[U-Boot] [PATCH 00/27] arm64: zynqmp: Update DT files
these are patches I have collected in Xilinx repo and which should go to mainline. There are 3 typo of patches. 1. IIO wiring for ina226 and using IIO ina226 driver instead of hwmon 2. DT fixes and small updates 3. Alignments including name synchronization
Thanks, Michal
Harini Katakam (2): arm64: zynqmp: dt: Add missing DP83867 quirk arm64: zynqmp: dt: Add optional gpio phy reset properties
Michal Simek (21): arm64: zynqmp: Sync names for SC with Versal arm64: zynqmp: Use ethernet-phy as node name for ethernet phys arm64: zynqmp: Enable iio-hwmon for ina226 on g-a2197-00 arm64: zynqmp: Add label property to all ina226 on g-a2197-00 arm64: zynqmp: Fix typo in zynqmp-p-a2197-00-revA arm64: zynqmp: Enable iio-hwmon for ina226 on m-a2197-01 arm64: zynqmp: Add label property to all ina226 on m-a2197-01 arm64: zynqmp: Switch spi-flash to jedec,spi-nor on m-a2197 arm64: zynqmp: Fix m-a2197-01 DT based on latest schematics arm64: zynqmp: Sync si570 setup and clock names arm64: zynqmp: Remove fixme about memory size on zynqmp-p-a2197 arm64: zynqmp: Enable iio-hwmon for ina226 on zcu111 arm64: zynqmp: Add label property to all ina226 on zcu111 arm64: zynqmp: Enable iio-hwmon for ina226 on zcu106 arm64: zynqmp: Add label property to all ina226 on zcu106 arm64: zynqmp: Enable iio-hwmon for ina226 on zcu104 arm64: zynqmp: Enable fpd_dma for zcu104 platforms arm64: zynqmp: Enable iio-hwmon for ina226 on zcu102 arm64: zynqmp: Add label property to all ina226 on zcu102 arm64: zynqmp: Turn comment to gpio-line-names arm64: zynqmp: Enable iio-hwmon for ina226 on zcu100
Nishant Mittal (2): arm64: zynqmp: Fix i2c address of u70 on p-a2197-00 board arm64: zynqmp: Added new tps53679 compatible string for a2197-0x boards
T Karthik Reddy (1): arm64: zynqmp: dt: Delete no-1-8-v property from zcu102-rev1.0
Venkatesh Yadav Abbarapu (1): arm64: zynqmp: Fix the si570 clock frequency on zcu111
arch/arm/dts/Makefile | 6 +- ...-g-revA.dts => zynqmp-g-a2197-00-revA.dts} | 55 ++++- ...-m-revA.dts => zynqmp-m-a2197-01-revA.dts} | 68 +++++-- ...-p-revA.dts => zynqmp-p-a2197-00-revA.dts} | 42 ++-- arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts | 3 +- arch/arm/dts/zynqmp-zc1751-xm017-dc3.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts | 2 +- arch/arm/dts/zynqmp-zcu100-revC.dts | 8 +- arch/arm/dts/zynqmp-zcu102-rev1.0.dts | 4 + arch/arm/dts/zynqmp-zcu102-revA.dts | 192 +++++++++++++----- arch/arm/dts/zynqmp-zcu102-revB.dts | 4 +- arch/arm/dts/zynqmp-zcu104-revA.dts | 35 +++- arch/arm/dts/zynqmp-zcu104-revC.dts | 43 +++- arch/arm/dts/zynqmp-zcu106-revA.dts | 148 ++++++++++++-- arch/arm/dts/zynqmp-zcu111-revA.dts | 118 +++++++++-- configs/xilinx_zynqmp_a2197_revA_defconfig | 2 +- ...> xilinx_zynqmp_g_a2197_00_revA_defconfig} | 2 +- ...> xilinx_zynqmp_m_a2197_01_revA_defconfig} | 2 +- ...> xilinx_zynqmp_p_a2197_00_revA_defconfig} | 2 +- 20 files changed, 588 insertions(+), 152 deletions(-) rename arch/arm/dts/{zynqmp-a2197-g-revA.dts => zynqmp-g-a2197-00-revA.dts} (85%) rename arch/arm/dts/{zynqmp-a2197-m-revA.dts => zynqmp-m-a2197-01-revA.dts} (86%) rename arch/arm/dts/{zynqmp-a2197-p-revA.dts => zynqmp-p-a2197-00-revA.dts} (93%) rename configs/{xilinx_zynqmp_a2197_m_revA_defconfig => xilinx_zynqmp_g_a2197_00_revA_defconfig} (98%) rename configs/{xilinx_zynqmp_a2197_g_revA_defconfig => xilinx_zynqmp_m_a2197_01_revA_defconfig} (98%) rename configs/{xilinx_zynqmp_a2197_p_revA_defconfig => xilinx_zynqmp_p_a2197_00_revA_defconfig} (98%)
ZynqMP based System controller is present on Versal boards. This patch is aligning names with Versal to follow the spec.
arch/arm/dts/Makefile | 6 +++--- .../{zynqmp-a2197-g-revA.dts => zynqmp-g-a2197-00-revA.dts} | 2 +- .../{zynqmp-a2197-m-revA.dts => zynqmp-m-a2197-01-revA.dts} | 2 +- .../{zynqmp-a2197-p-revA.dts => zynqmp-p-a2197-00-revA.dts} | 2 +- configs/xilinx_zynqmp_a2197_revA_defconfig | 2 +- ...vA_defconfig => xilinx_zynqmp_g_a2197_00_revA_defconfig} | 2 +- ...vA_defconfig => xilinx_zynqmp_m_a2197_01_revA_defconfig} | 2 +- ...vA_defconfig => xilinx_zynqmp_p_a2197_00_revA_defconfig} | 2 +- 8 files changed, 10 insertions(+), 10 deletions(-) rename arch/arm/dts/{zynqmp-a2197-g-revA.dts => zynqmp-g-a2197-00-revA.dts} (99%) rename arch/arm/dts/{zynqmp-a2197-m-revA.dts => zynqmp-m-a2197-01-revA.dts} (99%) rename arch/arm/dts/{zynqmp-a2197-p-revA.dts => zynqmp-p-a2197-00-revA.dts} (99%) rename configs/{xilinx_zynqmp_a2197_m_revA_defconfig => xilinx_zynqmp_g_a2197_00_revA_defconfig} (98%) rename configs/{xilinx_zynqmp_a2197_g_revA_defconfig => xilinx_zynqmp_m_a2197_01_revA_defconfig} (98%) rename configs/{xilinx_zynqmp_a2197_p_revA_defconfig => xilinx_zynqmp_p_a2197_00_revA_defconfig} (98%)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 727da1a280bc..53f919621bef 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -248,9 +248,9 @@ dtb-$(CONFIG_ARCH_ZYNQMP) += \ avnet-ultra96-rev1.dtb \ avnet-ultrazedev-cc-v1.0-ultrazedev-som-v1.0.dtb \ zynqmp-a2197-revA.dtb \ - zynqmp-a2197-g-revA.dtb \ - zynqmp-a2197-m-revA.dtb \ - zynqmp-a2197-p-revA.dtb \ + zynqmp-g-a2197-00-revA.dtb \ + zynqmp-m-a2197-01-revA.dtb \ + zynqmp-p-a2197-00-revA.dtb \ zynqmp-mini.dtb \ zynqmp-mini-emmc0.dtb \ zynqmp-mini-emmc1.dtb \ diff --git a/arch/arm/dts/zynqmp-a2197-g-revA.dts b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts similarity index 99% rename from arch/arm/dts/zynqmp-a2197-g-revA.dts rename to arch/arm/dts/zynqmp-g-a2197-00-revA.dts index c6072b5f4273..ae834bc2a692 100644 --- a/arch/arm/dts/zynqmp-a2197-g-revA.dts +++ b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts @@ -14,7 +14,7 @@
/ { model = "Versal System Controller on a2197 MGT Char board RevA"; - compatible = "xlnx,zynqmp-a2197-g-revA", "xlnx,zynqmp-a2197-revA", + compatible = "xlnx,zynqmp-g-a2197-00-revA", "xlnx,zynqmp-a2197-revA", "xlnx,zynqmp-a2197", "xlnx,zynqmp";
aliases { diff --git a/arch/arm/dts/zynqmp-a2197-m-revA.dts b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts similarity index 99% rename from arch/arm/dts/zynqmp-a2197-m-revA.dts rename to arch/arm/dts/zynqmp-m-a2197-01-revA.dts index e4b45eafe42e..65eeea1b26b6 100644 --- a/arch/arm/dts/zynqmp-a2197-m-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts @@ -14,7 +14,7 @@
/ { model = "Versal System Controller on a2197 Memory Char board RevA"; - compatible = "xlnx,zynqmp-a2197-m-revA", "xlnx,zynqmp-a2197-revA", + compatible = "xlnx,zynqmp-m-a2197-01-revA", "xlnx,zynqmp-a2197-revA", "xlnx,zynqmp-a2197", "xlnx,zynqmp";
aliases { diff --git a/arch/arm/dts/zynqmp-a2197-p-revA.dts b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts similarity index 99% rename from arch/arm/dts/zynqmp-a2197-p-revA.dts rename to arch/arm/dts/zynqmp-p-a2197-00-revA.dts index 322b36e391a7..f49da8162a01 100644 --- a/arch/arm/dts/zynqmp-a2197-p-revA.dts +++ b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts @@ -14,7 +14,7 @@
/ { model = "Versal System Controller on a2197 Processor Char board RevA"; /* Tenzing */ - compatible = "xlnx,zynqmp-a2197-p-revA", "xlnx,zynqmp-a2197-revA", + compatible = "xlnx,zynqmp-p-a2197-00-revA", "xlnx,zynqmp-a2197-revA", "xlnx,zynqmp-a2197", "xlnx,zynqmp";
