[PATCH 1/4] rockchip: rk3399-roc-pc: Hook sysreset gpio to enable full reset
The reset mechanism used by Linux to reset the SoC is known to only partially reset the logic. A mechanism is implemented in rk3399_force_power_on_reset to use a GPIO connected to the PMIC's over-temperature (OTP) reset pin, which fully resets all logic.
Hook the associated GPIO where the function expects it to enable this reset mechanism and avoid any possible side-effect of partially-reset units.
Without this patch, reading from the micro sd slot fails after a reset. With this mechanism, U-Boot is able to boot from it reliably.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/dts/rk3399-roc-pc-u-boot.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi b/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi index aecf7dbe383c..883d399a06a3 100644 --- a/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi +++ b/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi @@ -7,6 +7,10 @@ #include "rk3399-sdram-lpddr4-100.dtsi"
/ { + config { + sysreset-gpio = <&gpio1 RK_PA6 GPIO_ACTIVE_HIGH>; + }; + vcc_hub_en: vcc_hub_en-regulator { compatible = "regulator-fixed"; enable-active-high; @@ -36,6 +40,10 @@ bootph-pre-ram; };
+&gpio1 { + bootph-pre-ram; +}; + &spi1 { flash@0 { bootph-pre-ram;
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/dts/rk3399-rockpro64-u-boot.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi b/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi index 43b67991fe5a..cd84269dab48 100644 --- a/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi +++ b/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi @@ -7,6 +7,10 @@ #include "rk3399-sdram-lpddr4-100.dtsi"
/ { + config { + sysreset-gpio = <&gpio1 RK_PA6 GPIO_ACTIVE_HIGH>; + }; + smbios { compatible = "u-boot,sysinfo-smbios"; smbios { @@ -32,6 +36,10 @@ bootph-pre-ram; };
+&gpio1 { + bootph-pre-ram; +}; + &sdhci { cap-mmc-highspeed; mmc-ddr-1_8v;
Hi Paul,
- config {
We've been using this on RK3399 Puma for a while already, and a similar routing can be observed on both boards, therefore:
Reviewed-by: Quentin Schulz quentin.schulz@cherry.de
Thanks! Quentin
Hi Paul,
Since patches 3 and 4 seems to be a bit controversial, maybe send patches 1 and 2 in a different patch series so those can be merged separately?
You may want to have a look at https://lore.kernel.org/u-boot/20241105-rk3399-sysreset-gpio-tpl-v1-0-12caff... too BTW.
Cheers, Quentin
Le Tue 05 Nov 24, 16:38, Quentin Schulz a écrit :
Hi Paul,
Sounds like a good idea. I should probably wait for your series to get-in and respin a version of just the sysreset patches with the right bootph flags.
Cheers,
Paul
The boot timing and reporting (bootstage) infrastructure is useful for performance analysis and debug but adds overhead and console noise when using the device normally. Remove it from the device config.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- configs/rockpro64-rk3399_defconfig | 3 --- 1 file changed, 3 deletions(-)
diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index fc0804a0b80d..095d27ffaa04 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -19,8 +19,6 @@ CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_PCI=y CONFIG_DEBUG_UART=y -CONFIG_BOOTSTAGE=y -CONFIG_BOOTSTAGE_REPORT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rockpro64.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 @@ -38,7 +36,6 @@ CONFIG_CMD_POWEROFF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_BOOTSTAGE=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_SPI_FLASH=y
Reviewed-by: Peter Robinson pbrobinson@gmail.com
This makes sense, for those that want this information will know how to build it for testing.
diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index fc0804a0b80d..095d27ffaa04 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -19,8 +19,6 @@ CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_PCI=y CONFIG_DEBUG_UART=y -CONFIG_BOOTSTAGE=y -CONFIG_BOOTSTAGE_REPORT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rockpro64.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 @@ -38,7 +36,6 @@ CONFIG_CMD_POWEROFF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_BOOTSTAGE=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_SPI_FLASH=y -- 2.46.2
Can you just disable the report? There should be no need to disable bootstage itself.
I see bootstage as a debug/development feature, so I don't really see why it should be enabled on default builds.
Besides the console noise aspect, my intent here is also to tidy up this config.
Cheers,
Paul
Hi Paul,
Well OK.
