[U-Boot] [PATCH 0/4] kbuild & kconfig: sync with Linux 4.1
These change sets have been imported from Linux.
This series should not change any boards.
Masahiro Yamada (4): kconfig: sync with Linux 4.1 kbuild: sync with Linux 4.1 kbuild: do not add $((generic-)offsets-file) to targets kbuild: use relative path more to include Makefile
Kbuild | 3 +- Makefile | 33 ++++-------- scripts/Kbuild.include | 25 +++++++-- scripts/Makefile.build | 5 +- scripts/Makefile.clean | 29 ++++------ scripts/Makefile.lib | 25 +++++---- scripts/kconfig/Makefile | 80 ++++++++++++++-------------- scripts/kconfig/conf.c | 8 ++- scripts/kconfig/confdata.c | 6 +++ scripts/kconfig/expr.c | 22 ++++---- scripts/kconfig/expr.h | 5 -- scripts/kconfig/gconf.c | 29 ++-------- scripts/kconfig/list.h | 6 +-- scripts/kconfig/lkc.h | 14 ----- scripts/kconfig/lkc_proto.h | 85 ++++++++++++++---------------- scripts/kconfig/lxdialog/check-lxdialog.sh | 6 ++- scripts/kconfig/mconf.c | 35 +++++++----- scripts/kconfig/menu.c | 4 +- scripts/kconfig/merge_config.sh | 30 +++++++---- scripts/kconfig/nconf.c | 5 ++ scripts/kconfig/qconf.cc | 5 +- scripts/kconfig/symbol.c | 42 +++++++-------- scripts/kconfig/util.c | 10 ---- 23 files changed, 244 insertions(+), 268 deletions(-)
Update the files under scripts/kconfig/ to match Linux 4.1. Some Kconfig sources have diverged from those in the kernel, so commit-base syncing was done not to lose U-Boot specific updates.
The commits cherry-picked from Linux are:
[1] commit be8af2d54a66911693eddc556e4f7a866670082b Author: Bjørn Forsman bjorn.forsman@gmail.com kconfig/lxdialog: get ncurses CFLAGS with pkg-config
[2] commit 3943f42c11896ce82ad3da132c8a5630313bdd0e Author: Andrey Utkin andrey.krieger.utkin@gmail.com Replace mentions of "list_struct" to "list_head"
[3] commit e4e458b45c5861808674eebfea94cee2258bb2ea Author: Arjun Sreedharan arjun024@gmail.com calloc/xcalloc: Fix argument order
[4] commit 09950bc256e3628d275f90e016e6f5a039fbdcab Author: Olof Johansson olof@lixom.net merge_config.sh: Display usage if given too few arguments
[5] commit b6a2ab2cd4739a9573ed41677e53171987b8da34 Author: Colin Ian King colin.king@canonical.com kconfig: use va_end to match corresponding va_start
[6] commit 70529b1a1784503169416df19ce3d68746401340 Author: Michal Marek mmarek@suse.cz kconfig: Get rid of the P() macro in headers
[7] commit 463157444e377bf9b279101b1f16a94c4648c03a Author: Michal Marek mmarek@suse.cz kconfig: Remove dead code
[8] commit ad8d40cda3ad22ad9e8863d55a5c88f85c0173f0 Author: Michal Marek mmarek@suse.cz kconfig: Remove unnecessary prototypes from headers
[9] commit de4619937229378e81f95e99c9866acc8e207d34 Author: Masahiro Yamada yamada.masahiro@socionext.com kbuild: mergeconfig: fix "jobserver unavailable" warning
[10] commit b9fe99c5b994c6ddc57780993966b18899526c0b Author: Masahiro Yamada yamada.masahiro@socionext.com kbuild: mergeconfig: move an error check to merge_config.sh
[11] commit 371cfd4ff0611d8bc5d18bbb9cc6a2bc3d56cd3d Author: Masahiro Yamada yamada.masahiro@socionext.com kbuild: mergeconfig: remove redundant $(objtree)
[12] commit 3a975b8cfcbe026b535f83bde9a3c009bae214f9 Author: Masahiro Yamada yamada.masahiro@socionext.com merge_config.sh: improve indentation
[13] commit bc8f8f5fc47cd02c2c5f3580dac2fe6695af1edd Author: Masahiro Yamada yamada.masahiro@socionext.com merge_config.sh: rename MAKE to RUNMAKE
[14] commit 63a91033d52e64a22e571fe84924c0b7f21c280d Author: Masahiro Yamada yamada.masahiro@socionext.com kbuild: add generic mergeconfig target, %.config
[15] commit 1cba0c305758c3c1786ecaceb03e142c95a4edc9 Author: Michal Marek mmarek@suse.cz kconfig: Simplify Makefile
[16] commit 0a1f00a1c86421cc07cec87011c7cf4df68ee54b Author: Michal Marek mmarek@suse.cz kconfig: Do not print status messages in make -s mode
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Signed-off-by: Bjørn Forsman bjorn.forsman@gmail.com Signed-off-by: Andrey Utkin andrey.krieger.utkin@gmail.com Signed-off-by: Jiri Kosina jkosina@suse.cz Signed-off-by: Arjun Sreedharan arjun024@gmail.com Signed-off-by: Arnaldo Carvalho de Melo acme@redhat.com Signed-off-by: Olof Johansson olof@lixom.net Signed-off-by: Colin Ian King colin.king@canonical.com Signed-off-by: Michal Marek mmarek@suse.cz ---
scripts/kconfig/Makefile | 80 ++++++++++++++-------------- scripts/kconfig/conf.c | 8 ++- scripts/kconfig/confdata.c | 6 +++ scripts/kconfig/expr.c | 22 ++++---- scripts/kconfig/expr.h | 5 -- scripts/kconfig/gconf.c | 29 ++-------- scripts/kconfig/list.h | 6 +-- scripts/kconfig/lkc.h | 14 ----- scripts/kconfig/lkc_proto.h | 85 ++++++++++++++---------------- scripts/kconfig/lxdialog/check-lxdialog.sh | 6 ++- scripts/kconfig/mconf.c | 35 +++++++----- scripts/kconfig/menu.c | 4 +- scripts/kconfig/merge_config.sh | 30 +++++++---- scripts/kconfig/nconf.c | 5 ++ scripts/kconfig/qconf.cc | 5 +- scripts/kconfig/symbol.c | 42 +++++++-------- scripts/kconfig/util.c | 10 ---- 17 files changed, 189 insertions(+), 203 deletions(-)
diff --git a/scripts/kconfig/Makefile b/scripts/kconfig/Makefile index ff4ce6e..46ddf2d 100644 --- a/scripts/kconfig/Makefile +++ b/scripts/kconfig/Makefile @@ -2,7 +2,7 @@ # Kernel configuration targets # These targets are used from top-level makefile
-PHONY += oldconfig xconfig gconfig menuconfig config silentoldconfig update-po-config \ +PHONY += xconfig gconfig menuconfig config silentoldconfig update-po-config \ localmodconfig localyesconfig
# Added for U-Boot @@ -17,30 +17,31 @@ else Kconfig := Kconfig endif
+ifeq ($(quiet),silent_) +silent := -s +endif + # We need this, in case the user has it in its environment unexport CONFIG_
xconfig: $(obj)/qconf - $< $(Kconfig) + $< $(silent) $(Kconfig)
gconfig: $(obj)/gconf - $< $(Kconfig) + $< $(silent) $(Kconfig)
