[PATCH] arm: mvebu: turris_omnia: Fix MTD partitions order for Linux
Linux enumerates MTD partitions in DTB order, while the fdt_add_subnode() function puts a new subnode at the beginning.
To fix this, put MTD partitions into DTB in reverse order.
Fixes: 92f36c8e74c1 ("arm: mvebu: turris_omnia: fixup MTD partitions in Linux' DTB") Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Marek Behún marek.behun@nic.cz --- board/CZ.NIC/turris_omnia/turris_omnia.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index a48e1f5c305d..d2f510993449 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -601,7 +601,7 @@ static bool fixup_mtd_partitions(void *blob, int offset, struct mtd_info *mtd)
mtd_probe_devices();
- list_for_each_entry(slave, &mtd->partitions, node) { + list_for_each_entry_reverse(slave, &mtd->partitions, node) { char name[32]; int part;
Thanks, Stefan
- list_for_each_entry_reverse(slave, &mtd->partitions, node) { char name[32]; int part;
Viele Grüße, Stefan
Applied to u-boot-marvell/master
Thanks, Stefan
Viele Grüße, Stefan
Pali Rohár
Stefan Roese
