[U-Boot] [PULL] u-boot-atmel/master -> u-boot/master
The following changes since commit 8d77576371381ade83de475bb639949b44941e8c:
ARM: davinci: remove support for cam_enc_4xx (2015-08-20 12:55:50 -0400)
git://git.denx.de/u-boot-atmel.git master
for you to fetch changes up to 6e119bc25a27700b71a6340f9c7cd5382d9c6649:
ARM: at91: sama5: update the spi flash mapping (2015-08-21 15:15:28 +0200)
---------------------------------------------------------------- Erik van Luijk (4): arm: at91: mpddr: allow multiple DDR controllers arm: at91: at91sam9m10g45ek/corvus remove useless chip select 1 init arm: at91: pmc: replace the constant with a define in at91_pmc.h arm: at91: add support for mini-box picosam9g45 board
Heiko Schocher (2): arm, at91: add axm extensions taurus: board updates
Wu, Josh (4): ARM: at91: sama5: move the sd/mmc env config to at91-sama5_common.h ARM: at91: sama5d3xek: use a $dtb_name to load dtb ARM: at91: sama5: move the nandflash env config to at91-sama5_common.h ARM: at91: sama5: update the spi flash mapping
arch/arm/include/asm/mach-types.h | 1 + arch/arm/mach-at91/Kconfig | 6 + arch/arm/mach-at91/include/mach/at91_pmc.h | 1 + arch/arm/mach-at91/include/mach/atmel_mpddrc.h | 6 +- arch/arm/mach-at91/mpddrc.c | 41 +-- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 12 +- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 4 +- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 4 +- board/atmel/sama5d3_xplained/sama5d3_xplained.c | 4 +- board/atmel/sama5d3xek/sama5d3xek.c | 24 +- board/atmel/sama5d4_xplained/sama5d4_xplained.c | 4 +- board/atmel/sama5d4ek/sama5d4ek.c | 4 +- board/mini-box/picosam9g45/Kconfig | 12 + board/mini-box/picosam9g45/MAINTAINERS | 6 + board/mini-box/picosam9g45/Makefile | 19 ++ board/mini-box/picosam9g45/led.c | 25 ++ board/mini-box/picosam9g45/picosam9g45.c | 354 ++++++++++++++++++++++++ board/siemens/corvus/board.c | 12 +- board/siemens/taurus/taurus.c | 202 ++++++++++++-- configs/picosam9g45_defconfig | 12 + include/configs/at91-sama5_common.h | 37 +++ include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 2 - include/configs/at91sam9x5ek.h | 2 - include/configs/corvus.h | 2 - include/configs/picosam9g45.h | 211 ++++++++++++++ include/configs/sama5d3_xplained.h | 19 +- include/configs/sama5d3xek.h | 33 +-- include/configs/sama5d4_xplained.h | 41 +-- include/configs/sama5d4ek.h | 39 +-- include/configs/taurus.h | 79 +++++- 31 files changed, 1019 insertions(+), 200 deletions(-) create mode 100644 board/mini-box/picosam9g45/Kconfig create mode 100644 board/mini-box/picosam9g45/MAINTAINERS create mode 100644 board/mini-box/picosam9g45/Makefile create mode 100644 board/mini-box/picosam9g45/led.c create mode 100644 board/mini-box/picosam9g45/picosam9g45.c create mode 100644 configs/picosam9g45_defconfig create mode 100644 include/configs/picosam9g45.h
Sorry Tom,
there slipped one wrong commit in. Please forget this PR!
Andreas
Hi Tom,
this is the corrected PR.
Andreas
for you to fetch changes up to 7a53b9544e388ac80bff2a3912865df029de27d0:
ARM: at91: sama5: update the spi flash mapping (2015-08-21 15:47:05 +0200)
arch/arm/include/asm/mach-types.h | 1 + arch/arm/mach-at91/Kconfig | 6 + arch/arm/mach-at91/include/mach/at91_pmc.h | 1 + arch/arm/mach-at91/include/mach/atmel_mpddrc.h | 6 +- arch/arm/mach-at91/mpddrc.c | 41 +-- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 12 +- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 4 +- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 4 +- board/atmel/sama5d3_xplained/sama5d3_xplained.c | 4 +- board/atmel/sama5d3xek/sama5d3xek.c | 24 +- board/atmel/sama5d4_xplained/sama5d4_xplained.c | 4 +- board/atmel/sama5d4ek/sama5d4ek.c | 4 +- board/mini-box/picosam9g45/Kconfig | 12 + board/mini-box/picosam9g45/MAINTAINERS | 6 + board/mini-box/picosam9g45/Makefile | 19 ++ board/mini-box/picosam9g45/led.c | 25 ++ board/mini-box/picosam9g45/picosam9g45.c | 354 ++++++++++++++++++++++++ board/siemens/corvus/board.c | 12 +- configs/picosam9g45_defconfig | 12 + include/configs/at91-sama5_common.h | 37 +++ include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 2 - include/configs/at91sam9x5ek.h | 2 - include/configs/corvus.h | 2 - include/configs/picosam9g45.h | 211 ++++++++++++++ include/configs/sama5d3_xplained.h | 19 +- include/configs/sama5d3xek.h | 33 +-- include/configs/sama5d4_xplained.h | 41 +-- include/configs/sama5d4ek.h | 39 +-- 29 files changed, 763 insertions(+), 175 deletions(-) create mode 100644 board/mini-box/picosam9g45/Kconfig create mode 100644 board/mini-box/picosam9g45/MAINTAINERS create mode 100644 board/mini-box/picosam9g45/Makefile create mode 100644 board/mini-box/picosam9g45/led.c create mode 100644 board/mini-box/picosam9g45/picosam9g45.c create mode 100644 configs/picosam9g45_defconfig create mode 100644 include/configs/picosam9g45.h
On Fri, Aug 21, 2015 at 03:51:05PM +0200, Andreas Bießmann wrote:
Hi Tom,
Andreas
Andreas Bießmann