BTW one day I'd like to see bootstage be on by default, since it provides a way to monitor boot times for devices. But that would need some improvements: the current shared-memory approach between SPL and U-Boot is not great and we could use bloblist instead. Also I'm not sure how the information could be sent to the OS.
Cheers,
Paul
-- Paul Kocialkowski,
Independent contractor - sys-base - https://www.sys-base.io/ Free software developer - https://www.paulk.fr/
Specialist in multimedia, graphics and embedded hardware support with Linux.
Printing debug details about DRAM is not useful in regular use and adds visual pollution to the log. Disable it by default.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- configs/anbernic-rgxx3-rk3566_defconfig | 1 - configs/neu2-io-rv1126_defconfig | 1 - configs/roc-pc-mezzanine-rk3399_defconfig | 1 - configs/roc-pc-rk3399_defconfig | 1 - configs/rock-pi-n10-rk3399pro_defconfig | 1 - configs/rock-pi-n8-rk3288_defconfig | 1 - configs/sonoff-ihost-rv1126_defconfig | 1 - drivers/ram/rockchip/Kconfig | 1 - 8 files changed, 8 deletions(-)
diff --git a/configs/anbernic-rgxx3-rk3566_defconfig b/configs/anbernic-rgxx3-rk3566_defconfig index a03509bf4671..5c074cffeb44 100644 --- a/configs/anbernic-rgxx3-rk3566_defconfig +++ b/configs/anbernic-rgxx3-rk3566_defconfig @@ -67,7 +67,6 @@ CONFIG_SPL_DM_REGULATOR_FIXED=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y -# CONFIG_RAM_ROCKCHIP_DEBUG is not set # CONFIG_RNG_SMCCC_TRNG is not set CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/neu2-io-rv1126_defconfig b/configs/neu2-io-rv1126_defconfig index 2a4c9b45a04f..84e4465f2c5f 100644 --- a/configs/neu2-io-rv1126_defconfig +++ b/configs/neu2-io-rv1126_defconfig @@ -45,7 +45,6 @@ CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_REGULATOR_PWM=y CONFIG_PWM_ROCKCHIP=y -# CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index a57899bfdfa0..b4041902b381 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -65,7 +65,6 @@ CONFIG_REGULATOR_PWM=y CONFIG_SPL_DM_REGULATOR_FIXED=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -# CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index b45f0e0a8994..922f67320c20 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -62,7 +62,6 @@ CONFIG_REGULATOR_PWM=y CONFIG_SPL_DM_REGULATOR_FIXED=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -# CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index ec995a54a0ee..17fe939ec989 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -51,7 +51,6 @@ CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -# CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y diff --git a/configs/rock-pi-n8-rk3288_defconfig b/configs/rock-pi-n8-rk3288_defconfig index 4c09b9137ef8..af0fa8879421 100644 --- a/configs/rock-pi-n8-rk3288_defconfig +++ b/configs/rock-pi-n8-rk3288_defconfig @@ -73,7 +73,6 @@ CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y CONFIG_RAM=y CONFIG_SPL_RAM=y -# CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y diff --git a/configs/sonoff-ihost-rv1126_defconfig b/configs/sonoff-ihost-rv1126_defconfig index 4890644c7e6f..739adb49ce93 100644 --- a/configs/sonoff-ihost-rv1126_defconfig +++ b/configs/sonoff-ihost-rv1126_defconfig @@ -46,7 +46,6 @@ CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_REGULATOR_PWM=y CONFIG_PWM_ROCKCHIP=y -# CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y diff --git a/drivers/ram/rockchip/Kconfig b/drivers/ram/rockchip/Kconfig index 67c63ecba047..e030c982eccb 100644 --- a/drivers/ram/rockchip/Kconfig +++ b/drivers/ram/rockchip/Kconfig @@ -15,7 +15,6 @@ if RAM_ROCKCHIP
config RAM_ROCKCHIP_DEBUG bool "Rockchip ram drivers debugging" - default y help This enables debugging ram driver API's for the platforms based on Rockchip SoCs.
Hello Paul,
With all the respect, I disagree with disabling this by default. This prints just a couple of lines that can actually be very helpful when figuring out what's going on in case of some DRAM-related issues on random devices in the field.