menuconfig: $(obj)/mconf - $< $(Kconfig) + $< $(silent) $(Kconfig)
config: $(obj)/conf - $< --oldaskconfig $(Kconfig) + $< $(silent) --oldaskconfig $(Kconfig)
nconfig: $(obj)/nconf - $< $(Kconfig) - -oldconfig: $(obj)/conf - $< --$@ $(Kconfig) + $< $(silent) $(Kconfig)
silentoldconfig: $(obj)/conf $(Q)mkdir -p include/config include/generated - $< --$@ $(Kconfig) + $< $(silent) --$@ $(Kconfig)
localyesconfig localmodconfig: $(obj)/streamline_config.pl $(obj)/conf $(Q)mkdir -p include/config include/generated @@ -49,18 +50,18 @@ localyesconfig localmodconfig: $(obj)/streamline_config.pl $(obj)/conf cmp -s .tmp.config .config || \ (mv -f .config .config.old.1; \ mv -f .tmp.config .config; \ - $(obj)/conf --silentoldconfig $(Kconfig); \ + $(obj)/conf $(silent) --silentoldconfig $(Kconfig); \ mv -f .config.old.1 .config.old) \ else \ mv -f .tmp.config .config; \ - $(obj)/conf --silentoldconfig $(Kconfig); \ + $(obj)/conf $(silent) --silentoldconfig $(Kconfig); \ fi $(Q)rm -f .tmp.config
# Create new linux.pot file # Adjust charset to UTF-8 in .po file to accept UTF-8 in Kconfig files update-po-config: $(obj)/kxgettext $(obj)/gconf.glade.h - $(Q)echo " GEN config.pot" + $(Q)$(kecho) " GEN config.pot" $(Q)xgettext --default-domain=linux \ --add-comments --keyword=_ --keyword=N_ \ --from-code=UTF-8 \ @@ -71,65 +72,62 @@ update-po-config: $(obj)/kxgettext $(obj)/gconf.glade.h $(Q)(for i in `ls $(srctree)/arch/*/Kconfig \ $(srctree)/arch/*/um/Kconfig`; \ do \ - echo " GEN $$i"; \ + $(kecho) " GEN $$i"; \ $(obj)/kxgettext $$i \ >> $(obj)/config.pot; \ done ) - $(Q)echo " GEN linux.pot" + $(Q)$(kecho) " GEN linux.pot" $(Q)msguniq --sort-by-file --to-code=UTF-8 $(obj)/config.pot \ --output $(obj)/linux.pot $(Q)rm -f $(obj)/config.pot
-PHONY += allnoconfig allyesconfig allmodconfig alldefconfig randconfig +# These targets map 1:1 to the commandline options of 'conf' +simple-targets := oldconfig allnoconfig allyesconfig allmodconfig \ + alldefconfig randconfig listnewconfig olddefconfig +PHONY += $(simple-targets)
-allnoconfig allyesconfig allmodconfig alldefconfig randconfig: $(obj)/conf - $< --$@ $(Kconfig) +$(simple-targets): $(obj)/conf + $< $(silent) --$@ $(Kconfig)
-PHONY += listnewconfig olddefconfig oldnoconfig savedefconfig defconfig - -listnewconfig olddefconfig: $(obj)/conf - $< --$@ $(Kconfig) +PHONY += oldnoconfig savedefconfig defconfig
# oldnoconfig is an alias of olddefconfig, because people already are dependent # on its behavior(sets new symbols to their default value but not 'n') with the # counter-intuitive name. -oldnoconfig: $(obj)/conf - $< --olddefconfig $(Kconfig) +oldnoconfig: olddefconfig
savedefconfig: $(obj)/conf - $< --$@=defconfig $(Kconfig) + $< $(silent) --$@=defconfig $(Kconfig)
defconfig: $(obj)/conf ifeq ($(KBUILD_DEFCONFIG),) - $< --defconfig $(Kconfig) + $< $(silent) --defconfig $(Kconfig) else - @echo "*** Default configuration is based on '$(KBUILD_DEFCONFIG)'" - $(Q)$< --defconfig=arch/$(SRCARCH)/configs/$(KBUILD_DEFCONFIG) $(Kconfig) + @$(kecho) "*** Default configuration is based on '$(KBUILD_DEFCONFIG)'" + $(Q)$< $(silent) --defconfig=arch/$(SRCARCH)/configs/$(KBUILD_DEFCONFIG) $(Kconfig) endif
%_defconfig: $(obj)/conf - $(Q)$< --defconfig=arch/$(SRCARCH)/configs/$@ $(Kconfig) + $(Q)$< $(silent) --defconfig=arch/$(SRCARCH)/configs/$@ $(Kconfig)
# Added for U-Boot (backward compatibility) %_config: %_defconfig @:
-configfiles=$(wildcard $(srctree)/kernel/configs/$(1).config $(srctree)/arch/$(SRCARCH)/configs/$(1).config) +configfiles=$(wildcard $(srctree)/kernel/configs/$@ $(srctree)/arch/$(SRCARCH)/configs/$@)
-define mergeconfig -$(if $(wildcard $(objtree)/.config),, $(error You need an existing .config for this target)) -$(if $(call configfiles,$(1)),, $(error No configuration exists for this target on this architecture)) -$(Q)$(CONFIG_SHELL) $(srctree)/scripts/kconfig/merge_config.sh -m -O $(objtree) $(objtree)/.config $(call configfiles,$(1)) -$(Q)yes "" | $(MAKE) -f $(srctree)/Makefile oldconfig -endef +%.config: $(obj)/conf + $(if $(call configfiles),, $(error No configuration exists for this target on this architecture)) + $(Q)$(CONFIG_SHELL) $(srctree)/scripts/kconfig/merge_config.sh -m .config $(configfiles) + +$(Q)yes "" | $(MAKE) -f $(srctree)/Makefile oldconfig
PHONY += kvmconfig -kvmconfig: - $(call mergeconfig,kvm_guest) +kvmconfig: kvm_guest.config + @:
PHONY += tinyconfig -tinyconfig: allnoconfig - $(call mergeconfig,tiny) +tinyconfig: + $(Q)$(MAKE) -f $(srctree)/Makefile allnoconfig tiny.config
# Help text used by make help help: @@ -231,7 +229,7 @@ $(obj)/.tmp_qtcheck: $(src)/Makefile
# QT needs some extra effort... $(obj)/.tmp_qtcheck: - @set -e; echo " CHECK qt"; dir=""; pkg=""; \ + @set -e; $(kecho) " CHECK qt"; dir=""; pkg=""; \ if ! pkg-config --exists QtCore 2> /dev/null; then \ echo "* Unable to find the QT4 tool qmake. Trying to use QT3"; \ pkg-config --exists qt 2> /dev/null && pkg=qt; \ diff --git a/scripts/kconfig/conf.c b/scripts/kconfig/conf.c index fef75fc..6c20431 100644 --- a/scripts/kconfig/conf.c +++ b/scripts/kconfig/conf.c @@ -471,7 +471,7 @@ static struct option long_opts[] = { static void conf_usage(const char *progname) {
- printf("Usage: %s [option] <kconfig-file>\n", progname); + printf("Usage: %s [-s] [option] <kconfig-file>\n", progname); printf("[option] is _one_ of the following:\n"); printf(" --listnewconfig List new options\n"); printf(" --oldaskconfig Start a new configuration using a line-oriented program\n"); @@ -501,7 +501,11 @@ int main(int ac, char **av)
tty_stdio = isatty(0) && isatty(1) && isatty(2);
