[U-Boot] [PATCH] ARM DaVinci: Changing function names for EMAC driver
DM644x is just one of a series of DaVinci chips that use the EMAC driver. By replacing all the function names that start with dm644x_* to davinci_* we make these function more portable. I have tested this change on my EVM. DM6467 is another DaVinci SOC which uses the EMAC driver and i will be sending patches that add DaVinci DM6467 support to the list soon.
Signed-off-by: Sandeep Paulraj s-paulraj@ti.com --- cpu/arm926ejs/davinci/dp83848.c | 24 ++++---- cpu/arm926ejs/davinci/ether.c | 114 +++++++++++++++++++------------------- cpu/arm926ejs/davinci/lxt972.c | 20 ++++---- lib_arm/board.c | 4 +- net/eth.c | 2 +- 5 files changed, 82 insertions(+), 82 deletions(-)
diff --git a/cpu/arm926ejs/davinci/dp83848.c b/cpu/arm926ejs/davinci/dp83848.c index 2aa9ef1..59f039b 100644 --- a/cpu/arm926ejs/davinci/dp83848.c +++ b/cpu/arm926ejs/davinci/dp83848.c @@ -38,9 +38,9 @@ int dp83848_is_phy_connected(int phy_addr) { u_int16_t id1, id2;
- if (!dm644x_eth_phy_read(phy_addr, DP83848_PHYID1_REG, &id1)) + if (!davinci_eth_phy_read(phy_addr, DP83848_PHYID1_REG, &id1)) return(0); - if (!dm644x_eth_phy_read(phy_addr, DP83848_PHYID2_REG, &id2)) + if (!davinci_eth_phy_read(phy_addr, DP83848_PHYID2_REG, &id2)) return(0);
if ((id1 == DP83848_PHYID1_OUI) && (id2 == DP83848_PHYID2_OUI)) @@ -54,13 +54,13 @@ int dp83848_get_link_speed(int phy_addr) u_int16_t tmp; volatile emac_regs* emac = (emac_regs *)EMAC_BASE_ADDR;
- if (!dm644x_eth_phy_read(phy_addr, DP83848_STAT_REG, &tmp)) + if (!davinci_eth_phy_read(phy_addr, DP83848_STAT_REG, &tmp)) return(0);
if (!(tmp & DP83848_LINK_STATUS)) /* link up? */ return(0);
- if (!dm644x_eth_phy_read(phy_addr, DP83848_PHY_STAT_REG, &tmp)) + if (!davinci_eth_phy_read(phy_addr, DP83848_PHY_STAT_REG, &tmp)) return(0);
/* Speed doesn't matter, there is no setting for it in EMAC... */ @@ -101,7 +101,7 @@ int dp83848_init_phy(int phy_addr) }
/* Disable PHY Interrupts */ - dm644x_eth_phy_write(phy_addr, DP83848_PHY_INTR_CTRL_REG, 0); + davinci_eth_phy_write(phy_addr, DP83848_PHY_INTR_CTRL_REG, 0);
return(ret); } @@ -112,13 +112,13 @@ int dp83848_auto_negotiate(int phy_addr) u_int16_t tmp;
- if (!dm644x_eth_phy_read(phy_addr, DP83848_CTL_REG, &tmp)) + if (!davinci_eth_phy_read(phy_addr, DP83848_CTL_REG, &tmp)) return(0);
/* Restart Auto_negotiation */ tmp &= ~DP83848_AUTONEG; /* remove autonegotiation enable */ tmp |= DP83848_ISOLATE; /* Electrically isolate PHY */ - dm644x_eth_phy_write(phy_addr, DP83848_CTL_REG, tmp); + davinci_eth_phy_write(phy_addr, DP83848_CTL_REG, tmp);
/* Set the Auto_negotiation Advertisement Register * MII advertising for Next page, 100BaseTxFD and HD, @@ -126,23 +126,23 @@ int dp83848_auto_negotiate(int phy_addr) */ tmp = DP83848_NP | DP83848_TX_FDX | DP83848_TX_HDX | DP83848_10_FDX | DP83848_10_HDX | DP83848_AN_IEEE_802_3; - dm644x_eth_phy_write(phy_addr, DP83848_ANA_REG, tmp); + davinci_eth_phy_write(phy_addr, DP83848_ANA_REG, tmp);
/* Read Control Register */ - if (!dm644x_eth_phy_read(phy_addr, DP83848_CTL_REG, &tmp)) + if (!davinci_eth_phy_read(phy_addr, DP83848_CTL_REG, &tmp)) return(0);
tmp |= DP83848_SPEED_SELECT | DP83848_AUTONEG | DP83848_DUPLEX_MODE; - dm644x_eth_phy_write(phy_addr, DP83848_CTL_REG, tmp); + davinci_eth_phy_write(phy_addr, DP83848_CTL_REG, tmp);