aliases { diff --git a/configs/xilinx_zynqmp_a2197_revA_defconfig b/configs/xilinx_zynqmp_a2197_revA_defconfig index 3498483f4b78..5acf70107339 100644 --- a/configs/xilinx_zynqmp_a2197_revA_defconfig +++ b/configs/xilinx_zynqmp_a2197_revA_defconfig @@ -43,7 +43,7 @@ CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-a2197-revA" -CONFIG_OF_LIST="zynqmp-a2197-revA zynqmp-a2197-g-revA zynqmp-a2197-p-revA zynqmp-a2197-m-revA" +CONFIG_OF_LIST="zynqmp-a2197-revA zynqmp-g-a2197-00-revA zynqmp-p-a2197-00-revA zynqmp-m-a2197-01-revA" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y diff --git a/configs/xilinx_zynqmp_a2197_m_revA_defconfig b/configs/xilinx_zynqmp_g_a2197_00_revA_defconfig similarity index 98% rename from configs/xilinx_zynqmp_a2197_m_revA_defconfig rename to configs/xilinx_zynqmp_g_a2197_00_revA_defconfig index fb4020b2dfed..9cc9191a4138 100644 --- a/configs/xilinx_zynqmp_a2197_m_revA_defconfig +++ b/configs/xilinx_zynqmp_g_a2197_00_revA_defconfig @@ -42,7 +42,7 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="zynqmp-a2197-m-revA" +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-g-a2197-00-revA" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y diff --git a/configs/xilinx_zynqmp_a2197_g_revA_defconfig b/configs/xilinx_zynqmp_m_a2197_01_revA_defconfig similarity index 98% rename from configs/xilinx_zynqmp_a2197_g_revA_defconfig rename to configs/xilinx_zynqmp_m_a2197_01_revA_defconfig index 47a98c6d4d8b..ea6c6b9b0122 100644 --- a/configs/xilinx_zynqmp_a2197_g_revA_defconfig +++ b/configs/xilinx_zynqmp_m_a2197_01_revA_defconfig @@ -42,7 +42,7 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="zynqmp-a2197-g-revA" +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-m-a2197-01-revA" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y diff --git a/configs/xilinx_zynqmp_a2197_p_revA_defconfig b/configs/xilinx_zynqmp_p_a2197_00_revA_defconfig similarity index 98% rename from configs/xilinx_zynqmp_a2197_p_revA_defconfig rename to configs/xilinx_zynqmp_p_a2197_00_revA_defconfig index d19c6b34cac6..a7c4c79ebafb 100644 --- a/configs/xilinx_zynqmp_a2197_p_revA_defconfig +++ b/configs/xilinx_zynqmp_p_a2197_00_revA_defconfig @@ -43,7 +43,7 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="zynqmp-a2197-p-revA" +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-p-a2197-00-revA" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y
Ethernet phys based on devicetree specification should be using ethernet-phy@ node name instead of pure phy@.
arch/arm/dts/zynqmp-g-a2197-00-revA.dts | 2 +- arch/arm/dts/zynqmp-m-a2197-01-revA.dts | 2 +- arch/arm/dts/zynqmp-p-a2197-00-revA.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm017-dc3.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts | 2 +- arch/arm/dts/zynqmp-zcu102-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu102-revB.dts | 2 +- arch/arm/dts/zynqmp-zcu104-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu104-revC.dts | 2 +- arch/arm/dts/zynqmp-zcu106-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu111-revA.dts | 2 +- 13 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts index ae834bc2a692..6e5a0d2c5be6 100644 --- a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts @@ -58,7 +58,7 @@ phy-handle = <&phy0>; phy-mode = "sgmii"; is-internal-pcspma; - phy0: phy@0 { /* marwell m88e1512 */ + phy0: ethernet-phy@0 { /* marwell m88e1512 */ reg = <0>; reset-gpios = <&gpio 42 GPIO_ACTIVE_LOW>; /* xlnx,phy-type = <PHY_TYPE_SGMII>; */ diff --git a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts index 65eeea1b26b6..889491456aa4 100644 --- a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts @@ -89,7 +89,7 @@ phy-handle = <&phy0>; phy-mode = "sgmii"; /* DTG generates this properly 1512 */ phy-reset-gpios = <&gpio 142 GPIO_ACTIVE_LOW>; - phy0: phy@0 { /* marwell m88e1512 - SGMII */ + phy0: ethernet-phy@0 { /* marwell m88e1512 - SGMII */ reg = <0>; /* xlnx,phy-type = <PHY_TYPE_SGMII>; */ }; diff --git a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts index f49da8162a01..04d5fc9f933f 100644 --- a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts @@ -76,7 +76,7 @@ phy-mode = "sgmii"; /* DTG generates this properly 1512 */ is-internal-pcspma; /* phy-reset-gpios = <&gpio 142 GPIO_ACTIVE_LOW>; */ - phy0: phy@0 { + phy0: ethernet-phy@0 { reg = <0>; }; }; diff --git a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts index 8824f5cc0272..bb6a94eefb8f 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts @@ -75,7 +75,7 @@ status = "okay"; phy-handle = <&phy0>; phy-mode = "rgmii-id"; - phy0: phy@0 { + phy0: ethernet-phy@0 { reg = <0>; }; }; diff --git a/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts b/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts index afa90a8a5b09..b8cc5ed22e61 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts @@ -85,7 +85,7 @@ status = "okay"; phy-handle = <&phy0>; phy-mode = "rgmii-id"; - phy0: phy@5 { + phy0: ethernet-phy@5 { reg = <5>; ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; diff --git a/arch/arm/dts/zynqmp-zc1751-xm017-dc3.dts b/arch/arm/dts/zynqmp-zc1751-xm017-dc3.dts index d6a010355bb8..2ead8dd24d57 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm017-dc3.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm017-dc3.dts @@ -76,7 +76,7 @@ status = "okay"; phy-handle = <&phy0>; phy-mode = "rgmii-id"; - phy0: phy@0 { /* VSC8211 */ + phy0: ethernet-phy@0 { /* VSC8211 */ reg = <0>; }; }; diff --git a/arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts b/arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts index 0632b18ccf00..12c0173c5599 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts @@ -73,7 +73,7 @@ status = "okay"; phy-handle = <&phy0>; phy-mode = "rgmii-id"; - phy0: phy@0 { + phy0: ethernet-phy@0 { reg = <0>; }; }; diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index 6e2287171313..e2a49a61cd15 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -110,7 +110,7 @@ status = "okay"; phy-handle = <&phy0>; phy-mode = "rgmii-id"; - phy0: phy@21 { + phy0: ethernet-phy@21 { reg = <21>; ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; diff --git a/arch/arm/dts/zynqmp-zcu102-revB.dts b/arch/arm/dts/zynqmp-zcu102-revB.dts index af4d86882a5c..08a4887401cf 100644 --- a/arch/arm/dts/zynqmp-zcu102-revB.dts +++ b/arch/arm/dts/zynqmp-zcu102-revB.dts @@ -16,7 +16,7 @@
&gem3 { phy-handle = <&phyc>; - phyc: phy@c { + phyc: ethernet-phy@c { reg = <0xc>; ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; diff --git a/arch/arm/dts/zynqmp-zcu104-revA.dts b/arch/arm/dts/zynqmp-zcu104-revA.dts index c7a3cdcf61df..3e63765c6b47 100644 --- a/arch/arm/dts/zynqmp-zcu104-revA.dts +++ b/arch/arm/dts/zynqmp-zcu104-revA.dts @@ -54,7 +54,7 @@ status = "okay"; phy-handle = <&phy0>; phy-mode = "rgmii-id"; - phy0: phy@c { + phy0: ethernet-phy@c { reg = <0xc>; ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; diff --git a/arch/arm/dts/zynqmp-zcu104-revC.dts b/arch/arm/dts/zynqmp-zcu104-revC.dts index 7df16b047ceb..8d8cabfcb280 100644 --- a/arch/arm/dts/zynqmp-zcu104-revC.dts +++ b/arch/arm/dts/zynqmp-zcu104-revC.dts @@ -55,7 +55,7 @@ status = "okay"; phy-handle = <&phy0>; phy-mode = "rgmii-id"; - phy0: phy@c { + phy0: ethernet-phy@c { reg = <0xc>; ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; diff --git a/arch/arm/dts/zynqmp-zcu106-revA.dts b/arch/arm/dts/zynqmp-zcu106-revA.dts index 9fd3953fb44b..74d501df38ba 100644 --- a/arch/arm/dts/zynqmp-zcu106-revA.dts +++ b/arch/arm/dts/zynqmp-zcu106-revA.dts @@ -110,7 +110,7 @@ status = "okay"; phy-handle = <&phy0>; phy-mode = "rgmii-id"; - phy0: phy@c { + phy0: ethernet-phy@c { reg = <0xc>; ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; diff --git a/arch/arm/dts/zynqmp-zcu111-revA.dts b/arch/arm/dts/zynqmp-zcu111-revA.dts index 2e28a3934fd3..d23e4ea156e5 100644 --- a/arch/arm/dts/zynqmp-zcu111-revA.dts +++ b/arch/arm/dts/zynqmp-zcu111-revA.dts @@ -106,7 +106,7 @@ status = "okay"; phy-handle = <&phy0>; phy-mode = "rgmii-id"; - phy0: phy@c { + phy0: ethernet-phy@c { reg = <0xc>; ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>;
ina226 hwmon driver is deprecated and it is recommended to use new iio based driver. The patch is enabling iio-hwmon driver to export functionality from IIO to hwmon interface to be able to use lm-sensors package.