- while ((opt = getopt_long(ac, av, "", long_opts, NULL)) != -1) { + while ((opt = getopt_long(ac, av, "s", long_opts, NULL)) != -1) { + if (opt == 's') { + conf_set_message_callback(NULL); + continue; + } input_mode = (enum input_mode)opt; switch (opt) { case silentoldconfig: diff --git a/scripts/kconfig/confdata.c b/scripts/kconfig/confdata.c index 2f778df..9847ae6 100644 --- a/scripts/kconfig/confdata.c +++ b/scripts/kconfig/confdata.c @@ -16,6 +16,11 @@
#include "lkc.h"
+struct conf_printer { + void (*print_symbol)(FILE *, struct symbol *, const char *, void *); + void (*print_comment)(FILE *, const char *, void *); +}; + static void conf_warning(const char *fmt, ...) __attribute__ ((format (printf, 1, 2)));
@@ -59,6 +64,7 @@ static void conf_message(const char *fmt, ...) va_start(ap, fmt); if (conf_message_callback) conf_message_callback(fmt, ap); + va_end(ap); }
const char *conf_get_configname(void) diff --git a/scripts/kconfig/expr.c b/scripts/kconfig/expr.c index d662652..fb0a2a2 100644 --- a/scripts/kconfig/expr.c +++ b/scripts/kconfig/expr.c @@ -11,6 +11,12 @@
#define DEBUG_EXPR 0
+static int expr_eq(struct expr *e1, struct expr *e2); +static struct expr *expr_eliminate_yn(struct expr *e); +static struct expr *expr_extract_eq_and(struct expr **ep1, struct expr **ep2); +static struct expr *expr_extract_eq_or(struct expr **ep1, struct expr **ep2); +static void expr_extract_eq(enum expr_type type, struct expr **ep, struct expr **ep1, struct expr **ep2); + struct expr *expr_alloc_symbol(struct symbol *sym) { struct expr *e = xcalloc(1, sizeof(*e)); @@ -186,7 +192,7 @@ void expr_eliminate_eq(struct expr **ep1, struct expr **ep2) #undef e1 #undef e2
-int expr_eq(struct expr *e1, struct expr *e2) +static int expr_eq(struct expr *e1, struct expr *e2) { int res, old_count;
@@ -228,7 +234,7 @@ int expr_eq(struct expr *e1, struct expr *e2) return 0; }
-struct expr *expr_eliminate_yn(struct expr *e) +static struct expr *expr_eliminate_yn(struct expr *e) { struct expr *tmp;
@@ -823,7 +829,7 @@ bool expr_depends_symbol(struct expr *dep, struct symbol *sym) return false; }
-struct expr *expr_extract_eq_and(struct expr **ep1, struct expr **ep2) +static struct expr *expr_extract_eq_and(struct expr **ep1, struct expr **ep2) { struct expr *tmp = NULL; expr_extract_eq(E_AND, &tmp, ep1, ep2); @@ -834,7 +840,7 @@ struct expr *expr_extract_eq_and(struct expr **ep1, struct expr **ep2) return tmp; }
-struct expr *expr_extract_eq_or(struct expr **ep1, struct expr **ep2) +static struct expr *expr_extract_eq_or(struct expr **ep1, struct expr **ep2) { struct expr *tmp = NULL; expr_extract_eq(E_OR, &tmp, ep1, ep2); @@ -845,7 +851,7 @@ struct expr *expr_extract_eq_or(struct expr **ep1, struct expr **ep2) return tmp; }
-void expr_extract_eq(enum expr_type type, struct expr **ep, struct expr **ep1, struct expr **ep2) +static void expr_extract_eq(enum expr_type type, struct expr **ep, struct expr **ep1, struct expr **ep2) { #define e1 (*ep1) #define e2 (*ep2) @@ -976,11 +982,8 @@ tristate expr_calc_value(struct expr *e) } }
-int expr_compare_type(enum expr_type t1, enum expr_type t2) +static int expr_compare_type(enum expr_type t1, enum expr_type t2) { -#if 0 - return 1; -#else if (t1 == t2) return 0; switch (t1) { @@ -1005,7 +1008,6 @@ int expr_compare_type(enum expr_type t1, enum expr_type t2) } printf("[%dgt%d?]", t1, t2); return 0; -#endif }
static inline struct expr * diff --git a/scripts/kconfig/expr.h b/scripts/kconfig/expr.h index 412ea8a..a2fc96a 100644 --- a/scripts/kconfig/expr.h +++ b/scripts/kconfig/expr.h @@ -205,18 +205,13 @@ struct expr *expr_alloc_and(struct expr *e1, struct expr *e2); struct expr *expr_alloc_or(struct expr *e1, struct expr *e2); struct expr *expr_copy(const struct expr *org); void expr_free(struct expr *e); -int expr_eq(struct expr *e1, struct expr *e2); void expr_eliminate_eq(struct expr **ep1, struct expr **ep2); tristate expr_calc_value(struct expr *e); -struct expr *expr_eliminate_yn(struct expr *e); struct expr *expr_trans_bool(struct expr *e); struct expr *expr_eliminate_dups(struct expr *e); struct expr *expr_transform(struct expr *e); int expr_contains_symbol(struct expr *dep, struct symbol *sym); bool expr_depends_symbol(struct expr *dep, struct symbol *sym); -struct expr *expr_extract_eq_and(struct expr **ep1, struct expr **ep2); -struct expr *expr_extract_eq_or(struct expr **ep1, struct expr **ep2); -void expr_extract_eq(enum expr_type type, struct expr **ep, struct expr **ep1, struct expr **ep2); struct expr *expr_trans_compare(struct expr *e, enum expr_type type, struct symbol *sym); struct expr *expr_simplify_unmet_dep(struct expr *e1, struct expr *e2);
diff --git a/scripts/kconfig/gconf.c b/scripts/kconfig/gconf.c index d0a35b2..26d208b 100644 --- a/scripts/kconfig/gconf.c +++ b/scripts/kconfig/gconf.c @@ -169,14 +169,6 @@ void init_main_window(const gchar * glade_file) style = gtk_widget_get_style(main_wnd); widget = glade_xml_get_widget(xml, "toolbar1");
-#if 0 /* Use stock Gtk icons instead */ - replace_button_icon(xml, main_wnd->window, style, - "button1", (gchar **) xpm_back); - replace_button_icon(xml, main_wnd->window, style, - "button2", (gchar **) xpm_load); - replace_button_icon(xml, main_wnd->window, style, - "button3", (gchar **) xpm_save); -#endif replace_button_icon(xml, main_wnd->window, style, "button4", (gchar **) xpm_single_view); replace_button_icon(xml, main_wnd->window, style, @@ -184,22 +176,6 @@ void init_main_window(const gchar * glade_file) replace_button_icon(xml, main_wnd->window, style, "button6", (gchar **) xpm_tree_view);
