[PATCH v3 0/3] efi: Start tidying up memory management
We have been discussing the state of EFI memory management for some years so I thought it might be best to send a short series showing some of the issues we have talked about.
This one just deals with memory allocation. It provides a way to detect EFI 'page allocations' when U-Boot' malloc() should be used. It should help us to clean up this area of U-Boot.
It also updates EFI to use U-Boot memory allocation for the pool. Most functions use that anyway and it is much more efficient. It also avoids allocating things 'in space' in conflict with the loaded images.
This series also includes a little patch to show more information in the index for the EFI pages.
Note that this series is independent from Sugosh's lmb series[1], although I believe it will point the way to simplifying some of the later patches in that series.
Overall, some issues which should be resolved are: - allocation inconsistency, e.g. efi_add_protocol() uses malloc() but efi_dp_dup() does not (this series makes a start) - change efi_bl_init() to register events later, when the devices are actually used - rather than efi_set_bootdev(), provide a bootstd way to take note of the device images came from and allow EFI to query that when needed - EFI_LOADER_BOUNCE_BUFFER - can use U-Boot bounce buffers?
Minor questions on my mind: - is unaligned access useful? Is there a performance penalty? - API confusion about whether something is an address or a pointer
[1] https://patchwork.ozlabs.org/project/uboot/list/?series=416441
Changes in v3: - Add new patch to drop the memset() from efi_alloc() - Drop patch to convert device_path allocation to use malloc()
Changes in v2: - Drop patch 'Show more information in efi index' - Drop patch 'Avoid pool allocation in efi_get_memory_map_alloc()' - Add the word 'warning', use log_warning() and show the end address
Simon Glass (3): efi: Drop the memset() from efi_alloc() efi: Allow use of malloc() for the EFI pool efi: Show the location of the bounce buffer
common/dlmalloc.c | 7 +++ include/efi_loader.h | 29 ++++++++- include/malloc.h | 7 +++ lib/efi_loader/efi_bootbin.c | 11 ++++ lib/efi_loader/efi_memory.c | 119 ++++++++++++++++++++++++----------- 5 files changed, 136 insertions(+), 37 deletions(-)
From my inspection none of the users need the memory to be zeroed. It
is somewhat unexpected that it does so, since the name gives no clue to this.
Drop the memset() so that it effectively becomes a wrapper around the normal EFI-pool allocator.
Another option would be to drop this function and call efi_allocate_pool() directly, but that increase code size a little.
Move the function comment to the header file like most other exported functions in U-Boot.
include/efi_loader.h | 11 ++++++++++- lib/efi_loader/efi_memory.c | 9 --------- 2 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index f84852e384f..38971d01442 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -758,8 +758,17 @@ efi_status_t efi_next_variable_name(efi_uintn_t *size, u16 **buf, * Return: size in pages */ #define efi_size_in_pages(size) (((size) + EFI_PAGE_MASK) >> EFI_PAGE_SHIFT) -/* Allocate boot service data pool memory */ + +/** + * efi_alloc() - allocate boot services data pool memory + * + * Allocate memory from pool with type EFI_BOOT_SERVICES_DATA + * + * @size: number of bytes to allocate + * Return: pointer to allocated memory, or NULL if out of memory + */ void *efi_alloc(size_t len); + /* Allocate pages on the specified alignment */ void *efi_alloc_aligned_pages(u64 len, int memory_type, size_t align); /* More specific EFI memory allocator, called by EFI payloads */ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index c6f1dd09456..50cb2f3898b 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -664,14 +664,6 @@ efi_status_t efi_allocate_pool(enum efi_memory_type pool_type, efi_uintn_t size, return r; }
-/** - * efi_alloc() - allocate boot services data pool memory - * - * Allocate memory from pool and zero it out. - * - * @size: number of bytes to allocate - * Return: pointer to allocated memory or NULL - */ void *efi_alloc(size_t size) { void *buf; @@ -681,7 +673,6 @@ void *efi_alloc(size_t size) log_err("out of memory"); return NULL; } - memset(buf, 0, size);
return buf; }
On 02.09.24 00:22, Simon Glass wrote:
From my inspection none of the users need the memory to be zeroed. It is somewhat unexpected that it does so, since the name gives no clue to this.
Though the UEFI specification does not require it, EDK II uses AllocateZeroPool() to implement EFI_DEVICE_PATH_UTILITIES_PROTOCOL.CreateDeviceNode(). We should not deviate from it.
Yes, we should move all non-static EFI function descriptions to headers. But it makes no sense to move the comments of a single function and leave the other functions unchanged. Have a look at doc/api/efi.rst.
Best regards
Heinrich
Changes in v3:
- Return: size in pages
- efi_alloc() - allocate boot services data pool memory
- Allocate memory from pool with type EFI_BOOT_SERVICES_DATA
- @size: number of bytes to allocate
- Return: pointer to allocated memory, or NULL if out of memory
- */ void *efi_alloc(size_t len);
- /* Allocate pages on the specified alignment */ void *efi_alloc_aligned_pages(u64 len, int memory_type, size_t align); /* More specific EFI memory allocator, called by EFI payloads */
- Allocate memory from pool and zero it out.
- Return: pointer to allocated memory or NULL
return buf; }
Hi Heinrich,
Are you saying that there is an unwritten convention in the spec? My inspection of the code leads me to believe that all of the bytes which are allocated are written to, within that code, so that zeroing the bytes serves no purpose.
My goal here is to allow use of malloc(), instead of calloc(), for example.
I normally like to do these things one at a time, when changes are needed, to avoid massive wholesale changes with no other purpose. That is what has happened with image.h over time. But OK I can drop that part of the patch, once we sort out the zeroring.
Changes in v3:
memset(buf, 0, size); return buf;
On 19.09.24 16:13, Simon Glass wrote:
Hi Heinrich,
EFI_DEVICE_PATH_UTILITIES_PROTOCOL.CreateDeviceNode() is an API:
You have to consider the current and future usage outside U-Boot.
For saving a few microseconds I would not want to give up compatibility with EDK II.
The caller of the API has to release with the memory with FreePool(). So we should allocate it with AllocatePool().
See chapter 10.5.8 "EFI_DEVICE_PATH_UTILITIES_PROTOCOL.CreateDeviceNode()" in the UEFI specification.
Best regards
Heinrich
Changes in v3:
Hi Heinrich,
Hi Heinrich,
What sort of compatibility are you referring to? Are we implementing a spec or copying Tianocore? Also, did you miss the second sentence in my response?
Yes, my patch does not change that.
Best regards
Heinrich
Changes in v3:
This API call is intended for allocating small amounts of memory, similar to malloc(). The current implementation rounds up to whole pages which can waste large amounts of memory. It also implements its own malloc()-style header on each block.
For certain allocations (those of type EFI_BOOT_SERVICES_DATA) we can use U-Boot's built-in malloc() instead, at least until the app starts. This avoids poluting the memory space with blocks of data which may interfere with boot scripts, etc.
Once the app has started, there is no advantage to using malloc(), since it doesn't matter what memory is used: everything is under control of the EFI subsystem. Also, using malloc() after the app starts might result in running of memory, since U-Boot's malloc() space is typically quite small.
In fact, malloc() is already used for most EFI-related allocations, so the impact of this change is fairly small.
One side effect is that this seems to be showing up some bugs in the EFI code, since the malloc() pool becomes corrupted with some tests. This has likely crept in due to the very large gaps between allocations (around 4KB), which provides a lot of leeway when the allocation size is too small. Work around this by increasing the size for now, until these (presumed) bugs are located.