arch/arm/dts/zynqmp-g-a2197-00-revA.dts | 43 +++++++++++++++++++++---- 1 file changed, 37 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts index 6e5a0d2c5be6..56d23b2b0894 100644 --- a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts @@ -38,6 +38,31 @@ device_type = "memory"; reg = <0x0 0x0 0x0 0x80000000>; }; + + ina226-u74 { + compatible = "iio-hwmon"; + io-channels = <&u74 0>, <&u74 1>, <&u74 2>, <&u74 3>; + }; + ina226-u75 { + compatible = "iio-hwmon"; + io-channels = <&u75 0>, <&u75 1>, <&u75 2>, <&u75 3>; + }; + ina226-u78 { + compatible = "iio-hwmon"; + io-channels = <&u78 0>, <&u78 1>, <&u78 2>, <&u78 3>; + }; + ina226-u79 { + compatible = "iio-hwmon"; + io-channels = <&u79 0>, <&u79 1>, <&u79 2>, <&u79 3>; + }; + ina226-u82 { + compatible = "iio-hwmon"; + io-channels = <&u82 0>, <&u82 1>, <&u82 2>, <&u82 3>; + }; + ina226-u84 { + compatible = "iio-hwmon"; + io-channels = <&u84 0>, <&u84 1>, <&u84 2>, <&u84 3>; + }; };
&sdhci0 { /* emmc MIO 13-23 16GB */ @@ -198,33 +223,39 @@ compatible = "ti,tps544b25"; reg = <0x20>; }; - ina226@40 { /* u74 */ + u74: ina226@40 { /* u74 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x40>; shunt-resistor = <1000>; }; - ina226@41 { /* u75 */ + u75: ina226@41 { /* u75 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x41>; shunt-resistor = <1000>; }; - ina226@42 { /* u78 */ + u78: ina226@42 { /* u78 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x42>; shunt-resistor = <5000>; }; - ina226@43 { /* u79 */ + u79: ina226@43 { /* u79 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x43>; shunt-resistor = <1000>; }; - ina226@44 { /* u82 */ + u82: ina226@44 { /* u82 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x44>; shunt-resistor = <1000>; }; - ina226@45 { /* u84 */ + u84: ina226@45 { /* u84 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x45>; shunt-resistor = <5000>; };
Label property is adding capability to distiguish chips from each other when iio framework is used.
arch/arm/dts/zynqmp-g-a2197-00-revA.dts | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts index 56d23b2b0894..3616ddc2a78c 100644 --- a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts @@ -226,36 +226,42 @@ u74: ina226@40 { /* u74 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u74"; reg = <0x40>; shunt-resistor = <1000>; }; u75: ina226@41 { /* u75 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u75"; reg = <0x41>; shunt-resistor = <1000>; }; u78: ina226@42 { /* u78 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u78"; reg = <0x42>; shunt-resistor = <5000>; }; u79: ina226@43 { /* u79 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u79"; reg = <0x43>; shunt-resistor = <1000>; }; u82: ina226@44 { /* u82 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u82"; reg = <0x44>; shunt-resistor = <1000>; }; u84: ina226@45 { /* u84 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u84"; reg = <0x45>; shunt-resistor = <5000>; };
tps53681 is i2c address 0x60 not 0xc0.
Signed-off-by: Nishant Mittal nishant.mittal@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynqmp-p-a2197-00-revA.dts | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts index 04d5fc9f933f..956a68da464c 100644 --- a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts @@ -155,9 +155,9 @@ compatible = "ti,tps544b25"; /* Documentation/hwmon/pmbus - wiring is missing */ reg = <0xa>; }; - reg_vccint: tps53681@c0 { /* u70 - FIXME name - don't know what it does - also vcc_io_soc */ + reg_vccint: tps53681@60 { /* u70 - FIXME name - don't know what it does - also vcc_io_soc */ compatible = "ti,tps53681"; /* FIXME no linux driver */ - reg = <0xc0>; + reg = <0x60>; /* vccint, vcc_io_soc */ }; };
Added tps53679 compatible string to tps53681. They are both compatible to each other and tps53679 has Linux driver already.
arch/arm/dts/zynqmp-g-a2197-00-revA.dts | 2 +- arch/arm/dts/zynqmp-m-a2197-01-revA.dts | 2 +- arch/arm/dts/zynqmp-p-a2197-00-revA.dts | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts index 3616ddc2a78c..09da60b10072 100644 --- a/arch/arm/dts/zynqmp-g-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-g-a2197-00-revA.dts @@ -266,7 +266,7 @@ shunt-resistor = <5000>; }; tps53681@c0 { /* u53 - FIXME name - don't know what it does - also vcc_io_soc */ - compatible = "ti,tps53681"; /* FIXME no linux driver */ + compatible = "ti,tps53681", "ti,tps53679"; reg = <0xc0>; }; }; diff --git a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts index 889491456aa4..4215b08bec8b 100644 --- a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts @@ -217,7 +217,7 @@ #size-cells = <0>; reg = <2>; reg_vccint: tps53681@c0 { /* u69 */ - compatible = "ti,tps53681"; /* FIXME no linux driver */ + compatible = "ti,tps53681", "ti,tps53679"; reg = <0xc0>; }; reg_vcc_pmc: tps544@7 { /* u80 */ diff --git a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts index 956a68da464c..bb9ecf8c6781 100644 --- a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts @@ -156,7 +156,7 @@ reg = <0xa>; }; reg_vccint: tps53681@60 { /* u70 - FIXME name - don't know what it does - also vcc_io_soc */ - compatible = "ti,tps53681"; /* FIXME no linux driver */ + compatible = "ti,tps53681", "ti,tps53679"; reg = <0x60>; /* vccint, vcc_io_soc */ };
Trivial fix but not detected by checkpatch.
arch/arm/dts/zynqmp-p-a2197-00-revA.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts index bb9ecf8c6781..26e127b2f264 100644 --- a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts @@ -165,7 +165,7 @@ #address-cells = <1>; #size-cells = <0>; reg = <1>; - /* FIXME check alerts comming to SC */ + /* FIXME check alerts coming to SC */ vcc_fmc: ina226@42 { /* u81 */ compatible = "ti,ina226"; reg = <0x42>;
arch/arm/dts/zynqmp-m-a2197-01-revA.dts | 31 +++++++++++++++++++++++++ 1 file changed, 31 insertions(+)
diff --git a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts index 4215b08bec8b..bfa86afddb28 100644 --- a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts @@ -43,6 +43,31 @@ device_type = "memory"; reg = <0x0 0x0 0x0 0x80000000>; /* FIXME don't know how big memory is there */ }; + + ina226-vcc-aux { + compatible = "iio-hwmon"; + io-channels = <&vcc_aux 0>, <&vcc_aux 1>, <&vcc_aux 2>, <&vcc_aux 3>; + }; + ina226-vcc-ram { + compatible = "iio-hwmon"; + io-channels = <&vcc_ram 0>, <&vcc_ram 1>, <&vcc_ram 2>, <&vcc_ram 3>; + }; + ina226-vcc1v1-lp4 { + compatible = "iio-hwmon"; + io-channels = <&vcc1v1_lp4 0>, <&vcc1v1_lp4 1>, <&vcc1v1_lp4 2>, <&vcc1v1_lp4 3>; + }; + ina226-vcc1v2-lp4 { + compatible = "iio-hwmon"; + io-channels = <&vcc1v2_lp4 0>, <&vcc1v2_lp4 1>, <&vcc1v2_lp4 2>, <&vcc1v2_lp4 3>; + }; + ina226-vdd1-1v8-lp4 { + compatible = "iio-hwmon"; + io-channels = <&vdd1_1v8_lp4 0>, <&vdd1_1v8_lp4 1>, <&vdd1_1v8_lp4 2>, <&vdd1_1v8_lp4 3>; + }; + ina226-vcc0v6-lp4 { + compatible = "iio-hwmon"; + io-channels = <&vcc0v6_lp4 0>, <&vcc0v6_lp4 1>, <&vcc0v6_lp4 2>, <&vcc0v6_lp4 3>; + }; };
&qspi { @@ -183,31 +208,37 @@ reg = <1>; vcc_aux: ina226@42 { /* u86 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x42>; shunt-resistor = <5000>; }; vcc_ram: ina226@43 { /* u81 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x43>; shunt-resistor = <5000>; }; vcc1v1_lp4: ina226@46 { /* u96 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x46>; shunt-resistor = <5000>; }; vcc1v2_lp4: ina226@47 { /* u98 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x47>; shunt-resistor = <5000>; }; vdd1_1v8_lp4: ina226@48 { /* u100 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x48>; shunt-resistor = <5000>; }; vcc0v6_lp4: ina226@49 { /* u101 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x49>; shunt-resistor = <5000>; };
arch/arm/dts/zynqmp-m-a2197-01-revA.dts | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts index bfa86afddb28..4e41b6dfde16 100644 --- a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts @@ -209,36 +209,42 @@ vcc_aux: ina226@42 { /* u86 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-vcc-aux"; reg = <0x42>; shunt-resistor = <5000>; }; vcc_ram: ina226@43 { /* u81 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-vcc-ram"; reg = <0x43>; shunt-resistor = <5000>; }; vcc1v1_lp4: ina226@46 { /* u96 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-vcc1v1-lp4"; reg = <0x46>; shunt-resistor = <5000>; }; vcc1v2_lp4: ina226@47 { /* u98 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-vcc1v2-lp4"; reg = <0x47>; shunt-resistor = <5000>; }; vdd1_1v8_lp4: ina226@48 { /* u100 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-vdd1-1v8-lp4"; reg = <0x48>; shunt-resistor = <5000>; }; vcc0v6_lp4: ina226@49 { /* u101 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-vcc0v6-lp4"; reg = <0x49>; shunt-resistor = <5000>; };
Mainline has done this switch and there is no reason not to switch it too.
