_BUFFER_WRITE -#define CONFIG_SYS_MAX_FLASH_SECT 128 -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_8BIT -#define CONFIG_SYS_FLASH_LEGACY_512Kx8 -#define CONFIG_SYS_FLASH_ERASE_TOUT 2000 /* ms */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 2000 /* ms */ - -/*----------------------------------------------------------------------- - * Environment configuration - * - Boot flash is 512kB with 64kB sectors - * - StrataFlash is 32MB with 128kB sectors - * - Redundant embedded environment is 25% of the Boot flash - * - Redundant StrataFlash environment is <1% of the StrataFlash - * - Environment is therefore located in StrataFlash - * - Primary copy is located in first sector of first flash - * - Redundant copy is located in second sector of first flash - * - Stack is only 32kB, so environment size is limited to 4kB - */ -#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE 0x01000 -#define CONFIG_ENV_ADDR CONFIG_SYS_FLASH_BASE_1 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_SYS_FLASH_BASE_1 + \ - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE - -/*----------------------------------------------------------------------- - * PCI configuration - */ -#define CONFIG_PCI -#define CONFIG_PCI_PNP -#define CONFIG_SYS_FIRST_PCI_IRQ 10 -#define CONFIG_SYS_SECOND_PCI_IRQ 9 -#define CONFIG_SYS_THIRD_PCI_IRQ 11 -#define CONFIG_SYS_FORTH_PCI_IRQ 15 - -/*----------------------------------------------------------------------- - * Network device (TRL8100B) support - */ -#define CONFIG_RTL8139 - -/*----------------------------------------------------------------------- - * BOOTCS Control (for AM29LV040B-120JC) - * - * 000 0 00 0 000 11 0 011 }- 0x0033 - * \ / | | | \ / | | \ / - * | | | | | | | | - * | | | | | | | +---- 3 Wait States (First Access) - * | | | | | | +------- Reserved - * | | | | | +--------- 3 Wait States (Subsequent Access) - * | | | | +------------- Reserved - * | | | +---------------- Non-Paged Mode - * | | +------------------ 8 Bit Wide - * | +--------------------- GP Bus - * +------------------------ Reserved - */ -#define CONFIG_SYS_SC520_BOOTCS_CTRL 0x0033 - -/*----------------------------------------------------------------------- - * ROMCS Control (for E28F128J3A-150 StrataFlash) - * - * 000 0 01 1 000 01 0 101 }- 0x0615 - * \ / | | | \ / | | \ / - * | | | | | | | | - * | | | | | | | +---- 5 Wait States (First Access) - * | | | | | | +------- Reserved - * | | | | | +--------- 1 Wait State (Subsequent Access) - * | | | | +------------- Reserved - * | | | +---------------- Paged Mode - * | | +------------------ 16 Bit Wide - * | +--------------------- GP Bus - * +------------------------ Reserved - */ -#define CONFIG_SYS_SC520_ROMCS1_CTRL 0x0615 -#define CONFIG_SYS_SC520_ROMCS2_CTRL 0x0615 - -/*----------------------------------------------------------------------- - * SC520 General Purpose Bus configuration - * - * Chip Select Offset 1 Clock Cycle - * Chip Select Pulse Width 8 Clock Cycles - * Chip Select Read Offset 2 Clock Cycles - * Chip Select Read Width 6 Clock Cycles - * Chip Select Write Offset 2 Clock Cycles - * Chip Select Write Width 6 Clock Cycles - * Chip Select Recovery Time 2 Clock Cycles - * - * Timing Diagram (from SC520 Register Set Manual - Order #22005B) - * - * |<-------------General Purpose Bus Cycle---------------->| - * | | - * ----------------------__________________/------------------ - * |<--(GPCSOFF + 1)-->|<--(GPCSPW + 1)-->|<-(GPCSRT + 1)-> | - * - * ------------------------_______________/------------------- - * |<---(GPRDOFF + 1)--->|<-(GPRDW + 1)->| - * - * --------------------------_______________/----------------- - * |<----(GPWROFF + 1)---->|<-(GPWRW + 1)->| - * - * ________/-----------_______________________________________ - * |<--->|<--------->| - * ^ ^ - * (GPALEOFF + 1) | - * | - * (GPALEW + 1) - */ -#define CONFIG_SYS_SC520_GPCSOFF 0x00 -#define CONFIG_SYS_SC520_GPCSPW 0x07 -#define CONFIG_SYS_SC520_GPRDOFF 0x01 -#define CONFIG_SYS_SC520_GPRDW 0x05 -#define CONFIG_SYS_SC520_GPWROFF 0x01 -#define CONFIG_SYS_SC520_GPWRW 0x05 -#define CONFIG_SYS_SC520_GPCSRT 0x01 - -/*----------------------------------------------------------------------- - * SC520 Programmable I/O configuration - * - * Pin Mode Dir. Description - * ---------------------------------------------------------------------- - * PIO0 PIO Output Unused - * PIO1 GPBHE# Output GP Bus Byte High Enable (active low) - * PIO2 PIO Output Auxiliary power output enable - * PIO3 GPAEN Output GP Bus Address Enable - * PIO4 PIO Output Top Board Enable (active low) - * PIO5 PIO Output StrataFlash 16 bit mode (low = 8 bit mode) - * PIO6 PIO Input Data output of Power Supply ADC - * PIO7 PIO Output Clock input to Power Supply ADC - * PIO8 PIO Output Chip Select input of Power Supply ADC - * PIO9 PIO Output StrataFlash 1 Reset / Power Down (active low) - * PIO10 PIO Output StrataFlash 2 Reset / Power Down (active low) - * PIO11 PIO Input StrataFlash 1 Status - * PIO12 PIO Input StrataFlash 2 Status - * PIO13 GPIRQ10# Input Can Bus / I2C IRQ (active low) - * PIO14 PIO Input Low Input Voltage Warning (active low) - * PIO15 PIO Output Watchdog (must toggle at least every 1.6s) - * PIO16 PIO Input Power Fail - * PIO17 GPIRQ6 Input Compact Flash 1 IRQ (active low) - * PIO18 GPIRQ5 Input Compact Flash 2 IRQ (active low) - * PIO19 GPIRQ4# Input Dual-Port RAM IRQ (active low) - * PIO20 GPIRQ3 Input UART D IRQ - * PIO21 GPIRQ2 Input UART C IRQ - * PIO22 GPIRQ1 Input UART B IRQ - * PIO23 GPIRQ0 Input UART A IRQ - * PIO24 GPDBUFOE# Output GP Bus Data Bus Buffer Output Enable - * PIO25 PIO Input Battery OK Indication - * PIO26 GPMEMCS16# Input GP Bus Memory Chip-Select 16-bit access - * PIO27 GPCS0# Output SRAM 1 Chip Select - * PIO28 PIO Input Top Board UART CTS - * PIO29 PIO Output FPGA Program Mode (active low) - * PIO30 PIO Input FPGA Initialised (active low) - * PIO31 PIO Input FPGA Done (active low) - */ -#define CONFIG_SYS_SC520_PIOPFS15_0 0x200a -#define CONFIG_SYS_SC520_PIOPFS31_16 0x0dfe -#define CONFIG_SYS_SC520_PIODIR15_0 0x87bf -#define CONFIG_SYS_SC520_PIODIR31_16 0x2900 - -/*----------------------------------------------------------------------- - * PIO Pin defines - */ -#define CONFIG_SYS_ENET_AUX_PWR 0x0004 -#define CONFIG_SYS_ENET_TOP_BRD_PWR 0x0010 -#define CONFIG_SYS_ENET_SF_WIDTH 0x0020 -#define CONFIG_SYS_ENET_PWR_ADC_DATA 0x0040 -#define CONFIG_SYS_ENET_PWR_ADC_CLK 0x0080 -#define CONFIG_SYS_ENET_PWR_ADC_CS 0x0100 -#define CONFIG_SYS_ENET_SF1_MODE 0x0200 -#define CONFIG_SYS_ENET_SF2_MODE 0x0400 -#define CONFIG_SYS_ENET_SF1_STATUS 0x0800 -#define CONFIG_SYS_ENET_SF2_STATUS 0x1000 -#define CONFIG_SYS_ENET_PWR_STATUS 0x4000 -#define CONFIG_SYS_ENET_WATCHDOG 0x8000 - -#define CONFIG_SYS_ENET_PWR_FAIL 0x0001 -#define CONFIG_SYS_ENET_BAT_OK 0x0200 -#define CONFIG_SYS_ENET_TOP_BRD_CTS 0x1000 -#define CONFIG_SYS_ENET_FPGA_PROG 0x2000 -#define CONFIG_SYS_ENET_FPGA_INIT 0x4000 -#define CONFIG_SYS_ENET_FPGA_DONE 0x8000 - -/*----------------------------------------------------------------------- - * Chip Select Pin Function Select - * - * 1 1 1 1 1 0 0 0 }- 0xf8 - * | | | | | | | | - * | | | | | | | +--- Reserved - * | | | | | | +----- GPCS1_SEL = ROMCS1# - * | | | | | +------- GPCS2_SEL = ROMCS2# - * | | | | +--------- GPCS3_SEL = GPCS3 - * | | | +----------- GPCS4_SEL = GPCS4 - * | | +------------- GPCS5_SEL = GPCS5 - * | +--------------- GPCS6_SEL = GPCS6 - * +----------------- GPCS7_SEL = GPCS7 - */ -#define CONFIG_SYS_SC520_CSPFS 0xf8 - -/*----------------------------------------------------------------------- - * Clock Select (CLKTIMER[CLKTEST] pin) - * - * 0 111 00 1 0 }- 0x72 - * | \ / | | | - * | | | | +--- Pin Disabled - * | | | +----- Pin is an output - * | | +------- Reserved - * | +----------- Disabled (pin stays Low) - * +-------------- Reserved - */ -#define CONFIG_SYS_SC520_CLKSEL 0x72 - -/*----------------------------------------------------------------------- - * Address Decode Control - * - * 0 00 0 0 0 0 0 }- 0x00 - * | | | | | | | - * | | | | | | +--- Integrated UART 1 is enabled - * | | | | | +----- Integrated UART 2 is enabled - * | | | | +------- Integrated RTC is enabled - * | | | +--------- Reserved - * | | +----------- I/O Hole accesses are forwarded to the external GP bus - * | +------------- Reserved - * +---------------- Write-protect violations do not generate an IRQ - */ -#define CONFIG_SYS_SC520_ADDDECCTL 0x00 - -/*----------------------------------------------------------------------- - * UART Control - * - * 00000 1 1 1 }- 0x07 - * ___/ | | | - * | | | +--- Transmit TC interrupt enable - * | | +----- Receive TC interrupt enable - * | +------- 1.8432 MHz - * +----------- Reserved - */ -#define CONFIG_SYS_SC520_UART1CTL 0x07 -#define CONFIG_SYS_SC520_UART2CTL 0x07 - -/*----------------------------------------------------------------------- - * System Arbiter Control - * - * 00000 1 1 0 }- 0x06 - * ___/ | | | - * | | | +--- Disable PCI Bus Arbiter Grant Time-Out Interrupt - * | | +----- The system arbiter operates in concurrent mode - * | +------- Park the PCI bus on the last master that acquired the bus - * +----------- Reserved - */ -#define CONFIG_SYS_SC520_SYSARBCTL 0x06 - -/*----------------------------------------------------------------------- - * System Arbiter Master Enable - * - * 00000000000 0 0 0 1 1 }- 0x06 - * _________/ | | | | | - * | | | | | +--- PCI master REQ0 enabled (Ethernet 1) - * | | | | +----- PCI master REQ1 enabled (Ethernet 2) - * | | | +------- PCI master REQ2 disabled - * | | +--------- PCI master REQ3 disabled - * | +----------- PCI master REQ4 disabled - * +------------------ Reserved - */ -#define CONFIG_SYS_SC520_SYSARBMENB 0x0003 - -/*----------------------------------------------------------------------- - * System Arbiter Master Enable - * - * 0 0000 0 00 0000 1 000 }- 0x06 - * | __/ | | __/ | _/ - * | | | | | | +---- Reserved - * | | | | | +------- Enable CPU-to-PCI bus write posting - * | | | | +---------- Reserved - * | | | +-------------- PCI bus reads to SDRAM are not automatically - * | | | retried - * | | +----------------- Target read FIFOs are not snooped during write - * | | transactions - * | +-------------------- Reserved - * +------------------------ Deassert the PCI bus reset signal - */ -#define CONFIG_SYS_SC520_HBCTL 0x08 - -/*----------------------------------------------------------------------- - * PAR for Boot Flash - 512kB @ 0x38000000, BOOTCS - * 100 0 1 0 1 00000000111 11100000000000 }- 0x8a01f800 - * \ / | | | | ----+----/ -----+------/ - * | | | | | | +---------- Start at 0x38000000 - * | | | | | +----------------------- 512kB Region Size - * | | | | | ((7 + 1) * 64kB) - * | | | | +------------------------------ 64kB Page Size - * | | | +-------------------------------- Writes Enabled (So it can be - * | | | reprogrammed!) - * | | +---------------------------------- Caching Disabled - * | +------------------------------------ Execution Enabled - * +--------------------------------------- BOOTCS - */ -#define CONFIG_SYS_SC520_BOOTCS_PAR 0x8a01f800 - -/*----------------------------------------------------------------------- - * Cache-As-RAM (Targets Boot Flash) - * - * 100 1 0 0 0 0001111 011001001000000000 }- 0x903d9200 - * \ / | | | | --+--/ -------+--------/ - * | | | | | | +------------ Start at 0x19200000 - * | | | | | +------------------------- 64k Region Size - * | | | | | ((15 + 1) * 4kB) - * | | | | +------------------------------ 4kB Page Size - * | | | +-------------------------------- Writes Enabled - * | | +---------------------------------- Caching Enabled - * | +------------------------------------ Execution Prevented - * +--------------------------------------- BOOTCS - */ -#define CONFIG_SYS_SC520_CAR_PAR 0x903d9200 - -/*----------------------------------------------------------------------- - * PAR for Low Level I/O (LEDs, Hex Switches etc) - 33 Bytes @ 0x1000, GPCS6 - * - * 001 110 0 000100000 0001000000000000 }- 0x38201000 - * \ / \ / | ---+---/ ------+-------/ - * | | | | +----------- Start at 0x00001000 - * | | | +------------------------ 33 Bytes (0x20 + 1) - * | | +------------------------------ Ignored - * | +--------------------------------- GPCS6 - * +------------------------------------- GP Bus I/O - */ -#define CONFIG_SYS_SC520_LLIO_PAR 0x38201000 - -/*----------------------------------------------------------------------- - * PAR for Compact Flash Port #1 - 4kB @ 0x200000000, CS5 - * PAR for Compact Flash Port #2 - 4kB @ 0x200010000, CS7 - * - * 010 101 0 0000000 100000000000000000 }- 0x54020000 - * 010 111 0 0000000 100000000000000001 }- 0x5c020001 - * \ / \ / | --+--/ -------+--------/ - * | | | | +------------ Start at 0x200000000 - * | | | | 0x200010000 - * | | | +------------------------- 4kB Region Size - * | | | ((0 + 1) * 4kB) - * | | +------------------------------ 4k Page Size - * | +--------------------------------- GPCS5 - * | GPCS7 - * +------------------------------------- GP Bus Memory - */ -#define CONFIG_SYS_SC520_CF1_PAR 0x54020000 -#define CONFIG_SYS_SC520_CF2_PAR 0x5c020001 - -/*----------------------------------------------------------------------- - * PAR for Extra 16550 UART A - 8 bytes @ 0x013f8, GPCS0 - * PAR for Extra 16550 UART B - 8 bytes @ 0x012f8, GPCS3 - * PAR for Extra 16550 UART C - 8 bytes @ 0x011f8, GPCS4 - * PAR for Extra 16550 UART D - 8 bytes @ 0x010f8, GPCS5 - * - * 001 000 0 000000111 0001001111111000 }- 0x200713f8 - * 001 011 0 000000111 0001001011111000 }- 0x2c0712f8 - * 001 011 0 000000111 0001001011111000 }- 0x300711f8 - * 001 011 0 000000111 0001001011111000 }- 0x340710f8 - * \ / \ / | ---+---/ ------+-------/ - * | | | | +----------- Start at 0x013f8 - * | | | | 0x012f8 - * | | | | 0x011f8 - * | | | | 0x010f8 - * | | | +------------------------ 33 Bytes (32 + 1) - * | | +------------------------------ Ignored - * | +--------------------------------- GPCS6 - * +------------------------------------- GP Bus I/O - */ -#define CONFIG_SYS_SC520_UARTA_PAR 0x200713f8 -#define CONFIG_SYS_SC520_UARTB_PAR 0x2c0712f8 -#define CONFIG_SYS_SC520_UARTC_PAR 0x300711f8 -#define CONFIG_SYS_SC520_UARTD_PAR 0x340710f8 - -/*----------------------------------------------------------------------- - * PAR for StrataFlash #1 - 16MB @ 0x10000000, ROMCS1 - * PAR for StrataFlash #2 - 16MB @ 0x11000000, ROMCS2 - * - * 101 0 1 0 1 00011111111 01000000000000 }- 0xaa3fd000 - * 110 0 1 0 1 00011111111 01000100000000 }- 0xca3fd100 - * \ / | | | | ----+----/ -----+------/ - * | | | | | | +---------- Start at 0x10000000 - * | | | | | | 0x11000000 - * | | | | | +----------------------- 16MB Region Size - * | | | | | ((255 + 1) * 64kB) - * | | | | +------------------------------ 64kB Page Size - * | | | +-------------------------------- Writes Enabled - * | | +---------------------------------- Caching Disabled - * | +------------------------------------ Execution Enabled - * +--------------------------------------- ROMCS1 - * ROMCS2 - */ -#define CONFIG_SYS_SC520_SF1_PAR 0xaa3fd000 -#define CONFIG_SYS_SC520_SF2_PAR 0xca3fd100 - -/*----------------------------------------------------------------------- - * PAR for SRAM #1 - 1MB @ 0x19000000, GPCS0 - * PAR for SRAM #2 - 1MB @ 0x19100000, GPCS3 - * - * 010 000 1 00000001111 01100100000000 }- 0x4203d900 - * 010 011 1 00000001111 01100100010000 }- 0x4e03d910 - * \ / \ / | ----+----/ -----+------/ - * | | | | +---------- Start at 0x19000000 - * | | | | 0x19100000 - * | | | +----------------------- 1MB Region Size - * | | | ((15 + 1) * 64kB) - * | | +------------------------------ 64kB Page Size - * | +--------------------------------- GPCS0 - * | GPCS3 - * +------------------------------------- GP Bus Memory - */ -#define CONFIG_SYS_SC520_SRAM1_PAR 0x4203d900 -#define CONFIG_SYS_SC520_SRAM2_PAR 0x4e03d910 - -/*----------------------------------------------------------------------- - * PAR for Dual-Port RAM - 4kB @ 0x18100000, GPCS4 - * - * 010 100 0 00000000 11000000100000000 }- 0x50018100 - * \ / \ / | ---+--/ -------+-------/ - * | | | | +----------- Start at 0x18100000 - * | | | +------------------------ 4kB Region Size - * | | | ((0 + 1) * 4kB) - * | | +------------------------------ 4kB Page Size - * | +--------------------------------- GPCS4 - * +------------------------------------- GP Bus Memory - */ -#define CONFIG_SYS_SC520_DPRAM_PAR 0x50018100 - -#endif /* __CONFIG_H */
Hi Simon,
Acked-by: Graeme Russ graeme.russ@gmail.com
Regards,
Graeme
This x86 CPU variant is no longer required as the boards that use it have been removed.
