[PATCH 1/3] spl: fit: Discard decompression if not supported
And simplify further decompression testing.
Signed-off-by: Loic Poulain loic.poulain@linaro.org --- common/spl/spl_fit.c | 27 +++++++++++++++++++++------ 1 file changed, 21 insertions(+), 6 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 70d8d5942d..1d42cb1d10 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -208,6 +208,20 @@ static int get_aligned_image_size(struct spl_load_info *info, int data_size, return (data_size + info->bl_len - 1) / info->bl_len; }
+static inline bool spl_fit_decompression_supported(uint8_t comp) +{ + switch (comp) { + case IH_COMP_GZIP: + return IS_ENABLED(CONFIG_SPL_GZIP); + case IH_COMP_LZMA: + return IS_ENABLED(CONFIG_SPL_LZMA); + case IH_COMP_NONE: + return true; + } + + return false; +} + /** * load_simple_fit(): load the image described in a certain FIT node * @info: points to information about the device to load data from @@ -235,7 +249,7 @@ static int load_simple_fit(struct spl_load_info *info, ulong sector, void *src; ulong overhead; int nr_sectors; - uint8_t image_comp = -1, type = -1; + uint8_t image_comp, type = -1; const void *data; const void *fit = ctx->fit; bool external_data = false; @@ -248,9 +262,11 @@ static int load_simple_fit(struct spl_load_info *info, ulong sector, debug("%s ", genimg_get_type_name(type)); }
- if (spl_decompression_enabled()) { - fit_image_get_comp(fit, node, &image_comp); - debug("%s ", genimg_get_comp_name(image_comp)); + fit_image_get_comp(fit, node, &image_comp); + if (!spl_fit_decompression_supported(image_comp)) { + debug("Discard unsupported compression %s ", + genimg_get_comp_name(image_comp)); + image_comp = IH_COMP_NONE; }
if (fit_image_get_load(fit, node, &load_addr)) { @@ -283,8 +299,7 @@ static int load_simple_fit(struct spl_load_info *info, ulong sector, return 0; }
- if (spl_decompression_enabled() && - (image_comp == IH_COMP_GZIP || image_comp == IH_COMP_LZMA)) + if (image_comp != IH_COMP_NONE) src_ptr = map_sysmem(ALIGN(CONFIG_SYS_LOAD_ADDR, ARCH_DMA_MINALIGN), len); else src_ptr = map_sysmem(ALIGN(load_addr, ARCH_DMA_MINALIGN), len);
Signed-off-by: Loic Poulain loic.poulain@linaro.org --- common/spl/spl_fit.c | 10 ++++++++++ include/spl.h | 4 +++- 2 files changed, 13 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 1d42cb1d10..08428660b0 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -18,6 +18,7 @@ #include <asm/global_data.h> #include <asm/io.h> #include <linux/libfdt.h> +#include <linux/lzo.h> #include <linux/printk.h>
DECLARE_GLOBAL_DATA_PTR; @@ -215,6 +216,8 @@ static inline bool spl_fit_decompression_supported(uint8_t comp) return IS_ENABLED(CONFIG_SPL_GZIP); case IH_COMP_LZMA: return IS_ENABLED(CONFIG_SPL_LZMA); + case IH_COMP_LZO: + return IS_ENABLED(CONFIG_SPL_LZO); case IH_COMP_NONE: return true; } @@ -357,6 +360,13 @@ static int load_simple_fit(struct spl_load_info *info, ulong sector, return -EIO; } length = loadEnd - CONFIG_SYS_LOAD_ADDR; + } else if (IS_ENABLED(CONFIG_SPL_LZO) && image_comp == IH_COMP_LZO) { + size = CONFIG_SYS_BOOTM_LEN; + if (lzop_decompress(src, length, load_ptr, &size)) { + puts("Uncompressing error\n"); + return -EIO; + } + length = size; } else { memcpy(load_ptr, src, length); } diff --git a/include/spl.h b/include/spl.h index 8ff20adc28..e07092372a 100644 --- a/include/spl.h +++ b/include/spl.h @@ -1016,6 +1016,8 @@ int spl_load_fit_image(struct spl_image_info *spl_image, */ static inline bool spl_decompression_enabled(void) { - return IS_ENABLED(CONFIG_SPL_GZIP) || IS_ENABLED(CONFIG_SPL_LZMA); + return IS_ENABLED(CONFIG_SPL_GZIP) || IS_ENABLED(CONFIG_SPL_LZMA) || + IS_ENABLED(CONFIG_SPL_LZO); } + #endif
Please add an appropriate commit message.
