[U-Boot] [PATCH 1/1] Kconfig: net: give PHYLIB to designware driver
The designware driver has a build guard which makes it to only work when using the PHYLIB. With b68fe152272 the PHYLIB was added to the net Kconfig but not selected by all hardware depending on it.
This patch enables PHYLIB for the Designware MAC
Signed-off-by: Olliver Schinagl o.schinagl@ultimaker.com --- drivers/net/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index bbec6a6..51b1668 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -79,10 +79,10 @@ config ETH_SANDBOX_RAW
config ETH_DESIGNWARE bool "Synopsys Designware Ethernet MAC" + select PHYLIB help This MAC is present in SoCs from various vendors. It supports - 100Mbit and 1 Gbit operation. You must enable CONFIG_PHYLIB to - provide the PHY (physical media interface). + 100Mbit and 1 Gbit operation.
config PCH_GBE bool "Intel Platform Controller Hub EG20T GMAC driver"
Hi Olliver,
On Fri, Sep 18, 2015 at 11:29 PM, Olliver Schinagl oliver+list@schinagl.nl wrote:
config PCH_GBE bool "Intel Platform Controller Hub EG20T GMAC driver" --
This is not enough. You need update all borads' config.h files to remove CONFIG_PHYLIB, otherwise it causes redefinition warnings.
Regards, Bin
Hey Bin,
On 21-09-15 03:50, Bin Meng wrote:
Hi Olliver,
I was being conservative here,
Is it enough to only do the boards that are featured using Kconfig?
Regards, Bin
Hi Olliver,
On Mon, Sep 21, 2015 at 3:18 PM, Olliver Schinagl o.schinagl@ultimaker.com wrote:
Hey Bin,
Hi Olliver,
I think all boards have been converted to Kconfig, no?
Regards, Bin
-- Met vriendelijke groeten, Kind regards, 与亲切的问候
Ah, you know Chinese :-)
Olliver Schinagl Research & Development Ultimaker B.V.
Regards, Bin
Hey Bin,
On 21-09-15 09:24, Bin Meng wrote:
Hi Olliver,
Hey Bin,
Hi Olliver,
I'm not sure but will check and work this out.
Regards, Bin
Copy paste style yeah ;)
Olliver
Regards, Bin
-- Visit us at http://linux-sunxi.org
Bin Meng
Olliver Schinagl
Olliver Schinagl
