[PATCH v3 0/3] Add imx93-var-som support
Hello,
This v3 adds support for binman and documents how to build and flash a bootloader for the i.MX93 Variscite Symphony evaluation board.
Thanks,
Mathieu
v2: https://lists.denx.de/pipermail/u-boot/2023-December/542001.html
Mathieu Othacehe (3): spl: binman: Disable u_boot_any symbols for i.MX93 boards mach-imx: Add i.MX93 binman support. Add imx93-var-som support
arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx93-u-boot.dtsi | 88 + .../dts/imx93-var-som-symphony-u-boot.dtsi | 253 +++ arch/arm/dts/imx93-var-som-symphony.dts | 305 ++++ arch/arm/dts/imx93-var-som.dtsi | 111 ++ arch/arm/include/asm/arch-imx9/clock.h | 1 + arch/arm/mach-imx/Makefile | 22 +- arch/arm/mach-imx/imx9/Kconfig | 7 + board/variscite/common/eth.c | 59 + board/variscite/common/eth.h | 12 + board/variscite/common/imx9_eeprom.c | 190 +++ board/variscite/common/imx9_eeprom.h | 83 + board/variscite/common/mmc.c | 47 + board/variscite/imx93_var_som/Kconfig | 12 + board/variscite/imx93_var_som/MAINTAINERS | 7 + board/variscite/imx93_var_som/Makefile | 17 + board/variscite/imx93_var_som/container.cfg | 10 + board/variscite/imx93_var_som/imx93_var_som.c | 126 ++ .../variscite/imx93_var_som/imx93_var_som.env | 104 ++ board/variscite/imx93_var_som/imximage.cfg | 10 + .../variscite/imx93_var_som/lpddr4x_timing.c | 1489 +++++++++++++++++ board/variscite/imx93_var_som/spl.c | 144 ++ common/spl/Kconfig | 2 +- common/spl/Kconfig.tpl | 2 +- common/spl/Kconfig.vpl | 2 +- configs/imx93_var_som_defconfig | 156 ++ doc/board/variscite/imx93_var_som.rst | 68 + doc/board/variscite/index.rst | 1 + include/configs/imx93_var_som.h | 48 + 29 files changed, 3374 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/imx93-u-boot.dtsi create mode 100644 arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi create mode 100644 arch/arm/dts/imx93-var-som-symphony.dts create mode 100644 arch/arm/dts/imx93-var-som.dtsi create mode 100644 board/variscite/common/eth.c create mode 100644 board/variscite/common/eth.h create mode 100644 board/variscite/common/imx9_eeprom.c create mode 100644 board/variscite/common/imx9_eeprom.h create mode 100644 board/variscite/common/mmc.c create mode 100644 board/variscite/imx93_var_som/Kconfig create mode 100644 board/variscite/imx93_var_som/MAINTAINERS create mode 100644 board/variscite/imx93_var_som/Makefile create mode 100644 board/variscite/imx93_var_som/container.cfg create mode 100644 board/variscite/imx93_var_som/imx93_var_som.c create mode 100644 board/variscite/imx93_var_som/imx93_var_som.env create mode 100644 board/variscite/imx93_var_som/imximage.cfg create mode 100644 board/variscite/imx93_var_som/lpddr4x_timing.c create mode 100644 board/variscite/imx93_var_som/spl.c create mode 100644 configs/imx93_var_som_defconfig create mode 100644 doc/board/variscite/imx93_var_som.rst create mode 100644 include/configs/imx93_var_som.h
This is extending commit 6516c9b349b3 ("spl: binman: Disable u_boot_any symbols for i.MX8M boards") to i.MX93 boards.
Signed-off-by: Mathieu Othacehe m.othacehe@gmail.com --- common/spl/Kconfig | 2 +- common/spl/Kconfig.tpl | 2 +- common/spl/Kconfig.vpl | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index c5dd476db58..322e6fe882f 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -206,7 +206,7 @@ config SPL_BINMAN_SYMBOLS config SPL_BINMAN_UBOOT_SYMBOLS bool "Declare binman symbols for U-Boot phases in SPL" depends on SPL_BINMAN_SYMBOLS - default n if ARCH_IMX8M + default n if ARCH_IMX8M || ARCH_IMX9 default y help This enables use of symbols in SPL which refer to U-Boot phases, diff --git a/common/spl/Kconfig.tpl b/common/spl/Kconfig.tpl index 3d6cf1e59f3..9bb57e6fbff 100644 --- a/common/spl/Kconfig.tpl +++ b/common/spl/Kconfig.tpl @@ -23,7 +23,7 @@ config TPL_BINMAN_SYMBOLS config TPL_BINMAN_UBOOT_SYMBOLS bool "Declare binman symbols for U-Boot phases in TPL" depends on TPL_BINMAN_SYMBOLS - default n if ARCH_IMX8M + default n if ARCH_IMX8M || ARCH_IMX9 default y help This enables use of symbols in TPL which refer to U-Boot phases, diff --git a/common/spl/Kconfig.vpl b/common/spl/Kconfig.vpl index ae1a3c724f3..f1993026bba 100644 --- a/common/spl/Kconfig.vpl +++ b/common/spl/Kconfig.vpl @@ -243,7 +243,7 @@ config VPL_BINMAN_SYMBOLS config VPL_BINMAN_UBOOT_SYMBOLS bool "Declare binman symbols for U-Boot phases in VPL" depends on VPL_BINMAN_SYMBOLS - default n if ARCH_IMX8M + default n if ARCH_IMX8M || ARCH_IMX9 default y help This enables use of symbols in VPL which refer to U-Boot phases,
Reviewed-by: Fabio Estevam festevam@gmail.com
Add dedicated Makefile targets for the i.MX93 and a new imx93-u-boot.dtsi device-tree to create binman images.
Signed-off-by: Mathieu Othacehe m.othacehe@gmail.com --- arch/arm/dts/imx93-u-boot.dtsi | 88 ++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/Makefile | 22 ++++++++- 2 files changed, 109 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx93-u-boot.dtsi
diff --git a/arch/arm/dts/imx93-u-boot.dtsi b/arch/arm/dts/imx93-u-boot.dtsi new file mode 100644 index 00000000000..40e17bbc5ae --- /dev/null +++ b/arch/arm/dts/imx93-u-boot.dtsi @@ -0,0 +1,88 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Mathieu Othacehe m.othacehe@gmail.com + */ + +/ { + binman: binman { + multiple-images; + }; +}; + +&binman { + u-boot-spl-ddr { + align = <4>; + align-size = <4>; + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + + u-boot-spl { + align-end = <4>; + filename = "u-boot-spl.bin"; + }; + + ddr-1d-imem-fw { + filename = "lpddr4_imem_1d_v202201.bin"; + align-end = <4>; + type = "blob-ext"; + }; + + ddr-1d-dmem-fw { + filename = "lpddr4_dmem_1d_v202201.bin"; + align-end = <4>; + type = "blob-ext"; + }; + + ddr-2d-imem-fw { + filename = "lpddr4_imem_2d_v202201.bin"; + align-end = <4>; + type = "blob-ext"; + }; + + ddr-2d-dmem-fw { + filename = "lpddr4_dmem_2d_v202201.bin"; + align-end = <4>; + type = "blob-ext"; + }; + }; + + spl { + filename = "spl.bin"; + + mkimage { + args = "-n spl/u-boot-spl.cfgout -T imx8image -e 0x2049A000"; + + blob { + filename = "u-boot-spl-ddr.bin"; + }; + }; + }; + + u-boot-container { + filename = "u-boot-container.bin"; + + mkimage { + args = "-n u-boot-container.cfgout -T imx8image -e 0x0"; + + blob { + filename = "u-boot.bin"; + }; + }; + }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + filename = "spl.bin"; + offset = <0x0>; + align-size = <0x400>; + align = <0x400>; + }; + + uboot: blob-ext@2 { + filename = "u-boot-container.bin"; + }; + }; +}; diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index aebfa6517bd..2a16f9b9dfc 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -129,6 +129,9 @@ DEPFILE_EXISTS := $(shell $(CPP) $(cpp_flags) -x c -o u-boot-dtb.cfgout $(srctre else ifeq ($(CONFIG_ARCH_IMX8M), y) IMAGE_TYPE := imx8mimage DEPFILE_EXISTS := 0 +else ifeq ($(CONFIG_ARCH_IMX9), y) +IMAGE_TYPE := imx8image +DEPFILE_EXISTS := 0 else IMAGE_TYPE := imximage DEPFILE_EXISTS := 0 @@ -211,7 +214,24 @@ endif endif
ifeq ($(CONFIG_ARCH_IMX9), y) -SPL: + +SPL: spl/u-boot-spl.bin spl/u-boot-spl.cfgout u-boot-container.cfgout FORCE + +MKIMAGEFLAGS_flash.bin = -n spl/u-boot-spl.cfgout -T $(IMAGE_TYPE) -e $(CONFIG_SPL_TEXT_BASE) +flash.bin: MKIMAGEOUTPUT = flash.log + +spl/u-boot-spl.cfgout: $(IMX_CONFIG) FORCE + $(Q)mkdir -p $(dir $@) + $(call if_changed_dep,cpp_cfg) + +spl/u-boot-spl-ddr.bin: spl/u-boot-spl.bin spl/u-boot-spl.cfgout FORCE + +u-boot-container.cfgout: $(IMX_CONTAINER_CFG) FORCE + $(Q)mkdir -p $(dir $@) + $(call if_changed_dep,cpp_cfg) + +flash.bin: spl/u-boot-spl-ddr.bin container.cfgout FORCE + $(call if_changed,mkimage) endif
else
Add support for the Variscite VAR-SOM-IMX93 evaluation kit. The SoM consists of an NXP iMX93 dual A55 CPU. The SoM is mounted on a Variscite Symphony SBC.