Signed-off-by: Simon Glass sjg@chromium.org --- arch/x86/cpu/sc520/Makefile | 58 ---- arch/x86/cpu/sc520/asm-offsets.c | 45 --- arch/x86/cpu/sc520/sc520.c | 66 ----- arch/x86/cpu/sc520/sc520_car.S | 94 ------- arch/x86/cpu/sc520/sc520_pci.c | 142 ---------- arch/x86/cpu/sc520/sc520_reset.c | 40 --- arch/x86/cpu/sc520/sc520_sdram.c | 479 -------------------------------- arch/x86/cpu/sc520/sc520_ssi.c | 93 ------- arch/x86/cpu/sc520/sc520_timer.c | 89 ------ arch/x86/include/asm/arch-sc520/pci.h | 79 ------ arch/x86/include/asm/arch-sc520/sc520.h | 372 ------------------------- arch/x86/include/asm/arch-sc520/ssi.h | 34 --- 12 files changed, 1591 deletions(-) delete mode 100644 arch/x86/cpu/sc520/Makefile delete mode 100644 arch/x86/cpu/sc520/asm-offsets.c delete mode 100644 arch/x86/cpu/sc520/sc520.c delete mode 100644 arch/x86/cpu/sc520/sc520_car.S delete mode 100644 arch/x86/cpu/sc520/sc520_pci.c delete mode 100644 arch/x86/cpu/sc520/sc520_reset.c delete mode 100644 arch/x86/cpu/sc520/sc520_sdram.c delete mode 100644 arch/x86/cpu/sc520/sc520_ssi.c delete mode 100644 arch/x86/cpu/sc520/sc520_timer.c delete mode 100644 arch/x86/include/asm/arch-sc520/pci.h delete mode 100644 arch/x86/include/asm/arch-sc520/sc520.h delete mode 100644 arch/x86/include/asm/arch-sc520/ssi.h
diff --git a/arch/x86/cpu/sc520/Makefile b/arch/x86/cpu/sc520/Makefile deleted file mode 100644 index f462264..0000000 --- a/arch/x86/cpu/sc520/Makefile +++ /dev/null @@ -1,58 +0,0 @@ -# -# (C) Copyright 2008 -# Graeme Russ, graeme.russ@gmail.com. -# -# (C) Copyright 2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# (C) Copyright 2002 -# Daniel Engström, Omicron Ceti AB, daniel@omicron.se. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB := $(obj)lib$(SOC).o - -COBJS-$(CONFIG_SYS_SC520) += sc520.o -COBJS-$(CONFIG_PCI) += sc520_pci.o -COBJS-$(CONFIG_SYS_SC520_RESET) += sc520_reset.o -COBJS-$(CONFIG_SYS_SC520) += sc520_sdram.o -COBJS-$(CONFIG_SYS_SC520_SSI) += sc520_ssi.o -COBJS-$(CONFIG_SYS_SC520_TIMER) += sc520_timer.o - -SOBJS-$(CONFIG_SYS_SC520) += sc520_car.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### \ No newline at end of file diff --git a/arch/x86/cpu/sc520/asm-offsets.c b/arch/x86/cpu/sc520/asm-offsets.c deleted file mode 100644 index 794f00c..0000000 --- a/arch/x86/cpu/sc520/asm-offsets.c +++ /dev/null @@ -1,45 +0,0 @@ -/* - * Adapted from Linux v2.6.36 kernel: arch/powerpc/kernel/asm-offsets.c - * - * This program is used to generate definitions needed by - * assembly language modules. - * - * We use the technique used in the OSF Mach kernel code: - * generate asm statements containing #defines, - * compile this file to assembler, and then extract the - * #defines from the assembly-language output. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * as published by the Free Software Foundation; either version - * 2 of the License, or (at your option) any later version. - */ - -#include <common.h> -#include <asm/arch/sc520.h> - -#include <linux/kbuild.h> - -int main(void) -{ - DEFINE(GENERATED_GD_RELOC_OFF, offsetof(gd_t, reloc_off)); - - DEFINE(GENERATED_SC520_PAR0, offsetof(struct sc520_mmcr, par[0])); - DEFINE(GENERATED_SC520_PAR1, offsetof(struct sc520_mmcr, par[1])); - DEFINE(GENERATED_SC520_PAR2, offsetof(struct sc520_mmcr, par[2])); - DEFINE(GENERATED_SC520_PAR3, offsetof(struct sc520_mmcr, par[3])); - DEFINE(GENERATED_SC520_PAR4, offsetof(struct sc520_mmcr, par[4])); - DEFINE(GENERATED_SC520_PAR5, offsetof(struct sc520_mmcr, par[5])); - DEFINE(GENERATED_SC520_PAR6, offsetof(struct sc520_mmcr, par[6])); - DEFINE(GENERATED_SC520_PAR7, offsetof(struct sc520_mmcr, par[7])); - DEFINE(GENERATED_SC520_PAR8, offsetof(struct sc520_mmcr, par[8])); - DEFINE(GENERATED_SC520_PAR9, offsetof(struct sc520_mmcr, par[9])); - DEFINE(GENERATED_SC520_PAR10, offsetof(struct sc520_mmcr, par[10])); - DEFINE(GENERATED_SC520_PAR11, offsetof(struct sc520_mmcr, par[11])); - DEFINE(GENERATED_SC520_PAR12, offsetof(struct sc520_mmcr, par[12])); - DEFINE(GENERATED_SC520_PAR13, offsetof(struct sc520_mmcr, par[13])); - DEFINE(GENERATED_SC520_PAR14, offsetof(struct sc520_mmcr, par[14])); - DEFINE(GENERATED_SC520_PAR15, offsetof(struct sc520_mmcr, par[15])); - - return 0; -} diff --git a/arch/x86/cpu/sc520/sc520.c b/arch/x86/cpu/sc520/sc520.c deleted file mode 100644 index 3fe85e7..0000000 --- a/arch/x86/cpu/sc520/sc520.c +++ /dev/null @@ -1,66 +0,0 @@ -/* - * (C) Copyright 2008-2011 - * Graeme Russ, graeme.russ@gmail.com - * - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/processor-flags.h> -#include <asm/arch/sc520.h> - -DECLARE_GLOBAL_DATA_PTR; - -sc520_mmcr_t *sc520_mmcr = (sc520_mmcr_t *)SC520_MMCR_BASE; - -int cpu_init_f(void) -{ - if (CONFIG_SYS_SC520_HIGH_SPEED) { - /* set it to 133 MHz and write back */ - writeb(0x02, &sc520_mmcr->cpuctl); - gd->cpu_clk = 133000000; - } else { - /* set it to 100 MHz and write back */ - writeb(0x01, &sc520_mmcr->cpuctl); - gd->cpu_clk = 100000000; - } - - /* wait at least one millisecond */ - asm("movl $0x2000, %%ecx\n" - "0: pushl %%ecx\n" - "popl %%ecx\n" - "loop 0b\n" : : : "ecx"); - - return x86_cpu_init_f(); -} - -int cpu_init_r(void) -{ - /* Disable the PAR used for CAR */ - writel(0x0000000, &sc520_mmcr->par[2]); - - /* turn on the SDRAM write buffer */ - writeb(0x11, &sc520_mmcr->dbctl); - - return x86_cpu_init_r(); -} diff --git a/arch/x86/cpu/sc520/sc520_car.S b/arch/x86/cpu/sc520/sc520_car.S deleted file mode 100644 index c04cc1f..0000000 --- a/arch/x86/cpu/sc520/sc520_car.S +++ /dev/null @@ -1,94 +0,0 @@ -/* - * (C) Copyright 2010-2011 - * Graeme Russ, graeme.russ@gmail.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <asm/processor-flags.h> -#include <asm/arch/sc520.h> -#include <generated/asm-offsets.h> - -.section .text - -.globl car_init -car_init: - /* - * How to enable Cache-As-RAM for the AMD Elan SC520: - * 1. Turn off the CPU Cache (may not be strictly required) - * 2. Set code execution PAR (usually the BOOTCS region) to be - * non-cachable - * 3. Create a Cachable PAR Region for an area of memory which is - * a) NOT where the code is being executed - * b) NOT SDRAM (Controller not initialised yet) - * c) WILL response to read requests - * The easiest way to do this is to create a second BOOTCS - * PAR mappnig with an address != the PAR in step 2 - * 4. Issue a wbinvd to invalidate the CPU cache - * 5. Turn on the CPU Cache - * 6. Read 16kB from the cached PAR region setup in step 3 - * 7. Turn off the CPU Cache (but DO NOT issue a wbinvd) - * - * The following code uses PAR2 as the cached PAR (PAR0 and PAR1 - * are avoided as these are the only two PARs which can be used - * as PCI BUS Memory regions which the board might require) - * - * The configuration of PAR2 must be set in the board configuration - * file as CONFIG_SYS_SC520_CAR_PAR - */ - - /* Configure Cache-As-RAM PAR */ - movl $CONFIG_SYS_SC520_CAR_PAR, %eax - movl $(SC520_MMCR_BASE + GENERATED_SC520_PAR2), %edi - movl %eax, (%edi) - - /* Trash the cache then turn it on */ - wbinvd - movl %cr0, %eax - andl $~(X86_CR0_NW | X86_CR0_CD), %eax - movl %eax, %cr0 - - /* - * The cache is now enabled and empty. Map a region of memory to - * it by reading that region. - */ - movl $CONFIG_SYS_CAR_ADDR, %esi - movl $CONFIG_SYS_CAR_SIZE, %ecx - shrl $2, %ecx /* we are reading longs */ - cld - rep lodsl - - /* Turn off the cache, but don't trash it */ - movl %cr0, %eax - orl $(X86_CR0_NW | X86_CR0_CD), %eax - movl %eax, %cr0 - - /* Clear the CAR region */ - xorl %eax, %eax - movl $CONFIG_SYS_CAR_ADDR, %edi - movl $CONFIG_SYS_CAR_SIZE, %ecx - shrl $2, %ecx /* we are writing longs */ - rep stosl - - /* - * Done - We should now have CONFIG_SYS_CAR_SIZE bytes of - * Cache-As-RAM - */ - jmp car_init_ret diff --git a/arch/x86/cpu/sc520/sc520_pci.c b/arch/x86/cpu/sc520/sc520_pci.c deleted file mode 100644 index 52d07c1..0000000 --- a/arch/x86/cpu/sc520/sc520_pci.c +++ /dev/null @@ -1,142 +0,0 @@ -/* - * (C) Copyright 2008-2011 - * Graeme Russ, graeme.russ@gmail.com - * - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <pci.h> -#include <asm/io.h> -#include <asm/pci.h> -#include <asm/arch/pci.h> -#include <asm/arch/sc520.h> - -static struct { - u8 priority; - u16 level_reg; - u8 level_bit; -} sc520_irq[] = { - { SC520_IRQ0, 0, 0x01 }, - { SC520_IRQ1, 0, 0x02 }, - { SC520_IRQ2, 1, 0x02 }, - { SC520_IRQ3, 0, 0x08 }, - { SC520_IRQ4, 0, 0x10 }, - { SC520_IRQ5, 0, 0x20 }, - { SC520_IRQ6, 0, 0x40 }, - { SC520_IRQ7, 0, 0x80 }, - - { SC520_IRQ8, 1, 0x01 }, - { SC520_IRQ9, 1, 0x02 }, - { SC520_IRQ10, 1, 0x04 }, - { SC520_IRQ11, 1, 0x08 }, - { SC520_IRQ12, 1, 0x10 }, - { SC520_IRQ13, 1, 0x20 }, - { SC520_IRQ14, 1, 0x40 }, - { SC520_IRQ15, 1, 0x80 } -}; - -/* The interrupt used for PCI INTA-INTD */ -int sc520_pci_ints[15] = { - -1, -1, -1, -1, -1, -1, -1, -1, - -1, -1, -1, -1, -1, -1, -1 -}; - -/* utility function to configure a pci interrupt */ -int pci_sc520_set_irq(int pci_pin, int irq) -{ - int i; - u8 tmpb; - u16 tmpw; - - debug("set_irq(): map INT%c to IRQ%d\n", pci_pin + 'A', irq); - - if (irq < 0 || irq > 15) - return -1; /* illegal irq */ - - if (pci_pin < 0 || pci_pin > 15) - return -1; /* illegal pci int pin */ - - /* first disable any non-pci interrupt source that use - * this level */ - - /* PCI interrupt mapping (A through D)*/ - for (i = 0; i <= 3 ; i++) { - tmpb = readb(&sc520_mmcr->pci_int_map[i]); - - if (tmpb == sc520_irq[irq].priority) - writeb(SC520_IRQ_DISABLED, &sc520_mmcr->pci_int_map[i]); - } - - /* GP IRQ interrupt mapping */ - for (i = 0; i <= 10 ; i++) { - tmpb = readb(&sc520_mmcr->gp_int_map[i]); - - if (tmpb == sc520_irq[irq].priority) - writeb(SC520_IRQ_DISABLED, &sc520_mmcr->gp_int_map[i]); - } - - /* Set the trigger to level */ - tmpb = readb(&sc520_mmcr->pic_mode[sc520_irq[irq].level_reg]); - tmpb |= sc520_irq[irq].level_bit; - writeb(tmpb, &sc520_mmcr->pic_mode[sc520_irq[irq].level_reg]); - - - if (pci_pin < 4) { - /* PCI INTA-INTD */ - /* route the interrupt */ - writeb(sc520_irq[irq].priority, - &sc520_mmcr->pci_int_map[pci_pin]); - } else { - /* GPIRQ0-GPIRQ10 used for additional PCI INTS */ - writeb(sc520_irq[irq].priority, - &sc520_mmcr->gp_int_map[pci_pin - 4]); - - /* also set the polarity in this case */ - tmpw = readw(&sc520_mmcr->intpinpol); - tmpw |= (1 << (pci_pin-4)); - writew(tmpw, &sc520_mmcr->intpinpol); - } - - /* register the pin */ - sc520_pci_ints[pci_pin] = irq; - - - return 0; /* OK */ -} - -void pci_sc520_init(struct pci_controller *hose) -{ - hose->first_busno = 0; - hose->last_busno = 0xff; - hose->region_count = pci_set_regions(hose); - - pci_setup_type1(hose); - - pci_register_hose(hose); - - hose->last_busno = pci_hose_scan(hose); - - /* enable target memory acceses on host brige */ - pci_write_config_word(0, PCI_COMMAND, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); -} diff --git a/arch/x86/cpu/sc520/sc520_reset.c b/arch/x86/cpu/sc520/sc520_reset.c deleted file mode 100644 index 137af97..0000000 --- a/arch/x86/cpu/sc520/sc520_reset.c +++ /dev/null @@ -1,40 +0,0 @@ -/* - * (C) Copyright 2011 - * Graeme Russ, graeme.russ@gmail.com - * - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/arch/sc520.h> - -DECLARE_GLOBAL_DATA_PTR; - -void reset_cpu(ulong addr) -{ - printf("Resetting using SC520 MMCR\n"); - /* Write a '1' to the SYS_RST of the RESCFG MMCR */ - writeb(0x01, &sc520_mmcr->rescfg); - - /* NOTREACHED */ -} diff --git a/arch/x86/cpu/sc520/sc520_sdram.c b/arch/x86/cpu/sc520/sc520_sdram.c deleted file mode 100644 index 9dc1334..0000000 --- a/arch/x86/cpu/sc520/sc520_sdram.c +++ /dev/null @@ -1,479 +0,0 @@ -/* - * (C) Copyright 2010,2011 - * Graeme Russ, graeme.russ@gmail.