Well this rationale could apply to lots of things and we generally don't print debug info about anything else by default.
Maybe DRAM is more likely to be a source of issues than other hardware aspects that are maybe more stable, but I don't see what would prevent rebuilding a u-boot binary with debug enabled. If the DRAM config needs tweaking it will be necessary to rebuild a binary anyway.
Cheers,
Paul
I'd rather see these messages as some kind of additional verbosity, rather than some true debugging messages for the DRAM init. It's just a couple of additional lines printed on the console, in the end.
In theory, rebuilding a U-Boot image and reinstalling it is rather easy. In practice, it's hardly doable on random devices in the field, and it's sometimes virtually impossible. It's simply that not every end user is willing or capable of doing things like that.
It's mostly the fact that it's platform-specific and makes about no sense to a non-developer user that makes me think it's not welcome by default. It's really printing internal variables, not providing user-readable information that can be useful outside of the scope of development.
Well that is more or less what makes me think this is not welcome by default: a non-developer user would not be able to do anything useful with this information, since they won't be able to rebuild a binary to change the DRAM config and solve any DRAM-related issue.
Just knowing this information "on the field" won't help solve any issue if there is no possibility to undergo development and build a binary with a modified DRAM config.
In what scenario exactly do you think this would be valuable information to a non-developer?
Cheers,
Paul
Well, each and every U-Boot build is platform- and device-specific, so I see no problems with some of the messages produced by default being platform- or device-specific.
In practice, anything that U-Boot prints on the console has little to no meaning to the vast majority of people who actually happen to see and register those messages. As a result, those messages are mostly useful to the developers only.
A non-developer may be able to forward the messages to a developer, who in turn may be able to use them to roughly figure out what's going on.
I'm actually speaking from experience. Those messages have already proven to be useful in a few cases that I happened to witness.
I like the idea that U-Boot behaves more or less the same regardless of the platform and that there is some consistency in what is shown on the console. At least that's how I understand the "universal" aspect of it.
I disagree. Most of what is shown is understandable for technical users and provides informative value. I'm obviously not talking about users that are not interested in understand how their technology works here, for whom nothing shown on the console will have any value.
There is a fundamental difference between printing status information and printing debug information. I think this clearly falls under debug information (and the name of the config option agrees).
I don't see how it is useful to have a deeper understanding of some DRAM-related issue if nothing can be done about it.
I'd be curious to see cases where this information helped resolve any actual issue. Honestly I'm not very convinced and haven't changed my mind.
Of course it will be up to maintainers to decide whether this change is good or not. I can still live with the debug info on by default, I've just been annoyed by it for a while and thought most people would better like it gone.
Thanks for sharing your thoughts!
Cheers,
Paul
On 2024-09-26 20:31, Paul Kocialkowski wrote: > From: Paul Kocialkowski contact@paulk.fr > > Printing debug details about DRAM is not useful in regular use and > adds visual pollution to the log. Disable it by default.
Well, have a look at TF-A for Allwinner A64, for example, and what it ends up producing in the U-Boot console. That's highly non-universal, not just what gets printed out, but also what the TF-A for A64 ends up doing, such as setting up some voltage regulators.
The config option could be named CONFIG_RAM_ROCKCHIP_VERBOSE instead, would that change anything?
However, I don't see us agreeing on this, so I think it's best to agree to disagree and wait for additional opinions from other people.
