[PATCH] checkpatch: fix a false check against wchar/utf-16 string
UEFI subsystem uses utf-16 string, but checkpatch.pl complains about any occurrences of L"xxx" which is definitely legal. So just suppress this kind of warning. Precautiously, we will check u"xxx" as well.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- scripts/checkpatch.pl | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/scripts/checkpatch.pl b/scripts/checkpatch.pl index edba36565167..b3697720787c 100755 --- a/scripts/checkpatch.pl +++ b/scripts/checkpatch.pl @@ -5462,7 +5462,7 @@ sub process { }
# concatenated string without spaces between elements - if ($line =~ /$String[A-Za-z0-9_]/ || $line =~ /[A-Za-z0-9_]$String/) { + if ($line =~ /$String[A-Za-z0-9_]/ || $line =~ /([A-Za-z0-9_]+[Lu]|[A-Za-z0-9_]*[A-KM-Za-tv-z0-9_])$String/) { if (CHK("CONCATENATED_STRING", "Concatenated strings should use spaces between elements\n" . $herecurr) && $fix) {
This looks like a generic checkpatch issue. I think we're a little out of sync with the kernel's v5.7 but this doesn't look to be fixed there either. Can you please submit it upstream? Thanks!
Hello Tom,
I already raised that issue to the Kernel people and they were not interested in fixing it:
https://lkml.org/lkml/2017/10/17/1086
Recently a lot of changes have been done to the U-Boot version of checkpatch.pl.
Do we want to diverge from the upstream and have a lot of work each time we try to sync? Or should we use checkpatch.pl as is and live without U-Boot specific stuff?
Best regards
Heinrich
Hello Tom,
I would raise the issue with Joe again to see if he still doesn't want to support wide strings. If he doesn't I worry that since this change is outside of the new u-boot function it will get removed by accident with a future resync.
Hello Tom,
To be strict, Joe's comment, "Kernel doesn't support wide strings." is no longer true. We can see several examples of L"..." in security/integrity/platform_certs/load_uefi.c
-Takahiro Akashi
-- Tom
Am 3. Juli 2020 07:45:03 MESZ schrieb AKASHI Takahiro takahiro.akashi@linaro.org:
. $herecurr) &&
$fix) {
little out
there
Hello Tom,
time
without
want
change
That makes things easier. Please, check if the upstream checkpatch.pl still has the issue. If yes, please, send your pstch upstream.
Best regards
Heinrich
-Takahiro Akashi
-- Tom
AKASHI Takahiro