-#if 0 - switch (view_mode) { - case SINGLE_VIEW: - widget = glade_xml_get_widget(xml, "button4"); - g_signal_emit_by_name(widget, "clicked"); - break; - case SPLIT_VIEW: - widget = glade_xml_get_widget(xml, "button5"); - g_signal_emit_by_name(widget, "clicked"); - break; - case FULL_VIEW: - widget = glade_xml_get_widget(xml, "button6"); - g_signal_emit_by_name(widget, "clicked"); - break; - } -#endif txtbuf = gtk_text_view_get_buffer(GTK_TEXT_VIEW(text_w)); tag1 = gtk_text_buffer_create_tag(txtbuf, "mytag1", "foreground", "red", @@ -1498,9 +1474,12 @@ int main(int ac, char *av[]) case 'a': //showAll = 1; break; + case 's': + conf_set_message_callback(NULL); + break; case 'h': case '?': - printf("%s <config>\n", av[0]); + printf("%s [-s] <config>\n", av[0]); exit(0); } name = av[2]; diff --git a/scripts/kconfig/list.h b/scripts/kconfig/list.h index 685d80e..2cf23f0 100644 --- a/scripts/kconfig/list.h +++ b/scripts/kconfig/list.h @@ -34,7 +34,7 @@ struct list_head { * list_entry - get the struct for this entry * @ptr: the &struct list_head pointer. * @type: the type of the struct this is embedded in. - * @member: the name of the list_struct within the struct. + * @member: the name of the list_head within the struct. */ #define list_entry(ptr, type, member) \ container_of(ptr, type, member) @@ -43,7 +43,7 @@ struct list_head { * list_for_each_entry - iterate over list of given type * @pos: the type * to use as a loop cursor. * @head: the head for your list. - * @member: the name of the list_struct within the struct. + * @member: the name of the list_head within the struct. */ #define list_for_each_entry(pos, head, member) \ for (pos = list_entry((head)->next, typeof(*pos), member); \ @@ -55,7 +55,7 @@ struct list_head { * @pos: the type * to use as a loop cursor. * @n: another type * to use as temporary storage * @head: the head for your list. - * @member: the name of the list_struct within the struct. + * @member: the name of the list_head within the struct. */ #define list_for_each_entry_safe(pos, n, head, member) \ for (pos = list_entry((head)->next, typeof(*pos), member), \ diff --git a/scripts/kconfig/lkc.h b/scripts/kconfig/lkc.h index d5daa7a..91ca126 100644 --- a/scripts/kconfig/lkc.h +++ b/scripts/kconfig/lkc.h @@ -21,9 +21,7 @@ static inline char *bind_textdomain_codeset(const char *dn, char *c) { return c; extern "C" { #endif
-#define P(name,type,arg) extern type name arg #include "lkc_proto.h" -#undef P
#define SRCTREE "srctree"
@@ -70,9 +68,6 @@ struct kconf_id { enum symbol_type stype; };
-extern int zconfdebug; - -int zconfparse(void); void zconfdump(FILE *out); void zconf_starthelp(void); FILE *zconf_fopen(const char *name); @@ -90,11 +85,6 @@ void sym_add_change_count(int count); bool conf_set_all_new_symbols(enum conf_def_mode mode); void set_all_choice_values(struct symbol *csym);
-struct conf_printer { - void (*print_symbol)(FILE *, struct symbol *, const char *, void *); - void (*print_comment)(FILE *, const char *, void *); -}; - /* confdata.c and expr.c */ static inline void xfwrite(const void *str, size_t len, size_t count, FILE *out) { @@ -113,7 +103,6 @@ void menu_add_entry(struct symbol *sym); void menu_end_entry(void); void menu_add_dep(struct expr *dep); void menu_add_visibility(struct expr *dep); -struct property *menu_add_prop(enum prop_type type, char *prompt, struct expr *expr, struct expr *dep); struct property *menu_add_prompt(enum prop_type type, char *prompt, struct expr *dep); void menu_add_expr(enum prop_type type, struct expr *expr, struct expr *dep); void menu_add_symbol(enum prop_type type, struct symbol *sym, struct expr *dep); @@ -137,7 +126,6 @@ struct gstr { int max_width; }; struct gstr str_new(void); -struct gstr str_assign(const char *s); void str_free(struct gstr *gs); void str_append(struct gstr *gs, const char *s); void str_printf(struct gstr *gs, const char *fmt, ...); @@ -148,8 +136,6 @@ extern struct expr *sym_env_list;
void sym_init(void); void sym_clear_all_valid(void); -void sym_set_all_changed(void); -void sym_set_changed(struct symbol *sym); struct symbol *sym_choice_default(struct symbol *sym); const char *sym_get_string_default(struct symbol *sym); struct symbol *sym_check_deps(struct symbol *sym); diff --git a/scripts/kconfig/lkc_proto.h b/scripts/kconfig/lkc_proto.h index ecdb965..d539871 100644 --- a/scripts/kconfig/lkc_proto.h +++ b/scripts/kconfig/lkc_proto.h @@ -1,57 +1,52 @@ #include <stdarg.h>
/* confdata.c */ -P(conf_parse,void,(const char *name)); -P(conf_read,int,(const char *name)); -P(conf_read_simple,int,(const char *name, int)); -P(conf_write_defconfig,int,(const char *name)); -P(conf_write,int,(const char *name)); -P(conf_write_autoconf,int,(void)); -P(conf_get_changed,bool,(void)); -P(conf_set_changed_callback, void,(void (*fn)(void))); -P(conf_set_message_callback, void,(void (*fn)(const char *fmt, va_list ap))); +void conf_parse(const char *name); +int conf_read(const char *name); +int conf_read_simple(const char *name, int); +int conf_write_defconfig(const char *name); +int conf_write(const char *name); +int conf_write_autoconf(void); +bool conf_get_changed(void); +void conf_set_changed_callback(void (*fn)(void)); +void conf_set_message_callback(void (*fn)(const char *fmt, va_list ap));
/* menu.c */ -P(rootmenu,struct menu,); +extern struct menu rootmenu;
-P(menu_is_empty, bool, (struct menu *menu)); -P(menu_is_visible, bool, (struct menu *menu)); -P(menu_has_prompt, bool, (struct menu *menu)); -P(menu_get_prompt,const char *,(struct menu *menu)); -P(menu_get_root_menu,struct menu *,(struct menu *menu)); -P(menu_get_parent_menu,struct menu *,(struct menu *menu)); -P(menu_has_help,bool,(struct menu *menu)); -P(menu_get_help,const char *,(struct menu *menu)); -P(get_symbol_str, void, (struct gstr *r, struct symbol *sym, struct list_head - *head)); -P(get_relations_str, struct gstr, (struct symbol **sym_arr, struct list_head - *head)); -P(menu_get_ext_help,void,(struct menu *menu, struct gstr *help)); +bool menu_is_empty(struct menu *menu); +bool menu_is_visible(struct menu *menu); +bool menu_has_prompt(struct menu *menu); +const char * menu_get_prompt(struct menu *menu); +struct menu * menu_get_root_menu(struct menu *menu); +struct menu * menu_get_parent_menu(struct menu *menu); +bool menu_has_help(struct menu *menu); +const char * menu_get_help(struct menu *menu); +struct gstr get_relations_str(struct symbol **sym_arr, struct list_head *head); +void menu_get_ext_help(struct menu *menu, struct gstr *help);
