[U-Boot] [PATCH] common: remove unaligned access error in bootmenu_getoption()
Some ARM compilers may emit code that makes unaligned accesses when faced with constructs such as:
char name[12] = "bootmenu_";
same fix as commit: 064d55f8bc8d7d205ed0be6abb6717e92eeb7cad
========================================================= data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<3ff4b60c>] lr : [<3ff4b7b0>] sp : 3f346a58 ip : 3ff9c8e6 fp : 02000060 r10: 00000000 r9 : 3df47fc0 r8 : 3f347f40 r7 : 00000000 r6 : 00000000 r5 : 00000003 r4 : 3f759140 r3 : 000003f0 r2 : 00000000 r1 : 000003f1 r0 : 00000000 Flags: nzCv IRQs on FIQs off Mode SVC_32 Resetting CPU ... ======================================================
Signed-off-by: Lan Yixun (dlan) dennis.yxun@gmail.com --- common/cmd_bootmenu.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/cmd_bootmenu.c b/common/cmd_bootmenu.c index 7041273..d414c17 100644 --- a/common/cmd_bootmenu.c +++ b/common/cmd_bootmenu.c @@ -65,12 +65,12 @@ enum bootmenu_key {
static char *bootmenu_getoption(unsigned short int n) { - char name[MAX_ENV_SIZE] = "bootmenu_"; + char name[MAX_ENV_SIZE];
if (n > MAX_COUNT) return NULL;
- sprintf(name + 9, "%d", n); + sprintf(name, "bootmenu_%d", n); return getenv(name); }
Lan Yixun (dlan)
