[U-Boot] [PATCH] MCI support for AT91 family processors.
Fixed to parse CSD correctly on little endian processors as gcc orders bitfields differently between big and little endian ones.
Signed-off-by: Sami Kantoluoto sami.kantoluoto@embedtronics.fi --- drivers/mmc/atmel_mci.c | 55 ++++++++++++++++++++++++++++++++++++-- include/asm-arm/arch-at91/clk.h | 5 +++ 2 files changed, 57 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/atmel_mci.c b/drivers/mmc/atmel_mci.c index 3946ffe..c2837a8 100644 --- a/drivers/mmc/atmel_mci.c +++ b/drivers/mmc/atmel_mci.c @@ -282,6 +282,53 @@ static void sd_parse_cid(struct mmc_cid *cid, unsigned long *resp) cid->mdt = (resp[3] >> 8) & 0x0fff; }
+static void mmc_parse_csd(struct mmc_csd *csd, unsigned long *resp) +{ +#if __BYTE_ORDER == __BIG_ENDIAN + memcpy(csd, resp, sizeof(csd)); +#elif __BYTE_ORDER == __LITTLE_ENDIAN + csd->csd_structure = resp[0] >> 30; + csd->spec_vers = resp[0] >> 26; + csd->rsvd1 = resp[0] >> 24; + csd->taac = resp[0] >> 16; + csd->nsac = resp[0] >> 8; + csd->tran_speed = resp[0] & 0xff; + csd->ccc = resp[1] >> 20; + csd->read_bl_len = resp[1] >> 16; + csd->read_bl_partial = resp[1] >> 15; + csd->write_blk_misalign = resp[1] >> 14; + csd->read_blk_misalign = resp[1] >> 13; + csd->dsr_imp = resp[1] >> 12; + csd->rsvd2 = resp[1] >> 10; + csd->c_size = (resp[1] << 2) | (resp[2] >> 30); + csd->vdd_r_curr_min = resp[2] >> 27; + csd->vdd_r_curr_max = resp[2] >> 24; + csd->vdd_w_curr_min = resp[2] >> 21; + csd->vdd_w_curr_max = resp[2] >> 18; + csd->c_size_mult = resp[2] >> 15; + csd->sector_size = resp[2] >> 10; + csd->erase_grp_size = resp[2] >> 5; + csd->wp_grp_size = resp[2] & 0x1f; + csd->wp_grp_enable = resp[3] >> 31; + csd->default_ecc = resp[3] >> 29; + csd->r2w_factor = resp[3] >> 26; + csd->write_bl_len = resp[3] >> 22; + csd->write_bl_partial = resp[3] >> 21; + csd->rsvd3 = resp[3] >> 16; + + csd->file_format_grp = resp[3] >> 15; + csd->copy = resp[3] >> 14; + csd->perm_write_protect = resp[3] >> 13; + csd->tmp_write_protect = resp[3] >> 12; + csd->file_format = resp[3] >> 10; + csd->ecc = resp[3] >> 8; + csd->crc = resp[3] >> 1; + csd->one = resp[3] & 1; +#else +#error Unsupported __BYTE_ORDER +#endif +} + static void mmc_dump_cid(const struct mmc_cid *cid) { printf("Manufacturer ID: %02X\n", cid->mid); @@ -298,7 +345,7 @@ static void mmc_dump_csd(const struct mmc_csd *csd) { unsigned long *csd_raw = (unsigned long *)csd; printf("CSD data: %08lx %08lx %08lx %08lx\n", - csd_raw[0], csd_raw[1], csd_raw[2], csd_raw[3]); + ntohl(csd_raw[0]), ntohl(csd_raw[1]), ntohl(csd_raw[2]), ntohl(csd_raw[3])); printf("CSD structure version: 1.%u\n", csd->csd_structure); printf("MMC System Spec version: %u\n", csd->spec_vers); printf("Card command classes: %03x\n", csd->ccc); @@ -368,7 +415,7 @@ static int sd_init_card(struct mmc_cid *cid, int verbose)
