[PATCH v2 0/3] Adjust how autoprobe is implemented
This little series makes a minor change to how autoprobe is implemeneted, as discussed on the list:
https://patchwork.ozlabs.org/project/uboot/patch/ 20240626235717.272219-1-marex@denx.de/
Changes in v2: - Add autoprobe to SPL also - Leave the function name the same - Fix 'Prove' typo - Update cover letter since SPL is now covered also - Update the documentation too, with a discussion link
Simon Glass (3): common: Drop check for DM in initf_dm() dm: core: Simplify dm_probe_devices() common: Move autoprobe out to board init
common/board_f.c | 9 +++++++-- common/board_r.c | 4 ++++ common/spl/spl.c | 4 ++++ doc/develop/driver-model/design.rst | 15 +++++++++++++++ drivers/core/root.c | 27 ++++++++++++++++----------- include/dm/root.h | 10 ++++++++++ 6 files changed, 56 insertions(+), 13 deletions(-)
This is enabled by all boards, so drop the condition.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
(no changes since v1)
common/board_f.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 98dc2591e1d..1e1aa08530a 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -811,9 +811,11 @@ static int initf_bootstage(void)
static int initf_dm(void) { -#if defined(CONFIG_DM) && CONFIG_IS_ENABLED(SYS_MALLOC_F) int ret;
+ if (!CONFIG_IS_ENABLED(SYS_MALLOC_F)) + return 0; + bootstage_start(BOOTSTAGE_ID_ACCUM_DM_F, "dm_f"); ret = dm_init_and_scan(true); bootstage_accum(BOOTSTAGE_ID_ACCUM_DM_F); @@ -825,7 +827,6 @@ static int initf_dm(void) if (ret) return ret; } -#endif
return 0; }
There is no point in checking the pre_reloc flag, since devices not marked as pre-reloc will not have been bound, so won't exist yet.
There doesn't seem to be any point in checking if the device has a valid devicetree node either, so drop that too.
drivers/core/root.c | 16 +++++----------- 1 file changed, 5 insertions(+), 11 deletions(-)
diff --git a/drivers/core/root.c b/drivers/core/root.c index 7a714f5478a..2d4f078f97f 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -281,26 +281,20 @@ void *dm_priv_to_rw(void *priv) } #endif
-static int dm_probe_devices(struct udevice *dev, bool pre_reloc_only) +static int dm_probe_devices(struct udevice *dev) { - ofnode node = dev_ofnode(dev); struct udevice *child; - int ret; - - if (pre_reloc_only && - (!ofnode_valid(node) || !ofnode_pre_reloc(node)) && - !(dev->driver->flags & DM_FLAG_PRE_RELOC)) - goto probe_children;
if (dev_get_flags(dev) & DM_FLAG_PROBE_AFTER_BIND) { + int ret; + ret = device_probe(dev); if (ret) return ret; }
-probe_children: list_for_each_entry(child, &dev->child_head, sibling_node) - dm_probe_devices(child, pre_reloc_only); + dm_probe_devices(child);
return 0; } @@ -337,7 +331,7 @@ static int dm_scan(bool pre_reloc_only) if (ret) return ret;
- return dm_probe_devices(gd->dm_root, pre_reloc_only); + return dm_probe_devices(gd->dm_root); }
int dm_init_and_scan(bool pre_reloc_only)
Rather than doing autoprobe within the driver model code, move it out to the board-init code. This makes it clear that it is a separate step from binding devices.
For now this is always done twice, before and after relocation, but we should discuss whether it might be possible to drop the post-relocation probe.
For boards with SPL, the autoprobe is still done there as well.
Note that with this change, autoprobe happens after the EVT_DM_POST_INIT_R/F events are sent, rather than before.
Update the docs a little, for this feature.
common/board_f.c | 4 ++++ common/board_r.c | 4 ++++ common/spl/spl.c | 4 ++++ doc/develop/driver-model/design.rst | 15 +++++++++++++++ drivers/core/root.c | 13 ++++++++++++- include/dm/root.h | 10 ++++++++++ 6 files changed, 49 insertions(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index 1e1aa08530a..974eb4f39e9 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -822,6 +822,10 @@ static int initf_dm(void) if (ret) return ret;
+ ret = dm_autoprobe(); + if (ret) + return ret; + if (IS_ENABLED(CONFIG_TIMER_EARLY)) { ret = dm_timer_init(); if (ret) diff --git a/common/board_r.c b/common/board_r.c index 62228a723e1..d1507b06f8d 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -241,6 +241,10 @@ static int initr_dm(void) if (ret) return ret;
+ ret = dm_autoprobe(); + if (ret) + return ret; + return 0; } #endif diff --git a/common/spl/spl.c b/common/spl/spl.c index 1ceb63daf31..c4256f237ee 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -500,6 +500,10 @@ static int spl_common_init(bool setup_malloc) debug("dm_init_and_scan() returned error %d\n", ret); return ret; } + + ret = dm_autoprobe(); + if (ret) + return ret; }
return 0; diff --git a/doc/develop/driver-model/design.rst b/doc/develop/driver-model/design.rst index 8c2c81d7ac9..1dcac1408ff 100644 --- a/doc/develop/driver-model/design.rst +++ b/doc/develop/driver-model/design.rst @@ -842,6 +842,21 @@ steps (see device_probe()): cause the uclass to do some housekeeping to record the device as activated and 'known' by the uclass.
