[U-Boot] [STATUS] Patch status update
Hi everybody,
here is a list of e-mail messages / patches, which I have marked as "open" in my folder. It would we be really helpful if both submitters and responsible custodians could take a look at these and provide feedback if these patches are still to be applied, or have been rejected or obsoleted or are queued in some repo to be pulled soon or whatever.
Thanks in advance.
The list is chronologically sorted (oldes entries first) and consist of
1) Index (only meaningful to me, but for me this is the key information I need) 2) date 3) Subject 4) Link to gmane mailing list archive
8 08/28 Markus Kammerstet [U-Boot] PATCH: U-Boot support for Olimex SAM9L-9260 development board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/46038 9 09/05 "Swarthout Edward [U-Boot] Image.c get_table_entry_name http://article.gmane.org/gmane.comp.boot-loaders.u-boot/46596 12 11/13 Chaofu Chen [U-Boot] [PATCH] bug fix for the delay function of ARM s3c44b0 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/50104 17 03/03 Jean-Christophe P [U-Boot] [PATCH 1/9] at91sam9/cap9: use define instead hardcoded value for the USB_OHCI_REGS_BA http://article.gmane.org/gmane.comp.boot-loaders.u-boot/55481 26 03/20 Richard Retanubun [U-Boot] [PATCH] Coldfire: interrupts: Add watchdog auto reset to dtimer_interrupt http://article.gmane.org/gmane.comp.boot-loaders.u-boot/56267 27 03/23 Richard Retanubun [U-Boot] [PATCH] Coldfire: cleanup compiler warning for lib-m68k unused variables. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/56390 28 03/24 Heiko Schocher i2c: rework multibus/multiadapter functionality http://article.gmane.org/gmane.comp.boot-loaders.u-boot/56416 29 04/03 Dave Liu [U-Boot] [PATCH 2/2] 85xx: add the nfsboot/ramboot to default environment http://article.gmane.org/gmane.comp.boot-loaders.u-boot/57219 33 04/18 Jean-Christophe P [U-Boot] [PATCH] omap2420h4: move arch pre lowlevel init to board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/58008 36 05/01 Jean-Christophe P [U-Boot] [PATCH 3/4] s3c4510b: move interrupts code to soc http://article.gmane.org/gmane.comp.boot-loaders.u-boot/58874 37 05/01 Jean-Christophe P [U-Boot] [PATCH 4/4] lpc2292: move interrupts code to soc http://article.gmane.org/gmane.comp.boot-loaders.u-boot/58873 53 06/13 Dave Liu [U-Boot] [PATCH] 85xx: Enable the DDR3 SPD support for P2020DS board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/61457 59 07/08 Matthias Weisser [U-Boot] [PATCH RESEND 1/3] arm: Added support for MB86R01 'Jade' SoC http://article.gmane.org/gmane.comp.boot-loaders.u-boot/63112 64 07/14 Dimitar Dimitrov [U-Boot] [PATCH 02/03 v2] Add support for Olimex SAM9-L9261 SBC http://article.gmane.org/gmane.comp.boot-loaders.u-boot/63724 65 07/14 Dimitar Dimitrov [U-Boot] [PATCH 03/03 v2] Add support for Olimex SAM9-L9260 SBC http://article.gmane.org/gmane.comp.boot-loaders.u-boot/63725 66 07/15 Dimitar Dimitrov [U-Boot] [PATCH] Add inverted clock polarity support for Atmel LCD driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/63774 70 07/28 TsiChung Liew [U-Boot] [PATCH] ColdFire: Fix missing _IO_BASE which caused compile error http://article.gmane.org/gmane.comp.boot-loaders.u-boot/65083 71 07/28 TsiChung Liew [U-Boot] [PATCH] ColdFire: Fix compile warning messages http://article.gmane.org/gmane.comp.boot-loaders.u-boot/65084 74 08/04 Alex Dubov [U-Boot] [PATCH 2/2] stx: add support for AMC8548 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/65311 75 08/07 oakad@yahoo.com [U-Boot] Another patchset for STx AMC8548 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/65504 77 08/07 oakad@yahoo.com [U-Boot] [PATCH 2/4] stx: factor out LAW settings common for all STx boards http://article.gmane.org/gmane.comp.boot-loaders.u-boot/65507 82 08/24 Renato Andreola [U-Boot] PATCH mtd CFI flash: timeout calculation underflow if imprecise 1kHz timer: fix http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0 83 08/24 Renato Andreola [U-Boot] PATCH - Added support to YANU Nios2 uart (02) http://article.gmane.org/gmane.comp.boot-loaders.u-boot/66673 84 08/26 Albin Tonnerre [U-Boot] [PATCH 1/2] drivers/mmc/atmel_mci.c: port to the new CONFIG_GENERIC_MMC API http://article.gmane.org/gmane.comp.boot-loaders.u-boot/66798 85 08/26 Albin Tonnerre [U-Boot] [PATCH 2/2] AVR32: update to use CONFIG_GENERIC_MMC http://article.gmane.org/gmane.comp.boot-loaders.u-boot/66799 86 09/01 Albin Tonnerre [U-Boot] [PATCH] AT91: Add SD/MMC controller support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/67006 124 09/05 Jean-Christophe P [U-Boot] [PATCH] at91: move base address define to soc header http://article.gmane.org/gmane.comp.boot-loaders.u-boot/67393 125 09/07 "Berns" [U-Boot] autoscr command failure saveenv dataflash http://article.gmane.org/gmane.comp.boot-loaders.u-boot/67483 239 09/08 Albin Tonnerre [U-Boot] [PATCH v3] AT91: Add SD/MMC controller support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/67583 1092 09/21 ? ? [U-Boot] An error in u-boot-2009.08/cpu/arm920t/start.S http://article.gmane.org/gmane.comp.boot-loaders.u-boot/68400 1182 09/21 Philippe De Muyte [U-Boot] [PATCH MAKEALL coldfire] : Fix start.S:Error: Conversion of PC relative displacement t http://article.gmane.org/gmane.comp.boot-loaders.u-boot/68486 1884 10/01 Sebastian Heutlin [U-Boot] [PATCH v3] AT91: Add SD/MMC controller support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/69142 2055 10/05 Dipen Dudhat [U-Boot] [PATCH v3] ppc/85xx: PIO Support for FSL eSDHC Controller Driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/69297 2432 10/12 Kyungmin Park [U-Boot] [PATCH] Reduce apollon OneNAND IPL code http://article.gmane.org/gmane.comp.boot-loaders.u-boot/69648 2786 10/19 Mark Jackson [U-Boot] [PATCH] avr32 portmux : fix incorrect port mask http://article.gmane.org/gmane.comp.boot-loaders.u-boot/69985 2811 10/19 Shinya Kuribayash [U-Boot] [PATCH] qemu_mips: Fix CONFIG_NET_MULTI build warning http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70008 3449 10/28 Wolfgang Wegner [U-Boot] [PATCH] MCF532x: make icache_enable use CONFIG_SYS_SDRAM_SIZE http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70615 3450 10/28 Wolfgang Wegner [U-Boot] [PATCH] allow MCF532x to use CONFIG_MONITOR_IS_IN_RAM http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70616 3491 10/29 Mingkai Hu [U-Boot] [PATCH] ppc/85xx: Clean up mpc8536DS PCI setup code http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70655 3610 10/30 Javier Martin [U-Boot] [u-boot] [PATCH][1/2] mx27: Add necessary defines and helper functions to support I2C http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70769 3611 10/30 Javier Martin [U-Boot] [u-boot][PATCH][2/2] i2c_mxc: Add I2C support for i.MX27 chip processor. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70770 3620 10/30 Dirk Behme [U-Boot] Beagle Zippy: OMAP3 SPI code for U-Boot? http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70779 3703 10/31 Tom Rix [U-Boot] [PATCH] Add I2C multibus support for OMAP2/3 boards http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70856 3760 11/02 "Seunghyeon Rhee [U-Boot] [PATCH] NET: Fix MAC addr handling for smc911x http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70913 3784 11/02 Wolfgang Wegner [U-Boot] [PATCH] non-blocking flash write/erase/status check functions http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70937 3882 11/03 Peter Tyser [U-Boot] [PATCH] tsec: Force TBI PHY to 1000Mbps full duplex in SGMII mode http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71031 3893 11/04 Terry Lv [U-Boot] [PATCH] Improve read performance of generic mmc. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71042 3933 11/04 Kumar Gala [U-Boot] [PATCH v2] ppc/85xx: Clean up mpc8536DS PCI setup code http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71083 4009 11/05 "kevin.morfitt@fe [U-Boot] [PATCH ARM] Update the s3c2410 nand driver from linux-2.6.31.5 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71157 4051 11/06 Alessandro Rubini [U-Boot] [PATCH V3] Nomadik: fix reset_timer() http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71200 4114 11/08 Magnus Lilja [U-Boot] [RFC 3/4] MX31: Activate NAND support for i.MX31 Litekit board. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71259 4146 11/09 Peter Tyser [U-Boot] [PATCH 1/5] tsec: Clean up Broadcom PHY status parsing http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71295 4147 11/09 Peter Tyser [U-Boot] [PATCH 2/5] tsec: Make functions/data static when possible http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71298 4148 11/09 Peter Tyser [U-Boot] [PATCH 3/5] tsec: General cleanup http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71299 4149 11/09 Peter Tyser [U-Boot] [PATCH 4/5] tsec: Add support for using the BCM5482 PHY in fiber mode http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71296 4150 11/09 Peter Tyser [U-Boot] [PATCH 5/5] tsec: Add TSEC_FIBER flag http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71297 4237 11/11 Mike Rapoport [U-Boot] [PATCH] omap3: fix bi_dram initialization when CONFIG_NR_DRAM_BANKS is 1 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71382 4274 11/11 Magnus Lilja [U-Boot] [PATCH v1 3/3] MX31: Activate NAND support for i.MX31 Litekit board. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71425 4350 11/12 Magnus Lilja [U-Boot] [PATCH v2 3/3] MX31: Activate NAND support for i.MX31 Litekit board. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71499 4452 11/15 Dirk Behme [U-Boot] [PATCH] OMAP3: BeagleBoard: Add expansion board auto detection http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71608 4471 11/16 Mike Rapoport [U-Boot] [PATCHi v5] OMAP3: add CM-T35 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71628 4493 11/16 Tom Rix [U-Boot] [PATCH] OMAP3 Move declaration of gpmc_cfg. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71649 4532 11/17 Dave Liu [U-Boot] [PATCH] Fix the local bus divider mapping http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71687 4580 11/18 Mike Rapoport [U-Boot] [PATCH v6] OMAP3: add CM-T35 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71732 4592 11/18 To:u-boot@lists.d [PATCH] Clarify applicable licensing terms in COPYING file. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71743 4598 11/18 hvaibhav@ti.com [U-Boot] [PATCH V3] OMAP3EVM: Added NAND support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71749 4638 11/19 Terry Lv [U-Boot] [PATCH] Save environment data to mmc. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71792 4639 11/19 Terry Lv [U-Boot] [PATCH] Improve read performance of generic mmc. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71791 4698 11/19 "Robert P. J. Day [U-Boot] [PATCH v2] BeagleBoard: Add a comment explaining the use of "OMAP34XX" macros. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71853 4702 11/20 Ajay Kumar Gupta [U-Boot] [PATCH] omap3evm: Add board revision function http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71857 4803 11/23 hvaibhav@ti.com [U-Boot] [PATCH V4] OMAP3EVM: Added NAND support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71952 4930 11/25 Alessandro Rubini [U-Boot] [PATCH V2 0/9] display and keypad support for nhk8815 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72073 4932 11/25 Alessandro Rubini [U-Boot] [PATCH V2 2/9] video: add amba-clcd prime-cell http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72075 4933 11/25 Alessandro Rubini [U-Boot] [PATCH V2 3/9] include/nomadik.h: add physical address for cldc http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72076 4934 11/25 Alessandro Rubini [U-Boot] [PATCH V2 4/9] drivers/misc: add stmpe2401 port extender and keypad controller http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72077 4935 11/25 Alessandro Rubini [U-Boot] [PATCH V2 5/9] nhk8815.h: define we need stmpe http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72078 4936 11/25 Alessandro Rubini [U-Boot] [PATCH V2 6/9] lcd: make 16bpp work http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72079 4937 11/25 Alessandro Rubini [U-Boot] [PATCH V2 7/9] nhk8815: added keypad http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72080 4938 11/25 Alessandro Rubini [U-Boot] [PATCH V2 8/9] nhk8815: start lower in RAM, so the 800x480 frame buffer fits http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72081 4939 11/25 Alessandro Rubini [U-Boot] [PATCH V2 9/9] nhk8815: added lcd support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72082 4940 11/25 Alessandro Rubini [U-Boot] [PATCH V4] Nomadik: fix reset_timer() http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72083 4985 11/27 Liu Yu [U-Boot] [PATCH 1/2] ppc/85xx: Add PIB/ATM support for MPC8569mds http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72127 4986 11/27 Liu Yu [U-Boot] [PATCH 2/2] ppc/85xx: Add ATM config for MPC8569MDS http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72126 5080 12/01 Albert Aribaud [U-Boot] [PATCH V3 1/3] Initial support for Marvell Orion5x SoC http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72220 5081 12/01 Albert Aribaud [U-Boot] [PATCH V3 2/3] Add Orion5x support to 16550 device driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72219 5259 12/05 Alessandro Rubini [U-Boot] [PATCH V3 0/9] display and keypad support for nhk8815 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72395 5260 12/05 Alessandro Rubini [U-Boot] [PATCH V3 1/9] nhk8815: change the order of initialization http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72396 5261 12/05 Alessandro Rubini [U-Boot] [PATCH V3 2/9] video: add amba-clcd prime-cell http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72397 5262 12/05 Alessandro Rubini [U-Boot] [PATCH V3 3/9] include/nomadik.h: add physical address for cldc http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72398 5263 12/05 Alessandro Rubini [U-Boot] [PATCH V3 4/9] drivers/misc: add stmpe2401 port extender and keypad controller http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72399 5264 12/05 Alessandro Rubini [U-Boot] [PATCH V3 5/9] nhk8815.h: define we need stmpe http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72400 5265 12/05 Alessandro Rubini [U-Boot] [PATCH V3 6/9] lcd: make 16bpp work http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72401 5266 12/05 Alessandro Rubini [U-Boot] [PATCH V3 7/9] nhk8815: added keypad http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72402 5267 12/05 Alessandro Rubini [U-Boot] [PATCH V3 8/9] nhk8815: start lower in RAM, so the 800x480 frame buffer fits http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72403 5268 12/05 Alessandro Rubini [U-Boot] [PATCH V3 9/9] nhk8815: added lcd support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72404 5369 12/08 Nick Thompson [U-Boot] [PATCH RFC] NAND: Improve read performance from Large Page NAND devices http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72491 5400 12/09 Li Yang [U-Boot] [PATCH 2/3] fdt: add fdt_del_node_by_path() API http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72523 5438 12/10 Li Yang [U-Boot] [PATCH 1/5] fdt: add fdt_del_node_by_path() API http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72559 5440 12/10 Li Yang [U-Boot] [PATCH 3/5] 85xx: add common serdes ports configuration code http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72557 5441 12/10 Li Yang [U-Boot] [PATCH 4/5] p2020: add serdes status code complying to fsl_serdes APIs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72560 5442 12/10 Li Yang [U-Boot] [PATCH 5/5] p2020ds: use common code to initialize serdes ports http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72561 5443 12/10 Wolfgang Wegner [U-Boot] [PATCH v2] add ability to handle compressed images to imxtract http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72562 5446 12/10 Nick Thompson [U-Boot] [PATCH] da830evm: Use table driven pin mux configuration http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72566 5514 12/13 Peter Tyser [U-Boot] [PATCH 00/17] Reorganize directory structure http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72675 5515 12/13 Peter Tyser [U-Boot] [PATCH 01/17] Move lib_<ARCH> directories to arch/<ARCH>/lib http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72676 5516 12/13 Peter Tyser [U-Boot] [PATCH 02/17] Rename lib_generic/ to lib/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72636 5518 12/13 Peter Tyser [U-Boot] [PATCH 04/17] Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>" http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72637 5519 12/13 Peter Tyser [U-Boot] [PATCH 05/17] Move architecture-specific includes to arch/$ARCH/include/asm http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72677 5520 12/13 Peter Tyser [U-Boot] [PATCH 06/17] ppc: Move appropriate cpu/ dirs to arch/ppc/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72678 5521 12/13 Peter Tyser [U-Boot] [PATCH 07/17] sh: Move appropriate cpu/ dirs to arch/sh/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72638 5522 12/13 Peter Tyser [U-Boot] [PATCH 08/17] arm: Move appropriate cpu/ dirs to arch/arm/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72679 5523 12/13 Peter Tyser [U-Boot] [PATCH 09/17] m68k: Move appropriate cpu/ dirs to arch/m68k/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72639 5524 12/13 Peter Tyser [U-Boot] [PATCH 10/17] blackfin: Move appropriate cpu/ dirs to arch/blackfin/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72640 5525 12/13 Peter Tyser [U-Boot] [PATCH 11/17] mips: Move appropriate cpu/ dirs