Mainline U-Boot patch which has done that switch: "dts: switch spi-flash to jedec, spi-nor compatible" (sha1: ffd4c7c2ecb745586239eb98d5dc0fe5e6ebe3bd)
arch/arm/dts/zynqmp-m-a2197-01-revA.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts index 4e41b6dfde16..9bb4da6d9920 100644 --- a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts @@ -74,7 +74,7 @@ status = "okay"; is-dual = <1>; flash@0 { - compatible = "m25p80", "spi-flash"; /* 32MB */ + compatible = "m25p80", "jedec,spi-nor"; /* 32MB */ #address-cells = <1>; #size-cells = <1>; reg = <0x0>;
Remove some FIXMEs and align it with latest schematics.
arch/arm/dts/zynqmp-m-a2197-01-revA.dts | 23 +++++++++-------------- 1 file changed, 9 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts index 9bb4da6d9920..e295bac128cb 100644 --- a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts @@ -326,7 +326,7 @@ reg = <0x51>; };
- i2c-mux@74 { /* u35 */ + i2c-mux@74 { /* u47 */ compatible = "nxp,pca9548"; #address-cells = <1>; #size-cells = <0>; @@ -391,19 +391,14 @@ }; }; }; - i2c@1 { /* UTIL_PMBUS - FIXME incorrect schematics */ - #address-cells = <1>; - #size-cells = <0>; - /* reg = <1>; */ - }; i2c@2 { /* C0_LP4 */ #address-cells = <1>; #size-cells = <0>; reg = <2>; - si570_c0_lp4: clock-generator@5d { /* u10 */ + si570_c0_lp4: clock-generator@55 { /* u10 */ #clock-cells = <0>; compatible = "silabs,si570"; - reg = <0x5d>; /* FIXME addr */ + reg = <0x55>; temperature-stability = <50>; factory-fout = <30000000>; clock-frequency = <30000000>; @@ -428,10 +423,10 @@ #address-cells = <1>; #size-cells = <0>; reg = <4>; - si570_c2_lp4: clock-generator@5d { /* u10 */ + si570_c2_lp4: clock-generator@55 { /* u10 */ #clock-cells = <0>; compatible = "silabs,si570"; - reg = <0x5d>; /* FIXME addr */ + reg = <0x55>; temperature-stability = <50>; factory-fout = <30000000>; clock-frequency = <30000000>; @@ -442,10 +437,10 @@ #address-cells = <1>; #size-cells = <0>; reg = <5>; - si570_c3_lp4: clock-generator@5d { /* u15 */ + si570_c3_lp4: clock-generator@55 { /* u15 */ #clock-cells = <0>; compatible = "silabs,si570"; - reg = <0x5d>; /* FIXME addr */ + reg = <0x55>; temperature-stability = <50>; factory-fout = <30000000>; clock-frequency = <30000000>; @@ -461,8 +456,8 @@ compatible = "silabs,si570"; reg = <0x5d>; /* FIXME addr */ temperature-stability = <50>; - factory-fout = <156250000>; /* FIXME every chip can be different - 10MHZ_TO_810MHZ */ - clock-frequency = <33333333>; + factory-fout = <156250000>; + clock-frequency = <156250000>; clock-output-names = "HSDP_SI570"; }; };
Setup proper si570 names and default factory setup.
arch/arm/dts/zynqmp-p-a2197-00-revA.dts | 28 ++++++++++++------------- 1 file changed, 14 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts index 26e127b2f264..864263bd57df 100644 --- a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts @@ -387,9 +387,9 @@ compatible = "silabs,si570"; reg = <0x5d>; /* 570JAC000900DG */ temperature-stability = <50>; - factory-fout = <156250000>; /* FIXME every chip can be different */ + factory-fout = <33333333>; clock-frequency = <33333333>; - clock-output-names = "REF_CLK"; /* FIXME */ + clock-output-names = "ref_clk"; }; /* Connection via Samtec J212D */ /* Use for storing information about X-PRC card */ @@ -455,9 +455,9 @@ compatible = "silabs,si570"; reg = <0x60>; /* 570BAB000299DG */ temperature-stability = <50>; - factory-fout = <156250000>; /* FIXME every chip can be different - 10MHZ_TO_810MHZ */ - clock-frequency = <33333333>; - clock-output-names = "REF_CLK"; /* FIXME */ + factory-fout = <200000000>; + clock-frequency = <200000000>; + clock-output-names = "si570_ddrdimm1_clk"; }; /* 0x50 SPD? */ }; @@ -470,9 +470,9 @@ compatible = "silabs,si570"; reg = <0x60>; /* 570BAB000299DG */ temperature-stability = <50>; - factory-fout = <156250000>; /* FIXME every chip can be different - 10MHZ_TO_810MHZ */ - clock-frequency = <33333333>; - clock-output-names = "REF_CLK"; /* FIXME */ + factory-fout = <200000000>; + clock-frequency = <200000000>; + clock-output-names = "si570_ddrdimm2_clk"; }; /* 0x50 SPD? */ }; @@ -485,9 +485,9 @@ compatible = "silabs,si570"; reg = <0x60>; /* 570BAB000299DG */ temperature-stability = <50>; - factory-fout = <156250000>; /* FIXME every chip can be different - 10MHZ_TO_810MHZ */ - clock-frequency = <33333333>; - clock-output-names = "LPDDR4_SI570_CLK"; + factory-fout = <200000000>; + clock-frequency = <200000000>; + clock-output-names = "si570_lpddr4_clk"; }; }; i2c@6 { /* HSDP_SI570 */ @@ -499,9 +499,9 @@ compatible = "silabs,si570"; reg = <0x5d>; /* 570JAC000900DG */ temperature-stability = <50>; - factory-fout = <156250000>; /* FIXME every chip can be different - 10MHZ_TO_810MHZ */ - clock-frequency = <33333333>; - clock-output-names = "HSDP_SI570"; + factory-fout = <156250000>; + clock-frequency = <156250000>; + clock-output-names = "si570_hsdp_clk"; }; }; i2c@7 { /* PCIE_CLK */
System controller has 2GB of memory and fixme can be removed now.
