[GIT PULL] rpi: second round of updates for v2021.04
Hi Tom,
Below are the second round of updates for Raspberry Pi aimed for the v2021.04 release.
The green CI loop can be found here: https://source.denx.de/u-boot/custodians/u-boot-raspberrypi/-/pipelines/6579
Please have a look.
Regards, Matthias
The following changes since commit c5219c4a18f2b27547ecd799914f94e48b0fa86f:
Prepare v2021.04-rc3 (2021-03-01 22:46:41 -0500)
https://source.denx.de/u-boot/custodians/u-boot-raspberrypi.git tags/rpi-next-2021.04.2
for you to fetch changes up to fae165b5a1991ca55acfb3dc78f3c473275b3faf:
configs: rpi4_32: Enable iProc RNG200 (2021-03-02 13:53:53 +0100)
---------------------------------------------------------------- - Disable Grub workaround for RPi2 - enable HS200 mode for iproc sdhci - add armv7 support for iproc_rng200
---------------------------------------------------------------- Bharat Gooty (1): drivers: mmc: iproc_sdhci: enable HS200 mode
Matthias Brugger (4): configs: RPi2: Disable EFI Grub workaround MAINTAINERS: Update info for Raspberry Pi rng: iproc_rng200: Enable support for RPi4 armv7 configs: rpi4_32: Enable iProc RNG200
MAINTAINERS | 4 +- configs/rpi_2_defconfig | 1 + configs/rpi_4_32b_defconfig | 2 + drivers/mmc/iproc_sdhci.c | 92 ++++++++++++++++++++++++++++++++++++++++----- drivers/rng/iproc_rng200.c | 8 ++-- 5 files changed, 93 insertions(+), 14 deletions(-)
On Tue, Mar 02, 2021 at 06:13:26PM +0100, Matthias Brugger wrote:
Hi Tom,
Please have a look.
Regards, Matthias
Matthias Brugger
