[U-Boot-Users] [PATCH] ARM supplied & supported development boards. Errata & rationalization - corrected patch
Attached (diff -purN) patch against the GIT head code of 4th October 2005. This replaces yesterday's patch which broke CONFIG_SMC91111_BASE.
Apologies for any inconvenience caused.
CHANGELOG * Patch 005 by Peter Pearse peter.pearse@arm.com 4th Oct 2005 Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h.
Valid patches are now: --------------------- 000 Patch submitted 30th June 2005 Import cc-option shell function from kernel Use it to get the correct ARM gcc options for individual cpus 002 Patch submitted 29th Sept 2005 Ensure Integrator boards call platformsetup() rather than lowlevel_init() 003 Patch submitted 29th Sept 2005 Provide Makefile targets for all ARM supported development boards 005 Patch submitted 4th Oct 2005 Split off common core module data
Regards
Peter Pearse
In message 89A528FE6DB0FA44877BB2F05B84671803282269@ZIPPY.Emea.Arm.com you wrote:
CHANGELOG
- Patch 005 by Peter Pearse peter.pearse@arm.com 4th Oct 2005 Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h.
Please provide a changelog entry I can use for copy & paste. Please follow the format of existing examples.
Also please make sure to follow the coding style; your patches added trailing white space to board/integratorcp/platform.S, include/armcoremodule.h, include/configs/integratorcp.h; bad indentation (spaces instead of TAB) in config.mk; trailing empty lines in all touched config.mk files.
I now processed all your patches that were marked open in my list. Please cleanup / resubmit any missing / rejected parts.
Thanks.
CHANGELOG
Added, (as far as applicable). Thanks.
Peter Pearse