Signed-off-by: Mathieu Othacehe m.othacehe@gmail.com --- arch/arm/dts/Makefile | 3 +- .../dts/imx93-var-som-symphony-u-boot.dtsi | 253 +++ arch/arm/dts/imx93-var-som-symphony.dts | 305 ++++ arch/arm/dts/imx93-var-som.dtsi | 111 ++ arch/arm/include/asm/arch-imx9/clock.h | 1 + arch/arm/mach-imx/imx9/Kconfig | 7 + board/variscite/common/eth.c | 59 + board/variscite/common/eth.h | 12 + board/variscite/common/imx9_eeprom.c | 190 +++ board/variscite/common/imx9_eeprom.h | 83 + board/variscite/common/mmc.c | 47 + board/variscite/imx93_var_som/Kconfig | 12 + board/variscite/imx93_var_som/MAINTAINERS | 7 + board/variscite/imx93_var_som/Makefile | 17 + board/variscite/imx93_var_som/container.cfg | 10 + board/variscite/imx93_var_som/imx93_var_som.c | 126 ++ .../variscite/imx93_var_som/imx93_var_som.env | 104 ++ board/variscite/imx93_var_som/imximage.cfg | 10 + .../variscite/imx93_var_som/lpddr4x_timing.c | 1489 +++++++++++++++++ board/variscite/imx93_var_som/spl.c | 144 ++ configs/imx93_var_som_defconfig | 156 ++ doc/board/variscite/imx93_var_som.rst | 68 + doc/board/variscite/index.rst | 1 + include/configs/imx93_var_som.h | 48 + 24 files changed, 3262 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi create mode 100644 arch/arm/dts/imx93-var-som-symphony.dts create mode 100644 arch/arm/dts/imx93-var-som.dtsi create mode 100644 board/variscite/common/eth.c create mode 100644 board/variscite/common/eth.h create mode 100644 board/variscite/common/imx9_eeprom.c create mode 100644 board/variscite/common/imx9_eeprom.h create mode 100644 board/variscite/common/mmc.c create mode 100644 board/variscite/imx93_var_som/Kconfig create mode 100644 board/variscite/imx93_var_som/MAINTAINERS create mode 100644 board/variscite/imx93_var_som/Makefile create mode 100644 board/variscite/imx93_var_som/container.cfg create mode 100644 board/variscite/imx93_var_som/imx93_var_som.c create mode 100644 board/variscite/imx93_var_som/imx93_var_som.env create mode 100644 board/variscite/imx93_var_som/imximage.cfg create mode 100644 board/variscite/imx93_var_som/lpddr4x_timing.c create mode 100644 board/variscite/imx93_var_som/spl.c create mode 100644 configs/imx93_var_som_defconfig create mode 100644 doc/board/variscite/imx93_var_som.rst create mode 100644 include/configs/imx93_var_som.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 85fd5b1157b..e6b604a2232 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1057,7 +1057,8 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mq-librem5-r4.dtb
dtb-$(CONFIG_ARCH_IMX9) += \ - imx93-11x11-evk.dtb + imx93-11x11-evk.dtb \ + imx93-var-som-symphony.dtb
dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ imxrt1020-evk.dtb \ diff --git a/arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi new file mode 100644 index 00000000000..e98bafd461a --- /dev/null +++ b/arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi @@ -0,0 +1,253 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 NXP + * Copyright 2023 Variscite Ltd. + */ + +#include "imx93-u-boot.dtsi" + +/ { + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog3>; + bootph-pre-ram; + }; + + aliases { + ethernet0 = &eqos; + ethernet1 = &fec; + }; + + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + }; +}; + +&{/soc@0} { + bootph-all; + bootph-pre-ram; +}; + +&aips1 { + bootph-pre-ram; + bootph-all; +}; + +&aips2 { + bootph-pre-ram; +}; + +&aips3 { + bootph-pre-ram; +}; + +&iomuxc { + bootph-pre-ram; +}; + +®_usdhc2_vmmc { + u-boot,off-on-delay-us = <20000>; + bootph-pre-ram; +}; + +&pinctrl_reg_usdhc2_vmmc { + bootph-pre-ram; +}; + +&pinctrl_uart1 { + bootph-pre-ram; +}; + +&pinctrl_usdhc2 { + bootph-pre-ram; +}; + +&gpio1 { + bootph-pre-ram; +}; + +&gpio2 { + bootph-pre-ram; +}; + +&gpio3 { + bootph-pre-ram; +}; + +&gpio4 { + bootph-pre-ram; +}; + +&lpuart1 { + bootph-pre-ram; +}; + +&usdhc1 { + bootph-pre-ram; +}; + +&usdhc2 { + bootph-pre-ram; + fsl,signal-voltage-switch-extra-delay-ms = <8>; +}; + +&eqos { + compatible = "fsl,imx-eqos"; +}; + +ðphy0 { + reset-gpios = <&gpio1 7 GPIO_ACTIVE_LOW>; + reset-assert-us = <15000>; + reset-deassert-us = <100000>; +}; + +ðphy1 { + reset-gpios = <&pca9534 5 GPIO_ACTIVE_LOW>; + reset-assert-us = <15000>; + reset-deassert-us = <100000>; +}; + +&s4muap { + bootph-pre-ram; + status = "okay"; +}; + +&clk { + bootph-all; + bootph-pre-ram; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-rates; +}; + +&osc_32k { + bootph-all; + bootph-pre-ram; +}; + +&osc_24m { + bootph-all; + bootph-pre-ram; +}; + +&clk_ext1 { + bootph-all; + bootph-pre-ram; +}; + +/* + * The two nodes below won't be needed once nxp,pca9451a + * support is added to the Linux kernel. + */ +&iomuxc { + pinctrl_lpi2c3: lpi2c3grp { + bootph-pre-ram; + fsl,pins = < + MX93_PAD_GPIO_IO28__LPI2C3_SDA 0x40000b9e + MX93_PAD_GPIO_IO29__LPI2C3_SCL 0x40000b9e + >; + }; +}; + +&lpi2c3 { + bootph-pre-ram; + clock-frequency = <400000>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&pinctrl_lpi2c3>; + pinctrl-1 = <&pinctrl_lpi2c3>; + status = "okay"; + + pmic@25 { + bootph-pre-ram; + compatible = "nxp,pca9451a"; + reg = <0x25>; + pinctrl-names = "default"; + + regulators { + bootph-pre-ram; + buck1: BUCK1 { + regulator-name = "BUCK1"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <2187500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck2: BUCK2 { + regulator-name = "BUCK2"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <2187500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck4: BUCK4{ + regulator-name = "BUCK4"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5: BUCK5{ + regulator-name = "BUCK5"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6: BUCK6 { + regulator-name = "BUCK6"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1: LDO1 { + regulator-name = "LDO1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo2: LDO2 { + regulator-name = "LDO2"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1150000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3: LDO3 { + regulator-name = "LDO3"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4: LDO4 { + regulator-name = "LDO4"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo5: LDO5 { + regulator-name = "LDO5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; diff --git a/arch/arm/dts/imx93-var-som-symphony.dts b/arch/arm/dts/imx93-var-som-symphony.dts new file mode 100644 index 00000000000..a67bd005e54 --- /dev/null +++ b/arch/arm/dts/imx93-var-som-symphony.dts @@ -0,0 +1,305 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2021 NXP + * Copyright 2023 Variscite Ltd. + */ + +/dts-v1/; + +#include "imx93-var-som.dtsi" + +/{ + model = "Variscite VAR-SOM-MX93 on Symphony evaluation board"; + compatible = "variscite,var-som-mx93-symphony", + "variscite,var-som-mx93", "fsl,imx93"; + + aliases { + ethernet0 = &eqos; + ethernet1 = &fec; + }; + + chosen { + stdout-path = &lpuart1; + }; + + /* + * Needed only for Symphony <= v1.5 + */ + reg_fec_phy: regulator-fec-phy { + compatible = "regulator-fixed"; + regulator-name = "fec-phy"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-enable-ramp-delay = <20000>; + gpio = <&pca9534 7 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-always-on; + }; + + reg_usdhc2_vmmc: regulator-usdhc2 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; + regulator-name = "VSD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 18 GPIO_ACTIVE_HIGH>; + off-on-delay-us = <20000>; + enable-active-high; + }; + + reg_vref_1v8: regulator-adc-vref { + compatible = "regulator-fixed"; + regulator-name = "vref_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + ethosu_mem: ethosu-region@88000000 { + compatible = "shared-dma-pool"; + reusable; + reg = <0x0 0x88000000 0x0 0x8000000>; + }; + + vdev0vring0: vdev0vring0@87ee0000 { + reg = <0 0x87ee0000 0 0x8000>; + no-map; + }; + + vdev0vring1: vdev0vring1@87ee8000 { + reg = <0 0x87ee8000 0 0x8000>; + no-map; + }; + + vdev1vring0: vdev1vring0@87ef0000 { + reg = <0 0x87ef0000 0 0x8000>; + no-map; + }; + + vdev1vring1: vdev1vring1@87ef8000 { + reg = <0 0x87ef8000 0 0x8000>; + no-map; + }; + + rsc_table: rsc-table@2021f000 { + reg = <0 0x2021f000 0 0x1000>; + no-map; + }; + + vdevbuffer: vdevbuffer@87f00000 { + compatible = "shared-dma-pool"; + reg = <0 0x87f00000 0 0x100000>; + no-map; + }; + + ele_reserved: ele-reserved@87de0000 { + compatible = "shared-dma-pool"; + reg = <0 0x87de0000 0 0x100000>; + no-map; + }; + }; +}; + +/* Use external instead of internal RTC*/ +&bbnsm_rtc { + status = "disabled"; +}; + +&eqos { + mdio { + ethphy1: ethernet-phy@5 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <5>; + qca,disable-smarteee; + eee-broken-1000t; + reset-gpios = <&pca9534 5 GPIO_ACTIVE_LOW>; + reset-assert-us = <10000>; + reset-deassert-us = <20000>; + vddio-supply = <&vddio1>; + + vddio1: vddio-regulator { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + }; + }; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec>; + phy-mode = "rgmii"; + phy-handle = <ðphy1>; + phy-supply = <®_fec_phy>; + status = "okay"; +}; + +&flexcan1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan1>; + status = "okay"; +}; + +&iomuxc { + pinctrl_fec: fecgrp { + fsl,pins = < + MX93_PAD_ENET2_RD0__ENET1_RGMII_RD0 0x57e + MX93_PAD_ENET2_RD1__ENET1_RGMII_RD1 0x57e + MX93_PAD_ENET2_RD2__ENET1_RGMII_RD2 0x57e + MX93_PAD_ENET2_RD3__ENET1_RGMII_RD3 0x57e + MX93_PAD_ENET2_RXC__ENET1_RGMII_RXC 0x5fe + MX93_PAD_ENET2_RX_CTL__ENET1_RGMII_RX_CTL 0x57e + MX93_PAD_ENET2_TD0__ENET1_RGMII_TD0 0x57e + MX93_PAD_ENET2_TD1__ENET1_RGMII_TD1 0x57e + MX93_PAD_ENET2_TD2__ENET1_RGMII_TD2 0x57e + MX93_PAD_ENET2_TD3__ENET1_RGMII_TD3 0x57e + MX93_PAD_ENET2_TXC__ENET1_RGMII_TXC 0x5fe + MX93_PAD_ENET2_TX_CTL__ENET1_RGMII_TX_CTL 0x57e + >; + }; + + pinctrl_flexcan1: flexcan1grp { + fsl,pins = < + MX93_PAD_PDM_CLK__CAN1_TX 0x139e + MX93_PAD_PDM_BIT_STREAM0__CAN1_RX 0x139e + >; + }; + + pinctrl_lpi2c1: lpi2c1grp { + fsl,pins = < + MX93_PAD_I2C1_SCL__LPI2C1_SCL 0x40000b9e + MX93_PAD_I2C1_SDA__LPI2C1_SDA 0x40000b9e + >; + }; + + pinctrl_lpi2c1_gpio: lpi2c1gpiogrp { + fsl,pins = < + MX93_PAD_I2C1_SCL__GPIO1_IO00 0x31e + MX93_PAD_I2C1_SDA__GPIO1_IO01 0x31e + >; + }; + + pinctrl_lpi2c5: lpi2c5grp { + fsl,pins = < + MX93_PAD_GPIO_IO23__LPI2C5_SCL 0x40000b9e + MX93_PAD_GPIO_IO22__LPI2C5_SDA 0x40000b9e + >; + }; + + pinctrl_lpi2c5_gpio: lpi2c5gpiogrp { + fsl,pins = < + MX93_PAD_GPIO_IO23__GPIO2_IO23 0x31e + MX93_PAD_GPIO_IO22__GPIO2_IO22 0x31e + >; + }; + + pinctrl_pca9534: pca9534grp { + fsl,pins = < + MX93_PAD_CCM_CLKO1__GPIO3_IO26 0x31e + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX93_PAD_UART1_RXD__LPUART1_RX 0x31e + MX93_PAD_UART1_TXD__LPUART1_TX 0x31e + >; + }; + + pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { + fsl,pins = < + MX93_PAD_GPIO_IO18__GPIO2_IO18 0x31e + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX93_PAD_SD2_CLK__USDHC2_CLK 0x15fe + MX93_PAD_SD2_CMD__USDHC2_CMD 0x13fe + MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x13fe + MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x13fe + MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x13fe + MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x13fe + MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e + >; + }; + + pinctrl_usdhc2_gpio: usdhc2gpiogrp { + fsl,pins = < + MX93_PAD_SD2_CD_B__GPIO3_IO00 0x31e + >; + }; +}; + +&lpi2c1 { + clock-frequency = <400000>; + pinctrl-names = "default", "sleep", "gpio"; + pinctrl-0 = <&pinctrl_lpi2c1>; + pinctrl-1 = <&pinctrl_lpi2c1_gpio>; + pinctrl-2 = <&pinctrl_lpi2c1_gpio>; + scl-gpios = <&gpio1 0 GPIO_ACTIVE_HIGH>; + sda-gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>; + status = "okay"; + + /* DS1337 RTC module */ + rtc@68 { + compatible = "dallas,ds1337"; + reg = <0x68>; + }; +}; + +&lpi2c5 { + clock-frequency = <400000>; + pinctrl-names = "default", "sleep", "gpio"; + pinctrl-0 = <&pinctrl_lpi2c5>; + pinctrl-1 = <&pinctrl_lpi2c5_gpio>; + pinctrl-2 = <&pinctrl_lpi2c5_gpio>; + scl-gpios = <&gpio2 23 GPIO_ACTIVE_HIGH>; + sda-gpios = <&gpio2 22 GPIO_ACTIVE_HIGH>; + status = "okay"; + + pca9534: gpio@20 { + compatible = "nxp,pca9534"; + reg = <0x20>; + gpio-controller; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pca9534>; + interrupt-parent = <&gpio3>; + interrupts = <26 IRQ_TYPE_EDGE_FALLING>; + #gpio-cells = <2>; + wakeup-source; + }; +}; + +/* Console */ +&lpuart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + clocks = <&clk IMX93_CLK_LPUART1_GATE>, <&clk IMX93_CLK_LPUART1_GATE>; + clock-names = "ipg", "per"; + status = "okay"; +}; + +/* SD */ +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + cd-gpios = <&gpio3 00 GPIO_ACTIVE_LOW>; + vmmc-supply = <®_usdhc2_vmmc>; + bus-width = <4>; + status = "okay"; + no-sdio; + no-mmc; +}; + +/* Watchdog */ +&wdog3 { + status = "okay"; +}; diff --git a/arch/arm/dts/imx93-var-som.dtsi b/arch/arm/dts/imx93-var-som.dtsi new file mode 100644 index 00000000000..6c77b886666 --- /dev/null +++ b/arch/arm/dts/imx93-var-som.dtsi @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2022 NXP + * Copyright 2023 Variscite Ltd. + */ + +/dts-v1/; + +#include "imx93.dtsi" + +/{ + model = "Variscite VAR-SOM-MX93 module"; + compatible = "variscite,var-som-mx93", "fsl,imx93"; + + mmc_pwrseq: mmc-pwrseq { + compatible = "mmc-pwrseq-simple"; + post-power-on-delay-ms = <100>; + power-off-delay-us = <10000>; + reset-gpios = <&gpio4 14 GPIO_ACTIVE_LOW>, /* WIFI_RESET */ + <&gpio3 7 GPIO_ACTIVE_LOW>; /* WIFI_PWR_EN */ + }; + + reg_eqos_phy: regulator-eqos-phy { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_eqos_phy>; + regulator-name = "eth_phy_pwr"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio1 7 GPIO_ACTIVE_HIGH>; + enable-active-high; + startup-delay-us = <100000>; + regulator-always-on; + }; +}; + +&eqos { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_eqos>; + phy-mode = "rgmii"; + phy-handle = <ðphy0>; + phy-supply = <®_eqos_phy>; + status = "okay"; + + mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <1000000>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + eee-broken-1000t; + }; + }; +}; + +&iomuxc { + pinctrl_eqos: eqosgrp { + fsl,pins = < + MX93_PAD_ENET1_MDC__ENET_QOS_MDC 0x57e + MX93_PAD_ENET1_MDIO__ENET_QOS_MDIO 0x57e + MX93_PAD_ENET1_RD0__ENET_QOS_RGMII_RD0 0x57e + MX93_PAD_ENET1_RD1__ENET_QOS_RGMII_RD1 0x57e + MX93_PAD_ENET1_RD2__ENET_QOS_RGMII_RD2 0x57e + MX93_PAD_ENET1_RD3__ENET_QOS_RGMII_RD3 0x57e + MX93_PAD_ENET1_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x5fe + MX93_PAD_ENET1_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x57e + MX93_PAD_ENET1_TD0__ENET_QOS_RGMII_TD0 0x57e + MX93_PAD_ENET1_TD1__ENET_QOS_RGMII_TD1 0x57e + MX93_PAD_ENET1_TD2__ENET_QOS_RGMII_TD2 0x57e + MX93_PAD_ENET1_TD3__ENET_QOS_RGMII_TD3 0x57e + MX93_PAD_ENET1_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x5fe + MX93_PAD_ENET1_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x57e + >; + }; + + pinctrl_reg_eqos_phy: regeqosgrp { + fsl,pins = < + MX93_PAD_UART2_TXD__GPIO1_IO07 0x51e + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX93_PAD_SD1_CLK__USDHC1_CLK 0x15fe + MX93_PAD_SD1_CMD__USDHC1_CMD 0x13fe + MX93_PAD_SD1_DATA0__USDHC1_DATA0 0x13fe + MX93_PAD_SD1_DATA1__USDHC1_DATA1 0x13fe + MX93_PAD_SD1_DATA2__USDHC1_DATA2 0x13fe + MX93_PAD_SD1_DATA3__USDHC1_DATA3 0x13fe + MX93_PAD_SD1_DATA4__USDHC1_DATA4 0x13fe + MX93_PAD_SD1_DATA5__USDHC1_DATA5 0x13fe + MX93_PAD_SD1_DATA6__USDHC1_DATA6 0x13fe + MX93_PAD_SD1_DATA7__USDHC1_DATA7 0x13fe + MX93_PAD_SD1_STROBE__USDHC1_STROBE 0x15fe + >; + }; +}; + +/* eMMC */ +&usdhc1 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1>; + pinctrl-2 = <&pinctrl_usdhc1>; + bus-width = <8>; + non-removable; + status = "okay"; +}; diff --git a/arch/arm/include/asm/arch-imx9/clock.h b/arch/arm/include/asm/arch-imx9/clock.h index 1169ffd74d3..1ce6ac4c3a8 100644 --- a/arch/arm/include/asm/arch-imx9/clock.h +++ b/arch/arm/include/asm/arch-imx9/clock.h @@ -222,6 +222,7 @@ u32 mxc_get_clock(enum mxc_clock clk); void dram_pll_init(ulong pll_val); void dram_enable_bypass(ulong clk_val); void dram_disable_bypass(void); +void set_arm_core_max_clk(void);
int configure_intpll(enum ccm_clk_src pll, u32 freq);
diff --git a/arch/arm/mach-imx/imx9/Kconfig b/arch/arm/mach-imx/imx9/Kconfig index c51f80f311a..57e332a1958 100644 --- a/arch/arm/mach-imx/imx9/Kconfig +++ b/arch/arm/mach-imx/imx9/Kconfig @@ -31,9 +31,16 @@ config TARGET_IMX93_11X11_EVK bool "imx93_11x11_evk" select IMX93
+config TARGET_IMX93_VAR_SOM + bool "imx93_var_som" + select BINMAN + select IMX93 + select IMX9_LPDDR4X + endchoice
source "board/freescale/imx93_evk/Kconfig" +source "board/variscite/imx93_var_som/Kconfig"
endif