+For some platforms, certain devices must be probed to get the platform into +a working state. To help with this, drivers marked with +``DM_FLAG_PROBE_AFTER_BIND`` will be probed immediately after all devices are +bound. For now, this happens in each xPL build as well as in U-Boot proper, +both before relocation and after relocation. See the call to ``dm_autoprobe()`` +for where this is done. + +Note that autoprobe happens after the ``EVT_DM_POST_INIT_R`` and +``EVT_DM_POST_INIT_F`` events are sent, since these events relate to +device-binding. + +See here for discussion of this feature: + +:Link: https://patchwork.ozlabs.org/project/uboot/patch/20240626235717.272219-1-mar... + Running stage ^^^^^^^^^^^^^
diff --git a/drivers/core/root.c b/drivers/core/root.c index 2d4f078f97f..371a37fe752 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -299,6 +299,17 @@ static int dm_probe_devices(struct udevice *dev) return 0; }
+int dm_autoprobe(void) +{ + int ret; + + ret = dm_probe_devices(gd->dm_root); + if (ret) + return log_msg_ret("pro", ret); + + return 0; +} + /** * dm_scan() - Scan tables to bind devices * @@ -331,7 +342,7 @@ static int dm_scan(bool pre_reloc_only) if (ret) return ret;
- return dm_probe_devices(gd->dm_root); + return 0; }
int dm_init_and_scan(bool pre_reloc_only) diff --git a/include/dm/root.h b/include/dm/root.h index b2f30a842f5..cd240c6a716 100644 --- a/include/dm/root.h +++ b/include/dm/root.h @@ -136,6 +136,16 @@ int dm_scan_other(bool pre_reloc_only); */ int dm_init_and_scan(bool pre_reloc_only);
+/** + * dm_autoprobe() - Probe devices which are marked for probe-after-bind + * + * This probes all devices with a DM_FLAG_PROBE_AFTER_BIND flag. It checks the + * entire tree, so parent nodes need not have the flag set. + * + * Return: 0 if OK, -ve on error + */ +int dm_autoprobe(void); + /** * dm_init() - Initialise Driver Model structures *
This commit is where we need: Link: https://lore.kernel.org/u-boot/20240626235717.272219-1-marex@denx.de/
So that it's easy to go from git to fuller history.
There's 40+ messages in the thread (but I know not all of them were about design), so is the above really a sufficient summary?
Hi Simon,
Nitpicks below.
Changes in v2:
Fix 'Prove' typo
- ret = dm_autoprobe();
- if (ret)
return ret;
- if (IS_ENABLED(CONFIG_TIMER_EARLY)) { ret = dm_timer_init(); if (ret)
- if (ret)
return ret;
return dm_autoprobe();
if (ret)
return ret;
- Running stage ^^^^^^^^^^^^^
- int ret;
- ret = dm_probe_devices(gd->dm_root);
- if (ret)
1) Should be log_msg_retz since log_msg_ret will only print the message on < 0 and here we test for ret 2) Simplify:
return log_msg_retz("pro", dm_probe_devices(gd->dm_root));
the message won't be printed if the return value is 0.
- dm_scan() - Scan tables to bind devices
Simplify with:
return dm_scan_other(pre_reloc_only);
- dm_autoprobe() - Probe devices which are marked for probe-after-bind
- This probes all devices with a DM_FLAG_PROBE_AFTER_BIND flag. It checks the
- entire tree, so parent nodes need not have the flag set.
Can suggest: """ It recursively probes parent nodes, so they do not need to have the flag set themselves. """ which is what I believe you wanted to say? "Checking the entire tree" induces the opposite of "parent nodes need not have the flag set".
Cheers, Quentin
Hi Quentin,
On Wed, 6 Nov 2024 at 08:31, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
Nitpicks below.
Changes in v2:
Fix 'Prove' typo
if (ret)
return ret;
if (ret)
return ret;
OK
if (ret)
return ret; } return 0;
int ret;
if (ret)
- Should be log_msg_retz since log_msg_ret will only print the message
Well we have this all over the place. I'll add a comment to dm_probe_devices(), but log_msg_retz() is really only for cases where the function can return a positive value (e.g. a size, or node offset). Most functions just return 0 on success and -ve error, which is what log_msg_ret() is for.
- Simplify:
I don't like combining things like this, so tend to write it out in full. It is easier to add to the code later. Also the semantics of putting a required call inside a debugging call are not that clear. Perhaps we could document this in log.h ? But I always like to have a simple 'return 0' at the end of a function, after all the error cases have been handled.
Simplify with:
See above :-)
Thanks, added and I will expand a little, too.
Patchwork is not great for re-reading discussions, please use lore: https://lore.kernel.org/u-boot/20240626235717.272219-1-marex@denx.de/ (and since patchwork uses message-id for URLs now, it's easy to find the lore URL if you're looking at a patchwork link.
And now that I know this is what I thought it was, this needs Marek's Tested-by that it doesn't break the use case he was solving.
Quentin Schulz
