Hi Tom,
I have a series which changes sandbox over to use the newer SDL2. At present I cannot make it pass on gitlab since it seems to have SDL1.2 (only).
Is it possible to change that?
On Sun, Jan 12, 2020 at 09:01:18PM +1300, Simon Glass wrote:
Hi Tom,
Yes, change https://gitlab.denx.de/u-boot/gitlab-ci-runner/blob/master/Dockerfile#L35 and also https://gitlab.denx.de/u-boot/u-boot/blob/master/.travis.yml#L22 at the same time. Testing will be a little hard as you'll need to change your local .gitlab/.azure files to use your docker image to confirm the changes.
Hi Tom,
Hi Tom,
OK thanks It's just a case of adding libsdl2-dev to the list. I put the travis change in the series already.
I created a commit. But how do I submit a change to the gitlib-ci-runner project? I don't seem to be able to fork it or push to it, but I see others have made changes.
On Sun, Feb 02, 2020 at 09:14:56AM -0700, Simon Glass wrote:
Hi Tom,
Hi Tom,
Post to the regular ML, prefix it so it's clear that it's for the gitlab file and I'll pick it up and sync things up.
Hi Tom,
Hi Tom,
Hi Tom,
OK thanks, done.