diff --git a/board/variscite/common/eth.c b/board/variscite/common/eth.c new file mode 100644 index 00000000000..9e05dee51c2 --- /dev/null +++ b/board/variscite/common/eth.c @@ -0,0 +1,59 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2023 Variscite Ltd. + */ +#include <common.h> +#include <net.h> +#include <miiphy.h> +#include <env.h> +#include "../common/imx9_eeprom.h" + +#define CHAR_BIT 8 + +static u64 mac2int(const u8 hwaddr[]) +{ + s8 i; + u64 ret = 0; + const u8 *p = hwaddr; + + for (i = 5; i >= 0; i--) + ret |= (u64)*p++ << (CHAR_BIT * i); + + return ret; +} + +static void int2mac(const u64 mac, u8 *hwaddr) +{ + s8 i; + u8 *p = hwaddr; + + for (i = 5; i >= 0; i--) + *p++ = mac >> (CHAR_BIT * i); +} + +int var_setup_mac(struct var_eeprom *eeprom) +{ + int ret; + unsigned char enetaddr[6]; + u64 addr; + unsigned char enet1addr[6]; + + ret = eth_env_get_enetaddr("ethaddr", enetaddr); + if (ret) + return 0; + + ret = var_eeprom_get_mac(eeprom, enetaddr); + if (ret) + return ret; + + if (!is_valid_ethaddr(enetaddr)) + return -EINVAL; + + eth_env_set_enetaddr("ethaddr", enetaddr); + + addr = mac2int(enetaddr); + int2mac(addr + 1, enet1addr); + eth_env_set_enetaddr("eth1addr", enet1addr); + + return 0; +} diff --git a/board/variscite/common/eth.h b/board/variscite/common/eth.h new file mode 100644 index 00000000000..a335c08b8ce --- /dev/null +++ b/board/variscite/common/eth.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2023 Variscite Ltd. + * + */ + +#ifndef _MX9_ETH_H_ +#define _MX9_ETH_H_ + +int var_setup_mac(struct var_eeprom *eeprom); + +#endif /* _MX9_ETH_H_ */ diff --git a/board/variscite/common/imx9_eeprom.c b/board/variscite/common/imx9_eeprom.c new file mode 100644 index 00000000000..10bb42d9d13 --- /dev/null +++ b/board/variscite/common/imx9_eeprom.c @@ -0,0 +1,190 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Variscite Ltd. + * + */ +#include <common.h> +#include <command.h> +#include <dm.h> +#include <i2c.h> +#include <asm/io.h> +#include <cpu_func.h> +#include <u-boot/crc.h> +#include <asm/arch-imx9/ddr.h> + +#include "imx9_eeprom.h" + +static int var_eeprom_get_dev(struct udevice **devp) +{ + int ret; + struct udevice *bus; + + ret = uclass_get_device_by_name(UCLASS_I2C, VAR_SOM_EEPROM_I2C_NAME, &bus); + if (ret) { + debug("%s: No EEPROM I2C bus '%s'\n", __func__, VAR_SOM_EEPROM_I2C_NAME); + return ret; + } + + ret = dm_i2c_probe(bus, VAR_SOM_EEPROM_I2C_ADDR, 0, devp); + if (ret) { + debug("%s: I2C EEPROM probe failed\n", __func__); + return ret; + } + + i2c_set_chip_offset_len(*devp, 1); + i2c_set_chip_addr_offset_mask(*devp, 1); + + return 0; +} + +int var_eeprom_read_header(struct var_eeprom *e) +{ + int ret; + struct udevice *dev; + + ret = var_eeprom_get_dev(&dev); + if (ret) { + debug("%s: Failed to detect I2C EEPROM\n", __func__); + return ret; + } + + /* Read EEPROM header to memory */ + ret = dm_i2c_read(dev, 0, (void *)e, sizeof(*e)); + if (ret) { + debug("%s: EEPROM read failed, ret=%d\n", __func__, ret); + return ret; + } + + return 0; +} + +int var_eeprom_get_mac(struct var_eeprom *ep, u8 *mac) +{ + flush_dcache_all(); + if (!var_eeprom_is_valid(ep)) + return -1; + + memcpy(mac, ep->mac, sizeof(ep->mac)); + + return 0; +} + +int var_eeprom_get_dram_size(struct var_eeprom *ep, phys_size_t *size) +{ + /* No data in EEPROM - return default DRAM size */ + if (!var_eeprom_is_valid(ep)) { + *size = DEFAULT_SDRAM_SIZE; + return 0; + } + + *size = (ep->dramsize * 128UL) << 20; + return 0; +} + +void var_eeprom_print_prod_info(struct var_eeprom *ep) +{ + if (IS_ENABLED(CONFIG_SPL_BUILD)) + return; + + flush_dcache_all(); + + if (!var_eeprom_is_valid(ep)) + return; + + if (IS_ENABLED(CONFIG_TARGET_IMX93_VAR_SOM)) + printf("\nPart number: VSM-MX93-%.*s\n", + (int)sizeof(ep->partnum), ep->partnum); + + printf("Assembly: AS%.*s\n", (int)sizeof(ep->assembly), (char *)ep->assembly); + + printf("Production date: %.*s %.*s %.*s\n", + 4, /* YYYY */ + (char *)ep->date, + 3, /* MMM */ + ((char *)ep->date) + 4, + 2, /* DD */ + ((char *)ep->date) + 4 + 3); + + printf("Serial Number: %02x:%02x:%02x:%02x:%02x:%02x\n", + ep->mac[0], ep->mac[1], ep->mac[2], ep->mac[3], ep->mac[4], ep->mac[5]); + + debug("EEPROM version: 0x%x\n", ep->version); + debug("SOM features: 0x%x\n", ep->features); + printf("SOM revision: 0x%x\n", ep->somrev); + printf("DRAM PN: VIC-%04d\n", ep->ddr_vic); + debug("DRAM size: %d GiB\n\n", (ep->dramsize * 128) / 1024); +} + +int var_carrier_eeprom_read(const char *bus_name, int addr, struct var_carrier_eeprom *ep) +{ + int ret; + struct udevice *bus; + struct udevice *dev; + + ret = uclass_get_device_by_name(UCLASS_I2C, bus_name, &bus); + if (ret) { + debug("%s: No bus '%s'\n", __func__, bus_name); + return ret; + } + + ret = dm_i2c_probe(bus, addr, 0, &dev); + if (ret) { + debug("%s: Carrier EEPROM I2C probe failed\n", __func__); + return ret; + } + + /* Read EEPROM to memory */ + ret = dm_i2c_read(dev, 0, (void *)ep, sizeof(*ep)); + if (ret) { + debug("%s: Carrier EEPROM read failed, ret=%d\n", __func__, ret); + return ret; + } + + return 0; +} + +int var_carrier_eeprom_is_valid(struct var_carrier_eeprom *ep) +{ + u32 crc, crc_offset = offsetof(struct var_carrier_eeprom, crc); + + if (htons(ep->magic) != VAR_CARRIER_EEPROM_MAGIC) { + debug("Invalid carrier EEPROM magic 0x%x, expected 0x%x\n", + htons(ep->magic), VAR_CARRIER_EEPROM_MAGIC); + return 0; + } + + if (ep->struct_ver < 1) { + printf("Invalid carrier EEPROM version 0x%x\n", ep->struct_ver); + return 0; + } + + if (ep->struct_ver == 1) + return 1; + + /* Only EEPROM structure above version 1 has CRC field */ + crc = crc32(0, (void *)ep, crc_offset); + + if (crc != ep->crc) { + printf("Carrier EEPROM CRC mismatch (%08x != %08x)\n", + crc, be32_to_cpu(ep->crc)); + return 0; + } + + return 1; +} + +/* + * Returns carrier board revision string via 'rev' argument. For legacy + * carrier board revisions the "legacy" string is returned. For new carrier + * board revisions the actual carrier revision is returned. Symphony-Board + * 1.4 and below are legacy, 1.4a and above are new. DT8MCustomBoard 1.4 and + * below are legacy, 2.0 and above are new. + * + */ +void var_carrier_eeprom_get_revision(struct var_carrier_eeprom *ep, char *rev, size_t size) +{ + if (var_carrier_eeprom_is_valid(ep)) + strlcpy(rev, (const char *)ep->carrier_rev, size); + else + strlcpy(rev, "legacy", size); +} diff --git a/board/variscite/common/imx9_eeprom.h b/board/variscite/common/imx9_eeprom.h new file mode 100644 index 00000000000..ed33368d486 --- /dev/null +++ b/board/variscite/common/imx9_eeprom.h @@ -0,0 +1,83 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2023 Variscite Ltd. + * + */ + +#ifndef _MX9_VAR_EEPROM_H_ +#define _MX9_VAR_EEPROM_H_ + +#ifdef CONFIG_ARCH_IMX9 +#include <asm/arch-imx9/ddr.h> +#endif + +#define VAR_SOM_EEPROM_MAGIC 0x4D58 /* == HEX("MX") */ + +#define VAR_SOM_EEPROM_I2C_ADDR 0x52 + +/* Optional SOM features */ +#define VAR_EEPROM_F_WIFI BIT(0) +#define VAR_EEPROM_F_ETH BIT(1) +#define VAR_EEPROM_F_AUDIO BIT(2) + +/* SOM storage types */ +enum som_storage { + SOM_STORAGE_EMMC, + SOM_STORAGE_NAND, + SOM_STORAGE_UNDEFINED, +}; + +/* Number of DRAM adjustment tables */ +#define DRAM_TABLE_NUM 7 + +struct __packed var_eeprom +{ + u16 magic; /* 00-0x00 - magic number */ + u8 partnum[8]; /* 02-0x02 - part number */ + u8 assembly[10]; /* 10-0x0a - assembly number */ + u8 date[9]; /* 20-0x14 - build date */ + u8 mac[6]; /* 29-0x1d - MAC address */ + u8 somrev; /* 35-0x23 - SOM revision */ + u8 version; /* 36-0x24 - EEPROM version */ + u8 features; /* 37-0x25 - SOM features */ + u8 dramsize; /* 38-0x26 - DRAM size */ + u8 reserved[5]; /* 39 0x27 - reserved */ + u32 ddr_crc32; /* 44-0x2c - CRC32 of DDR DATAi */ + u16 ddr_vic; /* 48-0x30 - DDR VIC PN */ + u16 off[DRAM_TABLE_NUM + 1]; /* 50-0x32 - DRAM table offsets */ +}; + +#define VAR_EEPROM_DATA ((struct var_eeprom *)VAR_EEPROM_DRAM_START) + +#define VAR_CARRIER_EEPROM_MAGIC 0x5643 /* == HEX("VC") */ + +#define CARRIER_REV_LEN 16 +struct __packed var_carrier_eeprom +{ + u16 magic; /* 00-0x00 - magic number */ + u8 struct_ver; /* 01-0x01 - EEPROM structure version */ + u8 carrier_rev[CARRIER_REV_LEN]; /* 02-0x02 - carrier board revision */ + u32 crc; /* 10-0x0a - checksum */ +}; + +static inline int var_eeprom_is_valid(struct var_eeprom *ep) +{ + if (htons(ep->magic) != VAR_SOM_EEPROM_MAGIC) { + debug("Invalid EEPROM magic 0x%x, expected 0x%x\n", + htons(ep->magic), VAR_SOM_EEPROM_MAGIC); + return 0; + } + + return 1; +} + +int var_eeprom_read_header(struct var_eeprom *e); +int var_eeprom_get_dram_size(struct var_eeprom *e, phys_size_t *size); +int var_eeprom_get_mac(struct var_eeprom *e, u8 *mac); +void var_eeprom_print_prod_info(struct var_eeprom *e); + +int var_carrier_eeprom_read(const char *bus_name, int addr, struct var_carrier_eeprom *ep); +int var_carrier_eeprom_is_valid(struct var_carrier_eeprom *ep); +void var_carrier_eeprom_get_revision(struct var_carrier_eeprom *ep, char *rev, size_t size); + +#endif /* _MX9_VAR_EEPROM_H_ */ diff --git a/board/variscite/common/mmc.c b/board/variscite/common/mmc.c new file mode 100644 index 00000000000..b24b4c98f3f --- /dev/null +++ b/board/variscite/common/mmc.c @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * Copyright 2018 NXP + * + */ +#include <common.h> +#include <command.h> +#include <asm/arch/sys_proto.h> +#include <linux/errno.h> +#include <asm/io.h> +#include <stdbool.h> +#include <mmc.h> +#include <env.h> + +static int check_mmc_autodetect(void) +{ + char *autodetect_str = env_get("mmcautodetect"); + + if (autodetect_str && (strcmp(autodetect_str, "yes") == 0)) + return 1; + + return 0; +} + +/* This should be defined for each board */ +__weak int mmc_map_to_kernel_blk(int dev_no) +{ + return dev_no; +} + +void board_late_mmc_env_init(void) +{ + char cmd[32]; + u32 dev_no = mmc_get_env_dev(); + + if (!check_mmc_autodetect()) + return; + + env_set_ulong("mmcdev", dev_no); + + /* Set mmcblk env */ + env_set_ulong("mmcblk", mmc_map_to_kernel_blk(dev_no)); + + sprintf(cmd, "mmc dev %d", dev_no); + run_command(cmd, 0); +} diff --git a/board/variscite/imx93_var_som/Kconfig b/board/variscite/imx93_var_som/Kconfig new file mode 100644 index 00000000000..f02e48d8959 --- /dev/null +++ b/board/variscite/imx93_var_som/Kconfig @@ -0,0 +1,12 @@ +if TARGET_IMX93_VAR_SOM + +config SYS_BOARD + default "imx93_var_som" + +config SYS_VENDOR + default "variscite" + +config SYS_CONFIG_NAME + default "imx93_var_som" + +endif diff --git a/board/variscite/imx93_var_som/MAINTAINERS b/board/variscite/imx93_var_som/MAINTAINERS new file mode 100644 index 00000000000..7ddaaac14b2 --- /dev/null +++ b/board/variscite/imx93_var_som/MAINTAINERS @@ -0,0 +1,7 @@ +ARM i.MX93 VARISCITE VAR-SOM-MX93 MODULE +M: Mathieu Othacehe m.othacehe@gmail.com +S: Maintained +F: arch/arm/dts/imx93-var-som* +F: board/variscite/imx93_var_som/ +F: configs/imx93_var_som_defconfig +F: include/configs/imx93_var_som.h diff --git a/board/variscite/imx93_var_som/Makefile b/board/variscite/imx93_var_som/Makefile new file mode 100644 index 00000000000..b63883901bd --- /dev/null +++ b/board/variscite/imx93_var_som/Makefile @@ -0,0 +1,17 @@ +# +# Copyright 2022 NXP +# Copyright 2023 Variscite Ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += imx93_var_som.o +obj-$(CONFIG_TARGET_IMX93_VAR_SOM) += ../common/imx9_eeprom.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_TARGET_IMX93_VAR_SOM) += lpddr4x_timing.o +else +obj-y += ../common/eth.o +obj-y += ../common/mmc.o +endif diff --git a/board/variscite/imx93_var_som/container.cfg b/board/variscite/imx93_var_som/container.cfg new file mode 100644 index 00000000000..f268bc9eb2c --- /dev/null +++ b/board/variscite/imx93_var_som/container.cfg @@ -0,0 +1,10 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2023 Mathieu Othacehe m.othacehe@gmail.com + */ + +BOOT_FROM SD 0x400 +SOC_TYPE IMX9 +CONTAINER +IMAGE A55 bl31.bin 0x204E0000 +IMAGE A55 u-boot.bin CONFIG_TEXT_BASE \ No newline at end of file diff --git a/board/variscite/imx93_var_som/imx93_var_som.c b/board/variscite/imx93_var_som/imx93_var_som.c new file mode 100644 index 00000000000..251c2e9d0f8 --- /dev/null +++ b/board/variscite/imx93_var_som/imx93_var_som.c @@ -0,0 +1,126 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 NXP + * Copyright 2023 Variscite Ltd. + */ + +#include <common.h> +#include <env.h> +#include <init.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/global_data.h> +#include <asm/arch-imx9/ccm_regs.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch-imx9/imx93_pins.h> +#include <asm/arch/clock.h> +#include <power/pmic.h> +#include <dm/device.h> +#include <dm/uclass.h> +#include <usb.h> +#include <dwc3-uboot.h> + +#include "../common/imx9_eeprom.h" +#include "../common/eth.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define CARRIER_EEPROM_ADDR 0x54 + +#define UART_PAD_CTRL (PAD_CTL_DSE(6) | PAD_CTL_FSEL2) +#define WDOG_PAD_CTRL (PAD_CTL_DSE(6) | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +static const iomux_v3_cfg_t uart_pads[] = { + MX93_PAD_UART1_RXD__LPUART1_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX93_PAD_UART1_TXD__LPUART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + init_uart_clk(LPUART1_CLK_ROOT); + + return 0; +} + +int board_phys_sdram_size(phys_size_t *size) +{ + struct var_eeprom *ep = VAR_EEPROM_DATA; + + var_eeprom_get_dram_size(ep, size); + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +static int setup_eqos(void) +{ + struct blk_ctrl_wakeupmix_regs *bctrl = + (struct blk_ctrl_wakeupmix_regs *)BLK_CTRL_WAKEUPMIX_BASE_ADDR; + + /* set INTF as RGMII, enable RGMII TXC clock */ + clrsetbits_le32(&bctrl->eqos_gpr, + BCTRL_GPR_ENET_QOS_INTF_MODE_MASK, + BCTRL_GPR_ENET_QOS_INTF_SEL_RGMII | BCTRL_GPR_ENET_QOS_CLK_GEN_EN); + + return set_clk_eqos(ENET_125MHZ); +} + +int board_init(void) +{ + set_clk_enet(ENET_125MHZ); + + if (CONFIG_IS_ENABLED(DWC_ETH_QOS)) + setup_eqos(); + + return 0; +} + +#define SDRAM_SIZE_STR_LEN 5 + +int board_late_init(void) +{ + struct var_eeprom *ep = VAR_EEPROM_DATA; + char sdram_size_str[SDRAM_SIZE_STR_LEN]; + struct var_carrier_eeprom carrier_eeprom; + char carrier_rev[CARRIER_REV_LEN] = {0}; + char som_rev[CARRIER_REV_LEN] = {0}; + + var_setup_mac(ep); + var_eeprom_print_prod_info(ep); + + /* ENV Variables */ + + /* SDRAM ENV */ + snprintf(sdram_size_str, SDRAM_SIZE_STR_LEN, "%d", + (int)(gd->ram_size / 1024 / 1024)); + env_set("sdram_size", sdram_size_str); + + /* Carrier Board ENV */ + var_carrier_eeprom_read(VAR_CARRIER_EEPROM_I2C_NAME, CARRIER_EEPROM_ADDR, &carrier_eeprom); + var_carrier_eeprom_get_revision(&carrier_eeprom, carrier_rev, sizeof(carrier_rev)); + env_set("carrier_rev", carrier_rev); + + /* SoM Rev ENV */ + snprintf(som_rev, CARRIER_REV_LEN, "som_rev1%d", ep->somrev); + env_set("som_rev", som_rev); + + if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC)) + board_late_mmc_env_init(); + + env_set("sec_boot", "no"); + if (IS_ENABLED(CONFIG_AHAB_BOOT)) + env_set("sec_boot", "yes"); + + if (IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG)) + env_set("board_name", "VAR-SOM-MX93"); + + return 0; +} diff --git a/board/variscite/imx93_var_som/imx93_var_som.env b/board/variscite/imx93_var_som/imx93_var_som.env new file mode 100644 index 00000000000..84814e6d935 --- /dev/null +++ b/board/variscite/imx93_var_som/imx93_var_som.env @@ -0,0 +1,104 @@ +initrd_addr=0x83800000 +emmc_dev=0 +sd_dev=1 +scriptaddr=0x83500000 +kernel_addr_r= __stringify(CONFIG_SYS_LOAD_ADDR) +image=Image.gz +img_addr=0x82000000 +splashimage=0x90000000 +console=ttyLP0,115200 earlycon +fdt_addr_r=0x83000000 +fdt_addr=0x83000000 +cntr_addr=0x98000000 +cntr_file=os_cntr_signed.bin +boot_fit=no +bootdir=/boot +fdt_file=undefined +bootm_size=0x10000000 +mmcdev=0 +mmcpart=1 +mmcautodetect=yes +optargs=setenv bootargs ${bootargs} ${kernelargs}; +mmcroot=root=/dev/mmcblk0p1 +mmcargs=setenv bootargs ${jh_clk} console=${console} ${mmcroot} rootwait rw +loadbootscript=load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${bootdir}/${script}; +bootscript=echo Running bootscript from mmc ...; source +loadimage=load mmc ${mmcdev}:${mmcpart} ${img_addr} ${bootdir}/${image}; + unzip ${img_addr} ${loadaddr} +findfdt=if test $fdt_file = undefined; then + setenv fdt_file CONFIG_DEFAULT_FDT_FILE ; + fi; + echo fdt_file=${fdt_file}; +loadfdt=run findfdt;load mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} ${bootdir}/${fdt_file} +loadcntr=fatload mmc ${mmcdev}:${mmcpart} ${cntr_addr} ${cntr_file} +auth_os=auth_cntr ${cntr_addr} +boot_os=booti ${loadaddr} - ${fdt_addr_r}; +mmcboot=echo Booting from mmc ...; + run mmcargs; + run optargs; + if test ${sec_boot} = yes; then + if run auth_os; then + "run boot_os; + else + "echo ERR: failed to authenticate; + fi; + else + if test ${boot_fit} = yes || test ${boot_fit} = try; then + bootm ${loadaddr}; + else + if run loadfdt; then + run boot_os; + else + echo WARN: Cannot load the DT; + fi; + fi; + fi; +netargs=setenv bootargs ${jh_clk} console=${console} + root=/dev/nfs + ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp + etboot=echo Booting from net ...; + run netargs; + run optargs; + if test ${ip_dyn} = yes; then + setenv get_cmd dhcp; + else + setenv get_cmd tftp; + fi; + if test ${sec_boot} = yes; then + ${get_cmd} ${cntr_addr} ${cntr_file}; + if run auth_os; then + "run boot_os; + else + "echo ERR: failed to authenticate; + fi; + else + ${get_cmd} ${img_addr} ${image}; unzip ${img_addr} ${loadaddr}; + if test ${boot_fit} = yes || test ${boot_fit} = try; then + bootm ${loadaddr}; + else + run findfdt; + if ${get_cmd} ${fdt_addr_r} ${fdt_file}; then + run boot_os; + else + echo WARN: Cannot load the DT; + fi; + fi; + fi; +bsp_bootcmd=echo Running BSP bootcmd ...; + mmc dev ${mmcdev}; if mmc rescan; then + if run loadbootscript; then + run bootscript; + else + if test ${sec_boot} = yes; then + if run loadcntr; then + run