[GIT PULL] clock changes for v2022.04-rc2
The following changes since commit 90de95f7443cb06f014824976251f126ac6f71c0:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-usb (2022-02-23 13:34:14 -0500)
https://source.denx.de/u-boot/custodians/u-boot-clk.git tags/clk-2022.04-rc2
for you to fetch changes up to 92a1bba85761e4dd5c0647c48048423bceef4749:
cmd: clk: fix long help message (2022-02-25 01:41:04 -0500)
---------------------------------------------------------------- Clock patches for v2022.04-rc2
This has an assortment of cleanups and the occasional bugfix. Also present is the addition of the clock subsystem documentation to HTML docs.
CI: https://source.denx.de/u-boot/custodians/u-boot-clk/-/pipelines/11075
---------------------------------------------------------------- Patrick Delaunay (5): clk: ccf: correct the test on the parent uclass in clk_enable/clk_disable cmd: clk: test the number of argument in setfreq command cmd: clk: replace clk_lookup by uclass_get_device_by_name cmd: clk: update result of do_clk_setfreq cmd: clk: fix long help message
Sean Anderson (11): clk: Alphabetize Makefile clk: Alphabetize Kconfig clk: Rename ICS8N3QV01 to CLK_ICS8N3QV01 clk: Remove no-op request and rfree callbacks clk: versaclock: Remove xlate function clk: cdce9xx: Convert .of_xlate to .request clk: Rename clk_get_optional_nodev clk: Inline clk_get_*_optional clk: Add client API to HTML docs clk: Add driver API to HTML docs clk: Add clk_get_by_name_optional
cmd/clk.c | 25 +++------- configs/gazerbeam_defconfig | 2 +- doc/api/clk.rst | 19 ++++++++ doc/api/index.rst | 1 + drivers/clk/Kconfig | 182 +++++++++++++++++++++++++++++++++++----------------------------------- drivers/clk/Makefile | 20 ++++---- drivers/clk/clk-cdce9xx.c | 12 ++--- drivers/clk/clk-uclass.c | 25 +--------- drivers/clk/clk_versaclock.c | 19 -------- drivers/clk/clk_zynq.c | 5 +- drivers/clk/ics8n3qv01.c | 6 --- drivers/clk/tegra/tegra-car-clk.c | 9 ---- drivers/clk/ti/clk-sci.c | 14 ------ drivers/phy/phy-mtk-tphy.c | 8 ++-- drivers/rng/meson-rng.c | 4 +- include/clk-uclass.h | 187 ++++++++++++++++++++++++++++++++++++++++++------------------------------ include/clk.h | 255 +++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------------------------------- 17 files changed, 394 insertions(+), 399 deletions(-) create mode 100644 doc/api/clk.rst
Sean Anderson