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/processor-flags.h> -#include <asm/arch/sc520.h> - -DECLARE_GLOBAL_DATA_PTR; - -struct sc520_sdram_info { - u8 banks; - u8 columns; - u8 rows; - u8 size; -}; - -static void sc520_sizemem(void); -static void sc520_set_dram_timing(void); -static void sc520_set_dram_refresh_rate(void); -static void sc520_enable_dram_refresh(void); -static void sc520_enable_sdram(void); - -int dram_init_f(void) -{ - sc520_sizemem(); - sc520_set_dram_timing(); - sc520_set_dram_refresh_rate(); - sc520_enable_dram_refresh(); - sc520_enable_sdram(); - - return 0; -} - -static inline void sc520_dummy_write(void) -{ - writew(0x0000, CACHELINESZ); -} -static inline void sc520_issue_sdram_op_mode_select(u8 command) -{ - writeb(command, &sc520_mmcr->drcctl); - sc520_dummy_write(); -} - -static inline int check_long(u32 test_long) -{ - u8 i; - u8 tmp_byte = (u8)(test_long & 0x000000ff); - - for (i = 1; i < 4; i++) { - if ((u8)((test_long >> (i * 8)) & 0x000000ff) != tmp_byte) - return -1; - } - - return 0; -} - -static inline int write_and_test(u32 data, u32 address) -{ - writel(data, address); - if (readl(address) == data) - return 0; /* Good */ - else - return -1; /* Bad */ -} - -static void sc520_enable_sdram(void) -{ - u32 par_config; - - /* Enable Writes, Caching and Code Execution to SDRAM */ - par_config = readl(&sc520_mmcr->par[3]); - par_config &= ~(SC520_PAR_EXEC_DIS | - SC520_PAR_CACHE_DIS | - SC520_PAR_WRITE_DIS); - writel(par_config, &sc520_mmcr->par[3]); - - par_config = readl(&sc520_mmcr->par[4]); - par_config &= ~(SC520_PAR_EXEC_DIS | - SC520_PAR_CACHE_DIS | - SC520_PAR_WRITE_DIS); - writel(par_config, &sc520_mmcr->par[4]); -} - -static void sc520_set_dram_timing(void) -{ - u8 drctmctl = 0x00; - -#if defined CONFIG_SYS_SDRAM_DRCTMCTL - /* just have your hardware designer _GIVE_ you what you need here! */ - drctmctl = CONFIG_SYS_SDRAM_DRCTMCTL; -#else - switch (CONFIG_SYS_SDRAM_RAS_CAS_DELAY) { - case 2: - break; - case 3: - drctmctl |= 0x01; - break; - case 4: - default: - drctmctl |= 0x02; - break; - } - - switch (CONFIG_SYS_SDRAM_PRECHARGE_DELAY) { - case 2: - break; - case 3: - drctmctl |= 0x04; - break; - case 4: - default: - drctmctl |= 0x08; - break; - - case 6: - drctmctl |= 0x0c; - break; - } - - switch (CONFIG_SYS_SDRAM_CAS_LATENCY) { - case 2: - break; - case 3: - default: - drctmctl |= 0x10; - break; - } -#endif - writeb(drctmctl, &sc520_mmcr->drctmctl); - - /* Issue load mode register command */ - sc520_issue_sdram_op_mode_select(0x03); -} - -static void sc520_set_dram_refresh_rate(void) -{ - u8 drctl; - - drctl = readb(&sc520_mmcr->drcctl); - drctl &= 0xcf; - - switch (CONFIG_SYS_SDRAM_REFRESH_RATE) { - case 78: - break; - case 156: - default: - drctl |= 0x10; - break; - case 312: - drctl |= 0x20; - break; - case 624: - drctl |= 0x30; - break; - } - - writeb(drctl, &sc520_mmcr->drcctl); -} - -static void sc520_enable_dram_refresh(void) -{ - u8 drctl; - - drctl = readb(&sc520_mmcr->drcctl); - drctl &= 0x30; /* keep refresh rate */ - drctl |= 0x08; /* enable refresh, normal mode */ - - writeb(drctl, &sc520_mmcr->drcctl); -} - -static void sc520_get_bank_info(int bank, struct sc520_sdram_info *bank_info) -{ - u32 col_data; - u32 row_data; - - u32 drcbendadr; - u16 drccfg; - - u8 banks = 0x00; - u8 columns = 0x00; - u8 rows = 0x00; - - bank_info->banks = 0x00; - bank_info->columns = 0x00; - bank_info->rows = 0x00; - bank_info->size = 0x00; - - if ((bank < 0) || (bank > 3)) { - printf("Bad Bank ID\n"); - return; - } - - /* Save configuration */ - drcbendadr = readl(&sc520_mmcr->drcbendadr); - drccfg = readw(&sc520_mmcr->drccfg); - - /* Setup SDRAM Bank to largest possible size */ - writew(0x000b << (bank * 4), &sc520_mmcr->drccfg); - - /* Set ending address for this bank */ - writel(0x000000ff << (bank * 8), &sc520_mmcr->drcbendadr); - - /* write col 11 wrap adr */ - if (write_and_test(COL11_DATA, COL11_ADR) != 0) - goto restore_and_exit; - - /* write col 10 wrap adr */ - if (write_and_test(COL10_DATA, COL10_ADR) != 0) - goto restore_and_exit; - - /* write col 9 wrap adr */ - if (write_and_test(COL09_DATA, COL09_ADR) != 0) - goto restore_and_exit; - - /* write col 8 wrap adr */ - if (write_and_test(COL08_DATA, COL08_ADR) != 0) - goto restore_and_exit; - - col_data = readl(COL11_ADR); - - /* All four bytes in the read long must be the same */ - if (check_long(col_data) < 0) - goto restore_and_exit; - - if ((col_data >= COL08_DATA) && (col_data <= COL11_DATA)) - columns = (u8)(col_data & 0x000000ff); - else - goto restore_and_exit; - - /* write row 14 wrap adr */ - if (write_and_test(ROW14_DATA, ROW14_ADR) != 0) - goto restore_and_exit; - - /* write row 13 wrap adr */ - if (write_and_test(ROW13_DATA, ROW13_ADR) != 0) - goto restore_and_exit; - - /* write row 12 wrap adr */ - if (write_and_test(ROW12_DATA, ROW12_ADR) != 0) - goto restore_and_exit; - - /* write row 11 wrap adr */ - if (write_and_test(ROW11_DATA, ROW11_ADR) != 0) - goto restore_and_exit; - - if (write_and_test(ROW10_DATA, ROW10_ADR) != 0) - goto restore_and_exit; - - /* - * read data @ row 12 wrap adr to determine number of banks, - * and read data @ row 14 wrap adr to determine number of rows. - * if data @ row 12 wrap adr is not AA, 11 or 12 we have bad RAM. - * if data @ row 12 wrap == AA, we only have 2 banks, NOT 4 - * if data @ row 12 wrap == 11 or 12, we have 4 banks, - */ - row_data = readl(ROW12_ADR); - - /* All four bytes in the read long must be the same */ - if (check_long(row_data) != 0) - goto restore_and_exit; - - switch (row_data) { - case ROW10_DATA: - banks = 2; - break; - - case ROW11_DATA: - case ROW12_DATA: - banks = 4; - break; - - default: - goto restore_and_exit; - } - - row_data = readl(ROW14_ADR); - - /* All four bytes in the read long must be the same */ - if (check_long(row_data) != 0) - goto restore_and_exit; - - switch (row_data) { - case ROW11_DATA: - case ROW12_DATA: - case ROW13_DATA: - case ROW14_DATA: - rows = (u8)(row_data & 0x000000ff); - break; - - default: - goto restore_and_exit; - } - - bank_info->banks = banks; - bank_info->columns = columns; - bank_info->rows = rows; - - if ((bank_info->banks != 0) && - (bank_info->columns != 0) && - (bank_info->rows != 0)) { - bank_info->size = bank_info->rows; - bank_info->size >>= (11 - bank_info->columns); - bank_info->size++; - } - -restore_and_exit: - /* Restore configuration */ - writel(drcbendadr, &sc520_mmcr->drcbendadr); - writew(drccfg, &sc520_mmcr->drccfg); -} - -static void sc520_setup_sizemem(void) -{ - u8 i; - - /* Disable write buffer */ - writeb(0x00, &sc520_mmcr->dbctl); - - /* Disable ECC */ - writeb(0x00, &sc520_mmcr->eccctl); - - /* Set slowest SDRAM timing */ - writeb(0x1e, &sc520_mmcr->drctmctl); - - /* Issue a NOP to all SDRAM banks */ - sc520_issue_sdram_op_mode_select(0x01); - - /* Delay for 100 microseconds */ - udelay(100); - - /* Issue 'All Banks Precharge' command */ - sc520_issue_sdram_op_mode_select(0x02); - - /* Issue 2 'Auto Refresh Enable' command */ - sc520_issue_sdram_op_mode_select(0x04); - sc520_dummy_write(); - - /* Issue 'Load Mode Register' command */ - sc520_issue_sdram_op_mode_select(0x03); - - /* Issue 8 more 'Auto Refresh Enable' commands */ - sc520_issue_sdram_op_mode_select(0x04); - for (i = 0; i < 7; i++) - sc520_dummy_write(); - - /* Set control register to 'Normal Mode' */ - writeb(0x00, &sc520_mmcr->drcctl); -} - -static void sc520_sizemem(void) -{ - struct sc520_sdram_info sdram_info[4]; - u8 bank_config = 0x00; - u8 end_addr = 0x00; - u16 drccfg = 0x0000; - u32 drcbendadr = 0x00000000; - u8 i; - - /* Use PARs to disable caching of maximum allowable 256MB SDRAM */ - writel(SC520_SDRAM1_PAR | SC520_PAR_CACHE_DIS, &sc520_mmcr->par[3]); - writel(SC520_SDRAM2_PAR | SC520_PAR_CACHE_DIS, &sc520_mmcr->par[4]); - - sc520_setup_sizemem(); - - gd->ram_size = 0; - - /* Size each SDRAM bank */ - for (i = 0; i <= 3; i++) { - sc520_get_bank_info(i, &sdram_info[i]); - - if (sdram_info[i].banks != 0) { - /* Update Configuration register */ - bank_config = sdram_info[i].columns - 8; - - if (sdram_info[i].banks == 4) - bank_config |= 0x08; - - drccfg |= bank_config << (i * 4); - - /* Update End Address register */ - end_addr += sdram_info[i].size; - drcbendadr |= (end_addr | 0x80) << (i * 8); - - gd->ram_size += sdram_info[i].size << 22; - } - - /* Issue 'All Banks Precharge' command */ - sc520_issue_sdram_op_mode_select(0x02); - - /* Set control register to 'Normal Mode' */ - writeb(0x00, &sc520_mmcr->drcctl); - } - - writel(drcbendadr, &sc520_mmcr->drcbendadr); - writew(drccfg, &sc520_mmcr->drccfg); - - /* Clear PARs preventing caching of SDRAM */ - writel(0x00000000, &sc520_mmcr->par[3]); - writel(0x00000000, &sc520_mmcr->par[4]); -} - -int dram_init(void) -{ - ulong dram_ctrl; - ulong dram_present = 0x00000000; - - /* - * We read-back the configuration of the dram - * controller that the assembly code wrote - */ - dram_ctrl = readl(&sc520_mmcr->drcbendadr); - - gd->bd->bi_dram[0].start = 0; - if (dram_ctrl & 0x80) { - /* bank 0 enabled */ - gd->bd->bi_dram[1].start = (dram_ctrl & 0x7f) << 22; - dram_present = gd->bd->bi_dram[1].start; - gd->bd->bi_dram[0].size = gd->bd->bi_dram[1].start; - } else { - gd->bd->bi_dram[0].size = 0; - gd->bd->bi_dram[1].start = gd->bd->bi_dram[0].start; - } - - if (dram_ctrl & 0x8000) { - /* bank 1 enabled */ - gd->bd->bi_dram[2].start = (dram_ctrl & 0x7f00) << 14; - dram_present = gd->bd->bi_dram[2].start; - gd->bd->bi_dram[1].size = gd->bd->bi_dram[2].start - - gd->bd->bi_dram[1].start; - } else { - gd->bd->bi_dram[1].size = 0; - gd->bd->bi_dram[2].start = gd->bd->bi_dram[1].start; - } - - if (dram_ctrl & 0x800000) { - /* bank 2 enabled */ - gd->bd->bi_dram[3].start = (dram_ctrl & 0x7f0000) << 6; - dram_present = gd->bd->bi_dram[3].start; - gd->bd->bi_dram[2].size = gd->bd->bi_dram[3].start - - gd->bd->bi_dram[2].start; - } else { - gd->bd->bi_dram[2].size = 0; - gd->bd->bi_dram[3].start = gd->bd->bi_dram[2].start; - } - - if (dram_ctrl & 0x80000000) { - /* bank 3 enabled */ - dram_present = (dram_ctrl & 0x7f000000) >> 2; - gd->bd->bi_dram[3].size = dram_present - - gd->bd->bi_dram[3].start; - } else { - gd->bd->bi_dram[3].size = 0; - } - - gd->ram_size = dram_present; - - return 0; -} diff --git a/arch/x86/cpu/sc520/sc520_ssi.c b/arch/x86/cpu/sc520/sc520_ssi.c deleted file mode 100644 index cc601e5..0000000 --- a/arch/x86/cpu/sc520/sc520_ssi.c +++ /dev/null @@ -1,93 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/arch/ssi.h> -#include <asm/arch/sc520.h> - -int ssi_set_interface(int freq, int lsb_first, int inv_clock, int inv_phase) -{ - u8 temp = 0; - - if (freq >= 8192) - temp |= CTL_CLK_SEL_4; - else if (freq >= 4096) - temp |= CTL_CLK_SEL_8; - else if (freq >= 2048) - temp |= CTL_CLK_SEL_16; - else if (freq >= 1024) - temp |= CTL_CLK_SEL_32; - else if (freq >= 512) - temp |= CTL_CLK_SEL_64; - else if (freq >= 256) - temp |= CTL_CLK_SEL_128; - else if (freq >= 128) - temp |= CTL_CLK_SEL_256; - else - temp |= CTL_CLK_SEL_512; - - if (!lsb_first) - temp |= MSBF_ENB; - - if (inv_clock) - temp |= CLK_INV_ENB; - - if (inv_phase) - temp |= PHS_INV_ENB; - - writeb(temp, &sc520_mmcr->ssictl); - - return 0; -} - -u8 ssi_txrx_byte(u8 data) -{ - writeb(data, &sc520_mmcr->ssixmit); - while (readb(&sc520_mmcr->ssista) & SSISTA_BSY) - ; - writeb(SSICMD_CMD_SEL_XMITRCV, &sc520_mmcr->ssicmd); - while (readb(&sc520_mmcr->ssista) & SSISTA_BSY) - ; - - return readb(&sc520_mmcr->ssircv); -} - -void ssi_tx_byte(u8 data) -{ - writeb(data, &sc520_mmcr->ssixmit); - while (readb(&sc520_mmcr->ssista) & SSISTA_BSY) - ; - writeb(SSICMD_CMD_SEL_XMIT, &sc520_mmcr->ssicmd); -} - -u8 ssi_rx_byte(void) -{ - while (readb(&sc520_mmcr->ssista) & SSISTA_BSY) - ; - writeb(SSICMD_CMD_SEL_RCV, &sc520_mmcr->ssicmd); - while (readb(&sc520_mmcr->ssista) & SSISTA_BSY) - ; - - return readb(&sc520_mmcr->ssircv); -} diff --git a/arch/x86/cpu/sc520/sc520_timer.c b/arch/x86/cpu/sc520/sc520_timer.c deleted file mode 100644 index 41f121f..0000000 --- a/arch/x86/cpu/sc520/sc520_timer.c +++ /dev/null @@ -1,89 +0,0 @@ -/* - * (C) Copyright 2008-2011 - * Graeme Russ, graeme.russ@gmail.com - * - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/interrupt.h> -#include <asm/arch/sc520.h> - -void sc520_timer_isr(void) -{ - /* Ack the GP Timer Interrupt */ - writeb(0x02, &sc520_mmcr->gptmrsta); -} - -int timer_init(void) -{ - /* Register the SC520 specific timer interrupt handler */ - register_timer_isr(sc520_timer_isr); - - /* Install interrupt handler for GP Timer 1 */ - irq_install_handler (0, timer_isr, NULL); - - /* Map GP Timer 1 to Master PIC IR0 */ - writeb(0x01, &sc520_mmcr->gp_tmr_int_map[1]); - - /* Disable GP Timers 1 & 2 - Allow configuration writes */ - writew(0x4000, &sc520_mmcr->gptmr1ctl); - writew(0x4000, &sc520_mmcr->gptmr2ctl); - - /* Reset GP Timers 1 & 2 */ - writew(0x0000, &sc520_mmcr->gptmr1cnt); - writew(0x0000, &sc520_mmcr->gptmr2cnt); - - /* Setup GP Timer 2 as a 100kHz (10us) prescaler */ - writew(83, &sc520_mmcr->gptmr2maxcmpa); - writew(0xc001, &sc520_mmcr->gptmr2ctl); - - /* Setup GP Timer 1 as a 1000 Hz (1ms) interrupt generator */ - writew(100, &sc520_mmcr->gptmr1maxcmpa); - writew(0xe009, &sc520_mmcr->gptmr1ctl); - - unmask_irq(0); - - /* Clear the GP Timer 1 status register to get the show rolling*/ - writeb(0x02, &sc520_mmcr->gptmrsta); - - return 0; -} - -/* Allow boards to override udelay implementation */ -void __udelay(unsigned long usec) - __attribute__((weak, alias("sc520_udelay"))); - -void sc520_udelay(unsigned long usec) -{ - int m = 0; - long u; - - readw(&sc520_mmcr->swtmrmilli); - readw(&sc520_mmcr->swtmrmicro); - - do { - m += readw(&sc520_mmcr->swtmrmilli); - u = readw(&sc520_mmcr->swtmrmicro) + (m * 1000); - } while (u < usec); -} diff --git a/arch/x86/include/asm/arch-sc520/pci.h b/arch/x86/include/asm/arch-sc520/pci.h deleted file mode 100644 index 12ba656..0000000 --- a/arch/x86/include/asm/arch-sc520/pci.h +++ /dev/null @@ -1,79 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB daniel@omicron.se. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _ASM_IC_SC520_PCI_H_ -#define _ASM_IC_SC520_PCI_H_ 1 - -/* bus mapping constants (used for PCI core initialization) */ /* bus mapping constants */ -#define SC520_REG_ADDR 0x00000cf8 -#define SC520_REG_DATA 0x00000cfc - -#define SC520_ISA_MEM_PHYS 0x00000000 -#define SC520_ISA_MEM_BUS 0x00000000 -#define SC520_ISA_MEM_SIZE 0x01000000 - -#define SC520_ISA_IO_PHYS 0x00000000 -#define SC520_ISA_IO_BUS 0x00000000 -#define SC520_ISA_IO_SIZE 0x00001000 - -/* PCI I/O space from 0x1000 to 0xdfff - * (make 0xe000-0xfdff available for stuff like PCCard boot) */ -#define SC520_PCI_IO_PHYS 0x00001000 -#define SC520_PCI_IO_BUS 0x00001000 -#define SC520_PCI_IO_SIZE 0x0000d000 - -/* system memory from 0x00000000 to 0x0fffffff */ -#define SC520_PCI_MEMORY_PHYS 0x00000000 -#define SC520_PCI_MEMORY_BUS 0x00000000 -#define SC520_PCI_MEMORY_SIZE 0x10000000 - -/* PCI bus memory from 0x10000000 to 0x26ffffff - * (make 0x27000000 - 0x27ffffff available for stuff like PCCard boot) */ -#define SC520_PCI_MEM_PHYS 0x10000000 -#define SC520_PCI_MEM_BUS 0x10000000 -#define SC520_PCI_MEM_SIZE 0x17000000 - -/* pin number used for PCI interrupt mappings */ -#define SC520_PCI_INTA 0 -#define SC520_PCI_INTB 1 -#define SC520_PCI_INTC 2 -#define SC520_PCI_INTD 3 -#define SC520_PCI_GPIRQ0 4 -#define SC520_PCI_GPIRQ1 5 -#define SC520_PCI_GPIRQ2 6 -#define SC520_PCI_GPIRQ3 7 -#define SC520_PCI_GPIRQ4 8 -#define SC520_PCI_GPIRQ5 9 -#define SC520_PCI_GPIRQ6 10 -#define SC520_PCI_GPIRQ7 11 -#define SC520_PCI_GPIRQ8 12 -#define SC520_PCI_GPIRQ9 13 -#define SC520_PCI_GPIRQ10 14 - -extern int sc520_pci_ints[]; - -void pci_sc520_init(struct pci_controller *hose); -int pci_set_regions(struct pci_controller *hose); -int pci_sc520_set_irq(int pci_pin, int irq); - -#endif diff --git a/arch/x86/include/asm/arch-sc520/sc520.h b/arch/x86/include/asm/arch-sc520/sc520.h deleted file mode 100644 index 9dc29d3..0000000 --- a/arch/x86/include/asm/arch-sc520/sc520.h +++ /dev/null @@ -1,372 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB daniel@omicron.se. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _ASM_IC_SC520_H_ -#define _ASM_IC_SC520_H_ 1 - -#ifndef __ASSEMBLY__ - -void init_sc520(void); -unsigned long init_sc520_dram(void); -void sc520_udelay(unsigned long usec); - -/* Memory mapped configuration registers */ -typedef struct sc520_mmcr { - u16 revid; /* ElanSC520 microcontroller revision id */ - u8 cpuctl; /* am5x86 CPU control */ - - u8 pad_0x003[0x0d]; - - u8 drcctl; /* SDRAM control */ - u8 pad_0x011[0x01]; - u8 drctmctl; /* SDRAM timing control */ - u8 pad_0x013[0x01]; - u16 drccfg; /* SDRAM bank configuration*/ - u8 pad_0x016[0x02]; - u32 drcbendadr; /* SDRAM bank 0-3 ending address*/ - u8 pad_0x01c[0x04]; - u8 eccctl; /* ECC control */ - u8 eccsta; /* ECC status */ - u8 eccckbpos; /* ECC check bit position */ - u8 ecccktest; /* ECC Check Code Test */ - u32 eccsbadd; /* ECC single-bit error address */ - u32 eccmbadd; /* ECC multi-bit error address */ - - u8 pad_0x02c[0x14]; - - u8 dbctl; /* SDRAM buffer control */ - - u8 pad_0x041[0x0f]; - - u16 bootcsctl; /* /BOOTCS control */ - u8 pad_0x052[0x02]; - u16 romcs1ctl; /* /ROMCS1 control */ - u16 romcs2ctl; /* /ROMCS2 control */ - - u8 pad_0x058[0x08]; - - u16 hbctl; /* host bridge control */ - u16 hbtgtirqctl; /* host bridge target interrupt control */ - u16 hbtgtirqsta; /* host bridge target interrupt status */ - u16 hbmstirqctl; /* host bridge target interrupt control */ - u16 hbmstirqsta; /* host bridge master interrupt status */ - u8 pad_0x06a[0x02]; - u32 mstintadd; /* host bridge master interrupt address */ - - u8 sysarbctl; /* system arbiter control */ - u8 pciarbsta; /* PCI bus arbiter status */ - u16 sysarbmenb; /* system arbiter master enable */ - u32 arbprictl; /* arbiter priority control */ - - u8 pad_0x078[0x08]; - - u8 adddecctl; /* address decode control */ - u8 pad_0x081[0x01]; - u16 wpvsta; /* write-protect violation status */ - u8 pad_0x084[0x04]; - u32 par[16]; /* programmable address regions */ - - u8 pad_0x0c8[0x0b38]; - - u8 gpecho; /* GP echo mode */ - u8 gpcsdw; /* GP chip select data width */ - u16 gpcsqual; /* GP chip select qualification */ - u8 pad_0xc04[0x4]; - u8 gpcsrt; /* GP chip select recovery time */ - u8 gpcspw; /* GP chip select pulse width */ - u8 gpcsoff; /* GP chip select offset */ - u8 gprdw; /* GP read pulse width */ - u8 gprdoff; /* GP read offset */ - u8 gpwrw; /* GP write pulse width */ - u8 gpwroff; /* GP write offset */ - u8 gpalew; /* GP ale pulse width */ - u8 gpaleoff; /* GP ale offset */ - - u8 pad_0xc11[0x0f]; - - u16 piopfs15_0; /* PIO15-PIO0 pin function select */ - u16 piopfs31_16; /* PIO31-PIO16 pin function select */ - u8 cspfs; /* chip select pin function select */ - u8 pad_0xc25[0x01]; - u8 clksel; /* clock select */ - u8 pad_0xc27[0x01]; - u16 dsctl; /* drive strength control */ - u16 piodir15_0; /* PIO15-PIO0 direction */ - u16 piodir31_16; /* PIO31-PIO16 direction */ - u8 pad_0xc2e[0x02]; - u16 piodata15_0 ; /* PIO15-PIO0 data */ - u16 piodata31_16; /* PIO31-PIO16 data */ - u16 pioset15_0; /* PIO15-PIO0 set */ - u16 pioset31_16; /* PIO31-PIO16 set */ - u16 pioclr15_0; /* PIO15-PIO0 clear */ - u16 pioclr31_16; /* PIO31-PIO16 clear */ - - u8 pad_0xc3c[0x24]; - - u16 swtmrmilli; /* software timer millisecond count */ - u16 swtmrmicro; /* software timer microsecond count */ - u8 swtmrcfg; /* software timer configuration */ - - u8 pad_0xc65[0x0b]; - - u8 gptmrsta; /* GP timers status register */ - u8 pad_0xc71; - u16 gptmr0ctl; /* GP timer 0 mode/control */ - u16 gptmr0cnt; /* GP timer 0 count */ - u16 gptmr0maxcmpa; /* GP timer 0 maxcount compare A */ - u16 gptmr0maxcmpb; /* GP timer 0 maxcount compare B */ - u16 gptmr1ctl; /* GP timer 1 mode/control */ - u16 gptmr1cnt; /* GP timer 1 count */ - u16 gptmr1maxcmpa; /* GP timer 1 maxcount compare A */ - u16 gptmr1maxcmpb; /* GP timer 1 maxcount compare B*/ - u16 gptmr2ctl; /* GP timer 2 mode/control */ - u16 gptmr2cnt; /* GP timer 2 count */ - u8 pad_0xc86[0x08]; - u16 gptmr2maxcmpa; /* GP timer 2 maxcount compare A */ - - u8 pad_0xc90[0x20]; - - u16 wdtmrctl; /* watchdog timer control */ - u16 wdtmrcntl; /* watchdog timer count low */ - u16 wdtmrcnth; /* watchdog timer count high */ - - u8 pad_0xcb6[0x0a]; - - u8 uart1ctl; /* UART 1 general control */ - u8 uart1sta; /* UART 1 general status */ - u8 uart1fcrshad; /* UART 1 FIFO control shadow */ - u8 pad_0xcc3[0x01]; - u8 uart2ctl; /* UART 2 general control */ - u8 uart2sta; /* UART 2 general status */ - u8 uart2fcrshad; /* UART 2 FIFO control shadow */ - - u8 pad_0xcc7[0x09]; - - u8 ssictl; /* SSI control */ - u8 ssixmit; /* SSI transmit */ - u8 ssicmd; /* SSI command */ - u8 ssista; /* SSI status */ - u8 ssircv; /* SSI receive */ - - u8 pad_0xcd5[0x2b]; - - u8 picicr; /* interrupt control */ - u8 pad_0xd01[0x01]; - u8 pic_mode[3]; /* PIC interrupt mode */ - u8 pad_0xd05[0x03]; - u16 swint16_1; /* software interrupt 16-1 control */ - u8 swint22_17; /* software interrupt 22-17/NMI control */ - u8 pad_0xd0b[0x05]; - u16 intpinpol; /* interrupt pin polarity */ - u8 pad_0xd12[0x02]; - u16 pcihostmap; /* PCI host bridge interrupt mapping */ - u8 pad_0xd16[0x02]; - u16 eccmap; /* ECC interrupt mapping */ - u8 gp_tmr_int_map[3]; /* GP timer interrupt mapping */ - u8 pad_0xd1d[0x03]; - u8 pit_int_map[3]; /* PIT interrupt mapping */ - u8 pad_0xd23[0x05]; - u8 uart_int_map[2]; /* UART interrupt mapping */ - u8 pad_0xd2a[0x06]; - u8 pci_int_map[4]; /* PCI interrupt mapping (A through D)*/ - u8 pad_0xd34[0x0c]; - u8 dmabcintmap; /* DMA buffer chaining interrupt mapping */ - u8 ssimap; /* SSI interrupt mapping register */ - u8 wdtmap; /* watchdog timer interrupt mapping */ - u8 rtcmap; /* RTC interrupt mapping register */ - u8 wpvmap; /* write-protect interrupt mapping */ - u8 icemap; /* AMDebug JTAG Rx/Tx interrupt mapping */ - u8 ferrmap; /* floating point error interrupt mapping */ - u8 pad_0xd47[0x09]; - u8 gp_int_map[11]; /* GP IRQ interrupt mapping */ - - u8 pad_0xd5b[0x15]; - - u8 sysinfo; /* system board information */ - u8 pad_0xd71[0x01]; - u8 rescfg; /* reset configuration */ - u8 pad_0xd73[0x01]; - u8 ressta; /* reset status */ - - u8 pad_0xd75[0x0b]; - - u8 gpdmactl; /* GP-DMA Control */ - u8 gpdmammio; /* GP-DMA memory-mapped I/O */ - u16 gpdmaextchmapa; /* GP-DMA resource channel map a */ - u16 gpdmaextchmapb; /* GP-DMA resource channel map b */ - u8 gp_dma_ext_pg_0; /* GP-DMA channel extended page 0 */ - u8 gp_dma_ext_pg_1; /* GP-DMA channel extended page 0 */ - u8 gp_dma_ext_pg_2; /* GP-DMA channel extended page 0 */ - u8 gp_dma_ext_pg_3; /* GP-DMA channel extended page 0 */ - u8 gp_dma_ext_pg_5; /* GP-DMA channel extended page 0 */ - u8 gp_dma_ext_pg_6; /* GP-DMA channel extended page 0 */ - u8 gp_dma_ext_pg_7; /* GP-DMA channel extended page 0 */ - u8 pad_0xd8d[0x03]; - u8 gpdmaexttc3; /* GP-DMA channel 3 extender transfer count */ - u8 gpdmaexttc5; /* GP-DMA channel 5 extender transfer count */ - u8 gpdmaexttc6; /* GP-DMA channel 6 extender transfer count */ - u8 gpdmaexttc7; /* GP-DMA channel 7 extender transfer count */ - u8 pad_0xd94[0x4]; - u8 gpdmabcctl; /* buffer chaining control */ - u8 gpdmabcsta; /* buffer chaining status */ - u8 gpdmabsintenb; /* buffer chaining interrupt enable */ - u8 gpdmabcval; /* buffer chaining valid */ - u8 pad_0xd9c[0x04]; - u16 gpdmanxtaddl3; /* GP-DMA channel 3 next address low */ - u16 gpdmanxtaddh3; /* GP-DMA channel 3 next address high */ - u16 gpdmanxtaddl5; /* GP-DMA channel 5 next address low */ - u16 gpdmanxtaddh5; /* GP-DMA channel 5 next address high */ - u16 gpdmanxtaddl6; /* GP-DMA channel 6 next address low */ - u16 gpdmanxtaddh6; /* GP-DMA channel 6 next address high */ - u16 gpdmanxtaddl7; /* GP-DMA channel 7 next address low */ - u16 gpdmanxtaddh7; /* GP-DMA channel 7 next address high */ - u16 gpdmanxttcl3; /* GP-DMA channel 3 next transfer count low */ - u16 gpdmanxttch3; /* GP-DMA channel 3 next transfer count high */ - u16 gpdmanxttcl5; /* GP-DMA channel 5 next transfer count low */ - u16 gpdmanxttch5; /* GP-DMA channel 5 next transfer count high */ - u16 gpdmanxttcl6; /* GP-DMA channel 6 next transfer count low */ - u16 gpdmanxttch6; /* GP-DMA channel 6 next transfer count high */ - u16 gpdmanxttcl7; /* GP-DMA channel 7 next transfer count low */ - u16 gpdmanxttch7; /* GP-DMA channel 7 next transfer count high */ - - u8 pad_0xdc0[0x0240]; -} sc520_mmcr_t; - -extern sc520_mmcr_t *sc520_mmcr; - -#endif - -/* Memory Mapped Control Registers (MMCR) Base Address */ -#define SC520_MMCR_BASE 0xfffef000 - -/* - * PARs for maximum allowable 256MB of SDRAM @ 0x00000000 - * Two PARs are required due to maximum PAR size of 128MB - * These are used in the SDRAM sizing code to disable caching - * - * 111 0 0 0 1 11111111111 00000000000000 }- 0xe3ffc000 - * 111 0 0 0 1 11111111111 00100000000000 }- 0xe3ffc800 - * \ / | | | | ----+----/ -----+------/ - * | | | | | | +---------- Start at 0x00000000 - * | | | | | | 0x08000000 - * | | | | | +----------------------- 128MB Region Size - * | | | | | ((2047 + 1) * 64kB) - * | | | | +------------------------------ 64kB Page Size - * | | | +-------------------------------- Writes Enabled - * | | +---------------------------------- Caching Enabled - * | +------------------------------------ Execution Enabled - * +--------------------------------------- SDRAM - */ -#define SC520_SDRAM1_PAR 0xe3ffc000 -#define SC520_SDRAM2_PAR 0xe3ffc800 - -#define SC520_PAR_WRITE_DIS 0x04000000 -#define SC520_PAR_CACHE_DIS 0x08000000 -#define SC520_PAR_EXEC_DIS 0x10000000 - -/* - * Programmable Address Regions to cover 256MB SDRAM (Maximum supported) - * required for DRAM sizing code - */ - -/* MMCR Register bits (not all of them :) ) */ - -/* SSI Stuff */ -#define CTL_CLK_SEL_4 0x00 /* Nominal Bit Rate = 8 MHz */ -#define CTL_CLK_SEL_8 0x10 /* Nominal Bit Rate = 4 MHz */ -#define CTL_CLK_SEL_16 0x20 /* Nominal Bit Rate = 2 MHz */ -#define CTL_CLK_SEL_32 0x30 /* Nominal Bit Rate = 1 MHz */ -#define CTL_CLK_SEL_64 0x40 /* Nominal Bit Rate = 512 KHz */ -#define CTL_CLK_SEL_128 0x50 /* Nominal Bit Rate = 256 KHz */ -#define CTL_CLK_SEL_256 0x60 /* Nominal Bit Rate = 128 KHz */ -#define CTL_CLK_SEL_512 0x70 /* Nominal Bit Rate = 64 KHz */ - -#define TC_INT_ENB 0x08 /* Transaction Complete Interrupt Enable */ -#define PHS_INV_ENB 0x04 /* SSI Inverted Phase Mode Enable */ -#define CLK_INV_ENB 0x02 /* SSI Inverted Clock Mode Enable */ -#define MSBF_ENB 0x01 /* SSI Most Significant Bit First Mode Enable */ - -#define SSICMD_CMD_SEL_XMITRCV 0x03 /* Simultaneous Transmit / Receive Transaction */ -#define SSICMD_CMD_SEL_RCV 0x02 /* Receive Transaction */ -#define SSICMD_CMD_SEL_XMIT 0x01 /* Transmit Transaction */ -#define SSISTA_BSY 0x02 /* SSI Busy */ -#define SSISTA_TC_INT 0x01 /* SSI Transaction Complete Interrupt */ - -/* BITS for SC520_ADDDECCTL: */ -#define WPV_INT_ENB 0x80 /* Write-Protect Violation Interrupt Enable */ -#define IO_HOLE_DEST_PCI 0x10 /* I/O Hole Access Destination */ -#define RTC_DIS 0x04 /* RTC Disable */ -#define UART2_DIS 0x02 /* UART2 Disable */ -#define UART1_DIS 0x01 /* UART1 Disable */ - -/* - * Defines used for SDRAM Sizing (number of columns and rows) - * Refer to section 10.6.4 - SDRAM Sizing Algorithm in the - * Elan SC520 Microcontroller User's Manual (Order #22004B) - */ -#define CACHELINESZ 0x00000010 - -#define COL11_ADR 0x0e001e00 -#define COL10_ADR 0x0e000e00 -#define COL09_ADR 0x0e000600 -#define COL08_ADR 0x0e000200 -#define COL11_DATA 0x0b0b0b0b -#define COL10_DATA 0x0a0a0a0a -#define COL09_DATA 0x09090909 -#define COL08_DATA 0x08080808 - -#define ROW14_ADR 0x0f000000 -#define ROW13_ADR 0x07000000 -#define ROW12_ADR 0x03000000 -#define ROW11_ADR 0x01000000 -#define ROW10_ADR 0x00000000 -#define ROW14_DATA 0x3f3f3f3f -#define ROW13_DATA 0x1f1f1f1f -#define ROW12_DATA 0x0f0f0f0f -#define ROW11_DATA 0x07070707 -#define ROW10_DATA 0xaaaaaaaa - -/* 0x28000000 - 0x3fffffff is used by the flash banks */ - -/* 0x40000000 - 0xffffffff is not adressable by the SC520 */ - -/* priority numbers used for interrupt channel mappings */ -#define SC520_IRQ_DISABLED 0 -#define SC520_IRQ0 1 -#define SC520_IRQ1 2 -#define SC520_IRQ2 4 /* same as IRQ9 */ -#define SC520_IRQ3 11 -#define SC520_IRQ4 12 -#define SC520_IRQ5 13 -#define SC520_IRQ6 21 -#define SC520_IRQ7 22 -#define SC520_IRQ8 3 -#define SC520_IRQ9 4 -#define SC520_IRQ10 5 -#define SC520_IRQ11 6 -#define SC520_IRQ12 7 -#define SC520_IRQ13 8 -#define SC520_IRQ14 9 -#define SC520_IRQ15 10 - -#endif diff --git a/arch/x86/include/asm/arch-sc520/ssi.h b/arch/x86/include/asm/arch-sc520/ssi.h deleted file mode 100644 index bd48eab..0000000 --- a/arch/x86/include/asm/arch-sc520/ssi.h +++ /dev/null @@ -1,34 +0,0 @@ -/* - * (C) Copyright 2008 - * Graeme Russ graeme.russ@gmail.com. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _ASM_IC_SSI_H_ -#define _ASM_IC_SSI_H_ 1 - -int ssi_set_interface(int, int, int, int); -void ssi_chip_select(int); -u8 ssi_txrx_byte(u8); -void ssi_tx_byte(u8); -u8 ssi_rx_byte(void); - - -#endif
Hi Simon,
Regards,
Graeme
This code is pretty old and we want to support only 32-bit systems now.
Signed-off-by: Simon Glass sjg@chromium.org --- README | 5 - arch/x86/config.mk | 1 - arch/x86/cpu/u-boot.lds | 25 -- arch/x86/include/asm/realmode.h | 36 --- arch/x86/lib/Makefile | 10 - arch/x86/lib/bios.S | 569 ---------------------------------------- arch/x86/lib/bios.h | 3 - arch/x86/lib/bios_pci.S | 447 ------------------------------- arch/x86/lib/bios_setup.c | 179 ------------- arch/x86/lib/realmode.c | 93 ------- arch/x86/lib/realmode_switch.S | 232 ---------------- arch/x86/lib/video.c | 6 - arch/x86/lib/video_bios.c | 196 -------------- arch/x86/lib/zimage.c | 23 -- 14 files changed, 1825 deletions(-) delete mode 100644 arch/x86/include/asm/realmode.h delete mode 100644 arch/x86/lib/bios.S delete mode 100644 arch/x86/lib/bios_pci.S delete mode 100644 arch/x86/lib/bios_setup.c delete mode 100644 arch/x86/lib/realmode.c delete mode 100644 arch/x86/lib/realmode_switch.S delete mode 100644 arch/x86/lib/video_bios.c
diff --git a/README b/README index 2352e38..103036f 100644 --- a/README +++ b/README @@ -3820,11 +3820,6 @@ Low Level (hardware related) configuration options: If defined, the x86 reset vector code is excluded. You will need to do this when U-Boot is running from Coreboot.
-- CONFIG_X86_NO_REAL_MODE - If defined, x86 real mode code is omitted. This assumes a - 32-bit environment where such code is not needed. You will - need to do this when U-Boot is running from Coreboot. -
Freescale QE/FMAN Firmware Support: ----------------------------------- diff --git a/arch/x86/config.mk b/arch/x86/config.mk index 23cacff..8356577 100644 --- a/arch/x86/config.mk +++ b/arch/x86/config.mk @@ -34,7 +34,6 @@ PF_CPPFLAGS_X86 := $(call cc-option, -ffreestanding) \ $(call cc-option, -mpreferred-stack-boundary=2) PLATFORM_CPPFLAGS += $(PF_CPPFLAGS_X86) PLATFORM_CPPFLAGS += -fno-dwarf2-cfi-asm -PLATFORM_CPPFLAGS += -DREALMODE_BASE=0x7c0
PLATFORM_RELFLAGS += -ffunction-sections -fvisibility=hidden
diff --git a/arch/x86/cpu/u-boot.lds b/arch/x86/cpu/u-boot.lds index 0c6f0e3..8f5e444 100644 --- a/arch/x86/cpu/u-boot.lds +++ b/arch/x86/cpu/u-boot.lds @@ -73,29 +73,4 @@ SECTIONS /DISCARD/ : { *(.plt*) } /DISCARD/ : { *(.interp*) } /DISCARD/ : { *(.gnu*) } - - /* 16bit realmode trampoline code */ - .realmode REALMODE_BASE : AT ( LOADADDR(.rel.dyn) + SIZEOF(.rel.dyn) ) { KEEP(*(.realmode)) } - - __realmode_start = LOADADDR(.realmode); - __realmode_size = SIZEOF(.realmode); - - /* 16bit BIOS emulation code (just enough to boot Linux) */ - .bios 0 : AT ( LOADADDR(.realmode) + SIZEOF(.realmode) ) { KEEP(*(.bios)) } - - __bios_start = LOADADDR(.bios); - __bios_size = SIZEOF(.bios); - -#ifndef CONFIG_X86_NO_RESET_VECTOR - - /* - * The following expressions place the 16-bit Real-Mode code and - * Reset Vector at the end of the Flash ROM - */ - . = START_16; - .start16 : AT (CONFIG_SYS_TEXT_BASE + (CONFIG_SYS_MONITOR_LEN - RESET_SEG_SIZE + START_16)) { KEEP(*(.start16)); } - - . = RESET_VEC_LOC; - .resetvec : AT (CONFIG_SYS_TEXT_BASE + (CONFIG_SYS_MONITOR_LEN - RESET_SEG_SIZE + RESET_VEC_LOC)) { KEEP(*(.resetvec)); } -#endif } diff --git a/arch/x86/include/asm/realmode.h b/arch/x86/include/asm/realmode.h deleted file mode 100644 index 0f12a89..0000000 --- a/arch/x86/include/asm/realmode.h +++ /dev/null @@ -1,36 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __ASM_REALMODE_H_ -#define __ASM_REALMODE_H_ -#include <asm/ptrace.h> - -extern ulong __realmode_start; -extern ulong __realmode_size; -extern char realmode_enter; - -int bios_setup(void); -int enter_realmode(u16 seg, u16 off, struct pt_regs *in, struct pt_regs *out); -int enter_realmode_int(u8 lvl, struct pt_regs *in, struct pt_regs *out); - -#endif diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index 0a52cc8..9b24dc5 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -25,16 +25,6 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(ARCH).o
-ifeq ($(CONFIG_X86_NO_REAL_MODE),) -SOBJS-$(CONFIG_SYS_PC_BIOS) += bios.o -SOBJS-$(CONFIG_SYS_PCI_BIOS) += bios_pci.o -COBJS-y += realmode.o -SOBJS-y += realmode_switch.o - -COBJS-$(CONFIG_SYS_PC_BIOS) += bios_setup.o -COBJS-$(CONFIG_VIDEO_VGA) += video_bios.o -endif - COBJS-y += board.o COBJS-y += bootm.o COBJS-y += cmd_boot.o diff --git a/arch/x86/lib/bios.S b/arch/x86/lib/bios.S deleted file mode 100644 index 239aaa9..0000000 --- a/arch/x86/lib/bios.S +++ /dev/null @@ -1,569 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * Based on msbios.c from rolo 1.6: - *---------------------------------------------------------------------- - * (C) Copyright 2000 - * Sysgo Real-Time Solutions GmbH - * Klein-Winternheim, Germany - *---------------------------------------------------------------------- - */ - -#include "bios.h" - -/* - * During it's initialization phase, before switching to protected - * mode, the Linux Kernel makes a few BIOS calls. This won't work - * if the board does not have a BIOS. - * - * This is a very minimalisic BIOS that supplies just enough - * functionality to keep the Linux Kernel happy. It is NOT - * a general purpose replacement for a real BIOS !! - */ - -.section .bios, "ax" -.code16 -.org 0 - /* a call to f000:0 should warmboot */ - jmp realmode_reset - -.globl rm_int00 -.hidden rm_int00 -.type rm_int00, @function -rm_int00: - pushw $0 - jmp any_interrupt16 -.globl rm_int01 -.hidden rm_int01 -.type rm_int01, @function -rm_int01: - pushw $1 - jmp any_interrupt16 -.globl rm_int02 -.hidden rm_int02 -.type rm_int02, @function -rm_int02: - pushw $2 - jmp any_interrupt16 -.globl rm_int03 -.hidden rm_int03 -.type rm_int03, @function -rm_int03: - pushw $3 - jmp any_interrupt16 -.globl rm_int04 -.hidden rm_int04 -.type rm_int04, @function -rm_int04: - pushw $4 - jmp any_interrupt16 -.globl rm_int05 -.hidden rm_int05 -.type rm_int05, @function -rm_int05: - pushw $5 - jmp any_interrupt16 -.globl rm_int06 -.hidden rm_int06 -.type rm_int06, @function -rm_int06: - pushw $6 - jmp any_interrupt16 -.globl rm_int07 -.hidden rm_int07 -.type rm_int07, @function -rm_int07: - pushw $7 - jmp any_interrupt16 -.globl rm_int08 -.hidden rm_int08 -.type rm_int08, @function -rm_int08: - pushw $8 - jmp any_interrupt16 -.globl rm_int09 -.hidden rm_int09 -.type rm_int09, @function -rm_int09: - pushw $9 - jmp any_interrupt16 -.globl rm_int0a -.hidden rm_int0a -.type rm_int0a, @function -rm_int0a: - pushw $10 - jmp any_interrupt16 -.globl rm_int0b -.hidden rm_int0b -.type rm_int0b, @function -rm_int0b: - pushw $11 - jmp any_interrupt16 -.globl rm_int0c -.hidden rm_int0c -.type rm_int0c, @function -rm_int0c: - pushw $12 - jmp any_interrupt16 -.globl rm_int0d -.hidden rm_int0d -.type rm_int0d, @function -rm_int0d: - pushw $13 - jmp any_interrupt16 -.globl rm_int0e -.hidden rm_int0e -.type rm_int0e, @function -rm_int0e: - pushw $14 - jmp any_interrupt16 -.globl rm_int0f -.hidden rm_int0f -.type rm_int0f, @function -rm_int0f: - pushw $15 - jmp any_interrupt16 -.globl rm_int10 -.hidden rm_int10 -.type rm_int10, @function -rm_int10: - pushw $16 - jmp any_interrupt16 -.globl rm_int11 -.hidden rm_int11 -.type rm_int11, @function -rm_int11: - pushw $17 - jmp any_interrupt16 -.globl rm_int12 -.hidden rm_int12 -.type rm_int12, @function -rm_int12: - pushw $18 - jmp any_interrupt16 -.globl rm_int13 -.hidden rm_int13 -.type rm_int13, @function -rm_int13: - pushw $19 - jmp any_interrupt16 -.globl rm_int14 -.hidden rm_int14 -.type rm_int14, @function -rm_int14: - pushw $20 - jmp any_interrupt16 -.globl rm_int15 -.hidden rm_int15 -.type rm_int15, @function -rm_int15: - pushw $21 - jmp any_interrupt16 -.globl rm_int16 -.hidden rm_int16 -.type rm_int16, @function -rm_int16: - pushw $22 - jmp any_interrupt16 -.globl rm_int17 -.hidden rm_int17 -.type rm_int17, @function -rm_int17: - pushw $23 - jmp any_interrupt16 -.globl rm_int18 -.hidden rm_int18 -.type rm_int18, @function -rm_int18: - pushw $24 - jmp any_interrupt16 -.globl rm_int19 -.hidden rm_int19 -.type rm_int19, @function -rm_int19: - pushw $25 - jmp any_interrupt16 -.globl rm_int1a -.hidden rm_int1a -.type rm_int1a, @function -rm_int1a: - pushw $26 - jmp any_interrupt16 -.globl rm_int1b -.hidden rm_int1b -.type rm_int1b, @function -rm_int1b: - pushw $27 - jmp any_interrupt16 -.globl rm_int1c -.hidden rm_int1c -.type rm_int1c, @function -rm_int1c: - pushw $28 - jmp any_interrupt16 -.globl rm_int1d -.hidden rm_int1d -.type rm_int1d, @function -rm_int1d: - pushw $29 - jmp any_interrupt16 -.globl rm_int1e -.hidden rm_int1e -.type rm_int1e, @function -rm_int1e: - pushw $30 - jmp any_interrupt16 -.globl rm_int1f -.hidden rm_int1f -.type rm_int1f, @function -rm_int1f: - pushw $31 - jmp any_interrupt16 -.globl rm_def_int -.hidden rm_def_int -.type rm_def_int, @function -rm_def_int: - iret - - /* - * All interrupt jumptable entries jump to here after pushing the - * interrupt vector number onto the stack. - */ -any_interrupt16: - MAKE_BIOS_STACK - -gs movw OFFS_VECTOR(%bp), %ax - cmpw $0x10, %ax - je Lint_10h - cmpw $0x11, %ax - je Lint_11h - cmpw $0x12, %ax - je Lint_12h - cmpw $0x13, %ax - je Lint_13h - cmpw $0x15, %ax - je Lint_15h - cmpw $0x16, %ax - je Lint_16h - cmpw $0x1a, %ax - je Lint_1ah - movw $0xffff, %ax - jmp Lout -Lint_10h: - /* VGA BIOS services */ - call bios_10h - jmp Lout -Lint_11h: - call bios_11h - jmp Lout -Lint_12h: - call bios_12h - jmp Lout -Lint_13h: - /* BIOS disk services */ - call bios_13h - jmp Lout -Lint_15h: - /* Misc. BIOS services */ - call bios_15h - jmp Lout -Lint_16h: - /* keyboard services */ - call bios_16h - jmp Lout -Lint_1ah: - /* PCI bios */ - call bios_1ah - jmp Lout -Lout: - cmpw $0, %ax - je Lhandeled - - /* - * Insert code for unhandeled INTs here. - * - * ROLO prints a message to the console we could do that but then - * we're in 16bit mode so we'll have to get back into 32bit mode - * to use the console I/O routines (if we do this we should make - * int 0x10 and int 0x16 work as well) - */ -Lhandeled: - RESTORE_CALLERS_STACK - - /* dump vector number */ - addw $2,%sp - - /* return from interrupt */ - iret - -/* - ************************************************************ - * BIOS interrupt 10h -- VGA services - ************************************************************ - */ -bios_10h: -gs movw OFFS_AX(%bp), %ax - shrw $8, %ax - cmpw $0x3, %ax - je Lcur_pos - cmpw $0xf, %ax - je Lvid_state - cmpw $0x12, %ax - je Lvid_cfg - movw $0xffff, %ax - ret -Lcur_pos: - /* Read Cursor Position and Size */ -gs movw $0, OFFS_CX(%bp) -gs movw $0, OFFS_DX(%bp) - xorw %ax, %ax - ret -Lvid_state: - /* Get Video State - 80 columns, 80x25, 16 colors */ -gs movw $(80 << 8|0x03), OFFS_AX(%bp) -gs movw $0, OFFS_BX(%bp) - xorw %ax, %ax - ret -Lvid_cfg: - /* Video Subsystem