(no changes since v1)
common/dlmalloc.c | 7 +++ include/efi_loader.h | 18 ++++++ include/malloc.h | 7 +++ lib/efi_loader/efi_bootbin.c | 2 + lib/efi_loader/efi_memory.c | 110 ++++++++++++++++++++++++++--------- 5 files changed, 117 insertions(+), 27 deletions(-)
diff --git a/common/dlmalloc.c b/common/dlmalloc.c index 1ac7ce3f43c..48e9f3515f7 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -613,6 +613,13 @@ void mem_malloc_init(ulong start, ulong size) #endif }
+bool malloc_check_in_range(void *ptr) +{ + ulong val = (ulong)ptr; + + return val >= mem_malloc_start && val < mem_malloc_end; +} + /* field-extraction macros */
#define first(b) ((b)->fd) diff --git a/include/efi_loader.h b/include/efi_loader.h index 38971d01442..d07bc06bad4 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -805,6 +805,24 @@ int efi_disk_probe(void *ctx, struct event *event); int efi_disk_remove(void *ctx, struct event *event); /* Called by board init to initialize the EFI memory map */ int efi_memory_init(void); + +/** + * enum efi_alloc_flags - controls EFI memory allocation + * + * @EFIAF_USE_MALLOC: Use malloc() pool for pool allocations of type + * EFI_BOOT_SERVICES_DATA, otherwise use page allocation + */ +enum efi_alloc_flags { + EFIAF_USE_MALLOC = BIT(0), +}; + +/** + * efi_set_alloc() - Set behaviour of EFI memory allocation + * + * @flags: new value for allocation flags (see enum efi_alloc_flags) + */ +void efi_set_alloc(int flags); + /* Adds new or overrides configuration table entry to the system table */ efi_status_t efi_install_configuration_table(const efi_guid_t *guid, void *table); /* Sets up a loaded image */ diff --git a/include/malloc.h b/include/malloc.h index 07d3e90a855..a64f117e2f2 100644 --- a/include/malloc.h +++ b/include/malloc.h @@ -983,6 +983,13 @@ extern ulong mem_malloc_brk;
void mem_malloc_init(ulong start, ulong size);
+/** + * malloc_check_in_range() - Check if a pointer is within the malloc() region + * + * Return: true if within malloc() region + */ +bool malloc_check_in_range(void *ptr); + #ifdef __cplusplus }; /* end of extern "C" */ #endif diff --git a/lib/efi_loader/efi_bootbin.c b/lib/efi_loader/efi_bootbin.c index a87006b3c0e..5bb0fdcf75d 100644 --- a/lib/efi_loader/efi_bootbin.c +++ b/lib/efi_loader/efi_bootbin.c @@ -201,6 +201,8 @@ efi_status_t efi_binary_run(void *image, size_t size, void *fdt) { efi_status_t ret;
+ efi_set_alloc(0); + /* Initialize EFI drivers */ ret = efi_init_obj_list(); if (ret != EFI_SUCCESS) { diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index 50cb2f3898b..206d10f207a 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -24,6 +24,14 @@ DECLARE_GLOBAL_DATA_PTR; /* Magic number identifying memory allocated from pool */ #define EFI_ALLOC_POOL_MAGIC 0x1fe67ddf6491caa2
+/* Flags controlling EFI memory-allocation - see enum efi_alloc_flags */ +static int alloc_flags; + +void efi_set_alloc(int flags) +{ + alloc_flags = flags; +} + efi_uintn_t efi_memory_map_key;
struct efi_mem_list { @@ -57,8 +65,12 @@ void *efi_bounce_buffer; * The checksum calculated in function checksum() is used in FreePool() to avoid * freeing memory not allocated by AllocatePool() and duplicate freeing. * - * EFI requires 8 byte alignment for pool allocations, so we can - * prepend each allocation with these header fields. + * EFI requires 8-byte alignment for pool allocations, so we can prepend each + * allocation with these header fields. + * + * Note that before the EFI app is booted, EFI_BOOT_SERVICES_DATA allocations + * are served using malloc(), bypassing this struct. This helps to avoid memory + * fragmentation, since efi_allocate_pages() uses any pages it likes. */ struct efi_pool_allocation { u64 num_pages; @@ -631,18 +643,19 @@ void *efi_alloc_aligned_pages(u64 len, int memory_type, size_t align) /** * efi_allocate_pool - allocate memory from pool * + * This uses malloc() for EFI_BOOT_SERVICES_DATA allocations if EFIAF_USE_MALLOC + * is enabled + * * @pool_type: type of the pool from which memory is to be allocated * @size: number of bytes to be allocated * @buffer: allocated memory * Return: status code */ -efi_status_t efi_allocate_pool(enum efi_memory_type pool_type, efi_uintn_t size, void **buffer) +efi_status_t efi_allocate_pool(enum efi_memory_type pool_type, efi_uintn_t size, + void **buffer) { efi_status_t r; u64 addr; - struct efi_pool_allocation *alloc; - u64 num_pages = efi_size_in_pages(size + - sizeof(struct efi_pool_allocation));
if (!buffer) return EFI_INVALID_PARAMETER; @@ -652,13 +665,43 @@ efi_status_t efi_allocate_pool(enum efi_memory_type pool_type, efi_uintn_t size, return EFI_SUCCESS; }
- r = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, pool_type, num_pages, - &addr); - if (r == EFI_SUCCESS) { - alloc = (struct efi_pool_allocation *)(uintptr_t)addr; - alloc->num_pages = num_pages; - alloc->checksum = checksum(alloc); - *buffer = alloc->data; + if ((alloc_flags & EFIAF_USE_MALLOC) && + pool_type == EFI_BOOT_SERVICES_DATA) { + void *ptr; + + /* + * Some tests crash on qemu_arm etc. if the correct size is + * allocated. + * Adding 0x10 seems to fix test_efi_selftest_device_tree + * Increasing it to 0x20 seems to fix test_efi_selftest_base + * except * for riscv64 (in CI only). But 0x100 fixes CI too. + * + * This workaround can be dropped once these problems are + * resolved + */ + ptr = memalign(8, size + 0x100); + if (!ptr) + return EFI_OUT_OF_RESOURCES; + + *buffer = ptr; + r = EFI_SUCCESS; + log_debug("EFI pool: malloc(%zx) = %p\n", size, ptr); + } else { + u64 num_pages = efi_size_in_pages(size + + sizeof(struct efi_pool_allocation)); + + r = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, pool_type, + num_pages, &addr); + if (r == EFI_SUCCESS) { + struct efi_pool_allocation *alloc; + + alloc = (struct efi_pool_allocation *)(uintptr_t)addr; + alloc->num_pages = num_pages; + alloc->checksum = checksum(alloc); + *buffer = alloc->data; + log_debug("EFI pool: pages alloc(%zx) type %d = %p\n", + size, pool_type, *buffer); + } }
return r; @@ -686,27 +729,37 @@ void *efi_alloc(size_t size) efi_status_t efi_free_pool(void *buffer) { efi_status_t ret; - struct efi_pool_allocation *alloc;
- ret = efi_check_allocated((uintptr_t)buffer, true); - if (ret != EFI_SUCCESS) - return ret; + if (malloc_check_in_range(buffer)) { + log_debug("EFI pool: free(%p)\n", buffer); + free(buffer); + ret = EFI_SUCCESS; + } else { + struct efi_pool_allocation *alloc;
- alloc = container_of(buffer, struct efi_pool_allocation, data); + ret = efi_check_allocated((uintptr_t)buffer, true); + if (ret != EFI_SUCCESS) + return ret;
- /* Check that this memory was allocated by efi_allocate_pool() */ - if (((uintptr_t)alloc & EFI_PAGE_MASK) || - alloc->checksum != checksum(alloc)) { - printf("%s: illegal free 0x%p\n", __func__, buffer); - return EFI_INVALID_PARAMETER; - } - /* Avoid double free */ - alloc->checksum = 0; + alloc = container_of(buffer, struct efi_pool_allocation, data);
- ret = efi_free_pages((uintptr_t)alloc, alloc->num_pages); + /* + * Check that this memory was allocated by efi_allocate_pool() + */ + if (((uintptr_t)alloc & EFI_PAGE_MASK) || + alloc->checksum != checksum(alloc)) { + printf("%s: illegal free 0x%p\n", __func__, buffer); + return EFI_INVALID_PARAMETER; + } + /* Avoid double free */ + alloc->checksum = 0; + + ret = efi_free_pages((uintptr_t)alloc, alloc->num_pages); + log_debug("EFI pool: pages free(%p)\n", buffer); + }
return ret; } @@ -926,6 +979,9 @@ static void add_u_boot_and_runtime(void)
int efi_memory_init(void) { + /* use malloc() pool where possible */ + efi_set_alloc(EFIAF_USE_MALLOC); + efi_add_known_memory();
add_u_boot_and_runtime();
- enum efi_alloc_flags - controls EFI memory allocation
- @EFIAF_USE_MALLOC: Use malloc() pool for pool allocations of type
- efi_set_alloc() - Set behaviour of EFI memory allocation
- @flags: new value for allocation flags (see enum efi_alloc_flags)
- malloc_check_in_range() - Check if a pointer is within the malloc() region
- Return: true if within malloc() region
efi_set_alloc(0);
Here we are setting the flags to use the efi_allocate_pages() route to allocate memory, when booting into an EFI app. Do we need to set it back to EFIAF_USE_MALLOC if the app exits and control lands back in U-Boot? I am not sure that is being handled.
