[U-Boot] [PATCH] clk: sifive: Fix ethernet regression on HiFive Unleashed
Commit ed0ef37 broke compatibility with HiFive Unleashed with SiFive FSBL 2018-03-20. This caused ethernet to stop working. Restore compatibility by adding back the needed compatible string, and removing the special handling of rtcclk which was dead code anyway since no __prci_clock actually names "rtcclk" as its parent.
Signed-off-by: Marcus Comstedt marcus@mc.pp.se Cc: Anup Patel Anup.Patel@wdc.com --- drivers/clk/sifive/fu540-prci.c | 11 ++--------- 1 file changed, 2 insertions(+), 9 deletions(-)
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index ce0769f2d1..78a9fe3770 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -160,7 +160,6 @@ struct __prci_data { void *va; struct clk parent_hfclk; - struct clk parent_rtcclk; };
/** @@ -538,10 +537,7 @@ static ulong sifive_fu540_prci_parent_rate(struct __prci_clock *pc) return p->ops->recalc_rate(p, sifive_fu540_prci_parent_rate(p)); }
- if (strcmp(pc->parent_name, "rtcclk") == 0) - parent_rate = clk_get_rate(&pc->pd->parent_rtcclk); - else - parent_rate = clk_get_rate(&pc->pd->parent_hfclk); + parent_rate = clk_get_rate(&pc->pd->parent_hfclk);
return parent_rate; } @@ -593,10 +589,6 @@ static int sifive_fu540_prci_probe(struct udevice *dev) if (err) return err;
- err = clk_get_by_index(dev, 1, &pd->parent_rtcclk); - if (err) - return err; - for (i = 0; i < ARRAY_SIZE(__prci_init_clocks); ++i) { pc = &__prci_init_clocks[i]; pc->pd = pd; @@ -614,6 +606,7 @@ static struct clk_ops sifive_fu540_prci_ops = {
static const struct udevice_id sifive_fu540_prci_ids[] = { { .compatible = "sifive,fu540-c000-prci" }, + { .compatible = "sifive,aloeprci0" }, { } };
Hi Marcus,
I believe the officially supported booting workflow is to use the latest DT from Linux and compile it into OpenSBI, then boot to U-Boot. The original DT shipped by FSBL is not used by OpenSBI or U-Boot.
Regards, Bin
Hi Bin,
Bin Meng bmeng.cn@gmail.com writes:
Ok, if U-Boot uses a DT compiled into OpenSBI then the incompatibility is with OpenSBI v0.4 (the latest release) because that's what I'm running. In any case it is a regression since the same setup worked with U-Boot v2019.07.
// Marcus
Hi Marcus,
On Sun, Sep 8, 2019 at 8:54 PM Marcus Comstedt marcus@mc.pp.se wrote:
Hi Bin,
OpenSBI v0.4 works fine if you supply the the Linux DTB via FW_PAYLOAD_FDT_PATH when building OpenSBI.
Regards, Bin
And which "Linux DTB" should that be? Since RISC-V seems to be going the same annoying way as ARM with a requirement that you switch DTB every time you switch kernel version even though the hardware the DTB describes stays the same, because the syntax of the nodes keep changing, it's necessary to decide on a specific firmware DTB which is decoupled from the Linux DTB (which can be loaded separately from U-Boot as long as the ethernet/MMC drivers are working :-).
If U-Boot needs a specific DTB, shouldn't it be shipped in u-boot/arch/riscv/dts/?
// Marcus
Hi Marcus,
The one in arch/riscv/boot/dts/sifive.
Yes, it's annoying for ARM. Hence I believer on RISC-V the goal is to use the firmware provided DTB for all the software on the boot chain: OpenSBI, U-Boot, kernel. That's why U-Boot RISC-V is currently using OF_PRIOR_STAGE.
As for the syntax of the nodes keep changing, I would say that's inevitable because of the upstreaming process. Everything in vendor's DT that does not get merged in Linux will remain potentially changed by later upstreaming reviews.
This can be done by adding OF_SEPERATE support to RISC-V. But so far OF_PRIOR_STAGE already works hence adding that would be of low priority.
Regards, Bin
Hi Bin,
Yes, but in which Linux? This whole thing started because U-Boot will no longer accept the DTB used with Linux 4.14. If each Linux version is going to have its own incompatible DTB then U-Boot either needs to decide which one to work with, or work with the vendor DTB (which would be perferable in my opinion).
An upstreaming review that suggests changing a driver so that it no longer works with the vendor's DTB is IMHO contraproductive and against the very idea of DTB, but I suppose there's little that can be done to affect the review process over at Linux land... It would be nice if this weirdness did not spill over on U-Boot/OpenSBI though.
// Marcus
Hi Marcus,
On Sun, Sep 8, 2019 at 10:48 PM Marcus Comstedt marcus@mc.pp.se wrote:
Hi Bin,
The latest Linux kernel v5.3.
I checked kernel 4.14 and found it did not ship the SiFive Unleased board DTS in the kernel tree. Are you sure it's 4.14?
I don't think Linux is to be blamed for this case. They have a policy to maintain the the backward compatibility for the DT land. The issue what you were facing here is an out of tree DTB (the vendors') is incompatible with the kernel's. Once the kernel accepts a DTS, bringing in any out-of-tree DT with changes reviewed to in-tree, future compatibility will be assured.
Regards, Bin
Hi Bin,
Thanks. I'll try it later. As if to prove my point, the one from 5.2.11 (which is the Linux version I'm currently running) did not work (I got MMC but no ethernet)...
