[PATCH v3] bootstash: Do not provide a default address for all
A valid memory location to stash bootstage information at will be architecture dependent. Move the existing defaults to the main Kconfig file for this option and set 0x0 as the default only for sandbox.
Signed-off-by: Tom Rini trini@konsulko.com Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v3: - Use stub functions to avoid unnecessary #ifdefs
Changes in v2: - Seeing that BOOTSTAGE_STASH_ADDR did not depend on BOOTSTAGE_STASH in turn lead to discovering that (minor) BOOTSTAGE_STASH_SIZE was also missing a depends on line and then that a number of places built code with BOOTSTAGE_STASH_ADDR=0x0 as a compiles-but-likely-fails option. Rework a number of spots to guard usage around BOOTSTAGE_STASH being enabled.
arch/arm/mach-rockchip/tpl.c | 6 ++---- arch/arm/mach-stm32mp/Kconfig.13x | 3 --- arch/arm/mach-stm32mp/Kconfig.15x | 3 --- arch/arm/mach-stm32mp/Kconfig.25x | 3 --- arch/x86/cpu/cpu.c | 3 +-- boot/Kconfig | 6 +++++- cmd/bootstage.c | 8 +++++++- common/board_f.c | 5 +---- common/bootstage.c | 2 ++ 9 files changed, 18 insertions(+), 21 deletions(-)
diff --git a/arch/arm/mach-rockchip/tpl.c b/arch/arm/mach-rockchip/tpl.c index 50f04f9474a..597a5caa84b 100644 --- a/arch/arm/mach-rockchip/tpl.c +++ b/arch/arm/mach-rockchip/tpl.c @@ -92,15 +92,13 @@ void board_init_f(ulong dummy) int board_return_to_bootrom(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) { -#ifdef CONFIG_BOOTSTAGE_STASH int ret;
bootstage_mark_name(BOOTSTAGE_ID_END_TPL, "end tpl"); - ret = bootstage_stash((void *)CONFIG_BOOTSTAGE_STASH_ADDR, - CONFIG_BOOTSTAGE_STASH_SIZE); + ret = bootstage_stash_default(); if (ret) debug("Failed to stash bootstage: err=%d\n", ret); -#endif + back_to_bootrom(BROM_BOOT_NEXTSTAGE);
return 0; diff --git a/arch/arm/mach-stm32mp/Kconfig.13x b/arch/arm/mach-stm32mp/Kconfig.13x index 4d74b35055b..bc8b3f8cf77 100644 --- a/arch/arm/mach-stm32mp/Kconfig.13x +++ b/arch/arm/mach-stm32mp/Kconfig.13x @@ -28,9 +28,6 @@ config PRE_CON_BUF_ADDR config PRE_CON_BUF_SZ default 4096
-config BOOTSTAGE_STASH_ADDR - default 0xC3000000 - if BOOTCOUNT_GENERIC config SYS_BOOTCOUNT_SINGLEWORD default y diff --git a/arch/arm/mach-stm32mp/Kconfig.15x b/arch/arm/mach-stm32mp/Kconfig.15x index d99aa9fd694..42da36a73e8 100644 --- a/arch/arm/mach-stm32mp/Kconfig.15x +++ b/arch/arm/mach-stm32mp/Kconfig.15x @@ -86,9 +86,6 @@ config PRE_CON_BUF_ADDR config PRE_CON_BUF_SZ default 4096
-config BOOTSTAGE_STASH_ADDR - default 0xC3000000 - if BOOTCOUNT_GENERIC config SYS_BOOTCOUNT_SINGLEWORD default y diff --git a/arch/arm/mach-stm32mp/Kconfig.25x b/arch/arm/mach-stm32mp/Kconfig.25x index 2c0f691f8b5..7d2d8171845 100644 --- a/arch/arm/mach-stm32mp/Kconfig.25x +++ b/arch/arm/mach-stm32mp/Kconfig.25x @@ -24,9 +24,6 @@ config PRE_CON_BUF_ADDR config PRE_CON_BUF_SZ default 4096
-config BOOTSTAGE_STASH_ADDR - default 0x87000000 - if DEBUG_UART
config DEBUG_UART_BOARD_INIT diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index c8433360f28..ad21fdb457a 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -75,8 +75,7 @@ int __weak x86_cleanup_before_linux(void) ret = mp_park_aps(); if (ret) return log_msg_ret("park", ret); - bootstage_stash((void *)CONFIG_BOOTSTAGE_STASH_ADDR, - CONFIG_BOOTSTAGE_STASH_SIZE); + bootstage_stash_default();
return 0; } diff --git a/boot/Kconfig b/boot/Kconfig index 95300b008c5..05993743971 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -1002,13 +1002,17 @@ config BOOTSTAGE_STASH
config BOOTSTAGE_STASH_ADDR hex "Address to stash boot timing information" - default 0x0 + depends on BOOTSTAGE_STASH + default 0xC3000000 if STM32MP13X || STM32MP15X + default 0x87000000 if STM32MP25X + default 0x0 if SANDBOX help Provide an address which will not be overwritten by the OS when it starts, so that it can read this information when ready.
