[U-Boot] [PATCH] dwc_ahsata.c: Add weak disable_sata_clock
Signed-off-by: Tom Rini trini@ti.com --- drivers/block/dwc_ahsata.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/block/dwc_ahsata.c b/drivers/block/dwc_ahsata.c index 9a2b547..e9d4283 100644 --- a/drivers/block/dwc_ahsata.c +++ b/drivers/block/dwc_ahsata.c @@ -16,6 +16,7 @@ #include <asm/errno.h> #include <asm/io.h> #include <linux/bitops.h> +#include <linux/compiler.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> #include "dwc_ahsata.h" @@ -592,6 +593,10 @@ int init_sata(int dev) return 0; }
+__weak void disable_sata_clock(void) +{ +} + int reset_sata(int dev) { struct ahci_probe_ent *probe_ent =
On 11/25/14 23:34, Soeren Moch wrote:
Signed-off-by: Tom Rini <trini at ti.com http://lists.denx.de/mailman/listinfo/u-boot>
Tom, Nikita,
instead of adding a weak function for architectures without 'disable_sata_clock', should we remove this call from reset_sata entirely?
'reset_sata' is called repeatedly for several devices, but 'disable_sata_clock' has no such device parameter. Which clock should be disabled here? Makes not much sense for me.
BTW, there is an additional problem with 'reset_sata'. If sata support is configured into u-boot, but nobody has called 'sata init' before booting the kernel, I see a data abort exception on bootm. Tested on TBS2910 board (i.MX6Q-based).
Regards, Soeren
Forgot to add the u-boot list, sorry. Please ignore the previous email with wrong sender address.
Tom, Nikita,
I'm fine with reverting the original patch too, which sounds like the best case here.
Signed-off-by: Tom Rini <trini at ti.com http://lists.denx.de/mailman/listinfo/u-boot> --- drivers/block/dwc_ahsata.c | 5 +++++ 1 file changed, 5 insertions(+)
Tom, Nikita,
The original patch is part of a series which as a whole makes sense, I think. Tomorrow I can provide a patch to fix this behavior - it is not so easy to test patches currently, as u-boot-2015.01-rc2 is broken on armhf.
Soeren
- fix crash when sata device is not initialized - remove disable_sata_clock() since it is not clear which clock for which device should be disabled here - call disable_sata_clock() for mx6 in preboot_os instead
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Tom Rini trini@ti.com Cc: Nikita Kiryanov nikita@compulab.co.il Cc: Simon Glass sjg@chromium.org Cc: guillaume.gardet@free.fr Cc: Stefano Babic sbabic@denx.de --- arch/arm/imx-common/cpu.c | 3 +++ drivers/block/dwc_ahsata.c | 14 ++++++++------ 2 files changed, 11 insertions(+), 6 deletions(-)
diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index b58df7d..28ccd29 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -206,6 +206,9 @@ void arch_preboot_os(void) { #if defined(CONFIG_CMD_SATA) sata_stop(); +#if defined(CONFIG_MX6) + disable_sata_clock(); +#endif #endif #if defined(CONFIG_VIDEO_IPUV3) /* disable video before launching O/S */ diff --git a/drivers/block/dwc_ahsata.c b/drivers/block/dwc_ahsata.c index 9a2b547..9e925d1 100644 --- a/drivers/block/dwc_ahsata.c +++ b/drivers/block/dwc_ahsata.c @@ -594,22 +594,24 @@ int init_sata(int dev)
int reset_sata(int dev) { - struct ahci_probe_ent *probe_ent = - (struct ahci_probe_ent *)sata_dev_desc[dev].priv; - struct sata_host_regs *host_mmio = - (struct sata_host_regs *)probe_ent->mmio_base; + struct ahci_probe_ent *probe_ent; + struct sata_host_regs *host_mmio;
if (dev < 0 || dev > (CONFIG_SYS_SATA_MAX_DEVICE - 1)) { printf("The sata index %d is out of ranges\n\r", dev); return -1; }
+ probe_ent = (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + if (NULL == probe_ent) + /* not initialized, so nothing to reset */ + return 0; + + host_mmio = probe_ent->mmio_base; setbits_le32(&host_mmio->ghc, SATA_HOST_GHC_HR); while (readl(&host_mmio->ghc) & SATA_HOST_GHC_HR) udelay(100);
- disable_sata_clock(); - return 0; }
Hi Soeren,
I think a more proper way to do this might be to mirror the init sequence completely. The simplest init sequence calls setup_sata() somewhere before sata_initialize() is invoked, and the distribution of labor is: - arch/arm/imx-common/sata.c:setup_sata() Turns on clocks - common/cmd_sata.c: sata_initialize() Calls driver init
The inverse would be: - common/cmd_sata.c: sata_stop() Calls driver reset - arch/arm/imx-common/sata.c:disable_sata() Turns off clocks
Thus disable_sata() would need to be defined in arch/arm/imx-common/sata.c; it will call disable_sata_clock(), and be used in cm_fx6's version of stop_sata().
