[U-Boot] [PATCH] ppc, mgcoge: add DIP switch detection
This reads the DIP switch on mgcoge. The DIP switch is connected to the BFTICU (0x40000089) FPGA. If the DIP switch is set the environment variable 'actual_bank' is set to 0 and starts the SW in bank0.
Signed-off-by: Andreas Huber andreas.huber@keymile.com Signed-off-by: Holger Brunck holger.brunck@keymile.com --- board/keymile/mgcoge/mgcoge.c | 18 ++++++++++++++++++ include/configs/mgcoge.h | 5 +++++ 2 files changed, 23 insertions(+), 0 deletions(-)
diff --git a/board/keymile/mgcoge/mgcoge.c b/board/keymile/mgcoge/mgcoge.c index 5c9496c..5dcdf37 100644 --- a/board/keymile/mgcoge/mgcoge.c +++ b/board/keymile/mgcoge/mgcoge.c @@ -293,6 +293,24 @@ int checkboard(void) return 0; }
+#define DIPSWITCH_OFFSET 0x89 +#define DIPSWITCH_MASK 0x0f + +int last_stage_init(void) +{ + u8 dip_switch; + /* Dip switch */ + dip_switch = readb(CONFIG_SYS_BFTICU_BASE + DIPSWITCH_OFFSET); + dip_switch &= DIPSWITCH_MASK; + /* dip switch 'full reset' or 'db erase' */ + if (dip_switch & 0x1 || dip_switch & 0x2) { + /* start bootloader */ + puts("DIP: Enabled\n"); + setenv("actual_bank", "0"); + } + return 0; +} + /* * Early board initalization. */ diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h index 6dec0ee..f1bd32a 100644 --- a/include/configs/mgcoge.h +++ b/include/configs/mgcoge.h @@ -348,4 +348,9 @@ #define OF_TBCLK (bd->bi_busfreq / 4) #define OF_STDOUT_PATH "/soc/cpm/serial@11a90"
+/* enable last_stage_init */ +#define CONFIG_LAST_STAGE_INIT 1 +/* bfticu address */ +#define CONFIG_SYS_BFTICU_BASE 0x40000000 + #endif /* __CONFIG_H */
Dear Holger Brunck,
In message 1295951175-3635-1-git-send-email-holger.brunck@keymile.com you wrote:
Applied, thanks.
Dear Holger Brunck,
This patch breaks compiling of the mgcoge2ne board:
Configuring for mgcoge2ne board... mgcoge.c: In function 'last_stage_init': mgcoge.c:305: error: 'CONFIG_SYS_BFTICU_BASE' undeclared (first use in this function) mgcoge.c:305: error: (Each undeclared identifier is reported only once mgcoge.c:305: error: for each function it appears in.)
Please fix.
On 05/04/2011 10:01 PM, Wolfgang Denk wrote:
Dear Holger Brunck,
Argh sorry.
Please fix.
In the already posted patch serie http://lists.denx.de/pipermail/u-boot/2011-May/091976.html the problem is fixed, should I repost the patch powerpc/km82xx: rework DIP switch detection as a standalone patch and rebase the serie or can you take the whole serie?
Best regards Holger Brunck
Dear Holger Brunck,
As the merge window is closed, this new patch series will not go into this upcoming release any more.
Can you please extract a patch that just fixes the build problem for now? Thanks.
On 05/05/2011 09:29 AM, Wolfgang Denk wrote:
Dear Holger Brunck,
Sorry but why this? The initial patch serie was postet on april 8th: http://lists.denx.de/pipermail/u-boot/2011-April/090012.html And as far as I know the merge window was closed on april 10th.
The resulting patch series are a rework due to the input of the ML.
Dear Holger Brunck,
The reworked series goes in, but there appear to be a number of completely new patches; these go into next.
On 05/05/2011 08:16 PM, Wolfgang Denk wrote:
Dear Holger Brunck,
yes if there is something completely new it goes into next. But both reworked series posted from myside have no new patches and no new features inside the patches. Ok two patches are squashed to one, as a result of an input from your side and I thought this was ok. If you still see something let me know and I remove it from the serie.
So back to my original question should I post a bugfix patch for the compile issue for mgcoge2ne and rebase the serie "[PATCH v2 0/7] km82xx mainlining" above this patch or is it ok if it get fixed with this serie?
Dear Holger Brunck,
OK.
If it's not too much of effort, I'd appreciate a separate bug fix, which I can pull without longer review. Thanks!
Ok done. If the patch was ok and pulled, I send an rebased serie for [PATCH 0/7] km82xx mainlining
Holger Brunck