to arch/mips/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72641 5526 12/13 Peter Tyser [U-Boot] [PATCH 12/17] avr32: Move appropriate cpu/ dirs to arch/avr32/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72642 5527 12/13 Peter Tyser [U-Boot] [PATCH 13/17] microblaze: Move appropriate cpu/ dirs to arch/microblaze/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72643 5528 12/13 Peter Tyser [U-Boot] [PATCH 14/17] sparc: Move appropriate cpu/ dirs to arch/sparc/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72645 5529 12/13 Peter Tyser [U-Boot] [PATCH 15/17] nios: Move appropriate cpu/ dirs to arch/nios/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72644 5530 12/13 Peter Tyser [U-Boot] [PATCH 16/17] nios2: Move appropriate cpu/ dirs to arch/nios2/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72647 5531 12/13 Peter Tyser [U-Boot] [PATCH 17/17] i386: Move appropriate cpu/ dirs to arch/i386/cpu/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72646 5589 12/15 Sanjeev Premi [U-Boot] [PATCH 1/2] omap3: Identify the CPU in arch_cpu_init() http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72707 5590 12/15 Sanjeev Premi [U-Boot] [PATCH 2/2] omap3: Identify cpu in s_init() http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72709 5608 12/16 Sanjeev Premi [U-Boot] [PATCH 1/4] AM35x: Introduce support for AM35x processors http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72727 5611 12/16 Sanjeev Premi [U-Boot] [PATCH 4/4] OMAP3, AM35x: Update the checks for CPU revision http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72729 5668 12/16 Dirk Behme [U-Boot] [PATCH] OMAP3: Beagle: Update revision detection http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72786 5717 12/16 Mike Frysinger [U-Boot] [PATCH 2/5] usb: musb: make fifo support configurable http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72838 5718 12/16 Mike Frysinger [U-Boot] [PATCH 3/5] usb: musb: make multipoint optional http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72837 5719 12/16 Mike Frysinger [U-Boot] [PATCH 4/5] usb: musb: change rxcsr register from write to read/modify/write http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72839 5720 12/16 Mike Frysinger [U-Boot] [PATCH 5/5] usb: musb: add support for Blackfin MUSB http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72840 5731 12/17 Semih Hazar [U-Boot] [PATCH] Add misc_init_r support to AVR32 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72850 5732 12/17 Semih Hazar [U-Boot] [PATCH] macb: Fix mii_phy_read and mii_phy_write functions http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72851 5733 12/17 Semih Hazar [U-Boot] [PATCH] Remove duplicate #defines in atngw100.h and mimc200.h http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72852 5738 12/17 Sriramakrishnan [U-Boot] [PATCHv2] OMAP3: Increase bootargs string length. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72857 5804 12/18 Himanshu Chauhan [U-Boot] [PATCH]: U-Boot build failure with CONFIG_SYS_NO_FLASH defined for qemu-mips. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72923 5809 12/18 Nick Thompson [U-Boot] [PATCH v3] TI: DaVinci: Updating EMAC driver for DM365, DM646x and DA8XX http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72929 5811 12/18 Sudhakar Rajashek [U-Boot] [PATCH v2 1/3] TI: DaVinci: Prepare for da850 support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72932 5812 12/18 Sudhakar Rajashek [U-Boot] [PATCH v2 2/3] TI: DaVinci: Add board specific code for da850 EVM http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72933 5813 12/18 Sudhakar Rajashek [U-Boot] [PATCH v2 3/3] TI: DaVinci: Create configuration file for da850 EVM http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72934 5828 12/19 Himanshu Chauhan [U-Boot] [PATCH][RESEND]: Fix for U-Boot build failure with CONFIG_SYS_NO_FLASH defined for qem http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72948 5951 12/23 Sanjeev Premi [U-Boot] [PATCH 0/2] omap3: Remove extern declarations from headers http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73072 5952 12/23 Sanjeev Premi [U-Boot] [PATCH 1/2] omap3: Remove externs from config files http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73073 5953 12/23 Sanjeev Premi [U-Boot] [PATCH 2/2] omap3: Remove multiple extern decls for gpmc_cfg http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73074 5957 12/23 Vaibhav Hiremath [U-Boot] [PATCH 3/3] AM35x: Add support for EMIF4 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73076 5962 12/23 Matthias Kaehlcke [U-Boot] [PATCH 0/3] ARM: Add support for EDB93XX boards [rev2] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73085 5963 12/23 Matthias Kaehlcke [U-Boot] [PATCH 1/3] ARM: Add support for EP93XX SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73086 5964 12/23 Matthias Kaehlcke [U-Boot] [PATCH 2/3] Add EP93XX ethernet driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73087 5965 12/23 Matthias Kaehlcke [U-Boot] [PATCH 3/3] Add support for EDB93XX boards http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73088 5974 12/24 Marcel Ziswiler [U-Boot] [PATCH 0/3] Monahan/PXA3xx: integrate Linux NAND controller driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73094 5975 12/24 Marcel Ziswiler [U-Boot] [PATCH 1/3] Monahan/PXA3xx: integrate Linux NAND controller driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73095 5976 12/24 Marcel Ziswiler [U-Boot] [PATCH 2/3] delta: use new generic NAND controller driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73096 5977 12/24 Marcel Ziswiler [U-Boot] [PATCH 3/3] zylonite: use new generic NAND controller driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73097 6011 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 1/4] s3c24x0 white-space clean-up part 1 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73133 6012 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 2/4] s3c24x0 white-space clean-up part 2 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73134 6013 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 3/4] s3c24x0 code-style clean-up http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73135 6014 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 4/4] Change s3c24x0 register struct members to lower case http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73136 6043 12/30 Ladislav Michl [U-Boot] [PATCH] NetStar: Remove debug junk leaked into eeprom utility http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73165 6044 12/30 Ladislav Michl [U-Boot] [PATCH] NetStar: Disable CONFIG_CMD_JFFS2 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73166 6045 12/30 Ladislav Michl [U-Boot] [PATCH] NetStar: make crcit utility more readable. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73164 6069 01/03 Quentin Armitage [U-Boot] Issue in drivers/mmc/mmc.c http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73195 6070 01/03 Quentin Armitage [U-Boot] There appears to be the potential for an undetected error in fs/ext2/dev.c ext2fs_devr http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73196 6126 01/05 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 4/4] Enable I2C bus switching http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73260 6139 01/05 "Chris Zhang" [U-Boot] ppc440epx(sequoia) USB ehci fix. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73273 6154 01/06 Khasim Syed Moham [U-Boot] TI:OMAP:[PATCH 2/4] Support 720Mhz configuration for OMAP35xx http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73288 6161 01/06 Chris Zhang [U-Boot] [PATCH 0/3] PPC440EPX(sequoia) USB EHCI support. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73295 6177 01/07 Li Yang [U-Boot] [PATCH 1/2] fsl_esdhc: fix wrong clock mask http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73305 6178 01/07 Li Yang [U-Boot] [PATCH 2/2] p2020ds: use maximum timeout for esdhc http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73304 6181 01/07 Vivek Mahajan [U-Boot] [PATCH 1/2] 85xx/p1_p2_rdb: p1020: add muxed usb2 handling http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73316 6182 01/07 Vivek Mahajan [U-Boot] [PATCH 2/2] 85xx/p1_p2_rdb: enable hwconfig http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73315 6183 01/07 Sudhakar Rajashek [U-Boot] [PATCH v5] TI DaVinci: Driver for the davinci SPI controller http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73317 6200 01/07 Thomas Petazzoni [U-Boot] [PATCH] Support for Calao USB A9263 board based on AT91SAM9263 CPU http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73336 6220 01/08 Mike Frysinger [U-Boot] [PATCH] getline: split out for darwin systems http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73355 6227 01/08 Mike Frysinger [U-Boot] [PATCH] jffs2: fix hangs/crashs when not using CONFIG_JFFS2_PART_SIZE http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73363 6230 01/08 Vipin KUMAR [U-Boot] [PATCH v3 00/11] SPEAr : Adding support for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73366 6231 01/08 Vipin KUMAR [U-Boot] [PATCH v3 01/11] SPEAr : Adding README.spear in doc http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73367 6232 01/08 Vipin KUMAR [U-Boot] [PATCH v3 02/11] SPEAr : Adding basic support for SPEAr600 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73369 6233 01/08 Vipin KUMAR [U-Boot] [PATCH v3 03/11] SPEAr : Adding basic support for SPEAr300 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73368 6234 01/08 Vipin KUMAR [U-Boot] [PATCH v3 04/11] SPEAr : Adding basic support for SPEAr310 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73370 6235 01/08 Vipin KUMAR [U-Boot] [PATCH v3 05/11] SPEAr : Adding basic support for SPEAr320 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73371 6237 01/08 Vipin KUMAR [U-Boot] [PATCH v3 07/11] SPEAr : Support for HW macid read/write from i2c memory http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73373 6238 01/08 Vipin KUMAR [U-Boot] [PATCH v3 08/11] SPEAr : Support for serial memory interface driver and serial NOR fla http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73374 6239 01/08 Vipin KUMAR [U-Boot] [PATCH v3 09/11] SPEAr : Support for nand driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73372 6240 01/08 Vipin KUMAR [U-Boot] [PATCH v3 10/11] SPEAr : Support for usbd driver and usbtty support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73377 6241 01/08 Vipin KUMAR [U-Boot] [PATCH v3 11/11] SPEAr : Support for cfi driver and parallel NOR flash http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73375 6244 01/08 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 1/4] OMAP3 Beagle Update revision detection http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73380 6264 01/09 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH] Add support for 720Mhz http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73401 6265 01/09 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH] Add DSS driver for OMAP3 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73402 6267 01/09 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH] Enable DSS driver for Beagle http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73404 6278 01/09 Albin Tonnerre [PATCH v2] Add support for the Calao QIL-A9G20 and QIL-A9260 boards http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73415 6279 01/09 Mike Frysinger [U-Boot] [PATCH] usb: musb: add virtual root hub control support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73416 6287 01/10 Albert Aribaud [U-Boot] [PATCH V4 2/3] Add Orion5x support to 16550 device driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73427 6291 01/11 Li Wenhao [U-Boot] [PATCH] Add Yaffs2 image writing support. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73432 6301 01/11 Sudhakar Rajashek [U-Boot] [PATCH v6] TI DaVinci: Driver for the davinci SPI controller http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73445 6304 01/11 Prathap Srinivas [U-Boot] [PATCH v2] musb: Add host support for DM365 EVM http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73446 6310 01/11 Vipin KUMAR [U-Boot] [PATCH v4 00/12] Support for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73455 6311 01/11 Vipin KUMAR [U-Boot] [PATCH v4 01/12] SPEAr : Adding README.spear in doc http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73452 6312 01/11 Vipin KUMAR [U-Boot] [PATCH v4 02/12] SPEAr : Adding basic SPEAr architecture support. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73453 6313 01/11 Vipin KUMAR [U-Boot] [PATCH v4 03/12] SPEAr : i2c driver support added for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73454 6314 01/11 Vipin KUMAR [U-Boot] [PATCH v4 04/12] SPEAr : smi driver support for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73457 6315 01/11 Vipin KUMAR [U-Boot] [PATCH v4 05/12] SPEAr : nand driver support for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73458 6316 01/11 Vipin KUMAR [U-Boot] [PATCH v4 06/12] SPEAr : usbd driver support for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73459 6317 01/11 Vipin KUMAR [U-Boot] [PATCH v4 07/12] SPEAr : Support added for SPEAr600 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73456 6318 01/11 Vipin KUMAR [U-Boot] [PATCH v4 08/12] SPEAr : Support for HW mac id read/write from i2c mem http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73460 6319 01/11 Vipin KUMAR [U-Boot] [PATCH v4 09/12] SPEAr : Support added for SPEAr300 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73463 6320 01/11 Vipin KUMAR [U-Boot] [PATCH v4 10/12] SPEAr : emi controller initialization for CFI driver support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73464 6321 01/11 Vipin KUMAR [U-Boot] [PATCH v4 11/12] SPEAr : Support added for SPEAr310 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73461 6322 01/11 Vipin KUMAR [U-Boot] [PATCH v4 12/12] SPEAr : Support added for SPEAr320 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73462 6335 01/11 Stefano Babic [U-Boot] [PATCH 8/9] mmc: check correctness of the voltage mask in ocr http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73473 6376 01/12 Gregory Hermant [U-Boot] [U-boot] [PATCH] Support for the Calao USB-A9260/USB-A9G20 boards http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73522 6384 01/12 Matthias Weisser [U-Boot] [PATCH] video: Fix console display when splashscreen is used http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73529 6393 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: Re-submitting Beagle REV C4, 720 Mhz and DSS patches http://article.gmane.org/gmane.comp.hardware.beagleboard.user/0 6396 01/12 Kumar Gala [U-Boot] [PATCH 1/3] Add support to disable cpu's in multicore processors http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73543 6397 01/12 Kumar Gala [U-Boot] [PATCH 2/3] 86xx: Add support for 'cpu disable' command http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73545 6399 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 3/7] API to set twl4030 voltage and dev group 6400 01/13 Khasim Syed Moham [U-Boot] TI:OMAP:[PATCH 4/7] Add support for 720Mhz 6401 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 5/7] Add DSS driver for OMAP3 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73550 6402 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 6/7] Enable DSS driver for Beagle http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73551 6407 01/12 Kumar Gala [U-Boot] [PATCH v2 3/3] 85xx: Add support for 'cpu disable' command http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73556 6431 01/13 Stefano Babic [U-Boot] MX51 Support V2 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73590 6433 01/13 Stefano Babic [U-Boot] [PATCH V2 2/9] MX51: Add initial support for the Freescale MX51 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73584 6434 01/13 Stefano Babic [U-Boot] [PATCH V2 3/9] MX51: Add register definitions http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73581 6435 01/13 Stefano Babic [U-Boot] [PATCH V2 4/9] MX51: Add pin and multiplexer definitions. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73582 6436 01/13 Stefano Babic [U-Boot] [PATCH V2 5/9] serial_mxc: add support for MX51 processor http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73583 6437 01/13 Stefano Babic [U-Boot] [PATCH V2 6/9] fec_mxc: add support for MX51 processor http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73588 6438 01/13 Stefano Babic [U-Boot] [PATCH V2 7/9] fsl_esdhc: add support for mx51 processor http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73589 6439 01/13 Stefano Babic [U-Boot] [PATCH V2 8/9] mmc: check correctness of the voltage mask in ocr http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73585 6440 01/13 Stefano Babic [U-Boot] [PATCH V2 9/9] Add initial support for Freescale mx51evk board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73586 6445 01/13 Tom [U-Boot] [PATCH v4 01/12] SPEAr : Adding README.spear in doc http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73594 6451 01/13 Tom [U-Boot] [PATCH v4 08/12] SPEAr : Support for HW mac id read/write from i2c mem http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73600 6453 01/13 Tom [U-Boot] [PATCH v4 10/12] SPEAr : emi controller initialization for CFI driver support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73602 6465 01/13 Kumar Gala [U-Boot] [PATCH] ppc/p4080: Fix mask width of RCW fields MEM_PLL_RAT, SYS_PLL_RAT http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73614 6492 01/14 Anders Darander [U-Boot] [PATCH] Add bootcount to AT91 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73640 6512 01/15 Liu Yu [U-Boot] [PATCH v3] qe: fixup the snum for MPC8569 Rev2.0 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73658 6523 01/15 Vipin KUMAR [U-Boot] [PATCH v5 00/12] Support for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73677 6524 01/15 Vipin KUMAR [U-Boot] [PATCH v5 01/12] SPEAr : Adding README.spear in doc http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73675 6525 01/15 Vipin KUMAR [U-Boot] [PATCH v5 02/12] SPEAr : Adding basic SPEAr architecture support. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73674 6526 01/15 Vipin KUMAR [U-Boot] [PATCH v5 03/12] SPEAr : i2c driver support added for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73682 6527 01/15 Vipin KUMAR [U-Boot] [PATCH v5 04/12] SPEAr : smi driver support for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73681 6528 01/15 Vipin KUMAR [U-Boot] [PATCH v5 05/12] SPEAr : nand driver support for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73676 6529 01/15 Vipin KUMAR [U-Boot] [PATCH v5 06/12] SPEAr : usbd driver support for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73679 6530 01/15 Vipin KUMAR [U-Boot] [PATCH v5 07/12] SPEAr : Support added for SPEAr600 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73678 6531 01/15 Vipin KUMAR [U-Boot] [PATCH v5 08/12] SPEAr : Support for HW mac id read/write from i2c mem http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73673 6532 01/15 Vipin KUMAR [U-Boot] [PATCH v5 09/12] SPEAr : Support added for SPEAr300 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73671 6533 01/15 Vipin KUMAR [U-Boot] [PATCH v5 10/12] SPEAr : emi controller initialization for CFI driver support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73680 6534 01/15 Vipin KUMAR [U-Boot] [PATCH v5 11/12] SPEAr : Support added for SPEAr310 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73672 6535 01/15 Vipin KUMAR [U-Boot] [PATCH v5 12/12] SPEAr : Support added for SPEAr320 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73670 6572 01/16 Jens Scharsig [U-Boot] [PATCH 1/8 V2] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73719 6573 01/16 Jens Scharsig [U-Boot] [PATCH 2/8 V2] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73720 6574 01/16 Jens Scharsig [U-Boot] [PATCH 3/8 V2] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73721 6575 01/16 Jens Scharsig [U-Boot] [PATCH 4/8 V2] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73722 6576 01/16 Jens Scharsig [U-Boot] [PATCH 5/8 V2 Part 1/3] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73723 6577 01/16 Jens Scharsig [U-Boot] [PATCH 5/8 V2 Part 1/3] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73724 6578 01/16 Jens Scharsig [U-Boot] [PATCH 5/8 V2 Part 3/3] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73725 6579 01/16 Jens Scharsig [U-Boot] [PATCH 6/8 V2] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73726 6580 01/16 Jens Scharsig [U-Boot] [PATCH 7/8 V2] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73727 6581 01/16 Jens Scharsig [U-Boot] [PATCH 8/8 V2] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73728 6582 01/16 cyrus [U-Boot] [PATCH 5/8 V2 Part 2/3] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73745 6583 01/16 Jens Scharsig [U-Boot] [PATCH 5/8 V2 Part 2/3] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73729 6590 01/16 John Rigby [U-Boot] [PATCH-V2 1/9] mxc_serial replace platform specific clock http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73736 6591 01/16 John Rigby [U-Boot] [PATCH-V2 2/9] arm926ejs: add nand_spl boot support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73737 6592 01/16 John Rigby [PATCH-V2 3/9] Add MX25 support to nand_spl fsl nfc driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73738 6593 01/16 John Rigby [U-Boot] [PATCH-V2 4/9] Nand mxc_nand add v1.1 controller support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73739 6594 01/16 John Rigby [U-Boot] [PATCH-V2 5/9] fec_mxc: cleanup and factor out MX27 dependencies http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73740 6595 01/16 John Rigby [U-Boot] [PATCH-V2 6/9] Add support for Freescale MX25 SOC http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73744 6596 01/16 John Rigby [U-Boot] [PATCH-V2 7/9] fec_mxc: add MX25 support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73741 6597 01/16 John Rigby [PATCH-V2 8/9] env_nand.c: print error message and fail gracefully http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73743 6598 01/16 John Rigby [PATCH-V2 9/9] Add support for KARO TX25 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73742 6600 01/17 Magnus Lilja [U-Boot] [PATCH v2] SPI: Fix 32 bit transfers in mxc_spi.c http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73747 6673 01/17 To:u-boot@lists.d [PATCH] TFTP: allow for adjustable retransmission timout http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73816 6698 01/17 Mike Frysinger [U-Boot] [PATCH 1/1] [rfc] usb: musb: some more Blackfin stuff http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73841 6704 01/17 Ben Warren Re: [U-Boot] [RFC] 83xx: uec: miiphybb: Added support for bitBang SMI and uec SMI enabled at th http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73847 6741 01/18 Wolfgang Wegner [U-Boot] [PATCH v4] add ASTRO MCF5373L board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73883 6745 01/18 Quentin Armitage Re: [U-Boot] [U-boot] There appears to be the potential for an undetected error in fs/ext2/dev. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73887 6747 01/18 Quentin Armitage Re: [U-Boot] Issue in drivers/mmc/mmc.c http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73889 6748 01/18 Liu Yu [PATCH v2] Nand boot: Add nand boot support for MPC8569mds board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73890 6751 01/18 Shlomo Kut [U-Boot] davinci dm365 relocation http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73893 6752 01/18 Arno Steffen [U-Boot] OMAP3 EVM board nand support missed http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73894 6765 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 2/7] Enable I2C bus switching http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0 6766 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 3/7] API to set twl4030 voltage and dev group http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0 6767 01/18 Khasim Syed Moham [U-Boot] TI:OMAP:[PATCH 4/7] Add support for 720Mhz http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73914 6768 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 5/7] Add DSS driver for OMAP3 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0 6769 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 6/7] Enable DSS driver for Beagle http://article.gmane.org/gmane.comp.hardware.beagleboard.user/0 6770 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 7/7] Add 720Mhz support for Beagle Rev C4 http://article.gmane.org/gmane.comp.hardware.beagleboard.user/0 6774 01/18 Richard Retanubun [U-Boot] [PATCH V2] PPC: Record uboot's relocated address in RAM and show in bdinfo. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73925 6783 01/18 Nick Thompson [U-Boot] [PATCH v2] da830evm: Use table driven pin mux configuration http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73933 6785 01/18 Stefano Babic [U-Boot] [PATCH] SPI: add support for i.MX51 processor (mxc_spi) http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73935 6786 01/18 prakash bedge Re: U-boot running on DDR fails to detect the CFI compliant flash 6800 01/18 Magnus Lilja Re: [U-Boot] [PATCH-V2 4/9] Nand mxc_nand add v1.1 controller support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73945 6820 01/19 Mike Frysinger [U-Boot] [PATCH] usb: musb: fix Blackfin DMA register padding http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73965 6822 01/19 Siddarth Gore [U-Boot] [PATCH] NET: kirkwood-egiga smi access fix http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73966 6826 01/19 Shivaprashanth Hi [U-Boot] uboot for zylonite/ces-310 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73970 6827 01/19 Daniel Gorsulowsk [U-Boot] [PATCH] at91: Add esd gmbh OTC570 board support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73971 6862 01/19 Joakim Tjernlund [PATCH 1/4] ppc: Loose GOT access in IRQ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74001 6863 01/19 Joakim Tjernlund [PATCH 2/4] ppc: Use r12 instead of r14 as GOT pointer. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74002 6864 01/19 Joakim Tjernlund [PATCH 4/4] ppc: Update README about the new GOT ptr. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74004 6865 01/19 Joakim Tjernlund [PATCH 3/4] ppc: remove -ffixed-r14 gcc option. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74003 6869 01/19 Dennis Semakin [U-Boot] [U-BOOT] Ethernet problem on PXA320 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74008 6894 01/19 Remy Bohmer Re: [U-Boot] [PATCH] usb: musb: fix Blackfin DMA register padding http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74033 6895 01/19 Matthias Kaehlcke [U-Boot] [PATCH 0/3] ARM: Add support for EDB93xx boards [rev3] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74035 6897 01/19 Michael Durrant [U-Boot] MCF528x cache errata / fix [PATCH] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74037 6898 01/19 Michael Durrant [U-Boot] ColdFire I2C implementing I2C idle [PATCH] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74038 6899 01/19 Michael Durrant [U-Boot] Adding EP2500 MCF5282 board [PATCH] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74039 6900 01/19 Michael Durrant [U-Boot] ColdFire/M68K board.c initialization / order matters [PATCH] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74040 6916 01/20 Heiko Schocher [U-Boot] 83xx, uec: split enet_interface in two variables, was: 83xx, uec: adjust enet_interfac http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74056 6917 01/20 Heiko Schocher [U-Boot] 83xx, kmeter1: fix compile error http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74057 6920 01/20 Anders Darander Re: [U-Boot] [PATCH] Add bootcount to AT91 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74060 6927 01/20 Detlev Zundel [U-Boot] [PATCH] mpc5xxx: Support CPU internal watchdog. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74068 6931 01/20 Stefano Babic [U-Boot] [PATCH V3 01/11] mkimage: Add Freescale imx Boot Image support (imximage) http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74073 6932 01/20 Stefano Babic [U-Boot] [PATCH V3 02/11] MX51: Add initial support for the Freescale MX51 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74074 6933 01/20 Stefano Babic [U-Boot] [PATCH V3 03/11] MX51: Add register definitions http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74075 6934 01/20 Stefano Babic [U-Boot] [PATCH V3 04/11] MX51: Add pin and multiplexer definitions. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74076 6935 01/20 Stefano Babic [U-Boot] [PATCH V3 05/11] serial_mxc: add support for MX51 processor http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74077 6936 01/20 Stefano Babic [U-Boot] [PATCH V3 06/11] mmc: check correctness of the voltage mask in ocr http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74078 6937 01/20 Stefano Babic [U-Boot] [PATCH V3 07/11] fec_mxc: add support for MX51 processor http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74079 6938 01/20 Stefano Babic [U-Boot] [PATCH V3 08/11] MMC: add weak function to detect MMC/SD card http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74080 6939 01/20 Stefano Babic [U-Boot] [PATCH V3 09/11] ARM/PPC: add a common way to access registers http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74081 6940 01/20 Stefano Babic [U-Boot] [PATCH V3 10/11] fsl_esdhc: add support for mx51 processor http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74082 6941 01/20 Stefano Babic [U-Boot] [PATCH V3 11/11] Add initial support for Freescale mx51evk board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74083 6943 01/20 K Balaji [U-Boot] U-Boot for LENO3 processor board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74085 6947 01/20 Michael Durrant Re: [U-Boot] Adding EP2500 MCF5282 board [PATCH] -- resent in git format http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74089 6949 01/20 Michael Durrant Re: [U-Boot] ColdFire/M68K board.c initialization / order matters [PATCH] -- resent in git form http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74091 6950 01/20 Michael Durrant Re: [U-Boot] MCF528x cache errata / fix [PATCH] -- resent in git format http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74092 6959 01/21 Mingkai Hu [U-Boot] [PATCH] 85xx/eSDHC: fix eSDHC clock frequency mask http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74101 6960 01/21 "Liu Dave-R63238" Re: [U-Boot] [PATCH] 85xx/eSDHC: fix eSDHC clock frequency mask http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74102 6974 01/21 Mike Frysinger [U-Boot] [PATCH 3/3] asm-arm/unaligned.h: switch to asm-generic/unaligned.h http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74116 6975 01/21 Mike Frysinger [U-Boot] [PATCH 2/3] asm-blackfin/unaligned.h: add for zlib code http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74117 6976 01/21 Mike Frysinger [U-Boot] [PATCH 1/3] asm-generic/unaligned.h: dynamic default unaligned accesses http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74118 6977 01/21 Mike Frysinger [U-Boot] [PATCH] smc91111_eeprom: fix linking error http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74119 7003 01/21 Matthias Kaehlcke [U-Boot] [PATCH] cs8900_initialize() cleanup [rev2] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74144 7012 01/21 Matthias Kaehlcke [U-Boot] [PATCH] smc911x driver: cleanup smc911x_initialize() http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74153 7027 01/21 Mike Frysinger [U-Boot] [PATCH v2] gzip/zlib: make features optional http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74168 7030 01/21 Mike Frysinger [U-Boot] [PATCH] tools: give explicit libfdt paths http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74171 7075 01/23 Jens Scharsig [U-Boot] [PATCH 0/9 V3] add at91 SoC access with c structures http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74213 7076 01/23 Jens Scharsig [U-Boot] [PATCH 1/9 V3] add new CONFIG_AT91_LEGACY http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74214 7077 01/23 Jens Scharsig [U-Boot] [PATCH 2/9 V3] add c structures for SoC access http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74215 7078 01/23 Jens Scharsig [U-Boot] [PATCH 3/9 V3] add a new AT91 GPIO driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74216 7079 01/23 Jens Scharsig [U-Boot] [PATCH 5/9 V3] convert common files to new SoC access http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74217 7080 01/23 Jens Scharsig [U-Boot] [PATCH 4/9 V3] convert all at91 files to use at91_gpio driver syntax http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74218 7081 01/23 Jens Scharsig [U-Boot] [PATCH 6/9 V3] update at91sam9263ek board to new SoC access http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74219 7082 01/23 Jens Scharsig [U-Boot] [PATCH 7/9 V3] prepare joining at91rm9200 into at91 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74220 7083 01/23 Jens Scharsig [U-Boot] [PATCH 8/9 V3] new at91_emac network driver (NET_MULTI api) http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74221 7084 01/23 Jens Scharsig [U-Boot] [PATCH 9/9 V3] new board (eb_cpux9k2) http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74222 7094 01/23 Ed Swarthout [U-Boot] [PATCH RFC] tsec: do not print Speed: if using netconsole http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74231 7138 01/24 Matthias Kaehlcke [U-Boot] [PATCH 0/3] ARM: Add support for EDB93xx boards [rev4] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74274 7139 01/24 Matthias Kaehlcke [U-Boot] [PATCH 2/3] Add EP93xx ethernet driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74275 7140 01/24 Matthias Kaehlcke [U-Boot] [PATCH 1/3] ARM: Add support for EP93xx SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74276 7141 01/24 Matthias Kaehlcke [U-Boot] [PATCH 3/3] Add support for EDB93xx boards http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74273 7159 01/25 Daniel Gorsulowsk [U-Boot] [PATCH v2] at91: Add esd gmbh OTC570 board support http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74293 7160 01/25 Wolfgang Wegner [U-Boot] [PATCH v5] add ASTRO MCF5373L board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74294 7166 01/25 Khasim Syed Moham [U-Boot] Fwd: TI:OMAP: [PATCH 6/7] Enable DSS driver for Beagle http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74300 7167 01/25 Khasim Syed Moham [U-Boot] Fwd: TI:OMAP: [PATCH 5/7] Add DSS driver for OMAP3 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74301 7177 01/25 Scott Ellis [U-Boot] [PATCH] Overo GPMC registers http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74310 7178 01/25 Kumar Gala [U-Boot] [PATCH] Revert "ppc/p4080: Fix reporting of PME & FM clock frequencies" http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74311 7179 01/25 richardretanubun@ [U-Boot] [PATCH V3] PPC: Record uboot's relocated address in RAM and show in bdinfo. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74312
On Mon, 25 Jan 2010 23:44 +0100, Wolfgang Denk wrote :
Hi everybody,
Hi Wolfgang,
Thanks in advance.