-sughosh
- The checksum calculated in function checksum() is used in FreePool() to avoid
- freeing memory not allocated by AllocatePool() and duplicate freeing.
- EFI requires 8 byte alignment for pool allocations, so we can
- prepend each allocation with these header fields.
- EFI requires 8-byte alignment for pool allocations, so we can prepend each
- allocation with these header fields.
- Note that before the EFI app is booted, EFI_BOOT_SERVICES_DATA allocations
- are served using malloc(), bypassing this struct. This helps to avoid memory
- fragmentation, since efi_allocate_pages() uses any pages it likes.
- efi_allocate_pool - allocate memory from pool
- This uses malloc() for EFI_BOOT_SERVICES_DATA allocations if EFIAF_USE_MALLOC
- is enabled
- @pool_type: type of the pool from which memory is to be allocated
- @size: number of bytes to be allocated
- @buffer: allocated memory
- Return: status code
void **buffer)
sizeof(struct efi_pool_allocation)); if (!buffer) return EFI_INVALID_PARAMETER;
&addr);
void *ptr;
* allocated.
* resolved
if (!ptr)
*buffer = ptr;
r = EFI_SUCCESS;
} else {
num_pages, &addr);
} } return r;
struct efi_pool_allocation *alloc; if (!buffer) return EFI_INVALID_PARAMETER;
return ret;
free(buffer);
ret = EFI_SUCCESS;
} else {
return ret;
} return ret;
efi_add_known_memory(); add_u_boot_and_runtime();
-- 2.34.1
Hi Sughosh,
efi_set_alloc(0);
I don't believe so. Once we have booted into the app, U-Boot loses control of its memory layout, in the sense that the efi_allocate_pages() has likely been called and placed things all over the place in the memory. People should expect this.
We can potentially deal with this if we find a specific problem, but I can't think of one at the moment.
-sughosh
- is enabled
void **buffer)
&addr);
void *ptr;
* allocated.
* resolved
if (!ptr)
*buffer = ptr;
r = EFI_SUCCESS;
} else {
num_pages, &addr);
} } return r;
return ret;
free(buffer);
ret = EFI_SUCCESS;
} else {
return ret;
} return ret;
-- 2.34.1
On Fri, 6 Sept 2024 at 18:31, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
efi_set_alloc(0);
I am referring to a scenario where the app exits and control returns back to U-Boot, which I believe is a valid scenario. In such a case, should control not switch back to the malloc based allocations. Otherwise we do not have consistent behaviour with the allocations -- any subsequent calls to efi_allocate_pool on return from an EFI app would continue using the other (efi_allocate_pages() based) path.
This is of course with the assumption that the EFI maintainers are fine with using this hybrid approach on the allocations.
-sughosh
-sughosh
- is enabled
void **buffer)
&addr);
void *ptr;
* allocated.
* resolved
if (!ptr)
*buffer = ptr;
r = EFI_SUCCESS;
} else {
num_pages, &addr);
} } return r;
return ret;
free(buffer);
ret = EFI_SUCCESS;
} else {
return ret;
} return ret;
-- 2.34.1
Hi Sughosh,
Hi Sughosh,
efi_set_alloc(0);
Thanks for reviewing.
I completely understand your scenario, but I think I explained it above. The important thing is to keep memory 'consistent' from a U-Boot point of view until we actually boot something.
U-Boot expects memory from 0 to the bottom of the stack to be available for loading images. That is why it relocates itself.
Yes, I certainly hope so. This whole problem has caused an enormous amount of confusion and I very much want to clean it up.
-sughosh
-sughosh
- is enabled
void **buffer)
&addr);
void *ptr;
* allocated.
* resolved
if (!ptr)
*buffer = ptr;
r = EFI_SUCCESS;
} else {
num_pages, &addr);
} } return r;
return ret;
free(buffer);
ret = EFI_SUCCESS;
} else {
return ret;
} return ret;
-- 2.34.1
On Wed, 11 Sept 2024 at 00:14, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
Hi Sughosh,
efi_set_alloc(0);
How does reverting back to using the malloc heap for efi_allocate_pool() after returning back from the EFI app affect memory consistency? We now have the LMB memory map which is global and persistent. So any allocations that were done (and not freed) from the app, would be using the memory that you mention -- from 0 to bottom of the stack. In fact, I would argue that not reverting back to malloc based allocations on return from the app is inconsistent behaviour.
The EFI app is supposed to use the memory allocation API's (efi_allocate_{pages,pool}) for getting memory. And those requests are going to come from the LMB allocations (after the latest LMB rework series). So the heap memory is not supposed to be trampled over with.
-sughosh
-sughosh
-sughosh
- is enabled
void **buffer)
&addr);
void *ptr;
* allocated.
* resolved
if (!ptr)
*buffer = ptr;
r = EFI_SUCCESS;
} else {
num_pages, &addr);
} } return r;
return ret;
free(buffer);
ret = EFI_SUCCESS;
} else {
return ret;
} return ret;
-- 2.34.1
Hi Sughosh,
Hi Sughosh,
Hi Sughosh,
efi_set_alloc(0);
No, I mean we should *not* use memory from 0 to the bottom of the stack. That is supposed to be reserved for image loading. Scripts may assume they can do anything in this space and most boards have fixed addresses for kernel, etc.
I'm not quite sure what you are getting at here? My goal is to tidy up the allocation of memory *before* the app boots.
