[PATCH v3 0/3] Random Number Generator fixes
This series aim to fix smccc bind issue and add a list command for RNG devices.
Changelog:
v2 --> v3 - remove fallback smc call - add Fixes tag
v1 --> v2 - check SMCCC_ARCH_FEATURES - update commit message and rng help info
Weizhao Ouyang (3): firmware: psci: Fix bind_smccc_features psci check driver: rng: Fix SMCCC TRNG crash cmd: rng: Add rng list command
cmd/rng.c | 23 ++++++++++++++++++----- drivers/firmware/psci.c | 5 ++++- drivers/rng/smccc_trng.c | 2 +- include/linux/arm-smccc.h | 6 ++++++ 4 files changed, 29 insertions(+), 7 deletions(-)
According to PSCI specification DEN0022F, PSCI_FEATURES is used to check whether the SMCCC is implemented by discovering SMCCC_VERSION.
Signed-off-by: Weizhao Ouyang o451686892@gmail.com --- v3: remove fallback smc call v2: check SMCCC_ARCH_FEATURES --- drivers/firmware/psci.c | 5 ++++- include/linux/arm-smccc.h | 6 ++++++ 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/drivers/firmware/psci.c b/drivers/firmware/psci.c index c6b9efab41..03544d76ed 100644 --- a/drivers/firmware/psci.c +++ b/drivers/firmware/psci.c @@ -135,10 +135,13 @@ static int bind_smccc_features(struct udevice *dev, int psci_method) PSCI_VERSION_MAJOR(psci_0_2_get_version()) == 0) return 0;
- if (request_psci_features(ARM_SMCCC_ARCH_FEATURES) == + if (request_psci_features(ARM_SMCCC_VERSION) == PSCI_RET_NOT_SUPPORTED) return 0;
+ if (invoke_psci_fn(ARM_SMCCC_VERSION, 0, 0, 0) < ARM_SMCCC_VERSION_1_1) + return 0; + if (psci_method == PSCI_METHOD_HVC) pdata->invoke_fn = smccc_invoke_hvc; else diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index f44e9e8f93..da3d29aabe 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -55,8 +55,14 @@ #define ARM_SMCCC_QUIRK_NONE 0 #define ARM_SMCCC_QUIRK_QCOM_A6 1 /* Save/restore register a6 */
+#define ARM_SMCCC_VERSION 0x80000000 #define ARM_SMCCC_ARCH_FEATURES 0x80000001
+#define ARM_SMCCC_VERSION_1_0 0x10000 +#define ARM_SMCCC_VERSION_1_1 0x10001 +#define ARM_SMCCC_VERSION_1_2 0x10002 +#define ARM_SMCCC_VERSION_1_3 0x10003 + #define ARM_SMCCC_RET_NOT_SUPPORTED ((unsigned long)-1)
#ifndef __ASSEMBLY__
Hi Weizhao,
It makes sense to me, thanks.
Apart from ARM_SMCCC_VERSION_1_1, are the other ARM_SMCCC_VERSION_1_x defines needed ?
Cheers, Abdellatif
Hi Abdellatif,
On Thu, Feb 1, 2024 at 7:40 PM Abdellatif El Khlifi abdellatif.elkhlifi@arm.com wrote:
Hi Weizhao,
I'm trying to synchronize with linux kernel, it might be a bit odd to add only one version.
BR, Weizhao
Cheers, Abdellatif
Hello Weizhao,
Could you please add more details to your commit message or as a comment explaining what exact steps should be done for a full discovery sequence of Arm Architecture Service functions, so people don't need to search for that information explicitly?
For instance: Step 1: Determine if SMCCC_VERSION is implemented - Use firmware data, device tree PSCI node, or ACPI FADT PSCI flag, to determine whether a PSCI implementation is present. - Use PSCI_VERSION to learn whether PSCI_FEATURES is provided. PSCI_FEATURES is mandatory from version 1.0 of PSCI Step 2. etc.
I would just pull that info from the latest SMC Calling Convention version 1.5, from 9 Appendix B: Discovery of Arm Architecture Service functions.
Thank you!
IMO, to fully comply with SMC Calling Convention version 1.5 we should also check for SMCCC_ARCH_WORKAROUND_1:
From 9 Appendix B: Discovery of Arm Architecture Service functions,
Step 2: Determine if Arm Architecture Service function is implemented - Use SMCCC_VERSION to learn whether the calling convention complies to version 1.1 or above. - Use SMCCC_ARCH_FEATURES to query whether the Arm Architecture Service function is implemented on this system <--- we lack of this step
2.39.2
Hi Igor,
On Thu, Feb 1, 2024 at 10:36 PM Igor Opaniuk igor.opaniuk@foundries.io wrote:
Hello Weizhao,
Thank you!
From 9 Appendix B: Discovery of Arm Architecture Service functions, Step 2: Determine if Arm Architecture Service function is implemented
Thanks for your review. The 9 Appendix B describes an approach to discovery the maximize ability without causing unsafe behavior on existing platforms. Regarding the second step, it is just using SMCCC_ARCH_WORKAROUND_1 as an example to test SMCCC_ARCH_FEATURES.