Apparently those two have issues on some AT91SAM9263-based boards, but I don't have such hardware so I can't test the patches, so I guess you should mark them as obsolete.
Obsoleted by the following patch
Should be OK for inclusion.
Ditto.
Regards,
Dear Albin Tonnerre,
Thanks.
Ditto.
Tom, these are for you, then.
Ditto.
Tom, in case you had queued up one of those patches, please drop them. They both need updates to work with the latest AT91 changes. I'll make sure to post an updated version soon.
Regards,
I got no feedback on this.
Nor this.
Scott and Magnus had some comments on this which I thought I addressed. I believe Scott asked Magnus to test the patch which he did. Scott, are you waiting on an update from me on this?
I heard nothing on this.
Nor this.
Nor this.
Ditto.
Again, nothing.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de If it went on at this rate, in several billion years he'd be rich beyond his wildest dreams! - Terry Pratchett, _Soul Music_ _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Nor this.
I can take it if there are no objections from the ARM side.
Can you respin on top of the conflicting patches from Magnus (which are now upstream)?
Ditto.
Sorry, forgot about that one -- will apply.
-Scott
I'm working on this.
Dear John,
In message 4b73d43f1001251513o16380ef6yaf5e14f17dd4c478@mail.gmail.com you wrote:
--000e0cd1b36ebb16c2047e055293 Content-Type: text/plain; charset=ISO-8859-1
Nor this.
Nor this.
Nor this.
Ditto.
Again, nothing.
Thanks.
Feng??? I hyaven't hear=d from you for a while, so I assume you do not have any time available for custodian work?
Tom, as it seems Feng disappeared in a black hole, can you please take care of this stuff, then? [Ditto for Stefano's i.MX51 code, please.]
Hi everybody,
Thanks in advance.
- Index (only meaningful to me, but for me this is the key information I need)
- date
- Subject
- Link to gmane mailing list archive
[SNIP]
These are still valid and only exist as patches. I hope you can add them to the u-boot repo.
Dear Joakim Tjernlund,
In message OF8FFD86D8.60A8DA1C-ONC12576B6.007F888A-C12576B6.00800191@transmode.se you wrote:
Applied, thanks.
Hi Wolfgang,
comments on my patches. Of course I would like to have all of them included except the obsoleted index 6741. ;-)
On Mon, Jan 25, 2010 at 11:44:48PM +0100, Wolfgang Denk wrote: [...]
I think TsiChung should comment if these are useful/needed.
NACKed by you and Stefan Roese, so not for inclusion in mainline
No further feedback after I fixed the style errors.
obsoleted by 7160 (removed update.c because of 3784)
no further comments after last correction and removal of offending non-blocking flash functions. Needs index 3450 and 5443 at run-time.
Hope this summary helps! Regards, Wolfgang
Dear Wolfgang Wegner,
Rigth.
Applied.
TsiChung, can you please comment on this?
read/modify/write
these have been merged already
needs maintainer feedback for a better way of addressing the issue
usb maintainer has picked it up, so i guess you can ignore
generic/unaligned.h
accesses
patch 1/3 and 2/3 need merging (fix build errors for all Blackfin boards). patch 3/3 is up to Tom i guess ... doesnt matter much to me as i dont do arm, but i thought i'd help him out with a general solution for all rather than continuing the copy & paste duplication tradition.
net maintainer has picked it up, so i guess you can ignore -mike
Dear Mike Frysinger,
Thanks for the confirmation - I still had the USB patches marked as open.
OK.
Well, I close a patch only after it was finally rejected or applied to mainline.
generic/unaligned.h
accesses
I see. I guess I have your ACK for BF?
Tom, can you please send an ACK for the ARM part?
Then I would apply all 3 of them...
Thanks again for the feedback.
if you want to pick it up directly instead of through my tree, that's fine. all three have my s-o-b already. -mike
Dear Mike,
patch 1/3 and 2/3 need merging (fix build errors for all Blackfin boards). patch 3/3 is up to Tom i guess ... doesnt matter much to me as=
i
=20 I see. I guess I have your ACK for BF?
if you want to pick it up directly instead of through my tree, that's fine.> all three have my s-o-b already.
We need at least Tom's ACK for #3.
Mostly consists of ARM boot code, and submitter agreed it should go through ARM.
No longer applies, submitter asked for it to be dropped: http://lists.denx.de/pipermail/u-boot/2010-January/066696.html
4114 11/08 Magnus Lilja [U-Boot] [RFC 3/4] MX31: Activate NAND support for i.MX31 Litekit board. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71259 4274 11/11 Magnus Lilja [U-Boot] [PATCH v1 3/3] MX31: Activate NAND support for i.MX31 Litekit board. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71425 4350 11/12 Magnus Lilja [U-Boot] [PATCH v2 3/3] MX31: Activate NAND support for i.MX31 Litekit board. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71499
Superseded by 38a8b3eafb17d61690e5fc93e6dc45120f79d7d0
I don't have this e-mail anymore; if it's to go through NAND please resubmit (though patches which just turn on support in a given board config file should usually go through the board/arch tree IMHO).
This is an RFC patch; no ready-to-apply patch has been sent. Note that there are some minor changes needed to several drivers to go along with this patch.
It would be nice if such changes were proposed in Linux as well.
Changes requested here: http://lists.denx.de/pipermail/u-boot/2010-January/066061.html
BTW, is there any way from the gmane links to find replies, besides scanning the normal archives for the same subject?
6239 01/08 Vipin KUMAR [U-Boot] [PATCH v3 09/11] SPEAr : Support for nand driver http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73372 6315 01/11 Vipin KUMAR [U-Boot] [PATCH v4 05/12] SPEAr : nand driver support for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73458 6528 01/15 Vipin KUMAR [U-Boot] [PATCH v5 05/12] SPEAr : nand driver support for SPEAr SoCs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73676
Last version is 165fa406ad8c39c0c32a31476a8a9bda3db72851
Applied
Not a patch
Not a patch
-Scott
Dear Scott Wood,
Tom?
Agreed.
I think Tom should pick this up, too.
Thanks.
Yes, of course (which is why I prefer the gmane links): just clock on the link presented in the Subject: line. This will take you to the threaded display.
Ah, right. Thanks.
Applied
To your repo? I don't see it in mainline yet.
Thanks a lot for the feedback.
I see, thanks!
Applied
To my repo. I meant "applied just now due to the reminder", not "was already applied".
-Scott
On Jan 25, 2010, at 4:44 PM, Wolfgang Denk wrote:
Hi everybody,
here is a list of e-mail messages / patches, which I have marked as "open" in my folder. It would we be really helpful if both submitters and responsible custodians could take a look at these and provide feedback if these patches are still to be applied, or have been rejected or obsoleted or are queued in some repo to be pulled soon or whatever.
Thanks in advance.
The list is chronologically sorted (oldes entries first) and consist of
information I need) 2) date 3) Subject 4) Link to gmane mailing list archive
Still need work, review, or updating: 9 09/05 "Swarthout Edward [U-Boot] Image.c get_table_entry_name http://article.gmane.org/gmane.comp.boot-loaders.u-boot/46596 29 04/03 Dave Liu [U-Boot] [PATCH 2/2] 85xx: add the nfsboot/ramboot to default environment http://article.gmane.org/gmane.comp.boot-loaders.u-boot/57219 53 06/13 Dave Liu [U-Boot] [PATCH] 85xx: Enable the DDR3 SPD support for P2020DS board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/61457 74 08/04 Alex Dubov [U-Boot] [PATCH 2/2] stx: add support for AMC8548 board http://article.gmane.org/gmane.comp.boot-loaders.u-boot/65311 75 08/07 oakad@yahoo.com [U-Boot] Another patchset for STx AMC8548 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/65504 77 08/07 oakad@yahoo.com [U-Boot] [PATCH 2/4] stx: factor out LAW settings common for all STx boards http://article.gmane.org/gmane.comp.boot-loaders.u-boot/65507 5400 12/09 Li Yang [U-Boot] [PATCH 2/3] fdt: add fdt_del_node_by_path() API http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72523 (superceded by 5438) 5438 12/10 Li Yang [U-Boot] [PATCH 1/5] fdt: add fdt_del_node_by_path() API http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72559 5440 12/10 Li Yang [U-Boot] [PATCH 3/5] 85xx: add common serdes ports configuration code http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72557 5441 12/10 Li Yang [U-Boot] [PATCH 4/5] p2020: add serdes status code complying to fsl_serdes APIs http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72560 5442 12/10 Li Yang [U-Boot] [PATCH 5/5] p2020ds: use common code to initialize serdes ports http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72561 6181 01/07 Vivek Mahajan [U-Boot] [PATCH 1/2] 85xx/p1_p2_rdb: p1020: add muxed usb2 handling http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73316 6178 01/07 Li Yang [U-Boot] [PATCH 2/2] p2020ds: use maximum timeout for esdhc http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73304 7094 01/23 Ed Swarthout [U-Boot] [PATCH RFC] tsec: do not print Speed: if using netconsole http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74231
Already applied:
3491 10/29 Mingkai Hu [U-Boot] [PATCH] ppc/85xx: Clean up mpc8536DS PCI setup code http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70655 (3491 was superceded by 3933) 3933 11/04 Kumar Gala [U-Boot] [PATCH v2] ppc/85xx: Clean up mpc8536DS PCI setup code http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71083
Queued up in 85xx:
6182 01/07 Vivek Mahajan [U-Boot] [PATCH 2/2] 85xx/p1_p2_rdb: enable hwconfig http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73315 6512 01/15 Liu Yu [U-Boot] [PATCH v3] qe: fixup the snum for MPC8569 Rev2.0 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73658 4532 11/17 Dave Liu [U-Boot] [PATCH] Fix the local bus divider mapping http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71687 4985 11/27 Liu Yu [U-Boot] [PATCH 1/2] ppc/85xx: Add PIB/ATM support for MPC8569mds http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72127 4986 11/27 Liu Yu [U-Boot] [PATCH 2/2] ppc/85xx: Add ATM config for MPC8569MDS http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72126
6177 01/07 Li Yang [U-Boot] [PATCH 1/2] fsl_esdhc: fix wrong clock mask http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73305 (6959, 6960 are duplicates of 6177) 6959 01/21 Mingkai Hu [U-Boot] [PATCH] 85xx/eSDHC: fix eSDHC clock frequency mask http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74101 6960 01/21 "Liu Dave-R63238" Re: [U-Boot] [PATCH] 85xx/eSDHC: fix eSDHC clock frequency mask http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74102
6396 01/12 Kumar Gala [U-Boot] [PATCH 1/3] Add support to disable cpu's in multicore processors http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73543 6397 01/12 Kumar Gala [U-Boot] [PATCH 2/3] 86xx: Add support for 'cpu disable' command http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73545 6407 01/12 Kumar Gala [U-Boot] [PATCH v2 3/3] 85xx: Add support for 'cpu disable' command http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73556 6465 01/13 Kumar Gala [U-Boot] [PATCH] ppc/p4080: Fix mask width of RCW fields MEM_PLL_RAT, SYS_PLL_RAT http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73614 7178 01/25 Kumar Gala [U-Boot] [PATCH] Revert "ppc/p4080: Fix reporting of PME & FM clock frequencies" http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74311
{snip}
Hi Kumar,
I got no feedback on this series for almost 2 months. Do you have further comment?