On 12.09.24 02:59, Simon Glass wrote:
Hi Sughosh,
Hi Sughosh,
Hi Sughosh,
On Mon, 2 Sept 2024 at 03:53, Simon Glass sjg@chromium.org wrote: > > This API call is intended for allocating small amounts of memory, > similar to malloc(). The current implementation rounds up to whole pages > which can waste large amounts of memory. It also implements its own > malloc()-style header on each block. > > For certain allocations (those of type EFI_BOOT_SERVICES_DATA) we can > use U-Boot's built-in malloc() instead, at least until the app starts. > This avoids poluting the memory space with blocks of data which may > interfere with boot scripts, etc. > > Once the app has started, there is no advantage to using malloc(), since > it doesn't matter what memory is used: everything is under control of > the EFI subsystem. Also, using malloc() after the app starts might > result in running of memory, since U-Boot's malloc() space is typically > quite small. > > In fact, malloc() is already used for most EFI-related allocations, so > the impact of this change is fairly small. > > One side effect is that this seems to be showing up some bugs in the > EFI code, since the malloc() pool becomes corrupted with some tests. > This has likely crept in due to the very large gaps between allocations > (around 4KB), which provides a lot of leeway when the allocation size is > too small. Work around this by increasing the size for now, until these > (presumed) bugs are located. > > Signed-off-by: Simon Glass sjg@chromium.org > --- > > (no changes since v1) > > common/dlmalloc.c | 7 +++ > include/efi_loader.h | 18 ++++++ > include/malloc.h | 7 +++ > lib/efi_loader/efi_bootbin.c | 2 + > lib/efi_loader/efi_memory.c | 110 ++++++++++++++++++++++++++--------- > 5 files changed, 117 insertions(+), 27 deletions(-) > > diff --git a/common/dlmalloc.c b/common/dlmalloc.c > index 1ac7ce3f43c..48e9f3515f7 100644 > --- a/common/dlmalloc.c > +++ b/common/dlmalloc.c > @@ -613,6 +613,13 @@ void mem_malloc_init(ulong start, ulong size) > #endif > } > > +bool malloc_check_in_range(void *ptr) > +{ > + ulong val = (ulong)ptr; > + > + return val >= mem_malloc_start && val < mem_malloc_end; > +} > + > /* field-extraction macros */ > > #define first(b) ((b)->fd) > diff --git a/include/efi_loader.h b/include/efi_loader.h > index 38971d01442..d07bc06bad4 100644 > --- a/include/efi_loader.h > +++ b/include/efi_loader.h > @@ -805,6 +805,24 @@ int efi_disk_probe(void *ctx, struct event *event); > int efi_disk_remove(void *ctx, struct event *event); > /* Called by board init to initialize the EFI memory map */ > int efi_memory_init(void); > + > +/** > + * enum efi_alloc_flags - controls EFI memory allocation > + * > + * @EFIAF_USE_MALLOC: Use malloc() pool for pool allocations of type > + * EFI_BOOT_SERVICES_DATA, otherwise use page allocation > + */ > +enum efi_alloc_flags { > + EFIAF_USE_MALLOC = BIT(0), > +}; > + > +/** > + * efi_set_alloc() - Set behaviour of EFI memory allocation > + * > + * @flags: new value for allocation flags (see enum efi_alloc_flags) > + */ > +void efi_set_alloc(int flags); > + > /* Adds new or overrides configuration table entry to the system table */ > efi_status_t efi_install_configuration_table(const efi_guid_t *guid, void *table); > /* Sets up a loaded image */ > diff --git a/include/malloc.h b/include/malloc.h > index 07d3e90a855..a64f117e2f2 100644 > --- a/include/malloc.h > +++ b/include/malloc.h > @@ -983,6 +983,13 @@ extern ulong mem_malloc_brk; > > void mem_malloc_init(ulong start, ulong size); > > +/** > + * malloc_check_in_range() - Check if a pointer is within the malloc() region > + * > + * Return: true if within malloc() region > + */ > +bool malloc_check_in_range(void *ptr); > + > #ifdef __cplusplus > }; /* end of extern "C" */ > #endif > diff --git a/lib/efi_loader/efi_bootbin.c b/lib/efi_loader/efi_bootbin.c > index a87006b3c0e..5bb0fdcf75d 100644 > --- a/lib/efi_loader/efi_bootbin.c > +++ b/lib/efi_loader/efi_bootbin.c > @@ -201,6 +201,8 @@ efi_status_t efi_binary_run(void *image, size_t size, void *fdt) > { > efi_status_t ret; > > + efi_set_alloc(0); > +
AllocatePool() can be used to allocate multiple GiB of memory. The malloc pool is too small for this purpose. You would first have to change the malloc implementation to acquire arbitrary amounts of memory from LMB.
Please, don't complicate the code by treating different memory types differently in AllocatePool().
The way forward is to change LMB to store EFI memory types. This will allow us to remove most of the code in lib/efi_loader/efi_memory.c.
Once that integration work is done we can start thinking about generalizing malloc() to support multiple memory pools of arbitrary size to encompass AllocatePool().
Best regards
Heinrich
Hi Heinrich,
Hi Sughosh,
Hi Sughosh,
Hi Sughosh,
On Fri, 6 Sept 2024 at 00:23, Sughosh Ganu sughosh.ganu@linaro.org wrote: > > On Mon, 2 Sept 2024 at 03:53, Simon Glass sjg@chromium.org wrote: >> >> This API call is intended for allocating small amounts of memory, >> similar to malloc(). The current implementation rounds up to whole pages >> which can waste large amounts of memory. It also implements its own >> malloc()-style header on each block. >> >> For certain allocations (those of type EFI_BOOT_SERVICES_DATA) we can >> use U-Boot's built-in malloc() instead, at least until the app starts. >> This avoids poluting the memory space with blocks of data which may >> interfere with boot scripts, etc. >> >> Once the app has started, there is no advantage to using malloc(), since >> it doesn't matter what memory is used: everything is under control of >> the EFI subsystem. Also, using malloc() after the app starts might >> result in running of memory, since U-Boot's malloc() space is typically >> quite small. >> >> In fact, malloc() is already used for most EFI-related allocations, so >> the impact of this change is fairly small. >> >> One side effect is that this seems to be showing up some bugs in the >> EFI code, since the malloc() pool becomes corrupted with some tests. >> This has likely crept in due to the very large gaps between allocations >> (around 4KB), which provides a lot of leeway when the allocation size is >> too small. Work around this by increasing the size for now, until these >> (presumed) bugs are located. >> >> Signed-off-by: Simon Glass sjg@chromium.org >> --- >> >> (no changes since v1) >> >> common/dlmalloc.c | 7 +++ >> include/efi_loader.h | 18 ++++++ >> include/malloc.h | 7 +++ >> lib/efi_loader/efi_bootbin.c | 2 + >> lib/efi_loader/efi_memory.c | 110 ++++++++++++++++++++++++++--------- >> 5 files changed, 117 insertions(+), 27 deletions(-) >> >> diff --git a/common/dlmalloc.c b/common/dlmalloc.c >> index 1ac7ce3f43c..48e9f3515f7 100644 >> --- a/common/dlmalloc.c >> +++ b/common/dlmalloc.c >> @@ -613,6 +613,13 @@ void mem_malloc_init(ulong start, ulong size) >> #endif >> } >> >> +bool malloc_check_in_range(void *ptr) >> +{ >> + ulong val = (ulong)ptr; >> + >> + return val >= mem_malloc_start && val < mem_malloc_end; >> +} >> + >> /* field-extraction macros */ >> >> #define first(b) ((b)->fd) >> diff --git a/include/efi_loader.h b/include/efi_loader.h >> index 38971d01442..d07bc06bad4 100644 >> --- a/include/efi_loader.h >> +++ b/include/efi_loader.h >> @@ -805,6 +805,24 @@ int efi_disk_probe(void *ctx, struct event *event); >> int efi_disk_remove(void *ctx, struct event *event); >> /* Called by board init to initialize the EFI memory map */ >> int efi_memory_init(void); >> + >> +/** >> + * enum efi_alloc_flags - controls EFI memory allocation >> + * >> + * @EFIAF_USE_MALLOC: Use malloc() pool for pool allocations of type >> + * EFI_BOOT_SERVICES_DATA, otherwise use page allocation >> + */ >> +enum efi_alloc_flags { >> + EFIAF_USE_MALLOC = BIT(0), >> +}; >> + >> +/** >> + * efi_set_alloc() - Set behaviour of EFI memory allocation >> + * >> + * @flags: new value for allocation flags (see enum efi_alloc_flags) >> + */ >> +void efi_set_alloc(int flags); >> + >> /* Adds new or overrides configuration table entry to the system table */ >> efi_status_t efi_install_configuration_table(const efi_guid_t *guid, void *table); >> /* Sets up a loaded image */ >> diff --git a/include/malloc.h b/include/malloc.h >> index 07d3e90a855..a64f117e2f2 100644 >> --- a/include/malloc.h >> +++ b/include/malloc.h >> @@ -983,6 +983,13 @@ extern ulong mem_malloc_brk; >> >> void mem_malloc_init(ulong start, ulong size); >> >> +/** >> + * malloc_check_in_range() - Check if a pointer is within the malloc() region >> + * >> + * Return: true if within malloc() region >> + */ >> +bool malloc_check_in_range(void *ptr); >> + >> #ifdef __cplusplus >> }; /* end of extern "C" */ >> #endif >> diff --git a/lib/efi_loader/efi_bootbin.c b/lib/efi_loader/efi_bootbin.c >> index a87006b3c0e..5bb0fdcf75d 100644 >> --- a/lib/efi_loader/efi_bootbin.c >> +++ b/lib/efi_loader/efi_bootbin.c >> @@ -201,6 +201,8 @@ efi_status_t efi_binary_run(void *image, size_t size, void *fdt) >> { >> efi_status_t ret; >> >> + efi_set_alloc(0); >> + > > Here we are setting the flags to use the efi_allocate_pages() route to > allocate memory, when booting into an EFI app. Do we need to set it > back to EFIAF_USE_MALLOC if the app exits and control lands back in > U-Boot? I am not sure that is being handled.