/* symbol.c */ -P(symbol_hash,struct symbol *,[SYMBOL_HASHSIZE]); +extern struct symbol * symbol_hash[SYMBOL_HASHSIZE];
-P(sym_lookup,struct symbol *,(const char *name, int flags)); -P(sym_find,struct symbol *,(const char *name)); -P(sym_expand_string_value,const char *,(const char *in)); -P(sym_escape_string_value, const char *,(const char *in)); -P(sym_re_search,struct symbol **,(const char *pattern)); -P(sym_type_name,const char *,(enum symbol_type type)); -P(sym_calc_value,void,(struct symbol *sym)); -P(sym_get_type,enum symbol_type,(struct symbol *sym)); -P(sym_tristate_within_range,bool,(struct symbol *sym,tristate tri)); -P(sym_set_tristate_value,bool,(struct symbol *sym,tristate tri)); -P(sym_toggle_tristate_value,tristate,(struct symbol *sym)); -P(sym_string_valid,bool,(struct symbol *sym, const char *newval)); -P(sym_string_within_range,bool,(struct symbol *sym, const char *str)); -P(sym_set_string_value,bool,(struct symbol *sym, const char *newval)); -P(sym_is_changable,bool,(struct symbol *sym)); -P(sym_get_choice_prop,struct property *,(struct symbol *sym)); -P(sym_get_default_prop,struct property *,(struct symbol *sym)); -P(sym_get_string_value,const char *,(struct symbol *sym)); +struct symbol * sym_lookup(const char *name, int flags); +struct symbol * sym_find(const char *name); +const char * sym_expand_string_value(const char *in); +const char * sym_escape_string_value(const char *in); +struct symbol ** sym_re_search(const char *pattern); +const char * sym_type_name(enum symbol_type type); +void sym_calc_value(struct symbol *sym); +enum symbol_type sym_get_type(struct symbol *sym); +bool sym_tristate_within_range(struct symbol *sym,tristate tri); +bool sym_set_tristate_value(struct symbol *sym,tristate tri); +tristate sym_toggle_tristate_value(struct symbol *sym); +bool sym_string_valid(struct symbol *sym, const char *newval); +bool sym_string_within_range(struct symbol *sym, const char *str); +bool sym_set_string_value(struct symbol *sym, const char *newval); +bool sym_is_changable(struct symbol *sym); +struct property * sym_get_choice_prop(struct symbol *sym); +const char * sym_get_string_value(struct symbol *sym);
-P(prop_get_type_name,const char *,(enum prop_type type)); +const char * prop_get_type_name(enum prop_type type);
/* expr.c */ -P(expr_compare_type,int,(enum expr_type t1, enum expr_type t2)); -P(expr_print,void,(struct expr *e, void (*fn)(void *, struct symbol *, const char *), void *data, int prevtoken)); +void expr_print(struct expr *e, void (*fn)(void *, struct symbol *, const char *), void *data, int prevtoken); diff --git a/scripts/kconfig/lxdialog/check-lxdialog.sh b/scripts/kconfig/lxdialog/check-lxdialog.sh index 9d2a4c5..5075ebf 100755 --- a/scripts/kconfig/lxdialog/check-lxdialog.sh +++ b/scripts/kconfig/lxdialog/check-lxdialog.sh @@ -21,7 +21,11 @@ ldflags() # Where is ncurses.h? ccflags() { - if [ -f /usr/include/ncursesw/curses.h ]; then + if pkg-config --cflags ncursesw 2>/dev/null; then + echo '-DCURSES_LOC="<ncurses.h>" -DNCURSES_WIDECHAR=1' + elif pkg-config --cflags ncurses 2>/dev/null; then + echo '-DCURSES_LOC="<ncurses.h>"' + elif [ -f /usr/include/ncursesw/curses.h ]; then echo '-I/usr/include/ncursesw -DCURSES_LOC="<curses.h>"' echo ' -DNCURSES_WIDECHAR=1' elif [ -f /usr/include/ncurses/ncurses.h ]; then diff --git a/scripts/kconfig/mconf.c b/scripts/kconfig/mconf.c index 14cea74..315ce2c 100644 --- a/scripts/kconfig/mconf.c +++ b/scripts/kconfig/mconf.c @@ -279,6 +279,7 @@ static int child_count; static int single_menu_mode; static int show_all_options; static int save_and_exit; +static int silent;
static void conf(struct menu *menu, struct menu *active_menu); static void conf_choice(struct menu *menu); @@ -330,10 +331,10 @@ static void set_subtitle(void) list_for_each_entry(sp, &trail, entries) { if (sp->text) { if (pos) { - pos->next = xcalloc(sizeof(*pos), 1); + pos->next = xcalloc(1, sizeof(*pos)); pos = pos->next; } else { - subtitles = pos = xcalloc(sizeof(*pos), 1); + subtitles = pos = xcalloc(1, sizeof(*pos)); } pos->text = sp->text; } @@ -777,10 +778,12 @@ static void conf_message_callback(const char *fmt, va_list ap) char buf[PATH_MAX+1];
vsnprintf(buf, sizeof(buf), fmt, ap); - if (save_and_exit) - printf("%s", buf); - else + if (save_and_exit) { + if (!silent) + printf("%s", buf); + } else { show_textbox(NULL, buf, 6, 60); + } }
static void show_help(struct menu *menu) @@ -977,16 +980,18 @@ static int handle_exit(void) } /* fall through */ case -1: - printf(_("\n\n" - "*** End of the configuration.\n" - "*** Execute 'make' to start the build or try 'make help'." - "\n\n")); + if (!silent) + printf(_("\n\n" + "*** End of the configuration.\n" + "*** Execute 'make' to start the build or try 'make help'." + "\n\n")); res = 0; break; default: - fprintf(stderr, _("\n\n" - "Your configuration changes were NOT saved." - "\n\n")); + if (!silent) + fprintf(stderr, _("\n\n" + "Your configuration changes were NOT saved." + "\n\n")); if (res != KEY_ESC) res = 0; } @@ -1010,6 +1015,12 @@ int main(int ac, char **av)
signal(SIGINT, sig_handler);
+ if (ac > 1 && strcmp(av[1], "-s") == 0) { + silent = 1; + /* Silence conf_read() until the real callback is set up */ + conf_set_message_callback(NULL); + av++; + } conf_parse(av[1]); conf_read(NULL);