diff --git a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts index 864263bd57df..d49b632a1d3c 100644 --- a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts @@ -41,7 +41,7 @@
memory@0 { device_type = "memory"; - reg = <0x0 0x0 0x0 0x80000000>; /* FIXME don't know how big memory is there */ + reg = <0x0 0x0 0x0 0x80000000>; }; };
Currently zcu102 Rev1.0 board includes RevA sdhci dt node which has no-1-8-v property. Since Rev1.0 has level shifters delete this property to enable support for 1.8v.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynqmp-zcu102-rev1.0.dts | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/zynqmp-zcu102-rev1.0.dts b/arch/arm/dts/zynqmp-zcu102-rev1.0.dts index 6647e97edba3..6c702f2674e3 100644 --- a/arch/arm/dts/zynqmp-zcu102-rev1.0.dts +++ b/arch/arm/dts/zynqmp-zcu102-rev1.0.dts @@ -34,3 +34,7 @@ reg = <0xe0 0x3>; }; }; + +&sdhci1 { + /delete-property/ no-1-8-v; +};
arch/arm/dts/zynqmp-zcu111-revA.dts | 99 +++++++++++++++++++++++++---- 1 file changed, 85 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/zynqmp-zcu111-revA.dts b/arch/arm/dts/zynqmp-zcu111-revA.dts index d23e4ea156e5..e0e955cb8efa 100644 --- a/arch/arm/dts/zynqmp-zcu111-revA.dts +++ b/arch/arm/dts/zynqmp-zcu111-revA.dts @@ -64,6 +64,63 @@ linux,default-trigger = "heartbeat"; }; }; + + ina226-u67 { + compatible = "iio-hwmon"; + io-channels = <&u67 0>, <&u67 1>, <&u67 2>, <&u67 3>; + }; + ina226-u59 { + compatible = "iio-hwmon"; + io-channels = <&u59 0>, <&u59 1>, <&u59 2>, <&u59 3>; + }; + ina226-u61 { + compatible = "iio-hwmon"; + io-channels = <&u61 0>, <&u61 1>, <&u61 2>, <&u61 3>; + }; + ina226-u60 { + compatible = "iio-hwmon"; + io-channels = <&u60 0>, <&u60 1>, <&u60 2>, <&u60 3>; + }; + ina226-u64 { + compatible = "iio-hwmon"; + io-channels = <&u64 0>, <&u64 1>, <&u64 2>, <&u64 3>; + }; + ina226-u69 { + compatible = "iio-hwmon"; + io-channels = <&u69 0>, <&u69 1>, <&u69 2>, <&u69 3>; + }; + ina226-u66 { + compatible = "iio-hwmon"; + io-channels = <&u66 0>, <&u66 1>, <&u66 2>, <&u66 3>; + }; + ina226-u65 { + compatible = "iio-hwmon"; + io-channels = <&u65 0>, <&u65 1>, <&u65 2>, <&u65 3>; + }; + ina226-u63 { + compatible = "iio-hwmon"; + io-channels = <&u63 0>, <&u63 1>, <&u63 2>, <&u63 3>; + }; + ina226-u3 { + compatible = "iio-hwmon"; + io-channels = <&u3 0>, <&u3 1>, <&u3 2>, <&u3 3>; + }; + ina226-u71 { + compatible = "iio-hwmon"; + io-channels = <&u71 0>, <&u71 1>, <&u71 2>, <&u71 3>; + }; + ina226-u77 { + compatible = "iio-hwmon"; + io-channels = <&u77 0>, <&u77 1>, <&u77 2>, <&u77 3>; + }; + ina226-u73 { + compatible = "iio-hwmon"; + io-channels = <&u73 0>, <&u73 1>, <&u73 2>, <&u73 3>; + }; + ina226-u79 { + compatible = "iio-hwmon"; + io-channels = <&u79 0>, <&u79 1>, <&u79 2>, <&u79 3>; + }; };
&dcc { @@ -160,73 +217,87 @@ reg = <0>; /* PS_PMBUS */ /* PMBUS_ALERT done via pca9544 */ - ina226@40 { /* u67 */ + u67: ina226@40 { /* u67 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x40>; shunt-resistor = <2000>; }; - ina226@41 { /* u59 */ + u59: ina226@41 { /* u59 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x41>; shunt-resistor = <5000>; }; - ina226@42 { /* u61 */ + u61: ina226@42 { /* u61 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x42>; shunt-resistor = <5000>; }; - ina226@43 { /* u60 */ + u60: ina226@43 { /* u60 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x43>; shunt-resistor = <5000>; }; - ina226@45 { /* u64 */ + u64: ina226@45 { /* u64 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x45>; shunt-resistor = <5000>; }; - ina226@46 { /* u69 */ + u69: ina226@46 { /* u69 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x46>; shunt-resistor = <2000>; }; - ina226@47 { /* u66 */ + u66: ina226@47 { /* u66 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x47>; shunt-resistor = <5000>; }; - ina226@48 { /* u65 */ + u65: ina226@48 { /* u65 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x48>; shunt-resistor = <5000>; }; - ina226@49 { /* u63 */ + u63: ina226@49 { /* u63 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x49>; shunt-resistor = <5000>; }; - ina226@4a { /* u3 */ + u3: ina226@4a { /* u3 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x4a>; shunt-resistor = <5000>; }; - ina226@4b { /* u71 */ + u71: ina226@4b { /* u71 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x4b>; shunt-resistor = <5000>; }; - ina226@4c { /* u77 */ + u77: ina226@4c { /* u77 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x4c>; shunt-resistor = <5000>; }; - ina226@4d { /* u73 */ + u73: ina226@4d { /* u73 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x4d>; shunt-resistor = <5000>; }; - ina226@4e { /* u79 */ + u79: ina226@4e { /* u79 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x4e>; shunt-resistor = <5000>; };
arch/arm/dts/zynqmp-zcu111-revA.dts | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/arch/arm/dts/zynqmp-zcu111-revA.dts b/arch/arm/dts/zynqmp-zcu111-revA.dts index e0e955cb8efa..62fd2b47156d 100644 --- a/arch/arm/dts/zynqmp-zcu111-revA.dts +++ b/arch/arm/dts/zynqmp-zcu111-revA.dts @@ -220,84 +220,98 @@ u67: ina226@40 { /* u67 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u67"; reg = <0x40>; shunt-resistor = <2000>; }; u59: ina226@41 { /* u59 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u59"; reg = <0x41>; shunt-resistor = <5000>; }; u61: ina226@42 { /* u61 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u61"; reg = <0x42>; shunt-resistor = <5000>; }; u60: ina226@43 { /* u60 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u60"; reg = <0x43>; shunt-resistor = <5000>; }; u64: ina226@45 { /* u64 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u64"; reg = <0x45>; shunt-resistor = <5000>; }; u69: ina226@46 { /* u69 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u69"; reg = <0x46>; shunt-resistor = <2000>; }; u66: ina226@47 { /* u66 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u66"; reg = <0x47>; shunt-resistor = <5000>; }; u65: ina226@48 { /* u65 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u65"; reg = <0x48>; shunt-resistor = <5000>; }; u63: ina226@49 { /* u63 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u63"; reg = <0x49>; shunt-resistor = <5000>; }; u3: ina226@4a { /* u3 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u3"; reg = <0x4a>; shunt-resistor = <5000>; }; u71: ina226@4b { /* u71 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u71"; reg = <0x4b>; shunt-resistor = <5000>; }; u77: ina226@4c { /* u77 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u77"; reg = <0x4c>; shunt-resistor = <5000>; }; u73: ina226@4d { /* u73 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u73"; reg = <0x4d>; shunt-resistor = <5000>; }; u79: ina226@4e { /* u79 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u79"; reg = <0x4e>; shunt-resistor = <5000>; };
From: Venkatesh Yadav Abbarapu venkatesh.abbarapu@xilinx.com
The si570 clock frequency should be 156.25MHz as per datasheet.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynqmp-zcu111-revA.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp-zcu111-revA.dts b/arch/arm/dts/zynqmp-zcu111-revA.dts index 62fd2b47156d..c651a283b3d8 100644 --- a/arch/arm/dts/zynqmp-zcu111-revA.dts +++ b/arch/arm/dts/zynqmp-zcu111-revA.dts @@ -417,7 +417,7 @@ reg = <0x5d>; temperature-stability = <50>; factory-fout = <156250000>; - clock-frequency = <148500000>; + clock-frequency = <156250000>; clock-output-names = "si570_mgt"; }; };
arch/arm/dts/zynqmp-zcu106-revA.dts | 127 ++++++++++++++++++++++++---- 1 file changed, 109 insertions(+), 18 deletions(-)
diff --git a/arch/arm/dts/zynqmp-zcu106-revA.dts b/arch/arm/dts/zynqmp-zcu106-revA.dts index 74d501df38ba..1d452e835909 100644 --- a/arch/arm/dts/zynqmp-zcu106-revA.dts +++ b/arch/arm/dts/zynqmp-zcu106-revA.dts @@ -64,6 +64,79 @@ linux,default-trigger = "heartbeat"; }; }; + + ina226-u76 { + compatible = "iio-hwmon"; + io-channels = <&u76 0>, <&u76 1>, <&u76 2>, <&u76 3>; + }; + ina226-u77 { + compatible = "iio-hwmon"; + io-channels = <&u77 0>, <&u77 1>, <&u77 2>, <&u77 3>; + }; + ina226-u78 { + compatible = "iio-hwmon"; + io-channels = <&u78 0>, <&u78 1>, <&u78 2>, <&u78 3>; + }; + ina226-u87 { + compatible = "iio-hwmon"; + io-channels = <&u87 0>, <&u87 1>, <&u87 2>, <&u87 3>; + }; + ina226-u85 { + compatible = "iio-hwmon"; + io-channels = <&u85 0>, <&u85 1>, <&u85 2>, <&u85 3>; + }; + ina226-u86 { + compatible = "iio-hwmon"; + io-channels = <&u86 0>, <&u86 1>, <&u86 2>, <&u86 3>; + }; + ina226-u93 { + compatible = "iio-hwmon"; + io-channels = <&u93 0>, <&u93 1>, <&u93 2>, <&u93 3>; + }; + ina226-u88 { + compatible = "iio-hwmon"; + io-channels = <&u88 0>, <&u88 1>, <&u88 2>, <&u88 3>; + }; + ina226-u15 { + compatible = "iio-hwmon"; + io-channels = <&u15 0>, <&u15 1>, <&u15 2>, <&u15 3>; + }; + ina226-u92 { + compatible = "iio-hwmon"; + io-channels = <&u92 0>, <&u92 1>, <&u92 2>, <&u92 3>; + }; + ina226-u79 { + compatible = "iio-hwmon"; + io-channels = <&u79 0>, <&u79 1>, <&u79 2>, <&u79 3>; + }; + ina226-u81 { + compatible = "iio-hwmon"; + io-channels = <&u81 0>, <&u81 1>, <&u81 2>, <&u81 3>; + }; + ina226-u80 { + compatible = "iio-hwmon"; + io-channels = <&u80 0>, <&u80 1>, <&u80 2>, <&u80 3>; + }; + ina226-u84 { + compatible = "iio-hwmon"; + io-channels = <&u84 0>, <&u84 1>, <&u84 2>, <&u84 3>; + }; + ina226-u16 { + compatible = "iio-hwmon"; + io-channels = <&u16 0>, <&u16 1>, <&u16 2>, <&u16 3>; + }; + ina226-u65 { + compatible = "iio-hwmon"; + io-channels = <&u65 0>, <&u65 1>, <&u65 2>, <&u65 3>; + }; + ina226-u74 { + compatible = "iio-hwmon"; + io-channels = <&u74 0>, <&u74 1>, <&u74 2>, <&u74 3>; + }; + ina226-u75 { + compatible = "iio-hwmon"; + io-channels = <&u75 0>, <&u75 1>, <&u75 2>, <&u75 3>; + }; };