Unfortunately that is not the correct approach at all. I fully understand where you are coming from, but the complexity involved is wrong for U-Boot.
I do not have to have to change the malloc() implementation at all. It is perfectly fine as it is. It is only EFI that needs to change slightly, using malloc() for the pool until the app starts.
We also need to consider what happens when EFI_LOADER is disabled, which I am intent on preserving.
Best regards
Heinrich
Hi Simon,
Apologies for the late reply, I was attending a conference.
Why do we need to handle cases differently? IOW can't all EFI allocations that need a pool gi via malloc?
- is enabled
void **buffer)
&addr);
void *ptr;
* allocated.
* resolved
I don't think the explanation is enough here. On top of that adding random values to fix the problem doesn't sound right. Can we figure out why?
if (!ptr)
*buffer = ptr;
r = EFI_SUCCESS;
So as I commented above, I think this is papering over whatever problem you are seeing. If you want to move the pool to use malloc() that's fine, but *all* of the pool allocations should use it. Not just boot services because its easier to retrofit it on the current code.
} else {
num_pages, &addr);
} } return r;
return ret;
free(buffer);
ret = EFI_SUCCESS;
} else {
return ret;
Thanks /Ilias
Hi Ilias,
On Fri, 6 Sept 2024 at 01:13, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon,
Once the app boots, as Heinrich pointed out, it expects to be able to malloc() very large amount of memory, but the malloc() pool is small.
- is enabled
void **buffer)
&addr);
void *ptr;
* allocated.
* resolved
My guess is that an allocated pointer is going beyond its limits. The newer upstream dlmalloc() has a checker which might help. I fiddled around a bit but could not work one where the problem was.
if (!ptr)
*buffer = ptr;
r = EFI_SUCCESS;
Please see above. Also, please see the commit message. This change actually solves the problems I am seeing, quite well.
} else {
num_pages, &addr);
} } return r;
return ret;
free(buffer);
ret = EFI_SUCCESS;
} else {
return ret;
Hi Simon,
On Fri, 6 Sept 2024 at 16:01, Simon Glass sjg@chromium.org wrote:
Hi Ilias,
Hi Simon,
This won't happen with LMB merged no?
Where? We explained in the past that malloc is only used to handle internal EFI stuff which don't need the efi allocations and that's perfectly fine.
Yes, it does. My problem is that right now we have everything in the same pool, handled by LMB, but you are arguing it's 'cleaner' to split the allocations. I can't really understand what the problem with the current allocations is.
- is enabled
void **buffer)
&addr);
void *ptr;
* allocated.
* resolved
Ok, but I don't want us to pull code with random values that happened to work during testing. We need to understand why
if (!ptr)
*buffer = ptr;
r = EFI_SUCCESS;
I did and the only 'problem' that is mentioned is polluting and overwriting memory of scripts etc. But that goes away with LMB AFAICT. So the only advantage is that you save a few kbs of space when requesting pool allocations?
Thanks /Ilias
} else {
num_pages, &addr);
} } return r;
return ret;
free(buffer);
ret = EFI_SUCCESS;
} else {
return ret;
Hi Ilias,
On Thu, 12 Sept 2024 at 08:37, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon,
Hi Ilias,
Hi Simon,
It still happens with LMB merged. As I covered in the cover letter, this is orthogonal to all of that. In fact, I think a lot of the effort there is actually missing the point, unfortunately.
I see only about 5 allocations affected by this change, when booting from EFI.
The problem is that they happen in space, between the bottom of memory and the bottom of the stack. That is the area which is supposed to not be used by U-Boot.
- is enabled
void **buffer)
&addr);
void *ptr;
* allocated.
* resolved
It is presumably because of bugs in the EFI code. The current code adds about 4KB to the size of each allocation, so adding 100 bytes is at least an improvement. I did do some digging but couldn't immediately locate any bugs. To be honest I am not sure what is going on.
But once I have these two EFI series in, I will spend some time digging into it and help fix these (presumed) bugs.
if (!ptr)
*buffer = ptr;
r = EFI_SUCCESS;
No, you misunderstand. I am happy to arrange a call to go through this if it is still unclear from my comment above. When I say this is orthogonal to the lmb series, I really do mean that.
Thanks /Ilias
} else {
num_pages, &addr);
} } return r;
return ret;
free(buffer);
ret = EFI_SUCCESS;
} else {
return ret;
Hi Simon
A few more comments after looking into this a bit more
On Mon, Sep 16, 2024 at 05:42:59PM +0200, Simon Glass wrote:
Hi Ilias,
Hi Simon,
Hi Ilias,
Hi Simon,
Well it's not only for small memory. Look below.
Yes and there is a reason for that. The EFI spec description is
"The AllocatePool() function allocates a memory region of Size bytes from memory of type PoolType and returns the address of the allocated memory in the location referenced by Buffer. This function allocates *pages* from EfiConventionalMemory as needed to grow the requested pool type. All allocations are eight-byte aligned. The allocated pool memory is returned to the available pool with the EFI_BOOT_SERVICES.FreePool() function"
The current implementation of efi_allocate_pool kind of does that, but is indeed very inefficient, since it allocates a single page and pool every time. A proper implementation would be to allocate a page and return the size needed. Then for every subsequent request to the same pooltype, you look up the existing pool, and return the requested memory. If the pool is depleted you allocate another *page* and so on and so forth. That's where the metadata is actually useful.