diff --git a/scripts/kconfig/menu.c b/scripts/kconfig/menu.c index 72c9dba..b05cc3d 100644 --- a/scripts/kconfig/menu.c +++ b/scripts/kconfig/menu.c @@ -125,7 +125,7 @@ void menu_set_type(int type) sym_type_name(sym->type), sym_type_name(type)); }
-struct property *menu_add_prop(enum prop_type type, char *prompt, struct expr *expr, struct expr *dep) +static struct property *menu_add_prop(enum prop_type type, char *prompt, struct expr *expr, struct expr *dep) { struct property *prop = prop_alloc(type, current_entry->sym);
@@ -615,7 +615,7 @@ static struct property *get_symbol_prop(struct symbol *sym) /* * head is optional and may be NULL */ -void get_symbol_str(struct gstr *r, struct symbol *sym, +static void get_symbol_str(struct gstr *r, struct symbol *sym, struct list_head *head) { bool hit; diff --git a/scripts/kconfig/merge_config.sh b/scripts/kconfig/merge_config.sh index efa4733..ec8e203 100755 --- a/scripts/kconfig/merge_config.sh +++ b/scripts/kconfig/merge_config.sh @@ -35,7 +35,7 @@ usage() { echo " -O dir to put generated output files" }
-MAKE=true +RUNMAKE=true ALLTARGET=alldefconfig WARNREDUN=false OUTPUT=. @@ -48,7 +48,7 @@ while true; do continue ;; "-m") - MAKE=false + RUNMAKE=false shift continue ;; @@ -77,9 +77,19 @@ while true; do esac done
+if [ "$#" -lt 2 ] ; then + usage + exit +fi + INITFILE=$1 shift;
+if [ ! -r "$INITFILE" ]; then + echo "The base file '$INITFILE' does not exist. Exit." >&2 + exit 1 +fi + MERGE_LIST=$* SED_CONFIG_EXP="s/^(# ){0,1}(CONFIG_[a-zA-Z0-9_]*)[= ].*/\2/p" TMP_FILE=$(mktemp ./.tmp.config.XXXXXXXXXX) @@ -93,25 +103,23 @@ for MERGE_FILE in $MERGE_LIST ; do CFG_LIST=$(sed -n "$SED_CONFIG_EXP" $MERGE_FILE)
for CFG in $CFG_LIST ; do - grep -q -w $CFG $TMP_FILE - if [ $? -eq 0 ] ; then - PREV_VAL=$(grep -w $CFG $TMP_FILE) - NEW_VAL=$(grep -w $CFG $MERGE_FILE) - if [ "x$PREV_VAL" != "x$NEW_VAL" ] ; then + grep -q -w $CFG $TMP_FILE || continue + PREV_VAL=$(grep -w $CFG $TMP_FILE) + NEW_VAL=$(grep -w $CFG $MERGE_FILE) + if [ "x$PREV_VAL" != "x$NEW_VAL" ] ; then echo Value of $CFG is redefined by fragment $MERGE_FILE: echo Previous value: $PREV_VAL echo New value: $NEW_VAL echo - elif [ "$WARNREDUN" = "true" ]; then + elif [ "$WARNREDUN" = "true" ]; then echo Value of $CFG is redundant by fragment $MERGE_FILE: - fi - sed -i "/$CFG[ =]/d" $TMP_FILE fi + sed -i "/$CFG[ =]/d" $TMP_FILE done cat $MERGE_FILE >> $TMP_FILE done
-if [ "$MAKE" = "false" ]; then +if [ "$RUNMAKE" = "false" ]; then cp $TMP_FILE $OUTPUT/.config echo "#" echo "# merged configuration written to $OUTPUT/.config (needs make)" diff --git a/scripts/kconfig/nconf.c b/scripts/kconfig/nconf.c index 984489e..d42d534 100644 --- a/scripts/kconfig/nconf.c +++ b/scripts/kconfig/nconf.c @@ -1482,6 +1482,11 @@ int main(int ac, char **av) bindtextdomain(PACKAGE, LOCALEDIR); textdomain(PACKAGE);
+ if (ac > 1 && strcmp(av[1], "-s") == 0) { + /* Silence conf_read() until the real callback is set up */ + conf_set_message_callback(NULL); + av++; + } conf_parse(av[1]); conf_read(NULL);
diff --git a/scripts/kconfig/qconf.cc b/scripts/kconfig/qconf.cc index 9d3b04b..c3bb7fe 100644 --- a/scripts/kconfig/qconf.cc +++ b/scripts/kconfig/qconf.cc @@ -1746,7 +1746,7 @@ static const char *progname;
static void usage(void) { - printf(_("%s <config>\n"), progname); + printf(_("%s [-s] <config>\n"), progname); exit(0); }
@@ -1762,6 +1762,9 @@ int main(int ac, char** av) configApp = new QApplication(ac, av); if (ac > 1 && av[1][0] == '-') { switch (av[1][1]) { + case 's': + conf_set_message_callback(NULL); + break; case 'h': case '?': usage(); diff --git a/scripts/kconfig/symbol.c b/scripts/kconfig/symbol.c index ab339eb..550e1d7 100644 --- a/scripts/kconfig/symbol.c +++ b/scripts/kconfig/symbol.c @@ -112,7 +112,7 @@ struct property *sym_get_env_prop(struct symbol *sym) return NULL; }
-struct property *sym_get_default_prop(struct symbol *sym) +static struct property *sym_get_default_prop(struct symbol *sym) { struct property *prop;
@@ -186,6 +186,26 @@ static void sym_validate_range(struct symbol *sym) sym->curr.val = strdup(str); }
+static void sym_set_changed(struct symbol *sym) +{ + struct property *prop; + + sym->flags |= SYMBOL_CHANGED; + for (prop = sym->prop; prop; prop = prop->next) { + if (prop->menu) + prop->menu->flags |= MENU_CHANGED; + } +} + +static void sym_set_all_changed(void) +{ + struct symbol *sym; + int i; + + for_all_symbols(i, sym) + sym_set_changed(sym); +} + static void sym_calc_visibility(struct symbol *sym) { struct property *prop; @@ -451,26 +471,6 @@ void sym_clear_all_valid(void) sym_calc_value(modules_sym); }
-void sym_set_changed(struct symbol *sym) -{ - struct property *prop; - - sym->flags |= SYMBOL_CHANGED; - for (prop = sym->prop; prop; prop = prop->next) { - if (prop->menu) - prop->menu->flags |= MENU_CHANGED; - } -} - -void sym_set_all_changed(void) -{ - struct symbol *sym; - int i; - - for_all_symbols(i, sym) - sym_set_changed(sym); -} - bool sym_tristate_within_range(struct symbol *sym, tristate val) { int type = sym_get_type(sym); diff --git a/scripts/kconfig/util.c b/scripts/kconfig/util.c index 94f9c83..0e76042 100644 --- a/scripts/kconfig/util.c +++ b/scripts/kconfig/util.c @@ -88,16 +88,6 @@ struct gstr str_new(void) return gs; }
-/* Allocate and assign growable string */ -struct gstr str_assign(const char *s) -{ - struct gstr gs; - gs.s = strdup(s); - gs.len = strlen(s) + 1; - gs.max_width = 0; - return gs; -} - /* Free storage for growable string */ void str_free(struct gstr *gs) {
Update some build scripts to match Linux 4.1. Commit-based syncing was done so as not to break U-Boot specific changes. The previous big sync was from Linux 3.18-rc1 by commit 176d09827725 (kbuild: sync misc scripts with Linux 3.18-rc1).