config BOOTSTAGE_STASH_SIZE hex "Size of boot timing stash region" + depends on BOOTSTAGE_STASH default 0x1000 help This should be large enough to hold the bootstage stash. A value of diff --git a/cmd/bootstage.c b/cmd/bootstage.c index 5246924f39a..4ae09a6fd03 100644 --- a/cmd/bootstage.c +++ b/cmd/bootstage.c @@ -15,6 +15,7 @@ static int do_bootstage_report(struct cmd_tbl *cmdtp, int flag, int argc, return 0; }
+#if IS_ENABLED(CONFIG_BOOTSTAGE_STASH) static int get_base_size(int argc, char *const argv[], ulong *basep, ulong *sizep) { @@ -58,11 +59,14 @@ static int do_bootstage_stash(struct cmd_tbl *cmdtp, int flag, int argc,
return 0; } +#endif
static struct cmd_tbl cmd_bootstage_sub[] = { U_BOOT_CMD_MKENT(report, 2, 1, do_bootstage_report, "", ""), +#if IS_ENABLED(CONFIG_BOOTSTAGE_STASH) U_BOOT_CMD_MKENT(stash, 4, 0, do_bootstage_stash, "", ""), U_BOOT_CMD_MKENT(unstash, 4, 0, do_bootstage_stash, "", ""), +#endif };
/* @@ -91,6 +95,8 @@ U_BOOT_CMD(bootstage, 4, 1, do_boostage, "Boot stage command", " - check boot progress and timing\n" "report - Print a report\n" +#if IS_ENABLED(CONFIG_BOOTSTAGE_STASH) "stash [<start> [<size>]] - Stash data into memory\n" - "unstash [<start> [<size>]] - Unstash data from memory" + "unstash [<start> [<size>]] - Unstash data from memory\n" +#endif ); diff --git a/common/board_f.c b/common/board_f.c index 22c180b2187..29e185137ad 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -810,10 +810,7 @@ static int initf_bootstage(void) if (ret) return ret; if (from_spl) { - const void *stash = map_sysmem(CONFIG_BOOTSTAGE_STASH_ADDR, - CONFIG_BOOTSTAGE_STASH_SIZE); - - ret = bootstage_unstash(stash, CONFIG_BOOTSTAGE_STASH_SIZE); + ret = bootstage_stash_default(); if (ret && ret != -ENOENT) { debug("Failed to unstash bootstage: err=%d\n", ret); return ret; diff --git a/common/bootstage.c b/common/bootstage.c index fb6befcbc4a..5e6462cd0a3 100644 --- a/common/bootstage.c +++ b/common/bootstage.c @@ -501,6 +501,7 @@ int bootstage_unstash(const void *base, int size) return 0; }
+#if IS_ENABLED(CONFIG_BOOTSTAGE_STASH) int _bootstage_stash_default(void) { return bootstage_stash(map_sysmem(CONFIG_BOOTSTAGE_STASH_ADDR, 0), @@ -514,6 +515,7 @@ int _bootstage_unstash_default(void)
return bootstage_unstash(stash, CONFIG_BOOTSTAGE_STASH_SIZE); } +#endif
int bootstage_get_size(void) {
Changes in v3:
Ah, I see now, thanks.