For the U-Boot case, we can revisit this from two perspectives: 1. SMCCC_ARCH_FEATURES is MANDATORY from SMCCC v1.1. 2. SMCCC_VERSION is OPTIONAL for SMCCC v1.0, so we should consider a safe behavior. 3. U-Boot is using CONFIG_ARM_SMCCC_FEATURES to probe and bind SMCCC service driver if this driver is reported as supported. 4. U-Boot SMCCC service driver can embed its discovery process in is_supported() callback.
So now we can choose the following approach in U-Boot: - Use firmware data (check "arm,psci-1.0") to determine whether a PSCI implementation is present. - Use PSCI_VERSION (psci_0_2_get_version() major version >= 0) to learn whether PSCI_FEATURES is provided. - Use PSCI_FEATURES with the SMCCC_VERSION Function Identifier as a parameter to determine that SMCCC_VERSION is implemented. - Use SMCCC_VERSION to learn whether the calling convention complies to version 1.1 or above. - Trying to probe and bind SMCCC service driver.
BR, Weizhao
2.39.2
-- Best regards - Freundliche Grüsse - Meilleures salutations
Igor Opaniuk Senior Software Engineer, Embedded & Security E: igor.opaniuk@foundries.io W: www.foundries.io
Hello Weizhao,
On Fri, Feb 2, 2024 at 4:43 AM Weizhao Ouyang o451686892@gmail.com wrote:
Hi Igor,
Hello Weizhao,
Thank you!
- SMCCC_ARCH_FEATURES is MANDATORY from SMCCC v1.1.
- SMCCC_VERSION is OPTIONAL for SMCCC v1.0, so we should consider a
Thanks for the detailed explanation! Reviewed-by: Igor Opaniuk igor.opaniuk@foundries.io
BR, Weizhao
2.39.2
Fix a SMCCC TRNG null pointer crash due to a failed smccc feature binding.
Fixes: 53355bb86c25 ("drivers: rng: add smccc trng driver") Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Weizhao Ouyang o451686892@gmail.com --- v3: add Fixes tag --- drivers/rng/smccc_trng.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/rng/smccc_trng.c b/drivers/rng/smccc_trng.c index 3a4bb33941..3087cb991a 100644 --- a/drivers/rng/smccc_trng.c +++ b/drivers/rng/smccc_trng.c @@ -166,7 +166,7 @@ static int smccc_trng_probe(struct udevice *dev) struct smccc_trng_priv *priv = dev_get_priv(dev); struct arm_smccc_res res;
- if (!(smccc_trng_is_supported(smccc->invoke_fn))) + if (!smccc || !(smccc_trng_is_supported(smccc->invoke_fn))) return -ENODEV;
/* At least one of 64bit and 32bit interfaces is available */
Reviewed-by: Matthias Brugger mbrugger@suse.com
v3: add Fixes tag
-- 2.39.2
The 'rng list' command probes all RNG devices and list those devices that are successfully probed. Also update the help info.
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Weizhao Ouyang o451686892@gmail.com --- cmd/rng.c | 23 ++++++++++++++++++----- 1 file changed, 18 insertions(+), 5 deletions(-)
diff --git a/cmd/rng.c b/cmd/rng.c index 52f722c7af..b073a6c849 100644 --- a/cmd/rng.c +++ b/cmd/rng.c @@ -19,6 +19,22 @@ static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) struct udevice *dev; int ret = CMD_RET_SUCCESS;
+ if (argc == 2 && !strcmp(argv[1], "list")) { + int idx = 0; + + uclass_foreach_dev_probe(UCLASS_RNG, dev) { + idx++; + printf("RNG #%d - %s\n", dev->seq_, dev->name); + } + + if (!idx) { + log_err("No RNG device\n"); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; + } + switch (argc) { case 1: devnum = 0; @@ -56,12 +72,9 @@ static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) return ret; }
-U_BOOT_LONGHELP(rng, - "[dev [n]]\n" - " - print n random bytes(max 64) read from dev\n"); - U_BOOT_CMD( rng, 3, 0, do_rng, "print bytes from the hardware random number generator", - rng_help_text + "list - list all the probed rng devices\n" + "rng [dev] [n] - print n random bytes(max 64) read from dev\n" );
- if (argc == 2 && !strcmp(argv[1], "list")) {
int idx = 0;
idx++;
if (!idx) {
- switch (argc) { case 1: devnum = 0;
- "[dev [n]]\n"
- rng_help_text
- "list - list all the probed rng devices\n"
- "rng [dev] [n] - print n random bytes(max 64) read from dev\n"
2.39.2
int idx = 0;
idx++;
if (!idx) {
"[dev [n]]\n"
rng_help_text
2.39.2
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Weizhao Ouyang o451686892@gmail.com Reviewed-by: Matthias Brugger mbrugger@suse.com Reviewed-by: Igor Opaniuk igor.opaniuk@foundries.io
Please update doc/usage/cmd/rng.rst as well, thanks.
Hi Tom,
Ok, I will update it.
BR, Weizhao
-- Tom
participants (5)
Igor Opaniuk
Matthias Brugger
Weizhao Ouyang