The commits imported from Linux (some with adjustments) are:
[1] commit 9fb5e5372208973984a23ee6f5f025c05d364633 Author: Robert Richter rrichter@cavium.com dts, kbuild: Factor out dtbs install rules to Makefile.dtbinst
[2] commit 371fdc77af44f4cb32475fd499e1d912ccc30890 Author: Masahiro Yamada yamada.m@jp.panasonic.com kbuild: collect shorthands into scripts/Kbuild.include
[3] commit a29b82326ed4eb5567b03c85b52c6891578d5a03 Author: Michal Marek mmarek@suse.cz kbuild: Remove duplicate $(cmd) definition in Makefile.clean
[4] commit 1846dfbde3e8a53f3673dcb1c1b79fd9b3f8d40d Author: Masahiro Yamada yamada.m@jp.panasonic.com kbuild: remove redundant -rR flag of hdr-inst
[5] commit 34948e0bbf98640fc1821751b01d2f0cd17d84d5 Author: Michal Marek mmarek@suse.cz kbuild: Drop support for clean-rule
[6] commit a16c5f99a28c9945165c46da27fff8e6f26f8736 Author: Michal Marek mmarek@suse.cz kbuild: Fix removal of the debian/ directory
[7] commit d0d38cd9e853db11e0242b3df4c9c3c4a663fbb4 Author: Masahiro Yamada yamada.m@jp.panasonic.com kbuild: use mixed-targets when two or more config targets are given
[8] commit dd33c03b18b3f2db791eb6a17c37d2de66e4de18 Author: Masahiro Yamada yamada.m@jp.panasonic.com kbuild: fix cc-ifversion macro
[9] commit 665d92e38f65d70796aad2b8e49e42e80815d4a4 Author: Masahiro Yamada yamada.m@jp.panasonic.com kbuild: do not add $(call ...) to invoke cc-version or cc-fullversion
[10] commit 6dcb4e5edf39e3b65a75ca76f087b2fdbee8a808 Author: Masahiro Yamada yamada.m@jp.panasonic.com kbuild: allow cc-ifversion to have the argument for false condition
[11] commit c0a80c0c27e5e65b180a25e6c4c2f7ef9e386cd3 Author: Heiko Carstens heiko.carstens@de.ibm.com ftrace: allow architectures to specify ftrace compile options
[12] commit 0b24becc810dc3be6e3f94103a866f214c282394 Author: Andrey Ryabinin a.ryabinin@samsung.com kasan: add kernel address sanitizer infrastructure
[13] commit 4218affdf57f938c04e3a916a9685ee27079f377 Author: Masahiro Yamada yamada.m@jp.panasonic.com kbuild: remove warning about "make depend"
[14] commit 77479b38e2f58890eb221a0418357502a5b41cd6 Author: Nathan Rossi nathan.rossi@xilinx.com kbuild: Create directory for target DTB
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Signed-off-by: Robert Richter rrichter@cavium.com Signed-off-by: Heiko Carstens heiko.carstens@de.ibm.com Signed-off-by: Martin Schwidefsky schwidefsky@de.ibm.com Signed-off-by: Andrey Ryabinin a.ryabinin@samsung.com Signed-off-by: Nathan Rossi nathan.rossi@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com Signed-off-by: Olof Johansson olof@lixom.net Signed-off-by: Michal Marek mmarek@suse.cz Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Makefile | 13 +------------ scripts/Kbuild.include | 25 ++++++++++++++++++++----- scripts/Makefile.build | 5 +++-- scripts/Makefile.clean | 29 +++++++++-------------------- scripts/Makefile.lib | 25 ++++++++++++------------- 5 files changed, 45 insertions(+), 52 deletions(-)
diff --git a/Makefile b/Makefile index 37cc4c3..865c25d 100644 --- a/Makefile +++ b/Makefile @@ -437,7 +437,7 @@ endif ifeq ($(KBUILD_EXTMOD),) ifneq ($(filter config %config,$(MAKECMDGOALS)),) config-targets := 1 - ifneq ($(filter-out config %config,$(MAKECMDGOALS)),) + ifneq ($(words $(MAKECMDGOALS)),1) mixed-targets := 1 endif endif @@ -1243,12 +1243,6 @@ $(timestamp_h): $(srctree)/Makefile FORCE $(call filechk,timestamp.h)
# --------------------------------------------------------------------------- - -PHONY += depend dep -depend dep: - @echo '*** Warning: make $@ is unnecessary now.' - -# --------------------------------------------------------------------------- quiet_cmd_cpp_lds = LDS $@ cmd_cpp_lds = $(CPP) -Wp,-MD,$(depfile) $(cpp_flags) $(LDPPFLAGS) -ansi \ -D__ASSEMBLY__ -x assembler-with-cpp -P -o $@ $< @@ -1548,11 +1542,6 @@ ifneq ($(cmd_files),) include $(cmd_files) endif
-# Shorthand for $(Q)$(MAKE) -f scripts/Makefile.clean obj=dir -# Usage: -# $(Q)$(MAKE) $(clean)=dir -clean := -f $(srctree)/scripts/Makefile.clean obj - endif # skip-makefile
PHONY += FORCE diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index d20f20a..f02eb37 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -131,17 +131,15 @@ cc-disable-warning = $(call try-run,\ $(CC) $(KBUILD_CPPFLAGS) $(KBUILD_CFLAGS) -W$(strip $(1)) -c -x c /dev/null -o "$$TMP",-Wno-$(strip $(1)))
# cc-version -# Usage gcc-ver := $(call cc-version) cc-version = $(shell $(CONFIG_SHELL) $(srctree)/scripts/gcc-version.sh $(CC))
# cc-fullversion -# Usage gcc-ver := $(call cc-fullversion) cc-fullversion = $(shell $(CONFIG_SHELL) \ $(srctree)/scripts/gcc-version.sh -p $(CC))
# cc-ifversion # Usage: EXTRA_CFLAGS += $(call cc-ifversion, -lt, 0402, -O1) -cc-ifversion = $(shell [ $(call cc-version, $(CC)) $(1) $(2) ] && echo $(3)) +cc-ifversion = $(shell [ $(cc-version) $(1) $(2) ] && echo $(3) || echo $(4))
# added for U-Boot binutils-version = $(shell $(CONFIG_SHELL) $(srctree)/scripts/binutils-version.sh $(AS)) @@ -163,13 +161,12 @@ ld-option = $(call try-run,\ ar-option = $(call try-run, $(AR) rc$(1) "$$TMP",$(1),$(2))
# ld-version -# Usage: $(call ld-version) # Note this is mainly for HJ Lu's 3 number binutil versions ld-version = $(shell $(LD) --version | $(srctree)/scripts/ld-version.sh)
# ld-ifversion # Usage: $(call ld-ifversion, -ge, 22252, y) -ld-ifversion = $(shell [ $(call ld-version) $(1) $(2) ] && echo $(3)) +ld-ifversion = $(shell [ $(ld-version) $(1) $(2) ] && echo $(3) || echo $(4))
@@ -185,6 +182,24 @@ build := -f $(srctree)/scripts/Makefile.build obj # $(Q)$(MAKE) $(modbuiltin)=dir modbuiltin := -f $(srctree)/scripts/Makefile.modbuiltin obj
+### +# Shorthand for $(Q)$(MAKE) -f scripts/Makefile.dtbinst obj= +# Usage: +# $(Q)$(MAKE) $(dtbinst)=dir +dtbinst := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.dtbinst obj + +### +# Shorthand for $(Q)$(MAKE) -f scripts/Makefile.clean obj= +# Usage: +# $(Q)$(MAKE) $(clean)=dir +clean := -f $(srctree)/scripts/Makefile.clean obj + +### +# Shorthand for $(Q)$(MAKE) -f scripts/Makefile.headersinst obj= +# Usage: +# $(Q)$(MAKE) $(hdr-inst)=dir +hdr-inst := -f $(srctree)/scripts/Makefile.headersinst obj + # Prefix -I with $(srctree) if it is not an absolute path. # skip if -I has no parameter addtree = $(if $(patsubst -I%,%,$(1)), \ diff --git a/scripts/Makefile.build b/scripts/Makefile.build index ac0554e..de818ae 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -253,8 +253,9 @@ sub_cmd_record_mcount = set -e ; perl $(srctree)/scripts/recordmcount.pl "$(ARCH "$(if $(part-of-module),1,0)" "$(@)"; recordmcount_source := $(srctree)/scripts/recordmcount.pl endif -cmd_record_mcount = \ - if [ "$(findstring -pg,$(_c_flags))" = "-pg" ]; then \ +cmd_record_mcount = \ + if [ "$(findstring $(CC_FLAGS_FTRACE),$(_c_flags))" = \ + "$(CC_FLAGS_FTRACE)" ]; then \ $(sub_cmd_record_mcount) \ fi; endif diff --git a/scripts/Makefile.clean b/scripts/Makefile.clean index 21e1f21..4853631 100644 --- a/scripts/Makefile.clean +++ b/scripts/Makefile.clean @@ -7,10 +7,7 @@ src := $(obj) PHONY := __clean __clean:
-# Shorthand for $(Q)$(MAKE) scripts/Makefile.clean obj=dir -# Usage: -# $(Q)$(MAKE) $(clean)=dir -clean := -f $(srctree)/scripts/Makefile.clean obj +include scripts/Kbuild.include
# The filename Kbuild has precedence over Makefile kbuild-dir := $(if $(filter /%,$(src)),$(src),$(srctree)/$(src)) @@ -50,19 +47,19 @@ __clean-files := $(extra-y) $(extra-m) $(extra-) \
__clean-files := $(filter-out $(no-clean-files), $(__clean-files))
-# as clean-files is given relative to the current directory, this adds -# a $(obj) prefix, except for absolute paths +# clean-files is given relative to the current directory, unless it +# starts with $(objtree)/ (which means "./", so do not add "./" unless +# you want to delete a file from the toplevel object directory).