&can1 { @@ -184,53 +257,63 @@ #size-cells = <0>; reg = <0>; /* PS_PMBUS */ - ina226@40 { /* u76 */ + u76: ina226@40 { /* u76 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x40>; shunt-resistor = <5000>; }; - ina226@41 { /* u77 */ + u77: ina226@41 { /* u77 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x41>; shunt-resistor = <5000>; }; - ina226@42 { /* u78 */ + u78: ina226@42 { /* u78 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x42>; shunt-resistor = <5000>; }; - ina226@43 { /* u87 */ + u87: ina226@43 { /* u87 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x43>; shunt-resistor = <5000>; }; - ina226@44 { /* u85 */ + u85: ina226@44 { /* u85 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x44>; shunt-resistor = <5000>; }; - ina226@45 { /* u86 */ + u86: ina226@45 { /* u86 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x45>; shunt-resistor = <5000>; }; - ina226@46 { /* u93 */ + u93: ina226@46 { /* u93 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x46>; shunt-resistor = <5000>; }; - ina226@47 { /* u88 */ + u88: ina226@47 { /* u88 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x47>; shunt-resistor = <5000>; }; - ina226@4a { /* u15 */ + u15: ina226@4a { /* u15 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x4a>; shunt-resistor = <5000>; }; - ina226@4b { /* u92 */ + u92: ina226@4b { /* u92 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x4b>; shunt-resistor = <5000>; }; @@ -240,43 +323,51 @@ #size-cells = <0>; reg = <1>; /* PL_PMBUS */ - ina226@40 { /* u79 */ + u79: ina226@40 { /* u79 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x40>; shunt-resistor = <2000>; }; - ina226@41 { /* u81 */ + u81: ina226@41 { /* u81 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x41>; shunt-resistor = <5000>; }; - ina226@42 { /* u80 */ + u80: ina226@42 { /* u80 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x42>; shunt-resistor = <5000>; }; - ina226@43 { /* u84 */ + u84: ina226@43 { /* u84 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x43>; shunt-resistor = <5000>; }; - ina226@44 { /* u16 */ + u16: ina226@44 { /* u16 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x44>; shunt-resistor = <5000>; }; - ina226@45 { /* u65 */ + u65: ina226@45 { /* u65 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x45>; shunt-resistor = <5000>; }; - ina226@46 { /* u74 */ + u74: ina226@46 { /* u74 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x46>; shunt-resistor = <5000>; }; - ina226@47 { /* u75 */ + u75: ina226@47 { /* u75 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x47>; shunt-resistor = <5000>; };
arch/arm/dts/zynqmp-zcu106-revA.dts | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/arm/dts/zynqmp-zcu106-revA.dts b/arch/arm/dts/zynqmp-zcu106-revA.dts index 1d452e835909..18a403288f9d 100644 --- a/arch/arm/dts/zynqmp-zcu106-revA.dts +++ b/arch/arm/dts/zynqmp-zcu106-revA.dts @@ -260,60 +260,70 @@ u76: ina226@40 { /* u76 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u76"; reg = <0x40>; shunt-resistor = <5000>; }; u77: ina226@41 { /* u77 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u77"; reg = <0x41>; shunt-resistor = <5000>; }; u78: ina226@42 { /* u78 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u78"; reg = <0x42>; shunt-resistor = <5000>; }; u87: ina226@43 { /* u87 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u87"; reg = <0x43>; shunt-resistor = <5000>; }; u85: ina226@44 { /* u85 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u85"; reg = <0x44>; shunt-resistor = <5000>; }; u86: ina226@45 { /* u86 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u86"; reg = <0x45>; shunt-resistor = <5000>; }; u93: ina226@46 { /* u93 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u93"; reg = <0x46>; shunt-resistor = <5000>; }; u88: ina226@47 { /* u88 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u88"; reg = <0x47>; shunt-resistor = <5000>; }; u15: ina226@4a { /* u15 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u15"; reg = <0x4a>; shunt-resistor = <5000>; }; u92: ina226@4b { /* u92 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u92"; reg = <0x4b>; shunt-resistor = <5000>; }; @@ -326,48 +336,56 @@ u79: ina226@40 { /* u79 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u79"; reg = <0x40>; shunt-resistor = <2000>; }; u81: ina226@41 { /* u81 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u81"; reg = <0x41>; shunt-resistor = <5000>; }; u80: ina226@42 { /* u80 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u80"; reg = <0x42>; shunt-resistor = <5000>; }; u84: ina226@43 { /* u84 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u84"; reg = <0x43>; shunt-resistor = <5000>; }; u16: ina226@44 { /* u16 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u16"; reg = <0x44>; shunt-resistor = <5000>; }; u65: ina226@45 { /* u65 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u65"; reg = <0x45>; shunt-resistor = <5000>; }; u74: ina226@46 { /* u74 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u74"; reg = <0x46>; shunt-resistor = <5000>; }; u75: ina226@47 { /* u75 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u75"; reg = <0x47>; shunt-resistor = <5000>; };
arch/arm/dts/zynqmp-zcu104-revC.dts | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp-zcu104-revC.dts b/arch/arm/dts/zynqmp-zcu104-revC.dts index 8d8cabfcb280..4044eea12711 100644 --- a/arch/arm/dts/zynqmp-zcu104-revC.dts +++ b/arch/arm/dts/zynqmp-zcu104-revC.dts @@ -41,6 +41,11 @@ device_type = "memory"; reg = <0x0 0x0 0x0 0x80000000>; }; + + ina226 { + compatible = "iio-hwmon"; + io-channels = <&u183 0>, <&u183 1>, <&u183 2>, <&u183 3>; + }; };
&can1 { @@ -150,8 +155,9 @@ #address-cells = <1>; #size-cells = <0>; reg = <3>; - ina226@40 { /* u183 */ + u183: ina226@40 { /* u183 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x40>; shunt-resistor = <5000>; };
Enable fpd_dma for these boards.
arch/arm/dts/zynqmp-zcu104-revA.dts | 32 +++++++++++++++++++++++++++++ arch/arm/dts/zynqmp-zcu104-revC.dts | 32 +++++++++++++++++++++++++++++ 2 files changed, 64 insertions(+)
diff --git a/arch/arm/dts/zynqmp-zcu104-revA.dts b/arch/arm/dts/zynqmp-zcu104-revA.dts index 3e63765c6b47..0fed4acc1531 100644 --- a/arch/arm/dts/zynqmp-zcu104-revA.dts +++ b/arch/arm/dts/zynqmp-zcu104-revA.dts @@ -50,6 +50,38 @@ status = "okay"; };
+&fpd_dma_chan1 { + status = "okay"; +}; + +&fpd_dma_chan2 { + status = "okay"; +}; + +&fpd_dma_chan3 { + status = "okay"; +}; + +&fpd_dma_chan4 { + status = "okay"; +}; + +&fpd_dma_chan5 { + status = "okay"; +}; + +&fpd_dma_chan6 { + status = "okay"; +}; + +&fpd_dma_chan7 { + status = "okay"; +}; + +&fpd_dma_chan8 { + status = "okay"; +}; + &gem3 { status = "okay"; phy-handle = <&phy0>; diff --git a/arch/arm/dts/zynqmp-zcu104-revC.dts b/arch/arm/dts/zynqmp-zcu104-revC.dts index 4044eea12711..39b6cf109a42 100644 --- a/arch/arm/dts/zynqmp-zcu104-revC.dts +++ b/arch/arm/dts/zynqmp-zcu104-revC.dts @@ -56,6 +56,38 @@ status = "okay"; };
The DP83867 strap control workaround is already present in Linux kernel mainline binding. All these Xilinx boards require this quirk.
Signed-off-by: Harini Katakam harini.katakam@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts | 1 + arch/arm/dts/zynqmp-zcu102-revA.dts | 1 + arch/arm/dts/zynqmp-zcu102-revB.dts | 1 + arch/arm/dts/zynqmp-zcu104-revA.dts | 1 + arch/arm/dts/zynqmp-zcu104-revC.dts | 1 + arch/arm/dts/zynqmp-zcu106-revA.dts | 1 + arch/arm/dts/zynqmp-zcu111-revA.dts | 1 + 7 files changed, 7 insertions(+)
diff --git a/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts b/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts index b8cc5ed22e61..1cc469d93fb5 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts @@ -90,6 +90,7 @@ ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; }; };
diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index e2a49a61cd15..0a6bd8542a66 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -115,6 +115,7 @@ ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; }; };
diff --git a/arch/arm/dts/zynqmp-zcu102-revB.dts b/arch/arm/dts/zynqmp-zcu102-revB.dts index 08a4887401cf..05df542c0bf7 100644 --- a/arch/arm/dts/zynqmp-zcu102-revB.dts +++ b/arch/arm/dts/zynqmp-zcu102-revB.dts @@ -21,6 +21,7 @@ ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; }; /* Cleanup from RevA */ /delete-node/ phy@21; diff --git a/arch/arm/dts/zynqmp-zcu104-revA.dts b/arch/arm/dts/zynqmp-zcu104-revA.dts index 0fed4acc1531..82557c88d21c 100644 --- a/arch/arm/dts/zynqmp-zcu104-revA.dts +++ b/arch/arm/dts/zynqmp-zcu104-revA.dts @@ -91,6 +91,7 @@ ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; }; };
diff --git a/arch/arm/dts/zynqmp-zcu104-revC.dts b/arch/arm/dts/zynqmp-zcu104-revC.dts index 39b6cf109a42..e0e7dac010c5 100644 --- a/arch/arm/dts/zynqmp-zcu104-revC.dts +++ b/arch/arm/dts/zynqmp-zcu104-revC.dts @@ -97,6 +97,7 @@ ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; }; };
diff --git a/arch/arm/dts/zynqmp-zcu106-revA.dts b/arch/arm/dts/zynqmp-zcu106-revA.dts index 18a403288f9d..b4dd10133008 100644 --- a/arch/arm/dts/zynqmp-zcu106-revA.dts +++ b/arch/arm/dts/zynqmp-zcu106-revA.dts @@ -188,6 +188,7 @@ ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; }; };
diff --git a/arch/arm/dts/zynqmp-zcu111-revA.dts b/arch/arm/dts/zynqmp-zcu111-revA.dts index c651a283b3d8..aabf73dd6dc9 100644 --- a/arch/arm/dts/zynqmp-zcu111-revA.dts +++ b/arch/arm/dts/zynqmp-zcu111-revA.dts @@ -168,6 +168,7 @@ ti,rx-internal-delay = <0x8>; ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; }; };
Add gpio phy reset via I2C expander TCA6416 on board ZCU102. A warning call trace is observer in probe when this reset is called from context that can sleep. Keep this commented until that is resolved in phylib.