/* Get RCA of the card that responded */ ret = mmc_cmd(SD_CMD_SEND_RELATIVE_ADDR, 0, resp, R6 | NCR); - if (ret) + if (ret) return ret;
mmc_rca = resp[0] >> 16; @@ -468,6 +515,7 @@ int mmc_legacy_init(int verbose) struct mmc_cid cid; struct mmc_csd csd; unsigned int max_blksz; + unsigned long resp[4]; int ret;
/* Initialize controller */ @@ -488,9 +536,10 @@ int mmc_legacy_init(int verbose) return ret;
/* Get CSD from the card */ - ret = mmc_cmd(MMC_CMD_SEND_CSD, mmc_rca << 16, &csd, R2 | NCR); + ret = mmc_cmd(MMC_CMD_SEND_CSD, mmc_rca << 16, resp, R2 | NCR); if (ret) return ret; + mmc_parse_csd(&csd, resp); if (verbose) mmc_dump_csd(&csd);
diff --git a/include/asm-arm/arch-at91/clk.h b/include/asm-arm/arch-at91/clk.h index f642dd9..26b537c 100644 --- a/include/asm-arm/arch-at91/clk.h +++ b/include/asm-arm/arch-at91/clk.h @@ -54,6 +54,11 @@ static inline unsigned long get_spi_clk_rate(unsigned int dev_id) return get_mck_clk_rate(); }
+static inline unsigned long get_mci_clk_rate(void) +{ + return get_mck_clk_rate(); +} + static inline unsigned long get_twi_clk_rate(unsigned int dev_id) { return get_mck_clk_rate();
Hello Sami,
Please also see this patch, which will fix those bugs as weel, while switching to the new GENRIC_MMC API: http://lists.denx.de/pipermail/u-boot/2009-August/059456.html I'd highly appreciate if you could test it, to get some feedback
- return get_mck_clk_rate();
This is still rather incomplete, you're lacking the definition of MMCI_BASE and the configuration for the MCI controller, which should be done in the at91sam*_devices.c files. See the attached patch (relying on the patch mentionned above) that adds such support. It's not complete yet either: it partially lacks support for models which have 2 MCI controllers, but that's not the case of the 9G20 anyway (that's just a matter of putting proper ifdefs before defining AT91_BASE_MCI). If what I've done in this patch is not the way to go, I'd appreciate guidance on how to do it correctly.
Regards, Albin
--- cpu/arm926ejs/at91/at91cap9_devices.c | 36 +++++++++++++++++++ cpu/arm926ejs/at91/at91sam9260_devices.c | 25 +++++++++++++ cpu/arm926ejs/at91/at91sam9261_devices.c | 18 ++++++++++ cpu/arm926ejs/at91/at91sam9263_devices.c | 50 +++++++++++++++++++++++++++ cpu/arm926ejs/at91/at91sam9m10g45_devices.c | 50 +++++++++++++++++++++++++++ cpu/arm926ejs/at91/at91sam9rl_devices.c | 22 ++++++++++++ cpu/arm926ejs/at91/cpu.c | 7 ++++ include/asm-arm/arch-at91/at91_common.h | 2 + include/asm-arm/arch-at91/clk.h | 5 +++ include/asm-arm/arch-at91/hardware.h | 1 + include/asm-arm/arch-at91/memory-map.h | 1 + 11 files changed, 217 insertions(+), 0 deletions(-)
