[U-Boot-Users] [PATCH] QE: Move FDT support into a common file
Move the flat device tree setup for QE related devices into a common file shared between 83xx & 85xx platforms that have QE's.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- common/fdt_support.c | 48 -------------------------- cpu/mpc83xx/fdt.c | 13 ++----- cpu/mpc85xx/fdt.c | 8 ++--- drivers/qe/Makefile | 3 +- drivers/qe/fdt.c | 90 ++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/qe/qe.h | 1 + 6 files changed, 99 insertions(+), 64 deletions(-) create mode 100644 drivers/qe/fdt.c
diff --git a/common/fdt_support.c b/common/fdt_support.c index a13c140..92f1c7f 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -30,9 +30,6 @@ #include <fdt_support.h> #include <exports.h>
-#ifdef CONFIG_QE -#include "../drivers/qe/qe.h" -#endif /* * Global data (for the gd->bd) */ @@ -617,49 +614,4 @@ void fdt_fixup_ethernet(void *fdt, bd_t *bd) #endif } } - -#ifdef CONFIG_QE -/* - * If a QE firmware has been uploaded, then add the 'firmware' node under - * the 'qe' node. - */ -void fdt_fixup_qe_firmware(void *fdt) -{ - struct qe_firmware_info *qe_fw_info; - int node, ret; - - qe_fw_info = qe_get_firmware_info(); - if (!qe_fw_info) - return; - - node = fdt_path_offset(fdt, "/qe"); - if (node < 0) - return; - - /* We assume the node doesn't exist yet */ - node = fdt_add_subnode(fdt, node, "firmware"); - if (node < 0) - return; - - ret = fdt_setprop(fdt, node, "extended-modes", - &qe_fw_info->extended_modes, sizeof(u64)); - if (ret < 0) - goto error; - - ret = fdt_setprop_string(fdt, node, "id", qe_fw_info->id); - if (ret < 0) - goto error; - - ret = fdt_setprop(fdt, node, "virtual-traps", qe_fw_info->vtraps, - sizeof(qe_fw_info->vtraps)); - if (ret < 0) - goto error; - - return; - -error: - fdt_del_node(fdt, node); -} -#endif - #endif diff --git a/cpu/mpc83xx/fdt.c b/cpu/mpc83xx/fdt.c index 909171f..6f55932 100644 --- a/cpu/mpc83xx/fdt.c +++ b/cpu/mpc83xx/fdt.c @@ -30,6 +30,8 @@ #include <libfdt.h> #include <fdt_support.h>
+extern void ft_qe_setup(void *blob); + DECLARE_GLOBAL_DATA_PTR;
void ft_cpu_setup(void *blob, bd_t *bd) @@ -48,16 +50,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) do_fixup_by_prop_u32(blob, "device_type", "soc", 4, "bus-frequency", bd->bi_busfreq, 1); #ifdef CONFIG_QE - do_fixup_by_prop_u32(blob, "device_type", "qe", 4, - "bus-frequency", gd->qe_clk, 1); - do_fixup_by_prop_u32(blob, "device_type", "qe", 4, - "brg-frequency", gd->brg_clk, 1); - do_fixup_by_compat_u32(blob, "fsl,qe", - "clock-frequency", gd->qe_clk, 1); - do_fixup_by_compat_u32(blob, "fsl,qe", - "bus-frequency", gd->qe_clk, 1); - do_fixup_by_compat_u32(blob, "fsl,qe", - "brg-frequency", gd->brg_clk, 1); + ft_qe_setup(blob); #endif
#ifdef CFG_NS16550 diff --git a/cpu/mpc85xx/fdt.c b/cpu/mpc85xx/fdt.c index 0ce17e7..a6b014c 100644 --- a/cpu/mpc85xx/fdt.c +++ b/cpu/mpc85xx/fdt.c @@ -27,6 +27,8 @@ #include <libfdt.h> #include <fdt_support.h>
+extern void ft_qe_setup(void *blob); + void ft_cpu_setup(void *blob, bd_t *bd) { #if defined(CONFIG_HAS_ETH0) || defined(CONFIG_HAS_ETH1) ||\ @@ -43,11 +45,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) do_fixup_by_prop_u32(blob, "device_type", "soc", 4, "bus-frequency", bd->bi_busfreq, 1); #ifdef CONFIG_QE - do_fixup_by_prop_u32(blob, "device_type", "qe", 4, - "bus-frequency", bd->bi_busfreq, 1); - do_fixup_by_prop_u32(blob, "device_type", "qe", 4, - "brg-frequency", bd->bi_busfreq / 2, 1); - fdt_fixup_qe_firmware(blob); + ft_qe_setup(blob); #endif