/* Restart Auto_negotiation */ tmp |= DP83848_RESTART_AUTONEG; - dm644x_eth_phy_write(phy_addr, DP83848_CTL_REG, tmp); + davinci_eth_phy_write(phy_addr, DP83848_CTL_REG, tmp);
/*check AutoNegotiate complete */ udelay(10000); - if (!dm644x_eth_phy_read(phy_addr, DP83848_STAT_REG, &tmp)) + if (!davinci_eth_phy_read(phy_addr, DP83848_STAT_REG, &tmp)) return(0);
if (!(tmp & DP83848_AUTONEG_COMP)) diff --git a/cpu/arm926ejs/davinci/ether.c b/cpu/arm926ejs/davinci/ether.c index 5ae035b..f6f81df 100644 --- a/cpu/arm926ejs/davinci/ether.c +++ b/cpu/arm926ejs/davinci/ether.c @@ -50,12 +50,12 @@ unsigned int emac_dbg = 0; #define debug_emac(fmt,args...) if (emac_dbg) printf(fmt,##args)
/* Internal static functions */ -static int dm644x_eth_hw_init (void); -static int dm644x_eth_open (void); -static int dm644x_eth_close (void); -static int dm644x_eth_send_packet (volatile void *packet, int length); -static int dm644x_eth_rcv_packet (void); -static void dm644x_eth_mdio_enable(void); +static int davinci_eth_hw_init (void); +static int davinci_eth_open (void); +static int davinci_eth_close (void); +static int davinci_eth_send_packet (volatile void *packet, int length); +static int davinci_eth_rcv_packet (void); +static void davinci_eth_mdio_enable(void);
static int gen_init_phy(int phy_addr); static int gen_is_phy_connected(int phy_addr); @@ -65,48 +65,48 @@ static int gen_auto_negotiate(int phy_addr); /* Wrappers exported to the U-Boot proper */ int eth_hw_init(void) { - return(dm644x_eth_hw_init()); + return(davinci_eth_hw_init()); }
int eth_init(bd_t * bd) { - return(dm644x_eth_open()); + return(davinci_eth_open()); }
void eth_halt(void) { - dm644x_eth_close(); + davinci_eth_close(); }
int eth_send(volatile void *packet, int length) { - return(dm644x_eth_send_packet(packet, length)); + return(davinci_eth_send_packet(packet, length)); }
int eth_rx(void) { - return(dm644x_eth_rcv_packet()); + return(davinci_eth_rcv_packet()); }
void eth_mdio_enable(void) { - dm644x_eth_mdio_enable(); + davinci_eth_mdio_enable(); } /* End of wrappers */
-static u_int8_t dm644x_eth_mac_addr[] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff }; +static u_int8_t davinci_eth_mac_addr[] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff };
/* * This function must be called before emac_open() if you want to override * the default mac address. */ -void dm644x_eth_set_mac_addr(const u_int8_t *addr) +void davinci_eth_set_mac_addr(const u_int8_t *addr) { int i;
- for (i = 0; i < sizeof (dm644x_eth_mac_addr); i++) { - dm644x_eth_mac_addr[i] = addr[i]; + for (i = 0; i < sizeof (davinci_eth_mac_addr); i++) { + davinci_eth_mac_addr[i] = addr[i]; } }
@@ -130,7 +130,7 @@ static volatile u_int8_t active_phy_addr = 0xff;
phy_t phy;
-static void dm644x_eth_mdio_enable(void) +static void davinci_eth_mdio_enable(void) { u_int32_t clkdiv;
@@ -149,7 +149,7 @@ static void dm644x_eth_mdio_enable(void) * If no active PHY (or more than one PHY) found returns 0. * Sets active_phy_addr variable. */ -static int dm644x_eth_phy_detect(void) +static int davinci_eth_phy_detect(void) { u_int32_t phy_act_state; int i; @@ -159,7 +159,7 @@ static int dm644x_eth_phy_detect(void) if ((phy_act_state = adap_mdio->ALIVE) == 0) return(0); /* No active PHYs */