So the suggested solution here is trying to fix an existing hack, by papering over the problem with *another* hack that will basically make the process of fixing efi_allocate_pool() properly impossible.
So why isn't this an LMB problem since we plan to use it for EFI allocations? LMB is trying to fix similar issues for efi_allocate_pages(). Once that's done efi_allocate_pool() which calls efi_allocate_pages() is automatically sorted. So the only problem is efficiency, no ?
What we can do, is go over the usage of efi_allocate_pool(). A quick grep showed a few uses, but I am pretty certain those can be replaced by efi_allocate_pages().
Thanks /Ilias
- is enabled
void **buffer)
&addr);
void *ptr;
* allocated.
* resolved
if (!ptr)
*buffer = ptr;
r = EFI_SUCCESS;
Thanks /Ilias
} else {
num_pages, &addr);
} } return r;
return ret;
free(buffer);
ret = EFI_SUCCESS;
} else {
return ret;
Thanks /Ilias
Hi Ilias,
On Fri, 20 Sept 2024 at 14:10, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon
Hi Ilias,
Hi Simon,
Hi Ilias,
Hi Simon,
Yes, you are right, I was imprecise. In U-Boot, it it used for allocations or small amounts of memory. Until the app runs, we have control over this, so can be sure the allocations will be small. After that, allocations could be very large.
It actually makes it easier, doesn't it? We can decrease the 'margin' I have set in the patch until we see the first failure, then fix the bug thus exposed, decrease it again, etc. Eventually when all the bugs are fixed, the margin will be zero.
We are still not on the same page with this. If you happen to be at Plumbers, let's have a chat. Otherwise we can try to have a call to go over it.
Oh dear, please no. Until the EFI app runs, we should not use that function. It uses memory which should not be used for simple allocations, but instead kept free for images.
Thanks /Ilias
- is enabled
void **buffer)
&addr);
void *ptr;
* allocated.
* resolved
if (!ptr)
*buffer = ptr;
r = EFI_SUCCESS;
Thanks /Ilias
} else {
num_pages, &addr);
} } return r;
return ret;
free(buffer);
ret = EFI_SUCCESS;
} else {
return ret;
Thanks /Ilias
On Fri, 20 Sept 2024 at 19:03, Simon Glass sjg@chromium.org wrote:
Hi Ilias,
Hi Simon
Hi Ilias,
Hi Simon,
Hi Ilias,
Hi Simon,
On Mon, 2 Sept 2024 at 01:23, Simon Glass sjg@chromium.org wrote: > > This API call is intended for allocating small amounts of memory,
Not really. The AllocatePool says "it must allocate pages" for a reason, which we did discuss in earlier versions of the patch. How do you plan to deal with memory attributes and permissions when allocating memory, which you can only control per page?
EFI is a spec. You either adhere to it or not. You can't change random parts because it interferes with U-Boot image loading assumptions that were in place *before* merging EFI. This is a memory dump on QEMU aarch64. and
CONVENTIONAL 0000000040000000-000000023d52e000 WB BOOT DATA 000000023d52e000-000000023d533000 WB RUNTIME DATA 000000023d533000-000000023d534000 WB|RT BOOT DATA 000000023d534000-000000023d535000 WB ACPI NVS 000000023d535000-000000023d546000 WB BOOT DATA 000000023d546000-000000023d558000 WB RUNTIME DATA 000000023d558000-000000023d57a000 WB|RT BOOT DATA 000000023d57a000-000000023d585000 WB BOOT CODE 000000023d585000-000000023e6a3000 WB RUNTIME DATA 000000023e6a3000-000000023e6a4000 WB|RT BOOT CODE 000000023e6a4000-000000023f6c0000 WB RUNTIME CODE 000000023f6c0000-000000023f6d0000 WB|RT BOOT CODE 000000023f6d0000-0000000240000000 WB
As you can see the memory from the bottom is empty and free to load images. efi_find_free_memory() is always trying to allocate the highest available memory and stay out of the way.
So this is one more point..., efi_allocate_pages is used more than EFI allocate pool. So I really don't see any point in merging this. AFAICT it makes it impossible to fix memory permissions, it only deals with a very small fraction of the problem, it fragments the EFI memory management since random parts go via malloc now etc etc.
Thanks
/Ilias
Thanks /Ilias
> @@ -24,6 +24,14 @@ DECLARE_GLOBAL_DATA_PTR; > /* Magic number identifying memory allocated from pool */ > #define EFI_ALLOC_POOL_MAGIC 0x1fe67ddf6491caa2 > > +/* Flags controlling EFI memory-allocation - see enum efi_alloc_flags */ > +static int alloc_flags; > + > +void efi_set_alloc(int flags) > +{ > + alloc_flags = flags; > +} > + > efi_uintn_t efi_memory_map_key; > > struct efi_mem_list { > @@ -57,8 +65,12 @@ void *efi_bounce_buffer; > * The checksum calculated in function checksum() is used in FreePool() to avoid > * freeing memory not allocated by AllocatePool() and duplicate freeing. > * > - * EFI requires 8 byte alignment for pool allocations, so we can > - * prepend each allocation with these header fields. > + * EFI requires 8-byte alignment for pool allocations, so we can prepend each > + * allocation with these header fields. > + * > + * Note that before the EFI app is booted, EFI_BOOT_SERVICES_DATA allocations > + * are served using malloc(), bypassing this struct. This helps to avoid memory > + * fragmentation, since efi_allocate_pages() uses any pages it likes. > */ > struct efi_pool_allocation { > u64 num_pages; > @@ -631,18 +643,19 @@ void *efi_alloc_aligned_pages(u64 len, int memory_type, size_t align) > /** > * efi_allocate_pool - allocate memory from pool > * > + * This uses malloc() for EFI_BOOT_SERVICES_DATA allocations if EFIAF_USE_MALLOC > + * is enabled > + * > * @pool_type: type of the pool from which memory is to be allocated > * @size: number of bytes to be allocated > * @buffer: allocated memory > * Return: status code > */ > -efi_status_t efi_allocate_pool(enum efi_memory_type pool_type, efi_uintn_t size, void **buffer) > +efi_status_t efi_allocate_pool(enum efi_memory_type pool_type, efi_uintn_t size, > + void **buffer) > { > efi_status_t r; > u64 addr; > - struct efi_pool_allocation *alloc; > - u64 num_pages = efi_size_in_pages(size + > - sizeof(struct efi_pool_allocation)); > > if (!buffer) > return EFI_INVALID_PARAMETER; > @@ -652,13 +665,43 @@ efi_status_t efi_allocate_pool(enum efi_memory_type pool_type, efi_uintn_t size, > return EFI_SUCCESS; > } > > - r = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, pool_type, num_pages, > - &addr); > - if (r == EFI_SUCCESS) { > - alloc = (struct efi_pool_allocation *)(uintptr_t)addr; > - alloc->num_pages = num_pages; > - alloc->checksum = checksum(alloc); > - *buffer = alloc->data; > + if ((alloc_flags & EFIAF_USE_MALLOC) && > + pool_type == EFI_BOOT_SERVICES_DATA) { > + void *ptr; > + > + /* > + * Some tests crash on qemu_arm etc. if the correct size is > + * allocated. > + * Adding 0x10 seems to fix test_efi_selftest_device_tree > + * Increasing it to 0x20 seems to fix test_efi_selftest_base > + * except * for riscv64 (in CI only). But 0x100 fixes CI too. > + * > + * This workaround can be dropped once these problems are > + * resolved > + */ > + ptr = memalign(8, size + 0x100);
> + if (!ptr) > + return EFI_OUT_OF_RESOURCES; > + > + *buffer = ptr; > + r = EFI_SUCCESS; > + log_debug("EFI pool: malloc(%zx) = %p\n", size, ptr);
Thanks /Ilias
> + } else { > + u64 num_pages = efi_size_in_pages(size + > + sizeof(struct efi_pool_allocation)); > + > + r = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, pool_type, > + num_pages, &addr); > + if (r == EFI_SUCCESS) { > + struct efi_pool_allocation *alloc; > + > + alloc = (struct efi_pool_allocation *)(uintptr_t)addr; > + alloc->num_pages = num_pages; > + alloc->checksum = checksum(alloc); > + *buffer = alloc->data; > + log_debug("EFI pool: pages alloc(%zx) type %d = %p\n", > + size, pool_type, *buffer); > + } > } > > return r; > @@ -686,27 +729,37 @@ void *efi_alloc(size_t size) > efi_status_t efi_free_pool(void *buffer) > { > efi_status_t ret; > - struct efi_pool_allocation *alloc; > > if (!buffer) > return EFI_INVALID_PARAMETER; > > - ret = efi_check_allocated((uintptr_t)buffer, true); > - if (ret != EFI_SUCCESS) > - return ret; > + if (malloc_check_in_range(buffer)) { > + log_debug("EFI pool: free(%p)\n", buffer); > + free(buffer); > + ret = EFI_SUCCESS; > + } else { > + struct efi_pool_allocation *alloc; > > - alloc = container_of(buffer, struct efi_pool_allocation, data); > + ret = efi_check_allocated((uintptr_t)buffer, true); > + if (ret != EFI_SUCCESS) > + return ret; > [...]
