[U-Boot-Users] [PATCH 2/17] Improve error messages, more informative.
Print more than the raw libfdt error message strings. This is especially useful for cluing in the user when the bootm command aborts due to blob problems.
Signed-off-by: Gerald Van Baren vanbaren@cideas.com --- common/fdt_support.c | 27 ++++++++++++++------------- 1 files changed, 14 insertions(+), 13 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 69099c4..bcdc415 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -67,7 +67,7 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) return err; } if (used >= total) { - printf("fdt_chosen: no room in the reserved map (%d of %d)\n", + printf("WARNING fdt_chosen: no room in the reserved map (%d of %d)\n", used, total); return -1; } @@ -110,7 +110,7 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) */ nodeoffset = fdt_add_subnode(fdt, 0, "chosen"); if (nodeoffset < 0) { - printf("libfdt: %s\n", fdt_strerror(nodeoffset)); + printf("WARNING fdt_chosen: could not create the "/chosen node" (libfdt error %s).\n", fdt_strerror(nodeoffset)); return nodeoffset; } } @@ -122,22 +122,22 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) if (str != NULL) { err = fdt_setprop(fdt, nodeoffset, "bootargs", str, strlen(str)+1); if (err < 0) - printf("libfdt: %s\n", fdt_strerror(err)); + printf("WARNING fdt_chosen: could not set "bootargs" (libfdt error %s).\n", fdt_strerror(err)); } if (initrd_start && initrd_end) { tmp = __cpu_to_be32(initrd_start); err = fdt_setprop(fdt, nodeoffset, "linux,initrd-start", &tmp, sizeof(tmp)); if (err < 0) - printf("libfdt: %s\n", fdt_strerror(err)); + printf("WARNING fdt_chosen: could not set "linux,initrd-start" (libfdt error %s).\n", fdt_strerror(err)); tmp = __cpu_to_be32(initrd_end); err = fdt_setprop(fdt, nodeoffset, "linux,initrd-end", &tmp, sizeof(tmp)); if (err < 0) - printf("libfdt: %s\n", fdt_strerror(err)); + printf("WARNING fdt_chosen: could not set "linux,initrd-end" (libfdt error %s).\n", fdt_strerror(err)); } #ifdef OF_STDOUT_PATH err = fdt_setprop(fdt, nodeoffset, "linux,stdout-path", OF_STDOUT_PATH, strlen(OF_STDOUT_PATH)+1); if (err < 0) - printf("libfdt: %s\n", fdt_strerror(err)); + printf("WARNING fdt_chosen: could not set "linux,stdout-path" (libfdt error %s).\n", fdt_strerror(err)); #endif
nodeoffset = fdt_path_offset (fdt, "/cpus"); @@ -145,7 +145,7 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) clock = cpu_to_be32(bd->bi_intfreq); err = fdt_setprop(fdt, nodeoffset, "clock-frequency", &clock, 4); if (err < 0) - printf("libfdt: %s\n", fdt_strerror(err)); + printf("WARNING fdt_chosen: could not set "clock-frequency" (libfdt error %s).\n", fdt_strerror(err)); } #ifdef OF_TBCLK nodeoffset = fdt_path_offset (fdt, "/cpus/" OF_CPU "/timebase-frequency"); @@ -153,7 +153,7 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) clock = cpu_to_be32(OF_TBCLK); err = fdt_setprop(fdt, nodeoffset, "clock-frequency", &clock, 4); if (err < 0) - printf("libfdt: %s\n", fdt_strerror(err)); + printf("WARNING fdt_chosen: could not set "clock-frequency" (libfdt error %s).\n", fdt_strerror(err)); } #endif return err; @@ -198,7 +198,7 @@ int fdt_env(void *fdt) */ nodeoffset = fdt_add_subnode(fdt, 0, "u-boot-env"); if (nodeoffset < 0) { - printf("libfdt: %s\n", fdt_strerror(nodeoffset)); + printf("WARNING fdt_env: could not create the "/u-boot-env node" (libfdt error %s).\n", fdt_strerror(nodeoffset)); return nodeoffset; }