- debug_emac("dm644x_eth_phy_detect(), ALIVE = 0x%08x\n", phy_act_state); + debug_emac("davinci_eth_phy_detect(), ALIVE = 0x%08x\n", phy_act_state);
for (i = 0; i < 32; i++) { if (phy_act_state & (1 << i)) { @@ -177,7 +177,7 @@ static int dm644x_eth_phy_detect(void)
/* Read a PHY register via MDIO inteface. Returns 1 on success, 0 otherwise */ -int dm644x_eth_phy_read(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t *data) +int davinci_eth_phy_read(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t *data) { int tmp;
@@ -201,7 +201,7 @@ int dm644x_eth_phy_read(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t *data) }
/* Write to a PHY register via MDIO inteface. Blocks until operation is complete. */ -int dm644x_eth_phy_write(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t data) +int davinci_eth_phy_write(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t data) {
while (adap_mdio->USERACCESS0 & MDIO_USERACCESS0_GO) {;} @@ -235,14 +235,14 @@ static int gen_is_phy_connected(int phy_addr) { u_int16_t dummy;
- return(dm644x_eth_phy_read(phy_addr, PHY_PHYIDR1, &dummy)); + return(davinci_eth_phy_read(phy_addr, PHY_PHYIDR1, &dummy)); }
static int gen_get_link_speed(int phy_addr) { u_int16_t tmp;
- if (dm644x_eth_phy_read(phy_addr, MII_STATUS_REG, &tmp) && (tmp & 0x04)) + if (davinci_eth_phy_read(phy_addr, MII_STATUS_REG, &tmp) && (tmp & 0x04)) return(1);
return(0); @@ -252,16 +252,16 @@ static int gen_auto_negotiate(int phy_addr) { u_int16_t tmp;
- if (!dm644x_eth_phy_read(phy_addr, PHY_BMCR, &tmp)) + if (!davinci_eth_phy_read(phy_addr, PHY_BMCR, &tmp)) return(0);
/* Restart Auto_negotiation */ tmp |= PHY_BMCR_AUTON; - dm644x_eth_phy_write(phy_addr, PHY_BMCR, tmp); + davinci_eth_phy_write(phy_addr, PHY_BMCR, tmp);
/*check AutoNegotiate complete */ udelay (10000); - if (!dm644x_eth_phy_read(phy_addr, PHY_BMSR, &tmp)) + if (!davinci_eth_phy_read(phy_addr, PHY_BMSR, &tmp)) return(0);
if (!(tmp & PHY_BMSR_AUTN_COMP)) @@ -273,19 +273,19 @@ static int gen_auto_negotiate(int phy_addr)
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) -static int dm644x_mii_phy_read(char *devname, unsigned char addr, unsigned char reg, unsigned short *value) +static int davinci_mii_phy_read(char *devname, unsigned char addr, unsigned char reg, unsigned short *value) { - return(dm644x_eth_phy_read(addr, reg, value) ? 0 : 1); + return(davinci_eth_phy_read(addr, reg, value) ? 0 : 1); }
-static int dm644x_mii_phy_write(char *devname, unsigned char addr, unsigned char reg, unsigned short value) +static int davinci_mii_phy_write(char *devname, unsigned char addr, unsigned char reg, unsigned short value) { - return(dm644x_eth_phy_write(addr, reg, value) ? 0 : 1); + return(davinci_eth_phy_write(addr, reg, value) ? 0 : 1); }
-int dm644x_eth_miiphy_initialize(bd_t *bis) +int davinci_eth_miiphy_initialize(bd_t *bis) { - miiphy_register(phy.name, dm644x_mii_phy_read, dm644x_mii_phy_write); + miiphy_register(phy.name, davinci_mii_phy_read, davinci_mii_phy_write);
return(1); } @@ -296,13 +296,13 @@ int dm644x_eth_miiphy_initialize(bd_t *bis) * EMAC modules power or pin multiplexors, that is done by board_init() * much earlier in bootup process. Returns 1 on success, 0 otherwise. */ -static int dm644x_eth_hw_init(void) +static int davinci_eth_hw_init(void) { u_int32_t phy_id; u_int16_t tmp; int i;