It's the one shipped with the H5U, which I'm pretty sure ran Linux 4.14 at the time (as part of the "Freedom U SDK") since 4.15 was not out yet. It looks like SiFive never added the DTS to their own Linux tree (https://github.com/sifive/riscv-linux).
Isn't the reason that the DTS accepted by the kernel is different from the out-of-tree vendor one that the review process caused changes in the DTS then? It seems unlikely that the vendor (SiFive) would deliberately submit an incompatible DTS for inclusion...
// Marcus
Hi Marcus,
On Tue, Sep 10, 2019 at 4:52 AM Marcus Comstedt marcus@mc.pp.se wrote:
Hi Bin,
Maybe Anup could chime in for various SiFive kernel driver upstream history. My memory was that before all these drivers were upstreamed, we were using SiFive's out-of-tree kernel and drivers.
So 4.14 definitely was an out-of-tree kernel since I did not see the SiFive DTS in the mainline kernel. For the DTS it was passed all the way from FSBL to BBL to kernel.
Well, that's the normal upstream process we have to live with. It's nothing to do with whether that's a DT change, or a feature design change. No one can guarantee an out-of-tree implementation will be keeping compatible after it's accepted in-tree. Reviewers/maintainers may have different view from the author on what's the best to be included in the kernel mainline and this may require the author to change the implementation and break something ...
Regards, Bin
Hi Bin,
Everything before 5.2 was out-of-tree.
Reviewers/maintainers can guarantee compatibility with existing hardware and DT by not instisting on breaking changes.
It's not really about keeping in-tree and out-of-tree compatible with each other, but about keeping both of them compatible with the actual hardware and DT of the system the OS is supposed to run on.
A reviewer/maintainer could for example have the view that a certain register in a piece of hardware should really be two registers with the bits divided between them based on some logical partitioning. And they might be right. But the hardware is what it is, and if they insist that the driver access two different registers the driver will not work the hardware. You'll have a nice driver that works on nothing (at least until the vendor makes a new spin of the hardware with the two registers).
My opinion is that the DT should be treated the same way. It is part of the hardware (sort of the "metadata" for the hardware). Sure you can have some idea of how things could be expressed better and add support for that, but you need to also keep compat with the actual hardware platform that the driver is there to interface against, otherwise the driver won't work.
// Marcus
Hi Marcus,
On Tue, Sep 10, 2019 at 11:53 PM Marcus Comstedt marcus@mc.pp.se wrote:
Hi Bin,
Per my understanding kernel reviewers/maintainers want to have a clean implementation from the start. That's why it's being done this way.
The original hardware vendor's DT may be written in a way that violates the DT specs. Hence I believe it's really hard to keep the comparability for both.
For this specific FU540 ethernet, what you did in this patch does not completely bring back the compatibility. Things were changed a lot in the upstream kernel.
For example, the U-Boot GEM GXL-MGMT driver was needed to work with SiFive's DT https://lists.denx.de/pipermail/u-boot/2019-May/369577.html
But later, it was dropped due to kernel mainline DT reviewers/maintainers thought it was a misuse of clock node and the GXL-MGMT module should be part of the GEM spec. https://lists.denx.de/pipermail/u-boot/2019-June/373306.html
While I agree with you to some extent that, that's now how things are done with current kernel practice.
Regards, Bin
On Wed, Sep 11, 2019 at 7:28 AM Bin Meng bmeng.cn@gmail.com wrote:
Hi Marcus,
Hi Bin,
Sorry for the slow response...
The DT bindings for most of the Linux drivers accepted upstream have changed in a backward in-compatible way for SiFive Unleashed. The Linux clock driver implementation also changed quite a bit.
Most of the recent U-Boot changes for SiFive Unleashed were to sync-up DT bindings followed by U-Boot drivers with SiFive Unleashed drivers accepted in Linux. The built-in DTB passed by FSBL to OpenSBI + U-Boot is totally out-of-date. Going forward SiFive folks will use upstreamed Linux DT bindings for newer platforms so it made sense to update U-Boot drivers.
The root of the problem is delay in freezing DT bindings by SOC vendors.
I think the SOC vendors should get DT bindings reviewed very early before sending patches to Linux or U-Boot. The Linux kernel is still a central place for all DT bindings documentation across architectures.
May be things would be different if DT bindings documentation was maintained as separate project ???
For now, we can insist SOC vendors to get DT bindings reviewed/froozen in LKML before sending U-Boot driver patches. Suggestions ??
Regards, Anup
Regards, Bin _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
+devicetree
Hi Marcus,
Hi Bin,
The question is when we can call that "very early"? Normally SoC vendors will ship their own software stack (bootloaders, kernels, dtb) on their evaluation board and provided forked git repos of these software for their customers, aka SDK. If we expect bringing DT bindings in a very early phase to fix such compatibility problem, that means SoC vendors cannot ship their SDK to their customers before every DT bindings used in their SoC get reviewed and approved. That sounds unrealistic.
I vaguely remember a similar proposal was once discussed in the LKML. If we manage to go with that direction, I think we should also request all DTS files to be dual licensed with one BSD-style permissive license model for other projects to use.
So U-Boot upstream drivers always work with upstream DT in Linux kernel. Sounds good to me. But again this does not help with the out-of-tree U-Boot fork provided by the SoC vendor to their customers ...
Regards, Bin
Anup Patel
Bin Meng
Marcus Comstedt
