[PATCH v2 0/1] disk: add TegraPT support
Production Tegra20/30/114/124/132 devices use Nvidia's own partition table, which makes them a bit complicated to deal with. Luckily, it is compatible with the existing EFI partition already available in U-Boot, apart from the fact that it cannot pass Protective MBR check.
In order to address this without unwanted code additions, I have come up with this solution.
--- Changes from v1 - fix typo in code comment ---
Svyatoslav Ryhel (1): disk: add TegraPT support
disk/Kconfig | 8 ++++++++ disk/part_efi.c | 13 +++++++++++++ 2 files changed, 21 insertions(+)
TegraPT is compatible with EFI part but it can't pass Protective MBR check. Skip this check if CONFIG_TEGRA_PARTITION is enabled, storage uclass is MMC and devnum is 0. Note, eMMC on supported devices MUST be aliased to mmc0.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- disk/Kconfig | 8 ++++++++ disk/part_efi.c | 13 +++++++++++++ 2 files changed, 21 insertions(+)
diff --git a/disk/Kconfig b/disk/Kconfig index ffa835eb35..75a849ec8c 100644 --- a/disk/Kconfig +++ b/disk/Kconfig @@ -49,6 +49,14 @@ config SPL_MAC_PARTITION default y if MAC_PARTITION select SPL_PARTITIONS
+config TEGRA_PARTITION + bool "Enable Nvidia Tegra partition table" + select PARTITIONS + select EFI_PARTITION + help + Say Y here if you would like to use U-Boot on a device with + Nvidia Tegra partition table. + config DOS_PARTITION bool "Enable MS Dos partition table" default y if BOOT_DEFAULTS diff --git a/disk/part_efi.c b/disk/part_efi.c index b1a03bd165..350a8a6dc5 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -318,6 +318,19 @@ static int part_test_efi(struct blk_desc *desc) /* Read legacy MBR from block 0 and validate it */ if ((blk_dread(desc, 0, 1, (ulong *)legacymbr) != 1) || (is_pmbr_valid(legacymbr) != 1)) { + + /* + * TegraPT is compatible with EFI part, but it + * cannot pass the Protective MBR check. Skip it + * if CONFIG_TEGRA_PARTITION is enabled and the + * device in question is eMMC. + */ + if (IS_ENABLED(CONFIG_TEGRA_PARTITION)) + if (!is_pmbr_valid(legacymbr) && + desc->uclass_id == UCLASS_MMC && + !desc->devnum) + return 0; + return -1; } return 0;
Am 7. August 2024 14:10:24 MESZ schrieb Svyatoslav Ryhel clamor95@gmail.com:
Why wouldn't you use U-Boot's gpt command to fix the non-conformant partition table?
Best regards
Heinrich
- bool "Enable Nvidia Tegra partition table"
- select PARTITIONS
- select EFI_PARTITION
- help
!desc->devnum)
- return -1; } return 0;
пт, 9 серп. 2024 р. о 08:49 Heinrich Schuchardt xypron.glpk@gmx.de пише:
I would love to, but I am forced to use TegraPT and DON'T modify it. Tegra114 bootloader is RSA signed and there is no possible way to replace it with open source one unless vendor allows this. SO I am stuck with vendor bootloader to chainload from which enforces TegraPT as well. Modification of existing partition table can irreversibly brick the device.
Best regards, Svyatoslav R.
Best regards
Heinrich
select PARTITIONS
help
!desc->devnum)
Can we please incorporate some of this information to the help text, so it's clear what the use case is? Thanks.
сб, 10 серп. 2024 р. о 01:02 Tom Rini trini@konsulko.com пише:
Sure, though usually those who know what they are dealing with will understand. BTW, Tom, may I pick patchsets assigned to Thierry (tagr) via Tegra custodian tree if they pass? Even if they, apart being related to Tegra, belong to different subsystems (like this patch and, for example, tegra gpio driver changes).
-- Tom
Yes, that's fine.
Since there were no objections (apart help Kconfig expansion which I will add) or improvement suggestions to this patch for over 2 weeks (first patchset submitted on 01.08.24) I am picking it into Tegra custodian tree.
пн, 12 серп. 2024 р. о 21:42 Tom Rini trini@konsulko.com пише:
Yes, that's fine.
-- Tom
Svyatoslav Ryhel