__clean-files := $(wildcard \ - $(addprefix $(obj)/, $(filter-out /%, $(__clean-files))) \ - $(filter /%, $(__clean-files))) + $(addprefix $(obj)/, $(filter-out $(objtree)/%, $(__clean-files))) \ + $(filter $(objtree)/%, $(__clean-files)))
-# as clean-dirs is given relative to the current directory, this adds -# a $(obj) prefix, except for absolute paths +# same as clean-files
__clean-dirs := $(wildcard \ - $(addprefix $(obj)/, $(filter-out /%, $(clean-dirs))) \ - $(filter /%, $(clean-dirs))) + $(addprefix $(obj)/, $(filter-out $(objtree)/%, $(clean-dirs))) \ + $(filter $(objtree)/%, $(clean-dirs)))
@@ -79,9 +76,6 @@ endif ifneq ($(strip $(__clean-dirs)),) +$(call cmd,cleandir) endif -ifneq ($(strip $(clean-rule)),) - +$(clean-rule) -endif @:
@@ -96,11 +90,6 @@ PHONY += $(subdir-ymn) $(subdir-ymn): $(Q)$(MAKE) $(clean)=$@
-# If quiet is set, only print short version of command - -cmd = @$(if $($(quiet)cmd_$(1)),echo ' $($(quiet)cmd_$(1))' &&) $(cmd_$(1)) - - # Declare the contents of the .PHONY variable as phony. We keep that # information in a variable se we can use it in if_changed and friends.
diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 8731fc6..84915d7 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -119,6 +119,16 @@ _c_flags += $(if $(patsubst n%,, \ $(CFLAGS_GCOV)) endif
+# +# Enable address sanitizer flags for kernel except some files or directories +# we don't want to check (depends on variables KASAN_SANITIZE_obj.o, KASAN_SANITIZE) +# +ifeq ($(CONFIG_KASAN),y) +_c_flags += $(if $(patsubst n%,, \ + $(KASAN_SANITIZE_$(basetarget).o)$(KASAN_SANITIZE)y), \ + $(CFLAGS_KASAN)) +endif + # If building the kernel in a separate objtree expand all occurrences # of -Idir to -I$(srctree)/dir except for absolute paths (starting with '/').
@@ -274,7 +284,8 @@ $(obj)/%.dtb.S: $(obj)/%.dtb
quiet_cmd_dtc = DTC $@ # Modified for U-Boot -cmd_dtc = $(CPP) $(dtc_cpp_flags) -x assembler-with-cpp -o $(dtc-tmp) $< ; \ +cmd_dtc = mkdir -p $(dir ${dtc-tmp}) ; \ + $(CPP) $(dtc_cpp_flags) -x assembler-with-cpp -o $(dtc-tmp) $< ; \ $(DTC) -O dtb -o $@ -b 0 \ -i $(dir $<) $(DTC_FLAGS) \ -d $(depfile).dtc.tmp $(dtc-tmp) ; \ @@ -285,18 +296,6 @@ $(obj)/%.dtb: $(src)/%.dts FORCE
dtc-tmp = $(subst $(comma),_,$(dot-target).dts.tmp)
-# Helper targets for Installing DTBs into the boot directory -quiet_cmd_dtb_install = INSTALL $< - cmd_dtb_install = cp $< $(2) - -_dtbinst_pre_: - $(Q)if [ -d $(INSTALL_DTBS_PATH).old ]; then rm -rf $(INSTALL_DTBS_PATH).old; fi - $(Q)if [ -d $(INSTALL_DTBS_PATH) ]; then mv $(INSTALL_DTBS_PATH) $(INSTALL_DTBS_PATH).old; fi - $(Q)mkdir -p $(INSTALL_DTBS_PATH) - -%.dtb_dtbinst_: $(obj)/%.dtb _dtbinst_pre_ - $(call cmd,dtb_install,$(INSTALL_DTBS_PATH)) - # Bzip2 # ---------------------------------------------------------------------------
$(always) is added to targets by scripts/Makefile.build. Moreover, filechk does not need .*.cmd files.
Adding these two files to targets is redundant.
Kbuild | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/Kbuild b/Kbuild index 465b930..e2e3b29 100644 --- a/Kbuild +++ b/Kbuild @@ -36,7 +36,7 @@ endef generic-offsets-file := include/generated/generic-asm-offsets.h
always := $(generic-offsets-file) -targets := $(generic-offsets-file) lib/asm-offsets.s +targets := lib/asm-offsets.s
# We use internal kbuild rules to avoid the "is up to date" message from make lib/asm-offsets.s: lib/asm-offsets.c FORCE @@ -55,7 +55,6 @@ offsets-file := include/generated/asm-offsets.h endif
always += $(offsets-file) -targets += $(offsets-file) targets += arch/$(ARCH)/lib/asm-offsets.s
CFLAGS_asm-offsets.o := -DDO_DEPS_ONLY
Prior to this commit, it was impossible to use relative path to include Makefiles from the top level Makefile because the option "--include-dir=$(srctree)" becomes effective when Make enters into sub Makefiles.
To use relative path in any places, this commit moves the option above the "sub-make" target.
This was imported from Linux (commit a436bb7b8063) and adjusted for U-Boot.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Signed-off-by: Michal Marek mmarek@suse.cz ---
Makefile | 20 +++++++++----------- 1 file changed, 9 insertions(+), 11 deletions(-)
diff --git a/Makefile b/Makefile index 865c25d..7471a4f 100644 --- a/Makefile +++ b/Makefile @@ -10,9 +10,10 @@ NAME = # Comments in this file are targeted only to the developer, do not # expect to learn how to build the kernel reading this file.
-# Do not use make's built-in rules and variables -# (this increases performance and avoids hard-to-debug behaviour); -MAKEFLAGS += -rR +# o Do not use make's built-in rules and variables +# (this increases performance and avoids hard-to-debug behaviour); +# o Look for make include files relative to root of kernel src +MAKEFLAGS += -rR --include-dir=$(CURDIR)
# Avoid funny character set dependencies unexport LC_ALL @@ -319,12 +320,9 @@ endif export KBUILD_MODULES KBUILD_BUILTIN export KBUILD_CHECKSRC KBUILD_SRC KBUILD_EXTMOD
-# Look for make include files relative to root of kernel src -MAKEFLAGS += --include-dir=$(srctree) - # We need some generic definitions (do not try to remake the file). -$(srctree)/scripts/Kbuild.include: ; -include $(srctree)/scripts/Kbuild.include +scripts/Kbuild.include: ; +include scripts/Kbuild.include
# Make variables (CC, etc...)
@@ -518,8 +516,8 @@ ifneq ($(wildcard include/config/auto.conf),) autoconf_is_old := $(shell find . -path ./$(KCONFIG_CONFIG) -newer \ include/config/auto.conf) ifeq ($(autoconf_is_old),) -include $(srctree)/config.mk -include $(srctree)/arch/$(ARCH)/Makefile +include config.mk +include arch/$(ARCH)/Makefile endif endif endif @@ -594,7 +592,7 @@ endif
export CONFIG_SYS_TEXT_BASE
-include $(srctree)/scripts/Makefile.extrawarn +include scripts/Makefile.extrawarn
# Add user supplied CPPFLAGS, AFLAGS and CFLAGS as the last assignments KBUILD_CPPFLAGS += $(KCPPFLAGS)
Masahiro Yamada