- case IH_COMP_LZO:
case IH_COMP_NONE: return true; }return IS_ENABLED(CONFIG_SPL_LZO);
- } else if (IS_ENABLED(CONFIG_SPL_LZO) && image_comp == IH_COMP_LZO) {
return -EIO;
} else { memcpy(load_ptr, src, length); }length = size;
- return IS_ENABLED(CONFIG_SPL_GZIP) || IS_ENABLED(CONFIG_SPL_LZMA) ||
}IS_ENABLED(CONFIG_SPL_LZO);
- #endif
Please also add a decompression test. I think spl_test_image should be extended to test all decompression types (see do_spl_test_load for inspiration). do_spl_test_load should also be extended to test LZMA FITs.
--Sean
CONFIG_SYS_LOAD_ADDR is usually configured as the address where the kernel should be loaded at. It can be problematic to use it as a generic temporary buffer for FIT compressed blobs.
An example is when the image is a compressed kernel with load address equal to CONFIG_SYS_LOAD_ADDR, this causes (inplace) decompression to fail.
Instead we can simply allocate a temporary buffer in the heap
Signed-off-by: Loic Poulain loic.poulain@linaro.org --- common/spl/spl_fit.c | 16 ++++++++++------ 1 file changed, 10 insertions(+), 6 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 08428660b0..8a807db5ba 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -249,7 +249,7 @@ static int load_simple_fit(struct spl_load_info *info, ulong sector, ulong size; ulong load_addr; void *load_ptr; - void *src; + void *src, *src_ptr; ulong overhead; int nr_sectors; uint8_t image_comp, type = -1; @@ -289,8 +289,6 @@ static int load_simple_fit(struct spl_load_info *info, ulong sector, }
if (external_data) { - void *src_ptr; - /* External data */ if (fit_image_get_data_size(fit, node, &len)) return -ENOENT; @@ -302,10 +300,13 @@ static int load_simple_fit(struct spl_load_info *info, ulong sector, return 0; }
- if (image_comp != IH_COMP_NONE) - src_ptr = map_sysmem(ALIGN(CONFIG_SYS_LOAD_ADDR, ARCH_DMA_MINALIGN), len); - else + if (image_comp != IH_COMP_NONE) { + src_ptr = malloc_cache_aligned(len + 2 * info->bl_len); + if (!src_ptr) + return -ENOMEM; + } else { src_ptr = map_sysmem(ALIGN(load_addr, ARCH_DMA_MINALIGN), len); + } length = len;
overhead = get_aligned_image_overhead(info, offset); @@ -383,6 +384,9 @@ static int load_simple_fit(struct spl_load_info *info, ulong sector, image_info->entry_point = FDT_ERROR; }
+ if (external_data && image_comp != IH_COMP_NONE) + free(src_ptr); + return 0; }
- void *src;
- void *src, *src_ptr; ulong overhead; int nr_sectors; uint8_t image_comp, type = -1;
void *src_ptr;
else
if (!src_ptr)
return -ENOMEM;
length = len;
- if (external_data && image_comp != IH_COMP_NONE)
free(src_ptr);
- return 0; }
Why not use spl_simple_fit_read?
--Sean
- switch (comp) {
- case IH_COMP_GZIP:
- case IH_COMP_LZMA:
- case IH_COMP_NONE:
return true;
- return false;
- load_simple_fit(): load the image described in a certain FIT node
- @info: points to information about the device to load data from
- uint8_t image_comp, type = -1; const void *data; const void *fit = ctx->fit; bool external_data = false;
else src_ptr = map_sysmem(ALIGN(load_addr, ARCH_DMA_MINALIGN), len);if (image_comp != IH_COMP_NONE) src_ptr = map_sysmem(ALIGN(CONFIG_SYS_LOAD_ADDR, ARCH_DMA_MINALIGN), len);
Why doesn't spl_decompression_enabled work here?
--Sean
Loic Poulain
Sean Anderson