- Leo
On Jan 25, 2010, at 10:23 PM, Li Yang-R58472 wrote:
{snip}
Hi Kumar,
I do. I want to look at what we need for p4080 as well before these go in. We will look at these for the next merge window.
- k
submitters
or
whatever.
This patch is obsoleted by the "ppc: Enable full relocation to RAM" series. I've verified the fix.
I have not seen any comments, but netconsole is unusable for any 85xx board using tsec driver without a fix to stop the messages.
-Ed
Dear "Swarthout Edward L-SWARTHOU",
In message B52955765C54604CB1A62A9967F22C7304DAC314@az33exm20.fsl.freescale.net you wrote:
Thanks.
Ben?
Dear Kumar Gala,
In message C4E98F5C-EE68-4B39-B86D-639FE37443CA@kernel.crashing.org you wrote:
Thanks.
Already applied:
3491 10/29 Mingkai Hu [U-Boot] [PATCH] ppc/85xx: Clean up mpc8536DS PCI setup code > http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70655 (3491 was superceded by 3933) 3933 11/04 Kumar Gala [U-Boot] [PATCH v2] ppc/85xx: Clean up mpc8536DS PCI setup code > http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71083
Applied? I don;t see it in mainline yet.
Queued up in 85xx:
Thanks a lot for the feedback!
On Jan 26, 2010, at 1:07 PM, Wolfgang Denk wrote:
Dear Kumar Gala,
Thanks.
Already applied:
commit 8a414c4258aeeab93fb83fad0544894597c8bd35 Author: Mingkai Hu Mingkai.hu@freescale.com Date: Wed Oct 28 10:49:31 2009 +0800
ppc/85xx: Clean up MPC8536 DS PCI setup code
Use new fsl_pci_init_port() that reduces amount of duplicated code in the board ports, use IO accessors and clean up printing of status info.
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org
- k
Dear Kumar Gala,
In message 9C694FEF-D566-4F34-A98B-9B5943D445E7@kernel.crashing.org you wrote:
Already applied:
Argh. Please do not change the subject lines.
3882 11/03 Peter Tyser [U-Boot] [PATCH] tsec: Force TBI PHY to 1000Mbps full duplex in SGMII mode http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71031
Waiting for ack/nack. Andy sounded OK with the change on IRC.
4146 11/09 Peter Tyser [U-Boot] [PATCH 1/5] tsec: Clean up Broadcom PHY status parsing http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71295 4147 11/09 Peter Tyser [U-Boot] [PATCH 2/5] tsec: Make functions/data static when possible http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71298 4148 11/09 Peter Tyser [U-Boot] [PATCH 3/5] tsec: General cleanup http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71299 4149 11/09 Peter Tyser [U-Boot] [PATCH 4/5] tsec: Add support for using the BCM5482 PHY in fiber mode http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71296 4150 11/09 Peter Tyser [U-Boot] [PATCH 5/5] tsec: Add TSEC_FIBER flag http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71297
Waiting for ack/nack (Andy and/or Kumar?). 1-3 seem pretty straightforward, 4-5 a bit more involved.
I plan on sending a 2nd version of these after most of the other patches have been applied or rejected as its going to break lots of outstanding patches due to directory reorganization.
This series wasn't in Wolfgang's list and is waiting for an ack/nack: http://www.mail-archive.com/u-boot@lists.denx.de/msg25115.html
Best, Peter
Hi Wolfgang and all others,
Comments on my patches:
This one is still valid, and of course, I'd like it mainlined. I've got no feedback on this one though. (Apart from a few users off-list, that also wanted to use this feature).
This one can be disregarded. This was just a reply to my own patch, to bump it and hopefully get some comments on it.
Best regards, Anders Darander
Dear Anders Darander,
In message 2c9a759f1001252324s6a7ee6dbr63df260ff4475f69@mail.gmail.com you wrote:
6492 01/14 Anders Darander [U-Boot] [PATCH] Add bootcount to> AT91 http://article.gmane.org/gmane.comp.boot-loaders.%3E u-boot/73640
OK, that's for Tom, then.
Thanks.
4051 11/06 Alessandro Rubini [U-Boot] [PATCH V3] Nomadik: fix reset_timer() http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71200
Superseded by V4 below.
This is needed for saveenv to work reliably. I'd like it to be merged
Then there is my sequence of 9 nhk patches. V2 is obsoleted by V3 which fixed structure definitions and removed a few debugging printf.
So these are obsolete:
As for V3 this is the status:
cover letter, please discard
Needed for correct bringup of diplay in 7/9 and 9/9.
These two have been applied to u-boot-video/next by Anatolij (Dec 12). Still in next branch.
These depend on the ones in video/next and apply cleanly to the master branch as of today. There is one minor delay about lcd_setfgcolor/lcd_setbgcolor that was sorted out by Anatolij on Dec 12 ("lcd: remove CONFIG_ATMEL_LCD ifdefs from lcd_setfgcolor"). But his patch isn't in master yet nor in the video branches.
Thanks /alessandro
[damn, I re-read it over and over before sending....]
It was a minor __detail__. No delay issues here. If his patch of Dec12 goes in, a one line cleanup in my own patch will follow.
Sorry for the mistype /alessandro
Dear Alessandro Rubini,
Me too.
Tom?
OK. As long as I haven't pulled, they will remain open for me.
OK, so this is all work for Anatolij and Tom.
Thanks a lot for the review & summary.
Hi Wolfgang,
these are still valid and are touching board files only and are not present in u-boot-ti nor u-boot-arm repository. I would be happy if you could apply them directly in case the responsible custodian (Cc'ed) remains in silence.
Thank you, ladis
Dear Ladislav Michl,
Sandeep, could you please comment?
Subject: Re: [U-Boot] [STATUS] Patch status update
boot/73165
CONFIG_CMD_JFFS2
boot/73166
boot/73164
present
apply
silence.
I have pushed these updates.
These were sent over the holidays and missed me completely.
Thanks, Sandeep
Dear Sandeep,
In message 0554BEF07D437848AF01B9C9B5F0BC5D985EE2F3@dlee01.ent.ti.com you wrote:
Thanks. Please send a pull request to Tom when you think you are ready.
No problem. I try to keep an eye on these things.
On Tue, Jan 26, 2010 at 11:52:23PM +0100, Wolfgang Denk wrote:
Dear Sandeep,
Thank you.
FYI, there are more patches pending, I just didn't have time to look closely where a problem is. Will send them after more testing, probably later today. Also sorry for pushing on you both as I do not have too good experince with merging board patches - trying to fully sync since 2005...
Best regards, ladis
Hi Wolfgang,
Hi everybody,
Thanks in advance.
- date
- Subject
<snip>
2811 10/19 Shinya Kuribayash [U-Boot] [PATCH] qemu_mips: Fix CONFIG_NET_MULTI build warning http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70008
NAK'd
3760 11/02 "Seunghyeon Rhee [U-Boot] [PATCH] NET: Fix MAC addr handling for smc911x http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70913
Will apply ASAP
I can take this one I guess
I'll look through this patch set and ACK/NAK. Any technical input from Freescale folks would be helpful <snip>
Will apply
Will apply
Superseded by others. Latest is #7139
Superseded by #6531
Will review
This one appears to be feedback for 6318. Don't know why it doesn't show up as a reply
Will apply
Will review
Will review
This is feedback for another patch
Will review
I need to sort out the fec_mxc patches by Stefano & John, will supply feedback or ACK/NAK
Applied to net repo
Will review
Will review
Have provided feedback
regards, Ben
Dear Ben Warren,
NAK'd
OK.
Will apply ASAP
OK.
Yes, please.
Thanks.
Because Tom mess^H^H^H^Htried different things with his mailer ;-)
Thanks a lot for the summary and feedback.
Hello Wolfgang,
Hi everybody,
Thanks in advance.
<snip>
This is obsoleted by the following patch.
Still to be applied, waiting for response.
Regards, Daniel Gorsulowski
Dear Daniel Gorsulowski,
Thanks.
Right, this should be in Tom's queue.
Hi Wolfgang,
On Monday 25 January 2010 23:44:48 Wolfgang Denk wrote:
82 08/24 Renato Andreola [U-Boot] PATCH mtd CFI flash: timeout calculation underflow if imprecise 1kHz timer: fix http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0
Patch still needs some reworking from author. Waiting for a new version. Renato, could you send a new version soon? Thanks.
This is superseeded by the patch series below.
Not a patch, just a cover letter. This is the patch series that superseeded the patch above. It's already in mainline via USB repository.
This is not a patch. A reported problem not resolved yet. Could be that it's not CFI driver related but a problem with the SoC support (custom PPC440 system, not AMCC).
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Dear Stefan Roese,
In message 201001261102.04837.sr@denx.de you wrote:
Hi Wolfgang,
OK.
Right.
Thanks for the feedback!
59 07/08 Matthias Weisser [U-Boot] [PATCH RESEND 1/3] arm: Added support for MB86R01 'Jade' SoC http://article.gmane.org/gmane.comp.boot-loaders.u-boot/63112
Can be dropped. I will come up with a new version of this patch set.
I don't received feedback on this an would like to see it mainlined.
Dear Matthias =?ISO-8859-1?Q?Wei=DFer?=,
Done, thanks.
This should be in Anatolij's queue, then.
Hello Wolfgang,
Thanks in advance.
28 03/24 Heiko Schocher i2c: rework multibus/multiadapter functionality http://article.gmane.org/gmane.comp.boot-loaders.u-boot/56416
I just need (hopefully only) one more merge window, to integrate new boards, 1 or 2 new i2c driver, and update README. Then it should be ready for using the following merge window as the last chance for comments, testing, and then it should be ready for mainline ... actual code is accessible at:
http://git.denx.de/?p=u-boot/u-boot-i2c.git;a=shortlog;h=refs/heads/multibus...
3611 10/30 Javier Martin [U-Boot] [u-boot][PATCH][2/2] i2c_mxc: Add I2C support for i.MX27 chip processor. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70770
Discussion ended here:
http://lists.denx.de/pipermail/u-boot/2009-November/063627.html
3703 10/31 Tom Rix [U-Boot] [PATCH] Add I2C multibus support for OMAP2/3 boards http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70856
This patch is in mainline (after some discussion, new patch made from Dirk Behme)
http://git.denx.de/?p=u-boot.git;a=commitdiff;h=1d2e96de56cc57e25a19bc40d297...
Acked from me, see:
http://lists.denx.de/pipermail/u-boot/2010-January/066025.html
Acked from me, see:
http://lists.denx.de/pipermail/u-boot/2010-January/066236.html
see v4 ... or should I Ack each new version?
This patch is Acked from me.
This patch is in discussion, reviewed, waiting for new version.
got no comments for this 2 patches ...
bye Heiko
Dear Heiko Schocher,
Feel free to prepare this early; as soon a -rc1 is out we can have a "next" branch where we could put this in.
So what do we do about it? Drop it?
Thanks.
Acked from me, see:
OK. Sandeep will pick this up, then.
no, not needed - actually alreay in mainline.
See above.
OK.
This is for Ben.
And this for Kim.
Which means Ben and Kim will pull them in soon - I hope :-)
Thanks for the review.
Hello Wolfgang,
Hmm.. it;s not the problem, that the merge window is to long, instead I am to slow ... Sorry ... :-(
But if testers want to step in, the above tree should be in a good state for testing ;-)
Hmm.. I looked in this discussion, end if Sandeep or Tom has nothing against this __REG defines, I think it can go in mainline.
bye, Heiko
On 25/01/10 22:44, Wolfgang Denk wrote:
5369 12/08 Nick Thompson [U-Boot] [PATCH RFC] NAND: Improve read performance from Large Page NAND devices http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72491
This one is not ready yet, some other drivers need updating.
5446 12/10 Nick Thompson [U-Boot] [PATCH] da830evm: Use table driven pin mux configuration http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72566
Obsoleted by a v2 patch below.
Ben has said today that he is picking this one up.
This was applied to u-boot-ti a few days ago.
Dear Nick Thompson,
OK.
OK.
Thanks for the review!>
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Wolfgang Denk Sent: Tuesday, January 26, 2010 4:15 AM To: u-boot@lists.denx.de Subject: [U-Boot] [STATUS] Patch status update
Hi everybody,
Thanks in advance.
