[U-Boot] Improve upstream support for Snowball board
Patches are loosely based on the tree maintained by Calao. FDT confirmed working, LAN is successfully detected by u-boot (but lacking a proper tftp setup this is untested). Upstream U-Boot still has one bug that prevents booting from eMMC. Easiest workaround is to revert
e95504497ecac46907204b0ee3460b708a2981ac mmc: Split device init to decouple OCR-polling delay
until I (or someone else) has time to device a proper fix. This doesn't prevent anyone from pushing these two patches though.
Signed-off-by: Roy Spliet rspliet@eclipso.eu --- board/st-ericsson/snowball/snowball.c | 11 +++++++++++ drivers/net/smc911x.h | 14 ++++++++++---- include/configs/snowball.h | 14 ++++++++++++++ 3 files changed, 35 insertions(+), 4 deletions(-)
diff --git a/board/st-ericsson/snowball/snowball.c b/board/st-ericsson/snowball/snowball.c index c3061e2..356beb1 100644 --- a/board/st-ericsson/snowball/snowball.c +++ b/board/st-ericsson/snowball/snowball.c @@ -245,6 +245,8 @@ int board_late_init(void) while (tstc()) (void) getc();
+ mdelay(25); + return 0; }
@@ -338,3 +340,12 @@ int board_mmc_init(bd_t *bis) return 0; } #endif /* CONFIG_MMC */ + +int board_eth_init(bd_t *bis) +{ + int error = smc911x_initialize(0, CONFIG_SMC911X_BASE); + if(error) + return error; + + return cpu_eth_init(bis); +} diff --git a/drivers/net/smc911x.h b/drivers/net/smc911x.h index acae0cf..7fe55f1 100644 --- a/drivers/net/smc911x.h +++ b/drivers/net/smc911x.h @@ -19,6 +19,12 @@ CONFIG_SMC911X_16_BIT shall be set" #endif
+#ifndef CONFIG_SMC911X_SHIFT +#define CONFIG_SMC911X_SHIFT 0 +#endif + +#define smc911x_shift(i) ((i) << CONFIG_SMC911X_SHIFT) + #if defined (CONFIG_SMC911X_32_BIT) static inline u32 __smc911x_reg_read(struct eth_device *dev, u32 offset) { @@ -37,14 +43,14 @@ void smc911x_reg_write(struct eth_device *dev, u32 offset, u32 val) #elif defined (CONFIG_SMC911X_16_BIT) static inline u32 smc911x_reg_read(struct eth_device *dev, u32 offset) { - volatile u16 *addr_16 = (u16 *)(dev->iobase + offset); - return ((*addr_16 & 0x0000ffff) | (*(addr_16 + 1) << 16)); + volatile u16 *addr_16 = (u16 *)(dev->iobase + smc911x_shift(offset)); + return ((*addr_16 & 0x0000FFFF) | (*(addr_16 + smc911x_shift(1)) << 16)); } static inline void smc911x_reg_write(struct eth_device *dev, u32 offset, u32 val) { - *(volatile u16 *)(dev->iobase + offset) = (u16)val; - *(volatile u16 *)(dev->iobase + offset + 2) = (u16)(val >> 16); + *(volatile u16 *)(dev->iobase + smc911x_shift(offset)) = (u16)val; + *(volatile u16 *)(dev->iobase + smc911x_shift(offset + 2)) = (u16)val; } #else #error "SMC911X: undefined bus width" diff --git a/include/configs/snowball.h b/include/configs/snowball.h index 9a069f3..6201b3f 100644 --- a/include/configs/snowball.h +++ b/include/configs/snowball.h @@ -95,6 +95,10 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 #define CONFIG_CMD_SOURCE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PING
#ifndef CONFIG_BOOTDELAY #define CONFIG_BOOTDELAY 1 @@ -245,4 +249,14 @@
#define CFG_FSMC_BASE 0x80000000 /* FSMC Controller */
+/* + * Networking + */ +#define CONFIG_NET +#define CONFIG_NET_MULTI +#define CONFIG_SMC911X +#define CONFIG_SMC911X_16_BIT +#define CONFIG_SMC911X_SHIFT 1 +#define CONFIG_SMC911X_BASE 0x50000000 + #endif /* __CONFIG_H */
Try to fix - checkpatch.pl issues. total: 2 errors, 4 warnings, 0 checks, 74 lines checked
mdelay(25);
if(error)
return error;
TAG++
TAG--
TAG++ ..TAG-- as this area of code is part of smc911x driver, better to create another patch for it.
By the way does this change comes from bcz of snowball or a generic one?
Dear Jagan,
Thanks for the feedback. I will check the patch and split it up in two. This fix is derived from the igloocommunity github u-boot repository, but their implementation was a bit too ad-hoc for my taste, using #ifdef CONFIG_SNOWBALL to override the alignment of the smc911x driver. I added the delay based on trial-and-error, and without the delay the device would not be detected correctly. Perhaps 25ms is a little bit too long, but since I have no documentation to back the exact value up I guess this will just do. If you please I can experiment with shorter periods, but I personally feel it's not worth the effort and risks having a u-boot that doesn't work based on physical properties of the device (and thus appears to fail "randomly"). Yours,
Roy
--- Ursprüngliche Nachricht --- Von: Jagan Teki jagannadh.teki@gmail.com Datum: 18:07:30 14-12-2013 An: Roy Spliet rspliet@eclipso.eu Betreff: Re: [U-Boot] [PATCH 1/2] snowball: Add networking support
mdelay(25);
if(error)
return error;
TAG++
offset, u32 val)
16));
<< 16));
16);
(u16)val;
= (u16)val;
TAG--
-- Thanks, Jagan.
Jagannadha Sutradharudu Teki, E: jagannadh.teki@gmail.com, P: +91-9676773388 Engineer - System Software Hacker U-boot - SPI Custodian and Zynq APSOC Ln: http://www.linkedin.com/in/jaganteki
Signed-off-by: Roy Spliet rspliet@eclipso.eu --- include/configs/snowball.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/configs/snowball.h b/include/configs/snowball.h index 6201b3f..4a19d2c 100644 --- a/include/configs/snowball.h +++ b/include/configs/snowball.h @@ -259,4 +259,9 @@ #define CONFIG_SMC911X_SHIFT 1 #define CONFIG_SMC911X_BASE 0x50000000
+/* + * Device tree + */ +#define CONFIG_OF_LIBFDT + #endif /* __CONFIG_H */
- Device tree
Acked-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com
Jagan Teki
Roy Spliet