Configuration (EGA/VGA) - indicate CGA/MDA/HGA */ -gs movw $0x10, OFFS_BX(%bp) - xorw %ax, %ax - ret - -/* - ************************************************************ - * BIOS interrupt 11h -- Equipment determination - ************************************************************ - */ - -bios_11h: -cs movw bios_equipment, %ax -gs movw %ax, OFFS_AX(%bp) - xorw %ax, %ax - ret - -/* - ************************************************************ - * BIOS interrupt 12h -- Get Memory Size - ************************************************************ - */ -bios_12h: -cs movw ram_in_64kb_chunks, %ax - cmpw $0xa, %ax - ja b12_more_than_640k - shlw $6, %ax - jmp b12_return -b12_more_than_640k: - movw $0x280, %ax -b12_return: - /* return number of kilobytes in ax */ -gs movw %ax, OFFS_AX(%bp) - -gs movw OFFS_FLAGS(%bp), %ax - - /* clear carry -- function succeeded */ - andw $0xfffe, %ax -gs movw %ax, OFFS_FLAGS(%bp) - - xorw %ax, %ax - ret - -/* - ************************************************************ - * BIOS interrupt 13h -- Disk services - ************************************************************ - */ -bios_13h: -gs movw OFFS_AX(%bp), %ax - shrw $8, %ax - cmpw $0x15, %ax - je Lfunc_15h - movw $0xffff, %ax - ret -Lfunc_15h: -gs movw OFFS_AX(%bp), %ax - - /* return AH=0->drive not present */ - andw $0x00ff, %ax -gs movw %ax, OFFS_AX(%bp) - xorw %ax, %ax - ret - -/* - *********************************************************** - * BIOS interrupt 15h -- Miscellaneous services - *********************************************************** - */ -bios_15h: -gs movw OFFS_AX(%bp), %ax - shrw $8, %ax - cmpw $0xc0, %ax - je Lfunc_c0h - cmpw $0xe8, %ax - je Lfunc_e8h - cmpw $0x88, %ax - je Lfunc_88h - movw $0xffff, %ax - ret - -Lfunc_c0h: - /* Return System Configuration Parameters (PS2 only) */ -gs movw OFFS_FLAGS(%bp), %ax - - /* return carry -- function not supported */ - orw $1, %ax -gs movw %ax, OFFS_FLAGS(%bp) - xorw %ax, %ax - ret - -Lfunc_e8h: -gs movw OFFS_AX(%bp), %ax - andw $0xff, %ax - cmpw $1, %ax - je Lfunc_e801h -gs movw OFFS_FLAGS(%bp), %ax - - /* return carry -- function not supported */ - orw $1, %ax -gs movw %ax, OFFS_FLAGS(%bp) - xorw %ax, %ax - ret - -Lfunc_e801h: - /* Get memory size for >64M Configurations */ -cs movw ram_in_64kb_chunks, %ax - cmpw $0x100, %ax - ja e801_more_than_16mb - - /* multiply by 64 */ - shlw $6, %ax - - /* 1st meg does not count */ - subw $0x400, %ax - - /* return memory size between 1M and 16M in 1kb chunks in AX and CX */ -gs movw %ax, OFFS_AX(%bp) -gs movw %ax, OFFS_CX(%bp) - - /* set BX and DX to 0*/ -gs movw $0, OFFS_BX(%bp) -gs movw $0, OFFS_DX(%bp) -gs movw OFFS_FLAGS(%bp), %ax - - /* clear carry -- function succeeded */ - andw $0xfffe, %ax -gs movw %ax, OFFS_FLAGS(%bp) - xorw %ax, %ax - ret - -e801_more_than_16mb: - /* subtract 16MB */ - subw $0x100, %ax - - /* return 0x3c00 (16MB-1MB) in AX and CX */ -gs movw $0x3c00, OFFS_AX(%bp) -gs movw $0x3c00, OFFS_CX(%bp) - - /* set BX and DX to number of 64kb chunks above 16MB */ -gs movw %ax, OFFS_BX(%bp) -gs movw %ax, OFFS_DX(%bp) - -gs movw OFFS_FLAGS(%bp), %ax - - /* clear carry -- function succeeded */ - andw $0xfffe, %ax -gs movw %ax, OFFS_FLAGS(%bp) - xorw %ax, %ax - ret - -Lfunc_88h: -cs movw ram_in_64kb_chunks, %ax - cmpw $0x100, %ax - jna b88_not_more_than16 - movw $0x100, %ax -b88_not_more_than16: - shlw $6, %ax - - /* 1st meg does not count */ - subw $0x400, %ax - - /* return number of kilobytes between 16MB and 16MB in ax */ -gs movw %ax, OFFS_AX(%bp) - -gs movw OFFS_FLAGS(%bp), %ax - - /* clear carry -- function succeeded */ - andw $0xfffe, %ax -gs movw %ax, OFFS_FLAGS(%bp) - - xorw %ax, %ax - ret - -/* - ************************************************************ - * BIOS interrupt 16h -- keyboard services - ************************************************************ - */ -bios_16h: -gs movw OFFS_AX(%bp), %ax - shrw $8, %ax - cmpw $0x03, %ax - je Lfunc_03h - movw $0xffff, %ax - ret -Lfunc_03h: - /* do nothing -- function not supported */ - xorw %ax, %ax - ret - -/* - ************************************************************ - * BIOS interrupt 1ah -- PCI bios - ************************************************************ - */ -bios_1ah: -gs movw OFFS_AX(%bp), %ax - cmpb $0xb1, %ah - je Lfunc_b1h - movw $0xffff, %ax - ret -Lfunc_b1h: - call realmode_pci_bios - - /* do nothing -- function not supported */ - xorw %ax, %ax - ret - - -.globl ram_in_64kb_chunks -.hidden ram_in_64kb_chunks -.type ram_in_64kb_chunks, @function -ram_in_64kb_chunks: - .word 0 - -.globl bios_equipment -.hidden bios_equipment -.type bios_equipment, @function -bios_equipment: - .word 0 diff --git a/arch/x86/lib/bios.h b/arch/x86/lib/bios.h index a220983..96509b0 100644 --- a/arch/x86/lib/bios.h +++ b/arch/x86/lib/bios.h @@ -145,9 +145,6 @@ extern void *rm_int1e; extern void *rm_int1f; extern void *rm_def_int;
-extern void *realmode_reset; -extern void *realmode_pci_bios_call_entry; - #define RELOC_16_LONG(seg, off) (*(u32 *)(seg << 4 | (u32)&off)) #define RELOC_16_WORD(seg, off) (*(u16 *)(seg << 4 | (u32)&off)) #define RELOC_16_BYTE(seg, off) (*(u8 *)(seg << 4 | (u32)&off)) diff --git a/arch/x86/lib/bios_pci.S b/arch/x86/lib/bios_pci.S deleted file mode 100644 index 47c478b..0000000 --- a/arch/x86/lib/bios_pci.S +++ /dev/null @@ -1,447 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * x86 realmode assembly implementation of a PCI BIOS - * for platforms that use one PCI hose and configuration - * access type 1. (The common case for low-end PC's) - */ - -#include "bios.h" - -#define PCI_BIOS_DEBUG - -.section .bios, "ax" -.code16 -.globl realmode_pci_bios_call_entry -.hidden realmode_pci_bios_call_entry -.type realmode_pci_bios_call_entry, @function -realmode_pci_bios_call_entry: - MAKE_BIOS_STACK - call realmode_pci_bios - RESTORE_CALLERS_STACK - ret - - -.globl realmode_pci_bios -realmode_pci_bios: -gs movw OFFS_AX(%bp), %ax - cmpb $1, %al - je pci_bios_present - cmpb $2, %al - je pci_bios_find_device - cmpb $3, %al - je pci_bios_find_class - cmpb $6, %al - je pci_bios_generate_special_cycle - cmpb $8, %al - je pci_bios_read_cfg_byte - cmpb $9, %al - je pci_bios_read_cfg_word - cmpb $10, %al - je pci_bios_read_cfg_dword - cmpb $11, %al - je pci_bios_write_cfg_byte - cmpb $12, %al - je pci_bios_write_cfg_word - cmpb $13, %al - je pci_bios_write_cfg_dword - cmpb $14, %al - je pci_bios_get_irq_routing - cmpb $15, %al - je pci_bios_set_irq - jmp unknown_function - -/*****************************************************************************/ - -pci_bios_present: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_present -#endif - movl $0x20494350, %eax -gs movl %eax, OFFS_EDX(%bp) - - /* We support cfg type 1 version 2.10 */ - movb $0x01, %al -gs movb %al, OFFS_AL(%bp) - movw $0x0210, %ax -gs movw %ax, OFFS_BX(%bp) - - /* last bus number */ -cs movb pci_last_bus, %al -gs movb %al, OFFS_CL(%bp) - jmp clear_carry - -/*****************************************************************************/ - -/* device 0-31, function 0-7 */ -pci_bios_find_device: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_find_device -#endif -gs movw OFFS_CX(%bp), %di - shll $16, %edi -gs movw OFFS_DX(%bp), %di - /* edi now holds device in upper 16 bits and vendor in lower 16 bits */ - -gs movw OFFS_SI(%bp), %si - - /* start at bus 0 dev 0 function 0 */ - xorw %bx, %bx -pfd_loop: - /* dword 0 is vendor/device */ - xorw %ax, %ax - call __pci_bios_select_register - movw $0xcfc, %dx - inl %dx, %eax - - /* our device ? */ - cmpl %edi, %eax - je pfd_found_one -pfd_next_dev: - /* check for multi function devices */ - movw %bx, %ax - andw $3, %ax - jnz pfd_function_not_zero - movw $0x000c, %ax - call __pci_bios_select_register - movw $0xcfe, %dx - inb %dx, %al - andb $0x80, %al - jz pfd_not_multi_function -pfd_function_not_zero: - /* next function, overflows in to device number, then bus number */ - incw %bx - jmp pfd_check_bus - -pfd_not_multi_function: - /* remove function bits */ - andw $0xfff8, %bx - - /* next device, overflows in to bus number */ - addw $0x0008, %bx -pfd_check_bus: -cs movb pci_last_bus, %ah - cmpb %ah, %bh - ja pfd_not_found - jmp pfd_loop -pfd_found_one: - decw %si - js pfd_done - jmp pfd_next_dev - -pfd_done: -gs movw %bx, OFFS_BX(%bp) - jmp clear_carry - -pfd_not_found: - /* device not found */ - movb $0x86, %ah - jmp set_carry - -/*****************************************************************************/ - -pci_bios_find_class: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_find_class -#endif -gs movl OFFS_ECX(%bp), %edi - - /* edi now holds class-code in lower 24 bits */ - andl $0x00ffffff, %edi -gs movw OFFS_SI(%bp), %si - - /* start at bus 0 dev 0 function 0 */ - xorw %bx, %bx -pfc_loop: - /* dword 8 is class-code high 24bits */ - movw $8, %ax - call __pci_bios_select_register - movw $0xcfc, %dx - inl %dx, %eax - shrl $8, %eax - andl $0x00ffffff, %eax - - /* our device ? */ - cmpl %edi, %eax - je pfc_found_one -pfc_next_dev: - /* check for multi function devices */ - andw $3, %bx - jnz pfc_function_not_zero - movw $0x000c, %ax - call __pci_bios_select_register - movw $0xcfe, %dx - inb %dx, %al - andb $0x80, %al - jz pfc_not_multi_function -pfc_function_not_zero: - /* next function, overflows in to device number, then bus number */ - incw %bx - jmp pfc_check_bus - -pfc_not_multi_function: - /* remove function bits */ - andw $0xfff8, %bx - - /* next device, overflows in to bus number */ - addw $0x0008, %bx -pfc_check_bus: -cs movb pci_last_bus, %ah - cmpb %ah, %bh - ja pfc_not_found - jmp pfc_loop -pfc_found_one: - decw %si - js pfc_done - jmp pfc_next_dev - -pfc_done: -gs movw %bx, OFFS_BX(%bp) - jmp clear_carry - -pfc_not_found: - /* device not found */ - movb $0x86, %ah - jmp set_carry - -/*****************************************************************************/ - -pci_bios_generate_special_cycle: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_generate_special_cycle -#endif - /* function not supported */ - movb $0x81, %ah - jmp set_carry - -/*****************************************************************************/ - -pci_bios_read_cfg_byte: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_read_cfg_byte -#endif - call pci_bios_select_register -gs movw OFFS_DI(%bp), %dx - andw $3, %dx - addw $0xcfc, %dx - inb %dx, %al -gs movb %al, OFFS_CL(%bp) - jmp clear_carry - -/*****************************************************************************/ - -pci_bios_read_cfg_word: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_read_cfg_word -#endif - call pci_bios_select_register -gs movw OFFS_DI(%bp), %dx - andw $2, %dx - addw $0xcfc, %dx - inw %dx, %ax -gs movw %ax, OFFS_CX(%bp) - jmp clear_carry - - -/*****************************************************************************/ - -pci_bios_read_cfg_dword: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_read_cfg_dword -#endif - call pci_bios_select_register - movw $0xcfc, %dx - inl %dx, %eax -gs movl %eax, OFFS_ECX(%bp) - jmp clear_carry - -/*****************************************************************************/ - -pci_bios_write_cfg_byte: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_write_cfg_byte -#endif - call pci_bios_select_register -gs movw OFFS_DI(%bp), %dx -gs movb OFFS_CL(%bp), %al - andw $3, %dx - addw $0xcfc, %dx - outb %al, %dx - jmp clear_carry - -/*****************************************************************************/ - -pci_bios_write_cfg_word: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_write_cfg_word -#endif - call pci_bios_select_register -gs movw OFFS_DI(%bp), %dx -gs movw OFFS_CX(%bp), %ax - andw $2, %dx - addw $0xcfc, %dx - outw %ax, %dx - jmp clear_carry - -/*****************************************************************************/ - -pci_bios_write_cfg_dword: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_write_cfg_dword -#endif - call pci_bios_select_register -gs movl OFFS_ECX(%bp), %eax - movw $0xcfc, %dx - outl %eax, %dx - jmp clear_carry - -/*****************************************************************************/ - -pci_bios_get_irq_routing: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_get_irq_routing -#endif - /* function not supported */ - movb $0x81, %ah - jmp set_carry - -/*****************************************************************************/ - -pci_bios_set_irq: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_set_irq -#endif - /* function not supported */ - movb $0x81, %ah - jmp set_carry - -/*****************************************************************************/ - -unknown_function: -#ifdef PCI_BIOS_DEBUG -cs incl num_pci_bios_unknown_function -#endif - /* function not supported */ - movb $0x81, %ah - jmp set_carry - -/*****************************************************************************/ - -pci_bios_select_register: -gs movw OFFS_BX(%bp), %bx -gs movw OFFS_DI(%bp), %ax -/* destroys eax, dx */ -__pci_bios_select_register: - /* BX holds device id, AX holds register index */ - pushl %ebx - andl $0xfc, %eax - andl $0xffff, %ebx - shll $8, %ebx - orl %ebx, %eax - orl $0x80000000, %eax - movw $0xcf8, %dx - outl %eax, %dx - popl %ebx - ret - - -clear_carry: -gs movw OFFS_FLAGS(%bp), %ax - - /* clear carry -- function succeeded */ - andw $0xfffe, %ax -gs movw %ax, OFFS_FLAGS(%bp) - xorw %ax, %ax -gs movb %ah, OFFS_AH(%bp) - ret - -set_carry: -gs movb %ah, OFFS_AH(%bp) -gs movw OFFS_FLAGS(%bp), %ax - - /* return carry -- function not supported */ - orw $1, %ax -gs movw %ax, OFFS_FLAGS(%bp) - movw $-1, %ax - ret - -/*****************************************************************************/ - -.globl pci_last_bus -pci_last_bus: - .byte 0 - -#ifdef PCI_BIOS_DEBUG -.globl num_pci_bios_present -num_pci_bios_present: - .long 0 - -.globl num_pci_bios_find_device -num_pci_bios_find_device: - .long 0 - -.globl num_pci_bios_find_class -num_pci_bios_find_class: - .long 0 - -.globl num_pci_bios_generate_special_cycle -num_pci_bios_generate_special_cycle: - .long 0 - -.globl num_pci_bios_read_cfg_byte -num_pci_bios_read_cfg_byte: - .long 0 - -.globl num_pci_bios_read_cfg_word -num_pci_bios_read_cfg_word: - .long 0 - -.globl num_pci_bios_read_cfg_dword -num_pci_bios_read_cfg_dword: - .long 0 - -.globl num_pci_bios_write_cfg_byte -num_pci_bios_write_cfg_byte: - .long 0 - -.globl num_pci_bios_write_cfg_word -num_pci_bios_write_cfg_word: - .long 0 - -.globl num_pci_bios_write_cfg_dword -num_pci_bios_write_cfg_dword: - .long 0 - -.globl num_pci_bios_get_irq_routing -num_pci_bios_get_irq_routing: - .long 0 - -.globl num_pci_bios_set_irq -num_pci_bios_set_irq: - .long 0 - -.globl num_pci_bios_unknown_function -num_pci_bios_unknown_function: - .long 0 -#endif diff --git a/arch/x86/lib/bios_setup.c b/arch/x86/lib/bios_setup.c deleted file mode 100644 index 265f7d6..0000000 --- a/arch/x86/lib/bios_setup.c +++ /dev/null @@ -1,179 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * Partly based on msbios.c from rolo 1.6: - *---------------------------------------------------------------------- - * (C) Copyright 2000 - * Sysgo Real-Time Solutions GmbH - * Klein-Winternheim, Germany - *---------------------------------------------------------------------- - */ - -#include <common.h> -#include <pci.h> -#include <asm/realmode.h> -#include <asm/io.h> -#include "bios.h" - -DECLARE_GLOBAL_DATA_PTR; - -#define NUMVECTS 256 - -static int set_jmp_vector(int entry_point, void *target) -{ - if (entry_point & ~0xffff) - return -1; - - if (((u32)target - 0xf0000) & ~0xffff) - return -1; - - printf("set_jmp_vector: 0xf000:%04x -> %p\n", - entry_point, target); - - /* jmp opcode */ - writeb(0xea, 0xf0000 + entry_point); - - /* offset */ - writew(((u32)target-0xf0000), 0xf0000 + entry_point + 1); - - /* segment */ - writew(0xf000, 0xf0000 + entry_point + 3); - - return 0; -} - -/* Install an interrupt vector */ -static void setvector(int vector, u16 segment, void *handler) -{ - u16 *ptr = (u16 *)(vector * 4); - ptr[0] = ((u32)handler - (segment << 4)) & 0xffff; - ptr[1] = segment; - -#if 0 - printf("setvector: int%02x -> %04x:%04x\n", - vector, ptr[1], ptr[0]); -#endif -} - -int bios_setup(void) -{ - /* The BIOS section is not relocated and still in the ROM. */ - ulong bios_start = (ulong)&__bios_start; - ulong bios_size = (ulong)&__bios_size; - - static int done; - int vector; -#ifdef CONFIG_PCI - struct pci_controller *pri_hose; -#endif - if (done) - return 0; - - done = 1; - - if (bios_size > 65536) { - printf("BIOS too large (%ld bytes, max is 65536)\n", - bios_size); - return -1; - } - - memcpy(BIOS_BASE, (void *)bios_start, bios_size); - - /* clear bda */ - memset(BIOS_DATA, 0, BIOS_DATA_SIZE); - - /* enter some values to the bda */ - writew(0x3f8, BIOS_DATA); /* com1 addr */ - writew(0x2f8, BIOS_DATA+2); /* com2 addr */ - writew(0x3e8, BIOS_DATA+4); /* com3 addr */ - writew(0x2e8, BIOS_DATA+6); /* com4 addr */ - writew(0x278, BIOS_DATA+8); /* lpt1 addr */ - /* - * The kernel wants to read the base memory size - * from 40:13. Put a zero there to avoid an error message - */ - writew(0, BIOS_DATA+0x13); /* base memory size */ - - - /* setup realmode interrupt vectors */ - for (vector = 0; vector < NUMVECTS; vector++) - setvector(vector, BIOS_CS, &rm_def_int); - - setvector(0x00, BIOS_CS, &rm_int00); - setvector(0x01, BIOS_CS, &rm_int01); - setvector(0x02, BIOS_CS, &rm_int02); - setvector(0x03, BIOS_CS, &rm_int03); - setvector(0x04, BIOS_CS, &rm_int04); - setvector(0x05, BIOS_CS, &rm_int05); - setvector(0x06, BIOS_CS, &rm_int06); - setvector(0x07, BIOS_CS, &rm_int07); - setvector(0x08, BIOS_CS, &rm_int08); - setvector(0x09, BIOS_CS, &rm_int09); - setvector(0x0a, BIOS_CS, &rm_int0a); - setvector(0x0b, BIOS_CS, &rm_int0b); - setvector(0x0c, BIOS_CS, &rm_int0c); - setvector(0x0d, BIOS_CS, &rm_int0d); - setvector(0x0e, BIOS_CS, &rm_int0e); - setvector(0x0f, BIOS_CS, &rm_int0f); - setvector(0x10, BIOS_CS, &rm_int10); - setvector(0x11, BIOS_CS, &rm_int11); - setvector(0x12, BIOS_CS, &rm_int12); - setvector(0x13, BIOS_CS, &rm_int13); - setvector(0x14, BIOS_CS, &rm_int14); - setvector(0x15, BIOS_CS, &rm_int15); - setvector(0x16, BIOS_CS, &rm_int16); - setvector(0x17, BIOS_CS, &rm_int17); - setvector(0x18, BIOS_CS, &rm_int18); - setvector(0x19, BIOS_CS, &rm_int19); - setvector(0x1a, BIOS_CS, &rm_int1a); - setvector(0x1b, BIOS_CS, &rm_int1b); - setvector(0x1c, BIOS_CS, &rm_int1c); - setvector(0x1d, BIOS_CS, &rm_int1d); - setvector(0x1e, BIOS_CS, &rm_int1e); - setvector(0x1f, BIOS_CS, &rm_int1f); - - set_jmp_vector(0xfff0, &realmode_reset); - set_jmp_vector(0xfe6e, &realmode_pci_bios_call_entry); - - /* fill in data area */ - RELOC_16_WORD(0xf000, ram_in_64kb_chunks) = gd->ram_size >> 16; - RELOC_16_WORD(0xf000, bios_equipment) = 0; /* FixMe */ - - /* If we assume only one PCI hose, this PCI hose - * will own PCI bus #0, and the last PCI bus of - * that PCI hose will be the last PCI bus in the - * system. - * (This, ofcause break on multi hose systems, - * but our PCI BIOS only support one hose anyway) - */ -#ifdef CONFIG_PCI - pri_hose = pci_bus_to_hose(0); - if (NULL != pri_hose) { - /* fill in last pci bus number for use by the realmode - * PCI BIOS */ - RELOC_16_BYTE(0xf000, pci_last_bus) = pri_hose->last_busno; - } -#endif - return 0; -} diff --git a/arch/x86/lib/realmode.c b/arch/x86/lib/realmode.c deleted file mode 100644 index 75511b2..0000000 --- a/arch/x86/lib/realmode.c +++ /dev/null @@ -1,93 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/ptrace.h> -#include <asm/realmode.h> - -#define REALMODE_MAILBOX ((char *)0xe00) - -int realmode_setup(void) -{ - /* The realmode section is not relocated and still in the ROM. */ - ulong realmode_start = (ulong)&__realmode_start; - ulong realmode_size = (ulong)&__realmode_size; - - /* copy the realmode switch code */ - if (realmode_size > (REALMODE_MAILBOX - (char *)REALMODE_BASE)) { - printf("realmode switch too large (%ld bytes, max is %d)\n", - realmode_size, - (int)(REALMODE_MAILBOX - (char *)REALMODE_BASE)); - return -1; - } - - memcpy((char *)REALMODE_BASE, (void *)realmode_start, realmode_size); - asm("wbinvd\n"); - - return 0; -} - -int enter_realmode(u16 seg, u16 off, struct pt_regs *in, struct pt_regs *out) -{ - - /* setup out thin bios emulation */ - if (bios_setup()) - return -1; - - if (realmode_setup()) - return -1; - - in->eip = off; - in->xcs = seg; - if ((in->esp & 0xffff) < 4) - printf("Warning: entering realmode with sp < 4 will fail\n"); - - memcpy(REALMODE_MAILBOX, in, sizeof(struct pt_regs)); - asm("wbinvd\n"); - - __asm__ volatile ( - "lcall $0x20,%0\n" : : "i" (&realmode_enter)); - - asm("wbinvd\n"); - memcpy(out, REALMODE_MAILBOX, sizeof(struct pt_regs)); - - return out->eax; -} - -/* - * This code is supposed to access a realmode interrupt - * it does currently not work for me - */ -int enter_realmode_int(u8 lvl, struct pt_regs *in, struct pt_regs *out) -{ - /* place two instructions at 0x700 */ - writeb(0xcd, 0x700); /* int $lvl */ - writeb(lvl, 0x701); - writeb(0xcb, 0x702); /* lret */ - asm("wbinvd\n"); - - enter_realmode(0x00, 0x700, in, out); - - return out->eflags & 0x00000001; -} diff --git a/arch/x86/lib/realmode_switch.S b/arch/x86/lib/realmode_switch.S deleted file mode 100644 index c4c4c43..0000000 --- a/arch/x86/lib/realmode_switch.S +++ /dev/null @@ -1,232 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* 32bit -> 16bit -> 32bit mode switch code */ - -/* - * Stack frame at 0xe00 - * e00 ebx; - * e04 ecx; - * e08 edx; - * e0c esi; - * e10 edi; - * e14 ebp; - * e18 eax; - * e1c ds; - * e20 es; - * e24 fs; - * e28 gs; - * e2c orig_eax; - * e30 eip; - * e34 cs; - * e38 eflags; - * e3c esp; - * e40 ss; - */ - -#define a32 .byte 0x67; /* address size prefix 32 */ -#define o32 .byte 0x66; /* operand size prefix 32 */ - -.section .realmode, "ax" -.code16 - - /* 16bit protected mode code here */ -.globl realmode_enter -realmode_enter: -o32 pusha -o32 pushf - cli - sidt saved_idt - sgdt saved_gdt - movl %esp, %eax - movl %eax, saved_protected_mode_esp - - movl $0x10, %eax - movl %eax, %esp - movw $0x28, %ax - movw %ax, %ds - movw %ax, %es - movw %ax, %fs - movw %ax, %gs - - lidt realmode_idt_ptr - /* Go back into real mode by clearing PE to 0 */ - movl %cr0, %eax - andl $0x7ffffffe, %eax - movl %eax, %cr0 - - /* switch to real mode */ - ljmp $0x0,$do_realmode - -do_realmode: - /* realmode code from here */ - movw %cs,%ax - movw %ax,%ds - movw %ax,%es - movw %ax,%fs - movw %ax,%gs - - /* create a temporary stack */ - movw $0xc0, %ax - movw %ax, %ss - movw $0x200, %ax - movw %ax, %sp - - popl %ebx - popl %ecx - popl %edx - popl %esi - popl %edi - popl %ebp - popl %eax - movl %eax, temp_eax - popl %eax - movw %ax, %ds - popl %eax - movw %ax, %es - popl %eax - movw %ax, %fs - popl %eax - movw %ax, %gs - popl %eax /* orig_eax */ - popl %eax -cs movw %ax, temp_ip - popl %eax -cs movw %ax, temp_cs -o32 popf - popl %eax - popw %ss - movl %eax, %esp -cs movl temp_eax, %eax - - /* self-modifying code, better flush the cache */ - wbinvd - - .byte 0x9a /* lcall */ -temp_ip: - .word 0 /* new ip */ -temp_cs: - .word 0 /* new cs */ - -realmode_ret: - /* save eax, esp and ss */ -cs movl %eax, saved_eax - movl %esp, %eax -cs movl %eax, saved_esp - movw %ss, %ax -cs movw %ax, saved_ss - - /* - * restore the stack, note that we set sp to 0x244; - * pt_regs is 0x44 bytes long and we push the structure - * backwards on to the stack, bottom first - */ - movw $0xc0, %ax - movw %ax, %ss - movw $0x244, %ax - movw %ax, %sp - - xorl %eax,%eax -cs movw saved_ss, %ax - pushl %eax -cs movl saved_esp, %eax - pushl %eax -o32 pushf - xorl %eax,%eax -cs movw temp_cs, %ax - pushl %eax -cs movw temp_ip, %ax - pushl %eax - pushl $0 - movw %gs, %ax - pushl %eax - movw %fs, %ax - pushl %eax - movw %es, %ax - pushl %eax - movw %ds, %ax - pushl %eax - movl saved_eax, %eax - pushl %eax - pushl %ebp - pushl %edi - pushl %esi - pushl %edx - pushl %ecx - pushl %ebx - -o32 cs lidt saved_idt -o32 cs lgdt saved_gdt - - /* Go back into protected mode reset PE to 1 */ - movl %cr0, %eax - orl $1,%eax - movl %eax, %cr0 - - /* flush prefetch queue */ - jmp next_line -next_line: - movw $return_ptr, %ax - movw %ax,%bp -o32 cs ljmp *(%bp) - -.code32 -protected_mode: - /* Reload segment registers */ - movl $0x18, %eax - movw %ax, %fs - movw %ax, %ds - movw %ax, %gs - movw %ax, %es - movw %ax, %ss - movl saved_protected_mode_esp, %eax - movl %eax, %esp - popf - popa - ret - -temp_eax: - .long 0 - -saved_ss: - .word 0 -saved_esp: - .long 0 -saved_eax: - .long 0 - -realmode_idt_ptr: - .word 0x400 - .word 0x0, 0x0 - -saved_gdt: - .word 0, 0, 0, 0 -saved_idt: - .word 0, 0, 0, 0 - -saved_protected_mode_esp: - .long 0 - -return_ptr: - .long protected_mode - .word 0x10 diff --git a/arch/x86/lib/video.c b/arch/x86/lib/video.c index 20e2416..81824f3 100644 --- a/arch/x86/lib/video.c +++ b/arch/x86/lib/video.c @@ -26,7 +26,6 @@ #include <stdio_dev.h> #include <i8042.h> #include <asm/ptrace.h> -#include <asm/realmode.h> #include <asm/io.h> #include <asm/pci.h>
@@ -222,10 +221,5 @@ int video_init(void)
