[U-Boot] [PATCH] doc/mkimage.1: Fix some typos
Signed-off-by: Horst Kronstorfer hkronsto@frequentis.com --- doc/mkimage.1 | 12 ++++++------ 1 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/doc/mkimage.1 b/doc/mkimage.1 index f27da6b..800aed4 100644 --- a/doc/mkimage.1 +++ b/doc/mkimage.1 @@ -9,13 +9,13 @@ mkimage - Generate image for U-Boot The .B mkimage command is used to create images for use with the U-Boot boot loader. -Thes eimages can contain the linux kernel, device tree blob, root file +These images can contain the linux kernel, device tree blob, root file system image, firmware images etc., either separate or combined.
.B mkimage supports two different formats:
-The old, +The old .I legacy image format concatenates the individual parts (for example, kernel image, device tree blob and ramdisk image) and adds a 64 bytes header @@ -23,9 +23,9 @@ containing information about target architecture, operating system, image type, compression method, entry points, time stamp, checksums, etc.
-The new, +The new .I FIT (Flattened Image Tree) format -allows for more flexibility in handling images of various and also +allows for more flexibility in handling images of various types and also enhances integrity protection of images with stronger checksums.
.SH "OPTIONS" @@ -88,10 +88,10 @@ create the image.
.TP .BI "-f "fit-image.its" -Image tree source fine that descbres the structure and contents of the +Image tree source file that describes the structure and contents of the FIT image.
-.SH EXMAPLES +.SH EXAMPLES
List image information: .nf
Dear Horst Kronstorfer,
In message 1324477883-26678-1-git-send-email-hkronsto@frequentis.com you wrote:
Applied, thanks.
Horst Kronstorfer
Mike Frysinger