Thanks /Ilias
Hi Ilias,
On Mon, 23 Sept 2024 at 12:03, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Ilias,
Hi Simon
Hi Ilias,
Hi Simon,
Hi Ilias,
On Fri, 6 Sept 2024 at 01:13, Ilias Apalodimas ilias.apalodimas@linaro.org wrote: > > Hi Simon, > > Apologies for the late reply, I was attending a conference. > > On Mon, 2 Sept 2024 at 01:23, Simon Glass sjg@chromium.org wrote: > > > > This API call is intended for allocating small amounts of memory,
> > similar to malloc(). The current implementation rounds up to whole pages > > which can waste large amounts of memory. It also implements its own > > malloc()-style header on each block.
How about this explantion?:
1) The pool-allocation is only used by U-Boot itself until the app starts (obviously :-) 2) Until that point all pool allocations are boot-services data 3) We can therefore simply mark the malloc() region as boot-services data 4) If what you say is true, how does that square with add_u_boot_and_runtime() which sets the whole region (code and malloc() region, etc.) to boot-services code?
I have no intention of changing any parts, random or otherwise
That's good, but not quite good enough. We need to use the existing malloc() pool until the app starts.
> > > > For certain allocations (those of type EFI_BOOT_SERVICES_DATA) we can > > use U-Boot's built-in malloc() instead, at least until the app starts. > > This avoids poluting the memory space with blocks of data which may > > interfere with boot scripts, etc.
> > > > Once the app has started, there is no advantage to using malloc(), since > > it doesn't matter what memory is used: everything is under control of > > the EFI subsystem. Also, using malloc() after the app starts might > > result in running of memory, since U-Boot's malloc() space is typically > > quite small. > > > > In fact, malloc() is already used for most EFI-related allocations, so > > the impact of this change is fairly small.
It is so odd that we are completely talking at cross-purposes after so many weeks.
The fragmenting of memory is the current state. All of U-Boot's allocations go through malloc(), except for EFI which have their own, strange, confusing, unnecessary variation. We need to clean this up. EFI should use malloc() just like any other *part of U-Boot*.
When and if we get to a patch to change the memory permissions, we can do so for the whole malloc() region, surely? It doesn't make a lot of sense to me to allow code execution in the malloc() region...
Thanks
/Ilias
Thanks /Ilias
> > > > One side effect is that this seems to be showing up some bugs in the > > EFI code, since the malloc() pool becomes corrupted with some tests. > > This has likely crept in due to the very large gaps between allocations > > (around 4KB), which provides a lot of leeway when the allocation size is > > too small. Work around this by increasing the size for now, until these > > (presumed) bugs are located. > > > > Signed-off-by: Simon Glass sjg@chromium.org > > --- > > > > (no changes since v1) > > > > common/dlmalloc.c | 7 +++ > > include/efi_loader.h | 18 ++++++ > > include/malloc.h | 7 +++ > > lib/efi_loader/efi_bootbin.c | 2 + > > lib/efi_loader/efi_memory.c | 110 ++++++++++++++++++++++++++--------- > > 5 files changed, 117 insertions(+), 27 deletions(-) > > > > diff --git a/common/dlmalloc.c b/common/dlmalloc.c > > index 1ac7ce3f43c..48e9f3515f7 100644 > > --- a/common/dlmalloc.c > > +++ b/common/dlmalloc.c > > @@ -613,6 +613,13 @@ void mem_malloc_init(ulong start, ulong size) > > #endif > > } > > > > +bool malloc_check_in_range(void *ptr) > > +{ > > + ulong val = (ulong)ptr; > > + > > + return val >= mem_malloc_start && val < mem_malloc_end; > > +} > > + > > /* field-extraction macros */ > > > > #define first(b) ((b)->fd) > > diff --git a/include/efi_loader.h b/include/efi_loader.h > > index 38971d01442..d07bc06bad4 100644 > > --- a/include/efi_loader.h > > +++ b/include/efi_loader.h > > @@ -805,6 +805,24 @@ int efi_disk_probe(void *ctx, struct event *event); > > int efi_disk_remove(void *ctx, struct event *event); > > /* Called by board init to initialize the EFI memory map */ > > int efi_memory_init(void); > > + > > +/** > > + * enum efi_alloc_flags - controls EFI memory allocation > > + * > > + * @EFIAF_USE_MALLOC: Use malloc() pool for pool allocations of type > > + * EFI_BOOT_SERVICES_DATA, otherwise use page allocation > > + */ > > +enum efi_alloc_flags { > > + EFIAF_USE_MALLOC = BIT(0), > > +}; > > Why do we need to handle cases differently? IOW can't all EFI > allocations that need a pool gi via malloc?
