[U-Boot] [PATCH] 4xx_enet.c: fix GCC 4.6 build warnings
Fix: 4xx_enet.c: In function 'enet_rcv': 4xx_enet.c:1772:21: warning: variable 'ef_ptr' set but not used [-Wunused-but-set-variable]
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Stefan Roese sr@denx.de --- drivers/net/4xx_enet.c | 3 --- 1 files changed, 0 insertions(+), 3 deletions(-)
diff --git a/drivers/net/4xx_enet.c b/drivers/net/4xx_enet.c index 8013ad9..a771139 100644 --- a/drivers/net/4xx_enet.c +++ b/drivers/net/4xx_enet.c @@ -1769,7 +1769,6 @@ static void emac_err (struct eth_device *dev, unsigned long isr) *-----------------------------------------------------------------------------*/ static void enet_rcv (struct eth_device *dev, unsigned long malisr) { - struct enet_frame *ef_ptr; unsigned long data_len; unsigned long rx_eob_isr; EMAC_4XX_HW_PST hw_p = dev->priv; @@ -1828,8 +1827,6 @@ static void enet_rcv (struct eth_device *dev, unsigned long malisr) } else { hw_p->stats.rx_frames++; hw_p->stats.rx += data_len; - ef_ptr = (struct enet_frame *) hw_p->rx[i]. - data_ptr; #ifdef INFO_4XX_ENET hw_p->stats.pkts_rx++; #endif
Dear Wolfgang Denk,
Applied, thanks.
