[U-Boot] Rockchip patches for testing
I have pushed a branch to u-boot-rockchip/testing. Please take a look and let me know if any of these patches need rework.
Are there more patches coming for this merge window?
Re rk3399, one of the patches causes a build error on rk3399. Can someone please take a look?
buildman -b rk-push rockchip -se boards.cfg is up to date. Nothing to do. Summary of 14 commits for 10 boards (8 threads, 1 job per thread) 01: Merge git://git.denx.de/u-boot-rockchip 02: rockchip: rk3288: sdram: fix DDR address range 03: rockchip: Fix SPL console output when ROCKCHIP_SPL_BACK_TO_BROM is enabled 04: Disable SPL_MMC_SUPPORT if ROCKCHIP_SPL_BACK_TO_BROM is enabled. 05: Enable ROCKCHIP_SPL_BACK_TO_BROM for rock2 board 06: rockchip: add usb mass storage feature support for rk3036 07: rockchip: rk3399: update PPLL and pmu_pclk frequency 08: rockchip: rkpwm: fix the register sequence 09: power: regulator: add pwm regulator 10: rockchip: evb_rk3399: init vdd_center regulator 11: Kconfig: rockchip: enable DM_PWM and DM_REGULATOR 12: dts: evb-rk3399: add init voltage node for vdd-center 13: config: evb-rk3399: enable pwm regulator aarch64: + evb-rk3399 +../drivers/power/regulator/pwm_regulator.c: In function 'pwm_regulator_probe': +../drivers/power/regulator/pwm_regulator.c:135:10: error: 'struct pwm_regulator_info' has no member named 'boot_on' + if (priv->boot_on) + ^ +make[2]: *** [drivers/power/regulator/pwm_regulator.o] Error 1 +make[1]: *** [drivers/power/regulator] Error 2 +make: *** [sub-make] Error 2
Hi Simon,
I'll going to fix this with new patch set.
Thanks, - Kever
- if (priv->boot_on)
Tested on rock2-rk3288 2GB RAM: Tested-by: Sandy Patterson apatterson@sightlogix.com
Kever Yang
Sandy Patterson
