[PATCH 1/1] phy: marvell: cp110: Support SATA invert polarity
In commit b24bb99d cp110 configuration initially done in u-boot was removed and delegated to atf firmware as smc call. That commit didn't account for later introduced in d13b740c SATA invert polarity support.
This patch adds support of passing SATA invert polarity flags to atf firmware during the smc call.
Signed-off-by: Denis Odintsov shiva@mail.ru Cc: Baruch Siach baruch@tkos.co.il Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Stefan Roese sr@denx.de --- drivers/phy/marvell/comphy_cp110.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/phy/marvell/comphy_cp110.c b/drivers/phy/marvell/comphy_cp110.c index 418318d12f..4fe2dfcdd1 100644 --- a/drivers/phy/marvell/comphy_cp110.c +++ b/drivers/phy/marvell/comphy_cp110.c @@ -36,6 +36,10 @@ DECLARE_GLOBAL_DATA_PTR; (COMPHY_CALLER_UBOOT | ((pcie_width) << 18) | \ ((clk_src) << 17) | COMPHY_FW_FORMAT(mode, 0, speeds))
+/* Invert polarity are bits 1-0 of the mode */ +#define COMPHY_FW_SATA_FORMAT(mode, invert) \ + ((invert) | COMPHY_FW_MODE_FORMAT(mode)) + #define COMPHY_SATA_MODE 0x1 #define COMPHY_SGMII_MODE 0x2 /* SGMII 1G */ #define COMPHY_HS_SGMII_MODE 0x3 /* SGMII 2.5G */ @@ -607,7 +611,8 @@ int comphy_cp110_init(struct chip_serdes_phy_config *ptr_chip_cfg, break; case COMPHY_TYPE_SATA0: case COMPHY_TYPE_SATA1: - mode = COMPHY_FW_MODE_FORMAT(COMPHY_SATA_MODE); + mode = COMPHY_FW_SATA_FORMAT(COMPHY_SATA_MODE, + serdes_map[lane].invert); ret = comphy_sata_power_up(lane, hpipe_base_addr, comphy_base_addr, ptr_chip_cfg->cp_index,
Thanks, Stefan
- #define COMPHY_SATA_MODE 0x1 #define COMPHY_SGMII_MODE 0x2 /* SGMII 1G */ #define COMPHY_HS_SGMII_MODE 0x3 /* SGMII 2.5G */
Viele Grüße, Stefan
Applied to u-boot-marvell/master
Thanks, Stefan
Viele Grüße, Stefan
Denis Odintsov
Stefan Roese