Cheers,
Paul
> Signed-off-by: Paul Kocialkowski contact@paulk.fr > --- > configs/anbernic-rgxx3-rk3566_defconfig | 1 - > configs/neu2-io-rv1126_defconfig | 1 - > configs/roc-pc-mezzanine-rk3399_defconfig | 1 - > configs/roc-pc-rk3399_defconfig | 1 - > configs/rock-pi-n10-rk3399pro_defconfig | 1 - > configs/rock-pi-n8-rk3288_defconfig | 1 - > configs/sonoff-ihost-rv1126_defconfig | 1 - > drivers/ram/rockchip/Kconfig | 1 - > 8 files changed, 8 deletions(-) > > diff --git a/configs/anbernic-rgxx3-rk3566_defconfig > b/configs/anbernic-rgxx3-rk3566_defconfig > index a03509bf4671..5c074cffeb44 100644 > --- a/configs/anbernic-rgxx3-rk3566_defconfig > +++ b/configs/anbernic-rgxx3-rk3566_defconfig > @@ -67,7 +67,6 @@ CONFIG_SPL_DM_REGULATOR_FIXED=y > CONFIG_REGULATOR_RK8XX=y > CONFIG_PWM_ROCKCHIP=y > CONFIG_SPL_RAM=y > -# CONFIG_RAM_ROCKCHIP_DEBUG is not set > # CONFIG_RNG_SMCCC_TRNG is not set > CONFIG_BAUDRATE=1500000 > CONFIG_DEBUG_UART_SHIFT=2 > diff --git a/configs/neu2-io-rv1126_defconfig > b/configs/neu2-io-rv1126_defconfig > index 2a4c9b45a04f..84e4465f2c5f 100644 > --- a/configs/neu2-io-rv1126_defconfig > +++ b/configs/neu2-io-rv1126_defconfig > @@ -45,7 +45,6 @@ CONFIG_MMC_DW=y > CONFIG_MMC_DW_ROCKCHIP=y > CONFIG_REGULATOR_PWM=y > CONFIG_PWM_ROCKCHIP=y > -# CONFIG_RAM_ROCKCHIP_DEBUG is not set > CONFIG_BAUDRATE=1500000 > CONFIG_DEBUG_UART_SHIFT=2 > CONFIG_SYSRESET=y > diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig > b/configs/roc-pc-mezzanine-rk3399_defconfig > index a57899bfdfa0..b4041902b381 100644 > --- a/configs/roc-pc-mezzanine-rk3399_defconfig > +++ b/configs/roc-pc-mezzanine-rk3399_defconfig > @@ -65,7 +65,6 @@ CONFIG_REGULATOR_PWM=y > CONFIG_SPL_DM_REGULATOR_FIXED=y > CONFIG_REGULATOR_RK8XX=y > CONFIG_PWM_ROCKCHIP=y > -# CONFIG_RAM_ROCKCHIP_DEBUG is not set > CONFIG_RAM_ROCKCHIP_LPDDR4=y > CONFIG_BAUDRATE=1500000 > CONFIG_DEBUG_UART_SHIFT=2 > diff --git a/configs/roc-pc-rk3399_defconfig > b/configs/roc-pc-rk3399_defconfig > index b45f0e0a8994..922f67320c20 100644 > --- a/configs/roc-pc-rk3399_defconfig > +++ b/configs/roc-pc-rk3399_defconfig > @@ -62,7 +62,6 @@ CONFIG_REGULATOR_PWM=y > CONFIG_SPL_DM_REGULATOR_FIXED=y > CONFIG_REGULATOR_RK8XX=y > CONFIG_PWM_ROCKCHIP=y > -# CONFIG_RAM_ROCKCHIP_DEBUG is not set > CONFIG_RAM_ROCKCHIP_LPDDR4=y > CONFIG_BAUDRATE=1500000 > CONFIG_DEBUG_UART_SHIFT=2 > diff --git a/configs/rock-pi-n10-rk3399pro_defconfig > b/configs/rock-pi-n10-rk3399pro_defconfig > index ec995a54a0ee..17fe939ec989 100644 > --- a/configs/rock-pi-n10-rk3399pro_defconfig > +++ b/configs/rock-pi-n10-rk3399pro_defconfig > @@ -51,7 +51,6 @@ CONFIG_PHY_ROCKCHIP_TYPEC=y > CONFIG_PMIC_RK8XX=y > CONFIG_REGULATOR_RK8XX=y > CONFIG_PWM_ROCKCHIP=y > -# CONFIG_RAM_ROCKCHIP_DEBUG is not set > CONFIG_BAUDRATE=1500000 > CONFIG_DEBUG_UART_SHIFT=2 > CONFIG_SYS_NS16550_MEM32=y > diff --git a/configs/rock-pi-n8-rk3288_defconfig > b/configs/rock-pi-n8-rk3288_defconfig > index 4c09b9137ef8..af0fa8879421 100644 > --- a/configs/rock-pi-n8-rk3288_defconfig > +++ b/configs/rock-pi-n8-rk3288_defconfig > @@ -73,7 +73,6 @@ CONFIG_REGULATOR_RK8XX=y > CONFIG_PWM_ROCKCHIP=y > CONFIG_RAM=y > CONFIG_SPL_RAM=y > -# CONFIG_RAM_ROCKCHIP_DEBUG is not set > CONFIG_DEBUG_UART_SHIFT=2 > CONFIG_SYS_NS16550_MEM32=y > CONFIG_SYSRESET=y > diff --git