[U-Boot] [PATCH] net: kirkwood: updates: used eth_setenv_enetaddr api
eth_setenv_enetaddr is avaible by upper layer using this saves 204 bytes on total image size
Signed-off-by: Prafulla Wadaskar prafulla@marvell.com --- drivers/net/kirkwood_egiga.c | 13 ++++++++----- 1 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/drivers/net/kirkwood_egiga.c b/drivers/net/kirkwood_egiga.c index 3d908f8..1a208f2 100644 --- a/drivers/net/kirkwood_egiga.c +++ b/drivers/net/kirkwood_egiga.c @@ -606,7 +606,7 @@ int kirkwood_egiga_initialize(bd_t * bis) struct kwgbe_device *dkwgbe; struct eth_device *dev; int devnum; - char *s, buf[NAMESIZE * 2]; + char *s; u8 used_ports[MAX_KWGBE_DEVS] = CONFIG_KIRKWOOD_EGIGA_PORTS;
for (devnum = 0; devnum < MAX_KWGBE_DEVS; devnum++) { @@ -665,10 +665,13 @@ int kirkwood_egiga_initialize(bd_t * bis)
while (!eth_getenv_enetaddr(s, dev->enetaddr)) { /* Generate Ramdom MAC addresses if not set */ - sprintf(buf, "00:50:43:%02x:%02x:%02x", - get_random_hex(), get_random_hex(), - get_random_hex()); - setenv(s, buf); + dev->enetaddr[0] = 0x00; + dev->enetaddr[1] = 0x50; + dev->enetaddr[2] = 0x43; + dev->enetaddr[3] = get_random_hex(); + dev->enetaddr[4] = get_random_hex(); + dev->enetaddr[5] = get_random_hex(); + eth_setenv_enetaddr(s, dev->enetaddr); }
dev->init = (void *)kwgbe_init;
get_random_hex());
setenv(s, buf);
it will be also good to use a private mac address dev->enetaddr[0] = 0x02;
Best Regards, J.
get_random_hex());
setenv(s, buf);
Full ACK. If you're generating something random, it MUST have the private bit. Unless Marvell owns this block and is giving it away and is keeping track of all used numbers and ...
regards, Ben
used Local OUI instead of Marvell OUI for random MAC address generation logic
Signed-off-by: Prafulla Wadaskar prafulla@marvell.com --- Change log v2: updated as per feedback for v1 private MAC address used typos corrected
drivers/net/kirkwood_egiga.c | 15 +++++++++------ 1 files changed, 9 insertions(+), 6 deletions(-)
diff --git a/drivers/net/kirkwood_egiga.c b/drivers/net/kirkwood_egiga.c index 701812b..e3580af 100644 --- a/drivers/net/kirkwood_egiga.c +++ b/drivers/net/kirkwood_egiga.c @@ -592,7 +592,7 @@ int kirkwood_egiga_initialize(bd_t * bis) struct kwgbe_device *dkwgbe; struct eth_device *dev; int devnum; - char *s, buf[NAMESIZE * 2]; + char *s; u8 used_ports[MAX_KWGBE_DEVS] = CONFIG_KIRKWOOD_EGIGA_PORTS;
for (devnum = 0; devnum < MAX_KWGBE_DEVS; devnum++) { @@ -650,11 +650,14 @@ int kirkwood_egiga_initialize(bd_t * bis) }
while (!eth_getenv_enetaddr(s, dev->enetaddr)) { - /* Generate Ramdom MAC addresses if not set */ - sprintf(buf, "00:50:43:%02x:%02x:%02x", - get_random_hex(), get_random_hex(), - get_random_hex()); - setenv(s, buf); + /* Generate Random Private MAC addr if not set */ + dev->enetaddr[0] = 0x02; + dev->enetaddr[1] = 0x50; + dev->enetaddr[2] = 0x43; + dev->enetaddr[3] = get_random_hex(); + dev->enetaddr[4] = get_random_hex(); + dev->enetaddr[5] = get_random_hex(); + eth_setenv_enetaddr(s, dev->enetaddr); }
Prafulla,
Applied to net repo.
thanks, Ben
get_random_hex());
setenv(s, buf);
really we should add a new common eth function that generates a random local mac address ... and have each arch implement a random function. you can see the one i use for Blackfin systems in asm-blackfin/net.h ... -mike
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Mike Frysinger Sent: Thursday, August 13, 2009 10:47 AM To: u-boot@lists.denx.de Cc: Ashish Karkare; Prabhanjan Sarnaik; Ben Warren Subject: Re: [U-Boot] [PATCH] net: kirkwood: updates: used eth_setenv_enetaddr api
saves 204
- char *s; u8 used_ports[MAX_KWGBE_DEVS] =
get_random_hex(),
get_random_hex(),
get_random_hex());
setenv(s, buf);
it away and
Good Idea, I hope each arch will have support to generate random values :-)
Regards.. Prafulla . .
-mike
Ben Warren
Mike Frysinger
Prafulla Wadaskar
