[PATCH 0/4] EFI: console: improves
Problems with Linux Grub and U-Boot EFI console - multiplexed console output scrambled - slow refresh rate for big console sizes - vidconsole incompatible with unicode
This patchset provides the following solutions:
1) Fixed detection of vidconsole from within a multiplexed stdout string. As you know, a user can use a comma-separated list of devices to set stdin, stdout and stderr. For example, "setenv stdout serial,vidconsole" is a multiplexed string.
2) Multiplexed adaptation of the query_console_size() function; automatically determine the minimal console area that will fit all outputs properly.
3) Setup the max rows and columns limit for the EFI console output.
4) If EFI_CONSOLE_UTF_SAFE is enabled and vidconsole is active, unicode characters will be replaced with "." for all console outputs. Vidconsole does not support unicode output, and your console will suffer display issues if EFI_CONSOLE_UTF_SAFE is disabled.
Artem Lapkin (4): EFI: console: query_vidconsole: multiplex adaptation EFI: console: query_console_size: multiplex adaptation EFI: console: max rows and cols user limit EFI: console: improve vidconsole unicode output
lib/efi_loader/Kconfig | 21 +++++++++++++++++++++ lib/efi_loader/efi_console.c | 27 +++++++++++++++++++-------- 2 files changed, 40 insertions(+), 8 deletions(-)
Signed-off-by: Artem Lapkin art@khadas.com --- lib/efi_loader/efi_console.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index 3b012e1a66..2d03285f82 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -314,7 +314,7 @@ static int __maybe_unused query_vidconsole(int *rows, int *cols) struct udevice *dev; struct vidconsole_priv *priv;
- if (!stdout_name || strncmp(stdout_name, "vidconsole", 10)) + if (!stdout_name || !strstr(stdout_name, "vidconsole")) return -ENODEV; stdout_dev = stdio_get_by_name("vidconsole"); if (!stdout_dev)
- if (!stdout_name || !strstr(stdout_name, "vidconsole"))
If stdout == "serial,vidconsole", serial is the primary output and we want to determine the size of the console window from serial and not from vidconsole.
So this change seems wrong.
Best regards
Heinrich
return -ENODEV;
please check 3rd patch before https://patchwork.ozlabs.org/project/uboot/patch/20210804102217.2419510-3-ar...
i think its must be clarify problem with multiplex output configuration
CONFIG_CONSOLE_MUX=y CONFIG_CONSOLE_NORMAL=y
please check more information and examples about this + https://dl.khadas.com/test/uboot_efi_examples/#readme + https://dl.khadas.com/test/uboot_efi_examples/media/01-EFI_console_example_n... + https://dl.khadas.com/test/uboot_efi_examples/media/02-EFI_console_example_t... + https://dl.khadas.com/test/uboot_efi_examples/media/02-EFI_console_example_t...
Best regards
Heinrich
Signed-off-by: Artem Lapkin art@khadas.com --- lib/efi_loader/efi_console.c | 16 ++++++++++------ 1 file changed, 10 insertions(+), 6 deletions(-)
diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index 3b012e1a66..ef5cf21bf7 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -340,14 +340,18 @@ static int __maybe_unused query_vidconsole(int *rows, int *cols) static void query_console_size(void) { int rows = 25, cols = 80; - int ret = -ENODEV;
- if (IS_ENABLED(CONFIG_DM_VIDEO)) - ret = query_vidconsole(&rows, &cols); - if (ret) - ret = query_console_serial(&rows, &cols); - if (ret) + if (IS_ENABLED(CONFIG_DM_VIDEO) && + !query_vidconsole(&rows, &cols)) { + int rows_serial, cols_serial; + + if (!query_console_serial(&rows_serial, &cols_serial)) { + rows = min(rows, rows_serial); + cols = min(cols, cols_serial); + } + } else if (query_console_serial(&rows, &cols)) { return; + }
/* Test if we can have Mode 1 */ if (cols >= 80 && rows >= 50) {
Signed-off-by: Artem Lapkin art@khadas.com --- lib/efi_loader/Kconfig | 12 ++++++++++++ lib/efi_loader/efi_console.c | 5 +++++ 2 files changed, 17 insertions(+)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index dacc3b5881..7d00d6cde5 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -381,4 +381,16 @@ config EFI_ESRT help Enabling this option creates the ESRT UEFI system table.
+config EFI_CONSOLE_MAX_ROWS + int "setup console max rows" + default 0 + help + Set console max rows limit or set to zero to disable limit. + +config EFI_CONSOLE_MAX_COLS + int "setup console max cols" + default 0 + help + Set console max rows limit or set to zero to disable limit. + endif diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index 847069212e..b5d79d788f 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -351,6 +351,11 @@ static void query_console_size(void) } else if (query_console_serial(&rows, &cols)) return;
+ if (CONFIG_EFI_CONSOLE_MAX_ROWS > 0) + rows = min(rows, CONFIG_EFI_CONSOLE_MAX_ROWS); + if (CONFIG_EFI_CONSOLE_MAX_COLS > 0) + cols = min(cols, CONFIG_EFI_CONSOLE_MAX_COLS); + /* Test if we can have Mode 1 */ if (cols >= 80 && rows >= 50) { efi_cout_modes[1].present = 1;
Why should a user set this up?
The size of serial console depends on the remote computers console windows size.
The size of a video console depends on the attached monitor.
So we have to detect the size dynamically. Hardcoding it does not make any sense.