> > [...] > > > @@ -24,6 +24,14 @@ DECLARE_GLOBAL_DATA_PTR; > > /* Magic number identifying memory allocated from pool */ > > #define EFI_ALLOC_POOL_MAGIC 0x1fe67ddf6491caa2 > > > > +/* Flags controlling EFI memory-allocation - see enum efi_alloc_flags */ > > +static int alloc_flags; > > + > > +void efi_set_alloc(int flags) > > +{ > > + alloc_flags = flags; > > +} > > + > > efi_uintn_t efi_memory_map_key; > > > > struct efi_mem_list { > > @@ -57,8 +65,12 @@ void *efi_bounce_buffer; > > * The checksum calculated in function checksum() is used in FreePool() to avoid > > * freeing memory not allocated by AllocatePool() and duplicate freeing. > > * > > - * EFI requires 8 byte alignment for pool allocations, so we can > > - * prepend each allocation with these header fields. > > + * EFI requires 8-byte alignment for pool allocations, so we can prepend each > > + * allocation with these header fields. > > + * > > + * Note that before the EFI app is booted, EFI_BOOT_SERVICES_DATA allocations > > + * are served using malloc(), bypassing this struct. This helps to avoid memory > > + * fragmentation, since efi_allocate_pages() uses any pages it likes. > > */ > > struct efi_pool_allocation { > > u64 num_pages; > > @@ -631,18 +643,19 @@ void *efi_alloc_aligned_pages(u64 len, int memory_type, size_t align) > > /** > > * efi_allocate_pool - allocate memory from pool > > * > > + * This uses malloc() for EFI_BOOT_SERVICES_DATA allocations if EFIAF_USE_MALLOC > > + * is enabled > > + * > > * @pool_type: type of the pool from which memory is to be allocated > > * @size: number of bytes to be allocated > > * @buffer: allocated memory > > * Return: status code > > */ > > -efi_status_t efi_allocate_pool(enum efi_memory_type pool_type, efi_uintn_t size, void **buffer) > > +efi_status_t efi_allocate_pool(enum efi_memory_type pool_type, efi_uintn_t size, > > + void **buffer) > > { > > efi_status_t r; > > u64 addr; > > - struct efi_pool_allocation *alloc; > > - u64 num_pages = efi_size_in_pages(size + > > - sizeof(struct efi_pool_allocation)); > > > > if (!buffer) > > return EFI_INVALID_PARAMETER; > > @@ -652,13 +665,43 @@ efi_status_t efi_allocate_pool(enum efi_memory_type pool_type, efi_uintn_t size, > > return EFI_SUCCESS; > > } > > > > - r = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, pool_type, num_pages, > > - &addr); > > - if (r == EFI_SUCCESS) { > > - alloc = (struct efi_pool_allocation *)(uintptr_t)addr; > > - alloc->num_pages = num_pages; > > - alloc->checksum = checksum(alloc); > > - *buffer = alloc->data; > > + if ((alloc_flags & EFIAF_USE_MALLOC) && > > + pool_type == EFI_BOOT_SERVICES_DATA) { > > + void *ptr; > > + > > + /* > > + * Some tests crash on qemu_arm etc. if the correct size is > > + * allocated. > > + * Adding 0x10 seems to fix test_efi_selftest_device_tree > > + * Increasing it to 0x20 seems to fix test_efi_selftest_base > > + * except * for riscv64 (in CI only). But 0x100 fixes CI too. > > + * > > + * This workaround can be dropped once these problems are > > + * resolved > > + */ > > + ptr = memalign(8, size + 0x100); > > I don't think the explanation is enough here. On top of that adding > random values to fix the problem doesn't sound right. Can we figure > out why?
> > > + if (!ptr) > > + return EFI_OUT_OF_RESOURCES; > > + > > + *buffer = ptr; > > + r = EFI_SUCCESS; > > + log_debug("EFI pool: malloc(%zx) = %p\n", size, ptr); > > So as I commented above, I think this is papering over whatever > problem you are seeing. If you want to move the pool to use malloc() > that's fine, but *all* of the pool allocations should use it. Not just > boot services because its easier to retrofit it on the current code.
Thanks /Ilias
> > > + } else { > > + u64 num_pages = efi_size_in_pages(size + > > + sizeof(struct efi_pool_allocation)); > > + > > + r = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, pool_type, > > + num_pages, &addr); > > + if (r == EFI_SUCCESS) { > > + struct efi_pool_allocation *alloc; > > + > > + alloc = (struct efi_pool_allocation *)(uintptr_t)addr; > > + alloc->num_pages = num_pages; > > + alloc->checksum = checksum(alloc); > > + *buffer = alloc->data; > > + log_debug("EFI pool: pages alloc(%zx) type %d = %p\n", > > + size, pool_type, *buffer); > > + } > > } > > > > return r; > > @@ -686,27 +729,37 @@ void *efi_alloc(size_t size) > > efi_status_t efi_free_pool(void *buffer) > > { > > efi_status_t ret; > > - struct efi_pool_allocation *alloc; > > > > if (!buffer) > > return EFI_INVALID_PARAMETER; > > > > - ret = efi_check_allocated((uintptr_t)buffer, true); > > - if (ret != EFI_SUCCESS) > > - return ret; > > + if (malloc_check_in_range(buffer)) { > > + log_debug("EFI pool: free(%p)\n", buffer); > > + free(buffer); > > + ret = EFI_SUCCESS; > > + } else { > > + struct efi_pool_allocation *alloc; > > > > - alloc = container_of(buffer, struct efi_pool_allocation, data); > > + ret = efi_check_allocated((uintptr_t)buffer, true); > > + if (ret != EFI_SUCCESS) > > + return ret; > > > [...]
Thanks /Ilias
The EFI_LOADER_BOUNCE_BUFFER feature was added many years ago. It is not clear whether it is still needed, but 24 boards (lx2160ardb_tfa_stmm, lx2162aqds_tfa_SECURE_BOOT and the like) use it.
This feature uses EFI page allocation to create a 64MB buffer 'in space' without any knowledge of where boards intend to load their images. This may result in image corruption or other problems.
For example, if the feature is enabled on qemu_arm64 it puts the EFI bounce buffer at 1045MB, with the kernel at 1028MB and the ramdisk at 1088MB. The kernel is probably smaller than 27MB but the buffer does overlap the ramdisk.
The solution is probably to use BOUNCE_BUFFER instead, with the EFI version being dropped. For now, show the address of the EFI bounce buffer so people have a better chance to detect the problem.
Note: I avoided converting this #ifdef to use IS_ENABLED() since I hope that the feature may be removed.
(no changes since v2)
lib/efi_loader/efi_bootbin.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/lib/efi_loader/efi_bootbin.c b/lib/efi_loader/efi_bootbin.c index 5bb0fdcf75d..9779dc09b5e 100644 --- a/lib/efi_loader/efi_bootbin.c +++ b/lib/efi_loader/efi_bootbin.c @@ -211,6 +211,15 @@ efi_status_t efi_binary_run(void *image, size_t size, void *fdt) return -1; }
+#ifdef CONFIG_EFI_LOADER_BOUNCE_BUFFER + /* + * Add a warning about this buffer, since it may conflict with other + * things + */ + log_warning("Warning: EFI bounce buffer %p-%p\n", efi_bounce_buffer, + efi_bounce_buffer + EFI_LOADER_BOUNCE_BUFFER_SIZE); +#endif + ret = efi_install_fdt(fdt); if (ret != EFI_SUCCESS) return ret;
Am 2. September 2024 00:22:59 MESZ schrieb Simon Glass sjg@chromium.org:
The functionality is still needed. A warning is of little use: what should the user do about it? The region should be reserved in LMB.
Best regards
Heinrich
Changes in v2:
* things
- log_warning("Warning: EFI bounce buffer %p-%p\n", efi_bounce_buffer,
- ret = efi_install_fdt(fdt); if (ret != EFI_SUCCESS) return ret;
Hi Heinrich,
I don't mind dropping this patch if we can get the other two applied. I suppose my main purpose was to highlight this sort of issue and get something in the commit log about it. For me, the message helped me understand why memory regions were overlapping.
Best regards
Heinrich
Changes in v2:
* things
Hi Simon,
Thank you for this series.
I did test it on top of v2024.10-rc4 with AArch64 simulators (FVP & Qemu), with OS boots and ACS-IR, and I see no regression. Same with sandbox on x86 and the python tests.
Best regards, Vincent.
Changes in v3:
Changes in v2:
-- 2.34.1
Hi Vincent,
Hi Simon,
Thank you for testing.
Ilias, Heinrich, can this series (and the EFI-test one) be applied? Sughosh has already sent a follow up where we start to diverge on how to fix the memory-allocation problems, so I would like to make sure these are in there first.
Changes in v3:
Changes in v2:
-- 2.34.1
participants (5)
Ilias Apalodimas
Sughosh Ganu
Vincent Stehlé