arch/arm/dts/zynqmp-zcu102-revA.dts | 1 + arch/arm/dts/zynqmp-zcu102-revB.dts | 1 + 2 files changed, 2 insertions(+)
diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index 0a6bd8542a66..3efb2b95e323 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -116,6 +116,7 @@ ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; ti,dp83867-rxctrl-strap-quirk; + /* reset-gpios = <&tca6416_u97 6 GPIO_ACTIVE_LOW>; */ }; };
diff --git a/arch/arm/dts/zynqmp-zcu102-revB.dts b/arch/arm/dts/zynqmp-zcu102-revB.dts index 05df542c0bf7..2132024a253d 100644 --- a/arch/arm/dts/zynqmp-zcu102-revB.dts +++ b/arch/arm/dts/zynqmp-zcu102-revB.dts @@ -22,6 +22,7 @@ ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; ti,dp83867-rxctrl-strap-quirk; + /* reset-gpios = <&tca6416_u97 6 GPIO_ACTIVE_LOW>; */ }; /* Cleanup from RevA */ /delete-node/ phy@21;
arch/arm/dts/zynqmp-zcu102-revA.dts | 127 ++++++++++++++++++++++++---- 1 file changed, 109 insertions(+), 18 deletions(-)
diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index 3efb2b95e323..e05357fd6b90 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -64,6 +64,79 @@ linux,default-trigger = "heartbeat"; }; }; + + ina226-u76 { + compatible = "iio-hwmon"; + io-channels = <&u76 0>, <&u76 1>, <&u76 2>, <&u76 3>; + }; + ina226-u77 { + compatible = "iio-hwmon"; + io-channels = <&u77 0>, <&u77 1>, <&u77 2>, <&u77 3>; + }; + ina226-u78 { + compatible = "iio-hwmon"; + io-channels = <&u78 0>, <&u78 1>, <&u78 2>, <&u78 3>; + }; + ina226-u87 { + compatible = "iio-hwmon"; + io-channels = <&u87 0>, <&u87 1>, <&u87 2>, <&u87 3>; + }; + ina226-u85 { + compatible = "iio-hwmon"; + io-channels = <&u85 0>, <&u85 1>, <&u85 2>, <&u85 3>; + }; + ina226-u86 { + compatible = "iio-hwmon"; + io-channels = <&u86 0>, <&u86 1>, <&u86 2>, <&u86 3>; + }; + ina226-u93 { + compatible = "iio-hwmon"; + io-channels = <&u93 0>, <&u93 1>, <&u93 2>, <&u93 3>; + }; + ina226-u88 { + compatible = "iio-hwmon"; + io-channels = <&u88 0>, <&u88 1>, <&u88 2>, <&u88 3>; + }; + ina226-u15 { + compatible = "iio-hwmon"; + io-channels = <&u15 0>, <&u15 1>, <&u15 2>, <&u15 3>; + }; + ina226-u92 { + compatible = "iio-hwmon"; + io-channels = <&u92 0>, <&u92 1>, <&u92 2>, <&u92 3>; + }; + ina226-u79 { + compatible = "iio-hwmon"; + io-channels = <&u79 0>, <&u79 1>, <&u79 2>, <&u79 3>; + }; + ina226-u81 { + compatible = "iio-hwmon"; + io-channels = <&u81 0>, <&u81 1>, <&u81 2>, <&u81 3>; + }; + ina226-u80 { + compatible = "iio-hwmon"; + io-channels = <&u80 0>, <&u80 1>, <&u80 2>, <&u80 3>; + }; + ina226-u84 { + compatible = "iio-hwmon"; + io-channels = <&u84 0>, <&u84 1>, <&u84 2>, <&u84 3>; + }; + ina226-u16 { + compatible = "iio-hwmon"; + io-channels = <&u16 0>, <&u16 1>, <&u16 2>, <&u16 3>; + }; + ina226-u65 { + compatible = "iio-hwmon"; + io-channels = <&u65 0>, <&u65 1>, <&u65 2>, <&u65 3>; + }; + ina226-u74 { + compatible = "iio-hwmon"; + io-channels = <&u74 0>, <&u74 1>, <&u74 2>, <&u74 3>; + }; + ina226-u75 { + compatible = "iio-hwmon"; + io-channels = <&u75 0>, <&u75 1>, <&u75 2>, <&u75 3>; + }; };
&can1 { @@ -212,53 +285,63 @@ #size-cells = <0>; reg = <0>; /* PS_PMBUS */ - ina226@40 { /* u76 */ + u76: ina226@40 { /* u76 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x40>; shunt-resistor = <5000>; }; - ina226@41 { /* u77 */ + u77: ina226@41 { /* u77 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x41>; shunt-resistor = <5000>; }; - ina226@42 { /* u78 */ + u78: ina226@42 { /* u78 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x42>; shunt-resistor = <5000>; }; - ina226@43 { /* u87 */ + u87: ina226@43 { /* u87 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x43>; shunt-resistor = <5000>; }; - ina226@44 { /* u85 */ + u85: ina226@44 { /* u85 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x44>; shunt-resistor = <5000>; }; - ina226@45 { /* u86 */ + u86: ina226@45 { /* u86 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x45>; shunt-resistor = <5000>; }; - ina226@46 { /* u93 */ + u93: ina226@46 { /* u93 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x46>; shunt-resistor = <5000>; }; - ina226@47 { /* u88 */ + u88: ina226@47 { /* u88 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x47>; shunt-resistor = <5000>; }; - ina226@4a { /* u15 */ + u15: ina226@4a { /* u15 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x4a>; shunt-resistor = <5000>; }; - ina226@4b { /* u92 */ + u92: ina226@4b { /* u92 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x4b>; shunt-resistor = <5000>; }; @@ -268,43 +351,51 @@ #size-cells = <0>; reg = <1>; /* PL_PMBUS */ - ina226@40 { /* u79 */ + u79: ina226@40 { /* u79 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x40>; shunt-resistor = <2000>; }; - ina226@41 { /* u81 */ + u81: ina226@41 { /* u81 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x41>; shunt-resistor = <5000>; }; - ina226@42 { /* u80 */ + u80: ina226@42 { /* u80 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x42>; shunt-resistor = <5000>; }; - ina226@43 { /* u84 */ + u84: ina226@43 { /* u84 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x43>; shunt-resistor = <5000>; }; - ina226@44 { /* u16 */ + u16: ina226@44 { /* u16 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x44>; shunt-resistor = <5000>; }; - ina226@45 { /* u65 */ + u65: ina226@45 { /* u65 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x45>; shunt-resistor = <5000>; }; - ina226@46 { /* u74 */ + u74: ina226@46 { /* u74 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x46>; shunt-resistor = <5000>; }; - ina226@47 { /* u75 */ + u75: ina226@47 { /* u75 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x47>; shunt-resistor = <5000>; };
arch/arm/dts/zynqmp-zcu102-revA.dts | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index e05357fd6b90..5babbf8ac59f 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -288,60 +288,70 @@ u76: ina226@40 { /* u76 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u76"; reg = <0x40>; shunt-resistor = <5000>; }; u77: ina226@41 { /* u77 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u77"; reg = <0x41>; shunt-resistor = <5000>; }; u78: ina226@42 { /* u78 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u78"; reg = <0x42>; shunt-resistor = <5000>; }; u87: ina226@43 { /* u87 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u87"; reg = <0x43>; shunt-resistor = <5000>; }; u85: ina226@44 { /* u85 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u85"; reg = <0x44>; shunt-resistor = <5000>; }; u86: ina226@45 { /* u86 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u86"; reg = <0x45>; shunt-resistor = <5000>; }; u93: ina226@46 { /* u93 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u93"; reg = <0x46>; shunt-resistor = <5000>; }; u88: ina226@47 { /* u88 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u88"; reg = <0x47>; shunt-resistor = <5000>; }; u15: ina226@4a { /* u15 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u15"; reg = <0x4a>; shunt-resistor = <5000>; }; u92: ina226@4b { /* u92 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u92"; reg = <0x4b>; shunt-resistor = <5000>; }; @@ -354,48 +364,56 @@ u79: ina226@40 { /* u79 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u79"; reg = <0x40>; shunt-resistor = <2000>; }; u81: ina226@41 { /* u81 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u81"; reg = <0x41>; shunt-resistor = <5000>; }; u80: ina226@42 { /* u80 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u80"; reg = <0x42>; shunt-resistor = <5000>; }; u84: ina226@43 { /* u84 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u84"; reg = <0x43>; shunt-resistor = <5000>; }; u16: ina226@44 { /* u16 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u16"; reg = <0x44>; shunt-resistor = <5000>; }; u65: ina226@45 { /* u65 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u65"; reg = <0x45>; shunt-resistor = <5000>; }; u74: ina226@46 { /* u74 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u74"; reg = <0x46>; shunt-resistor = <5000>; }; u75: ina226@47 { /* u75 */ compatible = "ti,ina226"; #io-channel-cells = <1>; + label = "ina226-u75"; reg = <0x47>; shunt-resistor = <5000>; };
Label gpio lines properly.
