[PATCH] binman: Add support for symlinking images
Adding support to symlink an image packaged using binman.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- tools/binman/image.py | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/tools/binman/image.py b/tools/binman/image.py index afc4b4d643..191d121d88 100644 --- a/tools/binman/image.py +++ b/tools/binman/image.py @@ -38,6 +38,7 @@ class Image(section.Entry_section): repacked later test_section_timeout: Use a zero timeout for section multi-threading (for testing) + symlink: Name of symlink to image
Args: copy_to_orig: Copy offset/size to orig_offset/orig_size after reading @@ -97,6 +98,7 @@ class Image(section.Entry_section): if filename: self._filename = filename self.allow_repack = fdt_util.GetBool(self._node, 'allow-repack') + self._symlink = fdt_util.GetString(self._node, 'symlink')
@classmethod def FromFile(cls, fname): @@ -181,6 +183,10 @@ class Image(section.Entry_section): fd.write(data) tout.info("Wrote %#x bytes" % len(data))
+ # Create symlink to file if symlink given + if self._symlink is not None: + tools.Run('ln', '-sf', self._filename, self._symlink) + def WriteMap(self): """Write a map of the image to a .map file
Hi Neha,
This looks fine as a feature, but please add a test to ftest.py and see below.
Please update 'Image description format' in binman.rst to describe your new feature.
Can you use os.symlink() instead?
- def WriteMap(self): """Write a map of the image to a .map file
-- 2.34.1
Hi Simon,
On 11/10/22 05:19, Simon Glass wrote:
Hi Neha,
Got it, will add a test.
symlink: Name of symlink to image Args: copy_to_orig: Copy offset/size to orig_offset/orig_size after reading
Will add that.
Yes that will be better, agreed. Thanks!
-- 2.34.1
Neha Malcom Francis