diff --git a/cpu/arm926ejs/at91/at91cap9_devices.c b/cpu/arm926ejs/at91/at91cap9_devices.c index 39e405f..2dc1984 100644 --- a/cpu/arm926ejs/at91/at91cap9_devices.c +++ b/cpu/arm926ejs/at91/at91cap9_devices.c @@ -79,6 +79,42 @@ void at91_serial_hw_init(void) #endif }
+#ifdef CONFIG_ATMEL_MCI +#ifdef CONFIG_AT91_MCI0 +void at91_mci0_hw_init(int slot) +{ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_MCI0); + at91_set_A_periph(AT91_PIN_PA2, 0); + + switch(slot) { + case 0: + at91_set_A_periph(AT91_PIN_PA0, 1); + at91_set_A_periph(AT91_PIN_PA1, 1); + at91_set_A_periph(AT91_PIN_PA3, 1); + at91_set_A_periph(AT91_PIN_PA4, 1); + at91_set_A_periph(AT91_PIN_PA5, 1); + break; + } +} +#elif defined(CONFIG_AT91_MCI1 +void at91_mci1_hw_init(int slot) +{ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_MCI); + at91_set_A_periph(AT91_PIN_PA16, 0); + + switch(slot) { + case 0: + at91_set_A_periph(AT91_PIN_PA17, 1); + at91_set_A_periph(AT91_PIN_PA18, 1); + at91_set_A_periph(AT91_PIN_PA19, 1); + at91_set_A_periph(AT91_PIN_PA20, 1); + at91_set_A_periph(AT91_PIN_PA21, 1); + break; + } +} +#endif +#endif + #ifdef CONFIG_HAS_DATAFLASH void at91_spi0_hw_init(unsigned long cs_mask) { diff --git a/cpu/arm926ejs/at91/at91sam9260_devices.c b/cpu/arm926ejs/at91/at91sam9260_devices.c index f86cb99..413fc8b 100644 --- a/cpu/arm926ejs/at91/at91sam9260_devices.c +++ b/cpu/arm926ejs/at91/at91sam9260_devices.c @@ -75,6 +75,31 @@ void at91_serial_hw_init(void) #endif }
+#ifdef CONFIG_ATMEL_MCI +void at91_mci0_hw_init(int slot) +{ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_MCI); + at91_set_A_periph(AT91_PIN_PA8, 0); + + switch(slot) { + case 0: + at91_set_A_periph(AT91_PIN_PA6, 1); + at91_set_A_periph(AT91_PIN_PA7, 1); + at91_set_A_periph(AT91_PIN_PA9, 1); + at91_set_A_periph(AT91_PIN_PA10, 1); + at91_set_A_periph(AT91_PIN_PA11, 1); + break; + case 1: + at91_set_B_periph(AT91_PIN_PA0, 1); + at91_set_B_periph(AT91_PIN_PA1, 1); + at91_set_B_periph(AT91_PIN_PA3, 1); + at91_set_B_periph(AT91_PIN_PA4, 1); + at91_set_B_periph(AT91_PIN_PA5, 1); + break; + } +} +#endif /* ATMEL_MCI */ + #if defined(CONFIG_HAS_DATAFLASH) || defined(CONFIG_ATMEL_SPI) void at91_spi0_hw_init(unsigned long cs_mask) { diff --git a/cpu/arm926ejs/at91/at91sam9261_devices.c b/cpu/arm926ejs/at91/at91sam9261_devices.c index 16d411f..e777367 100644 --- a/cpu/arm926ejs/at91/at91sam9261_devices.c +++ b/cpu/arm926ejs/at91/at91sam9261_devices.c @@ -75,6 +75,24 @@ void at91_serial_hw_init(void) #endif }
+#ifdef CONFIG_ATMEL_MCI +void at91_mci0_hw_init(int slot) +{ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_MCI); + at91_set_B_periph(AT91_PIN_PA2, 0); + + switch(slot) { + case 0: + at91_set_B_periph(AT91_PIN_PA0, 1); + at91_set_B_periph(AT91_PIN_PA1, 1); + at91_set_B_periph(AT91_PIN_PA4, 1); + at91_set_B_periph(AT91_PIN_PA5, 1); + at91_set_B_periph(AT91_PIN_PA6, 1); + break; + } +} +#endif /* ATMEL_MCI */ + #ifdef CONFIG_HAS_DATAFLASH void at91_spi0_hw_init(unsigned long cs_mask) { diff --git a/cpu/arm926ejs/at91/at91sam9263_devices.c b/cpu/arm926ejs/at91/at91sam9263_devices.c index f72efdf..e861108 100644 --- a/cpu/arm926ejs/at91/at91sam9263_devices.c +++ b/cpu/arm926ejs/at91/at91sam9263_devices.c @@ -79,6 +79,56 @@ void at91_serial_hw_init(void) #endif }