Best regards
Heinrich
- int "setup console max rows"
- default 0
- help
- int "setup console max cols"
- default 0
- help
- endif
- if (CONFIG_EFI_CONSOLE_MAX_ROWS > 0)
- if (CONFIG_EFI_CONSOLE_MAX_COLS > 0)
- /* Test if we can have Mode 1 */ if (cols >= 80 && rows >= 50) { efi_cout_modes[1].present = 1;
only if user need it! by default is 0 no limit
EFI console not usable for some cases: big screen sizes + mux with serial console
for example
EFI console - fullscreen (1080P) vidconsole - SLUGGISH FRAMERATES AND NOT USABLE
CONFIG_CONSOLE_MUX=y CONFIG_CONSOLE_NORMAL=y CONFIG_EFI_CONSOLE_MAX_ROWS=0 CONFIG_EFI_CONSOLE_MAX_COLS=0
https://dl.khadas.com/test/uboot_efi_examples/media/07-EFI_console_example_n...
EFI console - vidconsole with row and column limits - USABLE FRAMERATES
CONFIG_CONSOLE_MUX=y CONFIG_CONSOLE_NORMAL=y CONFIG_EFI_CONSOLE_MAX_ROWS=90 CONFIG_EFI_CONSOLE_MAX_COLS=25
https://dl.khadas.com/test/uboot_efi_examples/media/06-EFI_console_example_n...
Please check more information and examples about this
Best regards
Heinrich
default 0
help
default 0
help
- endif
for example
Best regards
Heinrich
This allows negative values.
Add an allowable range, e.g:
range 0 65535
default 0
help
range 0 65535
default 0
help
- endif
We should not neither call query_vidconsole() nor query_console_serial() if both CONFIG_EFI_CONSOLE_MAX_ROWS and CONFIG_EFI_CONSOLE_MAX_COLS are set.
The UEFI specification requires that a device providing the EFI_SIMPLE_TEXT_OUTPUT_PROTOCOL must at least support a mode with size 80x25. But some LCD screens are smaller. So if CONFIG_EFI_CONSOLE_MAX_ROWS or CONFIG_EFI_CONSOLE_MAX_COLS doesn't fit into 80x25, we should use CONFIG_EFI_CONSOLE_MAX_ROWS and CONFIG_EFI_CONSOLE_MAX_COLS for mode 0.
Best regards
Heinrich
Signed-off-by: Artem Lapkin art@khadas.com --- lib/efi_loader/Kconfig | 9 +++++++++ lib/efi_loader/efi_console.c | 6 +++++- 2 files changed, 14 insertions(+), 1 deletion(-)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 7d00d6cde5..886e0ce111 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -393,4 +393,13 @@ config EFI_CONSOLE_MAX_COLS help Set console max rows limit or set to zero to disable limit.
+config EFI_CONSOLE_UTF_SAFE + bool "If vidconsole is active, unicode characters will be replaced with '.'" + default n + help + If EFI_CONSOLE_UTF_SAFE is enabled and vidconsole is active, unicode + characters will be replaced with "." for all console outputs. + Vidconsole does not support unicode output, and your console will + suffer display issues if EFI_CONSOLE_UTF_SAFE is disabled. + endif diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index b5d79d788f..bd1c14995d 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -19,6 +19,8 @@ #define EFI_COUT_MODE_2 2 #define EFI_MAX_COUT_MODE 3
+static int vidconsole_active; + struct cout_mode { unsigned long columns; unsigned long rows; @@ -163,7 +165,8 @@ static efi_status_t EFIAPI efi_cout_output_string( } pos = buf; utf16_utf8_strcpy(&pos, string); - fputs(stdout, buf); + fputs(stdout, IS_ENABLED(CONFIG_EFI_CONSOLE_UTF_SAFE) && + strlen(buf) > 1 && vidconsole_active ? "." : buf); free(buf);
/* @@ -327,6 +330,7 @@ static int __maybe_unused query_vidconsole(int *rows, int *cols) return -ENODEV; *rows = priv->rows; *cols = priv->cols; + vidconsole_active = 1; return 0; }
The TrueType console is meant to support Unicode including the special characters used by GRUB like left and right triangle.
So this patch is based on a wrong assumption.
Best regards
Heinrich
- bool "If vidconsole is active, unicode characters will be replaced with '.'"
- default n
- help
- endif
- struct cout_mode { unsigned long columns; unsigned long rows;
free(buf);
- vidconsole_active = 1; return 0; }
Yes is meant but not works (on my side) ...
uboot TrueType vidconsole does not work properly as a unicode console in my case and have other problems
CONFIG_CONSOLE_MUX=y CONFIG_CONSOLE_NORMAL=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_SIZE=18 CONFIG_CONSOLE_TRUETYPE_NIMBUS=y
+ https://dl.khadas.com/test/uboot_efi_examples/#readme + https://dl.khadas.com/test/uboot_efi_examples/media/02-EFI_console_example_t... + https://dl.khadas.com/test/uboot_efi_examples/media/02-EFI_console_example_t... + https://dl.khadas.com/test/uboot_efi_examples/media/02-EFI_console_example_t...
Best regards
Heinrich
default n
help
- endif
fputs(stdout, buf);
strlen(buf) > 1 && vidconsole_active ? "." : buf); free(buf); /*
}vidconsole_active = 1; return 0;
Art Nikpal
Artem Lapkin