date
Subject
8 08/28 Markus Kammerstet [U-Boot] PATCH: U-Boot
support for Olimex SAM9L-9260 development board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/46038 9 09/05 "Swarthout Edward [U-Boot] Image.c get_table_entry_name
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/46596 12 11/13 Chaofu Chen [U-Boot] [PATCH] bug fix for the delay function of ARM s3c44b0
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/50104 17 03/03 Jean-Christophe P [U-Boot] [PATCH 1/9] at91sam9/cap9: use define instead hardcoded value for the USB_OHCI_REGS_BA
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/55481 26 03/20 Richard Retanubun [U-Boot] [PATCH] Coldfire: interrupts: Add watchdog auto reset to dtimer_interrupt
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/56267 27 03/23 Richard Retanubun [U-Boot] [PATCH] Coldfire: cleanup compiler warning for lib-m68k unused variables.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/56390 28 03/24 Heiko Schocher i2c: rework multibus/multiadapter functionality
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/56416 29 04/03 Dave Liu [U-Boot] [PATCH 2/2] 85xx: add the nfsboot/ramboot to default environment
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/57219 33 04/18 Jean-Christophe P [U-Boot] [PATCH] omap2420h4: move arch pre lowlevel init to board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/58008 36 05/01 Jean-Christophe P [U-Boot] [PATCH 3/4] s3c4510b: move interrupts code to soc
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/58874 37 05/01 Jean-Christophe P [U-Boot] [PATCH 4/4] lpc2292: move interrupts code to soc
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/58873 53 06/13 Dave Liu [U-Boot] [PATCH] 85xx: Enable the DDR3 SPD support for P2020DS board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/61457 59 07/08 Matthias Weisser [U-Boot] [PATCH RESEND 1/3] arm: Added support for MB86R01 'Jade' SoC
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/63112 64 07/14 Dimitar Dimitrov [U-Boot] [PATCH 02/03 v2] Add support for Olimex SAM9-L9261 SBC
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/63724 65 07/14 Dimitar Dimitrov [U-Boot] [PATCH 03/03 v2] Add support for Olimex SAM9-L9260 SBC
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/63725 66 07/15 Dimitar Dimitrov [U-Boot] [PATCH] Add inverted clock polarity support for Atmel LCD driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/63774 70 07/28 TsiChung Liew [U-Boot] [PATCH] ColdFire: Fix missing _IO_BASE which caused compile error
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/65083 71 07/28 TsiChung Liew [U-Boot] [PATCH] ColdFire: Fix compile warning messages
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/65084 74 08/04 Alex Dubov [U-Boot] [PATCH 2/2] stx: add support for AMC8548 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/65507 82 08/24 Renato Andreola [U-Boot] PATCH mtd CFI flash: timeout calculation underflow if imprecise 1kHz timer: fix http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0 83 08/24 Renato Andreola [U-Boot] PATCH - Added support to YANU Nios2 uart (02)
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/66673 84 08/26 Albin Tonnerre [U-Boot] [PATCH 1/2] drivers/mmc/atmel_mci.c: port to the new CONFIG_GENERIC_MMC API
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/66798 85 08/26 Albin Tonnerre [U-Boot] [PATCH 2/2] AVR32: update to use CONFIG_GENERIC_MMC
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/66799 86 09/01 Albin Tonnerre [U-Boot] [PATCH] AT91: Add SD/MMC controller support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/67006 124 09/05 Jean-Christophe P [U-Boot] [PATCH] at91: move base address define to soc header
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/67393 125 09/07 "Berns" [U-Boot] autoscr command failure saveenv dataflash
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/67483 239 09/08 Albin Tonnerre [U-Boot] [PATCH v3] AT91: Add SD/MMC controller support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/67583 1092 09/21 ? ? [U-Boot] An error in u-boot-2009.08/cpu/arm920t/start.S
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/68400 1182 09/21 Philippe De Muyte [U-Boot] [PATCH MAKEALL coldfire] : Fix start.S:Error: Conversion of PC relative displacement t
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/68486 1884 10/01 Sebastian Heutlin [U-Boot] [PATCH v3] AT91: Add SD/MMC controller support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/69142 2055 10/05 Dipen Dudhat [U-Boot] [PATCH v3] ppc/85xx: PIO Support for FSL eSDHC Controller Driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/69297 2432 10/12 Kyungmin Park [U-Boot] [PATCH] Reduce apollon OneNAND IPL code
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/69648 2786 10/19 Mark Jackson [U-Boot] [PATCH] avr32 portmux : fix incorrect port mask
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/69985 2811 10/19 Shinya Kuribayash [U-Boot] [PATCH] qemu_mips: Fix CONFIG_NET_MULTI build warning
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70008 3449 10/28 Wolfgang Wegner [U-Boot] [PATCH] MCF532x: make icache_enable use CONFIG_SYS_SDRAM_SIZE
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70615 3450 10/28 Wolfgang Wegner [U-Boot] [PATCH] allow MCF532x to use CONFIG_MONITOR_IS_IN_RAM
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70616 3491 10/29 Mingkai Hu [U-Boot] [PATCH] ppc/85xx: Clean up mpc8536DS PCI setup code
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70655 3610 10/30 Javier Martin [U-Boot] [u-boot] [PATCH][1/2] mx27: Add necessary defines and helper functions to support I2C
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70769 3611 10/30 Javier Martin [U-Boot] [u-boot][PATCH][2/2] i2c_mxc: Add I2C support for i.MX27 chip processor.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70770 3620 10/30 Dirk Behme [U-Boot] Beagle Zippy: OMAP3 SPI code for U-Boot?
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70779 3703 10/31 Tom Rix [U-Boot] [PATCH] Add I2C multibus support for OMAP2/3 boards
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70856 3760 11/02 "Seunghyeon Rhee [U-Boot] [PATCH] NET: Fix MAC addr handling for smc911x
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70913 3784 11/02 Wolfgang Wegner [U-Boot] [PATCH] non-blocking flash write/erase/status check functions
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70937 3882 11/03 Peter Tyser [U-Boot] [PATCH] tsec: Force TBI PHY to 1000Mbps full duplex in SGMII mode
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71031 3893 11/04 Terry Lv [U-Boot] [PATCH] Improve read performance of generic mmc.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71042 3933 11/04 Kumar Gala [U-Boot] [PATCH v2] ppc/85xx: Clean up mpc8536DS PCI setup code
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71083 4009 11/05 "kevin.morfitt@fe [U-Boot] [PATCH ARM] Update the s3c2410 nand driver from linux-2.6.31.5
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71157 4051 11/06 Alessandro Rubini [U-Boot] [PATCH V3] Nomadik: fix reset_timer()
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71200 4114 11/08 Magnus Lilja [U-Boot] [RFC 3/4] MX31: Activate NAND support for i.MX31 Litekit board.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71259 4146 11/09 Peter Tyser [U-Boot] [PATCH 1/5] tsec: Clean up Broadcom PHY status parsing
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71297 4237 11/11 Mike Rapoport [U-Boot] [PATCH] omap3: fix bi_dram initialization when CONFIG_NR_DRAM_BANKS is 1
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71382 4274 11/11 Magnus Lilja [U-Boot] [PATCH v1 3/3] MX31: Activate NAND support for i.MX31 Litekit board.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71499 4452 11/15 Dirk Behme [U-Boot] [PATCH] OMAP3: BeagleBoard: Add expansion board auto detection
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71608 4471 11/16 Mike Rapoport [U-Boot] [PATCHi v5] OMAP3: add CM-T35 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71628 4493 11/16 Tom Rix [U-Boot] [PATCH] OMAP3 Move declaration of gpmc_cfg.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71649 4532 11/17 Dave Liu [U-Boot] [PATCH] Fix the local bus divider mapping
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71687 4580 11/18 Mike Rapoport [U-Boot] [PATCH v6] OMAP3: add CM-T35 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71732 4592 11/18 To:u-boot@lists.d [PATCH] Clarify applicable licensing terms in COPYING file.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71743 4598 11/18 hvaibhav@ti.com [U-Boot] [PATCH V3] OMAP3EVM: Added NAND support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71749 4638 11/19 Terry Lv [U-Boot] [PATCH] Save environment data to mmc.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71792 4639 11/19 Terry Lv [U-Boot] [PATCH] Improve read performance of generic mmc.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71791 4698 11/19 "Robert P. J. Day [U-Boot] [PATCH v2] BeagleBoard: Add a comment explaining the use of "OMAP34XX" macros.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71853 4702 11/20 Ajay Kumar Gupta [U-Boot] [PATCH] omap3evm: Add board revision function
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71857 4803 11/23 hvaibhav@ti.com [U-Boot] [PATCH V4] OMAP3EVM: Added NAND support
This should get merged. I don't see any issues with it.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/71952 4930 11/25 Alessandro Rubini [U-Boot] [PATCH V2 0/9] display and keypad support for nhk8815
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72073 4932 11/25 Alessandro Rubini [U-Boot] [PATCH V2 2/9] video: add amba-clcd prime-cell
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72075 4933 11/25 Alessandro Rubini [U-Boot] [PATCH V2 3/9] include/nomadik.h: add physical address for cldc
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72076 4934 11/25 Alessandro Rubini [U-Boot] [PATCH V2 4/9] drivers/misc: add stmpe2401 port extender and keypad controller
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72077 4935 11/25 Alessandro Rubini [U-Boot] [PATCH V2 5/9] nhk8815.h: define we need stmpe
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72078 4936 11/25 Alessandro Rubini [U-Boot] [PATCH V2 6/9] lcd: make 16bpp work
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72079 4937 11/25 Alessandro Rubini [U-Boot] [PATCH V2 7/9] nhk8815: added keypad
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72080 4938 11/25 Alessandro Rubini [U-Boot] [PATCH V2 8/9] nhk8815: start lower in RAM, so the 800x480 frame buffer fits
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72081 4939 11/25 Alessandro Rubini [U-Boot] [PATCH V2 9/9] nhk8815: added lcd support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72082 4940 11/25 Alessandro Rubini [U-Boot] [PATCH V4] Nomadik: fix reset_timer()
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72083 4985 11/27 Liu Yu [U-Boot] [PATCH 1/2] ppc/85xx: Add PIB/ATM support for MPC8569mds
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72126 5080 12/01 Albert Aribaud [U-Boot] [PATCH V3 1/3] Initial support for Marvell Orion5x SoC
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72220 5081 12/01 Albert Aribaud [U-Boot] [PATCH V3 2/3] Add Orion5x support to 16550 device driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72219 5259 12/05 Alessandro Rubini [U-Boot] [PATCH V3 0/9] display and keypad support for nhk8815
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72395 5260 12/05 Alessandro Rubini [U-Boot] [PATCH V3 1/9] nhk8815: change the order of initialization
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72396 5261 12/05 Alessandro Rubini [U-Boot] [PATCH V3 2/9] video: add amba-clcd prime-cell
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72397 5262 12/05 Alessandro Rubini [U-Boot] [PATCH V3 3/9] include/nomadik.h: add physical address for cldc
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72398 5263 12/05 Alessandro Rubini [U-Boot] [PATCH V3 4/9] drivers/misc: add stmpe2401 port extender and keypad controller
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72399 5264 12/05 Alessandro Rubini [U-Boot] [PATCH V3 5/9] nhk8815.h: define we need stmpe
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72400 5265 12/05 Alessandro Rubini [U-Boot] [PATCH V3 6/9] lcd: make 16bpp work
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72401 5266 12/05 Alessandro Rubini [U-Boot] [PATCH V3 7/9] nhk8815: added keypad
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72402 5267 12/05 Alessandro Rubini [U-Boot] [PATCH V3 8/9] nhk8815: start lower in RAM, so the 800x480 frame buffer fits
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72403 5268 12/05 Alessandro Rubini [U-Boot] [PATCH V3 9/9] nhk8815: added lcd support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72404 5369 12/08 Nick Thompson [U-Boot] [PATCH RFC] NAND: Improve read performance from Large Page NAND devices
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72491 5400 12/09 Li Yang [U-Boot] [PATCH 2/3] fdt: add fdt_del_node_by_path() API
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72523 5438 12/10 Li Yang [U-Boot] [PATCH 1/5] fdt: add fdt_del_node_by_path() API
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72561 5443 12/10 Wolfgang Wegner [U-Boot] [PATCH v2] add ability to handle compressed images to imxtract
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72562 5446 12/10 Nick Thompson [U-Boot] [PATCH] da830evm: Use table driven pin mux configuration
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72566 5514 12/13 Peter Tyser [U-Boot] [PATCH 00/17] Reorganize directory structure
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72675 5515 12/13 Peter Tyser [U-Boot] [PATCH 01/17] Move lib_<ARCH> directories to arch/<ARCH>/lib
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72676 5516 12/13 Peter Tyser [U-Boot] [PATCH 02/17] Rename lib_generic/ to lib/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72636 5518 12/13 Peter Tyser [U-Boot] [PATCH 04/17] Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72637 5519 12/13 Peter Tyser [U-Boot] [PATCH 05/17] Move architecture-specific includes to arch/$ARCH/include/asm
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72677 5520 12/13 Peter Tyser [U-Boot] [PATCH 06/17] ppc: Move appropriate cpu/ dirs to arch/ppc/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72678 5521 12/13 Peter Tyser [U-Boot] [PATCH 07/17] sh: Move appropriate cpu/ dirs to arch/sh/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72638 5522 12/13 Peter Tyser [U-Boot] [PATCH 08/17] arm: Move appropriate cpu/ dirs to arch/arm/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72679 5523 12/13 Peter Tyser [U-Boot] [PATCH 09/17] m68k: Move appropriate cpu/ dirs to arch/m68k/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72639 5524 12/13 Peter Tyser [U-Boot] [PATCH 10/17] blackfin: Move appropriate cpu/ dirs to arch/blackfin/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72640 5525 12/13 Peter Tyser [U-Boot] [PATCH 11/17] mips: Move appropriate cpu/ dirs to arch/mips/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72641 5526 12/13 Peter Tyser [U-Boot] [PATCH 12/17] avr32: Move appropriate cpu/ dirs to arch/avr32/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72642 5527 12/13 Peter Tyser [U-Boot] [PATCH 13/17] microblaze: Move appropriate cpu/ dirs to arch/microblaze/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72643 5528 12/13 Peter Tyser [U-Boot] [PATCH 14/17] sparc: Move appropriate cpu/ dirs to arch/sparc/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72645 5529 12/13 Peter Tyser [U-Boot] [PATCH 15/17] nios: Move appropriate cpu/ dirs to arch/nios/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72644 5530 12/13 Peter Tyser [U-Boot] [PATCH 16/17] nios2: Move appropriate cpu/ dirs to arch/nios2/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72647 5531 12/13 Peter Tyser [U-Boot] [PATCH 17/17] i386: Move appropriate cpu/ dirs to arch/i386/cpu/
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72646 5589 12/15 Sanjeev Premi [U-Boot] [PATCH 1/2] omap3: Identify the CPU in arch_cpu_init()
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72707 5590 12/15 Sanjeev Premi [U-Boot] [PATCH 2/2] omap3: Identify cpu in s_init()
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72709 5608 12/16 Sanjeev Premi [U-Boot] [PATCH 1/4] AM35x: Introduce support for AM35x processors
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72727 5611 12/16 Sanjeev Premi [U-Boot] [PATCH 4/4] OMAP3, AM35x: Update the checks for CPU revision
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72729 5668 12/16 Dirk Behme [U-Boot] [PATCH] OMAP3: Beagle: Update revision detection
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72786 5717 12/16 Mike Frysinger [U-Boot] [PATCH 2/5] usb: musb: make fifo support configurable
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72838 5718 12/16 Mike Frysinger [U-Boot] [PATCH 3/5] usb: musb: make multipoint optional
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72837 5719 12/16 Mike Frysinger [U-Boot] [PATCH 4/5] usb: musb: change rxcsr register from write to read/modify/write
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72839 5720 12/16 Mike Frysinger [U-Boot] [PATCH 5/5] usb: musb: add support for Blackfin MUSB
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72840 5731 12/17 Semih Hazar [U-Boot] [PATCH] Add misc_init_r support to AVR32
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72850 5732 12/17 Semih Hazar [U-Boot] [PATCH] macb: Fix mii_phy_read and mii_phy_write functions
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72851 5733 12/17 Semih Hazar [U-Boot] [PATCH] Remove duplicate #defines in atngw100.h and mimc200.h
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72852 5738 12/17 Sriramakrishnan [U-Boot] [PATCHv2] OMAP3: Increase bootargs string length.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72857 5804 12/18 Himanshu Chauhan [U-Boot] [PATCH]: U-Boot build failure with CONFIG_SYS_NO_FLASH defined for qemu-mips.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72923 5809 12/18 Nick Thompson [U-Boot] [PATCH v3] TI: DaVinci: Updating EMAC driver for DM365, DM646x and DA8XX
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72929 5811 12/18 Sudhakar Rajashek [U-Boot] [PATCH v2 1/3] TI: DaVinci: Prepare for da850 support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72932 5812 12/18 Sudhakar Rajashek [U-Boot] [PATCH v2 2/3] TI: DaVinci: Add board specific code for da850 EVM
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72933 5813 12/18 Sudhakar Rajashek [U-Boot] [PATCH v2 3/3] TI: DaVinci: Create configuration file for da850 EVM
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72934 5828 12/19 Himanshu Chauhan [U-Boot] [PATCH][RESEND]: Fix for U-Boot build failure with CONFIG_SYS_NO_FLASH defined for qem
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/72948 5951 12/23 Sanjeev Premi [U-Boot] [PATCH 0/2] omap3: Remove extern declarations from headers
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73072 5952 12/23 Sanjeev Premi [U-Boot] [PATCH 1/2] omap3: Remove externs from config files
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73073 5953 12/23 Sanjeev Premi [U-Boot] [PATCH 2/2] omap3: Remove multiple extern decls for gpmc_cfg
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73074 5957 12/23 Vaibhav Hiremath [U-Boot] [PATCH 3/3] AM35x: Add support for EMIF4
I will submit the next version of patch within couple of days.