a/configs/sonoff-ihost-rv1126_defconfig > b/configs/sonoff-ihost-rv1126_defconfig > index 4890644c7e6f..739adb49ce93 100644 > --- a/configs/sonoff-ihost-rv1126_defconfig > +++ b/configs/sonoff-ihost-rv1126_defconfig > @@ -46,7 +46,6 @@ CONFIG_MMC_DW=y > CONFIG_MMC_DW_ROCKCHIP=y > CONFIG_REGULATOR_PWM=y > CONFIG_PWM_ROCKCHIP=y > -# CONFIG_RAM_ROCKCHIP_DEBUG is not set > CONFIG_BAUDRATE=1500000 > CONFIG_DEBUG_UART_SHIFT=2 > CONFIG_SYSRESET=y > diff --git a/drivers/ram/rockchip/Kconfig b/drivers/ram/rockchip/Kconfig > index 67c63ecba047..e030c982eccb 100644 > --- a/drivers/ram/rockchip/Kconfig > +++ b/drivers/ram/rockchip/Kconfig > @@ -15,7 +15,6 @@ if RAM_ROCKCHIP > > config RAM_ROCKCHIP_DEBUG > bool "Rockchip ram drivers debugging" > - default y > help > This enables debugging ram driver API's for the platforms > based on Rockchip SoCs.
Hi Paul,
I'm not entirely sure on whose side the issue is, but I didn't receive your mails, either from the U-Boot mailing list or directly from the Cc field. I however could find the patch on lore.kernel.org... and I also received yours and Dragan's exchange on patch 4 (but not the patch itself). Any chance you received something from my mail server? Does anyone in Cc of this mail actually received the mail?
- config {
I think this is the wrong pin to use.
The routing of GPIO1_A6 is similar on RK3399 Puma and Pine64 RockPro64, but it differs massively for the Firefly Roc PC.
However, a similar routing is done for GPIO1_A5 on the Firefly, I believe that one is more appropriate. What do you think?
Cheers, Quentin
Hi Quentin,
Thanks for looking into this!
No automatic reply from your mail server and the logs look good on my side, with a 250 result on all sent patches. Strange indeed...
diff --git a/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi b/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi index aecf7dbe383c..883d399a06a3 100644 --- a/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi +++ b/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi @@ -7,6 +7,10 @@ #include "rk3399-sdram-lpddr4-100.dtsi" / {
- config {
I just double-checked the schematics (ROC_3399_PC), looking at signal OTP_OUT_H which is definitely connected to GPIO1_A6 (P26).
Also it clearly resets the board when toggled and solves the MMC reset issue I was having on this exact board, so I'm rather confident that it's the right one to use :)
Cheers,
Paul
Hi Paul,
On 9/27/24 11:53 AM, Paul Kocialkowski wrote:
Hi Quentin,
- config {
At least we're on the same page for using OTP_OUT_H, but it's routed to GPIO1_A5 on the schematics I found:
https://www.t-firefly.com/download/Firefly-RK3399/hardware/Firefly-RK3399_V1...
Mmmmmm seems like I was looking at the wrong schematics? https://en.t-firefly.com/doc/download/page/id/51.html does route GPIO1_A6 to the OTP_OUT_H signal.. https://en.t-firefly.com/doc/download/page/id/78.html https://en.t-firefly.com/doc/download/page/id/127.html
So, the Roc PC, Roc PC Plus and Roc PC Pro all seem to have a similar routing for this pin, therefore:
Thanks! Quentin
- config {
Ah yes I think the Firefly-RK3399 and ROC-RK3399-PC are two distinct designs.
Right, and for the record the version I have is the ROC-RK3399-PC Plus.
Thanks!
participants (5)
Dragan Simic
Paul Kocialkowski
Peter Robinson
Quentin Schulz
