[U-Boot] Pull request, v2018.11: u-boot-spi/master
Hi Tom,
Please pull this PR for v2018.11
thanks, Jagan.
The following changes since commit 6b0afcc85092650ce386868254c4a607ca7f1a26:
common: Compile error with CONFIG_MULTI_DTB_FIT and not SPL (2018-11-09 10:44:50 -0500)
git://git.denx.de/u-boot-spi.git master
for you to fetch changes up to 596330db350d4d428256f96eee8017a5741390a6:
mtd: Drop duplicate MTD_PARTITIONS Kconfig option (2018-11-12 10:10:45 +0530)
---------------------------------------------------------------- Boris Brezillon (3): mtd: Use default mtdparts/mtids when not defined in the environment cmd: ubi: Remove useless call to mtdparts_init() mtd: Drop duplicate MTD_PARTITIONS Kconfig option
cmd/Kconfig | 5 ++-- cmd/ubi.c | 5 ---- drivers/dfu/Kconfig | 1 + drivers/mtd/Kconfig | 6 ----- drivers/mtd/mtd_uboot.c | 62 +++++++++++++++++++++++++++++++++++++++++++++++-- 5 files changed, 63 insertions(+), 16 deletions(-)
On Mon, Nov 12, 2018 at 10:19 AM Jagan Teki jagan@amarulasolutions.com wrote:
Hi Tom,
Please ignore this, will send v2 for the same.
Jagan Teki
