[U-Boot] [PATCH 1/3] spi: xilinx_spi: Fix to configure CPOL, CPHA mask
priv->mode is initialized when .set_speed triggers with mode value, so checking mode for configuring CPOL, CPHA using priv->mode is invalid hence use mode from .set_speed argument, and at the end priv->mode will initialized with mode.
This patch also replaces formatting string to use speed instead of mode in .set_speed ops.
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/spi/xilinx_spi.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index 6c21acd..8ccc578 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -247,7 +247,7 @@ static int xilinx_spi_set_speed(struct udevice *bus, uint speed)
priv->freq = speed;
- debug("xilinx_spi_set_speed: regs=%p, mode=%d\n", priv->regs, + debug("xilinx_spi_set_speed: regs=%p, speed=%d\n", priv->regs, priv->freq);
return 0; @@ -260,13 +260,13 @@ static int xilinx_spi_set_mode(struct udevice *bus, uint mode) uint32_t spicr;
spicr = readl(®s->spicr); - if (priv->mode & SPI_LSB_FIRST) + if (mode & SPI_LSB_FIRST) spicr |= SPICR_LSB_FIRST; - if (priv->mode & SPI_CPHA) + if (mode & SPI_CPHA) spicr |= SPICR_CPHA; - if (priv->mode & SPI_CPOL) + if (mode & SPI_CPOL) spicr |= SPICR_CPOL; - if (priv->mode & SPI_LOOP) + if (mode & SPI_LOOP) spicr |= SPICR_LOOP;
writel(spicr, ®s->spicr);
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/spi/zynq_spi.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/zynq_spi.c b/drivers/spi/zynq_spi.c index d6057e6..65a9633 100644 --- a/drivers/spi/zynq_spi.c +++ b/drivers/spi/zynq_spi.c @@ -278,7 +278,8 @@ static int zynq_spi_set_speed(struct udevice *bus, uint speed) writel(confr, ®s->cr); priv->freq = speed;
- debug("zynq_spi_set_speed: regs=%p, mode=%d\n", priv->regs, priv->freq); + debug("zynq_spi_set_speed: regs=%p, speed=%d\n", + priv->regs, priv->freq);
return 0; } @@ -293,9 +294,9 @@ static int zynq_spi_set_mode(struct udevice *bus, uint mode) confr = readl(®s->cr); confr &= ~(ZYNQ_SPI_CR_CPHA_MASK | ZYNQ_SPI_CR_CPOL_MASK);
- if (priv->mode & SPI_CPHA) + if (mode & SPI_CPHA) confr |= ZYNQ_SPI_CR_CPHA_MASK; - if (priv->mode & SPI_CPOL) + if (mode & SPI_CPOL) confr |= ZYNQ_SPI_CR_CPOL_MASK;
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/spi/zynq_qspi.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/zynq_qspi.c b/drivers/spi/zynq_qspi.c index 0ce6127..8aa61d7 100644 --- a/drivers/spi/zynq_qspi.c +++ b/drivers/spi/zynq_qspi.c @@ -569,7 +569,8 @@ static int zynq_qspi_set_speed(struct udevice *bus, uint speed) writel(confr, ®s->cr); priv->freq = speed;
return 0; } @@ -584,9 +585,9 @@ static int zynq_qspi_set_mode(struct udevice *bus, uint mode) confr = readl(®s->cr); confr &= ~(ZYNQ_QSPI_CR_CPHA_MASK | ZYNQ_QSPI_CR_CPOL_MASK);
- if (priv->mode & SPI_CPHA) + if (mode & SPI_CPHA) confr |= ZYNQ_QSPI_CR_CPHA_MASK; - if (priv->mode & SPI_CPOL) + if (mode & SPI_CPOL) confr |= ZYNQ_QSPI_CR_CPOL_MASK;
Jagan Teki