#ifdef CFG_NS16550 diff --git a/drivers/qe/Makefile b/drivers/qe/Makefile index 4844181..ec5aa73 100644 --- a/drivers/qe/Makefile +++ b/drivers/qe/Makefile @@ -24,7 +24,8 @@ include $(TOPDIR)/config.mk
LIB := $(obj)qe.a
-COBJS := qe.o uccf.o uec.o uec_phy.o +COBJS-$(CONFIG_OF_LIBFDT) += fdt.o +COBJS := qe.o uccf.o uec.o uec_phy.o $(COBJS-y)
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/drivers/qe/fdt.c b/drivers/qe/fdt.c new file mode 100644 index 0000000..5307488 --- /dev/null +++ b/drivers/qe/fdt.c @@ -0,0 +1,90 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <libfdt.h> +#include <fdt_support.h> +#include "qe.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * If a QE firmware has been uploaded, then add the 'firmware' node under + * the 'qe' node. + */ +void fdt_fixup_qe_firmware(void *blob) +{ + struct qe_firmware_info *qe_fw_info; + int node, ret; + + qe_fw_info = qe_get_firmware_info(); + if (!qe_fw_info) + return; + + node = fdt_path_offset(blob, "/qe"); + if (node < 0) + return; + + /* We assume the node doesn't exist yet */ + node = fdt_add_subnode(blob, node, "firmware"); + if (node < 0) + return; + + ret = fdt_setprop(blob, node, "extended-modes", + &qe_fw_info->extended_modes, sizeof(u64)); + if (ret < 0) + goto error; + + ret = fdt_setprop_string(blob, node, "id", qe_fw_info->id); + if (ret < 0) + goto error; + + ret = fdt_setprop(blob, node, "virtual-traps", qe_fw_info->vtraps, + sizeof(qe_fw_info->vtraps)); + if (ret < 0) + goto error; + + return; + +error: + fdt_del_node(blob, node); +} + +void ft_qe_setup(void *blob) +{ +#ifdef CONFIG_QE + do_fixup_by_prop_u32(blob, "device_type", "qe", 4, + "bus-frequency", gd->qe_clk, 1); + do_fixup_by_prop_u32(blob, "device_type", "qe", 4, + "brg-frequency", gd->brg_clk, 1); + do_fixup_by_compat_u32(blob, "fsl,qe", + "clock-frequency", gd->qe_clk, 1); + do_fixup_by_compat_u32(blob, "fsl,qe", + "bus-frequency", gd->qe_clk, 1); + do_fixup_by_compat_u32(blob, "fsl,qe", + "brg-frequency", gd->brg_clk, 1); + fdt_fixup_qe_firmware(blob); +#endif +} diff --git a/drivers/qe/qe.h b/drivers/qe/qe.h index 4c96c67..741ed7f 100644 --- a/drivers/qe/qe.h +++ b/drivers/qe/qe.h @@ -289,5 +289,6 @@ int qe_set_brg(uint brg, uint rate); int qe_set_mii_clk_src(int ucc_num); int qe_upload_firmware(const struct qe_firmware *firmware); struct qe_firmware_info *qe_get_firmware_info(void); +void ft_qe_setup(void *blob);
#endif /* __QE_H__ */
Acked-by: Timur Tabi timur@freescale.com
FYI, this patch supersedes my previous patch, "83xx: add QE firmware node to device tree".
And Kumar, you should CC me on all QE patches.
Acked-by: Andy Fleming afleming@freescale.com
Acked-by: Kim Phillips kim.phillips@freescale.com
WD, please apply directly, thanks,
Kim
Applied, thanks!
In message Pine.LNX.4.64.0801170825310.10060@blarg.am.freescale.net you wrote:
Applied, thanks.
Applied, thanks.
Thanks for applying this. I have one more patch for 1.3.2 that you may have missed: "85xx, 86xx: Determine I2C clock frequencies and store in global_data". It's in Andy Fleming's tree: http://www.denx.de/cgi-bin/gitweb.cgi?p=u-boot/u-boot-mpc85xx.git
I don't have this one on my list, and I haven't seen a pull request from Andy ?
I emailed the patch to this mailing list on Jan 9, and both Jon and Andy ack'd it in replies:
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/34876 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/35917 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/35919
Andy posted a pull request on Feb 5:
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/36412/
OK, applied.
participants (5)
Andy Fleming
Kim Phillips
Kumar Gala
Timur Tabi