for (i = 0; i < 256; i++) { if (adap_mdio->ALIVE) @@ -316,18 +316,18 @@ static int dm644x_eth_hw_init(void) }
/* Find if a PHY is connected and get it's address */ - if (!dm644x_eth_phy_detect()) + if (!davinci_eth_phy_detect()) return(0);
/* Get PHY ID and initialize phy_ops for a detected PHY */ - if (!dm644x_eth_phy_read(active_phy_addr, PHY_PHYIDR1, &tmp)) { + if (!davinci_eth_phy_read(active_phy_addr, PHY_PHYIDR1, &tmp)) { active_phy_addr = 0xff; return(0); }
phy_id = (tmp << 16) & 0xffff0000;
- if (!dm644x_eth_phy_read(active_phy_addr, PHY_PHYIDR2, &tmp)) { + if (!davinci_eth_phy_read(active_phy_addr, PHY_PHYIDR2, &tmp)) { active_phy_addr = 0xff; return(0); } @@ -364,7 +364,7 @@ static int dm644x_eth_hw_init(void)
/* Eth device open */ -static int dm644x_eth_open(void) +static int davinci_eth_open(void) { dv_reg_p addr; u_int32_t clkdiv, cnt; @@ -389,26 +389,26 @@ static int dm644x_eth_open(void) /* Using channel 0 only - other channels are disabled */ adap_emac->MACINDEX = 0; adap_emac->MACADDRHI = - (dm644x_eth_mac_addr[3] << 24) | - (dm644x_eth_mac_addr[2] << 16) | - (dm644x_eth_mac_addr[1] << 8) | - (dm644x_eth_mac_addr[0]); + (davinci_eth_mac_addr[3] << 24) | + (davinci_eth_mac_addr[2] << 16) | + (davinci_eth_mac_addr[1] << 8) | + (davinci_eth_mac_addr[0]); adap_emac->MACADDRLO = - (dm644x_eth_mac_addr[5] << 8) | - (dm644x_eth_mac_addr[4]); + (davinci_eth_mac_addr[5] << 8) | + (davinci_eth_mac_addr[4]);
adap_emac->MACHASH1 = 0; adap_emac->MACHASH2 = 0;
/* Set source MAC address - REQUIRED */ adap_emac->MACSRCADDRHI = - (dm644x_eth_mac_addr[3] << 24) | - (dm644x_eth_mac_addr[2] << 16) | - (dm644x_eth_mac_addr[1] << 8) | - (dm644x_eth_mac_addr[0]); + (davinci_eth_mac_addr[3] << 24) | + (davinci_eth_mac_addr[2] << 16) | + (davinci_eth_mac_addr[1] << 8) | + (davinci_eth_mac_addr[0]); adap_emac->MACSRCADDRLO = - (dm644x_eth_mac_addr[4] << 8) | - (dm644x_eth_mac_addr[5]); + (davinci_eth_mac_addr[4] << 8) | + (davinci_eth_mac_addr[5]);
/* Set DMA 8 TX / 8 RX Head pointers to 0 */ addr = &adap_emac->TX0HDP; @@ -473,7 +473,7 @@ static int dm644x_eth_open(void) }
/* EMAC Channel Teardown */ -static void dm644x_eth_ch_teardown(int ch) +static void davinci_eth_ch_teardown(int ch) { dv_reg dly = 0xff; dv_reg cnt; @@ -516,12 +516,12 @@ static void dm644x_eth_ch_teardown(int ch) }
/* Eth device close */ -static int dm644x_eth_close(void) +static int davinci_eth_close(void) { debug_emac("+ emac_close\n");
- dm644x_eth_ch_teardown(EMAC_CH_TX); /* TX Channel teardown */ - dm644x_eth_ch_teardown(EMAC_CH_RX); /* RX Channel teardown */ + davinci_eth_ch_teardown(EMAC_CH_TX); /* TX Channel teardown */ + davinci_eth_ch_teardown(EMAC_CH_RX); /* RX Channel teardown */
/* Reset EMAC module and disable interrupts in wrapper */ adap_emac->SOFTRESET = 1; @@ -537,7 +537,7 @@ static int tx_send_loop = 0; * This function sends a single packet on the network and returns * positive number (number of bytes transmitted) or negative for error */ -static int dm644x_eth_send_packet (volatile void *packet, int length) +static int davinci_eth_send_packet (volatile void *packet, int length) { int ret_status = -1;