It's a little convoluted, but consistent with the existing code flow, and it also fixes the MX53 problems because arch/arm/imx-common/sata.c is not compiled for this platform.
The lack of casting generates a warning during compilation: drivers/block/dwc_ahsata.c:610:12: warning: assignment makes pointer from integer without a cast [enabled by default] host_mmio = probe_ent->mmio_base; ^
- return 0; }
On 26.11.2014 18:38, Nikita Kiryanov wrote:
Hi Soeren,
Nikita,
if I remember correctly, the whole purpose of this patch series was to get a SSD running, which was not recognized by linux if sata is enabled on boot. So for me disabling the sata link in u-boot makes perfectly sense to overcome this issue. But I cannot imagine that disabling the clock of the sata controller makes any difference here. But I did not test this (I have no access to such problematic SSD). I would prefer to keep the code simple and easy to maintain, I don't see any advantage in mirroring the init sequence on exit. I would not switch off the sata controller clock. I'm even not sure that my patch would work for i.MX6SX, if I further think about it. It is already not easy to understand all implications. But this is only my personal opinion, I'm not the maintainer of this code. My only goal with this patch was to get sata running again, for boards which enable sata (call setup_sata() in board_init() ), but do not run 'sata init' in the bootcmd by default - and for other architectures than mx6.
So how to proceed is a question for the maintainers now, I think. I see following opportunities: - implement the clock disabling framework as Nikita has described above - try to get my patch working with minimal changes of the merged code (as we are in -rc2 phase of development), and possibly apply additional patches from Nikita on this later - revert the whole patch series
Of course you are right here, I accidentally removed the type cast. If we decide to go on with this patch, I will fix this in a new patch version.
Soeren
}return 0;
Hi Soeren,
No need to worry about it: there is no sata on solox ;-)
Hi Fabio,
On 27.11.2014 02:12, Fabio Estevam wrote:
Hi Soeren,
Of course, but does the code compile for it? OK, probably yes, because nobody would define CMD_SATA for such board.
Even better if you think the patch will work for all mx6 variants. Maybe I should send a second version of the patch with fixed typecast.
Soeren
Hi Soeren,
Nikita,
Well, mostly I just wanted to put this idea up for discussion. I'm fine with first applying your fix and later making these changes, or even not making them at all if people think that being consistent with the init sequence is not worth it.
Signed-off-by: Soeren Moch smoch@web.de --- Changes in v2: - fix type cast warning
Cc: Tom Rini trini@ti.com Cc: Nikita Kiryanov nikita@compulab.co.il Cc: Simon Glass sjg@chromium.org Cc: guillaume.gardet@free.fr Cc: Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/imx-common/cpu.c | 3 +++ drivers/block/dwc_ahsata.c | 14 ++++++++------ 2 files changed, 11 insertions(+), 6 deletions(-)
diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index b58df7d..28ccd29 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -206,6 +206,9 @@ void arch_preboot_os(void) { #if defined(CONFIG_CMD_SATA) sata_stop(); +#if defined(CONFIG_MX6) + disable_sata_clock(); +#endif #endif #if defined(CONFIG_VIDEO_IPUV3) /* disable video before launching O/S */ diff --git a/drivers/block/dwc_ahsata.c b/drivers/block/dwc_ahsata.c index 9a2b547..01a4148 100644 --- a/drivers/block/dwc_ahsata.c +++ b/drivers/block/dwc_ahsata.c @@ -594,22 +594,24 @@ int init_sata(int dev)
+ probe_ent = (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + if (NULL == probe_ent) + /* not initialized, so nothing to reset */ + return 0; + + host_mmio = (struct sata_host_regs *)probe_ent->mmio_base; setbits_le32(&host_mmio->ghc, SATA_HOST_GHC_HR); while (readl(&host_mmio->ghc) & SATA_HOST_GHC_HR) udelay(100);
Hi Soeren,
Changes in v2:
- return 0; }
Acked-by: Nikita Kiryanov nikita@compulab.co.il Tested-by: Nikita Kiryanov nikita@compulab.co.il
Changes in v2:
Best regards, Stefano Babic
participants (5)
Fabio Estevam
Nikita Kiryanov
Soeren Moch
Stefano Babic