Thanks, Vaibhav
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73076 5962 12/23 Matthias Kaehlcke [U-Boot] [PATCH 0/3] ARM: Add support for EDB93XX boards [rev2]
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73085 5963 12/23 Matthias Kaehlcke [U-Boot] [PATCH 1/3] ARM: Add support for EP93XX SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73086 5964 12/23 Matthias Kaehlcke [U-Boot] [PATCH 2/3] Add EP93XX ethernet driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73087 5965 12/23 Matthias Kaehlcke [U-Boot] [PATCH 3/3] Add support for EDB93XX boards
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73088 5974 12/24 Marcel Ziswiler [U-Boot] [PATCH 0/3] Monahan/PXA3xx: integrate Linux NAND controller driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73094 5975 12/24 Marcel Ziswiler [U-Boot] [PATCH 1/3] Monahan/PXA3xx: integrate Linux NAND controller driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73095 5976 12/24 Marcel Ziswiler [U-Boot] [PATCH 2/3] delta: use new generic NAND controller driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73096 5977 12/24 Marcel Ziswiler [U-Boot] [PATCH 3/3] zylonite: use new generic NAND controller driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73097 6011 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 1/4] s3c24x0 white-space clean-up part 1
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73133 6012 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 2/4] s3c24x0 white-space clean-up part 2
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73134 6013 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 3/4] s3c24x0 code-style clean-up
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73135 6014 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 4/4] Change s3c24x0 register struct members to lower case
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73136 6043 12/30 Ladislav Michl [U-Boot] [PATCH] NetStar: Remove debug junk leaked into eeprom utility
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73165 6044 12/30 Ladislav Michl [U-Boot] [PATCH] NetStar: Disable CONFIG_CMD_JFFS2
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73166 6045 12/30 Ladislav Michl [U-Boot] [PATCH] NetStar: make crcit utility more readable.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73164 6069 01/03 Quentin Armitage [U-Boot] Issue in drivers/mmc/mmc.c
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73195 6070 01/03 Quentin Armitage [U-Boot] There appears to be the potential for an undetected error in fs/ext2/dev.c ext2fs_devr
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73196 6126 01/05 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 4/4] Enable I2C bus switching
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73260 6139 01/05 "Chris Zhang" [U-Boot] ppc440epx(sequoia) USB ehci fix.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73273 6154 01/06 Khasim Syed Moham [U-Boot] TI:OMAP:[PATCH 2/4] Support 720Mhz configuration for OMAP35xx
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73288 6161 01/06 Chris Zhang [U-Boot] [PATCH 0/3] PPC440EPX(sequoia) USB EHCI support.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73295 6177 01/07 Li Yang [U-Boot] [PATCH 1/2] fsl_esdhc: fix wrong clock mask
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73305 6178 01/07 Li Yang [U-Boot] [PATCH 2/2] p2020ds: use maximum timeout for esdhc
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73304 6181 01/07 Vivek Mahajan [U-Boot] [PATCH 1/2] 85xx/p1_p2_rdb: p1020: add muxed usb2 handling
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73316 6182 01/07 Vivek Mahajan [U-Boot] [PATCH 2/2] 85xx/p1_p2_rdb: enable hwconfig
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73315 6183 01/07 Sudhakar Rajashek [U-Boot] [PATCH v5] TI DaVinci: Driver for the davinci SPI controller
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73317 6200 01/07 Thomas Petazzoni [U-Boot] [PATCH] Support for Calao USB A9263 board based on AT91SAM9263 CPU
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73336 6220 01/08 Mike Frysinger [U-Boot] [PATCH] getline: split out for darwin systems
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73355 6227 01/08 Mike Frysinger [U-Boot] [PATCH] jffs2: fix hangs/crashs when not using CONFIG_JFFS2_PART_SIZE
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73363 6230 01/08 Vipin KUMAR [U-Boot] [PATCH v3 00/11] SPEAr : Adding support for SPEAr SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73366 6231 01/08 Vipin KUMAR [U-Boot] [PATCH v3 01/11] SPEAr : Adding README.spear in doc
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73367 6232 01/08 Vipin KUMAR [U-Boot] [PATCH v3 02/11] SPEAr : Adding basic support for SPEAr600
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73369 6233 01/08 Vipin KUMAR [U-Boot] [PATCH v3 03/11] SPEAr : Adding basic support for SPEAr300
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73368 6234 01/08 Vipin KUMAR [U-Boot] [PATCH v3 04/11] SPEAr : Adding basic support for SPEAr310
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73370 6235 01/08 Vipin KUMAR [U-Boot] [PATCH v3 05/11] SPEAr : Adding basic support for SPEAr320
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73371 6237 01/08 Vipin KUMAR [U-Boot] [PATCH v3 07/11] SPEAr : Support for HW macid read/write from i2c memory
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73373 6238 01/08 Vipin KUMAR [U-Boot] [PATCH v3 08/11] SPEAr : Support for serial memory interface driver and serial NOR fla
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73374 6239 01/08 Vipin KUMAR [U-Boot] [PATCH v3 09/11] SPEAr : Support for nand driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73372 6240 01/08 Vipin KUMAR [U-Boot] [PATCH v3 10/11] SPEAr : Support for usbd driver and usbtty support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73377 6241 01/08 Vipin KUMAR [U-Boot] [PATCH v3 11/11] SPEAr : Support for cfi driver and parallel NOR flash
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73375 6244 01/08 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 1/4] OMAP3 Beagle Update revision detection
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73380 6264 01/09 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH] Add support for 720Mhz
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73401 6265 01/09 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH] Add DSS driver for OMAP3
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73402 6267 01/09 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH] Enable DSS driver for Beagle
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73404 6278 01/09 Albin Tonnerre [PATCH v2] Add support for the Calao QIL-A9G20 and QIL-A9260 boards
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73415 6279 01/09 Mike Frysinger [U-Boot] [PATCH] usb: musb: add virtual root hub control support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73416 6287 01/10 Albert Aribaud [U-Boot] [PATCH V4 2/3] Add Orion5x support to 16550 device driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73427 6291 01/11 Li Wenhao [U-Boot] [PATCH] Add Yaffs2 image writing support.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73432 6301 01/11 Sudhakar Rajashek [U-Boot] [PATCH v6] TI DaVinci: Driver for the davinci SPI controller
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73445 6304 01/11 Prathap Srinivas [U-Boot] [PATCH v2] musb: Add host support for DM365 EVM
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73446 6310 01/11 Vipin KUMAR [U-Boot] [PATCH v4 00/12] Support for SPEAr SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73455 6311 01/11 Vipin KUMAR [U-Boot] [PATCH v4 01/12] SPEAr : Adding README.spear in doc
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73452 6312 01/11 Vipin KUMAR [U-Boot] [PATCH v4 02/12] SPEAr : Adding basic SPEAr architecture support.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73453 6313 01/11 Vipin KUMAR [U-Boot] [PATCH v4 03/12] SPEAr : i2c driver support added for SPEAr SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73454 6314 01/11 Vipin KUMAR [U-Boot] [PATCH v4 04/12] SPEAr : smi driver support for SPEAr SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73457 6315 01/11 Vipin KUMAR [U-Boot] [PATCH v4 05/12] SPEAr : nand driver support for SPEAr SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73458 6316 01/11 Vipin KUMAR [U-Boot] [PATCH v4 06/12] SPEAr : usbd driver support for SPEAr SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73459 6317 01/11 Vipin KUMAR [U-Boot] [PATCH v4 07/12] SPEAr : Support added for SPEAr600 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73456 6318 01/11 Vipin KUMAR [U-Boot] [PATCH v4 08/12] SPEAr : Support for HW mac id read/write from i2c mem
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73460 6319 01/11 Vipin KUMAR [U-Boot] [PATCH v4 09/12] SPEAr : Support added for SPEAr300 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73463 6320 01/11 Vipin KUMAR [U-Boot] [PATCH v4 10/12] SPEAr : emi controller initialization for CFI driver support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73464 6321 01/11 Vipin KUMAR [U-Boot] [PATCH v4 11/12] SPEAr : Support added for SPEAr310 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73461 6322 01/11 Vipin KUMAR [U-Boot] [PATCH v4 12/12] SPEAr : Support added for SPEAr320 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73462 6335 01/11 Stefano Babic [U-Boot] [PATCH 8/9] mmc: check correctness of the voltage mask in ocr
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73473 6376 01/12 Gregory Hermant [U-Boot] [U-boot] [PATCH] Support for the Calao USB-A9260/USB-A9G20 boards
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73522 6384 01/12 Matthias Weisser [U-Boot] [PATCH] video: Fix console display when splashscreen is used
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73529 6393 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: Re-submitting Beagle REV C4, 720 Mhz and DSS patches
http://article.gmane.org/gmane.comp.hardware.beagleboard.user/0 6396 01/12 Kumar Gala [U-Boot] [PATCH 1/3] Add support to disable cpu's in multicore processors
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73545 6399 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 3/7] API to set twl4030 voltage and dev group 6400 01/13 Khasim Syed Moham [U-Boot] TI:OMAP:[PATCH 4/7] Add support for 720Mhz 6401 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 5/7] Add DSS driver for OMAP3
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73550 6402 01/13 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 6/7] Enable DSS driver for Beagle
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73551 6407 01/12 Kumar Gala [U-Boot] [PATCH v2 3/3] 85xx: Add support for 'cpu disable' command
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73556 6431 01/13 Stefano Babic [U-Boot] MX51 Support V2
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73590 6433 01/13 Stefano Babic [U-Boot] [PATCH V2 2/9] MX51: Add initial support for the Freescale MX51
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73584 6434 01/13 Stefano Babic [U-Boot] [PATCH V2 3/9] MX51: Add register definitions
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73581 6435 01/13 Stefano Babic [U-Boot] [PATCH V2 4/9] MX51: Add pin and multiplexer definitions.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73582 6436 01/13 Stefano Babic [U-Boot] [PATCH V2 5/9] serial_mxc: add support for MX51 processor
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73583 6437 01/13 Stefano Babic [U-Boot] [PATCH V2 6/9] fec_mxc: add support for MX51 processor
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73588 6438 01/13 Stefano Babic [U-Boot] [PATCH V2 7/9] fsl_esdhc: add support for mx51 processor
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73589 6439 01/13 Stefano Babic [U-Boot] [PATCH V2 8/9] mmc: check correctness of the voltage mask in ocr
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73585 6440 01/13 Stefano Babic [U-Boot] [PATCH V2 9/9] Add initial support for Freescale mx51evk board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73586 6445 01/13 Tom [U-Boot] [PATCH v4 01/12] SPEAr : Adding README.spear in doc
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73594 6451 01/13 Tom [U-Boot] [PATCH v4 08/12] SPEAr : Support for HW mac id read/write from i2c mem
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73600 6453 01/13 Tom [U-Boot] [PATCH v4 10/12] SPEAr : emi controller initialization for CFI driver support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73602 6465 01/13 Kumar Gala [U-Boot] [PATCH] ppc/p4080: Fix mask width of RCW fields MEM_PLL_RAT, SYS_PLL_RAT
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73614 6492 01/14 Anders Darander [U-Boot] [PATCH] Add bootcount to AT91
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73640 6512 01/15 Liu Yu [U-Boot] [PATCH v3] qe: fixup the snum for MPC8569 Rev2.0
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73658 6523 01/15 Vipin KUMAR [U-Boot] [PATCH v5 00/12] Support for SPEAr SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73677 6524 01/15 Vipin KUMAR [U-Boot] [PATCH v5 01/12] SPEAr : Adding README.spear in doc
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73675 6525 01/15 Vipin KUMAR [U-Boot] [PATCH v5 02/12] SPEAr : Adding basic SPEAr architecture support.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73674 6526 01/15 Vipin KUMAR [U-Boot] [PATCH v5 03/12] SPEAr : i2c driver support added for SPEAr SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73682 6527 01/15 Vipin KUMAR [U-Boot] [PATCH v5 04/12] SPEAr : smi driver support for SPEAr SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73681 6528 01/15 Vipin KUMAR [U-Boot] [PATCH v5 05/12] SPEAr : nand driver support for SPEAr SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73676 6529 01/15 Vipin KUMAR [U-Boot] [PATCH v5 06/12] SPEAr : usbd driver support for SPEAr SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73679 6530 01/15 Vipin KUMAR [U-Boot] [PATCH v5 07/12] SPEAr : Support added for SPEAr600 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73678 6531 01/15 Vipin KUMAR [U-Boot] [PATCH v5 08/12] SPEAr : Support for HW mac id read/write from i2c mem
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73673 6532 01/15 Vipin KUMAR [U-Boot] [PATCH v5 09/12] SPEAr : Support added for SPEAr300 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73671 6533 01/15 Vipin KUMAR [U-Boot] [PATCH v5 10/12] SPEAr : emi controller initialization for CFI driver support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73680 6534 01/15 Vipin KUMAR [U-Boot] [PATCH v5 11/12] SPEAr : Support added for SPEAr310 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73672 6535 01/15 Vipin KUMAR [U-Boot] [PATCH v5 12/12] SPEAr : Support added for SPEAr320 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73670 6572 01/16 Jens Scharsig [U-Boot] [PATCH 1/8 V2] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73719 6573 01/16 Jens Scharsig [U-Boot] [PATCH 2/8 V2] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73720 6574 01/16 Jens Scharsig [U-Boot] [PATCH 3/8 V2] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73721 6575 01/16 Jens Scharsig [U-Boot] [PATCH 4/8 V2] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73722 6576 01/16 Jens Scharsig [U-Boot] [PATCH 5/8 V2 Part 1/3] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73723 6577 01/16 Jens Scharsig [U-Boot] [PATCH 5/8 V2 Part 1/3] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73724 6578 01/16 Jens Scharsig [U-Boot] [PATCH 5/8 V2 Part 3/3] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73725 6579 01/16 Jens Scharsig [U-Boot] [PATCH 6/8 V2] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73726 6580 01/16 Jens Scharsig [U-Boot] [PATCH 7/8 V2] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73727 6581 01/16 Jens Scharsig [U-Boot] [PATCH 8/8 V2] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73728 6582 01/16 cyrus [U-Boot] [PATCH 5/8 V2 Part 2/3] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73745 6583 01/16 Jens Scharsig [U-Boot] [PATCH 5/8 V2 Part 2/3] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73729 6590 01/16 John Rigby [U-Boot] [PATCH-V2 1/9] mxc_serial replace platform specific clock