@@ -568,7 +568,7 @@ static int dm644x_eth_send_packet (volatile void *packet, int length) /* Wait for packet to complete or link down */ while (1) { if (!phy.get_link_speed (active_phy_addr)) { - dm644x_eth_ch_teardown (EMAC_CH_TX); + davinci_eth_ch_teardown (EMAC_CH_TX); return (ret_status); } if (adap_emac->TXINTSTATRAW & 0x01) { @@ -584,7 +584,7 @@ static int dm644x_eth_send_packet (volatile void *packet, int length) /* * This function handles receipt of a packet from the network */ -static int dm644x_eth_rcv_packet (void) +static int davinci_eth_rcv_packet (void) { volatile emac_desc *rx_curr_desc; volatile emac_desc *curr_desc; diff --git a/cpu/arm926ejs/davinci/lxt972.c b/cpu/arm926ejs/davinci/lxt972.c index 8130b48..ce3e41c 100644 --- a/cpu/arm926ejs/davinci/lxt972.c +++ b/cpu/arm926ejs/davinci/lxt972.c @@ -39,9 +39,9 @@ int lxt972_is_phy_connected(int phy_addr) { u_int16_t id1, id2;
- if (!dm644x_eth_phy_read(phy_addr, PHY_PHYIDR1, &id1)) + if (!davinci_eth_phy_read(phy_addr, PHY_PHYIDR1, &id1)) return(0); - if (!dm644x_eth_phy_read(phy_addr, PHY_PHYIDR2, &id2)) + if (!davinci_eth_phy_read(phy_addr, PHY_PHYIDR2, &id2)) return(0);
if ((id1 == (0x0013)) && ((id2 & 0xfff0) == 0x78e0)) @@ -55,20 +55,20 @@ int lxt972_get_link_speed(int phy_addr) u_int16_t stat1, tmp; volatile emac_regs *emac = (emac_regs *)EMAC_BASE_ADDR;
- if (!dm644x_eth_phy_read(phy_addr, PHY_LXT971_STAT2, &stat1)) + if (!davinci_eth_phy_read(phy_addr, PHY_LXT971_STAT2, &stat1)) return(0);
if (!(stat1 & PHY_LXT971_STAT2_LINK)) /* link up? */ return(0);
- if (!dm644x_eth_phy_read(phy_addr, PHY_LXT971_DIG_CFG, &tmp)) + if (!davinci_eth_phy_read(phy_addr, PHY_LXT971_DIG_CFG, &tmp)) return(0);
tmp |= PHY_LXT971_DIG_CFG_MII_DRIVE;
- dm644x_eth_phy_write(phy_addr, PHY_LXT971_DIG_CFG, tmp); + davinci_eth_phy_write(phy_addr, PHY_LXT971_DIG_CFG, tmp); /* Read back */ - if (!dm644x_eth_phy_read(phy_addr, PHY_LXT971_DIG_CFG, &tmp)) + if (!davinci_eth_phy_read(phy_addr, PHY_LXT971_DIG_CFG, &tmp)) return(0);
/* Speed doesn't matter, there is no setting for it in EMAC... */ @@ -95,7 +95,7 @@ int lxt972_init_phy(int phy_addr) }
/* Disable PHY Interrupts */ - dm644x_eth_phy_write(phy_addr, PHY_LXT971_INT_ENABLE, 0); + davinci_eth_phy_write(phy_addr, PHY_LXT971_INT_ENABLE, 0);
return(ret); } @@ -105,16 +105,16 @@ int lxt972_auto_negotiate(int phy_addr) { u_int16_t tmp;
/* Restart Auto_negotiation */ tmp |= PHY_BMCR_RST_NEG; - dm644x_eth_phy_write(phy_addr, PHY_BMCR, tmp); + davinci_eth_phy_write(phy_addr, PHY_BMCR, tmp);
if (!(tmp & PHY_BMSR_AUTN_COMP)) diff --git a/lib_arm/board.c b/lib_arm/board.c index 6e3ef08..5ade882 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -430,9 +430,9 @@ void start_armboot (void)
/* Perform network card initialisation if necessary */ #ifdef CONFIG_DRIVER_TI_EMAC -extern void dm644x_eth_set_mac_addr (const u_int8_t *addr); +extern void davinci_eth_set_mac_addr (const u_int8_t *addr); if (getenv ("ethaddr")) { - dm644x_eth_set_mac_addr(gd->bd->bi_enetaddr); + davinci_eth_set_mac_addr(gd->bd->bi_enetaddr); } #endif
diff --git a/net/eth.c b/net/eth.c index 8e83b66..76992ec 100644 --- a/net/eth.c +++ b/net/eth.c @@ -623,7 +623,7 @@ int eth_initialize(bd_t *bis) ns7520_miiphy_initialize(bis); #endif #if defined(CONFIG_DRIVER_TI_EMAC) - dm644x_eth_miiphy_initialize(bis); + davinci_eth_miiphy_initialize(bis); #endif return 0; }
s-paulraj@ti.com
