[PATCH 09/18] configs/seli8: enable field fail-safe u-boot update
Field fail-safe u-boot update for pg-wcom-ls102x designs is introduced with 81fb05e.
This patch enables already added support by: - Defining default u-boot build as bootpackage (factory) image. - Defining u-boot update image location according to the SELI8 NOR layout. - Extending mtd partitions according defined SELI8 NOR layout.
Signed-off-by: Aleksandar Gerasimovski aleksandar.gerasimovski@hitachienergy.commailto:aleksandar.gerasimovski@hitachienergy.com --- configs/pg_wcom_seli8_defconfig | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/configs/pg_wcom_seli8_defconfig b/configs/pg_wcom_seli8_defconfig index 5b1aa8f..cb7c680 100644 --- a/configs/pg_wcom_seli8_defconfig +++ b/configs/pg_wcom_seli8_defconfig @@ -1,7 +1,10 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_PG_WCOM_SELI8=y +CONFIG_PG_WCOM_UBOOT_UPDATE_SUPPORTED=y +CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_PG_WCOM_UBOOT_UPDATE_TEXT_BASE=0x60240000 CONFIG_SYS_MALLOC_LEN=0x1004000 CONFIG_NR_DRAM_BANKS=1 CONFIG_KM_DEF_NETDEV="eth2" @@ -41,7 +44,7 @@ CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_CRAMFS=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=60000000.nor,nand0=68000000.flash" -CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:128k(rcw),128k(qe),128k(envred),128k(env),512k(res),1m(u-boot),-(ubi0);68000000.flash:-(ubi1)" +CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:128k(rcw),128k(qe),128k(envred),128k(env),512k(res),1m(u-boot),128k(redenvred),128k(redenv),1m(redu-boot),-(ubi0);68000000.flash:-(ubi1)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y -- 1.8.3.1
Field fail-safe u-boot update for pg-wcom-ls102x designs is introduced with patch 81fb05e.
Signed-off-by: Aleksandar Gerasimovski aleksandar.gerasimovski@hitachienergy.com --- configs/pg_wcom_seli8_defconfig | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
