[U-Boot] [PATCH] board: atmel: fix pda variable not being reset
In case someone detects a PDA and u-boot sets the 'pda' variable, and the user does a saveenv, the pda is set in env, and if the screen is removed, u-boot will still have in the env the 'pda' variable, even if no screen is attached. In order to fix this, we have to reset the 'pda' variable, such that it's not just set if the screen is detected, but also unset if no screen is detected.
Signed-off-by: Eugen Hristev eugen.hristev@microchip.com --- board/atmel/common/board.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/atmel/common/board.c b/board/atmel/common/board.c index fc300a4..20c3b8c 100644 --- a/board/atmel/common/board.c +++ b/board/atmel/common/board.c @@ -29,7 +29,7 @@ void at91_pda_detect(void)
ret = w1_get_bus(AT91_PDA_EEPROM_DEFAULT_BUS, &bus); if (ret) - return; + goto pda_detect_err;
for (device_find_first_child(bus, &dev); dev; @@ -41,7 +41,7 @@ void at91_pda_detect(void) ret = w1_eeprom_read_buf(dev, AT91_PDA_EEPROM_ID_OFFSET, (u8 *)buf, AT91_PDA_EEPROM_ID_LENGTH); if (ret) - return; + goto pda_detect_err; break; } } @@ -61,6 +61,8 @@ void at91_pda_detect(void) printf("PDA TM5000 detected\n"); break; } + +pda_detect_err: env_set("pda", (const char *)buf); } #else
Applied to u-boot-atmel/master
Eugen.Hristev@microchip.com
