[U-Boot] [PATCH] bootm: relocate names of sub-command table for archs with CONFIG_NEEDS_MANUAL_RELOC
From: Daniel Schwierzeck daniel.schwierzeck@gmail.com
To make bootm sub-command feature working on archs with CONFIG_NEEDS_MANUAL_RELOC, the name pointers in the sub-command table need to be relocated.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- common/cmd_bootm.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index f7595c0..1b8a8c1 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -592,12 +592,18 @@ int do_bootm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_NEEDS_MANUAL_RELOC static int relocated = 0;
- /* relocate boot function table */ if (!relocated) { int i; + + /* relocate boot function table */ for (i = 0; i < ARRAY_SIZE(boot_os); i++) if (boot_os[i] != NULL) boot_os[i] += gd->reloc_off; + + /* relocate names of sub-command table */ + for (i = 0; i < ARRAY_SIZE(cmd_bootm_sub); i++) + cmd_bootm_sub[i].name += gd->reloc_off; + relocated = 1; } #endif
