[PATCH] mmc: remove unneeded forward declarations
These functions are defined before the callers.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/mmc/mmc.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index b26e266c1c29..dd8e29460cef 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -24,10 +24,6 @@ #define DEFAULT_CMD6_TIMEOUT_MS 500
static int mmc_set_signal_voltage(struct mmc *mmc, uint signal_voltage); -static int mmc_power_cycle(struct mmc *mmc); -#if !CONFIG_IS_ENABLED(MMC_TINY) -static int mmc_select_mode_and_width(struct mmc *mmc, uint card_caps); -#endif
#if !CONFIG_IS_ENABLED(DM_MMC)
Subject: [PATCH] mmc: remove unneeded forward declarations
Reviewed-by: Peng Fan peng.fan@nxp.com
-- 2.17.1
Masahiro Yamada
Peng Fan