@@ -226,7 +226,7 @@ int fdt_env(void *fdt) continue; err = fdt_setprop(fdt, nodeoffset, lval, rval, strlen(rval)+1); if (err < 0) { - printf("libfdt: %s\n", fdt_strerror(err)); + printf("WARNING fdt_env: could not set "%s" (libfdt error %s).\n", lval, fdt_strerror(err)); return err; } } @@ -318,6 +318,7 @@ int fdt_bd_t(void *fdt) */ nodeoffset = fdt_add_subnode(fdt, 0, "bd_t"); if (nodeoffset < 0) { + printf("WARNING fdt_bd_t: could not create the "/bd_t node" (libfdt error %s).\n", fdt_strerror(nodeoffset)); printf("libfdt: %s\n", fdt_strerror(nodeoffset)); return nodeoffset; } @@ -328,17 +329,17 @@ int fdt_bd_t(void *fdt) tmp = cpu_to_be32(getenv("bootargs")); err = fdt_setprop(fdt, nodeoffset, bd_map[i].name, &tmp, sizeof(tmp)); if (err < 0) - printf("libfdt: %s\n", fdt_strerror(err)); + printf("WARNING fdt_bd_t: could not set "%s" (libfdt error %s).\n", bd_map[i].name, fdt_strerror(err)); } /* * Add a couple of oddball entries... */ err = fdt_setprop(fdt, nodeoffset, "enetaddr", &bd->bi_enetaddr, 6); if (err < 0) - printf("libfdt: %s\n", fdt_strerror(err)); + printf("WARNING fdt_bd_t: could not set "enetaddr" (libfdt error %s).\n", fdt_strerror(err)); err = fdt_setprop(fdt, nodeoffset, "ethspeed", &bd->bi_ethspeed, 4); if (err < 0) - printf("libfdt: %s\n", fdt_strerror(err)); + printf("WARNING fdt_bd_t: could not set "ethspeed" (libfdt error %s).\n", fdt_strerror(err));
return 0; }
Acked-by: Grant Likely grant.likely@secretlab.ca
printf("WARNING fdt_chosen: could not create the \"/chosen node\" (libfdt error %s).\n", fdt_strerror(nodeoffset)); return nodeoffset; } }
printf("WARNING fdt_chosen: could not set \"bootargs\" (libfdt error %s).\n", fdt_strerror(err)); } if (initrd_start && initrd_end) { tmp = __cpu_to_be32(initrd_start); err = fdt_setprop(fdt, nodeoffset, "linux,initrd-start", &tmp, sizeof(tmp)); if (err < 0)
printf("WARNING fdt_chosen: could not set \"linux,initrd-start\" (libfdt error %s).\n", fdt_strerror(err)); tmp = __cpu_to_be32(initrd_end); err = fdt_setprop(fdt, nodeoffset, "linux,initrd-end", &tmp, sizeof(tmp)); if (err < 0)
printf("WARNING fdt_chosen: could not set \"linux,initrd-end\" (libfdt error %s).\n", fdt_strerror(err)); }
printf("WARNING fdt_chosen: could not set \"linux,stdout-path\" (libfdt error %s).\n", fdt_strerror(err));
#endif
printf("WARNING fdt_chosen: could not set \"clock-frequency\" (libfdt error %s).\n", fdt_strerror(err)); }
printf("WARNING fdt_env: could not create the \"/u-boot-env node\" (libfdt error %s).\n", fdt_strerror(nodeoffset)); return nodeoffset; }
printf("WARNING fdt_env: could not set \"%s\" (libfdt error %s).\n", lval, fdt_strerror(err)); return err; } }
printf("WARNING fdt_bd_t: could not create the \"/bd_t node\" (libfdt error %s).\n", fdt_strerror(nodeoffset)); printf("libfdt: %s\n", fdt_strerror(nodeoffset)); return nodeoffset; }
printf("WARNING fdt_bd_t: could not set \"%s\" (libfdt error %s).\n", bd_map[i].name, fdt_strerror(err)); } /* * Add a couple of oddball entries... */ err = fdt_setprop(fdt, nodeoffset, "enetaddr", &bd->bi_enetaddr, 6); if (err < 0)
printf("WARNING fdt_bd_t: could not set \"enetaddr\" (libfdt error %s).\n", fdt_strerror(err)); err = fdt_setprop(fdt, nodeoffset, "ethspeed", &bd->bi_ethspeed, 4); if (err < 0)
printf("WARNING fdt_bd_t: could not set \"ethspeed\" (libfdt error %s).\n", fdt_strerror(err)); return 0;
1.4.4.4
This SF.net email is sponsored by DB2 Express Download DB2 Express C - the FREE version of DB2 express and take control of your XML. No limits. Just data. Click to get it now. http://sourceforge.net/powerbar/db2/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Grant Likely
Jerry Van Baren
