[U-Boot-Users] [MIPS] cpu/mips/cache.S: Introduce NESTED(), LEAF() and END()
These macros have been widely used by MIPS assemblers, and of course make codes more readable and easily maintainable.
Signed-off-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp ---
cpu/mips/cache.S | 25 +++++++------------------ 1 files changed, 7 insertions(+), 18 deletions(-)
diff --git a/cpu/mips/cache.S b/cpu/mips/cache.S index 9d793bf..66fe47a 100644 --- a/cpu/mips/cache.S +++ b/cpu/mips/cache.S @@ -24,6 +24,7 @@
#include <config.h> #include <version.h> +#include <asm/asm.h> #include <asm/regdef.h> #include <asm/mipsregs.h> #include <asm/addrspace.h> @@ -119,10 +120,7 @@ * RETURNS: N/A * */ - .globl mips_cache_reset - .ent mips_cache_reset -mips_cache_reset: - +NESTED(mips_cache_reset, 0, ra) li t2, CFG_ICACHE_SIZE li t3, CFG_DCACHE_SIZE li t4, CFG_CACHELINE_SIZE @@ -198,8 +196,7 @@ mips_cache_reset: icacheop(a0,a1,a2,a3,Index_Store_Tag_D)
j ra - - .end mips_cache_reset + END(mips_cache_reset)
/******************************************************************************* * @@ -208,15 +205,11 @@ mips_cache_reset: * RETURNS: 0 - cache disabled; 1 - cache enabled * */ - .globl dcache_status - .ent dcache_status -dcache_status: - +LEAF(dcache_status) mfc0 v0, CP0_CONFIG andi v0, v0, 1 j ra - - .end dcache_status + END(dcache_status)
/******************************************************************************* * @@ -225,15 +218,11 @@ dcache_status: * RETURNS: N/A * */ - .globl dcache_disable - .ent dcache_disable -dcache_disable: - +LEAF(dcache_disable) mfc0 t0, CP0_CONFIG li t1, -8 and t0, t0, t1 ori t0, t0, CONF_CM_UNCACHED mtc0 t0, CP0_CONFIG j ra - - .end dcache_disable + END(dcache_disable)
I have to admit that for me the resulting code is NOT better readable. Indead of just reading a single source file, I now have to look up a header file for a number of macros.
Speaking for myself, I don't see an improvement.
You need to look up a header file, true. But these macros are worth doing so.
as can be seen from macro definitions, they specify some more information ecplicitly; alignment, type of symbols, stack frame info which helps generating debug info.
These macros or their variants have been used in SGI or Algorithmics early MIPS programming, PMON, YAMON and of course Linux. They are good helper for MIPS assemblers, so I hope get them in.
Shinya
Shinya Kuribayashi