mmcboot; + else run netboot; + fi; + else + if run loadimage; then + run mmcboot; + else run netboot; + fi; + fi; + fi; + fi; diff --git a/board/variscite/imx93_var_som/imximage.cfg b/board/variscite/imx93_var_som/imximage.cfg new file mode 100644 index 00000000000..3e440465b23 --- /dev/null +++ b/board/variscite/imx93_var_som/imximage.cfg @@ -0,0 +1,10 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2023 Mathieu Othacehe m.othacehe@gmail.com + */ + +BOOT_FROM SD 0x400 +SOC_TYPE IMX9 +APPEND mx93a0-ahab-container.img +CONTAINER +IMAGE A55 u-boot-spl-ddr.bin 0x2049A000 \ No newline at end of file diff --git a/board/variscite/imx93_var_som/lpddr4x_timing.c b/board/variscite/imx93_var_som/lpddr4x_timing.c new file mode 100644 index 00000000000..a64b9045e24 --- /dev/null +++ b/board/variscite/imx93_var_som/lpddr4x_timing.c @@ -0,0 +1,1489 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2023 NXP + * + * Code generated with DDR Tool. + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x4e300110, 0x44100001 }, + { 0x4e300000, 0x8000ff }, + { 0x4e300008, 0x0 }, + { 0x4e300080, 0x80000512 }, + { 0x4e300084, 0x0 }, + { 0x4e300100, 0x24ab321b }, + { 0x4e300104, 0xa8ee001b }, + { 0x4e300108, 0x2f2ee233 }, + { 0x4e30010c, 0x5e18b }, + { 0x4e300114, 0x1002 }, + { 0x4e300124, 0x1c770000 }, + { 0x4e300160, 0x5402 }, + { 0x4e30016c, 0x35f00000 }, + { 0x4e300170, 0x8b0b0608 }, + { 0x4e300250, 0x28 }, + { 0x4e300254, 0x0 }, + { 0x4e30025c, 0x400 }, + { 0x4e300260, 0x800 }, + { 0x4e300300, 0x14281114 }, + { 0x4e300304, 0x163110a }, + { 0x4e300308, 0xa200e3c }, + { 0x4e300f04, 0x80 }, + { 0x4e300800, 0x43b30002 }, + { 0x4e300804, 0x1f1f1f1f }, + { 0x4e301000, 0x0 }, + +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x4 }, + { 0x100a1, 0x5 }, + { 0x100a2, 0x6 }, + { 0x100a3, 0x7 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x1 }, + { 0x100a6, 0x2 }, + { 0x100a7, 0x3 }, + { 0x110a0, 0x3 }, + { 0x110a1, 0x2 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x1 }, + { 0x110a4, 0x7 }, + { 0x110a5, 0x6 }, + { 0x110a6, 0x4 }, + { 0x110a7, 0x5 }, + { 0x1005f, 0x5ff }, + { 0x1015f, 0x5ff }, + { 0x1105f, 0x5ff }, + { 0x1115f, 0x5ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x2002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x20024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x2007d, 0x212 }, + { 0x2007c, 0x61 }, + { 0x20056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x10049, 0xe00 }, + { 0x10149, 0xe00 }, + { 0x11049, 0xe00 }, + { 0x11149, 0xe00 }, + { 0x43, 0x60 }, + { 0x1043, 0x60 }, + { 0x2043, 0x60 }, + { 0x20018, 0x1 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x2009b, 0x2 }, + { 0x20008, 0x3a5 }, + { 0x20088, 0x9 }, + { 0x200b2, 0x10c }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x200fa, 0x2 }, + { 0x20019, 0x1 }, + { 0x200f0, 0x0 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5555 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x1004a, 0x500 }, + { 0x1104a, 0x500 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x2002c, 0x0 }, + +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, + +}; + +/* P0 message block parameter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xe94 }, + { 0x54004, 0x4 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x15 }, + { 0x54008, 0x131f }, + { 0x54009, 0xff }, + { 0x5400b, 0x4 }, + { 0x5400c, 0x1 }, + { 0x5400d, 0x100 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x36e4 }, + { 0x5401a, 0x32 }, + { 0x5401b, 0x1146 }, + { 0x5401c, 0x1108 }, + { 0x5401e, 0x6 }, + { 0x5401f, 0x36e4 }, + { 0x54020, 0x32 }, + { 0x54021, 0x1146 }, + { 0x54022, 0x1108 }, + { 0x54024, 0x6 }, + { 0x54032, 0xe400 }, + { 0x54033, 0x3236 }, + { 0x54034, 0x4600 }, + { 0x54035, 0x811 }, + { 0x54036, 0x11 }, + { 0x54037, 0x600 }, + { 0x54038, 0xe400 }, + { 0x54039, 0x3236 }, + { 0x5403a, 0x4600 }, + { 0x5403b, 0x811 }, + { 0x5403c, 0x11 }, + { 0x5403d, 0x600 }, + { 0xd0000, 0x1} +}; + +/* P0 2D message block parameter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xe94 }, + { 0x54004, 0x4 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x15 }, + { 0x54008, 0x61 }, + { 0x54009, 0xff }, + { 0x5400b, 0x4 }, + { 0x5400c, 0x1 }, + { 0x5400d, 0x100 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x2080 }, + { 0x54012, 0x110 }, + { 0x54019, 0x36e4 }, + { 0x5401a, 0x32 }, + { 0x5401b, 0x1146 }, + { 0x5401c, 0x1108 }, + { 0x5401e, 0x6 }, + { 0x5401f, 0x36e4 }, + { 0x54020, 0x32 }, + { 0x54021, 0x1146 }, + { 0x54022, 0x1108 }, + { 0x54024, 0x6 }, + { 0x54032, 0xe400 }, + { 0x54033, 0x3236 }, + { 0x54034, 0x4600 }, + { 0x54035, 0x811 }, + { 0x54036, 0x11 }, + { 0x54037, 0x600 }, + { 0x54038, 0xe400 }, + { 0x54039, 0x3236 }, + { 0x5403a, 0x4600 }, + { 0x5403b, 0x811 }, + { 0x5403c, 0x11 }, + { 0x5403d, 0x600 }, + { 0xd0000, 0x1} +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xb }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x633 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x633 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x633 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x30 }, + { 0x90051, 0x65a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x45a }, + { 0x90055, 0x9 }, + { 0x90056, 0x0 }, + { 0x90057, 0x448 }, + { 0x90058, 0x109 }, + { 0x90059, 0x40 }, + { 0x9005a, 0x633 }, + { 0x9005b, 0x179 }, + { 0x9005c, 0x1 }, + { 0x9005d, 0x618 }, + { 0x9005e, 0x109 }, + { 0x9005f, 0x40c0 }, + { 0x90060, 0x633 }, + { 0x90061, 0x149 }, + { 0x90062, 0x8 }, + { 0x90063, 0x4 }, + { 0x90064, 0x48 }, + { 0x90065, 0x4040 }, + { 0x90066, 0x633 }, + { 0x90067, 0x149 }, + { 0x90068, 0x0 }, + { 0x90069, 0x4 }, + { 0x9006a, 0x48 }, + { 0x9006b, 0x40 }, + { 0x9006c, 0x633 }, + { 0x9006d, 0x149 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x658 }, + { 0x90070, 0x109 }, + { 0x90071, 0x10 }, + { 0x90072, 0x4 }, + { 0x90073, 0x18 }, + { 0x90074, 0x0 }, + { 0x90075, 0x4 }, + { 0x90076, 0x78 }, + { 0x90077, 0x549 }, + { 0x90078, 0x633 }, + { 0x90079, 0x159 }, + { 0x9007a, 0xd49 }, + { 0x9007b, 0x633 }, + { 0x9007c, 0x159 }, + { 0x9007d, 0x94a }, + { 0x9007e, 0x633 }, + { 0x9007f, 0x159 }, + { 0x90080, 0x441 }, + { 0x90081, 0x633 }, + { 0x90082, 0x149 }, + { 0x90083, 0x42 }, + { 0x90084, 0x633 }, + { 0x90085, 0x149 }, + { 0x90086, 0x1 }, + { 0x90087, 0x633 }, + { 0x90088, 0x149 }, + { 0x90089, 0x0 }, + { 0x9008a, 0xe0 }, + { 0x9008b, 0x109 }, + { 0x9008c, 0xa }, + { 0x9008d, 0x10 }, + { 0x9008e, 0x109 }, + { 0x9008f, 0x9 }, + { 0x90090, 0x3c0 }, + { 0x90091, 0x149 }, + { 0x90092, 0x9 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x159 }, + { 0x90095, 0x18 }, + { 0x90096, 0x10 }, + { 0x90097, 0x109 }, + { 0x90098, 0x0 }, + { 0x90099, 0x3c0 }, + { 0x9009a, 0x109 }, + { 0x9009b, 0x18 }, + { 0x9009c, 0x4 }, + { 0x9009d, 0x48 }, + { 0x9009e, 0x18 }, + { 0x9009f, 0x4 }, + { 0x900a0, 0x58 }, + { 0x900a1, 0xb }, + { 0x900a2, 0x10 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0x1 }, + { 0x900a5, 0x10 }, + { 0x900a6, 0x109 }, + { 0x900a7, 0x5 }, + { 0x900a8, 0x7c0 }, + { 0x900a9, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x625 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x625 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900aa, 0x0 }, + { 0x900ab, 0x790 }, + { 0x900ac, 0x11a }, + { 0x900ad, 0x8 }, + { 0x900ae, 0x7aa }, + { 0x900af, 0x2a }, + { 0x900b0, 0x10 }, + { 0x900b1, 0x7b2 }, + { 0x900b2, 0x2a }, + { 0x900b3, 0x0 }, + { 0x900b4, 0x7c8 }, + { 0x900b5, 0x109 }, + { 0x900b6, 0x10 }, + { 0x900b7, 0x10 }, + { 0x900b8, 0x109 }, + { 0x900b9, 0x10 }, + { 0x900ba, 0x2a8 }, + { 0x900bb, 0x129 }, + { 0x900bc, 0x8 }, + { 0x900bd, 0x370 }, + { 0x900be, 0x129 }, + { 0x900bf, 0xa }, + { 0x900c0, 0x3c8 }, + { 0x900c1, 0x1a9 }, + { 0x900c2, 0xc }, + { 0x900c3, 0x408 }, + { 0x900c4, 0x199 }, + { 0x900c5, 0x14 }, + { 0x900c6, 0x790 }, + { 0x900c7, 0x11a }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x4 }, + { 0x900ca, 0x18 }, + { 0x900cb, 0xe }, + { 0x900cc, 0x408 }, + { 0x900cd, 0x199 }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x8568 }, + { 0x900d0, 0x108 }, + { 0x900d1, 0x18 }, + { 0x900d2, 0x790 }, + { 0x900d3, 0x16a }, + { 0x900d4, 0x8 }, + { 0x900d5, 0x1d8 }, + { 0x900d6, 0x169 }, + { 0x900d7, 0x10 }, + { 0x900d8, 0x8558 }, + { 0x900d9, 0x168 }, + { 0x900da, 0x1ff8 }, + { 0x900db, 0x85a8 }, + { 0x900dc, 0x1e8 }, + { 0x900dd, 0x50 }, + { 0x900de, 0x798 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x60 }, + { 0x900e1, 0x7a0 }, + { 0x900e2, 0x16a }, + { 0x900e3, 0x8 }, + { 0x900e4, 0x8310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0x8 }, + { 0x900e7, 0xa310 }, + { 0x900e8, 0x168 }, + { 0x900e9, 0xa }, + { 0x900ea, 0x408 }, + { 0x900eb, 0x169 }, + { 0x900ec, 