+#ifdef CONFIG_ATMEL_MCI +#ifdef CONFIG_AT91_MCI0 +void at91_mci0_hw_init(int slot) +{ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_MCI0); + at91_set_A_periph(AT91_PIN_PA12, 0); + + switch(slot) { + case 0: + at91_set_A_periph(AT91_PIN_PA0, 1); + at91_set_A_periph(AT91_PIN_PA1, 1); + at91_set_A_periph(AT91_PIN_PA3, 1); + at91_set_A_periph(AT91_PIN_PA4, 1); + at91_set_A_periph(AT91_PIN_PA5, 1); + break; + case 1: + at91_set_A_periph(AT91_PIN_PA16, 1); + at91_set_A_periph(AT91_PIN_PA17, 1); + at91_set_A_periph(AT91_PIN_PA18, 1); + at91_set_A_periph(AT91_PIN_PA19, 1); + at91_set_A_periph(AT91_PIN_PA20, 1); + break; + } +} +#elif defined(CONFIG_AT91_MCI1 +void at91_mci1_hw_init(int slot) +{ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_MCI); + at91_set_A_periph(AT91_PIN_PA6, 0); + + switch(slot) { + case 0: + at91_set_A_periph(AT91_PIN_PA7, 1); + at91_set_A_periph(AT91_PIN_PA8, 1); + at91_set_A_periph(AT91_PIN_PA9, 1); + at91_set_A_periph(AT91_PIN_PA10, 1); + at91_set_A_periph(AT91_PIN_PA11, 1); + break; + case 1: + at91_set_B_periph(AT91_PIN_PA21, 1); + at91_set_B_periph(AT91_PIN_PA22, 1); + at91_set_B_periph(AT91_PIN_PA23, 1); + at91_set_B_periph(AT91_PIN_PA24, 1); + at91_set_B_periph(AT91_PIN_PA25, 1); + break; + } +} +#endif +#endif + #ifdef CONFIG_HAS_DATAFLASH void at91_spi0_hw_init(unsigned long cs_mask) { diff --git a/cpu/arm926ejs/at91/at91sam9m10g45_devices.c b/cpu/arm926ejs/at91/at91sam9m10g45_devices.c index 98d90f2..8b2d210 100644 --- a/cpu/arm926ejs/at91/at91sam9m10g45_devices.c +++ b/cpu/arm926ejs/at91/at91sam9m10g45_devices.c @@ -75,6 +75,56 @@ void at91_serial_hw_init(void) #endif }
+#ifdef CONFIG_ATMEL_MCI +#ifdef CONFIG_AT91_MCI0 +void at91_mci0_hw_init(int slot) +{ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_MCI0); + at91_set_A_periph(AT91_PIN_PA12, 0); + + switch(slot) { + case 0: + at91_set_A_periph(AT91_PIN_PA0, 1); + at91_set_A_periph(AT91_PIN_PA1, 1); + at91_set_A_periph(AT91_PIN_PA3, 1); + at91_set_A_periph(AT91_PIN_PA4, 1); + at91_set_A_periph(AT91_PIN_PA5, 1); + break; + case 1: + at91_set_A_periph(AT91_PIN_PA16, 1); + at91_set_A_periph(AT91_PIN_PA17, 1); + at91_set_A_periph(AT91_PIN_PA18, 1); + at91_set_A_periph(AT91_PIN_PA19, 1); + at91_set_A_periph(AT91_PIN_PA20, 1); + break; + } +} +#elif defined(CONFIG_AT91_MCI1 +void at91_mci1_hw_init(int slot) +{ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_MCI); + at91_set_A_periph(AT91_PIN_PA6, 0); + + switch(slot) { + case 0: + at91_set_A_periph(AT91_PIN_PA7, 