[U-Boot] [PATCH 1/5][v2] powerpc/mpc85xx:No NOR boot, do not compile IFC errata A003399
IFC errata A003399 is valid for IFC NOR boot i.e.if no on-board NOR flash or no NOR boot, do not compile its workaround.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Based upon git://git.denx.de/u-boot.git branch master Changes for v2: - Add CONFIG_A003399_NOR_WORKAROUND for errata workaround - Add CONFIG_A003399_NOR_WORKAROUND in README
README | 4 ++++ arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 9 ++++++--- arch/powerpc/cpu/mpc8xxx/fsl_ifc.c | 2 +- 3 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/README b/README index 7f2506a..c4ad69d 100644 --- a/README +++ b/README @@ -414,6 +414,10 @@ The following options need to be configured: See Freescale App Note 4493 for more information about this erratum.
+ CONFIG_A003399_NOR_WORKAROUND + Enables a workaround for IFC erratum A003399. It is only + requred during NOR boot. + CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY
This is the value to write into CCSR offset 0x18600 diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index dacfdd1..3a4bfc5 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -25,7 +25,8 @@
DECLARE_GLOBAL_DATA_PTR;
-#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) && !defined(CONFIG_SYS_RAMBOOT) +#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399)\ + && defined(CONFIG_A003399_NOR_WORKAROUND) void setup_ifc(void) { struct fsl_ifc *ifc_regs = (void *)CONFIG_SYS_IFC_ADDR; @@ -99,7 +100,8 @@ void cpu_init_early_f(void) #ifdef CONFIG_SYS_FSL_ERRATUM_P1010_A003549 ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif -#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) && !defined(CONFIG_SYS_RAMBOOT) +#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399)\ + && defined(CONFIG_A003399_NOR_WORKAROUND) ccsr_l2cache_t *l2cache = (void *)CONFIG_SYS_MPC85xx_L2_ADDR; u32 *dst, *src; void (*setup_ifc_sram)(void); @@ -138,7 +140,8 @@ void cpu_init_early_f(void) * Work Around for IFC Erratum A003399, issue will hit only when execution * from NOR Flash */ -#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) && !defined(CONFIG_SYS_RAMBOOT) +#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399)\ + && defined(CONFIG_A003399_NOR_WORKAROUND) #define SRAM_BASE_ADDR (0x00000000) /* TLB for SRAM */ mas0 = MAS0_TLBSEL(1) | MAS0_ESEL(9); diff --git a/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c b/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c index 56b319f..959a0e2 100644 --- a/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c +++ b/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c @@ -43,7 +43,7 @@ void init_early_memctl_regs(void) set_ifc_ftim(IFC_CS0, IFC_FTIM2, CONFIG_SYS_CS0_FTIM2); set_ifc_ftim(IFC_CS0, IFC_FTIM3, CONFIG_SYS_CS0_FTIM3);
-#if !defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) || defined(CONFIG_SYS_RAMBOOT) +#ifndef CONFIG_A003399_NOR_WORKAROUND #ifdef CONFIG_SYS_CSPR0_EXT set_ifc_cspr_ext(IFC_CS0, CONFIG_SYS_CSPR0_EXT); #endif
- && defined(CONFIG_A003399_NOR_WORKAROUND)
Why would CONFIG_A003399_NOR_WORKAROUND be enabled if CONFIG_SYS_FSL_ERRATUM_IFC_A003399 isn't?
-Scott
CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY This is the value to write into CCSR offset 0x18600
originally i tried the same but it did not work. As P1010RDB.h does not include config_mpc85xx.h. Only arch/powerpc/cpu/mpc85xx/*.c files includes both P1010RDB.h and config_mpc85xx.h
Regards, Prabhakar
Can you add #include <config.h> in P1010RDB.h near the top, but after the symbols that config_mpc85xx.h depends on (which I think is just CONFIG_P1010)?
-Scott
I need to add config_mpc85xx.h here.
#define CONFIG_MPC85xx #define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_SYS_HAS_SERDES /* common SERDES init code */ +#include "../../arch/powerpc/include/asm/config_mpc85xx.h"
I tried just after CONFIG_P1010 but it is giving compilation error.
Just to mention, I need to provide relative path in order to compile. I will still suggest to keep original patch, As header file location may change over period of time then config file needs to be updated again.
Regards, Prabhakar
What error?
What specifically did you try and what error did it produce?
No, this has been a repeated problem (not having access to config_mpc85xx.h in the board config file) and I'd like to see it fixed.
-Scott
What error?
make[1]: Entering directory `/home/b32579/Workspace/MERGE/OPENSRC/U-BOOT/u-boot' /opt/freescale/usr/local/gcc-4.5.55-eglibc-2.11.55/powerpc-linux-gnu/bin/powerpc-linux-gnu-gcc -DDO_DEPS_ONLY \ -g -Os -fpic -mrelocatable -ffunction-sections -fdata-sections -meabi -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x11000000 -I/home/b32579/Workspace/MERGE/OPENSRC/U-BOOT/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/freescale/usr/local/gcc-4.5.55-eglibc-2.11.55/powerpc-linux-gnu/lib/gcc/powerpc-linux-gnu/4.5.1/include -pipe -DCONFIG_PPC -D__powerpc__ -ffixed-r2 -Wa,-me500 -msoft-float -mno-string -mno-spe -Wall -Wstrict-prototypes -fno-stack-protector -Wno-format-nonliteral -Wno-format-security \ -o lib/asm-offsets.s lib/asm-offsets.c -c -S In file included from /home/b32579/Workspace/MERGE/OPENSRC/U-BOOT/u-boot/include/common.h:174:0, from lib/asm-offsets.c:18: /home/b32579/Workspace/MERGE/OPENSRC/U-BOOT/u-boot/include/asm/global_data.h:98:21: error: 'CONFIG_SYS_NUM_TLBCAMS' undeclared here (not in a function) make[1]: *** [lib/asm-offsets.s] Error 1
because of these defines in config_mpc85xx.h #if defined(CONFIG_E500MC) #define CONFIG_SYS_NUM_TLBCAMS 64 #elif defined(CONFIG_E500) #define CONFIG_SYS_NUM_TLBCAMS 16 #endif
I did not try anything. I was just doubting on having relative path. is it acceptable or not? As we are moving from dynamic header inclusions to more fixed inclusion.
oh.. I was not aware of this point.
Regards, Prabhakar
What error?
You also need CONFIG_E500 defined before you include config_mpc85xx.h -- although it might be better to define CONFIG_E500[MC] in config_mpc85xx.h based on the SoC type, and move the CONFIG_SYS_NUM_TLBCAMS setting to the bottom of the file.
If you didn't try a normal include patch and see a failure, why do you say you need to provide a relative path?
#include <asm/config_mpc85xx.h> works for me.
-Scott
Prabhakar Kushwaha
Scott Wood