0x6e }, + { 0x900ed, 0x0 }, + { 0x900ee, 0x68 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x408 }, + { 0x900f1, 0x169 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0x8310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x0 }, + { 0x900f6, 0xa310 }, + { 0x900f7, 0x168 }, + { 0x900f8, 0x1ff8 }, + { 0x900f9, 0x85a8 }, + { 0x900fa, 0x1e8 }, + { 0x900fb, 0x68 }, + { 0x900fc, 0x798 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x78 }, + { 0x900ff, 0x7a0 }, + { 0x90100, 0x16a }, + { 0x90101, 0x68 }, + { 0x90102, 0x790 }, + { 0x90103, 0x16a }, + { 0x90104, 0x8 }, + { 0x90105, 0x8b10 }, + { 0x90106, 0x168 }, + { 0x90107, 0x8 }, + { 0x90108, 0xab10 }, + { 0x90109, 0x168 }, + { 0x9010a, 0xa }, + { 0x9010b, 0x408 }, + { 0x9010c, 0x169 }, + { 0x9010d, 0x58 }, + { 0x9010e, 0x0 }, + { 0x9010f, 0x68 }, + { 0x90110, 0x0 }, + { 0x90111, 0x408 }, + { 0x90112, 0x169 }, + { 0x90113, 0x0 }, + { 0x90114, 0x8b10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x1 }, + { 0x90117, 0xab10 }, + { 0x90118, 0x168 }, + { 0x90119, 0x0 }, + { 0x9011a, 0x1d8 }, + { 0x9011b, 0x169 }, + { 0x9011c, 0x80 }, + { 0x9011d, 0x790 }, + { 0x9011e, 0x16a }, + { 0x9011f, 0x18 }, + { 0x90120, 0x7aa }, + { 0x90121, 0x6a }, + { 0x90122, 0xa }, + { 0x90123, 0x0 }, + { 0x90124, 0x1e9 }, + { 0x90125, 0x8 }, + { 0x90126, 0x8080 }, + { 0x90127, 0x108 }, + { 0x90128, 0xf }, + { 0x90129, 0x408 }, + { 0x9012a, 0x169 }, + { 0x9012b, 0xc }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x68 }, + { 0x9012e, 0x9 }, + { 0x9012f, 0x0 }, + { 0x90130, 0x1a9 }, + { 0x90131, 0x0 }, + { 0x90132, 0x408 }, + { 0x90133, 0x169 }, + { 0x90134, 0x0 }, + { 0x90135, 0x8080 }, + { 0x90136, 0x108 }, + { 0x90137, 0x8 }, + { 0x90138, 0x7aa }, + { 0x90139, 0x6a }, + { 0x9013a, 0x0 }, + { 0x9013b, 0x8568 }, + { 0x9013c, 0x108 }, + { 0x9013d, 0xb7 }, + { 0x9013e, 0x790 }, + { 0x9013f, 0x16a }, + { 0x90140, 0x1f }, + { 0x90141, 0x0 }, + { 0x90142, 0x68 }, + { 0x90143, 0x8 }, + { 0x90144, 0x8558 }, + { 0x90145, 0x168 }, + { 0x90146, 0xf }, + { 0x90147, 0x408 }, + { 0x90148, 0x169 }, + { 0x90149, 0xd }, + { 0x9014a, 0x0 }, + { 0x9014b, 0x68 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x408 }, + { 0x9014e, 0x169 }, + { 0x9014f, 0x0 }, + { 0x90150, 0x8558 }, + { 0x90151, 0x168 }, + { 0x90152, 0x8 }, + { 0x90153, 0x3c8 }, + { 0x90154, 0x1a9 }, + { 0x90155, 0x3 }, + { 0x90156, 0x370 }, + { 0x90157, 0x129 }, + { 0x90158, 0x20 }, + { 0x90159, 0x2aa }, + { 0x9015a, 0x9 }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x104 }, + { 0x90164, 0x8 }, + { 0x90165, 0x448 }, + { 0x90166, 0x109 }, + { 0x90167, 0xf }, + { 0x90168, 0x7c0 }, + { 0x90169, 0x109 }, + { 0x9016a, 0x0 }, + { 0x9016b, 0xe8 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0x47 }, + { 0x9016e, 0x630 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x8 }, + { 0x90171, 0x618 }, + { 0x90172, 0x109 }, + { 0x90173, 0x8 }, + { 0x90174, 0xe0 }, + { 0x90175, 0x109 }, + { 0x90176, 0x0 }, + { 0x90177, 0x7c8 }, + { 0x90178, 0x109 }, + { 0x90179, 0x8 }, + { 0x9017a, 0x8140 }, + { 0x9017b, 0x10c }, + { 0x9017c, 0x0 }, + { 0x9017d, 0x478 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x0 }, + { 0x90180, 0x1 }, + { 0x90181, 0x8 }, + { 0x90182, 0x8 }, + { 0x90183, 0x4 }, + { 0x90184, 0x0 }, + { 0x90006, 0x8 }, + { 0x90007, 0x7c8 }, + { 0x90008, 0x109 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x400 }, + { 0x9000b, 0x106 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2b }, + { 0x90026, 0x69 }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x200be, 0x3 }, + { 0x2000b, 0x75 }, + { 0x2000c, 0xe9 }, + { 0x2000d, 0x91c }, + { 0x2000e, 0x2c }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x2060 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x400fd, 0xf }, + { 0x400f1, 0xe }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x0 }, + { 0xd0000, 0x1 }, +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3733mts 1D */ + .drate = 3733, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P0 3733mts 2D */ + .drate = 3733, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3733, }, +}; + diff --git a/board/variscite/imx93_var_som/spl.c b/board/variscite/imx93_var_som/spl.c new file mode 100644 index 00000000000..abc174dc49e --- /dev/null +++ b/board/variscite/imx93_var_som/spl.c @@ -0,0 +1,144 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 NXP + * Copyright 2023 Variscite Ltd. + */ + +#include <common.h> +#include <command.h> +#include <cpu_func.h> +#include <hang.h> +#include <image.h> +#include <init.h> +#include <log.h> +#include <spl.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/arch/imx93_pins.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <asm/arch-mx7ulp/gpio.h> +#include <asm/mach-imx/syscounter.h> +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> +#include <linux/delay.h> +#include <asm/arch/clock.h> +#include <asm/arch/ccm_regs.h> +#include <asm/arch/ddr.h> +#include <power/pmic.h> +#include <power/pca9450.h> +#include <asm/arch/trdc.h> + +#include "../common/imx9_eeprom.h" + +DECLARE_GLOBAL_DATA_PTR; + +static struct var_eeprom eeprom = {0}; + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + return BOOT_DEVICE_BOOTROM; +} + +void spl_board_init(void) +{ + struct var_eeprom *ep = VAR_EEPROM_DATA; + + puts("Normal Boot\n"); + + /* Copy EEPROM contents to DRAM */ + memcpy(ep, &eeprom, sizeof(*ep)); +} + +void spl_dram_init(void) +{ + /* EEPROM initialization */ + var_eeprom_read_header(&eeprom); + + ddr_init(&dram_timing); +} + +int power_init_board(void) +{ + struct udevice *dev; + int ret; + + if (IS_ENABLED(CONFIG_SPL_DM_PMIC_PCA9450)) { + ret = pmic_get("pmic@25", &dev); + if (ret == -ENODEV) { + puts("No pca9450@25\n"); + return 0; + } + if (ret != 0) + return ret; + + /* BUCKxOUT_DVS0/1 control BUCK123 output */ + pmic_reg_write(dev, PCA9450_BUCK123_DVS, 0x29); + + /* enable DVS control through PMIC_STBY_REQ */ + pmic_reg_write(dev, PCA9450_BUCK1CTRL, 0x59); + + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS0, 0x18); + pmic_reg_write(dev, PCA9450_BUCK3OUT_DVS0, 0x18); + + /* set standby voltage to 0.65V */ + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS1, 0x4); + + /* I2C_LT_EN*/ + pmic_reg_write(dev, 0xa, 0x3); + + /* set WDOG_B_CFG to cold reset */ + pmic_reg_write(dev, PCA9450_RESET_CTRL, 0xA1); + } + + return 0; +} + +void board_init_f(ulong dummy) +{ + int ret; + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + timer_init(); + + arch_cpu_init(); + + board_early_init_f(); + + spl_early_init(); + + preloader_console_init(); + + ret = arch_cpu_init(); + if (ret) { + printf("Fail to init Sentinel API\n"); + } else { + printf("SOC: 0x%x\n", gd->arch.soc_rev); + printf("LC: 0x%x\n", gd->arch.lifecycle); + } + power_init_board(); + + set_arm_core_max_clk(); + + /* Init power of mix */ + soc_power_init(); + + /* Setup TRDC for DDR access */ + trdc_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Put M33 into CPUWAIT for following kick */ + ret = m33_prepare(); + if (!ret) + printf("M33 prepare ok\n"); + + board_init_r(NULL, 0); +} diff --git a/configs/imx93_var_som_defconfig b/configs/imx93_var_som_defconfig new file mode 100644 index 00000000000..bbe62c2c89c --- /dev/null +++ b/configs/imx93_var_som_defconfig @@ -0,0 +1,156 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX9=y +CONFIG_TEXT_BASE=0x80200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x18000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SYS_MEMTEST_START=0x80000000 +CONFIG_SYS_MEMTEST_END=0x90000000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x700000 +CONFIG_IMX_CONFIG="board/variscite/imx93_var_som/imximage.cfg" +CONFIG_IMX_CONTAINER_CFG="board/variscite/imx93_var_som/container.cfg" +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx93-var-som-symphony" +CONFIG_SPL_TEXT_BASE=0x2049A000 +CONFIG_TARGET_IMX93_VAR_SOM=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK=0x20519dd0 +CONFIG_SPL=y +CONFIG_CMD_DEKBLOB=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x88000000 +CONFIG_SPL_LOAD_IMX_CONTAINER=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_REMAKE_ELF=y +CONFIG_SYS_LOAD_ADDR=0x80400000 +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTDELAY=1 +CONFIG_BOOTCOMMAND="run bsp_bootcmd" +CONFIG_DEFAULT_FDT_FILE="imx93-var-som-symphony.dtb" +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x2051a000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x83200000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_PBSIZE=2074 +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CMD_NET=y +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_EEPROM=y +CONFIG_SYS_I2C_EEPROM_BUS=3 +CONFIG_SYS_EEPROM_SIZE=512 +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=4 +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=100 +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_POWEROFF=y +CONFIG_BOOTP_PREFER_SERVERIP=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_HASH=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SYSCON=y +CONFIG_SPL_CLK_IMX93=y +CONFIG_CLK_IMX93=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_FASTBOOT_BUF_ADDR=0x82800000 +CONFIG_FASTBOOT_BUF_SIZE=0x20000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 +CONFIG_GPIO_HOG=y +CONFIG_IMX_RGPIO2P=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_PHY_ADIN=y +CONFIG_PHY_ATHEROS=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_DM_ETH_PHY=y +CONFIG_PHY_GIGE=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_IMX=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_MIPI_DPHY_HELPERS=y +CONFIG_PHY_IMX93_MIPI_DPHY=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX93=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX93_BLK_CTRL=y +CONFIG_DM_PMIC=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_RTC_EMULATION=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y +CONFIG_CI_UDC=y +CONFIG_ULP_WATCHDOG=y +CONFIG_LZO=y +CONFIG_BZIP2=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_WATCHDOG=y +CONFIG_WDT=y +CONFIG_CMD_WDT=y +CONFIG_ETHPRIME="eth0" +CONFIG_SYS_I2C_SPEED=100000 +CONFIG_IMX_BOOTAUX=y +CONFIG_CMD_READ=y +CONFIG_SERIAL_TAG=y \ No newline at end of file diff --git a/doc/board/variscite/imx93_var_som.rst b/doc/board/variscite/imx93_var_som.rst new file mode 100644 index 00000000000..87c353f9311 --- /dev/null +++ b/doc/board/variscite/imx93_var_som.rst @@ -0,0 +1,68 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +imx93_var_som +======================= + +U-Boot for the Variscite VAR-SOM-MX93 Symphony evaluation board + +Quick Start +----------- + +- Get and Build the ARM Trusted firmware +- Get the DDR firmware +- Get ahab-container.img +- Build U-Boot +- Boot + +Get and Build the ARM Trusted firmware +-------------------------------------- + +Note: srctree is U-Boot source directory +Get ATF from: https://github.com/varigit/imx-atf +branch: lf_v2.8_var02 + +.. code-block:: bash + + $ unset LDFLAGS + $ make PLAT=imx93 bl31 + $ cp build/imx93/release/bl31.bin $(srctree) + +Get the DDR firmware +-------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.21.bin + $ chmod +x firmware-imx-8.21.bin + $ ./firmware-imx-8.21.bin + $ cp firmware-imx-8.21/firmware/ddr/synopsys/lpddr4*.bin $(srctree) + +Get ahab-container.img +--------------------------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-sentinel-0.10.bin + $ chmod +x firmware-sentinel-0.10.bin + $ ./firmware-sentinel-0.10.bin + $ cp firmware-sentinel-0.10/mx93a0-ahab-container.img $(srctree) + +Build U-Boot +------------ + +.. code-block:: bash + + $ export CROSS_COMPILE=aarch64-poky-linux- + $ make imx93_var_som_defconfig + $ make + +Burn the flash.bin to MicroSD card offset 32KB: + +.. code-block:: bash + + $ dd if=flash.bin of=/dev/sd[x] bs=1024 seek=32 conv=notrunc + +Boot +---- + +Set Boot switch to SD boot diff --git a/doc/board/variscite/index.rst b/doc/board/variscite/index.rst index 4186896b66d..f84ebe7eb62 100644 --- a/doc/board/variscite/index.rst +++ b/doc/board/variscite/index.rst @@ -7,3 +7,4 @@ Variscite :maxdepth: 2
imx8mn_var_som + imx93_var_som diff --git a/include/configs/imx93_var_som.h b/include/configs/imx93_var_som.h new file mode 100644 index 00000000000..18a8ee5deed --- /dev/null +++ b/include/configs/imx93_var_som.h @@ -0,0 +1,48 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2022 NXP + * Copyright 2023 Variscite Ltd. + */ + +#ifndef __IMX93_VAR_SOM_H +#define __IMX93_VAR_SOM_H + +#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h> + +#define CFG_SYS_SDRAM_BASE 0x80000000 +#define CFG_SYS_UBOOT_BASE \ + (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) + +#include <config_distro_bootcmd.h> + +/* Initial environment variables */ +#define CFG_EXTRA_ENV_SETTINGS BOOTENV + +#define CFG_SYS_INIT_RAM_ADDR 0x80000000 +#define CFG_SYS_INIT_RAM_SIZE 0x200000 + +#define CFG_SYS_SDRAM_BASE 0x80000000 +#define PHYS_SDRAM 0x80000000 +#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */ + +#define DEFAULT_SDRAM_SIZE (512 * SZ_1M) /* 512MB Minimum DDR4, see get_dram_size */ +#define VAR_EEPROM_DRAM_START (PHYS_SDRAM + (DEFAULT_SDRAM_SIZE >> 1)) +#define VAR_SOM_EEPROM_I2C_NAME "i2c@42530000" +#define VAR_CARRIER_EEPROM_I2C_NAME "i2c@44340000" + +#define CFG_SYS_FSL_USDHC_NUM 2 + +/* Using ULP WDOG for reset */ +#define WDOG_BASE_ADDR WDG3_BASE_ADDR + +#if defined(CONFIG_CMD_NET) +#define PHY_ANEG_TIMEOUT 20000 +#endif + +#endif
Hi Mathieu,
On Fri, Dec 29, 2023 at 8:17 AM Mathieu Othacehe othacehe@gnu.org wrote:
Add support for the Variscite VAR-SOM-IMX93 evaluation kit. The SoM consists of an NXP iMX93 dual A55 CPU. The SoM is mounted on a Variscite Symphony SBC.
Signed-off-by: Mathieu Othacehe m.othacehe@gmail.com
I applied this patch against U-Boot's next branch.
I had to manually add:
--- a/board/variscite/imx93_var_som/spl.c +++ b/board/variscite/imx93_var_som/spl.c @@ -21,6 +21,7 @@ #include <asm/mach-imx/mxc_i2c.h> #include <asm/arch-mx7ulp/gpio.h> #include <asm/mach-imx/syscounter.h> +#include <asm/sections.h> #include <dm/uclass.h> #include <dm/device.h> #include <dm/uclass-internal.h>
so that it can be built.
Also noticed some checkpatch warnings:
ERROR: Do not add common.h to files #802: FILE: board/variscite/common/eth.c:5: +#include <common.h>
ERROR: Do not add common.h to files #886: FILE: board/variscite/common/imx9_eeprom.c:6: +#include <common.h>
ERROR: Do not add common.h to files #1172: FILE: board/variscite/common/mmc.c:7: +#include <common.h>
ERROR: Do not add common.h to files #1296: FILE: board/variscite/imx93_var_som/imx93_var_som.c:7: +#include <common.h>
ERROR: Do not add common.h to files #3050: FILE: board/variscite/imx93_var_som/spl.c:7: +#include <common.h>
and also got a warning when applying it:
$ git am ~/Downloads/Add-imx93-var-som-support.patch Applying: spl: binman: Disable u_boot_any symbols for i.MX93 boards Applying: mach-imx: Add i.MX93 binman support. Applying: Add imx93-var-som support .git/rebase-apply/patch:3025: new blank line at EOF. + warning: 1 line adds whitespace errors.
--- /dev/null +++ b/arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi @@ -0,0 +1,253 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright 2022 NXP
- Copyright 2023 Variscite Ltd.
+#include "imx93-u-boot.dtsi"
This file should be included by default. No need to manually include it.
diff --git a/board/variscite/common/eth.c b/board/variscite/common/eth.c new file mode 100644 index 00000000000..9e05dee51c2 --- /dev/null +++ b/board/variscite/common/eth.c @@ -0,0 +1,59 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <common.h> +#include <net.h> +#include <miiphy.h> +#include <env.h> +#include "../common/imx9_eeprom.h"
+#define CHAR_BIT 8
+static u64 mac2int(const u8 hwaddr[]) +{
s8 i;
Why does i need to be signed?
u64 ret = 0;
const u8 *p = hwaddr;
for (i = 5; i >= 0; i--)
ret |= (u64)*p++ << (CHAR_BIT * i);
return ret;
+static void int2mac(const u64 mac, u8 *hwaddr) +{
s8 i;
Ditto.
int ret;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
Better print all these error messages.
Same here.
These USB-related header files could be removed.
/* SDRAM ENV */
No error checking?
No error checking?
Not used anywhere. Please remove it.
+sd_dev=1
There is no splash screen support. Please remove it.
earlycon is only useful for development. Please remove it.
Please make it 'static'.
Is this needed?
Please use a more generic repo, such as NXP https://github.com/nxp-imx/imx-atf/ branch: lf_v2.8
Not needed to be done in this series, but in the future, it would be nice to convert this wdog driver to DM.
Hello Fabio,
I was testing on 2023.10. I rebased the series on `next` on my side. I had to do something similar to fb2bdc4efcb in order to fix booting.
Fixed.
I am not sure why but without this include, I have the following warning:
binman: Device tree 'u-boot.dtb' does not have a 'binman' node
which seem to indicate that this include is needed.
Noted.
I will send a v4 that should take all remarks into account.
Thanks,
Mathieu
Hi Mathieu,
Hello,
This v3 adds support for binman and documents how to build and flash a bootloader for the i.MX93 Variscite Symphony evaluation board.
Nice work! Thanks for adding i.MX93 binman support.
From a glance, the whole series looks good. I will take a closer look soon.
Cheers
Fabio Estevam
Mathieu Othacehe
Mathieu Othacehe