int drv_video_init(void) { -#ifndef CONFIG_X86_NO_REAL_MODE - if (video_bios_init()) - return 1; -#endif - return video_init(); } diff --git a/arch/x86/lib/video_bios.c b/arch/x86/lib/video_bios.c deleted file mode 100644 index 1e06759..0000000 --- a/arch/x86/lib/video_bios.c +++ /dev/null @@ -1,196 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <pci.h> -#include <malloc.h> -#include <asm/ptrace.h> -#include <asm/realmode.h> -#include <asm/io.h> -#include <asm/pci.h> -#include "bios.h" - -#undef PCI_BIOS_DEBUG -#undef VGA_BIOS_DEBUG - -#ifdef VGA_BIOS_DEBUG -#define PRINTF(fmt, args...) printf(fmt, ##args) -#else -#define PRINTF(fmt, args...) -#endif - -#define PCI_CLASS_VIDEO 3 -#define PCI_CLASS_VIDEO_STD 0 -#define PCI_CLASS_VIDEO_PROG_IF_VGA 0 - -DEFINE_PCI_DEVICE_TABLE(supported) = { - {PCI_VIDEO_VENDOR_ID, PCI_VIDEO_DEVICE_ID}, - {} -}; - -static u32 probe_pci_video(void) -{ - struct pci_controller *hose; - pci_dev_t devbusfn = pci_find_devices(supported, 0); - - if ((devbusfn != -1)) { - u32 old; - u32 addr; - - /* PCI video device detected */ - printf("Found PCI VGA device at %02x.%02x.%x\n", - PCI_BUS(devbusfn), - PCI_DEV(devbusfn), - PCI_FUNC(devbusfn)); - - /* Enable I/O decoding as well, PCI viudeo boards - * support I/O accesses, but they provide no - * bar register for this since the ports are fixed. - */ - pci_write_config_word(devbusfn, - PCI_COMMAND, - PCI_COMMAND_MEMORY | - PCI_COMMAND_IO | - PCI_COMMAND_MASTER); - - /* Test the ROM decoder, do the device support a rom? */ - pci_read_config_dword(devbusfn, PCI_ROM_ADDRESS, &old); - pci_write_config_dword(devbusfn, PCI_ROM_ADDRESS, - (u32)PCI_ROM_ADDRESS_MASK); - pci_read_config_dword(devbusfn, PCI_ROM_ADDRESS, &addr); - pci_write_config_dword(devbusfn, PCI_ROM_ADDRESS, old); - - if (!addr) { - printf("PCI VGA have no ROM?\n"); - return 0; - } - - /* device have a rom */ - if (pci_shadow_rom(devbusfn, (void *)0xc0000)) { - printf("Shadowing of PCI VGA BIOS failed\n"); - return 0; - } - - /* Now enable lagacy VGA port access */ - hose = pci_bus_to_hose(PCI_BUS(devbusfn)); - if (pci_enable_legacy_video_ports(hose)) { - printf("PCI VGA enable failed\n"); - return 0; - } - - - /* return the pci device info, that we'll need later */ - return PCI_BUS(devbusfn) << 8 | - PCI_DEV(devbusfn) << 3 | (PCI_FUNC(devbusfn) & 7); - } - - return 0; -} - -static int probe_isa_video(void) -{ - u32 ptr; - char *buf; - - ptr = isa_map_rom(0xc0000, 0x8000); - - if (!ptr) - return -1; - - buf = malloc(0x8000); - if (!buf) { - isa_unmap_rom(ptr); - return -1; - } - - if (readw(ptr) != 0xaa55) { - free(buf); - isa_unmap_rom(ptr); - return -1; - } - - /* shadow the rom */ - memcpy(buf, (void *)ptr, 0x8000); - isa_unmap_rom(ptr); - memcpy((void *)0xc0000, buf, 0x8000); - - free(buf); - - return 0; -} - -int video_bios_init(void) -{ - struct pt_regs regs; - int size; - int i; - u8 sum; - - /* clear the video bios area in case we warmbooted */ - memset((void *)0xc0000, 0, 0x8000); - memset(®s, 0, sizeof(struct pt_regs)); - - if (probe_isa_video()) - /* No ISA board found, try the PCI bus */ - regs.eax = probe_pci_video(); - - /* Did we succeed in mapping any video bios */ - if (readw(0xc0000) == 0xaa55) { - PRINTF("Found video bios signature\n"); - size = readb(0xc0002) * 512; - PRINTF("size %d\n", size); - sum = 0; - - for (i = 0; i < size; i++) - sum += readb(0xc0000 + i); - - PRINTF("Checksum is %sOK\n", sum ? "NOT " : ""); - - if (sum) - return 1; - - /* - * Some video bioses (ATI Mach64) seem to think that - * the original int 10 handler is always at - * 0xf000:0xf065 , place an iret instruction there - */ - writeb(0xcf, 0xff065); - - regs.esp = 0x8000; - regs.xss = 0x2000; - enter_realmode(0xc000, 3, ®s, ®s); - - PRINTF("INT 0x10 vector after: %04x:%04x\n", - readw(0x42), readw(0x40)); - PRINTF("BIOS returned %scarry\n", - regs.eflags & 0x00000001 ? "" : "NOT "); -#ifdef PCI_BIOS_DEBUG - print_bios_bios_stat(); -#endif - return regs.eflags & 0x00000001; - - } - - return 1; - -} diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index 46af391..4e9e1f7 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -33,7 +33,6 @@ #include <asm/io.h> #include <asm/ptrace.h> #include <asm/zimage.h> -#include <asm/realmode.h> #include <asm/byteorder.h> #include <asm/bootparam.h> #ifdef CONFIG_SYS_COREBOOT @@ -175,16 +174,9 @@ struct boot_params *load_zimage(char *image, unsigned long kernel_size, else *load_address = (void *)ZIMAGE_LOAD_ADDR;
-#if (defined CONFIG_ZBOOT_32 || defined CONFIG_X86_NO_REAL_MODE) printf("Building boot_params at 0x%8.8lx\n", (ulong)setup_base); memset(setup_base, 0, sizeof(*setup_base)); setup_base->hdr = params->hdr; -#else - /* load setup */ - printf("Moving Real-Mode Code to 0x%8.8lx (%d bytes)\n", - (ulong)setup_base, setup_size); - memmove(setup_base, image, setup_size); -#endif
if (bootproto >= 0x0204) kernel_size = hdr->syssize * 16; @@ -241,10 +233,8 @@ int setup_zimage(struct boot_params *setup_base, char *cmd_line, int auto_boot, struct setup_header *hdr = &setup_base->hdr; int bootproto = get_boot_protocol(hdr);
-#if (defined CONFIG_ZBOOT_32 || defined CONFIG_X86_NO_REAL_MODE) setup_base->e820_entries = install_e820_map( ARRAY_SIZE(setup_base->e820_map), setup_base->e820_map); -#endif
if (bootproto == 0x0100) { setup_base->screen_info.cl_magic = COMMAND_LINE_MAGIC; @@ -300,7 +290,6 @@ void boot_zimage(void *setup_base, void *load_address) #ifdef CONFIG_SYS_COREBOOT timestamp_add_now(TS_U_BOOT_START_KERNEL); #endif -#if defined CONFIG_ZBOOT_32 /* * Set %ebx, %ebp, and %edi to 0, %esi to point to the boot_params * structure, and then jump to the kernel. We assume that %cs is @@ -317,18 +306,6 @@ void boot_zimage(void *setup_base, void *load_address) "b"(0), "D"(0) : "%ebp" ); -#else - struct pt_regs regs; - - memset(®s, 0, sizeof(struct pt_regs)); - regs.xds = (u32)setup_base >> 4; - regs.xes = regs.xds; - regs.xss = regs.xds; - regs.esp = 0x9000; - regs.eflags = 0; - enter_realmode(((u32)setup_base + SETUP_START_OFFSET) >> 4, 0, - ®s, ®s); -#endif }
void setup_pcat_compatibility(void)
Hi Simon,
. = START_16;
. = RESET_VEC_LOC;
-#endif
Can we please keep the reset vector and real-to-protected mode code. I know coreboot does not need it (and hence it is dead code) but it keeps alive the thought that U-Boot can actually boot an x86 from power-up
Apart from that, I'll be glad to see the back of this legacy crap :)
Regards,
Graeme
This code is not needed now, since we boot U-Boot from Coreboot on x86.
Signed-off-by: Simon Glass sjg@chromium.org --- Makefile | 4 -- README | 4 -- arch/x86/cpu/Makefile | 1 - arch/x86/cpu/resetvec.S | 38 ------------ arch/x86/cpu/start16.S | 146 --------------------------------------------- include/configs/coreboot.h | 1 - 6 files changed, 194 deletions(-) delete mode 100644 arch/x86/cpu/resetvec.S delete mode 100644 arch/x86/cpu/start16.S
diff --git a/Makefile b/Makefile index 51bd918..1924d4b 100644 --- a/Makefile +++ b/Makefile @@ -230,10 +230,6 @@ endif # U-Boot objects....order is important (i.e. start must be first)
OBJS = $(CPUDIR)/start.o -ifeq ($(CPU),x86) -RESET_OBJS-$(CONFIG_X86_NO_RESET_VECTOR) += $(CPUDIR)/start16.o -RESET_OBJS-$(CONFIG_X86_NO_RESET_VECTOR) += $(CPUDIR)/resetvec.o -endif ifeq ($(CPU),ppc4xx) OBJS += $(CPUDIR)/resetvec.o endif diff --git a/README b/README index 103036f..061898c 100644 --- a/README +++ b/README @@ -3816,10 +3816,6 @@ Low Level (hardware related) configuration options: be used if available. These functions may be faster under some conditions but may increase the binary size.
-- CONFIG_X86_NO_RESET_VECTOR - If defined, the x86 reset vector code is excluded. You will need - to do this when U-Boot is running from Coreboot. -
Freescale QE/FMAN Firmware Support: ----------------------------------- diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 57324b6..f27064f 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -29,7 +29,6 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).o
START-y = start.o -RESET_OBJS-$(CONFIG_X86_NO_RESET_VECTOR) += resetvec.o start16.o COBJS = interrupts.o cpu.o timer.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/arch/x86/cpu/resetvec.S b/arch/x86/cpu/resetvec.S deleted file mode 100644 index 44aee5f..0000000 --- a/arch/x86/cpu/resetvec.S +++ /dev/null @@ -1,38 +0,0 @@ -/* - * U-boot - x86 Startup Code - * - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* Reset vector, jumps to start16.S */ - -.extern start16 - -.section .resetvec, "ax" -.code16 -reset_vector: - cli - cld - jmp start16 - - .org 0xf - nop diff --git a/arch/x86/cpu/start16.S b/arch/x86/cpu/start16.S deleted file mode 100644 index 603bf1d..0000000 --- a/arch/x86/cpu/start16.S +++ /dev/null @@ -1,146 +0,0 @@ -/* - * U-boot - x86 Startup Code - * - * (C) Copyright 2008-2011 - * Graeme Russ, graeme.russ@gmail.com - * - * (C) Copyright 2002,2003 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <asm/global_data.h> -#include <asm/processor-flags.h> - -#define BOOT_SEG 0xffff0000 /* linear segment of boot code */ -#define a32 .byte 0x67; -#define o32 .byte 0x66; - -.section .start16, "ax" -.code16 -.globl start16 -start16: - /* Set the Cold Boot / Hard Reset flag */ - movl $GD_FLG_COLD_BOOT, %ebx - - /* - * First we let the BSP do some early initialization - * this code have to map the flash to its final position - */ - jmp board_init16 -.globl board_init16_ret -board_init16_ret: - - /* Turn of cache (this might require a 486-class CPU) */ - movl %cr0, %eax - orl $(X86_CR0_NW | X86_CR0_CD), %eax - movl %eax, %cr0 - wbinvd - - /* load the temporary Global Descriptor Table */ -o32 cs lidt idt_ptr -o32 cs lgdt gdt_ptr - - /* Now, we enter protected mode */ - movl %cr0, %eax - orl $X86_CR0_PE, %eax - movl %eax, %cr0 - - /* Flush the prefetch queue */ - jmp ff -ff: - /* Finally jump to the 32bit initialization code */ - movw $code32start, %ax - movw %ax, %bp -o32 cs ljmp *(%bp) - - /* 48-bit far pointer */ -code32start: - .long _start /* offset */ - .word 0x10 /* segment */ - -idt_ptr: - .word 0 /* limit */ - .long 0 /* base */ - -/* - * The following Global Descriptor Table is just enough to get us into - * 'Flat Protected Mode' - It will be discarded as soon as the final - * GDT is setup in a safe location in RAM - */ -gdt_ptr: - .word 0x20 /* limit (32 bytes = 4 GDT entries) */ - .long BOOT_SEG + gdt /* base */ - -/* Some CPUs are picky about GDT alignment... */ -.align 16 -gdt: - /* - * The GDT table ... - * - * Selector Type - * 0x00 NULL - * 0x08 Unused - * 0x10 32bit code - * 0x18 32bit data/stack - */ - /* The NULL Desciptor - Mandatory */ - .word 0x0000 /* limit_low */ - .word 0x0000 /* base_low */ - .byte 0x00 /* base_middle */ - .byte 0x00 /* access */ - .byte 0x00 /* flags + limit_high */ - .byte 0x00 /* base_high */ - - /* Unused Desciptor - (matches Linux) */ - .word 0x0000 /* limit_low */ - .word 0x0000 /* base_low */ - .byte 0x00 /* base_middle */ - .byte 0x00 /* access */ - .byte 0x00 /* flags + limit_high */ - .byte 0x00 /* base_high */ - - /* - * The Code Segment Descriptor: - * - Base = 0x00000000 - * - Size = 4GB - * - Access = Present, Ring 0, Exec (Code), Readable - * - Flags = 4kB Granularity, 32-bit - */ - .word 0xffff /* limit_low */ - .word 0x0000 /* base_low */ - .byte 0x00 /* base_middle */ - .byte 0x9b /* access */ - .byte 0xcf /* flags + limit_high */ - .byte 0x00 /* base_high */ - - /* - * The Data Segment Descriptor: - * - Base = 0x00000000 - * - Size = 4GB - * - Access = Present, Ring 0, Non-Exec (Data), Writable - * - Flags = 4kB Granularity, 32-bit - */ - .word 0xffff /* limit_low */ - .word 0x0000 /* base_low */ - .byte 0x00 /* base_middle */ - .byte 0x93 /* access */ - .byte 0xcf /* flags + limit_high */ - .byte 0x00 /* base_high */ diff --git a/include/configs/coreboot.h b/include/configs/coreboot.h index d8aabd4..c7f36ff 100644 --- a/include/configs/coreboot.h +++ b/include/configs/coreboot.h @@ -37,7 +37,6 @@ #define CONFIG_SYS_COREBOOT #define CONFIG_SHOW_BOOT_PROGRESS #define CONFIG_LAST_STAGE_INIT -#define CONFIG_X86_NO_RESET_VECTOR #define CONFIG_SYS_VSNPRINTF #define CONFIG_INTEL_CORE_ARCH /* Sandy bridge and ivy bridge chipsets. */ #define CONFIG_ZBOOT_32
Hi Simon,
As mentioned in reply to the previous patch, I would like to see this code stay
Hmm, odd - the logic here seems to be inverted - the reset vector code appears to be included if CONFIG_X86_NO_RESET_VECTOR is defined...
Oh, and as discussed before, this can actually be moved out of the main Makefile and into arch/x86/cpu/Makefile. Hmm, that's odd, it looks like it already is:
START-y = start.o RESET_OBJS-$(CONFIG_X86_NO_RESET_VECTOR) += resetvec.o start16.o COBJS = interrupts.o cpu.o timer.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) START := $(addprefix $(obj),$(START-y) $(RESET_OBJS-))
But again, the logic seems to be inverted...
Maybe we could just change this to CONFIG_X86_RESET_VECTOR and make exclusion of the 16-bit reset vector and protected mode switch the default case
Regards,
Graeme
Hi Graeme,
On Sun, Feb 10, 2013 at 2:20 PM, Graeme Russ graeme.russ@gmail.com wrote:
Hi Simon,
Do you mean I should just drop these last two patches? Sorry, I'm not quite sure what to do here.
Actually see where RESET_OBJS is used below - it is inverted there.
Yes it is in the library, and it seems like the link script should take care of putting things in the right place. However I'm not able to test a change like this. Still, perhaps this problem doesn't apply with the other boards removed.
See above.
OK I can create a patch for that.
Regards,
Graeme
Graeme Russ