1); + at91_set_A_periph(AT91_PIN_PA8, 1); + at91_set_A_periph(AT91_PIN_PA9, 1); + at91_set_A_periph(AT91_PIN_PA10, 1); + at91_set_A_periph(AT91_PIN_PA11, 1); + break; + case 1: + at91_set_B_periph(AT91_PIN_PA0, 1); + at91_set_B_periph(AT91_PIN_PA1, 1); + at91_set_B_periph(AT91_PIN_PA3, 1); + at91_set_B_periph(AT91_PIN_PA4, 1); + at91_set_B_periph(AT91_PIN_PA5, 1); + break; + } +} +#endif +#endif + #ifdef CONFIG_ATMEL_SPI void at91_spi0_hw_init(unsigned long cs_mask) { diff --git a/cpu/arm926ejs/at91/at91sam9rl_devices.c b/cpu/arm926ejs/at91/at91sam9rl_devices.c index ebed193..1839b0c 100644 --- a/cpu/arm926ejs/at91/at91sam9rl_devices.c +++ b/cpu/arm926ejs/at91/at91sam9rl_devices.c @@ -75,6 +75,28 @@ void at91_serial_hw_init(void) #endif }
+/* + * The AT91SAM9RL64 is said to have 2 slots, but the datasheet doesn't + * seem to mention to what pins the second slot is assigned + */ +#ifdef CONFIG_ATMEL_MCI +void at91_mci0_hw_init(int slot) +{ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_MCI); + at91_set_A_periph(AT91_PIN_PA2, 0); + + switch(slot) { + case 0: + at91_set_A_periph(AT91_PIN_PA0, 1); + at91_set_A_periph(AT91_PIN_PA1, 1); + at91_set_A_periph(AT91_PIN_PA3, 1); + at91_set_A_periph(AT91_PIN_PA4, 1); + at91_set_A_periph(AT91_PIN_PA5, 1); + break; + } +} +#endif /* ATMEL_MCI */ + #ifdef CONFIG_HAS_DATAFLASH void at91_spi0_hw_init(unsigned long cs_mask) { diff --git a/cpu/arm926ejs/at91/cpu.c b/cpu/arm926ejs/at91/cpu.c index f2f7b62..f96b715 100644 --- a/cpu/arm926ejs/at91/cpu.c +++ b/cpu/arm926ejs/at91/cpu.c @@ -52,3 +52,10 @@ int print_cpuinfo(void) return 0; } #endif + +#ifdef CONFIG_GENERIC_MMC +int cpu_mmc_init(bd_t *bis) +{ + atmel_mci_init(bis); +} +#endif /* GENERIC_MMC */ diff --git a/include/asm-arm/arch-at91/at91_common.h b/include/asm-arm/arch-at91/at91_common.h index 01840ee..4bb9887 100644 --- a/include/asm-arm/arch-at91/at91_common.h +++ b/include/asm-arm/arch-at91/at91_common.h @@ -32,6 +32,8 @@ void at91_serial0_hw_init(void); void at91_serial1_hw_init(void); void at91_serial2_hw_init(void); void at91_serial3_hw_init(void); +void at91_mci0_hw_init(int); +void at91_mci1_hw_init(int); void at91_spi0_hw_init(unsigned long cs_mask); void at91_spi1_hw_init(unsigned long cs_mask); void at91_uhp_hw_init(void); diff --git a/include/asm-arm/arch-at91/clk.h b/include/asm-arm/arch-at91/clk.h index f642dd9..457e6c9 100644 --- a/include/asm-arm/arch-at91/clk.h +++ b/include/asm-arm/arch-at91/clk.h @@ -59,5 +59,10 @@ static inline unsigned long get_twi_clk_rate(unsigned int dev_id) return get_mck_clk_rate(); }