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73736 6591 01/16 John Rigby [U-Boot] [PATCH-V2 2/9] arm926ejs: add nand_spl boot support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73737 6592 01/16 John Rigby [PATCH-V2 3/9] Add MX25 support to nand_spl fsl nfc driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73738 6593 01/16 John Rigby [U-Boot] [PATCH-V2 4/9] Nand mxc_nand add v1.1 controller support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73739 6594 01/16 John Rigby [U-Boot] [PATCH-V2 5/9] fec_mxc: cleanup and factor out MX27 dependencies
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73740 6595 01/16 John Rigby [U-Boot] [PATCH-V2 6/9] Add support for Freescale MX25 SOC
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73744 6596 01/16 John Rigby [U-Boot] [PATCH-V2 7/9] fec_mxc: add MX25 support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73741 6597 01/16 John Rigby [PATCH-V2 8/9] env_nand.c: print error message and fail gracefully
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73743 6598 01/16 John Rigby [PATCH-V2 9/9] Add support for KARO TX25 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73742 6600 01/17 Magnus Lilja [U-Boot] [PATCH v2] SPI: Fix 32 bit transfers in mxc_spi.c
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73747 6673 01/17 To:u-boot@lists.d [PATCH] TFTP: allow for adjustable retransmission timout
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73816 6698 01/17 Mike Frysinger [U-Boot] [PATCH 1/1] [rfc] usb: musb: some more Blackfin stuff
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73841 6704 01/17 Ben Warren Re: [U-Boot] [RFC] 83xx: uec: miiphybb: Added support for bitBang SMI and uec SMI enabled at th
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73847 6741 01/18 Wolfgang Wegner [U-Boot] [PATCH v4] add ASTRO MCF5373L board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73883 6745 01/18 Quentin Armitage Re: [U-Boot] [U-boot] There appears to be the potential for an undetected error in fs/ext2/dev.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73887 6747 01/18 Quentin Armitage Re: [U-Boot] Issue in drivers/mmc/mmc.c
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73889 6748 01/18 Liu Yu [PATCH v2] Nand boot: Add nand boot support for MPC8569mds board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73890 6751 01/18 Shlomo Kut [U-Boot] davinci dm365 relocation
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73893 6752 01/18 Arno Steffen [U-Boot] OMAP3 EVM board nand support missed
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73894 6765 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 2/7] Enable I2C bus switching http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0 6766 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 3/7] API to set twl4030 voltage and dev group http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0 6767 01/18 Khasim Syed Moham [U-Boot] TI:OMAP:[PATCH 4/7] Add support for 720Mhz
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73914 6768 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 5/7] Add DSS driver for OMAP3 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/0 6769 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 6/7] Enable DSS driver for Beagle
http://article.gmane.org/gmane.comp.hardware.beagleboard.user/0 6770 01/18 Khasim Syed Moham [U-Boot] TI:OMAP: [PATCH 7/7] Add 720Mhz support for Beagle Rev C4
http://article.gmane.org/gmane.comp.hardware.beagleboard.user/0 6774 01/18 Richard Retanubun [U-Boot] [PATCH V2] PPC: Record uboot's relocated address in RAM and show in bdinfo.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73925 6783 01/18 Nick Thompson [U-Boot] [PATCH v2] da830evm: Use table driven pin mux configuration
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73933 6785 01/18 Stefano Babic [U-Boot] [PATCH] SPI: add support for i.MX51 processor (mxc_spi)
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73935 6786 01/18 prakash bedge Re: U-boot running on DDR fails to detect the CFI compliant flash 6800 01/18 Magnus Lilja Re: [U-Boot] [PATCH-V2 4/9] Nand mxc_nand add v1.1 controller support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73945 6820 01/19 Mike Frysinger [U-Boot] [PATCH] usb: musb: fix Blackfin DMA register padding
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73965 6822 01/19 Siddarth Gore [U-Boot] [PATCH] NET: kirkwood-egiga smi access fix
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73966 6826 01/19 Shivaprashanth Hi [U-Boot] uboot for zylonite/ces-310 board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73970 6827 01/19 Daniel Gorsulowsk [U-Boot] [PATCH] at91: Add esd gmbh OTC570 board support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73971 6862 01/19 Joakim Tjernlund [PATCH 1/4] ppc: Loose GOT access in IRQ
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74001 6863 01/19 Joakim Tjernlund [PATCH 2/4] ppc: Use r12 instead of r14 as GOT pointer.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74002 6864 01/19 Joakim Tjernlund [PATCH 4/4] ppc: Update README about the new GOT ptr.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74004 6865 01/19 Joakim Tjernlund [PATCH 3/4] ppc: remove -ffixed-r14 gcc option.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74003 6869 01/19 Dennis Semakin [U-Boot] [U-BOOT] Ethernet problem on PXA320
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74008 6894 01/19 Remy Bohmer Re: [U-Boot] [PATCH] usb: musb: fix Blackfin DMA register padding
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74033 6895 01/19 Matthias Kaehlcke [U-Boot] [PATCH 0/3] ARM: Add support for EDB93xx boards [rev3]
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74035 6897 01/19 Michael Durrant [U-Boot] MCF528x cache errata / fix [PATCH]
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74037 6898 01/19 Michael Durrant [U-Boot] ColdFire I2C implementing I2C idle [PATCH]
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74038 6899 01/19 Michael Durrant [U-Boot] Adding EP2500 MCF5282 board [PATCH]
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74039 6900 01/19 Michael Durrant [U-Boot] ColdFire/M68K board.c initialization / order matters [PATCH]
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74040 6916 01/20 Heiko Schocher [U-Boot] 83xx, uec: split enet_interface in two variables, was: 83xx, uec: adjust enet_interfac
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74056 6917 01/20 Heiko Schocher [U-Boot] 83xx, kmeter1: fix compile error
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74057 6920 01/20 Anders Darander Re: [U-Boot] [PATCH] Add bootcount to AT91
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74060 6927 01/20 Detlev Zundel [U-Boot] [PATCH] mpc5xxx: Support CPU internal watchdog.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74068 6931 01/20 Stefano Babic [U-Boot] [PATCH V3 01/11] mkimage: Add Freescale imx Boot Image support (imximage)
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74073 6932 01/20 Stefano Babic [U-Boot] [PATCH V3 02/11] MX51: Add initial support for the Freescale MX51
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74074 6933 01/20 Stefano Babic [U-Boot] [PATCH V3 03/11] MX51: Add register definitions
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74075 6934 01/20 Stefano Babic [U-Boot] [PATCH V3 04/11] MX51: Add pin and multiplexer definitions.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74076 6935 01/20 Stefano Babic [U-Boot] [PATCH V3 05/11] serial_mxc: add support for MX51 processor
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74077 6936 01/20 Stefano Babic [U-Boot] [PATCH V3 06/11] mmc: check correctness of the voltage mask in ocr
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74078 6937 01/20 Stefano Babic [U-Boot] [PATCH V3 07/11] fec_mxc: add support for MX51 processor
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74079 6938 01/20 Stefano Babic [U-Boot] [PATCH V3 08/11] MMC: add weak function to detect MMC/SD card
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74080 6939 01/20 Stefano Babic [U-Boot] [PATCH V3 09/11] ARM/PPC: add a common way to access registers
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74081 6940 01/20 Stefano Babic [U-Boot] [PATCH V3 10/11] fsl_esdhc: add support for mx51 processor
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74082 6941 01/20 Stefano Babic [U-Boot] [PATCH V3 11/11] Add initial support for Freescale mx51evk board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74083 6943 01/20 K Balaji [U-Boot] U-Boot for LENO3 processor board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74085 6947 01/20 Michael Durrant Re: [U-Boot] Adding EP2500 MCF5282 board [PATCH] -- resent in git format
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74089 6949 01/20 Michael Durrant Re: [U-Boot] ColdFire/M68K board.c initialization / order matters [PATCH] -- resent in git form
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74091 6950 01/20 Michael Durrant Re: [U-Boot] MCF528x cache errata / fix [PATCH] -- resent in git format
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74092 6959 01/21 Mingkai Hu [U-Boot] [PATCH] 85xx/eSDHC: fix eSDHC clock frequency mask
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74101 6960 01/21 "Liu Dave-R63238" Re: [U-Boot] [PATCH] 85xx/eSDHC: fix eSDHC clock frequency mask
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74102 6974 01/21 Mike Frysinger [U-Boot] [PATCH 3/3] asm-arm/unaligned.h: switch to asm-generic/unaligned.h
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74116 6975 01/21 Mike Frysinger [U-Boot] [PATCH 2/3] asm-blackfin/unaligned.h: add for zlib code
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74117 6976 01/21 Mike Frysinger [U-Boot] [PATCH 1/3] asm-generic/unaligned.h: dynamic default unaligned accesses
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74118 6977 01/21 Mike Frysinger [U-Boot] [PATCH] smc91111_eeprom: fix linking error
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74119 7003 01/21 Matthias Kaehlcke [U-Boot] [PATCH] cs8900_initialize() cleanup [rev2]
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74144 7012 01/21 Matthias Kaehlcke [U-Boot] [PATCH] smc911x driver: cleanup smc911x_initialize()
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74153 7027 01/21 Mike Frysinger [U-Boot] [PATCH v2] gzip/zlib: make features optional
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74168 7030 01/21 Mike Frysinger [U-Boot] [PATCH] tools: give explicit libfdt paths
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74171 7075 01/23 Jens Scharsig [U-Boot] [PATCH 0/9 V3] add at91 SoC access with c structures
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74213 7076 01/23 Jens Scharsig [U-Boot] [PATCH 1/9 V3] add new CONFIG_AT91_LEGACY
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74214 7077 01/23 Jens Scharsig [U-Boot] [PATCH 2/9 V3] add c structures for SoC access
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74215 7078 01/23 Jens Scharsig [U-Boot] [PATCH 3/9 V3] add a new AT91 GPIO driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74216 7079 01/23 Jens Scharsig [U-Boot] [PATCH 5/9 V3] convert common files to new SoC access
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74217 7080 01/23 Jens Scharsig [U-Boot] [PATCH 4/9 V3] convert all at91 files to use at91_gpio driver syntax
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74218 7081 01/23 Jens Scharsig [U-Boot] [PATCH 6/9 V3] update at91sam9263ek board to new SoC access
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74219 7082 01/23 Jens Scharsig [U-Boot] [PATCH 7/9 V3] prepare joining at91rm9200 into at91
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74220 7083 01/23 Jens Scharsig [U-Boot] [PATCH 8/9 V3] new at91_emac network driver (NET_MULTI api)
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74221 7084 01/23 Jens Scharsig [U-Boot] [PATCH 9/9 V3] new board (eb_cpux9k2)
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74222 7094 01/23 Ed Swarthout [U-Boot] [PATCH RFC] tsec: do not print Speed: if using netconsole
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74231 7138 01/24 Matthias Kaehlcke [U-Boot] [PATCH 0/3] ARM: Add support for EDB93xx boards [rev4]
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74274 7139 01/24 Matthias Kaehlcke [U-Boot] [PATCH 2/3] Add EP93xx ethernet driver
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74275 7140 01/24 Matthias Kaehlcke [U-Boot] [PATCH 1/3] ARM: Add support for EP93xx SoCs
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74276 7141 01/24 Matthias Kaehlcke [U-Boot] [PATCH 3/3] Add support for EDB93xx boards
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74273 7159 01/25 Daniel Gorsulowsk [U-Boot] [PATCH v2] at91: Add esd gmbh OTC570 board support
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74293 7160 01/25 Wolfgang Wegner [U-Boot] [PATCH v5] add ASTRO MCF5373L board
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74294 7166 01/25 Khasim Syed Moham [U-Boot] Fwd: TI:OMAP: [PATCH 6/7] Enable DSS driver for Beagle
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74300 7167 01/25 Khasim Syed Moham [U-Boot] Fwd: TI:OMAP: [PATCH 5/7] Add DSS driver for OMAP3
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74301 7177 01/25 Scott Ellis [U-Boot] [PATCH] Overo GPMC registers
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74310 7178 01/25 Kumar Gala [U-Boot] [PATCH] Revert "ppc/p4080: Fix reporting of PME & FM clock frequencies"
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74311 7179 01/25 richardretanubun@ [U-Boot] [PATCH V3] PPC: Record uboot's relocated address in RAM and show in bdinfo.
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74312
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de If it went on at this rate, in several billion years he'd be rich beyond his wildest dreams! - Terry Pratchett, _Soul Music_ _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Mon, 25 Jan 2010 23:44:48 +0100 Wolfgang Denk wd@denx.de wrote:
6917 01/20 Heiko Schocher [U-Boot] 83xx, kmeter1: fix compile error http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74057
mainline pull request sent.
Kim
Dear Wolfgang and Kevin
On 26 January 2010 07:44, Wolfgang Denk wd@denx.de wrote:
6011 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 1/4] s3c24x0 white-space clean-up part 1 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73133 6012 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 2/4] s3c24x0 white-space clean-up part 2 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73134 6013 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 3/4] s3c24x0 code-style clean-up http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73135 6014 12/28 "kevin.morfitt@fe [U-Boot] [PATCH ARM 4/4] Change s3c24x0 register struct members to lower case http://article.gmane.org/gmane.comp.boot-loaders.u-boot/73136
I'll review these patch series soon.
Thanks Minkyu Kang
participants (24)
Albin Tonnerre
Alessandro Rubini
Anders Darander
Ben Warren
Daniel Gorsulowski
Heiko Schocher
Hiremath, Vaibhav
Joakim Tjernlund
John Rigby
Kim Phillips
Kumar Gala
Ladislav Michl
Li Yang-R58472
Matthias Weißer
Mike Frysinger
Minkyu Kang
Nick Thompson
Paulraj, Sandeep
Peter Tyser
Scott Wood
Stefan Roese
Swarthout Edward L-SWARTHOU
wolfgang@leila.ping.de