arch/arm/dts/zynqmp-zcu102-revA.dts | 43 ++++++----------------------- 1 file changed, 9 insertions(+), 34 deletions(-)
diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index 5babbf8ac59f..78110c490e8d 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -208,21 +208,11 @@ tca6416_u97: gpio@20 { compatible = "ti,tca6416"; reg = <0x20>; - gpio-controller; + gpio-controller; /* IRQ not connected */ #gpio-cells = <2>; - /* - * IRQ not connected - * Lines: - * 0 - PS_GTR_LAN_SEL0 - * 1 - PS_GTR_LAN_SEL1 - * 2 - PS_GTR_LAN_SEL2 - * 3 - PS_GTR_LAN_SEL3 - * 4 - PCI_CLK_DIR_SEL - * 5 - IIC_MUX_RESET_B - * 6 - GEM3_EXP_RESET_B - * 7, 10 - 17 - not connected - */ - + gpio-line-names = "PS_GTR_LAN_SEL0", "PS_GTR_LAN_SEL1", "PS_GTR_LAN_SEL2", "PS_GTR_LAN_SEL3", + "PCI_CLK_DIR_SEL", "IIC_MUX_RESET_B", "GEM3_EXP_RESET_B", + "", "", "", "", "", "", "", "", ""; gtr_sel0 { gpio-hog; gpios = <0 0>; @@ -252,27 +242,12 @@ tca6416_u61: gpio@21 { compatible = "ti,tca6416"; reg = <0x21>; - gpio-controller; + gpio-controller; /* IRQ not connected */ #gpio-cells = <2>; - /* - * IRQ not connected - * Lines: - * 0 - VCCPSPLL_EN - * 1 - MGTRAVCC_EN - * 2 - MGTRAVTT_EN - * 3 - VCCPSDDRPLL_EN - * 4 - MIO26_PMU_INPUT_LS - * 5 - PL_PMBUS_ALERT - * 6 - PS_PMBUS_ALERT - * 7 - MAXIM_PMBUS_ALERT - * 10 - PL_DDR4_VTERM_EN - * 11 - PL_DDR4_VPP_2V5_EN - * 12 - PS_DIMM_VDDQ_TO_PSVCCO_ON - * 13 - PS_DIMM_SUSPEND_EN - * 14 - PS_DDR4_VTERM_EN - * 15 - PS_DDR4_VPP_2V5_EN - * 16 - 17 - not connected - */ + gpio-line-names = "VCCPSPLL_EN", "MGTRAVCC_EN", "MGTRAVTT_EN", "VCCPSDDRPLL_EN", "MIO26_PMU_INPUT_LS", + "PL_PMBUS_ALERT", "PS_PMBUS_ALERT", "MAXIM_PMBUS_ALERT", "PL_DDR4_VTERM_EN", + "PL_DDR4_VPP_2V5_EN", "PS_DIMM_VDDQ_TO_PSVCCO_ON", "PS_DIMM_SUSPEND_EN", + "PS_DDR4_VTERM_EN", "PS_DDR4_VPP_2V5_EN", "", ""; };
i2c-mux@75 { /* u60 */
arch/arm/dts/zynqmp-zcu100-revC.dts | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp-zcu100-revC.dts b/arch/arm/dts/zynqmp-zcu100-revC.dts index 5285f62d1a30..14aa98de73fe 100644 --- a/arch/arm/dts/zynqmp-zcu100-revC.dts +++ b/arch/arm/dts/zynqmp-zcu100-revC.dts @@ -124,6 +124,11 @@ compatible = "mmc-pwrseq-simple"; reset-gpios = <&gpio 7 GPIO_ACTIVE_LOW>; /* WIFI_EN */ }; + + ina226 { + compatible = "iio-hwmon"; + io-channels = <&u35 0>, <&u35 1>, <&u35 2>, <&u35 3>; + }; };
&dcc { @@ -216,8 +221,9 @@ #size-cells = <0>; reg = <5>; /* PS_PMBUS */ - ina226@40 { /* u35 */ + u35: ina226@40 { /* u35 */ compatible = "ti,ina226"; + #io-channel-cells = <1>; reg = <0x40>; shunt-resistor = <10000>; /* MIO31 is alert which should be routed to PMUFW */
po 14. 10. 2019 v 12:16 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
these are patches I have collected in Xilinx repo and which should go to mainline. There are 3 typo of patches.
- IIO wiring for ina226 and using IIO ina226 driver instead of hwmon
- DT fixes and small updates
- Alignments including name synchronization
Thanks, Michal
Harini Katakam (2): arm64: zynqmp: dt: Add missing DP83867 quirk arm64: zynqmp: dt: Add optional gpio phy reset properties
Michal Simek (21): arm64: zynqmp: Sync names for SC with Versal arm64: zynqmp: Use ethernet-phy as node name for ethernet phys arm64: zynqmp: Enable iio-hwmon for ina226 on g-a2197-00 arm64: zynqmp: Add label property to all ina226 on g-a2197-00 arm64: zynqmp: Fix typo in zynqmp-p-a2197-00-revA arm64: zynqmp: Enable iio-hwmon for ina226 on m-a2197-01 arm64: zynqmp: Add label property to all ina226 on m-a2197-01 arm64: zynqmp: Switch spi-flash to jedec,spi-nor on m-a2197 arm64: zynqmp: Fix m-a2197-01 DT based on latest schematics arm64: zynqmp: Sync si570 setup and clock names arm64: zynqmp: Remove fixme about memory size on zynqmp-p-a2197 arm64: zynqmp: Enable iio-hwmon for ina226 on zcu111 arm64: zynqmp: Add label property to all ina226 on zcu111 arm64: zynqmp: Enable iio-hwmon for ina226 on zcu106 arm64: zynqmp: Add label property to all ina226 on zcu106 arm64: zynqmp: Enable iio-hwmon for ina226 on zcu104 arm64: zynqmp: Enable fpd_dma for zcu104 platforms arm64: zynqmp: Enable iio-hwmon for ina226 on zcu102 arm64: zynqmp: Add label property to all ina226 on zcu102 arm64: zynqmp: Turn comment to gpio-line-names arm64: zynqmp: Enable iio-hwmon for ina226 on zcu100
Nishant Mittal (2): arm64: zynqmp: Fix i2c address of u70 on p-a2197-00 board arm64: zynqmp: Added new tps53679 compatible string for a2197-0x boards
T Karthik Reddy (1): arm64: zynqmp: dt: Delete no-1-8-v property from zcu102-rev1.0
Venkatesh Yadav Abbarapu (1): arm64: zynqmp: Fix the si570 clock frequency on zcu111
arch/arm/dts/Makefile | 6 +- ...-g-revA.dts => zynqmp-g-a2197-00-revA.dts} | 55 ++++- ...-m-revA.dts => zynqmp-m-a2197-01-revA.dts} | 68 +++++-- ...-p-revA.dts => zynqmp-p-a2197-00-revA.dts} | 42 ++-- arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts | 3 +- arch/arm/dts/zynqmp-zc1751-xm017-dc3.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts | 2 +- arch/arm/dts/zynqmp-zcu100-revC.dts | 8 +- arch/arm/dts/zynqmp-zcu102-rev1.0.dts | 4 + arch/arm/dts/zynqmp-zcu102-revA.dts | 192 +++++++++++++----- arch/arm/dts/zynqmp-zcu102-revB.dts | 4 +- arch/arm/dts/zynqmp-zcu104-revA.dts | 35 +++- arch/arm/dts/zynqmp-zcu104-revC.dts | 43 +++- arch/arm/dts/zynqmp-zcu106-revA.dts | 148 ++++++++++++-- arch/arm/dts/zynqmp-zcu111-revA.dts | 118 +++++++++-- configs/xilinx_zynqmp_a2197_revA_defconfig | 2 +- ...> xilinx_zynqmp_g_a2197_00_revA_defconfig} | 2 +- ...> xilinx_zynqmp_m_a2197_01_revA_defconfig} | 2 +- ...> xilinx_zynqmp_p_a2197_00_revA_defconfig} | 2 +- 20 files changed, 588 insertions(+), 152 deletions(-) rename arch/arm/dts/{zynqmp-a2197-g-revA.dts => zynqmp-g-a2197-00-revA.dts} (85%) rename arch/arm/dts/{zynqmp-a2197-m-revA.dts => zynqmp-m-a2197-01-revA.dts} (86%) rename arch/arm/dts/{zynqmp-a2197-p-revA.dts => zynqmp-p-a2197-00-revA.dts} (93%) rename configs/{xilinx_zynqmp_a2197_m_revA_defconfig => xilinx_zynqmp_g_a2197_00_revA_defconfig} (98%) rename configs/{xilinx_zynqmp_a2197_g_revA_defconfig => xilinx_zynqmp_m_a2197_01_revA_defconfig} (98%) rename configs/{xilinx_zynqmp_a2197_p_revA_defconfig => xilinx_zynqmp_p_a2197_00_revA_defconfig} (98%)
-- 2.17.1
Applied all. M
Michal Simek
Michal Simek