+static inline unsigned long get_mci_clk_rate(void) +{ + return get_mck_clk_rate(); +} + int at91_clock_init(unsigned long main_clock); #endif /* __ASM_ARM_ARCH_CLK_H__ */ diff --git a/include/asm-arm/arch-at91/hardware.h b/include/asm-arm/arch-at91/hardware.h index de06a10..6430ade 100644 --- a/include/asm-arm/arch-at91/hardware.h +++ b/include/asm-arm/arch-at91/hardware.h @@ -20,6 +20,7 @@ #include <asm/arch/at91rm9200.h> #elif defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) #include <asm/arch/at91sam9260.h> +#define AT91_BASE_MCI AT91SAM9260_BASE_MCI #define AT91_BASE_SPI AT91SAM9260_BASE_SPI0 #define AT91_ID_UHP AT91SAM9260_ID_UHP #define AT91_PMC_UHP AT91SAM926x_PMC_UHP diff --git a/include/asm-arm/arch-at91/memory-map.h b/include/asm-arm/arch-at91/memory-map.h index f605f37..300b61d 100644 --- a/include/asm-arm/arch-at91/memory-map.h +++ b/include/asm-arm/arch-at91/memory-map.h @@ -31,5 +31,6 @@ #define USART2_BASE AT91_USART2 #define USART3_BASE (AT91_BASE_SYS + AT91_DBGU) #define SPI0_BASE AT91_BASE_SPI +#define MMCI_BASE AT91_BASE_MCI
#endif /* __ASM_ARM_ARCH_MEMORYMAP_H__ */
- at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_MCI0);
please use correct SOC cloclk marco everywhere
- at91_set_A_periph(AT91_PIN_PA2, 0);
- switch(slot) {
why switch slot? you are already in mci0 and there is only one for the cap9
case 0:
you need to add an option to PA3,4,5 only in 4 wire mode and it's will be also available for the other hw_init
break;
miss a ')' and on some other
- at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_MCI);
- at91_set_A_periph(AT91_PIN_PA16, 0);
- switch(slot) {
why switch slot? you are already in mci1 and there is only one for the cap9
case 0:
break;
+} +#endif +#endif
please use MCI0_BASE and MCI1_BASE so we can detect if the soc support multiple mci and please move it to soc header I'll send a patch to clean the other
Best Regards, J.
Oh ... I had a more recent patch, but looks like it didn't make it to the list. It already fixes a large parts of your comments. Thanks for the review
I'm not sure what other you're talking about
Regards,
take a look in the atmel_spi driver
the number of MCI will be detected depending on the MCIx_BASE declared in the soc header
Best Regards, J.
[Ccing Haavard, as he's the maintainer for the atmel_mci driver]
Hi Sami,
I guess it's mostly a matter of preference, but I'd tend to use be32_to_cpu for things that aren't network-related.
- if (ret)
- if (ret) return ret;
Looks like a random whitespace change, it's generally best to avoid that.
- ret = mmc_cmd(MMC_CMD_SEND_CSD, mmc_rca << 16, resp, R2 | NCR); if (ret) return ret;
- mmc_parse_csd(&csd, resp); if (verbose) mmc_dump_csd(&csd);
Please remove this part, as it's not related to the bug you're fixing in atmel_mci − and that's part of the AT91 MCI support patch I sent anyway :)
Other than that, I've tried it on my AT91-based boards and that works fine. Thanks!
Tested-by: Albin Tonnerre albin.tonnerre@free-electrons.com
Regards,
Albin Tonnerre
Jean-Christophe PLAGNIOL-VILLARD
Sami Kantoluoto
